Kubota Tractor ST ALPHA-35 Parts Catalog
Model: Kubota ST ALPHA-35 Tractor
Number of Pages: 402 Pages
Frequently Used Items Frequently Used Items
Engine Crankcase
Engine Oil Pan
Engine Cylinder Head
Engine Gear Case
Engine Head Cover
Engine Main Bearing Case
Engine Camshaft And Idle Gear Shaft
Engine Piston And Crankshaft ## NoteOrder By Ref.No.010 And 040 New Part.
Engine Flywheel
Engine Fuel Camshaft
Engine Engine Stop Lever
Engine Injection Pump
Engine Governor
Engine Speed Control Plate
Engine Nozzle Holder And Glow Plug
Engine Nozzle Holder [Component Parts]
Engine Water Flange And Thermostat
Engine Water Pump
Engine Valve And Rocker Arm
Engine Inlet Manifold
Engine Exhaust ManifoldMuffler
Engine Air Cleaner
Engine Upper Gasket Kit
Engine Lower Gasket Kit
Engine Accelerator Lever
Fuel System Fuel Tank
Fuel System Fuel Pipe
Fuel System Fuel Filter [Component Parts]
Cooling Water System Fan
Cooling Water System Water Pipe
Cooling Water System Radiator
Cooling Water System Reserve Tank
Electrical System Alternator
Electrical System Alternator [Component Parts]
Electrical System Starter
Electrical System Starter [Component Ports]
Electrical System Battery
Electrical System PanelSwitch
Electrical System Switch 1
Electrical System Switch 2
Electrical System Switch 3
Electrical System Head Light [Except [Uk]]
Electrical System Head Light [Uk]
Electrical System Light
Electrical System Trailer Socket
Electrical System Electrical Wiring
Clutch Transmission Clutch
Clutch Transmission Clutch Lever
Clutch Transmission Clutch Pedal
Clutch Transmission Clutch Housing
Clutch Transmission Transmission CaseHST
Clutch Transmission HST [Component Parts] 1
Clutch Transmission HST [Component Parts] 2
Clutch Transmission Differential Gear Case [Except [G]]
Clutch Transmission Differential Gear Case [G]
Clutch Transmission Mid PTO Case
Clutch Transmission Main Shaft
Clutch Transmission Counter Shaft
Clutch Transmission PTO Counter Shaft
Clutch Transmission PTO Shaft
Clutch Transmission Mid PTO Drive Shaft
Clutch Transmission Hypoid Pinion Shaft
Clutch Transmission Rear Differential
Clutch Transmission Bi-Speed Turn Shaft
Clutch Transmission Bi-Speed Turn Clutch
Speed Change Shift Fork Shift Lever Range Gear Shift Fork
Speed Change Shift Fork Shift Lever PTO Gear Shift Fork
Speed Change Shift Fork Shift Lever Differential Lock Shift Fork
Speed Change Shift Fork Shift Lever Cruise Control Lever 1
Speed Change Shift Fork Shift Lever Cruise Control Lever 2
Speed Change Shift Fork Shift Lever Cruise Control Cable
Speed Change Shift Fork Shift Lever Speed Control Pedal
Speed Change Shift Fork Shift Lever Speed Control Pedal Link
Speed Change Shift Fork Shift Lever Neutral Holder
Speed Change Shift Fork Shift Lever NeutralCruise Link
Speed Change Shift Fork Shift Lever Range Gear Shift Lever
Speed Change Shift Fork Shift Lever Front Wheel Drive Lever
Speed Change Shift Fork Shift Lever PTO Gear Shift Lever(MidRear)
Rear Axle Brake Rear Axle
Rear Axle Brake Brake
Rear Axle Brake Brake Shaft
Rear Axle Brake Brake Rod
Rear Axle Brake Brake Pedal
Rear Axle Brake Parking Brake
Rear Axle Brake Differential Lock Pedal
Front Axle Chassis Front Axle Frame
Front Axle Chassis Propeller Shaft
Front Axle Chassis Front Differential Case
