Kubota Tractor STW37C Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota STW37C Tractor
Number of Pages: 260 Pages
Itens Uso Frequente / F Requently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Arvore Cames E Veio / Camshaft And Idle Gear S Haft
Volante Motor / Flywheel
Veio / Fuel Camshaft
Ponto Neutro / Idle Apparatus
Regulador Velocidade [Antiga] / Speed Control Plate [Old]
Regulador Velocidade [Nova] / Speed Control Pl Ate [New]
Suporte Bico [Peças Componentes] / Nozzle Hold Er [Component Parts]
Bomba Agua E Termostacto / Water Flange And Th Ermostat
Bomba Agua / Water Pump
Escape Colector/Panela / Exhaust Manifold/Muff Ler
Filtro Ar / Air Cleaner
Alavanca Acelarador / Accelerator Lever
Interbloqueio Do Acelerador / Accelerator Coop Erative
Deposito Combustivel / Fuel Ta Nk
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo [Peças Componen Tes] / Fuel Filter [Component Parts]
Ventoinha / Fan
Tubo Agua / Water Pipe
Radiador / R Adiator
Alternador / Alternator
Alternador [Peças Componentes ] / Alternator [Component Parts]
Motor Arranque / Starter
Painel/Interruptor / Panel Bo Ard/Switch
Painel [Peças Componentes] / Panel Board [Component Parts]
Interruptor/Sensor (Bloco Mot Or) / Switch/Sensor (Engine)
Relé / Relay
Interruptor/Controlador/Buzin A / Switch/Controller/Horn
Interruptor/Sensor (Corpo) / Switch/Sensor (Body)
Sensor (Eixo Dianteiro) / Sen Sor (Front Axle)
Farol Dianteiro [Fr] / Head L Ight [Fr]
Farol Dianteiro [Uk] / Head L Ight [Uk]
Farol Matricula / License Lam P
Lampada (Dianteiro) / Winker Lamp (Front)
Farol Traseiro / Tail Light
Ficha Reboque / Trailer Socke T
Luzes Trabalho (Dianteiro) / Work Light (Front)
Farois Trabalho (Traseiros)/F Arol Matricula / Work Light (Rear)/Beacon Light
Luz Interior / Room Light
Altifalante / Speaker
Deposito Limpa Parabrisas [Fr ] / Washer Tank [Fr]
Deposito Limpa Parabrisas [Uk ] / Washer Tank [Uk]
Escova Limpa Vidros [Fr] / Wi Per [Fr]
Escova Limpa Vidros [Uk] / Wi Per [Uk]
Cablagem Electrica (Dianteiro ) / Electrical Wiring (Front)
Cablagem Electrica (Traseiros ) / Electrical Wiring (Rear)
Cabalagem Eletrica (Cabine) / Electrical Wiring (Cab)
Embraiagem / Clutch
Alavanca Da Embraiag Em / Clutch Lever
Pedal Embraiagem / C Lutch Pedal
Caixa Da Transmissão /Hst / Transmission Case/Hst
Hst (Bloco Do Cilind Ro) [Peças Componentes] / Hst (Cylinder Block) [Com Ponent Parts]
Hst (Válvula) [Peças Componentes] / Hst (Valve) [Component Parts]
Diferencial / Differ Ential Gear Case
Kit Da Tdf Traseira / Mid Pto Case
Veio Gamas Velocidad Es / Range Gear Shaft
Contraveio De Tdf / Pto Countershaft
Embraiagem Tdf / Pto Clutch
Veio Tdf / Pto Shaft
Carreto De Acionamen To Da Tdf Intermédia / Mid Pto Drive Gear
Tdf Central / Mid Pt O
Veio Do Pinhão Hipói De / Hypoid Pinion Shaft
Diferencial Carter / Rear Differential
Veio Bi-Speed / Bi-S Peed Turn Shaft
Embraiagem Hidraulic A / Double Speed Turn Clutch
Forqueta Ve Locidades / Range Gear Shift Fork
Alavanca / Differential Lock Shift Fork
Control Vel Ocidade / Cruise Control Lever
Cabo De Con Trolo Da Velocidade De Cruzeiro / Cruise Control Ca Ble
Pedal Acela Rador / Speed Control Pedal
Ligação Do Pedal De Controlo De Velocidade / Speed Control Ped Al Link
Fixador Do Neutro / Neutral Holder
Ligação Da Velocidade De Cruzeiro/Neutro / Neutral/Cruise Link
Alavanca Ve Locidades / Range Shift Lever
Alavanca Du Pla Traccao / Front Wheel Drive Lever
Alavanca Td F (Traseiros) / Pto Gear Shift Lever (Rear)
Alavanca Da S Mudanças De Tdf Intermédia / Mid Pto Gear Shift L Ever
Eixo Traseiro / Rear Axle
Travão / Brake
Eixo / Brake Shaft
Tirante Travao / Brake Ro D
Pedal Travao / Brake Peda L
Travão De Estacionamento / Parking Brake
Bloqueio Diferencial / Di Fferential Lock Pedal
Suporte Eixo Frente / Fr Ont Axle Frame
