Kubota Tractors ST371C Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota ST371C Tractor
Number of Pages: 424 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Volante / Flywheel
Combustible Arbol De Levas / Fuel Camshaft
Agua Bomba / Water Pump
Escape Colector/Silenciador / Exhaust Manifold/Muffler
Aire Limpiador / Air Cleaner
Hidraulico Bomba Soporte / Hydraulic Pump Holder
Piezas Electricas Del Motor (Conmutador/Sensor) / Engine Electrical Parts (Switch/Sensor)
Palanca Del Acelerador / Accelerator Lever
Cooperativo De Acelerador / Accelerator Cooperative
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Panel/Conmutador / Panel/Switch
Tablero De Instrumentos [Componente Piezas] / Panel Board [Component Parts]
Conmutador/Sensor (Motor) 1 / Switch/Sensor (Engine) 1
Conmutador/Sensor (Motor) 2 / Switch/Sensor (Engine) 2
Conmutador/Controlador/Claxon / Switch/Controller/Horn
Rele / Relay
Conmutador/Sensor (Carroceria) / Switch/Sensor (Body)
Sensor (Adelante Eje) / Sensor (Front Axle)
Faro Delantero [Fr] / Head Light [Fr]
Faro Delantero [Uk] / Head Light [Uk]
Luz Matricula / License Lamp
Intermitente Lampara / Winker Lamp
Cola Luz / Tail Light
Adelante Trabajo Luz (Adelante) / Working Light (Front)
Trabajo Luz (Posterior) / Lámpara De Faro Luminoso / Working Light (Rear)/Beacon Lamp
Altavoz / Speaker
Deposito De Lavaparabrisas [Fr] / Washer Tank [Fr]
Deposito De Lavaparabrisas [Uk] / Washer Tank [Uk]
Limpiaparabrisas [Fr] / Wiper [Fr]
Limpiaparabrisas [Uk] / Wiper [Uk]
Electrico Cableado (Adelante) / Electrical Wiring (Front)
Electrico Cableado (Trasero) / Electrical Wiring (Rear)
Electrico Cableado (Cabina) [Fr] / Electrical Wiring (Cab) [Fr]
Electrico Cableado (Cabina) [Uk] / Electrical Wiring (Cab) [Uk]
Embrague / Clutch
Embrague Palanca / Clutch Lever
Transmision Caja/Hst / Transmission Case/Hst
Hst (Bloque Cilindro) [Componente Piezas] / Hst (Cylinder Block) [Component Parts]
Hst (Válvula) [Componente Piezas] / Hst (Valve) [Component Parts]
Trasero Caja / Rear Case
Tdf Arbol Contrarrotante / Pto Counter Shaft
Tdf Embrague / Pto Clutch
Tdf Eje / Pto Shaft
Tdf Intermedia / Mid Pto Drive Gear
Hipoide Pinon Eje / Hypoid Pinion Shaft
Bi-Velocidad Girar Eje / Bi-Speed Turn Shaft
Embrague Hidraulico / Hydraulic Clutch
Palanca De Control De Velocidad De Marcha / Cruise Control Cable
Velocidad Control Pedal / Speed Control Pedal
Articulacion De Pedal De Control De Velocidad / Speed Control Pedal Link
Reten De Punto Muerto / Neutral Holder
Punto Muerto/Velocidad De Crucero Vinculo / Neutral/Cruise Link
Palanca De La Cambio De Engranaje / Range Gear Shift Lever
Palanca De Cambio De Tdf (Trasero) / Pto Gear Shift Lever (Rear)
Intermedia Tdf Engranaje Cambio Palanca / Mid Pto Gear Shift Lever
Trasero Eje / Rear Axle
Freno / Brake
Freno Eje / Brake Shaft
Freno Varilla / Brake Rod
Freno Pedal / Brake Pedal
Estacionamiento Freno / Parking Brake
Diferencial (Anterior) / Differential (Front)
Adelante Eje Caja / Front Axle Case
Regulador Valvula / Regulater Valve
Hidraulico Aceite Linea (Entrada) / Hydraulic Oil Line (Inlet)
