Kubota Tractor STV36 Parts Catalog
Model: Kubota STV36 Tractor
Number of Pages: 490 Pages
Frequently Used Items Frequently Used Items
Engine Crankcase
Engine Oil Pan
Engine Cylinder Head
Engine Gear Case [Old] ## S.No.=9e3065 [NoteOrder By Fig.No. Ref.No
Engine Gear Case [New] ## S.No.=9g0001 S.No.;=9g0001
Engine Head Cover
Engine Main Bearing Case
Engine Camshaft And Idle Gear Shaft
Engine Piston And Crankshaft ## NoteOrder By Ref.No.010 And 040 New Parts.
Engine Flywheel
Engine Fuel Camshaft
Engine Idle Apparatus
Engine Injection Pump ## NoteOrder By Ref.No.010,020,026 And 027 New Parts.
Engine Governor
Engine Speed Control Plate
Engine Nozzle Holder And Glow Plug
Engine Nozzle Holder [Component Parts]
Engine Water Flange And Thermostat
Engine Water Pump
Engine Valve And Rocker Arm ## NoteOrder By Ref.No.010 And 020 New Parts.
Engine Inlet Manifold
Engine Exhaust ManifoldMuffler
Engine Air Cleaner
Engine Upper Gasket Kit
Engine Lower Gasket Kit
Engine Accelerator Lever
Engine Accelerator Cooperative [New] ## S.No.=50428 S.No.;=50428
Fuel System Fuel Tank
Fuel System Fuel Pipe
Fuel System Fuel Filter [Component Parts]
Cooling Water System Fan
Cooling Water System Water Pipe
Cooling Water System Radiator
Cooling Water System Reserve Tank
Electrical System Alternator
Electrical System Alternator [Component Parts]
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System PanelSwitch
Electrical System Switch 1
Electrical System Switch 2
Electrical System Switch 3
Electrical System Switch 4
Electrical System Head Light [Except [Uk]] ## NoteOrder By Ref.No.090 New Part
Electrical System Head Light [Uk]
Electrical System Light
Electrical System Trailer Socket
Electrical System Electrical Wiring [Old] ## S.No.=51247 S.No.;=51247
Electrical System Electrical Wiring (Front) [New] ## S.No.=51248 S.No.;=51248
Electrical System Electrical Wiring (Rear) [New] ## S.No.=51248 S.No.;=51248
Clutch Transmission Clutch
Clutch Transmission Clutch Lever
Clutch Transmission Clutch Pedal
Clutch Transmission Clutch Housing
Clutch Transmission Transmission CaseHST
Clutch Transmission HST (Cylinder Block) [Component Parts]
Clutch Transmission HST (Valve) [Component Parts]
Clutch Transmission Differential Gear Case [Except [G]]
Clutch Transmission Differential Gear Case [G]
Clutch Transmission Mid PTO Case
Clutch Transmission Range Gear Shaft
Clutch Transmission PTO Counter Shaft
Clutch Transmission PTO Clutch
Clutch Transmission PTO Shaft
Clutch Transmission Mid PTO Drive Shaft
Clutch Transmission Hypoid Pinion Shaft
Clutch Transmission Rear Differential
Clutch Transmission Bi-Speed Turn Shaft
Clutch Transmission Bi-Speed Turn Clutch [Old] ## S.No.=53160 S.No.;=53160
Clutch Transmission Bi-Speed Turn Clutch [New] ## S.No.=53161 S.No.;=53161
Speed Change Shift Fork Shift Lever Range Gear Shift Fork
Speed Change Shift Fork Shift Lever Rear Differential Lock Shift Fork
Speed Change Shift Fork Shift Lever Cruise Control Lever
Speed Change Shift Fork Shift Lever Cruise Control Cable
Speed Change Shift Fork Shift Lever Speed Control Pedal
Speed Change Shift Fork Shift Lever Speed Control Pedal Link
Speed Change Shift Fork Shift Lever Neutral Holder
Speed Change Shift Fork Shift Lever NeutralCruise Link
Speed Change Shift Fork Shift Lever Range Gear Shift Lever
Speed Change Shift Fork Shift Lever Front Wheel Drive Lever
Speed Change Shift Fork Shift Lever PTO Gear Shift Lever (Rear)
Speed Change Shift Fork Shift Lever Mid PTO Gear Shift Lever
Rear Axle Brake Rear Axle
Rear Axle Brake Brake
Rear Axle Brake Brake Shaft
Rear Axle Brake Brake Rod
Rear Axle Brake Brake Pedal
Rear Axle Brake Parking Brake
Rear Axle Brake Differential Lock Pedal
Front Axle Chassis Front Axle Frame
Front Axle Chassis Propeller Shaft
Front Axle Chassis Front Differential Case
Front Axle Chassis Bevel Gear (Front)
Front Axle Chassis Differential (Front)
Front Axle Chassis Front Axle Case ## NoteOrder By Ref.No.110,120,140 And 145 New Parts.
