Kubota Tractor ST341C Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota ST341C Tractor
Number of Pages: 252 Pages
Itens Usados Fr Equentemente / Frequently Used Items
B Loco Motor / Crankcase
C Arter Oleo / Oil Pan
C Abeça Motor / Cylinder Head
C Arreto / Gear Case
T Ampa Cabeça / Head Cover
R Olamento Principal / Main Bearing Case
P Iston E Cambota / Piston And Crankshaft
V Olante Motor / Flywheel
V Eio / Fuel Camshaft
P Onto Neutro / Idle Apparatus
B Omba Injectora / Injection Pump
R Egulador / Governor
R Egulador Velocidade / Speed Control Plate
V Ela Pre Aquecimento / Nozzle Holder And Glow Plug
S Uporte Bico [Peças Componentes] / Nozzle Holder [Co Mponent Parts]
B Omba Agua / Water Pump
V Alvula E Veio Martelos / Valve And Rocker Arm
C Olector Escape/Panela Escape / Exhaust Manifold/Muf Fler
F Iltro Ar / Air Cleaner
S Uporte De Bomba Hidraulico / Hydraulic Pump Holder
K It De Junta Superior / Upper Gasket Kit
K It De Junta Inferior / Lower Gasket Kit
C Omponentes Electricos Motor (Interruptor/Sensor) / Engine Electrical Parts (Switch/Sensor)
A Lavanca Acelarador / Accelerator Lever
I Nterbloqueio Do Acelerador / Accelerator Cooperativ E
Deposito Combustivel / Fuel Ta Nk
Filtro Gasoleo [Peças Componen Tes] / Fuel Filter [Component Parts]
Ventoinha / Fan
Tubo Agua / Water Pipe
Radiador / R Adiator
Alternador / Alternator
Alternador [Peças Componentes ] / Alternator [Component Parts]
Motor Arranque / Starter
Painel/Interruptor / Panel/Sw Itch
Painel [Peças Componentes] / Panel Board [Component Parts]
Interruptor/Sensor (Bloco Mot Or) 1 / Switch/Sensor (Engine) 1
Interruptor/Sensor (Bloco Mot Or) 2 / Switch/Sensor (Engine) 2
Interruptor/Controlador/Buzin A / Switch/Controller/Horn
Relé / Relay
Interruptor/Sensor (Corpo) / Switch/Sensor (Body)
Sensor (Eixo Dianteiro) / Sen Sor (Front Axle)
Luzes Frente [Fr] / Head Ligh T [Fr]
Luzes Frente [Uk] / Head Ligh T [Uk]
Farol Matricula / License Lam P
Lampada / Winker Lamp
Farol Traseiro / Tail Light
Ficha Reboque / Trailer Socke T
Luzes Trabalho (Dianteiro) / Working Light (Front)
Farois Trabalho (Traseira) / Lâmpada Farol / Working Light (Rear)/Beacon Lamp
Luz Interior / Room Light
Altifalante / Speaker
Deposito Limpa Parabrisas [Fr ] / Washer Tank [Fr]
Deposito Limpa Parabrisas [Uk ] / Washer Tank [Uk]
Escova Limpa Vidros [Fr] / Wi Per [Fr]
Escova Limpa Vidros [Uk] / Wi Per [Uk]
Cablagem Electrica (Dianteiro ) / Electrical Wiring (Front)
Cablagem Electrica (Traseiros ) / Electrical Wiring (Rear)
Cabalagem Eletrica (Cabine) [ Fr] / Electrical Wiring (Cab) [Fr]
Cabalagem Eletrica (Cabine) [ Uk] / Electrical Wiring (Cab) [Uk]
Embraiagem / Clutch
Alavanca Da Embraiagem / Clutch Lever
Pedal Embraiagem / Clu Tch Pedal
Carter Embraiagem / Cl Utch Housing
Caixa Da Transmissão/H St / Transmission Case/Hst
Hst (Bloco De Motor) [ Peças Componentes] / Hst (Cylinder Block) [Componen T Parts]
Hst (Valvula) [Peças C Omponentes] / Hst (Valve) [Component Parts]
Diferencial / Differen Tial Gear Case
Caixa Traseiro / Rear Case
Veio Gamas Velocidades / Range Gear Shaft
Contraveio De Tdf / Pt O Counter Shaft
Embraiagem Tdf / Pto C Lutch
Veio Tdf / Pto Shaft
Carreto De Acionamento Da Tdf Intermédia / Mid Pto Drive Gear
Tdf Central / Mid Pto
Veio Do Pinhão Hipóide / Hypoid Pinion Shaft
Diferencial Carter / R Ear Differential
Veio Bi-Speed / Bi-Spe Ed Turn Shaft
Embraiagem Hidraulica / Hydraulic Clutch
Forqueta Ve Locidades / Range Gear Shift Fork
Bloqueio Di Ferencial De Forqueta / Differential Lock Shift For K
Control Vel Ocidade / Cruise Control Lever
Cabo De Con Trolo Da Velocidade De Cruzeiro / Cruise Control Ca Ble
Pedal Acela Rador / Speed Control Pedal
Ligação Do Pedal De Controlo De Velocidade / Speed Control Ped Al Link
Fixador Do Neutro / Neutral Holder
Gama Alavan Ca De Velocidades / Range Gear Shift Lever
