Kubota Utility Tractors M-120DTC Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M-120DTC Utility Tractors
Number of Pages: 510 Pages
Frequently Used Ite Ms / Frequently Used Items
Bloc Moteur [Type Vieux] / Crankcase [Old Type] # # No.S.<=2z0571 S.No.;<=2z0571 / S.No.<=2z0571 S.No .;<=2z0571
Bloc Moteur [Type Nouveau] / Crankcase [New Type]
Carter D'huile / Oil Pan
Culasse [Type Vieux] / Cylinder Head [Old Type] # # No.S.<=2z0571 S.No.;<=2z0571 / S.No.<=2z0571 S.No .;<=2z0571
Culasse [Type Nouveau] / Cylinder Head [New Type]
Carter De Distribution [Type Vieux] / Gear Case [ Old Type]
Carter De Distribution [Type Nouveau] / Gear Case [New Type]
Couvre-Culasse / Head Cover
Pompe D'huile / Oil Pump
Base De Pompe Carburant / Fuel Pump Base
Reniflard [Type Vieux] / Breather [Old Type]
Reniflard [Type Nouveau] / Breather [New Type]
Clapet De Securite / Relief Valve
Arbre A Cames Et Arbre De Pignon Fou / Camshaft A Nd Idle Gear Shaft
Piston Et Vilebrequin [Type Vieux] / Piston And C Rankshaft [Old Type]
Piston Et Vilebrequin [Type Nouveau] / Piston And Crankshaft [New Type]
Volant Du Moteur / Flywheel
Pompe D'injection [Type Vieux] / Injection Pump [ Old Type]
Pompe D'injection [Type Nouveau] / Injection Pump [New Type]
Pompe D'injection [Parties Composantes] [Type Vie Ux] / Injection Pump [Component Parts] [Old Type] # # No.S.<=2z0571 S.No.;<=2z0571 / S.No.<=2z0571 S.No .;<=2z0571
Pompe D'injection [Parties Composantes] [Type Nou Veau] / Injection Pump [Component Parts] [New Type]
Porte-Injecteur Et Bougie De Prechauffage [Type V Ieux] / Nozzle Holder And Glow Plug [Old Type]
Porte-Injecteur Et Bougie De Prechauffage [Type N Ouveau] / Nozzle Holder And Glow Plug [New Type]
Porte-Injecteur [Parties Composantes] [Type Vieu X] / Nozzle Holder [Component Parts] [Old Type]
Moteur Controle De Carbrant / Fuel Control Motor
Filtre A Carburant [Type Vieux] / Fuel Filter [Ol D Type]
Filtre A Carburant [Type Nouveau] / Fuel Filter [ New Type]
Filtre A Carburant [Parties Composantes] / Fuel F Ilter [Component Parts]
Kit D'accouplements Rapides [Option] / Water Flan Ge And Thermostat
Pompe A Eau / Water Pump
Filtre A Air [Eu] / Air Cleaner [Eu]
Filtre A Air [Excepte [Eu]] / Air Cleaner [Except [Eu]]
Pre-Filtre [Excepte [Eu]] [Type Vieux] / Pre-Clea Ner [Except [Eu]] [Old Type]
Pre-Filtre [Excepte [Eu]] [Type Nouveau] / Pre-Cl Eaner [Except [Eu]] [New Type]
Tuyau D'admission / Inlet Pipe
Silencieux [Type Vieux] / Muffler [Old Type]
Silencieux [Type Nouveau] / Muffler [New Type]
Turbo-Chargeur [Parties Composantes] [Type Vieux] / Turbo Charger [Component Parts] [Old Type]
Turbo-Chargeur [Parties Composantes] [Type Nouvea U] / Turbo Charger [Component Parts] [New Type]
Base De Pompe D'huile / Hydraulic Pump Base
Jeu De Joint Superieur [Type Vieux] / Upper Gaske T Kit [Old Type]
Jeu De Joint Superieur [Type Nouveau] / Upper Gas Ket Kit [New Type]
Jeu De Joint Inferieur [Type Vieux] / Lower Gaske T Kit [Old Type]
Jeu De Joint Inferieur [Type Nouveau] / Lower Gas Ket Kit [New Type]
Cable D'accelerateur / Accelerator Wire
Cable D'arret Du Moteur / Engine Stop Wire
