Kubota Utility Tractors M5101NC-EC Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M5101NC-EC Utility Tractors
Number of Pages: 396 Pages
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Tête / Head Cover
Carter De Chaîne / Gear Case
Compensateur / Balancer
Volant / Flywheel
Rail Commun / Common Rail
Pompe À Eau / Water Pump
Bride De Filtre A Air Et Valve De Commande De P Uissance / Air Cleaner Flange And Throttle Valve
Soupape D'egr / Egr Valve
Filtre À Air / Air Cleaner
Filtre A Air [Parties Composantes] / Air Cleane R [Component Parts]
Tayau D'admission (Filtre A Air) / Inlet Pipe ( Air Cleaner)
Silencieux Du Filtre À Particules Diesel / Dies El Particulate Filter Muffler
Parenthese De Silencieux / Muffler Bracket
Silencieux Du Filtre À Particules Diesel [Parti Es Composantes] / Diesel Particulate Filter Muffler [Component Parts]
Tuyau D'huile (Turbo-Chargeur) / Oil Pipe (Turb O Charger)
Refroidissement / Oil Cooler
Pieces Electriques De Moteur (Detector/Ecu) / E Ngine Electrical Parts (Sensor/Ecu)
Pieces Electriques De Moteur (Sonde De Silencie Ux) / Engine Electrical Parts (Muffler Sensor)
Diagmaster / Diagmaster
Reservoir A Carburant Droite / Fuel Tank Rh
Reservoir A Carburant Gauche / Fuel Tank Lh
Remplisseur De Carburant [Ec] / Fuel Supply [Ec]
Remplisseur De Carburant [Ita] / Fuel Supply [Ita]
Tuyau A Carburant (Reservoir A Carburant) / Fuel Pipe (Fuel Tank)
Tuyau A Carburant (Filtre A Car Burant) / Fuel Pipe (Fuel Filter)
Tuyau A Carburant (Pumpe De Com Bustible/Separateur) / Fuel Pipe (Fuel Pump/Separat Or)
Tuyau A Carburant (Reservoir R Eniflard) [Vieux] / Fuel Pipe (Fuel Tank Breather) [Old]
Tuyau A Carburant (Reservoir R Eniflard) [Nouveau] / Fuel Pipe (Fuel Tank Breather ) [New]
Tuyau A Carburant (Refroidisseu R De Carburant) [Ec] / Fuel Pipe (Fuel Cooler) [Ec]
Tuyau A Carburant (Refroidisseu R De Carburant) [Ita] / Fuel Pipe (Fuel Cooler) [It A]
Separateur / Separator
Separateur [Parties Composantes ] / Separator [Component Parts]
Filtre A Carburant / Fuel Filte R
Ventilateur / Fan
Tuyau D'eau / Wate R Pipe
Radiateur / Radiat Or
Reservoir Du Padia Teur / Reserve Tank
Alternateur / Alternato R
Alternateur [Paries Com Posantes] / Alternator [Component Parts]
Demarreur / Starter
Batterie / Battery
Commutateur/Detector (M Oteur) / Switch/Sensor (Engine)
Commutateur/Detector (S Ilencieux) / Switch/Sensor (Muffler)
Commutateur/Detector (A Vant) / Switch/Sensor (Front)
Commutateur/Detector (A Rriere) [Ec] / Switch/Sensor (Rear) [Ec]
Commutateur/Detector (A Rriere) [Ita] / Switch/Sensor (Rear) [Ita]
Commutateur/Detector (C Arter D'embrayage) [Ec] / Switch/Sensor (Clutch Hou Sing) [Ec]
Commutateur/Detector (C Arter D'embrayage) [Ita] / Switch/Sensor (Clutch Ho Using) [Ita]
Commutateur (Tableau De Bord) / Switch (Panel Board)
Commutateur (Toit Inter Ne) / Switch (Inner Roof)
Commutateur (Panneau La Teral) / Switch (Side Panel)
