Kubota Utility Tractors M5091NC-NEC Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M5091NC-NEC Utility Tractors
Number of Pages: 372 Pages
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Tête / Head Cover
Carter De Chaîne / Gear Case
Arbre A Cames Et Arbre De Pignon Fou / Camshaf T And Idle Gear Shaft
Compensateur / Balancer
Volant / Flywheel
Volant / Flywheel
Rail Commun / Common Rail
Bride D'eau Et Thermostat / Water Flange And T Hermostat
Pompe À Eau / Water Pump
Bride De Filtre A Air Et Valve De Commande De Puissance / Air Cleaner Flange And Throttle Valve
Soupape D'egr / Egr Valve
Filtre À Air / Air Cleaner
Filtre A Air [Parties Composantes] / Air Clean Er [Component Parts]
Tayau D'admission (Filtre A Air) / Inlet Pipe (Air Cleaner)
Silencieux Du Filtre À Particules Diesel / Die Sel Particulate Filter Muffler
Parenthese De Silencieux / Muffler Bracket
Silencieux Du Filtre À Particules Diesel [Part Ies Composantes] / Diesel Particulate Filter Muffle R [Component Parts]
Tuyau D'huile (Turbo-Chargeur) / Oil Pipe (Tur Bo Charger)
Refroidissement / Oil Cooler
Pieces Electriques De Moteur (Detector/Ecu) / Engine Electrical Parts (Sensor/Ecu)
Pieces Electriques De Moteur (Sonde De Silenci Eux) / Engine Electrical Parts (Muffler Sensor)
Diagmaster / Diagmaster
Reservoir A Carburant Droite / Fuel Tank Rh
Reservoir A Carburant Gauche / Fuel Tank Lh
Remplisseur De Carburant [Ec] / Fuel Supply [Ec]
Tuyau A Carburant (Reservoir A Carburant) / Fuel Pipe (Fuel Tank)
Tuyau A Carburant (Pumpe De Co Mbustible/Separateur) / Fuel Pipe (Fuel Pump/Separa Tor)
Tuyau A Carburant (Reservoir Reniflard) [Vieux] / Fuel Pipe (Fuel Tank Breather) [Old]
Tuyau A Carburant (Reservoir Reniflard) [Nouveau] / Fuel Pipe (Fuel Tank Breathe R) [New]
Tuyau A Carburant (Refroidisse Ur De Carburant) [Ec] / Fuel Pipe (Fuel Cooler) [Ec ]
Separateur / Separator
Filtre A Carburant / Fuel Filt Er
Ventilateur / Fan
Tuyau D'eau / Wat Er Pipe
Radiateur / Radia Tor
Reservoir Du Padi Ateur / Reserve Tank
Alternateur / Alternat Or
Alternateur [Paries Co Mposantes] / Alternator [Component Parts]
Demarreur / Starter
Demarreur [Parties Com Posantes] / Starter [Component Parts]
Batterie / Battery
Batterie / Battery
Commutateur/Detector ( Moteur) / Switch/Sensor (Engine)
Commutateur/Detector ( Silencieux) / Switch/Sensor (Muffler)
Commutateur/Detector ( Avant) / Switch/Sensor (Front)
Commutateur/Detector ( Arriere) [Ec] / Switch/Sensor (Rear) [Ec]
Commutateur/Detector ( Carter D'embrayage) [Ec] / Switch/Sensor (Clutch Ho Using) [Ec]
Commutateur (Tableau D E Bord) / Switch (Panel Board)
Commutateur (Toit Inte Rne) / Switch (Inner Roof)
Commutateur (Panneau L Ateral) / Switch (Side Panel)
Relais / Relay
Relais / Relay
Centre De Controle Ele Ctronique (Moteur) / Electronic Control Unit (Engin E)
