Kubota Utility Tractors M5071NC-NEC1 Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M5071NC-NEC1 Utility Tractors
Number of Pages: 352 Pages
Article S Fréquemment Utilisés / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Soupapes D'admission Et Soupapes D'echappemen T / Inlet Valve And Exhaust Valve
Couvre-Tête / Head Cover
Carter De Chaîne / Gear Case
Pistons Et Vilebrequin / Piston And Crankshaf T
Arbre A Cames Et Arbre De Pignon Fou / Camsha Ft And Idle Gear Shaft
Volant / Flywheel
Volant / Flywheel
Rail Commun / Common Rail
Bride D'eau Et Thermostat / Water Flange And Thermostat
Pompe À Eau / Water Pump
Bride De Filtre A Air Et Valve De Commande De Puissance / Air Cleaner Flange And Throttle Valve
Soupape D'egr / Egr Valve
Filtre À Air / Air Cleaner
Filtre A Air [Parties Composantes] / Air Clea Ner [Component Parts]
Tayau D'admission (Filtre A Air) / Inlet Pipe (Air Cleaner)
Silencieux Du Filtre À Particules Diesel / Di Esel Particulate Filter Muffler
Parenthese De Silencieux / Muffler Bracket
Silencieux Du Filtre À Particules Diesel [Par Ties Composantes] / Diesel Particulate Filter Muffl Er [Component Parts]
Tuyau D'huile (Turbo-Chargeur) / Oil Pipe (Tu Rbo Charger)
Refroidissement / Oil Cooler
Pieces Electriques De Moteur (Detector/Ecu) / Engine Electrical Parts (Sensor/Ecu)
Pieces Electriques De Moteur (Sonde De Silenc Ieux) / Engine Electrical Parts (Muffler Sensor)
Diagmaster / Diagmaster
Reservoir A Carburant Droite / Fuel Tank Rh
Reservoir A Carburant Gauche / Fuel Tank Lh
Remplisseur De Carburant / Fu El Supply
Tuyau A Carburant (Reservoir A Carburant) / Fuel Pipe (Fuel Tank)
Tuyau A Carburant (Filtre A C Arburant) / Fuel Pipe (Fuel Filter)
Tuyau A Carburant (Pumpe De C Ombustible/Separateur) / Fuel Pipe (Fuel Pump/Separ Ator)
Tuyau A Carburant (Reservoir Reniflard) / Fuel Pipe (Fuel Tank Breather)
Tuyau A Carburant (Refroidiss Eur De Carburant) / Fuel Pipe (Fuel Cooler)
Separateur / Separator
Separateur [Parties Composant Es] / Separator [Component Parts]
Filtre A Carburant / Fuel Fil Ter
Ventilateur / Fa N
Tuyau D'eau / Wa Ter Pipe
Radiateur / Radi Ator
Reservoir Du Pad Iateur / Reserve Tank
Alternateur / Alterna Tor
Alternateur [Paries C Omposantes] / Alternator [Component Parts]
Demarreur / Starter
Demarreur [Parties Co Mposantes] / Starter [Component Parts]
Batterie / Battery
Commutateur/Detector (Moteur) / Switch/Sensor (Engine)
Commutateur/Detector (Silencieux) / Switch/Sensor (Muffler)
Commutateur/Detector (Avant) / Switch/Sensor (Front)
Commutateur/Detector (Arriere) / Switch/Sensor (Rear)
Commutateur/Detector (Carter D'embrayage) / Switch/Sensor (Clutch Housin G)
Commutateur (Tableau De Bord) / Switch (Panel Board)
Commutateur (Toit Int Erne) / Switch (Inner Roof)
Commutateur (Panneau Lateral) / Switch (Side Panel)
Relais / Relay
Relais / Relay
Centre De Controle El Ectronique (Moteur) / Electronic Control Unit (Engi Ne)
Centre De Controle El Ectronique (Corps) / Electronic Control Unit (Body)
Panneau / Panel
Phare / Head Light
Phare / Head Light
Phare [Parties Compos Antes] / Head Light [Component Parts]
Feux De Combinaison A Vant / Front Combination Lamp
