Kubota Tractor STW40 Spare Parts Catalog EN FR
Language: French, English
Model: Kubota STW40 Tractor
Number of Pages: 212 Pages
Frequently Used Items / Frequently Used Items
B Loc Moteur / Crankcase
C Arter D'huile / Oil Pan
C Ulasse / Cylinder Head
K It D'accouplements Rapides [Option] / Gear Case
C Ouvre-Culasse / Head Cover
P Aliers De Principal / Main Bearing Case
A Rbre A Cames Et Arbre De Pignon Fou / Camshaft And Idle Gear Shaft
P Istons Et Vilebrequin / Piston And Crankshaft
V Olant Du Moteur / Flywheel
A Rbre A Cames Dalimentation / Fuel Camshaft
D Ispositif De Ralentisseur / Idle Apparatus
P Ompe D'injection / Injection Pump
R Egulateur De Vitesses / Governor
P Laque De Limiteur De Vitesse [Vieux] / Speed Contro L Plate [Old]
P Laque De Limiteur De Vitesse [Nouveau] / Speed Cont Rol Plate [New]
P Orte-Injecteur Et Bougie De Prechauffage / Nozzle H Older And Glow Plug
P Orte-Injecteur [Parties Composantes] / Nozzle Holde R [Component Parts]
K It D'accouplements Rapides [Option] / Water Flange And Thermostat
P Ompe A Eau / Water Pump
S Oupapes Culbuteurs / Valve And Rocker Arm
C Ollecteur D'admission / Inlet Manifold
C Ollecteur D'echappment/Silencieux / Exhaust Manifol D/Muffler
F Ilter A Air / Air Cleaner
J Eu De Joints Super. / Upper Gasket Kit
J Eu De Joints Infer. / Lower Gasket Kit
L Evier D'accelerateur / Accelerator Lever
D 'Acceleration Automatique / Accelerator Cooperative
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant [Parties Composan Tes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Tuyau D'eau / Water Pip E
Radiateur / Radiator
Reservoir Du Radiateur / Reserve Tank
Alternateur Complet / Altern Ator
Alternateur [Parties Composa Ntes] / Alternator [Component Parts]
Lanceur / Starter
Demarreur [Parties Composant Es] / Starter [Component Parts]
Batterie / Battery
Tableau De Bord/Contacteur / Panel Board/Switch
Tableau De Bord [Pieces Comp Osantes] / Panel Board [Component Parts]
Commutateur/Detector (Moteur ) / Switch/Sensor (Engine)
Relais / Relay
Commutateur/Controleur/Avert Isseur / Switch/Controller/Horn
Commutateur/Detector (Corps) / Switch/Sensor (Body)
Detecteur (Pont Avant) / Sen Sor (Front Axle)
Feux De Route [Fr] / Head Li Ght [Fr]
Feux De Route [Uk] / Head Li Ght [Uk]
Lampe Plaque Immatriculation / License Lamp
Faisceau Electrique (Avant) / Electrical Wiring (Front)
Faisceau Electrique (Arriere ) / Electrical Wiring (Rear)
Embrayage / Clutch
Levier D'embrayage / Cl Utch Lever
Pedala D'embrayage / Cl Utch Pedal
Carter D'embrayage / Cl Utch Housing
Carter De Transmission/ Hst / Transmission Case/Hst
Hst (Bloc-Cylindre) [Pa Rties Composantes] / Hst (Cylinder Block) [Componen T Parts]
Hst (Soupape De Securit E) [Parties Composantes] / Hst (Valve) [Component P Arts]
Carter De Differentiel / Differential Gear Case
Carter De Pdf / Mid Pto Case
Arbre Pdf Interm / Pto Countershaft
Pdf Embrayage / Pto Clu Tch
Arbre De Prise De Force / Pto Shaft
Arbre Menant De Pdf Ven Trale / Mid Pto Drive Gear
Pdf Ventrale / Mid Pto
Arbre De Pignon Hypoide / Hypoid Pinion Shaft
Arbre De Virage Vitesse S / Bi-Speed Turn Shaft
Embrayage Hydraulique / Double Speed Turn Clutch
Fourchette De Changemen T De Gamme / Range Gear Shift Fork
Fourchette De Blocage D Ifferentiel / Differential Lock Shift Fork
Levier De Commande D'av Ance / Cruise Control Lever
Cable De Commande D'ava Nce / Cruise Control Cable
