Kubota Tractor STW34 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota STW34 Tractor
Number of Pages: 214 Pages
Itens Uso Frequente / Fr Equently Used Items
Bl Oco Motor / Crankcase
Ca Rter Oleo / Oil Pan
Ca Beca Motor / Cylinder Head
Ca Rreto / Gear Case
Ta Mpa Cabeça / Head Cover
Ro Lamento Principal / Main Bearing Case
Ar Vore Cames E Veio / Camshaft And Idle Gear Shaft
Pi Ston E Cambota / Piston And Crankshaft
Vo Lante Motor / Flywheel
Ve Io / Fuel Camshaft
Po Nto Neutro / Idle Apparatus
Bo Mba Injectora / Injection Pump
Re Gulador / Governor
Re Gulador Velocidade [Antiga] / Speed Control Plate [ Old]
Re Gulador Velocidade [Nova] / Speed Control Plate [Ne W]
Ve La Pre Aquecimento / Nozzle Holder And Glow Plug
Su Porte Bico [Peças Componentes] / Nozzle Holder [Com Ponent Parts]
Bo Mba Agua / Water Pump
Va Lvula E Veio Martelos / Valve And Rocker Arm
Co Lector Admissao / Inlet Manifold
Es Cape Colector/Panela / Exhaust Manifold/Muffler
Fi Ltro Ar / Air Cleaner
Ki T Juntas Superior / Upper Gasket Kit
Ki T Juntas Inferior / Lower Gasket Kit
Al Avanca Acelarador / Accelerator Lever
In Terbloqueio Do Acelerador / Accelerator Cooperative
Deposito Combustivel / Fuel Tan K
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo [Peças Component Es] / Fuel Filter [Component Parts]
Ventoinha / F An
Tubo Agua / W Ater Pipe
Radiador / Ra Diator
Deposito Rese Rva / Reserve Tank
Alternador / Alternator
Alternador [Peças Componentes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Componen Tes] / Starter [Component Parts]
Painel/Interruptor / Panel Boa Rd/Switch
Painel [Peças Componentes] / P Anel Board [Component Parts]
Interruptor/Sensor (Bloco Moto R) / Switch/Sensor (Engine)
Relé / Relay
Interruptor/Controlador/Buzina / Switch/Controller/Horn
Interruptor/Sensor (Corpo) / S Witch/Sensor (Body)
Sensor (Eixo Dianteiro) / Sens Or (Front Axle)
Farol Dianteiro [Fr] / Head Li Ght [Fr]
Farol Dianteiro [Uk] / Head Li Ght [Uk]
Lampada / Winker Lamp
Cablagem Electrica (Dianteiro) / Electrical Wiring (Front)
Cablagem Electrica (Traseiros) / Electrical Wiring (Rear)
Embraiagem / Clutch
Alavanca Da Embraiagem / Clutch Lever
Pedal Embraiagem / Clut Ch Pedal
Carter Embraiagem / Clu Tch Housing
Caixa Da Transmissão/Hs T / Transmission Case/Hst
Hst (Bloco Do Cilindro) [Peças Componentes] / Hst (Cylinder Block) [Compon Ent Parts]
Hst (Válvula) [Peças Co Mponentes] / Hst (Valve) [Component Parts]
Diferencial / Different Ial Gear Case
Kit Da Tdf Traseira / M Id Pto Case
Veio Gamas Velocidades / Range Gear Shaft
Contraveio De Tdf / Pto Countershaft
Embraiagem Tdf / Pto Cl Utch
Veio Tdf / Pto Shaft
Carreto De Acionamento Da Tdf Intermédia / Mid Pto Drive Gear
Tdf Central / Mid Pto
Veio Do Pinhão Hipóide / Hypoid Pinion Shaft
Diferencial Carter / Re Ar Differential
Veio Bi-Speed / Bi-Spee D Turn Shaft
Embraiagem Hidraulica / Double Speed Turn Clutch
Forqueta Vel Ocidades / Range Gear Shift Fork
Alavanca / D Ifferential Lock Shift Fork
Cabo De Cont Rolo Da Velocidade De Cruzeiro / Cruise Control Cab Le
Ligação Do P Edal De Controlo De Velocidade / Speed Control Peda L Link
Fixador Do N Eutro / Neutral Holder
Ligação Da V Elocidade De Cruzeiro/Neutro / Neutral/Cruise Link
Alavanca Vel Ocidades / Range Shift Lever