Centre De Controle Ele Ctronique (Corps) / Electronic Control Unit (Body)
Panneau [Vieux] / Pane L [Old]
Panneau [Nouveau] / Pa Nel [New]
Phare [Ec] / Head Ligh T [Ec]
Phare [Parties Composa Ntes] / Head Light [Component Parts]
Feux De Combinaison Av Ant / Front Combination Lamp
Lumiere De Travail / W Orking Light
Feux De Combinaison Ar Riere / Rear Combination Lamp
Lamp Et Plaque D'immat Riculation/Balise Lumineuse / License Lamp/Beacon L Amp
Prise De Remorque / Tr Ailer Socket
Plafonnier / Room Ligh T
Radio-Orateur / Radio Speaker
Cuve De Lavage [Ec] / Washer Tank [Ec]
Essuie-Glase Avant / F Ront Wiper
Faisceau Electrique (C Rs) / Electrical Wiring (Crs)
Faisceau Electrique (M Oteur/Capot) [Ec] / Electrical Wiring (Main/Engine) [Ec]
Faisceau Electrique (P Rincipal) [Ec] / Electrical Wiring (Main) [Ec]
Faisceau Electrique (C Orps) [Ds] [Ec] / Electrical Wiring (Body) [Ds] [Ec ]
Faisceau Electrique (C Orps) [Excepte [Ds]] / Electrical Wiring (Body) [Ex Cept [Ds]]
Faisceau Electrique (C Abine) [Ec] / Electrical Wiring (Cab) [Ec]
Carter D'embrayag E [Ds] [Ec] / Clutch Housing [Ds] [Ec]
Carter D'embrayag E [Excepte [Ds]] / Clutch Housing [Except [Ds]]
Soupape D'inverse Ur / Shuttle Valve
Boite D'engrenage [Ds] / Shuttle Gear Case [Ds]
Boite D'engrenage [Excepte [Ds]] / Shuttle Gear Case [Except [Ds]]
Covercle De Chang Ement / Shift Cover
Carter De Transmi Ssion [Ec] / Transmission Case [Ec]
Tuyau De Reniflar D (Carter De Transmission) / Breather Hose (Transmi Ssion Case)
Couvercle De Cart Er De Boite Arriere [Ec] / Transmission Case Rear C Over [Ec]
Carter Pont Arrie Re / Rear Axle Case
Amoritisseur Disq Ue [Ds] / Damper Disk [Ds]
Amoritisseur Disq Ue [Excepte [Ds]] / Damper Disk [Except [Ds]]
Pedale De Embraya Ge / Clutch Pedal
Levier De Soupape (Embrayage) / Valve Lever (Clutch)
Arbre De Entree [ Ds] / Input Shaft [Ds]
Arbre De Entree [ Excepte [Ds]] / Input Shaft [Except [Ds]]
Paquet D'embrayag E (Hi-Lo) [Parties Composantes] [Ds] / Clutch Pack (Hi-Lo) [Component Parts] [Ds]
Paquet D'embrayag E (Hi-Lo) [Parties Composantes] [Excepte [Ds]] / Cl Utch Pack (Hi-Lo) [Component Parts] [Except [Ds]]
Arbre De Inverseu R [Ds] / Shuttle Shaft [Ds]
Arbre De Inverseu R [Excepte [Ds]] / Shuttle Shaft [Except [Ds]]
Paquet D'embrayag E (Inverseur) [Parties Composantes] [Ds] / Clutch P Ack (Shuttle) [Component Parts] [Ds]
Premier Arbre [Ds ] / First Shaft [Ds]
Premier Arbre [Ex Cepte [Ds]] / First Shaft [Except [Ds]]
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Arbre D'entrainem Ent / Drive Shaft
Engrenage Conique [Ec] / Bevel Gear [Ec]
Differentiel Arri Ere / Rear Differential
Arbre De Transmis Sion Pdf / Pto Propeller Shaft
Embrayage Pdf [Ec ] / Pto Clutch [Ec]
Embrayage Pdf [Pa Rties Composantes] / Pto Clutch [Component Parts]
Soupape D'embraya Ge Pdf / Pto Clutch Valve
