Kubota Tractor ST ALPHA-35 Spare Parts Catalog EN FR
Language: French, English
Model: Kubota ST ALPHA-35 Tractor
Number of Pages: 236 Pages
Frequently Used Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Ca Se
Couvre-Culasse / Head Cover
Arbre A Cames Et Arbre De Pignon Fou / Camshaf T And Idle Gear Shaft
Volant Du Moteur / Flywheel
Arbre A Cames Dalimentation / Fuel Camshaft
Levier D Arret Du Moteur / Engine Stop Lever
Plaque De Limiteur De Vitesse / Speed Control Plate
Porte-Injecteur Et Bougie De Prechauffage / No Zzle Holder And Glow Plug
Kit D'accouplements Rapides [Option] / Water F Lange And Thermostat
Pompe A Eau / Water Pump
Collecteur D'echappement/Silencieux / Exhaust Manifold/Muffler
Filter A Air / Air Cleaner
Reservoir Carb. / Fuel Tank
Tuyau A Carburant / Fuel Pipe
Filtre A Carburant [Parties Co Mposantes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Tuyau D'eau / Wat Er Pipe
Radiateur / Radia Tor
Reservoir Du Radi Ateur / Reserve Tank
Alternateur Complet / Alternator
Alternateur [Parties C Omposantes] / Alternator [Component Parts]
Lanceur / Starter
Demarreur [Parties Com Posantes] / Starter [Component Ports]
Batterie / Battery
Tableau De Bord/Contac Teur / Panel/Switch
Commutateur 1 / Switch 1
Commutateur 2 / Switch 2
Commutateur 3 / Switch 3
Phare [Excepte [Uk]] / Head Light [Except [Uk]]
Phare [Uk] / Head Ligh T [Uk]
Fuex / Light
Prise De Remorque / Tr Ailer Socket
Faisceau Electrique / Electrical Wiring
Embrayage / Clutc H
Embrayage / Clutc H
Levier D'embrayag E / Clutch Lever
Embrayage / Clutc H
Pedala D'embrayag E / Clutch Pedal
Carter D'embrayag E / Clutch Housing
Carter De Transmi Ssion/Hst / Transmission Case/Hst
Hst [Parties Comp Osantes] 1 / Hst [Component Parts] 1
Hst [Parties Comp Osantes] 2 / Hst [Component Parts] 2
Carter De Differe Ntiel [Excepte [G]] / Differential Gear Case [Excep T [G]]
Carter De Differe Ntiel [G] / Differential Gear Case [G]
Carter De Pdf / M Id Pto Case
Arbre Principal / Main Shaft
Arbre De Renvoi / Countershaft
Arbre Pdf Interm / Pto Countershaft
Arbre De Prise De Force / Pto Shaft
Arbre D'entrainem Ent Pdf / Mid Pto Drive Shaft
Pdf Ventrale / Mi D Pto
Arbre De Pignon H Ypoide / Hypoid Pinion Shaft
Differentiel Arri Ere / Rear Differential
Arbre De Commande Pour Demi-Tour Rapide / Bi-Speed Turn Shaft
Embrayage De Comm Ande Pour Demi-Tour Rapide / Bi-Speed Turn Clutch
Fourchette De Ch Angement De Gamme / Range Gear Shift Fork
Fourchette De Ch Angement De Vitesses Pdf / Pto Gear Shift Fork
Fourchette De Bl Ocage Differentiel / Differential Lock Shift Fork
Levier De Comman De D'avance 1 / Cruise Control Lever 1
Levier De Comman De D'avance 2 / Cruise Control Lever 2
Cable De Command E D'avance / Cruise Control Cable
Pedale De Comman De Vitesse / Speed Control Pedal
Biellete De Peda Le De Commande Vitesse / Speed Control Pedal Link
Support Neutre / Neutral Holder
Nuetre/Croisiere Biellete / Neutral/Cruise Link
Levier De Change Ment De Gamme / Renge Gear Shift Lever
Levier De Tranis Sion Aux Roues Avant / Front Wheel Drive Lever
Levier Pde Ventr Ale / Pto Gear Shift Lever(Mid/Rear)
Frein / Brake
Axe De Frein / Brake Shaf T
Tige De Frein / Brake Rod
Pedale De Frien / Brake P Edal
Frein De Stationnement / Parking Brake
Pedale Bloc.Differentiel / Differential Lock Pedal
Avant Carter De Differ Entiel / Front Differential Case
Differentiel (Avant) / Differential (Front)
Carter Reducteur / Fro Nt Axle Case
Carter D'egrenage De B Iais / Bevel Gear Case
Pont Avant / Front Axl E
Timonerie De Direction / Steering Linkage (Tie Rod)
Verib De Direction [Parties Composantes] / Steering Cylinder [Component Parts]
Support Avant Droit / H Ydraulic Pump
