Kubota Tractor ST371 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota ST371 Tractor
Number of Pages: 211 Pages
Itens Usados Fre Quentemente / Frequently Used Items
Bl Oco Motor / Crankcase
Ca Rter Oleo / Oil Pan
Ca Beça Motor / Cylinder Head
Ca Rreto / Gear Case
Ta Mpa Cabeça / Head Cover
Ro Lamento Principal / Main Bearing Case
Ar Vore Cames E Veio / Camshaft And Idle Gear Shaft
Pi Ston E Cambota / Piston And Crankshaft
Vo Lante Motor / Flywheel
Ve Io / Fuel Camshaft
Po Nto Neutro / Idle Apparatus
Bo Mba Injectora / Injection Pump
Re Gulador / Governor
Re Gulador Velocidade / Speed Control Plate
Ve La Pre Aquecimento / Nozzle Holder And Glow Plug
Su Porte Bico [Peças Componentes] / Nozzle Holder [Com Ponent Parts]
Bo Mba Agua E Termostacto / Water Flange And Thermosta T
Bo Mba Agua / Water Pump
Va Lvula E Veio Martelos / Valve And Rocker Arm
Co Lector Admissao / Inlet Manifold
Co Lector Escape/Panela Escape / Exhaust Manifold/Muff Ler
Fi Ltro Ar / Air Cleaner
Su Porte De Bomba Hidraulico / Hydraulic Pump Holder
Ki T De Junta Superior / Upper Gasket Kit
Ki T De Junta Inferior / Lower Gasket Kit
Co Mponentes Electricos Motor (Interruptor/Sensor) / E Ngine Electrical Parts (Switch/Sensor)
Al Avanca Acelarador / Accelerator Lever
In Terbloqueio Do Acelerador / Accelerator Cooperative
Deposito Combustivel / Fuel Tan K
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo [Peças Component Es] / Fuel Filter [Component Parts]
Ventoinha / F An
Tubo Agua / W Ater Pipe
Radiador / Ra Diator
Deposito Rese Rva / Reserve Tank
Alternador / Alternator
Alternador [Peças Componentes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Componen Tes] / Starter [Component Parts]
Painel/Interruptor / Panel/Swi Tch
Painel [Peças Componentes] / P Anel Board [Component Parts]
Interruptor/Sensor (Bloco Moto R) 1 / Switch/Sensor (Engine) 1
Interruptor/Sensor (Bloco Moto R) 2 / Switch/Sensor (Engine) 2
Interruptor/Controlador/Buzina / Switch/Controller/Horn
Relé / Relay
Interruptor/Sensor (Corpo) / S Witch/Sensor (Body)
Sensor (Eixo Dianteiro) / Sens Or (Front Axle)
Luzes Frente [Fr] / Head Light [Fr]
Luzes Frente [Uk] / Head Light [Uk]
Lampada / Winker Lamp
Farol Traseiro / Tail Light
Cablagem Electrica (Dianteiro) / Electrical Wiring (Front)
Cablagem Electrica (Traseiros) / Electrical Wiring (Rear)
Embraiagem / Clutch
Alavanca Da Embraiagem / Clutch Lever
Pedal Embraiagem / Clut Ch Pedal
Carter Embraiagem / Clu Tch Housing
Caixa Da Transmissão/Hs T / Transmission Case/Hst
Hst (Bloco De Motor) [P Eças Componentes] / Hst (Cylinder Block) [Component Parts]
Hst (Valvula) [Peças Co Mponentes] / Hst (Valve) [Component Parts]
Diferencial / Different Ial Gear Case
Caixa Traseiro / Rear C Ase
Veio Gamas Velocidades / Range Gear Shaft
Contraveio De Tdf / Pto Counter Shaft
Embraiagem Tdf / Pto Cl Utch
Veio Tdf / Pto Shaft
Carreto De Acionamento Da Tdf Intermédia / Mid Pto Drive Gear
Tdf Central / Mid Pto
Veio Do Pinhão Hipóide / Hypoid Pinion Shaft
Diferencial Carter / Re Ar Differential
Veio Bi-Speed / Bi-Spee D Turn Shaft
Embraiagem Hidraulica / Hydraulic Clutch
Forqueta Vel Ocidades / Range Gear Shift Fork
Bloqueio Dif Erencial De Forqueta / Differential Lock Shift Fork
Control Velo Cidade / Cruise Control Lever
Cabo De Cont Rolo Da Velocidade De Cruzeiro / Cruise Control Cab Le
