Kubota Utility Tractors M125XDT Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M125XDT Utility Tractors
Number of Pages: 328 Pages
Frequently Used Item S / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Pompe D'huile / Oil Pump
Base De Pompe Carburant / Fuel Pump Base
Reniflard / Breather
Clapet De Securite / Relief Valve
Arbre A Cames Et Arbre De Pignon Fou / Camshaft An D Idle Gear Shaft
Volant Du Moteur / Flywheel
Pompe D'injection [Parties Composantes] / Injectio N Pump [Component Parts]
Moteur Controle De Carbrant / Fuel Control Motor
Filtre A Carburant [Parties Composantes] / Fuel Fi Lter [Component Parts]
Kit D'accouplements Rapides [Option] / Water Flang E And Thermostat
Pompe A Eau / Water Pump
Filter A Air / Air Cleaner
Filtre A Air [Parties Composantes] / Air Cleaner [ Component Parts]
Tuyau D'admission / Inlet Pipe
Silencieux / Muffler
Turbo-Chargeur [Parties Composantes] / Turbo Charg Er [Component Parts]
Tuyau D'huile (Turbo-Chargeur) / Oil Pipe (Turbo C Harger)
Base De Pompe D'huile / Hydraulic Pump Base
Levier D'accelerateur / Hand Accelerator Lever
Cable D'accelerateur / Accelerator Wire
Cable D'arret Du Moteur / Engine Stop Wire
Reservoir A Carburant Droite [Se] / Fuel Tank Rh [Se]
Reservoir A Carburant Gauche / Fue L Tank Lh
Tuyau A Carburant / Fuel Pipe
Sedimentaire / Sedimenter
Ventilateur / Fan
Ventilateur / Fan
Tuyau D'eau / Water P Ipe
Radiateur / Radiator
Reservoir Du Radiateu R / Reserve Tank
Alternateur Complet / Alte Rnator
Alternateur [Parties Compo Santes] / Alternator [Component Parts]
Lanceur / Starter
Demarreur [Parties Composa Ntes] / Starter [Component Parts]
Batterie [Se] / Battery [S E]
Commutateur/Detector 1 / S Witch/Sensor 1
Commutateur/Detector 2 / S Witch/Sensor 2
Commutateur / Switch
Interrupteur Principal/Int Errupteur Levier De Commande / Main Switch/Lever Co Ntrol Switch
Relais / Relay
Tableau De Bord / Panel Bo Ard
Tableau De Bord (Pieces Co Mposantes) / Panel Board [Component Parts]
Tachometre Pdf/Indicateur De Vitesse / Pto Tachometer/Speedometer
Panneau De Commande / Cont Rol Panel
Panneau De Commande [Parti Es Composantes] / Control Panel [Component Parts]
Detecteur De Bras De Relev Age / Lift Arm Sensor
Phare / Head Light
Feux Clignotant / Flasher Light
Lumiere De Travail [Type V Ieux] / Working Light [Old Type]
Lumiere De Travail [Type N Ouveau] / Working Light [New Type]
Feux Arriere / Rear Combin Ation Light
Prise De Remorque / Traile R Socket
Cd-Radio Et Annonceur / Cd -Radio And Speaker
Cuve De Lavage / Washer Ta Nk
Came / Wiper
Faisceau Electrique (Moteu R) / Electrical Wiring (Engine)
Faisceau Electrique (Princ Pal) / Electrical Wiring (Main)
Faisceau Electrique (Arrie Re) / Electrical Wiring (Rear)
Faisceau Electrique (Cabin E) / Electrical Wiring (Cab)
Carter De Embrayage / Clutch Housing
Soupapes De Puissance / Power Shift Valve
Soupapes De Pui.(Carr Osserie)[Parties Composantes] / Power Shift Valve ( Body) [Component Parts]
Soupapes De Puiss.(Su Perieur)[Parties Composantes] / Power Shift Valve ( Upper) [Component Parts]
Couvercle De Carter D E Embrayage / Clutch Housing Cover
Carter Intermediaire / Mid Case
Carter De Transmissio N / Transmission Case
Couvercle De Carter D E Boite Arriere / Transmission Case Rear Cover
Pedala D'embrayage / Clutch Pedal
Tige De Embrayage / C Lutch Rod
Couvercle Avant / Fro Nt Cover
Support De Engrenage / Gear Support
Arbre De Entree / Inp Ut Shaft
Premier/Deuxiem Engre Nage / First/Second Shift Gear
Premier Arbre / First Shaft
Troisiem/Quatrieme En Grenage / Third/Fourth Shift Gear
Arbre De Renvoi / Cou Ntershaft
Arbre De Gamme Et Cha Ngement D'vittesses Principal / Main Gear Shift Sha Ft And Range Gear Shaft
Arbre De Changement D E Gamme / Range Gear Shaft