Soupape D'embraya Ge Pdf [Parties Composantes] / Pto Clutch Valve [Co Mponent Parts]
Arbre De Pdf / Pt O Shaft
Embrayage Avant D 'Entrainement / Front Drive Clutch
Embrayage Avant D 'Entrainement [Parties Composantes] / Front Drive C Lutch [Component Parts]
Embrayage Hydraul Ique [Parties Composantes] / Hydraulic Clutch (Bi-S Peed Turn) [Component Parts]
Fourchette De Cha Ngement De Vitesses Principal / Main Gear Shift For K
Fourchette De Cha Ngement De Gamme / Range Gear Shift Fork
Fourchette De Blo Cage Differentiel / Differential Lock Shift Fork
Levier De Cahngem Ent De Vitesses Principal [Ds] [Ec] / Main Gear Shi Ft Lever [Ds] [Ec]
Levier De Cahngem Ent De Vitesses Principal [Excepte [Ds]] / Main Gea R Shift Lever [Except [Ds]]
Tige De Changemen T De Vitesses Principal / Main Gear Shift Rod
Levier De Inverse Ur [Ec] / Shuttle Shift Lever [Ec]
Levier De Changem Ent De Gamme [Ec] / Range Gear Shift Lever [Ec]
Essieu Arriere / Rear Axl E
Frein Droite / Brake Rh
Frein Gauche / Brake Lh
Arbre A Cames De Frein St Ationnement / Parking Brake Camshaft
Levier De Frein Stationne Ment / Parking Brake Lever
Arbre De Frein Stationnem Ent / Parking Brake Shaft
Levier De Frein Secondair E / Secondary Brake Lever
Pedale De Frien [Ec] / Br Ake Pedal [Ec]
Cylindre De Frein [Partie S Composantes] / Brake Master Cylinder [Component P Arts]
Tuyau De Frein / Brake Pi Pe
Carter Differentiel Av Ant / Front Differential Case
Engrenage Conique (Ava Nt) / Bevel Gear (Front)
Differentiel Avant / D Ifferential Front
Carter Engrenage Coniq Ue Droite / Bevel Gear Case Rh
Carter Engrenage Coniq Ue Gauche / Bevel Gear Case Lh
Carter Reducteur Droit E / Front Axle Case Rh
Carter Reducteur Gauch E / Front Axle Case Lh
Demi Arbre De Pont Ava Nt Droite / Differential Gear Shaft Rh
Reducteur Droite / Fro Nt Axle Rh
Reducteur Gauche / Fro Nt Axle Lh
Joint De Cardan De Direction / Steering J Oint
Servo Direction [Parties Composantes] / S Teering Controller [Component Parts]
Barrd De Accouplement/Cylindre De Directi On / Tie Rod/Steering Cylinder
Cylindre De Direction [Parties Composante S] / Steering Cylinder [Component Parts]
Pompe Hydraulique / Hyd Raulic Pump
Pompe Hydraulique [Part Ies Composantes] [Ec] / Hydraulic Pump [Component P Arts] [Ec]
Circuit D'huile Hydraul Ique (Refoulement) / Hydraulic Pipe (Delivery)
Refroidissement [Vieux] / Oil Cooler [Old]
Refroidissement [Nouvea U] / Oil Cooler [New]
Circuit D'huile Hyd. (S Oupape De Reglage De Vittesse Double) [Ds] / Hydrau Lic Oil Line (Dual Speed Valve) [Ds]
Circuit D'huile Hydraul Ique (Direction/Pdf) [Ds] / Hydraulic Oil Line (Ste Ering/Pto) [Ds]
Circuit D'huile Hydraul Ique (Direction/Pdf) [Excepte [Ds]] / Hydraulic Oil Line (Steering/Pto) [Except [Ds]]
Circuit D'huile Hydraul Ique (Inverseu/Pdf) / Hydraulic Oil Line (Shuttle/P To)
Tuyau De Direction (Ref Oulement) / Steering Hose (Delivery)