Front Axle Chassis Differential (Front)
Front Axle Chassis Front Axle Case
Front Axle Chassis Bevel Gear Case
Steering Steering Handle
Steering Steering Controller
Steering Steering Linkage (Tie Rod)
Steering Steering Cylinder [Component Parts]
Hydraulic System Hydraulic Pump
Hydraulic System Hydraulic Pump [Component Parts]
Hydraulic System Hydraulic Oil Line (Inlet)
Hydraulic System Hydraulic Oil Line (Delivery)
Hydraulic System Hydraulic Oil Line (Ps)
Hydraulic System Hydraulic Pipe (HST)
Hydraulic System Oil Cooler (HST)
Hydraulic System Hydraulic Cylinder [Except [G]]
Hydraulic System Hydraulic Cylinder [G]
Hydraulic System Hydraulic Lift Arm
Hydraulic System Position LeverPTO Speed Gear Shift Lever
Hydraulic System Bi-Speed Turn Valve
Hydraulic System Bi-Speed Turn Valve [Component Parts] [Old Type] ## S.No.=51629 S
Hydraulic System Bi-Speed Turn Valve [Component Parts] [New Type] ## S.No.=51630 S
Hydraulic System Control Valve
Hydraulic System Control Valve [Component Parts]
Hydraulic System Hydraulic Cylinder Cap
Hydraulic System Hydraulic Cylinder Cap [Component Parts]
Hydraulic System Remote Control Valve [Except [G]]
Hydraulic System Remote Control Valve [Component Parts] [Except [G]]
Hydraulic System Remote Control Valve Lever [Except [G]]
3-Point Linkage Drawbar Hitch Top Link [Except [G]]
3-Point Linkage Drawbar Hitch Top Link [G]
3-Point Linkage Drawbar Hitch Lower Link
3-Point Linkage Drawbar Hitch Lift Rod
3-Point Linkage Drawbar Hitch Drawbar [Except [G]]
3-Point Linkage Drawbar Hitch Front Hitch
3-Point Linkage Drawbar Hitch PTO Protector
HoodBonnet Front Grille
HoodBonnet Bonnet
HoodBonnet Bonnet GrilleSide Cover
HoodBonnet Front Grille Support
HoodBonnet Rear Bonnet Support
HoodBonnet Panel Frame
HoodBonnet Fender Rh [Except [Cab]] [Old Type] ## S.No.=50986 S.No.;=50986
HoodBonnet Fender Rh [Except [Cab]] [New Type] ## S.No.=50987 S.No.;=50987
HoodBonnet Fender Rh [Cab]
HoodBonnet Fender Lh [Except [Cab]] [Old Type] ## S.No.=50986 S.No.;=50986
HoodBonnet Fender Lh [Except [Cab]] [New Type] ## S.No.=50987 S.No.;=50987
HoodBonnet Fender Lh [Cab]
HoodBonnet Floor Seat Cover [Except [G]]
HoodBonnet Floor Seat Cover [G]
HoodBonnet Seat [A Type]
HoodBonnet Seat [B Type]
HoodBonnet Seat [C Type]
HoodBonnet Rear Frame [Except [Cab]] [Old Type] ## S.No.=50986 S.No.;=50986
HoodBonnet Rear Frame [Except [Cab]] [New Type] ## S.No.=50987 S.No.;=50987
HoodBonnet Rear Frame [Cab]
HoodBonnet Step [Except [Cab]]
HoodBonnet Step [Cab]
HoodBonnet Sound Absorber
Rops Rops (Lower) [Except [Cab]] [Old Type] ## S.No.=50986 S.No.;=50986
Rops Rops (Lower) [Except [Cab]] [New Type] ## S.No.=50987 S.No.;=50987
Rops Rops (Lower) [Cab]
Rops Rops (Upper) [Except [Cab]]
FrontRear Tire Front Wheel (6.00-12)
FrontRear Tire Front Wheel (6-12)
FrontRear Tire Front Wheel (248.50-14)
FrontRear Tire Rear Wheel (9.5-22)
FrontRear Tire Rear Wheel (12.4-16)
FrontRear Tire Rear Wheel (13.6-16)
Labels Label 1
Labels Label 2
Accessories Accessories And Service Parts
Option Extension Muffler [Option]
Engine Crankcase
Engine Oil Pan
Engine Gear Case
Engine Head Cover
Engine Flywheel
Engine Governor
Engine Water Pump
Engine Air Cleaner
HoodBonnet Bonnet
Labels Label 1
Labels Label 2