Reservoir A Carburant Droite / Fu El Tank Rh
Reservoir A Carburant Gauche / Fu El Tank Lh
Tuyau A Carburant / Fuel Pipe
Sedimentaire / Sedimenter
Ventilateur / Fan
Tuyau D'eau / Water Pipe
Radiateur / Radiator
Reservoir Du Radiate Ur / Reserve Tank
Alternateur Complet / Alt Ernator
Alternateur [Parties Comp Osantes] [Type Vieux] / Alternator [Component Parts ] [Old Type]
Alternateur [Parties Comp Osantes] [Type Nouveau] / Alternator [Component Par Ts] [New Type]
Lanceur / Starter
Demarreur [Parties Compos Antes] / Starter [Component Parts]
Batterie / Battery
Commutateur/Detector 1 (M Oteur) / Switch/Sensor 1 (Engine)
Commutateur/Detector 2 [T Ype Vieux] / Switch/Sensor 2 [Old Type]
Commutateur/Detector 2 [T Ype Nouveau] / Switch/Sensor 2 [New Type]
Commutateur (Tableau De B Ord) / Switch (Panel Board)
Commutateur (Cabine) / Sw Itch (Cab)
Relais / Relay
Tableau De Bord / Panel B Oard
Tableau De Bord (Pieces C Omposantes) / Panel Board [Component Parts]
Tableau De Controle De L' Atterage 3-Pts. / 3-Point Hitch Control Panel
Tableau De Controle [Part Ies Composantes] / 3-Point Hitch Control Panel [Com Ponent Parts]
Detecteur De Bras De Rele Vage / Lift Arm Sensor
Detecteur D'accelerateur [Type Vieux] / Accelerator Sensor [Old Type]
Detecteur D'accelerateur {Type Nouveau] / Accelerator Sensor [New Type]
Phare / Head Light
Phare / Head Light
Feux Clignotant [Type Vie Ux] / Flasher Light [Old Type]
Feux Clignotant [Type Nou Veau] / Flasher Light [New Type]
Lumiere De Travail / Work Light
Feux Arriere / Rear Combi Nation Light
Prise De Remorque / Trail Er Socket
Cuve De Lavage / Washer T Ank
Essuie-Glase [Type Vieux] / Wiper [Old Type]
Essuie-Glase [Type Nouvea U] / Wiper [New Type]
Faisceau Electrique 1 [Ty Pe Vieux] / Electrical Wiring 1 [Old Type]
Faisceau Electrique 1 [Ty Pe Nouveau] / Electrical Wiring 1 [New Type]
Faisceau Electrique 2 [Ty Pe Vieux] / Electrical Wiring 2 [Old Type]
Faisceau Electrique 2 [Ty Pe Nouveau] / Electrical Wiring 2 [New Type]
Faisceau Electrique (Cabi Ne) [Type Vieux] / Electrical Wiring (Cab) [Old Typ E]
Faisceau Electrique (Cabi Ne) [Type Nouveau] / Electrical Wiring (Cab) [New T Ype]
Carter De Embrayage / Clutch Housing
Soupapes De Puissanc E / Power Shift Valve
Soupapes De Pui.(Car Rosserie)[Parties Composantes] / Power Shift Valve (Body) [Component Parts]
Soupapes De Puiss.(S Uperieur)[Parties Composantes] / Power Shift Valve (Upper) [Component Parts]
Couvercle De Carter De Embrayage / Clutch Housing Cover
Carter Intermediaire / Mid Case
Carter De Transmissi On / Transmission Case
Soupape De Embrayage Pdf / Pto Clutch Valve
Soupape D'embrayage Pdf [Parties Composantes] / Pto Clutch Valve [Compo Nent Parts]
Couvrcle De Carter D E Boite Arriere / Transmission Case Rear Cover
Carter De Frein / Br Ake Case
Amoritisseur Disque / Damper Disk
Pedala D'embrayage / Clutch Pedal
Tige De Embrayage / Clutch Rod
Support De Engrenage / Gear Support
Arbre De Entree / In Put Shaft
Premier/Deuxiem Engr Enage / First/Second Shift Gear
Troisiem/Quatrieme E Ngrenage / Third/Fourth Shift Gear
Arbre De Renvoi / Co Untershaft