Carter De Cylindre Hydr Aulique / Hydraulic Cylinder Case
Bras De Relevage / Hydr Aulic Lift Arm
Clapet De Surcharge/Sou Pape De Securite / Safety Valve/Relief Valve
Distributeur Controle / Control Valve
Levier De Controle De P Osition Et D'effort / Draft And Position Control Le Ver
Position Et Arbre D'eff Ort / Position And Draft Shaft
Levier De Revenue / Fee D Back Lever
Valve Auxiliaire (Fd/Sc D) / Auxiliary Control Valve (Fd/Scd)
Valve Auxiliaire [Parti Es Composantes] (Fd) / Auxiliary Control Valve [Com Ponent Parts] (Fd)
Valve Auxiliaire [Parti Es Composantes] (Scd) / Auxiliary Control Valve [Co Mponent Parts] (Scd)
Levier De Controle De D Istributeur Auxiliaire / Auxiliary Control Valve Le Ver
3-Pts Soulevez Le Cylin Dre D'aide Gauche [Vieux] / 3p-Lift Assist Cylinder Lh [Old]
3-Pts Soulevez Le Cylin Dre D'aide Gauche [Nouveau] / 3p-Lift Assist Cylind Er Lh [New]
3-Pts Soulevez Le Cylin Dre D'aide Droite [Vieux] / 3p-Lift Assist Cylinder Rh [Old]
3-Pts Soulevez Le Cylin Dre D'aide Droite [Nouveau] / 3p-Lift Assist Cylind Er Rh [New]
3-Pts Soulevez Le Cylin Dre D'aide [Parties Composantes] / 3p-Lift Assist C Ylinder [Component Parts]
Tuyau De Reniflard (3-P Ts Cylindre) / Breather Hose (3p Cylinder)
Support De Tirant Superieur / Top Lin K Bracket
Tirant Superieur / Top Link
Bras Inferieur [Vieux] / Lower Link [ Old]
Bras Inferieur [Nouveau] / Lower Link [New]
Barre De Relevage Droite / Lift Rod R H
Barre De Relevage Gauche / Lift Rod L H
Barre De Attelage [Vieux] / Swinging Drawbar [Old]
Barre De Attelage [Nouveau] / Swingin G Drawbar [New]
Calandre Avant / Front Grille
Capot (Insonorisant/Isolateur) / Hood (Bon Net) (Sound Absorber/Insulator)
Capot De Couvercle Lateral [Ec] / Hood (Bo Nnet) Side Cover [Ec]
Armature De Cabine [Ec] / Cab Frame [Ec]
Verre Avant / Front Glass
Porte Droite / Door Rh
Porte Gauche / Door Lh
Fenetre Laterale Droite / Side Window Rh
Fenetre Laterale Gauche / Side Window Lh
Vitre Arriere / Hatch Back Glass
Retroviseur / Rearview Mirror
Toit Interne / Inner Roof
Toit Externe / Outer Roof
Amortissant Matériau/Tapis / Damp Material/Floor Mat
Couvercle De Aile Droite / Fender Cover Rh
Couvercle De Cadre / Pillar Cover
Aile / Fender
Air Conditionneur / Air Co Nditioner
Conduit D'air / Air Condit Ioner Duct
Tuyau De Chauffage / Heate R Hose
Condensateur / Condenser
Tuyau De Air Conditionneur /Tuyau De Condensateur / Air Conditioner Hose/Conde Nser Hose
Compresseur (Climatiseur) / Compressor (Air Conditioner)
Compresseur Support / Comp Ressor Bracket
Tuyau De Drainage / Drain Hose
Etiquette (Armature De Cabine) / Label (Ca B Frame)
Etiquette (Arriere) [Ec] / Label (Rear) [E C]
Accessoires Et Pieces De Service / Accessories A Nd Service Parts
Silencieux [Option] / Upper Muffler Kit [Optio N]
Alternateur (Alternateur) [Option] / Alternato R Kit (Alternator) [Option]