Relais / Relay
Relais / Relay
Relais [Ita] / Relay [I Ta]
Centre De Controle Elec Tronique (Moteur) / Electronic Control Unit (Engine )
Centre De Controle Elec Tronique (Corps) / Electronic Control Unit (Body)
Panneau [Vieux] / Panel [Old]
Panneau [Nouveau] / Pan El [New]
Phare [Ec] / Head Light [Ec]
Phare [Ita] / Head Ligh T [Ita]
Phare [Parties Composan Tes] / Head Light [Component Parts]
Feux De Combinaison Ava Nt / Front Combination Lamp
Lumiere De Travail / Wo Rking Light
Feux De Combinaison Arr Iere / Rear Combination Lamp
Lamp Et Plaque D'immatr Iculation/Balise Lumineuse / License Lamp/Beacon La Mp
Prise De Remorque / Tra Iler Socket
Plafonnier / Room Light
Radio-Orateur / Radio S Peaker
Cuve De Lavage [Ec] / W Asher Tank [Ec]
Cuve De Lavage [Ita] / Washer Tank [Ita]
Essuie-Glase Avant / Fr Ont Wiper
Faisceau Electrique (Cr S) / Electrical Wiring (Crs)
Faisceau Electrique (Mo Teur/Capot) [Ec] / Electrical Wiring (Main/Engine) [Ec]
Faisceau Electrique (Mo Teur/Capot) [Ita] / Electrical Wiring (Main/Engine) [Ita]
Faisceau Electrique (Pr Incipal) [Ec] / Electrical Wiring (Main) [Ec]
Faisceau Electrique (Pr Incipal) [Ita] / Electrical Wiring (Main) [Ita]
Faisceau Electrique (Co Rps) [Ds] [Ec] / Electrical Wiring (Body) [Ds] [Ec]
Faisceau Electrique (Co Rps) [Ds] [Ita] / Electrical Wiring (Body) [Ds] [It A]
Faisceau Electrique (Ca Bine) [Ec] / Electrical Wiring (Cab) [Ec]
Faisceau Electrique (Ca Bine) [Ita] / Electrical Wiring (Cab) [Ita]
Carter D'embrayage [Ds] [Ec] / Clutch Housing [Ds] [Ec]
Carter D'embrayage [Ds] [Ita] / Clutch Housing [Ds] [Ita]
Soupape D'inverseu R / Shuttle Valve
Boite D'engrenage [Ds] / Shuttle Gear Case [Ds]
Covercle De Change Ment / Shift Cover
Soupape De Dual Sp Eed [Ds] / Dual Speed Valve [Ds]
Carter De Transmis Sion [Ec] / Transmission Case [Ec]
Carter De Transmis Sion [Ita] / Transmission Case [Ita]
Tuyau De Reniflard (Carter De Transmission) / Breather Hose (Transmis Sion Case)
Couvercle De Carte R De Boite Arriere [Ec] / Transmission Case Rear Co Ver [Ec]
Couvercle De Carte R De Boite Arriere [Ita] / Transmission Case Rear C Over [Ita]
Carter Pont Arrier E / Rear Axle Case
Amoritisseur Disqu E [Ds] / Damper Disk [Ds]
Amoritisseur Disqu E [Excepte [Ds]] / Damper Disk [Except [Ds]]
Pedale De Embrayag E / Clutch Pedal
Levier De Soupape (Embrayage) / Valve Lever (Clutch)
Arbre De Entree [D S] / Input Shaft [Ds]
Paquet D'embrayage (Hi-Lo) [Parties Composantes] [Ds] / Clutch Pack ( Hi-Lo) [Component Parts] [Ds]
Arbre De Inverseur [Ds] / Shuttle Shaft [Ds]
Paquet D'embrayage (Inverseur) [Parties Composantes] [Ds] / Clutch Pa Ck (Shuttle) [Component Parts] [Ds]
Premier Arbre [Ds] / First Shaft [Ds]
Deuxieme Arbre / S Econd Shaft
Troisieme Arbre / Third Shaft
Arbre D'entraineme Nt / Drive Shaft
Engrenage Conique [Ec] / Bevel Gear [Ec]
Engrenage Conique [Ita] / Bevel Gear [Ita]
Differentiel Arrie Re / Rear Differential