Arbre De Gamme Et Ch Angement D'vittesses Principal / Main Gear Shift Sh Aft And Range Gear Shaft
Arbre D'entrainement (Avant) / Drive Shaft (Front)
Arbre D'entrainement (Intermidiaire/Arriere) / Drive Shaft (Middle/Rear )
Couvercle De Transmi Ssion / Transmission Case Side Cover
Differentiel Arriere / Differential Rear
Embrayage De Block D Ifferentiel / Rear Differential Lock Clutch
Arbre De Transmissio N Pdf / Pto Propeller Shaft
Pdf Embrayage / Pto Clutch
Embrayage Pdf [Parti Es Composantes] [Vieux] / Pto Clutch [Component Par Ts] [Old]
Embrayage Pdf [Parti Es Composantes] [Nouveau] / Pto Clutch [Component P Arts] [New]
Arbre De Entrainemen T Pdf / Pto Drive Shaft
Arbre De Pdf / Pto S Haft
Embrayage Hydrauliqu E (Virage A 2 Vitesses) / Hydraulic Clutch (Bi-Spee D Turn)
Arbre De Virage A 2 Vitesses / Bi-Speed Turn Shaft
Fourchette De Chang Ement De Vitesses / Range Gear Shift Fork
Levier De Cahngemen T De Vitesses Principal / Main Gear Shift Lever
Levier De Inverseur [Type Vieux] / Shuttle Shift Lever [Old Type]
Levier De Inverseur [Type Nouveau] / Shuttle Shift Lever [New Type]
Tige De Changement Vitesses / Range Gear Shift Rod
Levier De Commande De Embrayage Pdf / Pto Clutch Lever
Levier De Vitesses Pdf / Pto Gear Shift Lever
Axe Arriere / Rear Axle
Levier De Frein Stationnemen T / Parking Brake Lever
Pedale De Frien / Brake Peda L
Frein De Stationnement / Par King Brake
Reservoir D'huile De Frein / Brake Oil Tank
Cylindre De Frein [Parties C Omposantes] / Brake Master Cylinder [Component Part S]
Tuyau De Frein / Brake Pipe
Support De Reducteur [Eu] / Front Axle Bracket [Eu]
Support De Reducteur [Exc Epte [Eu]] / Front Axle Bracket [Except [Eu]]
Support De Reducteur / Fr Ont Axle Support
Arbre De Transmission / F Ront Propeller Shaft
Avant Carter De Different Iel / Front Differential Case
Differentiel Avant / Diff Erential Front
Blocage De Differentiel A Vant / Front Differential Lock Clutch
Carter Engrenage Conique Droite [Eu] / Bevel Gear Case Rh [Eu]
Carter Engrenage Conique Droite [Excepte [Eu]] / Bevel Gear Case Rh [Except [Eu]]
Carter Engrenage Conique Gauche [Eu] / Bevel Gear Case Lh [Eu]
Carter Engrenage Conique Gauche [Excepte [Eu]] / Bevel Gear Case Lh [Except [Eu]]
Pont Avant / Front Axle
Demi Arbre De Pont Avant / Differential Gear Shaft
Volant De Direction [Type Vieux] / Steering Handle [Old Type]
Pedale De Inclinaison Du Volant De Direction / Tilt Pedal
Joint De Cardan De Direction / Steering Join T
Servo Direction [Parties Composantes] / Stee Ring Controller [Component Parts]
Barrd De Accouplement / Tie Rod
Support Avant Droit / Hydr Aulic Pump
Pompe Hydraulique [Parties Composantes] / Hydraulic Pump [Component Parts]
Pompe Hydraulique(Directio N) [Parties Composantes] / Hydraulic Pump (Steering ) [Component Parts]
Circuit De Huile Hydrauliq Ue (Aspiration) / Hydraulic Pipe (Suction)
Circuit De Huile Hydrauliq Ue (Refoulement) / Hydraulic Pipe (Delivery)
Valve De Frein Remorque / Trailer Brake Valve
Clapet De Surcharge / Safe Ty Valve
Circuit D'huile Hydrauliqu E (Differentiel Arriere) / Hydraulic Oil Line (Bi-S Peed Turn/Rear Diff.)
