Kubota Utility Tractors M5700DT-CAB Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M5700DT-CAB Utility Tractors
Number of Pages: 302 Pages
Frequently Used Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse [Type Cabine] / Cylinder Head [Cab Typ E]
Kit D'accouplements Rapides [Option] / Gear Ca Se
Couvre-Culasse / Head Cover
Arbre A Cames Et Arbre De Pignon Fou / Camshaf T And Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames Dalimentation / Fuel Camshaft
Levier D Arret Du Moteur / Engine Stop Lever
Plaque De Limiteur De Vitesse / Speed Control Plate
Porte-Injecteur Et Bougie De Prechauffage [Typ E Cabine] / Nozzle Holder And Glow Plug [Cab Type]
Bride A Eau Et Thermostat [Type Cabine] / Wate R Flange And Thermostat [Cab Type]
Pompe A Eau / Water Pump
Collecteur D'echappement [Type Cabine] / Exhau St Manifold [Cab Type]
Filtre A Air [Type Cabine] / Air Cleaner [Cab Type]
Filtre A Air [Parties Composantes] / Air Clean Er [Component Parts]
Silencieux [Type Cabine] / Muffler [Cab Type]
Jeu De Joint Superieur [Option] / Upper Gasket Kit [Option]
Jeu De Joint Inferieur [Option] / Lower Gasket Kit [Option]
Levier D'accelerateur [Type Cabine] / Hand Acc Elerator Lever [Cab Type]
Pedale D'accelerateur [Type Cabine] / Accelera Tor Pedal [Cab Type]
Tringle D'accelerateur [Type Cabine] / Acceler Ator Rod [Cab Type]
Solenoide D'arret/Cable D'arret Du Moteur [Typ E Cabine] / Stop Solenoid/Engine Stop Wire [Cab Typ E]
Reservoir A Carburant Droite [ Type Cabine] / Fuel Tank Rh [Cab Type]
Reservoir A Carburant Gauche [ Type Cabine] / Fuel Tank Lh [Cab Type]
Tuyau A Carburant 1 (Arriere) [Type Cabine] / Fuel Pipe 1 (Rear) [Cab Type]
Tuyau A Carburant 2 (Avant) [T Ype Cabine] [Type Vieux] / Fuel Pipe 2 (Front) [Cab Type] [Old Type]
Tuyau A Carburant 2 (Avant) [T Ype Cabine] [Type Nouveau] / Fuel Pipe 2 (Front) [C Ab Type] [New Type]
Separateur [Type Cabine] / Se Parator [Cab Type]
Separateur [Parties Composante S] [Type Cabine] / Separator [Component Parts] [Cab Type]
Filtre A Carburant [Parties Co Mposantes] [Type Cabine] / Fuel Filter [Component P Arts] [Cab Type]
Ventilateur [Type Cabine] / Fan [Cab Type]
Tuyau De Eau [Typ E Cabine] / Water Pipe [Cab Type]
Radiateur [Type C Abine] / Radiator [Cab Type]
Vase De Expansion [Type Cabine] / Reserve Tank [Cab Type]
Alternateur [Type Cabi Ne] / Alternator [Cab Type]
Alternateur [Parties C Omposantes] [Type Cabine] / Alternator [Component P Arts] [Cab Type]
Lanceur / Starter
Lanceur / Starter
Demarreur [Parties Com Posantes] / Starter [Component Parts]
Batterie [Type Cabine] / Battery [Cab Type]
Commutateur/Detector [ Type Cabine] / Switch/Sensor [Cab Type]
Commutateur (Tableau D E Bord) [Type Cabine] / Switch (Panel Board) [Cab T Ype]
Commutateur [Type Cabi Ne] / Switch [Cab Type]
Relais [Type Cabine] / Relay [Cab Type]
Relais De Demarreur [T Ype Cabine] / Starter Relay [Cab Type]
Tableau De Bord [Type Cabine] / Panel Board [Cab Type]
Tableau De Bord [Parti Es Composantes][Type Cabine] / Panel Board [Compone Nt Parts] [Cab Type]
Phare / Head Light
Feux De Detresse [Type Cabine] / Hazard Light [Cab Type]
Lumiere De Travail [Ty Pe Cabine] / Work Light [Cab Type]