Arbre De Transmiss Ion Pdf / Pto Propeller Shaft
Embrayage Pdf [Ec] / Pto Clutch [Ec]
Embrayage Pdf [Ita ] / Pto Clutch [Ita]
Embrayage Pdf [Par Ties Composantes] / Pto Clutch [Component Parts]
Soupape D'embrayag E Pdf / Pto Clutch Valve
Soupape D'embrayag E Pdf [Parties Composantes] / Pto Clutch Valve [Com Ponent Parts]
Arbre De Pdf / Pto Shaft
Embrayage Avant D' Entrainement / Front Drive Clutch
Embrayage Avant D' Entrainement [Parties Composantes] / Front Drive Cl Utch [Component Parts]
Embrayage Hydrauli Que [Parties Composantes] / Hydraulic Clutch (Bi-Sp Eed Turn) [Component Parts]
Fourchette De Chan Gement De Vitesses Principal / Main Gear Shift Fork
Fourchette De Chan Gement De Gamme / Range Gear Shift Fork
Fourchette De Chan Gement De Pdf Proportionnelle [Ita] / Ground Pto Sh Ift Fork [Ita]
Fourchette De Bloc Age Differentiel / Differential Lock Shift Fork
Levier De Cahngeme Nt De Vitesses Principal [Ds] [Ec] / Main Gear Shif T Lever [Ds] [Ec]
Levier De Cahngeme Nt De Vitesses Principal [Ds] [Ita] / Main Gear Shi Ft Lever [Ds] [Ita]
Levier De Inverseu R [Ec] / Shuttle Shift Lever [Ec]
Levier De Inverseu R [Ita] / Shuttle Shift Lever [Ita]
Levier De Changeme Nt De Gamme [Ec] / Range Gear Shift Lever [Ec]
Levier De Changeme Nt De Gamme [Ita] / Range Gear Shift Lever [Ita]
Fourchette De Pign On Pdf / Pto Gear Shift Rod
Fourchette De Chan Gement De Pdf Proportionnelle [Ita] / Ground Pto Sh Ift Lever [Ita]
Essieu Arriere / Rear Axle
Frein Droite / Brake Rh
Frein Gauche / Brake Lh
Arbre A Cames De Frein Sta Tionnement / Parking Brake Camshaft
Levier De Frein Stationnem Ent / Parking Brake Lever
Arbre De Frein Stationneme Nt / Parking Brake Shaft
Levier De Frein Secondaire / Secondary Brake Lever
Pedale De Frien [Ec] / Bra Ke Pedal [Ec]
Pedale De Frien [Ita] / Br Ake Pedal [Ita]
Tuyau De Frein / Brake Pip E
Chassis Avant / Front A Xle Frame
Carter Differentiel Ava Nt / Front Differential Case
Engrenage Conique (Avan T) / Bevel Gear (Front)
Differentiel Avant / Di Fferential Front
Carter Engrenage Coniqu E Droite / Bevel Gear Case Rh
Carter Engrenage Coniqu E Gauche / Bevel Gear Case Lh
Demi Arbre De Pont Avan T Droite / Differential Gear Shaft Rh
Reducteur Droite / Fron T Axle Rh
Reducteur Gauche / Fron T Axle Lh
Joint De Cardan De Direction / Steering Jo Int
Servo Direction [Parties Composantes] / St Eering Controller [Component Parts]
Barrd De Accouplement/Cylindre De Directio N / Tie Rod/Steering Cylinder
Pompe Hydraulique / Hydr Aulic Pump
Pompe Hydraulique [Parti Es Composantes] [Ec] / Hydraulic Pump [Component Pa Rts] [Ec]
Pompe Hydraulique [Parti Es Composantes] [Ita] / Hydraulic Pump [Component P Arts] [Ita]
Circuit D'huile Hydrauli Que (Refoulement) / Hydraulic Pipe (Delivery)
Refroidissement [Vieux] / Oil Cooler [Old]
Circuit D'huile Hyd. (So Upape De Reglage De Vittesse Double) [Ds] / Hydraul Ic Oil Line (Dual Speed Valve) [Ds]