Circuit D'huile Hydrauliqu E (Differentiel Avant) / Hydraulic Oil Line (Front Differential)
Refroidisseur [Type Vieux] / Oil Cooler [Old Type]
Refroidisseur [Type Nouvea U] / Oil Cooler [New Type]
Circuit D'huile Hydrauliqu E (Refroidisseur) / Hydraulic Oil Line (Oil Cooler)
Circuit D'huile Hydrauliqu E (Direction/Pdf) / Hydraulic Oil Line (Steering/Pt O)
Tuyau De Direction (Refoul Ement) / Steering Hose (Delivery)
Cylindre Hydraulique / Hyd Raulic Cylinder
Bras De Relevage / Hydraul Ic Lift Arm
Couvercle De Cylindre Hydr Aulique / Hydraulic Cylinder Cover
Levier De Verrouillage / L Owerring Lock Lever
Soupape De Controle D'effo Rt / Draft Control Valve
Soupape De Controle D'effo Rt [Parties Composantes] / Draft Control Valve [Com Ponent Parts]
Barre De Detecteur 1 (Barr E/Support De Barre) / Detector Bar 1 (Bar/Bar Suppo Rt)
Barre De Detecteur 2 (Mail Lon D'effort) / Detector Bar 2 (Draft Link)
Valve Auxiliaire [Eu] / Au Xiliary Control Valve [Eu]
Valve Auxiliaire [Excepte [Eu]] / Auxiliary Control Valve [Except [Eu]]
Valve Auxiliaire (Scd/Fc) [Eu] [Parties Composantes] / Auxiliary Control Valv E (Scd/Fc) [Eu] [Component Parts]
Valve Auxiliaire (Fd) [Par Ties Composantes] / Auxiliary Control Valve (Fd) [C Omponent Parts]
Valve Auxiliaire (Scd) [Pa Rties Composantes] / Auxiliary Control Valve (Scd) [Component Parts]
Tuyau De Valve Auxiliaire [Eu] / Auxiliary Control Valve Pipe [Eu]
Tuyau De Valve Auxiliaire [Excepte [Eu]] / Auxiliary Control Valve Pipe [Exce Pt [Eu]]
Levier De Controle De Dist Ributeur Auxiliaire [Excepte [Eu]] / Auxiliary Cont Rol Valve Lever [Except [Eu]]
Cylindre Assiste Gauche [T Ype Vieux] / Assist Cylinder Lh [Old Type]
Cylindre Assiste Gauche [T Ype Nouveau] / Assist Cylinder Lh [New Type]
Cylindre Assiste Doroite [ Type Vieux] / Assist Cylinder Rh [Old Type]
Cylindre Assiste Doroite [ Type Nouveau] / Assist Cylinder Rh [New Type]
Cylindre Assiste [Parties Composantes] [Type Vieux] / Assist Cylinder [Compon Ent Parts] [Old Type]
Cylindre Assiste [Parties Composantes] [Type Nouveau] / Assist Cylinder [Comp Onent Parts] [Old Type]
Cylindre Assiste [Parties Composantes] [Type Nouveau] / Assist Cylinder [Comp Onent Parts] [New Type]
Tirant Superieur [Eu] [Type Vieux] / Top Link [Eu] [Old Type]
Tirant Superieur [Eu] [Type Nouveau] / T Op Link [Eu] [New Type]
Tirant Superieur [Excepte [Eu]] [Type Vi Eux] / Top Link [Except [Eu]] [Old Type]
Tirant Superieur [Excepte [Eu]] [Type No Uveau] / Top Link [Except [Eu]] [New Type]
Bras Inferieurs [Eu] [Type Vieux] / Lowe R Link [Eu] [Old Type]
Bras Inferieurs [Excepte [Eu]] [Type Vie Ux] / Lower Link [Except [Eu]] [Old Type]