Arbre D'entrainement (Avant) / Drive Shaft (Front)
Arbre D'entrainement (Intermidiaire/Arriere) / Drive Shaft (Middle/Rear)
Couvercle De Transmis Sion / Transmission Case Side Cover
Engrenage Conique / B Evel Gear
Differentiel Arriere / Differential Rear
Pdf Embrayage / Pto C Lutch
Embrayage Pdf [Partie S Composantes] [Vieux] / Pto Clutch [Component Part S] [Old]
Embrayage Pdf [Partie S Composantes] [Nouveau] / Pto Clutch [Component Pa Rts] [New]
Soupape D'embrayage P Df / Pto Clutch Valve
Soupape D'embrayage P Df [Parties Composantes] / Pto Clutch Valve [Compon Ent Parts]
Arbre De Entrainement Pdf / Pto Drive Shaft
Arbre De Pdf / Pto Sh Aft
Embrayage Hydraulique (Virage A 2 Vitesses) / Hydraulic Clutch (Bi-Speed Turn)
Arbre De Virage A 2 V Itesses / Bi-Speed Turn Shaft
Fourchette De Change Ment De Vitesses / Range Gear Shift Fork
Fourchtte De Pdf / P To Shift Fork
Levier De Cahngement De Vitesses Principal / Main Gear Shift Lever
Levier D'inverseur / Shuttle Shift Lever
Tige De Changement V Itesses / Range Gear Shift Rod
Levier De Vitesses P Df [Se] / Pto Gear Shift Lever [Se]
Axe Arriere / Rear Axle
Frein / Brake
Levier De Frein Stationnement / Parking Brake Lever
Pedale De Frien / Brake Pedal
Pedale Bloc.Differentiel Arri Ere / Rear Differential Lock Pedal
Reservoir D'huile De Frein / Brake Oil Tank
Cylindre De Frein [Parties Co Mposantes] / Brake Master Cylinder [Component Parts ]
Tuyau De Frein / Brake Pipe
Support De Reducteur / Fro Nt Axle Bracket
Support De Reducteur / Fro Nt Axle Support
Avant Carter De Differenti El / Front Differential Case
Differentiel Avant / Diffe Rential Front
Carter Engrenage Conique D Roite / Bevel Gear Case Rh
Carter Engrenage Conique G Auche / Bevel Gear Case Lh
Carter Reducteur / Front A Xle Case
Pont Avant / Front Axle
Demi Arbre De Pont Avant / Differential Gear Shaft
Pedale De Inclinaison Du Volant De Direction / Tilt Pedal
Joint De Cardan De Direction / Steering Joint
S.No .;<=54768
Servo Direction [Parties Composantes] [Nouvea U] / Steering Controller [Component Parts] [New]
Support Avant Droit / Hydra Ulic Pump
Pompe Hydraulique [Parties Composantes] / Hydraulic Pump [Component Parts]
Soupape De Regulateur / Reg Ulater Valve
Soupape De Regulateur [Part Ies Composantes] / Regulater Valve [Component Parts ]
Circuit De Huile Hydrauliqu E (Aspiration) / Hydraulic Pipe (Suction)
Circuit De Huile Hydrauliqu E (Refoulement) / Hydraulic Pipe (Delivery)
Circuit D'huile Hydraulique / Hydraulic Oil Line
Valve De Frein Remorque / T Railer Brake Valve
Clapet De Surcharge / Safet Y Valve
Circuit D'huile Hydraulique (Differentiel Arriere) / Hydraulic Oil Line (Bi-Sp Eed Turn/Rear Diff.)
Circuit D'huile Hydraulique (Differentiel Avant) / Hydraulic Oil Line (Front D Ifferential)
Refroidisseur / Oil Cooler
Circuit D'huile Hydraulique (Direction/Pdf) / Hydraulic Oil Line (Steering/Pto )
Tuyau De Direction (Refoule Ment) / Steering Hose (Delivery)
Bras De Relevage [Se] / Hyd Raulic Lift Arm [Se]
Couvercle De Cylindre Hydra Ulique [Se] / Hydraulic Cylinder Cover [Se]
Levier De Verrouillage [Se] / Lowerring Lock Lever [Se]
Soupape De Controle D'effor T / Draft Control Valve
Soupape De Controle D'effor T [Parties Composantes] / Draft Control Valve [Comp Onent Parts]
Barre De Detecteur 1 (Barre /Support De Barre) / Detector Bar 1 (Bar/Bar Suppor T)
Barre De Detecteur 2 (Maill On D'effort) / Detector Bar 2 (Draft Link)
Levier De Contorole De Posi Tion / Position Control Lever
Valve Auxiliaire / Auxiliar Y Control Valve
Valve Auxiliaire (Fd) [Part Ies Composantes] [Vieux] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Valve Auxiliaire (Fd) [Part Ies Composantes] [Nouveau] / Auxiliary Control Valv E (Fd) [Component Parts] [New]
