Kubota Utility Tractors M5400DT-N-EU Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M5400DT-N-EU Utility Tractors
Number of Pages: 216 Pages
Frequently Used Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Pistons Et Vilebrequin / Piston And Crankshaf T
Volant Du Moteur / Flywheel
Culasse / Cylinder Head
Porte-Injecteur/Bougies De Pre-Chauffage / No Zzle Holder/Glow Plug
Porte-Injecteur [Parties Composantes] / Nozzl E Holder [Component Parts]
Couvre-Culbuters / Cylinder Head Cover
Filtre A Air / Air Cleaner (Double)
Filtre A Air [Parties Composantes] / Air Clea Ner (Double) [Component Parts]
Silencieux / Under Muffler
Arbre A Cames / Camshaft
Kit D'accouplements Rapides [Option] / Gear C Ase
Pompe A Eau / Water Pump
Kit D'accouplements Rapides [Option] / Water Flange And Thermostat
Arbre A Cames Dalimentation / Fuel Camshaft
Levier D Arret Du Moteur / Engine Stop Lever
Plaque De Limiteur De Vitesse / Speed Control Plate
Levier D' Accelerateur / Hand Accelerator Lev Er
Cable D' Arret / Engine Stop Wire
Reservoir Carb. / Fuel Tank
Filtre A Carburant/Tuyau A Ca Rburant / Fuel Filter/Fuel Pipe
Filtre A Carburant [Parties C Omposantes] / Fuel Filter [Compnent Parts]
Radiateur / Radi Ator
Tuyau D'eau / Wa Ter Pipe
Ventilateur / Fa N
Ventilateur / Fa N
Alternateur Complet / Alternator
Alternateur [Parties Composantes][Type Vieux] / Alternator [Compnent Par Ts][Old Type]
Lanceur / Starter
Lanceur / Starter
Lanceur / Starter
Demarreur [Parties Co Mposantes] / Starter [Component Parts]
Batterie / Battery
Tableau De Bord / Pan El Board
Tableau De Bord (Piec Es Composantes) / Panel Board [Component Parts]
Commutateur / Switch
Phare / Head Light
Lampe / Light
Eclairage De Travail [Option] / Working Light Kit [Option]
Kit D'accouplements R Apides [Option] / Trailer Socket Kit [Option]
Faisceau Electrique / Electrical Wiring
Embrayage / Clutch
Pedala D'embrayage / Clutch Pedal
Carter De Transmission / Transmis Sion Case
Support De Roulement / Bearing Ho Lder
Arbre D'entree/Arbre Premier / In Put Shaft/First Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Vitesse Ranpante / Creep
Arbre De Transmission Pdf / Pto P Ropeller Shaft
Pdf Embrayage / Pto Clutch
Soupape D'embrayage Pdf / Pto Clu Tch Valve
Soupape D'embrayage Pdf [Parties Composantes] / Pto Clutch Valve [Component Parts]
Arbre De Pdf/Protecteur Pdf / Pto Shaft/Pto Protector
Levier De Changement Vitesses Principal / Main Gear Shift Le Ver
Fourchett E De Changement De Vitesses / Range Gear Shift Fork
Levier De Changement Vitesses Lente Et Rapide / Range Gear S Hift Lever
Levier Pd F / Pto Gear Shift Lever
Levier D' Embrayage Pdf [Type Vieux] / Pto Clutch Control Lev Er [Old Type]
Levier D' Embrayage Pdf [Type Nouveau] / Pto Clutch Control L Ever [New Type]
Engrenage Co Nique (Arriere) / Bevel Gear (Rear)
Differentiel (Arriere) / Differential (Rear)
Pedale Bloc Diffrentiel / Differential Lock Pedal
Axe Arriere / Rear Axle
Roue Arriere (12,4-24fl) / Rear Wheel (12.4-24fl)
Roue Arriere (14,9-24fl) / Rear Wheel (14.9-24fl)
Frein / Brake
Pedale De Frien / Brake Pedal
Tige De Frein / Brake Rod
Frein De Stationnement [Option] / Parking Brake Kit [Option]
Arbre De Entrainement Avant / Front Wheel Drive Shaft