Bras Inferieurs [Type Nouveau] / Lower L Ink [New Type]
Chaine De Arret / Check Chain
Barre De Relevage Droite [Eu] [Type Vieu X] / Lift Rod Rh [Eu] [Old Type]
Barre De Relevage Droite [Eu] [Type Nouv Eau] / Lift Rod Rh [Eu] [New Type]
Barre De Relevage Droite [Excepte[Eu]] [ Type Vieux] / Lift Rod Rh [Except [Eu]] [Old Type]
Barre De Relevage Droite [Excepte [Eu]] [Type Nouveau] / Lift Rod Rh [Except [Eu]] [New Typ E]
Mancheron De Barre De Relevage [Excepte [Eu]] / Lift Rod Handle [Except [Eu]]
Barre De Attelage / Drawbar
Capot Avant [Type Vieux] / Hood(Bonnet) Front [Old Type]
Capot Superieur [Eu] [Type Vieux] / Hood(Bonn Et) Upper [Eu] [Old Type]
Capot Superieur [Eu] [Type Nouveau] / Hood(Bo Nnet) Upper [Eu] [New Type]
Capot Superieur [Excepte [Eu]] [Type Vieux] / Hood(Bonnet) Upper [Except [Eu]] [Old Type]
Capot Superieur [Excepte [Eu]] [Type Nouveau] / Hood(Bonnet) Upper [Except [Eu]] [New Type]
Capot Lateral De Superieur [Type Vieux] / Hoo D(Bonnet) Side Upper [Old Type]
Capot Lateral De Superieur [Type Nouveau] / H Ood(Bonnet) Side Upper [New Type]
Colonne Avant/Colonne Arriere / Front Post/Re Ar Post
Capot Lateral De Inferieur [Type Vieux] / Hoo D(Bonnet) Side Lower [Old Type]
Capot Lateral De Inferieur [Type Nouveau] / H Ood(Bonnet) Side Lower [New Type]
Capot Arriere / Hood(Bonnet) Rear
Aile Avant [Eu] [Type Vieux] / Front Fender [ Eu] [Old Type]
C Ardre [Eu] / Cab Frame [Eu]
C Ardre [Excepte [Eu]] / Cab Frame [Except [Eu]]
G Lace Avant / Front Glass
P Orte Droite / Door Rh
P Orte Gauche / Door Lh
S Errure De Porte Droite / Door Lock Rh
S Errure Porte Gauche / Door Lock Lh
F Enetre Laterale / Side Window
V Itre Arriere / Rear Window
R Etroviseur [Eu] / Rearview Mirror [Eu]
R Etroviseur [Excepte [Eu]] / Rearview Mirror [Except [Eu]]
T Oit Interne / Inner Roof
T Oit Externe [Type Vieux] / Outer Roof [Old Type]
T Oit Externe [Type Nouveau] / Outer Roof [New Type]
S Iege [Excepte [Eu] [Gr]] / Seat [Except [Eu] [Gr]]
T Apis [Type Vieux] / Floor Mat [Old Type]
T Apis [Type Nouveau] / Floor Mat [New Type]
C Ouvercle De Viste / Inspection Plate
G Uide De Levier / Shift Lever Guide
C Olonne Du Guide De Levier / Shift Lever Guide Post
C Ouvercle De Aile / Fender Cover
A Ile Droite / Fender Rh
B Alustrade / Balustrade
S Upport De Cabine Avant / Cab Bracket Front
S Upport De Cabine Arriere / Cab Bracket Rear
B Oite Outils / Tool Box
Air Conditionneur Controleur [Type Vieux] / Air Conditioner Controller [Old Type ]
Air Conditionneur Controleur [Type Nouveau] / Air Conditioner Controller [New Ty Pe]
Air Conditionneur / Air Condi Tioner
Conduit De Air / Air Conditio Ner Duct
Ventilateur-Moteur [Type Vieu X] / Blower Motor [Old Type]