Pedale De Commande Vite Sse / Speed Control Pedal
Biellete De Pedale De C Ommande Vitesse / Speed Control Pedal Link
Support Neutre / Neutra L Holder
Nuetre/Croisiere Bielle Te / Neutral/Cruise Link
Levier De Changement De Gamme / Range Shift Lever
Levier De Tranission Au X Roues Avant / Front Wheel Drive Lever
Levier De Vitesses Pdf (Arriere) / Pto Gear Shift Lever (Rear)
Levier Pdf Ventrale / M Id Pto Gear Shift Lever
Axe Arriere / Rear Axle
Frein / Brake
Arbre De Trein / Brake Shaft
Tige De Frein / Brake Rod
Pedale De Frien / Brake Pedal
Frein De Stationnement / Parkin G Brake
Pedale De Verrouillage Du Diffe Rentiel / Differential Lock Pedal
Chassis Avant / Front Axle F Rame
Arbre De Transmission / Prop Eller Shaft
Carter Reducteur / Front Axl E Case
Differentiel (Avant) / Diffe Rential (Front)
Carter Engre-Conique / Bevel Gear Case
Pont Avant / Front Axle
Barrd De Accouplement/Cylindre De Direction / T Ie Rod/Steering Cylinder
Cylindre De Direction [Parties Composantes] / S Teering Cylinder [Component Parts]
Support Avant Droit / Hydraul Ic Pump
Pompe Hydraulique [Parties Co Mposantes] / Hydraulic Pump [Component Parts]
Soupape De Regulateur / Regul Ater Valve
Circuit C'huile Hydraulique / Hydraulic Oil Line (Inlet)
Circuit D'huile Hydraulique ( Refoulement) / Hydraulic Oil Line (Delivery)
Circuit D'huile Hydraulique D Irection Assistee / Hydraulic Oil Line (Ps)
Tuyau De Hydraulique (Hst) / Hydraulic Pipe (Hst)
Radiateur D'huile (Hst) / Oil Cooler (Hst)
Cylindre Hydraulique / Hydrau Lic Cylinder
Bras De Relevage / Hydraulic Lift Arm
Levier De Position / Position Lever
Soupape De Commande / Bi-Spee D Turn Valve
Soupape De Commande [Parties Composantes] / Bi-Speed Turn Valve [Component Parts ]
Distributeur Hydraulique / Co Ntrol Valve
Distributeur [Parties Composa Ntes] / Control Valve [Component Parts]
Capuchon De Cylindre / Hydrau Lic Cylinder Cap
Capuchon De Cylindre [Parties Composantes] / Hydraulic Cylinder Cap [Component P Arts]
Valve Auxiliaire / Remote Con Trol Valve
Valve Auxiliaire [Parties Com Posantes] / Remote Control Valve [Component Parts]
Levier De Distributeur Auxili Aire / Remote Control Lever
Tirant Superieur / Top Link
Tirant Inferieur / Lower Link
Barre De Relevage / Lift Rod
Barre D'attelage / Drawbar
Attelage / Front Hitch
Protection Pdf / Pto Protector
Capot / Bonnet
Capot Lateral / Side Cover
Support De Grille Avant / Front Grille Support
Cadre De Panneau / Panel Frame
Retroviseur [Fr] / Rearview Mirror [Fr]
Retroviseur [Uk] / Rearview Mirror [Uk]
Aile Droite / Fender Rh
Aile Gauche / Fender Lh
Couvercle Inferieur / Seat Under Cover
Siege [Type A] / Seat [A Type]
Siege [Type B] / Seat [B Type]
Siege [Type C] / Seat [C Type]
Siege [Type D] / Seat [D Type]
Chassis Arriere / Rear Frame
Marchepied / Step
Cadre Anti-Renversment (Inferieur) / R Ops (Lower)
Cadre Anti-Renversment (Superieur) / R Ops (Upper)
Roue Avant (6,00-12) / Front Wh Eel (6.00-12)
Roue Avant (24*8,50-14) / Front Wheel (24*8.50-14)
Roue Arriere (9,5-22) / Rear Wh Eel (9.5-22)
Roue Arriere (13,6-16) / Rear Wheel (13.6-16)
Accessoires / Accessories
P To Arriere Kit [Option] / Rear Pto Kit [Option]
K It D'entretoise [Option] / Spacer Kit [Option]
Ventilateur / Fan
Lanceur / Starter
Batterie / Battery
Relais / Relay
Embrayage / Clutch
Frein / Brake
Capot / Bonnet
Marchepied / Step