Feux Arriere [Type Cab Ine] / Rear Combination Light [Cab Type]
Plafonnier [Type Cabin E] / Room Light [Cab Type]
Cuve De Lavage [Type C Abine] / Washer Tank [Cab Type]
Essuie-Glase [Type Cab Ine] / Wiper [Cab Type]
Faisceau Electrique 1 [Type Cabine] / Electrical Wiring 1 [Cab Type]
Faisceau Electrique (C Abine) [Type Cabine] / Electrical Wiring (Cab) [Cab Type]
Carter De Embraya Ge [Type Cabine] / Clutch Housing [Cab Type]
Boite D'engrenage / Shuttle Gear Case
Carter Intermedia Ire [Type Cabine] / Mid Case [Cab Type]
Carter De Transmi Ssion [Type Cabine] / Transmission Case [Cab Type]
Couvrcle De Carte R De Boite Arriere / Transmission Case Rear Cover
Carter Pont Arrie Re / Rear Axle Case
Carter Entraineme Nt / Front Drive Case
Embrayage / Clutc H
Fourchette De Emb Rayage [Type Cabine] / Clutch Release Fork [Cab Typ E]
Pedale De Embraya Ge [Type Cabine] / Clutch Pedal [Cab Type]
Arbre De Entree / Input Shaft
Premier Arbre / F Irst Shaft
Deuxieme Arbre / Second Shaft
Troisiem Arbre [T Ype Cabine] / Third Shaft [Cab Type]
Arbre De Marche A Rriere / Back Idle Shaft
Engrenage Conique [Type Vieux] / Bevel Gear [Old Type]
Engrenage Conique [Type Nouveau] / Bevel Gear [New Type]
Differentiel Arri Ere / Differential Rear
Arbre De Transmis Sion Pdf [Type Cabine] / Pto Propeller Shaft [Cab T Ype]
Pdf Embrayage / P To Clutch
Embrayage Pdf [Pa Rties Composantes] / Pto Clutch [Component Parts]
Soupape D'embraya Ge Pdf / Pto Clutch Valve
Soupape D'embraya Ge Pdf [Parties Composantes] / Pto Clutch Valve [C Omponent Parts]
Arbre De Transmis Sion (Arriere) / Front Propeller Shaft (Rear)
Fourchette De Ch Angement De Vitesses / Main Gear Shift Fork
Fourchtte De Inv Erseur / Shuttle Gear Shift Fork
Fourchette De Ch Angement De Vitesses [Type Cabine] / Range Gear Shi Ft Fork [Cab Type]
Fourchtte De Pdf / Pto Shift Fork
Fourchette De Bl Ocage Differentiel / Rear Differential Lock Shift F Ork
Levier De Cahnge Ment De Vitesses Principal [Type Cabine] / Main Gea R Shift Lever [Cab Type]
Tige De Changeme Nt De Vitesses Principal [Type Cabine] / Main Gear Shift Rod [Cab Type]
Arbre De Changem Ent De Vittesses Principal [Type Cabine] / Main Gea R Shift Lever Shaft [Cab Type]
Levier De Invers Eur [Type Cabine] / Shuttle Shift Lever [Cab Type]
Tige De Inverseu R [Type Cabine] / Shuttle Shift Rod [Cab Type]
Levier De Change Ment De Vitesses [Type Cabine] / Range Gear Shift L Ever [Cab Type]
Levier De Comman De De Embrayage Pdf [Type Cabine] / Pto Clutch Leve R [Cab Type]
Levier De Transm Ission Aux Roues Avant [Type Cabine] / Front Wheel Drive Lever [Cab Type]
Axe Arriere / Rear Axle
Frein / Brake
Tige De Frein 1 [Type Cab Ine] / Brake Rod 1 [Cab Type]
Tige De Frein 2 [Type Cab Ine] / Brake Rod 2 [Cab Type]
Levier De Frein Stationne Ment [Type Cabine] / Parking Brake Lever [Cab Type]
Tige De Frein Stationneme Nt [Type Cabine] [Type Vieux] / Parking Brake Rod [ Cab Type] [Old Type]
Tige De Frein Stationneme Nt [Type Cabine] [Type Nouveau] / Parking Brake Rod [Cab Type] [New Type]
Pedale De Frein [Type Cab Ine] / Brake Pedal [Cab Type]
Pedale Bloc.Differentiel Arriere [Type Cabine] / Rear Differential Lock Peda L [Cab Type]