Lumiere De Travail / Working Light
Feux De Combinaison A Rriere / Rear Combination Lamp
Lamp Et Plaque D'imma Triculation/Balise Lumineuse / License Lamp/Beacon Lamp
Prise De Remorque / T Railer Socket
Plafonnier / Room Lig Ht
Radio-Orateur / Radio Speaker
Cuve De Lavage / Wash Er Tank
Essuie-Glase Avant / Front Wiper
Faisceau Electrique ( Crs) / Electrical Wiring (Crs)
Faisceau Electrique ( Moteur/Capot) / Electrical Wiring (Main/Engine)
Faisceau Electrique ( Principal) / Electrical Wiring (Main)
Faisceau Electrique ( Corps) / Electrical Wiring (Body)
Faisceau Electrique ( Cabine) / Electrical Wiring (Cab)
Carter D'embraya Ge / Clutch Housing
Soupape D'invers Eur / Shuttle Valve
Boite D'engrenag E / Shuttle Gear Case
Covercle De Chan Gement / Shift Cover
Carter De Transm Ission / Transmission Case
Tuyau De Renifla Rd (Carter De Transmission) / Breather Hose (Transm Ission Case)
Couvercle De Car Ter De Boite Arriere / Transmission Case Rear Cover
Carter Pont Arri Ere / Rear Axle Case
Amoritisseur Dis Que / Damper Disk
Pedale De Embray Age / Clutch Pedal
Cable D'embrayag E / Clutch Cable
Arbre De Entree / Input Shaft
Paquet D'embraya Ge (Hi-Lo) [Parties Composantes] / Clutch Pack (Hi- Lo) [Component Parts]
Arbre De Inverse Ur / Shuttle Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Arbre D'entraine Ment / Drive Shaft
Engrenage Coniqu E / Bevel Gear
Differentiel Arr Iere / Rear Differential
Embrayage Pdf / Pto Clutch
Embrayage Pdf [P Arties Composantes] / Pto Clutch [Component Parts]
Soupape D'embray Age Pdf / Pto Clutch Valve
Soupape D'embray Age Pdf [Parties Composantes] / Pto Clutch Valve [C Omponent Parts]
Arbre De Pdf / P To Shaft
Embrayage Avant D'entrainement / Front Drive Clutch
Embrayage Avant D'entrainement [Parties Composantes] / Front Drive Clutch [Component Parts]
Embrayage Hydrau Lique [Parties Composantes] / Hydraulic Clutch (Bi- Speed Turn) [Component Parts]
Fourchette De Ch Angement De Vitesses Principal / Main Gear Shift Fo Rk
Fourchette De Ch Angement De Gamme / Range Gear Shift Fork
Fourchette De Bl Ocage Differentiel / Differential Lock Shift Fork
Levier De Cahnge Ment De Vitesses Principal / Main Gear Shift Lever
Tige De Changeme Nt De Vitesses Principal / Main Gear Shift Rod
Levier De Invers Eur / Shuttle Shift Lever
Levier De Change Ment De Gamme / Range Gear Shift Lever
Fourchette De Pi Gnon Pdf / Pto Gear Shift Rod
Essieu Arriere / Rear Ax Le
Frein Droite / Brake Rh
Frein Gauche / Brake Lh
Arbre A Cames De Frein S Tationnement / Parking Brake Camshaft
Levier De Frein Stationn Ement / Parking Brake Lever
Arbre De Frein Stationne Ment / Parking Brake Shaft
Levier De Frein Secondai Re / Secondary Brake Lever
Pedale De Frien / Brake Pedal
Cylindre De Frein / Brak E Master Cylinder
Tuyau De Frein / Brake P Ipe
Carter Differentiel A Vant / Front Differential Case
Engrenage Conique (Av Ant) / Bevel Gear (Front)
Differentiel Avant / Differential Front
Carter Engrenage Coni Que Droite / Bevel Gear Case Rh
Carter Engrenage Coni Que Gauche / Bevel Gear Case Lh
Carter Reducteur Droi Te / Front Axle Case Rh
Carter Reducteur Gauc He / Front Axle Case Lh