Front Axle Chassis Bevel Gear Case
Steering Steering Handle [Old] ## S.No.=51306 S.No.;=51306
Steering Steering Handle [New] ## S.No.=51307 S.No.;=51307
Steering Steering Controller [Old] ## S.No.=51306 S.No.;=51306
Steering Steering Controller [New] ## S.No.=51307 S.No.;=51307
Steering Steering Linkage (Tie Rod)
Steering Steering Cylinder [Component Parts]
Hydraulic System Hydraulic Pump
Hydraulic System Hydraulic Pump [Component Parts]
Hydraulic System Regulater Valve
Hydraulic System Hydraulic Oil Line (Inlet)
Hydraulic System Hydraulic Oil Line (Delivery)
Hydraulic System Hydraulic Oil Line (Ps)
Hydraulic System Hydraulic Pipe (HST)
Hydraulic System Oil Cooler (HST)
Hydraulic System Hydraulic Cylinder [Except [G]]
Hydraulic System Hydraulic Cylinder [G]
Hydraulic System Hydraulic Lift Arm
Hydraulic System Position Lever
Hydraulic System Bi-Speed Turn Valve
Hydraulic System Bi-Speed Turn Valve [Component Parts] [Old] ## S.No.=51025 S.No.;=51025
Hydraulic System Bi-Speed Turn Valve [Component Parts] [New] ## S.No.=51026 S.No.;=51026
Hydraulic System Control Valve
Hydraulic System Control Valve [Component Parts] [Old] ## S.No.=50703 S.No.;=50703
Hydraulic System Control Valve [Component Parts] [New] ## S.No.=50704 S.No.;=50704
Hydraulic System Hydraulic Cylinder Cap
Hydraulic System Hydraulic Cylinder Cap [Component Parts]
Hydraulic System Remote Control Valve [Except [G]]
Hydraulic System Remote Control Valve [Component Parts] [Except [G]]
Hydraulic System Remote Control Valve Lever [Except [G]]
3-Point Linkage Drawbar Hitch Top Link [Except [G]]
3-Point Linkage Drawbar Hitch Top Link [G]
3-Point Linkage Drawbar Hitch Lower Link
3-Point Linkage Drawbar Hitch Lift Rod
3-Point Linkage Drawbar Hitch Drawbar [Except [G]]
3-Point Linkage Drawbar Hitch Front Hitch
3-Point Linkage Drawbar Hitch PTO Shaft Protector
HoodBonnet Front Grille
HoodBonnet Bonnet
HoodBonnet Bonnet GrilleSide Cover
HoodBonnet Front Grille Support [Old] [Except [G]] ## S.No.=51247 S.No.;=51247
HoodBonnet Front Grille Support [New] [Except [G]] ## S.No.=51248 S.No.;=51248
HoodBonnet Front Grille Support [Old] [G] ## S.No.=50125 S.No.;=50125
HoodBonnet Front Grille Support [Old] [G] ## S.No.50126 To 51247 S.No.;50126 To 51247
HoodBonnet Front Grille Support [New] [G] ## S.No.=51248 S.No.;=51248
HoodBonnet Rear Bonnet Support [Old] ## S.No.=51247 S.No.;=51247
HoodBonnet Rear Bonnet Support [New] ## S.No.=51248 S.No.;=51248
HoodBonnet Panel Frame
HoodBonnet Fender Rh [Except [G]]
HoodBonnet Fender Rh [G]
HoodBonnet Fender Lh [Except [G]]
HoodBonnet Fender Lh [G]
HoodBonnet Floor Seat Cover
HoodBonnet Seat [A Type]
HoodBonnet Seat [B Type]
HoodBonnet Seat [C Type]
HoodBonnet Seat [D Type]
HoodBonnet Rear Frame
HoodBonnet Step [Except [G]]
HoodBonnet Step [G]
HoodBonnet Sound Absorber
Rops Rops (Lower)
Rops Rops (Upper)
FrontRear Tire Front Wheel (6.00-12)
FrontRear Tire Front Wheel (248.50-14)
FrontRear Tire Rear Wheel (9.5-12)
FrontRear Tire Rear Wheel (13.6-16)
Labels Label (Front)
Labels Label (Rear) [Except [G]]
Labels Label (Rear) [G]
Accessories Accessories And Service Parts
Option Accelerator Cooperative Kit [Option]
Option Mid PTO Kit [Option] ## S.No.=51284 S.No.;=51284
Option Replacement Parts Kit [Option] ## S.No.=53000 S.No.;=53000
Option Spacer Kit [Option]
Option Steering Controller [Option] ## S.No.=51306 S.No.;=51306
Engine Crankcase
Engine Oil Pan
Engine Head Cover
Engine Flywheel
Engine Governor
Engine Water Pump
Engine Air Cleaner
HoodBonnet Bonnet
HoodBonnet Step [G]
Rops Rops (Lower)
Rops Rops (Upper)