Ventilateur-Moteur [Type Nouv Eau] / Blower Motor [New Type]
Condensateur [Type Vieux] / C Ondenser [Eu] [Old Type]
Condensateur [Eu] [Type Nouve Au] / Condenser [Eu] [New Type]
Condensateur [Excepte [Eu]] [ Type Vieux] / Condenser [Except [Eu]] [Old Type]
Condensateur [Excepte [Eu]] [ Type Nouveau] / Condenser [Except [Eu]] [New Type]
Compresseur [Type Vieux] / Co Mpressor [Old Type]
Compresseur [Type Nouveau] / Compressor [New Type]
Compresseur Support [Type Vie Ux] / Compressor Bracket [Old Type]
Compresseur Support [Type Nou Veau] / Compressor Bracket [New Type]
Tuyau De Chauffage / Air Cond Itioner Pipe
Tuyau De Drainage / Drain Hos E
Etiquette 1 [Type Vieux] / Label 1 [Old Type]
Etiquette 1 [Type Nouveau] / Label 1 [New Typ E]
Pieces D'echange De Cas De Transmission [Opti On] / Label 2 [Old Type]
Pieces D'echange De Cas De Transmission [Opti On] / Label 2 [New Type]
Accessories Et Piece De Service / Acces Sories And Service Parts
Pre-Filtre [Eu] [Option] [Type Vieux] / Pre-Clean Er Kit [Eu] [Option] [Old Type]
Pre-Filtre [Eu] [Option] [Type Nouveau] / Pre-Cle Aner Kit [Eu] [Option] [New Type]
Detecteur D'accelerateur [Option] / Accelerator S Ensor Kit [Option]
Degivreur Arriere [Option] / Rear Defogger Kit [O Ption]
Vitesse Rampante 1 (Carter D'emgrenages) [Option] / Creep Speed Kit 1 (Gear Case) [Option]
Vitesse Rampante 2 (Fourchette/Levier) [Option] / Creep Speed Kit 2 (Shift Fork/Lever) [Option]
Pare-Chocs Avant [Eu] [Option] / Front Bumper Kit [Eu] [Option]
Valve Auxiliaire (Scd) (3eme) [Excepte [Eu]] [Opt Ion] / Auxiliary Control Valve Kit (Scd) (3rd) [Exc Ept [Eu]] [Option]
Valve Auxiliaire (Fd) (3eme) [Option] / Auxiliary Control Valve Kit (Fd) (3rd) [Option]
Valve Auxiliaire (Scd) (4eme) [Option] / Auxiliar Y Control Valve Kit (Scd) (4th) [Option]
Valve Auxiliaire (Scd/Fc) (4eme) [Option] / Auxil Iary Control Valve Kit (Scd/Fc) (4th) [Option]
Valve Auxiliaire (Fd) (4eme) [Option] / Auxiliary Control Valve Kit (Fd) (4th) [Option]
Valve Auxiliaire (Fc) [Option] / Auxiliary Contro L Valve Kit (Fc) [Option]
Valve Auxiliaire (Scd) [Parties Composantes] [Opt Ion] / Auxiliary Control Valve (Scd) [Component Par Ts] [Option]
Valve Auxiliaire (Fd) [Parties Composantes] [Opti On] / Auxiliary Control Valve (Fd) [Component Parts ] [Option]
Valve Auxiliaire (Fc) [Parties Composantes] [Opti On] / Auxiliary Control Valve (Fc) [Component Parts ] [Option]
Levier De Commande (3eme) [Option] / Auxilairy Co Ntrol Valve Lever Kit (3rd) [Option]
Levier De Commande (4eme) [Option] / Auxilairy Co Ntrol Valve Lever Kit (4th) [Option]
Aile Avant [Excepte [Eu]] [Option] / Front Fender Kit [Except [Eu]] [Option]