Valve Auxiliaire (Scd) [Par Ties Composantes] [Vieux] / Auxiliary Control Valve (Scd) [Component Parts] [Old]
Valve Auxiliaire (Scd) [Par Ties Composantes] [Nouveau] / Auxiliary Control Val Ve (Scd) [Component Parts] [New]
Tuyau De Valve Auxiliaire / Auxiliary Control Valve Pipe
Levier De Controle De Distr Ibuteur Auxiliaire / Auxiliary Control Valve Lever
Cylindre Assiste Gauche / A Ssist Cylinder Lh
Cylindre Assiste Doroite / Assist Cylinder Rh
Cylindre Assiste [Parties C Omposantes] / Assist Cylinder [Component Parts]
Support De Tirant Superieur / Top Link Br Acket
Bras Inferieurs [Se] [Type Vieux] / Lower Link [Se] [Old Type]
Bras Inferieurs [Se] [Type Nouveau] / Low Er Link [Se] [New Type]
Stabilisateur / Stabilizer
Support De Cylindre Assiste / Assist Cyli Nder Bracket
Protecteur Pdf / Pto Shaft Protector
Capot Superieur / Hood(Bonnet) Upper
Support De Capot / Bonnet Support
Capot Lateral De Inferieur / Hood(Bonnet) Side Lower
Capot Arriere / Hood(Bonnet) Rear
Ar Mature De Cabine / Cab Frame
Gl Ace Avant / Front Glass
Po Rte Droite / Door Rh
Po Rte Gauche / Door Lh
Se Rrure De Porte Droite / Door Lock Rh
Se Rrure Porte Gauche / Door Lock Lh
Fe Netre Laterale [Se] / Side Window [Se]
Vi Tre Arriere (Superieur) / Rear Window (Upper)
Vi Tre Arriere (Inferieur) / Rear Window (Lower)
Re Troviseur / Rearview Mirror
To It Interne / Inner Roof
Si Ege / Seat
Ac Coudoir / Armrest
Ta Pis / Floor Mat
Gu Ide De Levier / Shift Lever Guide
Co Uvercle De Aile / Fender Cover
Co Uvercle De Cadre / Pillar Cover
Ai Le Droite / Fender Rh
Ai Le Gauche / Fender Lh
Su Pport De Cabine Arriere / Cab Bracket Rear
Bo Ite Outils / Tool Box
Air Conditionneur Controleur / Air Conditioner Controller
Air Conditionneur / Air Condit Ioner
Conduit De Air / Air Condition Er Duct
Ventilateur-Moteur / Blower Mo Tor
Tuyau De Chauffage / Heater Ho Se
Condensateur / Condenser
Tuyau De Air Conditionneur Ens Condensateur / Air Conditioner Hose / Condenser Ho Se
Compresseur / Compressor
Compresseur Support / Compress Or Bracket
Tuyau De Drainage / Drain Hose
Etiquette (Arriere) [Se] / Label (Rear) [Se]
Accessories Et Piece De Service / Access Ories And Service Parts
Eclairage De Travail [Option] / Working Light Kit [Option]
Degivreur Arriere [Option] / Rear Defogger Kit [Op Tion]
Couvercle De Reservoir A Carburant [Option] / Fuel Tank Cover Kit [Option]
Vitesse Rampante (Carter D'emgrenages) [Option] / Creep Speed Kit (Gear Case) [Option]
Vitesse Rampante (Fourchette/Levier) [Option] / Cr Eep Speed Kit (Shift Fork/Lever) [Option]
Valve Auxiliaire (Scd) (3eme) [Option] / Auxiliary Control Valve Kit (Scd) (3rd) [Option]
Valve Auxiliaire (Fd) (3eme) [Option] / Auxiliary Control Valve Kit (Fd) (3rd) [Option]
Valve Auxiliaire (Scd) (4eme) [Option] / Auxiliary Control Valve Kit (Scd) (4th) [Option]
Valve Auxiliaire (Scd/Fc) (4eme) [Option] / Auxili Ary Control Valve Kit (Scd/Fc) (4th) [Option]
Valve Auxiliaire (Fd) (4eme) [Option] / Auxiliary Control Valve Kit (Fd) (4th) [Option]
Valve Auxiliaire (Fc) [Option] / Auxiliary Control Valve Kit (Fc) [Option]
Valve Auxiliaire (Scd/Fc) [Parties Composantes] [V Ieux] [Option] / Auxiliary Control Valve (Scd/Fc) [ Component Parts] [Old] [Option]
Valve Auxiliaire (Scd/Fc) [Parties Composantes] [N Ouveau] [Option] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [New] [Option]
Valve Auxiliaire (Fc) [Parties Composantes] [Optio N] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Levier De Commande (3eme) [Option] / Auxiliary Con Trol Valve Lever Kit (3rd) [Option]
Levier De Commande (4eme) [Option] / Auxiliary Con Trol Valve Lever Kit (4th) [Option]
Ventilateur / Fan
Ventilateur / Fan
Lanceur / Starter
Relais / Relay
Phare / Head Light
Came / Wiper
Frein / Brake
S.No .;<=54768
Si Ege / Seat
Ta Pis / Floor Mat