Veio Primario / Propelle R Shaft
Carter Eixo Frente / Fro Nt Axle Case
Engrenagem Cónica (Diant Eira) / Bevel Gear (Front)
Diferencial (Dianteiro) / Differential (Front)
Carter Eixo / Front Axle Case
Carter Grupo Conico / Be Vel Gear Case
Eixo Dianteiro / Front A Xle
Coluna Da Direção / Steering Handle
Distribuidor Direcção / Steering Controller
Rotula/Cilindro Direcção / Tie Rod/Steering Cyl Inder
Cilindro Direcção [Peças Componentes] / Steerin G Cylinder [Component Parts]
Bomba Hidraulico [Peças Compo Nentes] / Hydraulic Pump [Component Parts]
Válvula Do Regulador / Regula Ter Valve
Linha De Óleo Hidráulico (Ent Rada) / Hydraulic Oil Line (Inlet)
Linha De Óleo Hidráulico (For Necimento) / Hydraulic Oil Line (Delivery)
Linha De Óleo Hidráulico (Ps) / Hydraulic Oil Line (Ps)
Tubo Hidráulico (Hst) / Hydra Ulic Pipe (Hst)
Arrefecedor Do Óleo (Hst) / O Il Cooler (Hst)
Cilindro Hidraulico / Hydraul Ic Cylinder
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Alavanca De Posicionamento / Position Lever
Válvula Bi-Speed Turn / Bi-Sp Eed Turn Valve
Válvula Bi-Speed Turn [Peças Componentes] / Bi-Speed Turn Valve [Component Parts ]
Valvula Control / Control Val Ve
Valvula Control [Peças Compon Entes] / Control Valve [Component Parts]
Tampa Do Cilindro Hidráulico / Hydraulic Cylinder Cap
Tampa Do Cilindro Hidráulico [Peças Componentes] / Hydraulic Cylinder Cap [Compo Nent Parts]
Distribuidor Auxiliar / Remot E Control Valve
Distribuidor Auxiliar [Peças Componentes] / Remote Control Valve [Component Part S]
Valvula Control / Remote Cont Rol Lever
Elo Supe Rior / Top Link
Ligacao Inferior / Lower Link
Tirante De Elevação / Lift Rod
Barra Re Boque / Drawbar
Puxo / F Ront Hitch
Protecca O Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot / Bonnet
Grelha Do Capot / Side Cover
Trico Capot / Bonnet Lock
Suporte Da Grelha Dianteira / Front Grille Supp Ort
Placa / Shutter Plate
Cab Ine / Cab
Pai Nel Inferior / Panel Cover
Gui A Drt / Lever Guide Rh
Gui A Esq / Lever Guide Lh
Por Ta, Lado Esquerdo / Door Lh
Por Ta, Lado Direito / Door Rh
Fec Hadura Da Porta, Lado Esquerdo / Door Lock Lh
Fec Hadura Da Porta, Lado Direito / Door Lock Rh
Tej Adilho Interior / Inner Roof
Tej Adilho Exterior / Outer Roof
Ass Ento Por Baixo Da Cobertura / Seat Under Cover
Ass Ento [Tipo A] / Seat [A Type]
Ass Ento [Tipo B] / Seat [B Type]
Ass Ento [Tipo C] / Seat [C Type]
Ass Ento [Tipo D] / Seat [D Type]
Tap Ete [Velho] / Mat [Old]
Tap Ete [Novo] / Mat [New]
Sil Enciador (Guarda) / Sound Absorber (Fender)
Sil Enciador (Painel Inferior) / Sound Absorber (Panel Cover)
Dia Nteira Do Suporte Da Cabine / Cab Bracket Front
Tra Seira Do Suporte Da Cabine / Cab Bracket Rear
Vid Ro Frente E Traseiro / Front Glass
Vid Ro Traseira Da Escotilha [Fr] / Hatch Back Glass [F R]
Vid Ro Traseira Da Escotilha [Uk] / Hatch Back Glass [U K]
Esp Elho Retrovisor / Rearview Mirror
Ar Condicionado / Air Conditione R
Air Condicionado [Peças Componen Tes] / Air Conditioner [Component Parts]
Tubo Ar Condicionado / Air Condi Tioner Duct
Mangueira De Drenagem (Ar Condic Ionado) / Drain Hose (Air Conditioner)
Condesador / Condenser
Tubo Ar Condicionado/Tubo Conden Sador / Air Conditioner Hose/Condenser Hose
Pokrywa Przewodu Elastycznego Kl Imatyzatora / Air Conditioner Hose Cover
Compressor / Compressor
Roda Frente (6,00-12) / Front Wheel ( 6.00-12)
Roda Frente (24*8,50-14) / Front Whee L (24*8.50-14)
Roda Traseira (9,5-22) / Rear Wheel ( 9.5-22)
Roda Traseira (13,6-16) / Rear Wheel (13.6-16)
Etiqueta (Dianteiro) / Label (Front)
Etiqueta (Traseirios) / Label (Rear)
Etiqueta (Piso/Degrau) / Label (Floor Sh Eet/Step)
Acessorios / Accessories
K It Limpa Vidro Traseiros [Uk] [Opção] / Rear Wiper Kit [Uk] [Option]
C Ilindro De Elevação Do Cortador De Relva [Opção] / Rear Pto Kit [Option]