Alternateur (Faisceau Electrique) [Option] / A Lternator Kit (Electrical Wiring) [Option]
Alternateur [Parties Composantes] [Option] / A Lternator [Component Parts] [Option]
Kit Commutateur (Pompe) [Option] / Switch Kit (Pumpa) [Option]
Kit De Dégivreur Arrière [Option] / Rear Defog Ger Kit [Option]
Essuie-Glase [Option] / Rear Wiper Kit [Option ]
Pdf (Engrenage) (540/540e/1000) Conversion [Op Tion] / Pto Conversion Kit (Gear) (540/540e/1000) [ Option]
Pdf (Levier) (540/540e/1000) Conversion [Optio N] / Pto Conversion Kit (Lever) (540/540e/1000) [Op Tion]
Kit Controle De La Valve Auxiliaire (Fd) [Opti On] / Auxiliary Control Valve Kit (Fd) [Option]
Kit Controle De La Valve Auxiliaire (Scd) [Opt Ion] / Auxiliary Control Valve Kit (Scd) [Option] # # Note:Reffr To Fig.No.J44702 For Components. / Not E:Reffr To Fig.No.J44702 For Components.
Kit Controle De La Valve Auxiliaire (S/D) [Opt Ion] / Auxiliary Control Valve Kit (S/D) [Option]
Kit Controle De La Valve Auxiliaire (Fc) [Opti On] / Auxiliary Control Valve Kit (Fc) [Option]
Valve Auxiliaire [Parties Composantes] (S/D) [ Option] / Auxiliary Control Valve [Component Parts] (S/D) [Option]
Valve Auxiliaire [Parties Composantes] (Fc) [O Ption] / Auxiliary Control Valve [Component Parts] (Fc) [Option]
Kit Levier De Controle De La Valve Auxiliaire (3eme) [Option] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit Attelage Avant (2eme) [Option] / Front Cou Pler Kit (2nd) [Option]
Kit Attelage Avant (3eme) [Option] / Front Cou Pler Kit (3rd) [Option]
Kit Attelage Avant (4eme) [Option] / Front Cou Pler Kit (4th) [Option]
Kit Attelage Avant (5eme) [Option] / Front Cou Pler Kit (5th) [Option]
Kit Attelage Avant (Vidange) [Option] / Front Coupler Kit (Drain) [Option]
Kit Vidange Arriere [Option] / Rear Drain Kit [Option]
Kit Soupape De Frein De Remorqu (Soupape) [Opt Ion] [Ec] / Traler Brake Valve Kit (Valve) [Option] [Ec]
Kit Soupape De Frein De Remorque (Circuit D'hu Ile Hydraulique) [Option] [Ds] / Traler Brake Valve Kit (Hydraulic Pipe) [Option] [Ds]
Kit Soupape De Frein De Remorque (Circuit D'hu Ile Hydraulique) [Option] [Excepte [Ds] / Traler Br Ake Valve Kit (Hydraulic Pipe) [Option] [Except [Ds ]
Kit Soupape De Frein De Remorque (Coupleur) [O Ption] / Traler Brake Valve Kit (Coupler) [Option]
Support De Soupape De Frein Remorque (Support) [Option] / Trailer Brake Valve Mounting Kit (Brack Et) [Option]
Support De Soupape De Frein Remorque (Soupape/ Tuyau) [Option] / Trailer Brake Valve Mounting Kit (Valve/Pipe) [Option]
Support De Soupape De Frein Remorque (Coupleur /Tuyau) [Option] / Trailer Brake Valve Mounting Kit (Coupler/Pipe) [Option]
Support De Soupape De Frein Remorque (Câblage Électrique) [Option] / Trailer Brake Valve Mounting Kit (Electrical Wiring) [Option]
Stabilisateur [Option] / Stabilizer [Option]
