Kubota Tractors STV32 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota STV32 Tractor
Number of Pages: 493 Pages
Frequently Used Items
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja [Antiguo] / Gear Case [Old]
Engranaje Caja [Nuevo] / Gear Case [New]
Culata Cubierta / Head Cover
Volante / Flywheel
Speed Control Plate
Portainyector [Componentes] / Nozzle Holder [Component Parts]
Agua Bomba / Water Pump
Escape Colector/Silenciador / Exhaust Manifold/Muffler
Aire Limpiador / Air Cleaner
Cooperativo De Acelerador [Nuevo] / Accelerator Cooperative [New]
Filtro De Combustible [Componentes] / Fuel Filter [Component Parts]
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Alternador [Componentes] / Alternator [Component Parts]
Motor De Arranque / Starter
Motor De Arranque [Componentes] / Starter [Component Parts]
Panel/Conmutador / Panel/Switch
Conmutador 1 / Switch 1
Conmutador 2 / Switch 2
Conmutador 3 / Switch 3
Conmutador 4 / Switch 4
Faro Delantero [Excepto [Uk]] / Head Light [Except [Uk]]
Faro Delantero [Uk] / Head Light [Uk]
Luz / Light
Electrico Cableado [Antiguo] / Electrical Wiring [Old]
Electrico Cableado (Adelante) [Nuevo] / Electrical Wiring (Front) [New]
Electrico Cableado (Trasero) [Nuevo] / Electrical Wiring (Rear) [New]
Embrague / Clutch
Embrague Palanca / Clutch Lever
Transmision Caja/Hst / Transmission Case/Hst
Hst (Bloque Cilindro) [Componente Piezas] / Hst (Cylinder Block) [Component Parts]
Hst (Valvula) [Componente Piezas] / Hst (Valve) [Component Parts]
Caja De Diferencial [Excepto [G]] / Differential Gear Case [Except [G]]
Caja De Diferencial [G] / Differential Gear Case [G]
Intermedia Tdf Caja / Mid Pto Case
Pto Arbol Contrarrotante / Pto Countershaft
Embrague Tdf / Pto Clutch
Tdf Eje / Pto Shaft
Intermedia Tdf Accionar Eje / Mid Pto Drive Shaft
Tdf Intermedia / Mid Pto
Hipoide Pinon Eje / Hypoid Pinion Shaft
Bi-Velocidad Girar Eje / Bi-Speed Turn Shaft
Bi-Velocidad Girar Embrague [Antiguo] / Bi-Speed Turn Clutch [Old]
Bi-Velocidad Girar Embrague [Nuevo] / Bi-Speed Turn Clutch [New]
Diferencial Cerradura Cambio Bifurcacion / Rear Differential Lock Shift Fork
Velocidad De Crucero Control Cable / Cruise Control Cable
Pedal De Control De Velocidad / Speed Control Pedal
Velocidad Control Pedal Vinculo / Speed Control Pedal Link
Reten De Punto Muerto / Neutral Holder
Punto Muerto/Velocidad De Crucero Vinculo / Neutral/Cruise Link
Palanca De Cambio De Tdf (Trasero) / Pto Gear Shift Lever (Rear)
Intermedia Tdf Engranaje Cambio Palanca / Mid Pto Gear Shift Lever
Eje Trasero / Rear Axle
Freno / Brake
Freno Eje / Brake Shaft
Freno Varilla / Brake Rod
Freno Pedal / Brake Pedal
Estacionamiento Freno / Parking Brake
Helice Eje / Propeller Shaft
Diferencial (Adelante) / Differential (Front)
Adelante Eje / Front Axle
Direccion Maneta [Antiguo] / Steering Handle [Old]
Direccion Maneta [Nuevo] / Steering Handle [New]
Direccion Controlador [Antiguo] / Steering Controller [Old]
Direccion Controlador [Nuevo] / Steering Controller [New]
Direccion Varillaje (Atar Varilla) / Steering Linkage (Tie Rod)
Cilindro De Direccion [Componentes] / Steering Cylinder [Component Parts]
Bomba Hidraulica [Componentes] / Hydraulic Pump [Component Parts]
Regulador Valvula / Regulater Valve
Linea De Aceite Hidraulico (Entrada) / Hydraulic Oil Line (Inlet)