Hidraulico Aceite Linea (Impulsion) / Hydraulic Oil Line (Delivery)
Hidraulico Aceite Linea (Potencia Direccion) / Hydraulic Oil Line (Ps)
Aceite Refrigerador (Hst) / Oil Cooler (Hst)
Brazo De Elevacion / Hydraulic Lift Arm
Posicion Control Palanca / Position Control Lever
Bi-Velocidad Girar Valvula / Bi-Speed Turn Valve
Bi-Velocidad Girar Valvula [Componente Piezas] / Bi-Speed Turn Valve [Component Parts]
Distribuidor / Control Valve
Distribuidor [Componente Piezas] / Control Valve [Component Parts]
Hidraulico Cilindro Tapa / Hydraulic Cylinder Cap
Hidraulico Cilindro Tapa [Componente Piezas] / Hydraulic Cylinder Cap [Component Parts]
Distribuidor De Servicios Externos / Auxiliary Control Valve
Distribuidor De Servicios Externos [Componente Piezas] / Auxiliary Control Valve [Component Parts]
Palanca De Distribuidor De Servicios Externos / Auxiliary Control Lever
Bajar Vinculo / Lower Link
Ascenso Varilla / Lift Rod
Barra De Remolque / Drawbar
Enganche Delantero / Front Hitch
Tdf Protector / Pto Protector
Capo / Hood (Bonnet)
Lado Cubierta / Side Cover
Soporte Parrilla Frontal / Front Glille Support
Cabina Bastidor / Cab Frame
Panel Inferior / Panel Cover
Puerta Izquierdo / Door Lh
Puerta Derecho / Door Rh
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Asiento Inferior Cubierta / Seat Under Cover
Asiento [A Tipo] / Seat [A Type]
Asiento [B Tipo] / Seat [B Type]
Asiento [C Tipo] / Seat [C Type]
Asiento [D Tipo] / Seat [D Type]
Estera / Mat
Ruido Supresion (Guardabarros) / Sound Absorber (Fender)
Ruido Supresion (Panel Inferior) / Sound Absorber (Panel Cover)
Adelante Vidrio / Front Glass
Trasero Ventana [Fr] / Hatch Back Glass [Fr]
Trasero Ventana [Uk] / Hatch Back Glass [Uk]
Aire Acondicionador [Componentes] / Air Conditioner [Component Parts]
Conducto Aire Acondicionador / Air Conditioner Duct
Manguera De Vaciado (Aire Acondicionado) / Drain Hose (Air Conditioner)
Condensador / Condenser
Coperchio Flessibile Del Condizionatore D'aria / Air Conditioner Hose Cover
Compresor / Compressor
Rueda Delantera (6,00-12) / Front Wheel (6.00-12)
Rueda Delantera (24*8.50-14) / Front Wheel (24*8.50-14)
Rueda Trasera (9,5-22) / Rear Wheel (9,5-22)
Rueda Trasera (13,6-16) / Rear Wheel (13,6-16)
Etiqueta (Trasero) [Fr] / Label (Rear) [Fr]
Etiqueta (Trasero) [Uk] / Label (Rear) [Uk]
Etiqueta (Hoja De Piso/Peldano) / Label (Floor Sheet/Step)
Accesorio Y Pieza De Servicio / Accessories And Service Parts
Trasero Limpiaparabrisas Kit [Uk] [Opcion] / Rear Wiper Kit [Uk] [Option]
Tdf Trasera Kit [Opcion] / Rear Pto Kit [Option]
Cortacespedes Ascenso Cilindro Kit (Manguito) [Opcion] / Mower Lift Cylinder Kit (Hose) [Option]
Cortacespedes Ascenso Cilindro Kit (Cilindro) [Opcion] / Mower Lift Cylinder Kit (Cylinder) [Option]
Cortacespedes Ascenso Cilindro (Derecho) [Componente Piezas] [Opcion] / Mower Lift Cylinder (Rh) [Component Parts] [Option]
Cortacespedes Ascenso Cilindro (Izquierdo) [Componente Piezas] [Opcion] / Mower Lift Cylinder (Lh) [Component Parts] [Option]
Separador Kit [Opcion] / Spacer Kit [Option]