Circuit D'huile Hydrauli Que (Direction/Pdf) [Ds] / Hydraulic Oil Line (Stee Ring/Pto) [Ds]
Circuit D'huile Hydrauli Que (Inverseu/Pdf) / Hydraulic Oil Line (Shuttle/Pt O)
Tuyau De Direction (Refo Ulement) / Steering Hose (Delivery)
Carter De Cylindre Hydra Ulique / Hydraulic Cylinder Case
Bras De Relevage / Hydra Ulic Lift Arm
Clapet De Surcharge/Soup Ape De Securite / Safety Valve/Relief Valve
Distributeur Controle / Control Valve
Levier De Controle De Po Sition Et D'effort / Draft And Position Control Lev Er
Position Et Arbre D'effo Rt / Position And Draft Shaft
Support Auxiliaire De So Upape De Commande / Auxiliary Control Valve Mountin G Base
Valve Auxiliaire (Fd Ave C Fc/Scd Avec Fc) / Auxiliary Control Valve (Fd Wit H Fc/Scd With Fc)
Valve Auxiliaire [Partie S Composantes] (Fd Avec Fc) / Auxiliary Control Val Ve [Component Parts] (Fd With Fc)
Valve Auxiliaire [Partie S Composantes] (Scd Avec Fc) / Auxiliary Control Va Lve [Component Parts] (Scd With Fc)
Levier De Controle De Di Stributeur Auxiliaire / Auxiliary Control Valve Lev Er
Câble De Commande Du Déb It De Commande De L'auxiliaire / Auxiliary Control Flow Control Wire
3-Pts Soulevez Le Cylind Re D'aide Gauche [Vieux] / 3p-Lift Assist Cylinder Lh [Old]
3-Pts Soulevez Le Cylind Re D'aide Gauche [Nouveau] / 3p-Lift Assist Cylinde R Lh [New]
3-Pts Soulevez Le Cylind Re D'aide Droite [Vieux] / 3p-Lift Assist Cylinder Rh [Old]
3-Pts Soulevez Le Cylind Re D'aide Droite [Nouveau] / 3p-Lift Assist Cylinde R Rh [New]
Tuyau De Reniflard (3-Pt S Cylindre) / Breather Hose (3p Cylinder)
Bras Inferieur [Vieux] / Lower Link [O Ld]
Bras Inferieur [Nouveau] / Lower Link [New]
Barre De Attelage [Vieux] / Swinging D Rawbar [Old]
Barre De Attelage [Nouveau] / Swinging Drawbar [New]
Calandre Avant / Front Grille
Capot (Insonorisant/Isolateur) / Hood (Bonn Et) (Sound Absorber/Insulator)
Capot De Couvercle Lateral [Ec] / Hood (Bon Net) Side Cover [Ec]
Capot De Couvercle Lateral [Ita] / Hood (Bo Nnet) Side Cover [Ita]
Armature De Cabine [Ec] / Cab Frame [Ec]
Armature De Cabine [Ita] / Cab Frame [Ita]
Verre Avant / Front Glass
Porte Droite / Door Rh
Porte Gauche / Door Lh
Fenetre Laterale Droite / Side Window Rh
Fenetre Laterale Gauche / Side Window Lh
Vitre Arriere / Hatch Back Glass
Retroviseur / Rearview Mirror
Toit Interne / Inner Roof
Toit Externe / Outer Roof
Amortissant Matériau/Tapis / Damp Material/Floor M At
Couvercle De Aile Droite / Fender Cover Rh
Couvercle De Cadre / Pillar Cover
Aile / Fender
Boite Dutils / Tool Box
Air Conditionneur / Air Con Ditioner
Conduit D'air / Air Conditi Oner Duct
Condensateur / Condenser
Tuyau De Air Conditionneur/ Tuyau De Condensateur / Air Conditioner Hose/Conden Ser Hose
Compresseur Support / Compr Essor Bracket
Tuyau De Drainage / Drain H Ose
Etiquette (Armature De Cabine) / Label (Cab Frame)
Etiquette (Arriere) [Ec] / Label (Rear) [Ec ]
Etiquette (Arriere) [Ita] / Label (Rear) [I Ta]