Pompe Hydraulique [Piec Es Composantes] / Hydraulic Pump [Component Parts]
Circuit C'huile Hydraul Ique / Hydraulic Oil Line (Inlet)
Circuit D'huile Hydraul Ique (Refoulement) / Hydraulic Oil Line (Delivery)
Circuit D'huile Hydraul Ique Direction Assistee / Hydraulic Oil Line (Ps)
Tuyau De Hydraulique (H St) / Hydraulic Pipe (Hst)
Radiateur D'huile (Hst) / Oil Cooler (Hst)
Cylindre Hydraulique [E Xcepte [G]] / Hydraulic Cylinder [Except [G]]
Cylindre Hydraulique [G ] / Hydraulic Cylinder [G]
Bras De Relevage / Hydr Aulic Lift Arm
Levier De Position/Levi Er De Pdf / Position Lever/Pto Speed Gear Shift Lev Er
Soupape De Commande / B I-Speed Turn Valve
Soupape De Commande [Pa Rties Composantes] [Type Nouveau] / Bi-Speed Turn V Alve [Component Parts] [New Type]
Distributeur Hydrauliqu E / Control Valve
Distributeur [Parties C Omposantes] / Control Valve [Component Parts]
Capuchon De Cylindre / Hydraulic Cylinder Cap
Capuchon De Cylindre [P Arties Composantes] / Hydraulic Cylinder Cap [Compo Nent Parts]
Valve Auxiliare [Except E [G]] / Remote Control Valve [Except [G]]
Valve Auxiliare [Partie S Composantes] [Excepte [G]] / Remote Control Valve [Component Parts] [Except [G]]
Levier De Controle De L Avalve Auxiliare [Excepte [G]] / Remote Control Val Ve Lever [Except [G]]
Tirant Superieur [Excepte [G]] / Top Link [Except [G]]
Tirant Superieur [G] / Top Link [G]
Bras Inferieurs / Lower Link
Barre De Relevage / Lift Rod
Barre D'attelage [Excepte [G]] / Draw Bar [Except [G]]
Attelage / Front Hitch
Protection Pdf / Pto Protector
Capot / Bonnet
Capot / Bonnet
Capot / Bonnet
Calandre De Capot/Capot Lateral / Bonnet G Rille/Side Cover
Support De Grille Avant / Front Grille Sup Port
Support Calandre Arriere / Rear Bonnet Sup Port
Cadre De Panneau / Panel Frame
Aile Droite [Excepte [Cab]] [Type Vieux] / Fender Rh [Except [Cab]] [Old Type]
Aile Droite [Excepte [Cab]] [Type Nouveau] / Fender Rh [Except [Cab]] [New Type]
Aile Droite [Cab] / Fender Rh [Cab]
Aile Gauche [Excepte [Cab]] [Type Vieux] / Fender Lh [Except [Cab]] [Old Type]
Aile Gauche [Excepte [Cab]] [Type Nouveau] / Fender Lh [Except [Cab]] [New Type]
Aile Gauche [Cab] / Fender Lh [Cab]
Plancher Couvercle [Excepte [G]] / Floor S Eat Cover [Except [G]]
Plancher Couvercle [G] / Floor Seat Cover [G]
Siege [Type A] / Seat [A Type]
Siege [Type B] / Seat [B Type]
Siege [Type C] / Seat [C Type]
Chassis D'arriere [Excepte [Cab]] [Type Vi Eux] / Rear Frame [Except [Cab]] [Old Type]
Chassis D'arriere [Excepte [Cab]] [Type No Uveau] / Rear Frame [Except [Cab]] [New Type]
Chassis D'arriere [Cab] / Rear Frame [Cab]
Marchepied [Excepte [Cab]] / Step [Except [Cab]]
Marchepied [Cab] / Step [Cab]
Carnture Interieure / Sound Absorber
Cadre Anti-Renversment [Excepte [Cab]] [Type Vieux] / Rops (Lower) [Except [Cab]] [Old Type]
Cadre Anti-Renversment [Excepte [Cab]] [Type Nouveau] / Rops (Lower) [Except [Cab] ] [New Type]
Cadre Anti-Renversment [Cab] / Rops (Lower) [Cab]
Cadre Anti-Renversment [Excepte [Cab]] / Rops (Upper) [Except [Cab]]
Roue Avant (6,00-12) / Fr Ont Wheel (6.00-12)
Roue Avant (6-12) / Front Wheel (6-12)
Roue Avant (24*8,50-14) / Front Wheel (24*8.50-14)
Roue Arriere (9,5-22) / R Ear Wheel (9.5-22)
Roue Arriere (12,4-16) / Rear Wheel (12.4-16)
Roue Arriere (13,6-16) / Rear Wheel (13.6-16)
Etiquette 1 / Label 1
Etiquette 2 / Label 2
Accessories Et Piece De Service / Accessories And Service Parts
Silenceux [Option] / Extension Muffler [Option ]
Ventilateur / Fan
Lanceur / Starter
Batterie / Battery
Fuex / Light
Embrayage / Clutc H
Embrayage / Clutc H
Embrayage / Clutc H
Frein / Brake
Capot / Bonnet
Capot / Bonnet
Capot / Bonnet