Chassis Avant [Type Ca Bine] / Front Axle Frame [Cab Type]
Arbre De Transmission / Front Propeller Shaft
Avant Carter De Differ Entiel / Front Differential Case
Engrenage Conique (Ava Nt) / Bevel Gear (Front)
Differentiel Avant / D Ifferential Front
Carter Reducteur / Fro Nt Axle Case
Demi Arbre De Pont Ava Nt / Differential Gear Shaft
Pont Avant / Front Axl E
Volant De Direction [Type Cabine] / Steer Ing Handle [Cab Type]
Joint De Cardan De Direction [Type Cabine ] / Steering Joint [Cab Type]
Servo Direction [Type Cabine] / Steering Controller [Cab Type]
Servo Direction [Parties Composantes] / S Teering Controller [Component Parts]
Timoner De Direction / Steering Linkage
Cylindre De Direction [ Parties Composantes] / Steering Cylinder [Component Parts]
Support Avant Droit / H Ydraulic Pump
Pompe Hydraulique [Part Ies Composantes] / Hydraulic Pump [Component Parts]
Circuit De Huile Hydrau Lique (Aspiration) [Type Cabine] / Hydraulic Pipe ( Suction) [Cab Type]
Circuit De Huile Hydrau Lique (Refoulement) [Type Cabine] / Hydraulic Pipe (Delivery) [Cab Type]
Circuit D'huile Hydraul Ique (Refroidisseur) [Type Cabine] / Hydraulic Oil Line (Oil Cooler) [Cab Type]
Circuit D'huile Hydraul Ique (Direction/Pdf) [Type Cabine] / Hydraulic Oil Line (Steering/Pto) [Cab Type]
Tuyau De Direction (Ref Oulement) [Type Cabine] / Steering Hose (Delivery) [Cab Type]
Cylindre Hydraulique [T Ype Cabine] / Hydraulic Cylinder [Cab Type]
Bras De Relevage / Hydr Aulic Lift Arm
Couvercle De Cylindre H Ydraulique [Type Cabine] / Hydraulic Cylinder Cover [Cab Type]
Distributeur Hydrauliqu E / Control Valve
Levier De Controle De P Osition Et D'effort [Type Cabine] / Draft And Posit Ion Control Lever [Cab Type]
Support De Levier De Co Nt.De Position Et D'effort[Cab Type][Type Cabine] / Draft And Position Control Lever Bracket
Arbre De Controle De Po Sition / Position Control Shaft
Arbre De Controle D'eff Ort / Draft Control Shaft
Levier De Controle De P Osition / Feed Back Lever
Valve Auxiliaire [Type Cabine] / Auxiliary Control Valve [Cab Type]
Valve Auxiliaire [Parti Es Composantes] [Type Cabine] / Auxiliary Control V Alve[Component Parts][Cab Type]
Levier De Contorle De D Istributeur Auxiliaire [Type Cabine] / Auxiliary Co Ntorol Valve Lever [Cab Type]
Support De Tirant Superieur [Type Cab Ine] / Top Link Bracket [Cab Type]
Tirant Superieur [Type Cabine] / Top Link [Cab Type]
Bras Inferieurs [Type Cabine] [Type N Ouveau] / Lower Link [Cab Type] [New Type]
Barre De Relevage Droite / Lift Rod R H
Barre De Relevage Gauche / Lift Rod L H
Barre De Attelage [Type Cabine] / Swi Nging Drawbar [Cab Type]
Protecteur Pdf / Pto Shaft Protector
Capot Avant [Type Cabine] / Hood(Bonnet) F Ront [Cab Type]
Capot Superieur [Type Cabine] / Hood(Bonne T) Upper [Cab Type]
Capot Lateral [Type Cabine] / Hood(Bonnet) Side [Cab Type]
Capot De Couvercle Lateral [Type Cabine] / Hood(Bonnet) Side Cover [Cab Type]
Support De Capot [Type Cabine] / Bonnet Su Pport [Cab Type]
Cardre [Type Cabine] / Cab Frame [Cab Type]
Cadre De Panneau [Type Cabine] / Panel Frame [Cab Type]
Glace Avant [Type Cabine] / Front Glass [Cab Type ]
Porte Droite [Type Cabine] / Door Rh [Cab Type]