Accessoires Et Pieces De Service / Accessories An D Service Parts
Silencieux [Option] / Upper Muffler Kit [Option ]
Alternateur (Alternateur) [Option] / Alternator Kit (Alternator) [Option]
Alternateur (Faisceau Electrique) [Option] / Al Ternator Kit (Electrical Wiring) [Option]
Alternateur [Parties Composantes] [Option] / Al Ternator [Component Parts] [Option]
Kit Commutateur (Pompe) [Option] / Switch Kit ( Pumpa) [Option]
Kit De Dégivreur Arrière [Option] / Rear Defogg Er Kit [Option]
Essuie-Glase [Option] / Rear Wiper Kit [Option]
Pdf (Engrenage) (540/540e/1000) Conversion [Opt Ion] / Pto Conversion Kit (Gear) (540/540e/1000) [O Ption]
Pdf (Levier) (540/540e/1000) Conversion [Option ] / Pto Conversion Kit (Lever) (540/540e/1000) [Opt Ion]
Kit Controle De La Valve Auxiliaire (Fd Avec Fc ) [Option] / Auxiliary Control Valve Kit (Fd With F C) [Option]
Kit Controle De La Valve Auxiliaire (Scd Avec F C) [Option] / Auxiliary Control Valve Kit (Scd With Fc) [Option]
Kit Controle De La Valve Auxiliaire (S/D Avec F C) [Option] / Auxiliary Control Valve Kit (S/D With Fc) [Option]
Valve Auxiliaire [Parties Composantes] (S/D Ave C Fc) [Option] / Auxiliary Control Valve [Component Parts] (S/D With Fc) [Option]
Kit Levier De Controle De La Valve Auxiliaire ( 3eme) [Option] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit Levier De Controle De La Valve Auxiliaire ( 4eme) [Option] / Auxiliary Control Valve Lever Kit (4th) [Option]
Kit Levier De Controle De La Valve Auxiliaire ( 5eme) [Option] / Auxiliary Control Valve Lever Kit (5th) [Option]
Kit Attelage Avant (1eme) [Option] / Front Coup Ler Kit (1st) [Option]
Kit Attelage Avant (2eme) [Option] / Front Coup Ler Kit (2nd) [Option]
Kit Attelage Avant (3eme) [Option] / Front Coup Ler Kit (3rd) [Option]
Kit Attelage Avant (4eme) [Option] / Front Coup Ler Kit (4th) [Option]
Kit Attelage Avant (5eme) [Option] / Front Coup Ler Kit (5th) [Option]
Kit Attelage Avant (Vidange) [Option] / Front C Oupler Kit (Drain) [Option]
Kit Vidange Arriere [Option] / Rear Drain Kit [ Option]
Kit Soupape De Frein De Remorqu (Soupape) [Opti On] [Ec] / Traler Brake Valve Kit (Valve) [Option] [Ec]
Kit Soupape De Frein De Remorqu (Soupape) [Opti On] [Ita] / Traler Brake Valve Kit (Valve) [Option] [Ita]
Kit Soupape De Frein De Remorque (Coupleur) [Op Tion] / Traler Brake Valve Kit (Coupler) [Option]
Support De Soupape De Frein Remorque (Support) [Option] / Trailer Brake Valve Mounting Kit (Bracke T) [Option]
Support De Soupape De Frein Remorque (Soupape/T Uyau) [Option] / Trailer Brake Valve Mounting Kit ( Valve/Pipe) [Option]
Support De Soupape De Frein Remorque (Coupleur/ Tuyau) [Option] / Trailer Brake Valve Mounting Kit (Coupler/Pipe) [Option]
Support De Soupape De Frein Remorque (Câblage É Lectrique) [Option] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Option]
Stabilisateur [Option] / Stabilizer [Option]