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line (Delivery)
Linea De Aceite Hidraulico (Potencia Direccion) / Hydraulic Oil Line (Ps)
Tubo Hidraulico (Hst) / Hydraulic Pipe (Hst)
Aceite Refrigerador (Hst) / Oil Cooler (Hst)
Hidraulico Cilindro [Excepto [G]] / Hydraulic Cylinder [Except [G]]
Hidraulico Cilindro [G] / Hydraulic Cylinder [G]
Hidraulico Ascenso Brazo / Hydraulic Lift Arm
Posicion Palanca / Position Lever
Bi-Velocidad Girar Valvula / Bi-Speed Turn Valve
Valvula De Giro Bi-Speed [Componente Piezas] [Antiguo] / Bi-Speed Turn Valve [Component Parts] [Old]
Valvula De Giro Bi-Speed [Componente Piezas] [Nuevo] / Bi-Speed Turn Valve [Component Parts] [New]
Control Valvula [Componente Piezas] [Antiguo] / Control Valve [Component Parts] [Old]
Control Valvula [Componente Piezas] [Nuevo] / Control Valve [Component Parts] [New]
Hidraulico Cilindro Tapa / Hydraulic Cylinder Cap
Hidraulico Cilindro Tapa [Componente Piezas] / Hydraulic Cylinder Cap [Component Parts]
Distribuidor De Servicios Externos [Excepto [G]] / Remote Control Valve [Except [G]]
Distribuidor De Servicios Externos [Componentes] [Excepto [G]] / Remote Control Valve [Component Parts] [Except [G]]
Palanca De Distribuidor De Servicios Externos [Excepto [G]] / Remote Control Valve Lever [Except [G]]
Tercer Punto [Excepto [G]] / Top Link [Except [G]]
Tercer Punto [G] / Top Link [G]
Bajar Vinculo / Lower Link
Ascenso Varilla / Lift Rod
Barra De Remolque [Excepto [G]] / Drawbar [Except [G]]
Adelante Enganche / Front Hitch
Tdf Eje Protector / Pto Shaft Protector
Capo / Bonnet
Capo Parrilla/Lado Cubierta / Bonnet Grille/Side Cover
Soporte De Rejilla Delantera [Antiguo] [Excepto [G]] / Front Grille Support [Old] [Except [G]]
Soporte De Rejilla Delantera [Nuevo] [Excepto [G]] / Front Grille Support [New] [Except [G]]
Soporte De Rejilla Delantera [Antiguo] [G] / Front Grille Support [Old] [G]
Soporte De Rejilla Delantera [Nuevo] [G] / Front Grille Support [New] [G]
Trasero Capo Soporte [Antiguo] / Rear Bonnet Support [Old]
Trasero Capo Soporte [Nuevo] / Rear Bonnet Support [New]
Panel Bastidor / Panel Frame
Guardabarros Dcha [Excepto [G]] / Fender Rh [Except [G]]
Guardabarros Dcha [G] / Fender Rh [G]
Guardabarros Izqd [Excepto [G]] / Fender Lh [Except [G]]
Guardabarros Izqd [G] / Fender Lh [G]
Piso Asiento Cubierta / Floor Seat Cover
Asiento [Tipo A] / Seat [A Type]
Asiento [Tipo B] / Seat [B Type]
Asiento [Tipo C] / Seat [C Type]
Asiento [Tipo D] / Seat [D Type]
Trasero Bastidor / Rear Frame
Peldano [Excepto [G]] / Step [Except [G]]
Peldano [G] / Step [G]
Sonido Amortiguador / Sound Absorber
Rops (Bajar) / Rops (Lower)
Rops (Superior) / Rops (Upper)
Rueda Delantere (6,00-12) / Front Wheel (6.00-12)
Rueda Delantere (24*8,50-14) / Front Wheel (24*8.50-14)
Rueda Trasera (9,5-12) / Rear Wheel (9.5-12)
Rueda Trasera (13,6-16) / Rear Wheel (13.6-16)
Etiqueta (Trasero) [Excepto [G]] / Label (Rear) [Except [G]]
Etiqueta (Trasero) [G] / Label (Rear) [G]
Kit Cooperativo De Acelerador [Opcion] / Accelerator Cooperative Kit [Option]
Intermedia Tdf [Opcion] / Mid Pto Kit [Option]
Partes De Reemplazo Kit [Opcion] / Replacement Parts Kit [Option]
Separador Kit [Opcion] / Spacer Kit [Option]
Direccion Controlador [Opcion] / Steering Controller [Option]