Alavanca Du Pla Traccao / Front Wheel Drive Lever
Alavanca Td F (Traseiros) / Pto Gear Shift Lever (Rear)
Alavanca Da S Mudanças De Tdf Intermédia / Mid Pto Gear Shift L Ever
Eixo Traseiro / Rear Axle
Travão / Brake
Eixo / Brake Shaft
Tirante Travao / Brake Rod
Pedal Travao / Brake Pedal
Travão De Estacionamento / Parking Brake
Bloqueio Diferencial Pedal / Differential Lock Pedal
Quadro Eixo Frente / Fro Nt Axle Frame
Veio Primario / Propelle R Shaft
Carter Eixo Frente / Fro Nt Axle Case
Engrenagem Cónica (Diant Eira) / Bevel Gear (Front)
Diferencial (Dianteiro) / Differential (Front)
Carter Eixo / Front Axle Case
Carter Grupo Conico / Be Vel Gear Case
Eixo Dianteiro / Front A Xle
Distribuidor Direcção / Steering Controller
Rotula/Cilindro Direcção / Tie Rod/Steering Cyl Inder
Cilindro Direcção [Peças Componentes] / Steerin G Cylinder [Component Parts]
Bomba Hidraulico [Peças Compo Nentes] / Hydraulic Pump [Component Parts]
Válvula Do Regulador / Regula Ter Valve
Tubo Oleo (Entrada) / Hydraul Ic Oil Line (Inlet)
Tubo Oleo (Entrega) / Hydraul Ic Oil Line (Delivery)
Tubo Oleo (Dirección) / Hydra Ulic Oil Line (Ps)
Tubo Oleo (Hst) / Hydraulic O Il Line (Hst)
Arrefecedor Do Óleo (Hst) / O Il Cooler (Hst)
Caixa Cilindro Hidraulico / H Ydraulic Cylinder Case
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Alavanca Control Posicao / Po Sition Control Lever
Válvula Bi-Speed Turn / Bi-Sp Eed Turn Valve
Válvula Bi-Speed Turn [Peças Componentes] / Bi-Speed Turn Valve [Component Parts ]
Valvula Control / Control Val Ve
Valvula Control [Peças Compon Entes] / Control Valve [Component Parts]
Tampa Do Cilindro Hidráulico / Hydraulic Cylinder Cap
Tampa Do Cilindro Hidráulico [Peças Componentes] / Hydraulic Cylinder Cap [Compo Nent Parts]
Válvula De Controlo Auxiliar / Auxiliary Control Valve
Válvula De Controlo Auxiliar [Peças Componentes] / Auxiliary Control Valve [Comp Onent Parts]
Alavanca Da Válvula De Contro Lo Auxiliar / Auxiliary Control Lever
Ligacao Superior / Top Link
Ligacao Inferior / Lower Link
Tirante / Lift Rod
Barra Re Boque / Drawbar
Puxo Dia Nteiro / Front Hitch
Protecca O Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot / Hood (Bonnet)
Painel Lateral / Side Cover
Suporte De Grelha Dianteiro / Front Glille Supp Ort
Est Rutura Cabine / Cab Frame
Pai Nel Inferior / Panel Cover
Gui A Drt / Lever Guide Rh
Gui A Esq / Lever Guide Lh
Por Ta Esq / Door Lh
Por Ta Drt / Door Rh
Tri Nco Porta Esq / Door Lock Lh
Tri Nco Porta Drt / Door Lock Rh
Tej Adilho Interior / Inner Roof
Tec To Abrir / Outer Roof
Ass Ento Por Baixo Da Cobertura / Seat Under Cover
Ban Co [A Tipo] / Seat [A Type]
Ban Co [B Tipo] / Seat [B Type]
Ban Co [C Tipo] / Seat [C Type]
Ban Co [D Tipo] / Seat [D Type]
Tap Ete / Mat
Sil Enciador (Guarda) / Sound Absorber (Fender)
Sil Enciador (Painel Inferior) / Sound Absorber (Panel Cover)
Dia Nteira Do Suporte Da Cabine / Cab Bracket Front
Tra Seira Do Suporte Da Cabine / Cab Bracket Rear
Vid Ro Frente / Front Glass
Vid Ro Traseiro [Fr] / Hatch Back Glass [Fr]
Vid Ro Traseiro [Uk] / Hatch Back Glass [Uk]
Ar Condicionado / Air Conditioner
Tubo Ar Condicionado / Air Condit Ioner Duct
Tubo (Ar Condicionado) / Drain Ho Se (Air Conditioner)
Condesador / Condenser
Tubo Ar Condicionado/Tubo Condens Ador / Air Conditioner Hose/Condenser Hose
Pokrywa Przewodu Elastycznego Kli Matyzatora / Air Conditioner Hose Cover
Compressor / Compressor
Roda Frente (6,00-12) / Front Wheel ( 6.00-12)
Roda Frente (24*8.50-14) / Front Whee L (24*8.50-14)
Roda Traseira (9,5-22) / Rear Wheel ( 9,5-22)
Etiqueta (Traseira) [Fr] / Label (Rear) [Fr]
Etiqueta (Piso/Degrau) / Label (Floor Sheet/Step )
P Eça De Acessorio E Serviço Peças / Accessories And Service Parts
K It Limpa Vidro Traseiros [Uk] [Opção] / Rear Wiper Kit [Uk] [Option]
K It Do Espaçador [Opção] / Spacer Kit [Option]