Demi Arbre De Pont Av Ant Droite / Differential Gear Shaft Rh
Demi Arbre De Pont Av Ant Gauche / Differential Gear Shaft Lh
Reducteur Droite / Fr Ont Axle Rh
Reducteur Gauche / Fr Ont Axle Lh
Couvercle De Direction Support / Steerin G Post Cover
Joint De Cardan De Direction / Steering Joint
Servo Direction [Parties Composantes] / Steering Controller [Component Parts]
Barrd De Accouplement/Cylindre De Direct Ion / Tie Rod/Steering Cylinder
Cylindre De Direction [Parties Composant Es] / Steering Cylinder [Component Parts]
Pompe Hydraulique [Par Ties Composantes] / Hydraulic Pump [Component Parts ]
Circuit D'huile Hydrau Lique (Refoulement) / Hydraulic Pipe (Delivery)
Circuit D'huile Hydrau Lique (Direction/Pdf) / Hydraulic Oil Line (Steerin G/Pto)
Circuit D'huile Hydrau Lique (Inverseu/Pdf) / Hydraulic Oil Line (Shuttle/ Pto)
Tuyau De Direction (Re Foulement) / Steering Hose (Delivery)
Bras De Relevage / Hyd Raulic Lift Arm
Clapet De Surcharge/So Upape De Securite / Safety Valve/Relief Valve
Distributeur Controle / Control Valve
Levier De Controle De Position Et D'effort / Draft And Position Control L Ever
Position Et Arbre D'ef Fort / Position And Draft Shaft
Levier De Revenue / Fe Ed Back Lever
Soupape De Contrôle De L'auxiliaire (Fd/Scd) / Auxiliary Control Valve (F D/Scd)
Soupape De Contrôle De L'auxiliaire [Parties Composantes] (Fd) / Auxiliar Y Control Valve [Component Parts] (Fd)
Soupape De Contrôle De L'auxiliaire [Parties Composantes] (Scd) / Auxilia Ry Control Valve [Component Parts] (Scd)
3-Pts Soulevez Le Cyli Ndre D'aide Gauche [Vieux] / 3p-Lift Assist Cylinde R Lh [Old]
3-Pts Soulevez Le Cyli Ndre D'aide Gauche [Nouveau] / 3p-Lift Assist Cylin Der Lh [New]
3-Pts Soulevez Le Cyli Ndre D'aide Droite [Vieux] / 3p-Lift Assist Cylinde R Rh [Old]
3-Pts Soulevez Le Cyli Ndre D'aide Droite [Nouveau] / 3p-Lift Assist Cylin Der Rh [New]
3-Pts Soulevez Le Cyli Ndre D'aide [Parties Composantes] [Vieux] / 3p-Lift Assist Cylinder [Component Parts] [Old]
3-Pts Soulevez Le Cyli Ndre D'aide [Parties Composantes] [Nouveau] / 3p-Li Ft Assist Cylinder [Component Parts] [New]
Tuyau De Reniflard (3- Pts Cylindre) / Breather Hose (3p Cylinder)
Tirant Superieur / Top Link
Bras Inferieur [Nouveau] / Lower Lin K [New]
Barre De Attelage [Vieux] / Swinging Drawbar [Old]
Barre De Attelage [Nouveau] / Swingi Ng Drawbar [New]
Calandre Avant / Front Grille
Capo Superior / Hood (Bonnet) Upper
Capot (Insonorisant/Isolateur) / Hood (Bo Nnet) (Sound Absorber/Insulator)
Capot De Couvercle Lateral / Hood (Bonnet ) Side Cover
Armature De Cabine / Cab Frame
Verre Avant / Front Glass
Porte Droite / Door Rh
Porte Gauche / Door Lh
Fenetre Laterale Droite / Side Window Rh
Fenetre Laterale Gauche / Side Window Lh
Retroviseur / Rearview Mirror
Toit Interne / Inner Roof
Toit Externe / Outer Roof
Amortissant Matériau/Tapis / Damp Material/Floor Mat
Couvercle De Aile Droite / Fender Cover Rh
Couvercle De Cadre / Pillar Cover
Aile / Fender
Air Conditionneur / Air C Onditioner
Conduit D'air / Air Condi Tioner Duct
Tuyau De Chauffage / Heat Er Hose
Condensateur / Condenser