Pedal Acelar Ador / Speed Control Pedal
Ligação Do P Edal De Controlo De Velocidade / Speed Control Peda L Link
Fixador Do N Eutro / Neutral Holder
Ligação Da V Elocidade De Cruzeiro/Neutro / Neutral/Cruise Link
Gama Alavanc A De Velocidades / Range Gear Shift Lever
Alavanca Dup La Traccao / Front Wheel Drive Lever
Alavanca Tdf (Traseiros) / Pto Gear Shift Lever (Rear)
Alavanca Das Mudanças De Tdf Intermédia / Mid Pto Gear Shift Le Ver
Eixo Traseiro / Rear Axle
Travão / Brake
Eixo / Brake Shaft
Tirante Travao / Brake Rod
Pedal Travao / Brake Pedal
Travão De Estacionamento / P Arking Brake
Bloqueio Diferencial Pedal / Differential Lock Pedal
Quadro Eixo Frente / Fron T Axle Frame
Carter Eixo Frente / Fron T Axle Case
Engrenagem Cónica (Diante Ira) / Bevel Gear (Front)
Diferencial (Dianteiro) / Differential (Front)
Carter Eixo / Front Axle Case
Carter Grupo Conico / Bev El Gear Case
Eixo Dianteiro / Front Ax Le
Distribuidor Direcção / Steering Controller
Rotula/Cilindro Direcção / Tie Rod/Steering Cyli Nder
Cilindro Direcção [Peças Componentes] / Steering Cylinder [Component Parts]
Bomba Hidraulico / Hydraulic P Ump
Bomba Hidraulico [Peças Compon Entes] / Hydraulic Pump [Component Parts]
Válvula Do Regulador / Regulat Er Valve
Tubo Oleo (Entrada) / Hydrauli C Oil Line (Inlet)
Tubo Oleo (Entrega) / Hydrauli C Oil Line (Delivery)
Tubo Oleo (Ps) / Hydraulic Oil Line (Ps)
Tubo Oleo (Hst) / Hydraulic Oi L Line (Hst)
Arrefecedor Do Óleo (Hst) / Oi L Cooler (Hst)
Caixa Cilindro Hidraulico / Hy Draulic Cylinder Case
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Alavanca Control Posicao / Pos Ition Control Lever
Válvula Bi-Speed Turn / Bi-Spe Ed Turn Valve
Valvula Control / Control Valv E
Valvula Control [Peças Compone Ntes] / Control Valve [Component Parts]
Tampa Do Cilindro Hidráulico / Hydraulic Cylinder Cap
Tampa Do Cilindro Hidráulico [ Peças Componentes] / Hydraulic Cylinder Cap [Compon Ent Parts]
Válvula De Controlo Auxiliar / Auxiliary Control Valve
Válvula De Controlo Auxiliar [ Peças Componentes] / Auxiliary Control Valve [Compo Nent Parts]
Alavanca Da Válvula De Control O Auxiliar / Auxiliary Control Lever
Ligacao S Uperior / Top Link
Ligacao I Nferior / Lower Link
Tirante / Lift Rod
Barra Reb Oque / Drawbar
Puxo Dian Teiro / Front Hitch
Proteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot / Hood (Bonnet)
Painel Lateral / Side Cover
Suporte De Grelha Dianteiro / Front Glille Suppo Rt
Estrutura Do Painel / Panel Frame
Guarda-Lamas Direito / Fender Rh
Guarda-Lamas Esquerda / Fender Lh
Assento Por Baixo Da Cobertura / Seat Under Cove R
Banco [A Tipo] / Seat [A Type]
Banco [B Tipo] / Seat [B Type]
Banco [C Tipo] / Seat [C Type]
Banco [D Tipo] / Seat [D Type]
Arco Traseiro / Rear Frame
Degrau / Step
Estru Tura De Protecção (Traseira) / Rops (Lower)
Estru Tura De Protecção (Frente) [Velho] / Rops (Upper) [ Old]
Estru Tura De Protecção (Frente) [Novo] / Rops (Upper) [N Ew]
Roda Frente (6,00-12) / Front Wheel (6 .00-12)
Roda Frente (24*8,50-14) / Front Wheel (24*8.50-14)
Roda Traseira (9,5-22) / Rear Wheel (9 .5-22)
Roda Traseira (13,6-16) / Rear Wheel ( 13.6-16)
Pe Ça De Acessorio E Serviço Peças / Accessories And S Ervice Parts
Ci Lindro De Elevação Do Cortador De Relva [Opção] / R Ear Pto Kit [Option]
Ki T Do Espaçador [Opção] / Spacer Kit [Option]