Serrure De Porte Droite [Type Cabine] / Door Lock Rh [Cab Type]
Serrure Porte Gauche [Type Cabine] / Door Lock Lh [Cab Type]
Fenetre Laterale [Type Cabine] / Side Window [Cab Type]
Vitre Arriere [Type Cabine] / Rear Window [Cab Ty Pe]
Retroviseur [Type Cabine] / Rearview Mirror [Cab Type]
Toit Interne [Type Cabine] / Inner Roof [Cab Type ]
Toit Externe [Type Cabine] / Outer Roof [Cab Type ]
Siege [Type Cabine] / Seat [Cab Type]
Tapis [Type Cabine] / Floor Mat [Cab Type]
Couvercle De Aile Gauche [Type Cabine] / Fender C Over Lh [Cab Type]
Couvercle De Cadre [Type Cabine] / Pillar Cover [ Cab Type]
Aile Droite [Type Cabine] / Fender Rh [Cab Type]
Aile Gauche [Type Cabine] / Fender Lh [Cab Type]
Support De Cabine Avant [Type Cabine] / Cab Brack Et Front [Cab Type]
Support De Cabine Arriere [Type Cabine] / Cab Bra Cket Rear [Cab Type]
Boite Outils [Type Cabine] / Tool Box [Cab Type]
Air Conditionneur [Type Ca Bine] / Air Conditioner [Cab Type]
Tuyau De Chauffage [Type C Abine] / Heater Hose [Cab Type]
Condensateur [Type Cabine] [Type Vieux] / Condenser [Cab Type] [Old Type]
Condensateur [Type Cabine] [Type Nouveau] / Condenser [Cab Type] [New Type] # # S.No.;D:>=52753 / S.No.;D:>=52753
Compresseur [Type Cabine] [Type Vieux] / Compressor [Cab Type] [Old Type]
Compresseur [Type Cabine] [Type Nouveau] / Compressor [Cab Type] [New Type] # # S.No.;D:>=52753 [Note:Order By Ref.No.060 New Par T.] / [Note:Order By Ref.No.060 New Part.]
Roue Avant (8,3-24) [Opti On] / Front Wheel (8.3-24) [Option]
Roue Arriere (16,9-28) [O Ption] / Rear Wheel (16.9-28) [Option]
Roue Arriere (14,9-28) [O Ption] / Rear Wheel (14.9-28) [Option]
Etiquette 1 [Type Cabine] / Label 1 [Cab T Ype]
Etiquette 2 [Type Cabine] / Label 2 [Cab T Ype]
Accessories Et Piece De Service / Ac Cessories And Service Parts
Levier Raccord / Lever Joint Stay Kit
Prise De Remorque [Type Cabine] [Option] / Tra Iler Socket Kit [Cab Type] [Option]
Radio-Cassette [Type Cabine] [Option] / Radio Cassette Kit [Cab Type] [Option]
Essuie-Glase [Type Cabine] [Type Vieux] [Optio N] / Rear Wiper Kit [Cab Type] [Old Type] [Option]
Essuie-Glase [Type Cabine] [Type Nouveau] [Opt Ion] / Rear Wiper Kit [Cab Type] [New Type] [Option ]
Valve Auxiliaire (Scd) [Type Cabine] [Option] / Auxiliary Control Valve Kit(Scd)[Cab Type] [Optio N]
Valve Auxiliaire (Fd) [Type Cabine] [Option] / Auxiliary Control Valve Kit(Fd) [Cab Type] [Option ]
Valve Auxiliaire (Scd/Fc) [Type Cabine] [Optio N] / Auxiliary Control Valve Kit (Scd/Fc) [Cab Type ] [Option]
Valve Auxiliaire(Scd)[Parties Composantes][Typ E Cabine][Option] / Auxiliary Control Valve(Scd)[Co Mponent Parts][Cab Type][Option]
Valve Auxiliaire(Fd)[Parties Composantes][Type Cabine][Option] / Auxiliary Control Valve(Fd)[Comp Onent Parts][Cab Type][Option]
Valve Auxiliaire (Scd/Fc) [Parties Composantes ][Type Cabine][Option] / Auxiliary Control Valve (S Cd/Fc) [Component Parts][Cab Type][Option]
Levier De Commande (2eme) [Type Cabine] [Optio N] / Auxilairy Control Valve Lever Kit (2nd)[Cab Ty Pe] [Option]
Levier De Commande (3eme) [Type Cabine] [Optio N] / Auxilairy Control Valve Lever Kit (3rd) [Cab T Ype] [Option]