Arbre De Transmission [Type Vieux] / Propeller Shaft [Old Type]
Arbre De Transmission [Type Nouveau] / Propeller Shaft [New Type]
Differentiel (Avant) / Differential (Front)
Demi Arbre De Pont Av Ant / Differential Gear Shaft
Carter De Engrenage C Onique / Bevel Gear Case
Pont Avant / Front Ax Le
Levier De Tranission Aux Roues Avant / Front Wheel Drive Lever
Roue Avant (8-16) / F Ront Wheel (8-16)
Roue Avant (9,5-16) / Front Wheel (9.5-16)
Timoner De Direction / Steering Linkage
Cylindre De Direction [Parties Composant Es] / Steering Cylinder [Component Parts]
Volant De Direction/Servo Direction / St Eering Handle/Steering Controller
Servo Direction [Parties Composantes] / Steering Controller [Component Parts]
Circuit D'huile Hydrau Lique (Direction/Pdf) / Hydraulic Oil Line (Steerin G/Pto)
Support Avant Droit / Hydraulic Pump
Pompe Hydraulique [Par Ties Composantes] / Hydraulic Pump [Component Parts ]
Circuit D'huile Hydrau Lique / Hydraulic Oil Line
Cylindre Hydraulique / Hydraulic Cylinder
Couvercle De Cylindre Hydraulique [Type Vieux] / Hydraulic Cylinder Cover [Old Type]
Couvercle De Cylindre Hydraulique [Type Nouveau] / Hydraulic Cylinder Cov Er [New Type]
Clapet De Curcharge/Cl Apet De Decharge / Safety Valve/Relief Valve [Compo Nent Parts]
Bras De Relevag Hydrau Lique / Hydraulic Lift Lever
Distributeur Hydrauliq Ue / Control Valve
Levier De Revenue 1 / Feed Back Lever 1
Levier De Revenue 2 / Feed Back Lever 2
Levier De Revenue 3 / Feed Back Lever 3
Levier De Command De T Raction/Levier De Position 1 / Draft And Position C Ontrol Lever 1
Levier De Command De T Raction/Levier De Position 2 / Draft And Position C Ontrol Lever 2
Valve Auxiliaire / Aux Iliary Control Valve (Scd)
Valve Auxiliaire [Opti On] / Auxiliary Control Valve (Scd) [Option]
Valve Auxiliaire [Part Ies Composantes][Type Vieux] / Auxiliary Control Va Lve (Scd) [Component Parts]
Valve Auxiliaire [Part Ies Composantes] / Auxiliary Control Valve (Scd) [C Omponent Parts]
Relevage 3 Points 1 (T Irant Suprieur) / Hydraulic Lift Link 1 (Top Link)
Relevage 3 Points 2 (B Ras Inferieur) / Hydraulic Lift Link 2 (Lower Link)
Relevage 3 Points 3 (B Arre De Relevage) / Hydraulic Lift Link 3 (Lift Rod )
Support De Tirant Supe Rieur / Top Link Bracket
Barre D'attelage/Attelage / Swinging Drawbar/Hitch
Capot Avant / Bonnet (Hood) Front
Capot Superieur / Bonnet (Hood) Upper
Capot Lateral / Bonnet (Hood) Side
Capot De Couvercle Lateral [Type Nouveau] / Bonnet (Hood) Side Cover [New Type]
Capot Arriere / Bonnet (Hood) Rear
Aile / Fender
Plancher / Floor Seat
Siege / Seat
Marchepied / Step
Marchepied / Step
Retroviseur / Rearview Mirror
Boite Outils/Support / Tool Box/Top Link Holder
Cadre Anti-Renversament / Rops
Etiquettes / Labels
Etiquettes / Labels
Etiquettes / Labels
Accessories Et Piece De Service / A Ccessories And Service Parts
Kit De Support Du Marche-Pied [Option] / Step Support Kit [Option]
Ventilateur / Fa N
Ventilateur / Fa N
Lanceur / Starter
Lanceur / Starter
Lanceur / Starter
Batterie / Battery
Phare / Head Light
Lampe / Light
Embrayage / Clutch
Frein / Brake
Aile / Fender
Siege / Seat
Marchepied / Step
Marchepied / Step
Etiquettes / Labels
Etiquettes / Labels
Etiquettes / Labels
