Kubota Tractors STW37C Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota STW37C Tractor
Number of Pages: 439 Pages
Bloque Motor / Crankcase
Engrase La Cacerola / Oil Pan
Culata Cubierta / Head Cover
Piston Y Ciguenal / Piston And Crankshaft
Volante / Flywheel
Inyeccion Bomba / Injection Pump
Velocidad Control Placa [Antiguo] / Speed Control Plate [Old]
Velocidad Control Placa [Nuevo] / Speed Control Plate [New]
Agua Bomba / Water Pump
Escape Colector/Silenciador / Exhaust Manifold/Muffler
Aire Limpiador / Air Cleaner
Cooperativo De Acelerador / Accelerator Cooperative
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Panel Tablero/Conmutador / Panel Board/Switch
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Rele / Relay
Conmutador/Controlador/Claxon / Switch/Controller/Horn
Conmutador/Sensor (Carroceria) / Switch/Sensor (Body)
Sensor (Adelante Eje) / Sensor (Front Axle)
Faro Delantero [Fr] / Head Light [Fr]
Faro Delantero [Uk] / Head Light [Uk]
Luz Matricula / License Lamp
Intermitente Lampara (Adelante) / Winker Lamp (Front)
Cola Luz / Tail Light
Adelante Trabajo Luz (Adelante) / Work Light (Front)
Trabajo Luz (Trasero)/Luz Del Faro / Work Light (Rear)/Beacon Light
Altavoz / Speaker
Deposito De Lavaparabrisas [Fr] / Washer Tank [Fr]
Deposito De Lavaparabrisas [Uk] / Washer Tank [Uk]
Limpiaparabrisas [Fr] / Wiper [Fr]
Limpiaparabrisas [Uk] / Wiper [Uk]
Electrico Cableado (Adelante) / Electrical Wiring (Front)
Electrico Cableado (Trasero) / Electrical Wiring (Rear)
Electrico Cableado (Cabina) / Electrical Wiring (Cab)
Embrague / Clutch
Embrague Palanca / Clutch Lever
Transmision Caja/Hst / Transmission Case/Hst
Hst (Bloque Cilindro) [Componente Piezas] / Hst (Cylinder Block) [Component Parts]
Hst (Valvula) [Componente Piezas] / Hst (Valve) [Component Parts]
Intermedia Pto Caja / Mid Pto Case
Pto Arbol Contrarrotante / Pto Countershaft
Tdf Embrague / Pto Clutch
Pto Eje / Pto Shaft
Tdf Intermedia / Mid Pto Drive Gear
Hipoide Pinon Eje / Hypoid Pinion Shaft
Bi-Velocidad Girar Eje / Bi-Speed Turn Shaft
Embrague Hidraulico / Double Speed Turn Clutch
Palanca De Control De Velocidad De Marcha / Cruise Control Cable
Velocidad Control Pedal / Speed Control Pedal
Articulacion De Pedal De Control De Velocidad / Speed Control Pedal Link
Reten De Punto Muerto / Neutral Holder
Punto Muerto/Velocidad De Crucero Vinculo / Neutral/Cruise Link
Gama Engranaje Cambio Palanca / Range Shift Lever
Palanca De Cambio De Tdf (Trasero) / Pto Gear Shift Lever (Rear)
Intermedia Pto Engranaje Cambio Palanca / Mid Pto Gear Shift Lever
Eje Trasero / Rear Axle
Freno / Brake
Freno Eje / Brake Shaft
Freno Varilla / Brake Rod
Freno Pedal / Brake Pedal
Estacionamiento Freno / Parking Brake
Helice Eje / Propeller Shaft
Diferencial (Adelante) / Differential (Front)
Adelante Eje / Front Axle
Regulador Valvula / Regulater Valve
Hidraulico Aceite Linea (Entrada) / Hydraulic Oil Line (Inlet)
Linea De Aceite Hidraulico(Impulsion) / Hydraulic Oil Line (Delivery)
Hidraulico Aceite Linea (Potencia Direccion) / Hydraulic Oil Line (Ps)
Tubo Hidraulico (Hst) / Hydraulic Pipe (Hst)
Aceite Refrigerador (Hst) / Oil Cooler (Hst)
Hidraulico Ascenso Brazo / Hydraulic Lift Arm
Posicion Palanca / Position Lever
Bi-Velocidad Girar Valvula / Bi-Speed Turn Valve
Valvula De Giro Bi-Speed [Componente Piezas] / Bi-Speed Turn Valve [Component Parts]
Hidraulico Cilindro Tapa / Hydraulic Cylinder Cap
Hidraulico Cilindro Tapa [Componente Piezas] / Hydraulic Cylinder Cap [Component Parts]
Alejado Control Valvula / Remote Control Valve
Alejado Control Valvula [Componente Piezas] / Remote Control Valve [Component Parts]
Alejado Control Palanca / Remote Control Lever
Parte Superior / Top Link
Bajar Vinculo / Lower Link
Ascenso Varilla / Lift Rod
Barra De Remolque / Drawbar
Adelante Enganche / Front Hitch
Pto Protector
Parrilla Frontal / Front Grille
Capo / Bonnet
Lado Cubierta / Side Cover
Adelante Parrilla Soporte / Front Grille Support
Cabina / Cab
Panel Inferior / Panel Cover
Puerta Izqd / Door Lh
Puerta Derecho / Door Rh
Cerradura De Puerta Izqd / Door Lock Lh
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Asiento Inferior Cubierta / Seat Under Cover
Asiento [Tipo A] / Seat [A Type]
Asiento [Tipo B] / Seat [B Type]
Asiento [Tipo C] / Seat [C Type]
Asiento [Tipo D] / Seat [D Type]
Estera [Viejo] / Mat [Old]
Estera [Nuevo] / Mat [New]
Ruido Supresion (Guardabarros) / Sound Absorber (Fender)
Ruido Supresion (Panel Inferior) / Sound Absorber (Panel Cover)
Adelante Vidrio / Front Glass
Luna De Porton Trasero [Fr] / Hatch Back Glass [Fr]
Luna De Porton Trasero [Uk] / Hatch Back Glass [Uk]
Aire Acondicionador [Componente Piezas] / Air Conditioner [Component Parts]
Aire Acondicionador Conducto / Air Conditioner Duct
Vaciar Manguito (Aire Acondicionador) / Drain Hose (Air Conditioner)
Condensador / Condenser
Coperchio Flessibile Del Condizionatore D'aria / Air Conditioner Hose Cover
Compresor / Compressor
Rueda Delantera (6,00-12) / Front Wheel (6.00-12)
Rueda Delantera (24*8,50-14) / Front Wheel (24*8.50-14)
Rueda Trasera (9,5-22) / Rear Wheel (9.5-22)
Rueda Trasera (13,6-16) / Rear Wheel (13.6-16)
Etiqueta (Hoja De Piso/Peldano) / Label (Floor Sheet/Step)
Accesorios / Accessories
Trasero Limpiaparabrisas Kit [Uk] [Opcion] / Rear Wiper Kit [Uk] [Option]
Pto Trasera Kit [Opcion] / Rear Pto Kit [Option]
Separador Kit [Opcion] / Spacer Kit [Option]