Alavanca Dup La Traccao / Front Wheel Drive Lever
Alavanca Das Mudanças De Tdf Intermédia / Mid Pto Gear Shift Le Ver
Eixo Traseiro / Rear Axle
Travão / Brake
Eixo / Brake Shaft
Tirante Travao / Brake Rod
Pedal Travao / Brake Pedal
Travão De Estacionamento / P Arking Brake
Bloqueio Diferencial / Diffe Rential Lock Pedal
Suporte Eixo Frente / Fro Nt Axle Frame
Carter Eixo Frente / Fron T Axle Case
Engrenagem Cónica (Diante Ira) / Bevel Gear (Front)
Diferencial (Dianteiro) / Differential (Front)
Carter Eixo / Front Axle Case
Carter Grupo Conico / Bev El Gear Case
Eixo Dianteiro / Front Ax Le
Coluna Da Direção / Steering Handle
Distribuidor Direcção / Steering Controller
Rotula/Cilindro Direcção / Tie Rod/Steering Cyli Nder
Cilindro Direcção [Peças Componentes] / Steering Cylinder [Component Parts]
Bomba Hidraulico / Hydraulic P Ump
Bomba Hidraulico [Peças Compon Entes] / Hydraulic Pump [Component Parts]
Válvula Do Regulador / Regulat Er Valve
Linha De Óleo Hidráulico (Entr Ada) / Hydraulic Oil Line (Inlet)
Linha De Óleo Hidráulico (Forn Ecimento) / Hydraulic Oil Line (Delivery)
Linha De Óleo Hidráulico (Ps) / Hydraulic Oil Line (Ps)
Tubo Hidráulico (Hst) / Hydrau Lic Pipe (Hst)
Arrefecedor Do Óleo (Hst) / Oi L Cooler (Hst)
Cilindro Hidraulico / Hydrauli C Cylinder
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Alavanca De Posicionamento / P Osition Lever
Válvula Bi-Speed Turn / Bi-Spe Ed Turn Valve
Válvula Bi-Speed Turn [Peças C Omponentes] / Bi-Speed Turn Valve [Component Parts]
Valvula Control / Control Valv E
Valvula Control [Peças Compone Ntes] / Control Valve [Component Parts]
Tampa Do Cilindro Hidráulico / Hydraulic Cylinder Cap
Tampa Do Cilindro Hidráulico [ Peças Componentes] / Hydraulic Cylinder Cap [Compon Ent Parts]
Distribuidor Auxiliar / Remote Control Valve
Distribuidor Auxiliar [Peças C Omponentes] / Remote Control Valve [Component Parts ]
Valvula Control / Remote Contr Ol Lever
Elo Super Ior / Top Link
Ligacao I Nferior / Lower Link
Tirante D E Elevação / Lift Rod
Puxo / Fr Ont Hitch
Proteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Cpot / Bonnet
Grelha Do Capot / Side Cover
Trico Capot / Bonnet Lock
Suporte Da Grelha Dianteira / Front Grille Suppo Rt
Placa / Shutter Plate
Painel / Panel Frame
Espelho Rectrovisor [Fr] / Rearview Mirror [Fr]
Espelho Rectrovisor [Uk] / Rearview Mirror [Uk]
Guarda-Lamas Direito / Fender Rh
Guarda-Lamas Esquerda / Fender Lh
Assento Por Baixo Da Cobertura / Seat Under Cove R
Assento [Tipo A] / Seat [A Type]
Assento [Tipo B] / Seat [B Type]
Assento [Tipo C] / Seat [C Type]
Assento [Tipo D] / Seat [D Type]
Arco Traseiro / Rear Frame
Degrau / Step
Estru Tura De Protecção (Traseira) / Rops (Lower)
Estru Tura De Protecção (Frente) / Rops (Upper)
Roda Frente (6,00-12) / Front Wheel (6 .00-12)
Roda Traseira (9,5-22) / Rear Wheel (9 .5-22)
Roda Traseira (13,6-16) / Rear Wheel ( 13.6-16)
Etiqueta (Dianteiro) / Label (Front)
Etiqueta (Traseiros) / Label (Rear)
Acessorios / Accessories
Ci Lindro De Elevação Do Cortador De Relva [Opção] / R Ear Pto Kit [Option]
Ki T Do Espaçador [Opção] / Spacer Kit [Option]
Ventoinha / F An
Relé / Relay
Embraiagem / Clutch
Travão / Brake
Eixo / Brake Shaft
Puxo / Fr Ont Hitch
Cpot / Bonnet
Degrau / Step