Tuyau De Air Conditionneu R/Tuyau De Condensateur / Air Conditioner Hose/Cond Enser Hose
Compresseur (Climatiseur) / Compressor (Air Conditioner)
Compresseur Support / Com Pressor Bracket
Tuyau De Drainage / Drain Hose
Etiquette (Armature De Cabine) / Label (C Ab Frame)
Silencieux [Option] / Upper Muffler Kit [Opti On]
Alternateur (Faisceau Electrique) [Option] / Alternator Kit (Electrical Wiring) [Option]
Alternateur [Parties Composantes] [Option] / Alternator [Component Parts] [Option]
Kit Commutateur (Pompe) [Option] / Switch Kit (Pumpa) [Option]
Kit De Dégivreur Arrière [Option] / Rear Defo Gger Kit [Option]
Essuie-Glase [Option] / Rear Wiper Kit [Optio N]
Pdf (Engrenage) (540/540e/1000) Conversion [O Ption] / Pto Conversion Kit (Gear) (540/540e/1000) [Option]
Pdf (Levier) (540/540e/1000) Conversion [Opti On] / Pto Conversion Kit (Lever) (540/540e/1000) [O Ption]
Kit Controle De La Valve Auxiliaire (Scd) [Op Tion] / Auxiliary Control Valve Kit (Scd) [Option]
Kit Controle De La Valve Auxiliaire (S/D) [Op Tion] / Auxiliary Control Valve Kit (S/D) [Option]
Kit Controle De La Valve Auxiliaire (Fc) [Opt Ion] / Auxiliary Control Valve Kit (Fc) [Option]
Valve Auxiliaire [Parties Composantes] (S/D) [Option] / Auxiliary Control Valve [Component Parts ] (S/D) [Option]
Valve Auxiliaire [Parties Composantes] (Fc) [ Option] / Auxiliary Control Valve [Component Parts] (Fc) [Option]
Kit Levier De Controle De La Valve Auxiliaire (3eme) [Option] / Auxiliary Control Valve Lever Ki T (3rd) [Option]
Kit Levier De Controle De La Valve Auxiliaire (4eme) [Option] / Auxiliary Control Valve Lever Ki T (4th) [Option]
Kit Attelage Avant (1eme) [Option] / Front Co Upler Kit (1st) [Option]
Kit Attelage Avant (2eme) [Option] / Front Co Upler Kit (2nd) [Option]
Kit Attelage Avant (3eme) [Option] / Front Co Upler Kit (3rd) [Option]
Kit Attelage Avant (4eme) [Option] / Front Co Upler Kit (4th) [Option]
Kit Attelage Avant (5eme) [Option] / Front Co Upler Kit (5th) [Option]
Kit Attelage Avant (Vidange) [Option] / Front Coupler Kit (Drain) [Option]
Kit Vidange Arriere [Option] / Rear Drain Kit [Option]
Kit Soupape De Frein De Remorqu (Soupape) [Op Tion] / Traler Brake Valve Kit (Valve) [Option]
Kit Soupape De Frein De Remorque (Circuit D'h Uile Hydraulique) [Option] / Trailer Brake Valve Ki T (Hydraulic Pipe) [Option]
Kit Soupape De Frein De Remorque (Coupleur) [ Option] / Trailer Brake Valve Kit (Coupler) [Option ]
Support De Soupape De Frein Remorque (Support ) [Option] / Trailer Brake Valve Mounting Kit (Brac Ket) [Option]
Support De Soupape De Frein Remorque (Soupape /Tuyau) [Option] / Trailer Brake Valve Mounting Kit (Valve/Pipe) [Option]
Support De Soupape De Frein Remorque (Coupleu R/Tuyau) [Option] / Trailer Brake Valve Mounting Ki T (Coupler/Pipe) [Option]
Support De Soupape De Frein Remorque (Câblage Électrique) [Option] / Trailer Brake Valve Mountin G Kit (Electrical Wiring) [Option]
Stabilisateur [Option] / Stabilizer [Option]
Volant / Flywheel
Volant / Flywheel
Ventilateur / Fa N
Demarreur / Starter
Batterie / Battery
Relais / Relay
Relais / Relay
Panneau / Panel
Phare / Head Light
Phare / Head Light
Aile / Fender
