Kubota Tractor R420S Parts Manual
Model: Kubota R420S Tractor
Number of Pages: 362 Pages
Instructions For Parts Books
R420s
Crank Case
Oil Pan
Gear Case
Head Cover
Main Bearing Case
Main Bearing Case
Camshaft And Idle Gear Shaft
Piston And Crankshaft
Flywheel
Fuel Camshaft And Governor Shaft
Stop Solenoid
Governor
Speed Control Plate
Nozzle Holder And Glow Plug
Boost Compensator
Alternator (Component Parts)
Starter
Starter (Component Parts)
Water Flange And Thermostat
Valve And Rocker Arm
Turbo Charger
Oil Pipe (Turbo Charger)
Inlet Manifold
Exhaust Manifold
Gasket Kit
Gasket Kit
Outligger Control Lever Slide Lock
Operating Control Lever
Control Arm
Lock Rod
Control Cable
Control Cable
Stand
Cover
Slide Frame
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Bucket
Out Ligger Cylinder
Swing Cylinder
Boom Cylinder
Arm Cylinder
Bucket Cylinder
Slide Lock Cylinder
Oil Piping Quick Coupler
Oil Piping Out Ligger
Oil Piping Slide Lock 1
Oil Piping Slide Lock 2
Oil Piping Boom
Oil Piping Arm
Oil Piping Bucket
Oil Piping Swing
Control Valve
Control Valve (Component Parts)
Control Valve Spool Section
Label
Engine Bracket
Water Pipe
Air Cleaner
Muffler
Drain Piping
Fuel Piping
Fuel Filter (Component Parts)
Battery
Relay
Switch And Meter
Lamp
Lamp
Lamp
Electrical Wiring
Mission Case
Front Axle Case
Front Axle
Front Differential Case
Planetary Gear (Front)
Front Differential
Rear Axle Case
Rear Axle
Rear Differential Case
Planetary Gear (Rear)
Rear Differential
Propeller Shaft
Wheel Tire
Steering Handle
Hydraulic Oil Line (Steering)
Streering Controller
Accelerator Pedal
Accelerator Cable
Brake Pedal
Brake Operation
Brake Piping
Brake
Pump Housing
Lst Pump (Adapter)
Lst Pump (Relief Valve)
Lst Motor
Control Valve
Control Valve
Spool Section (Lift)
Spool Section (Tilt)
Spool Section (S P)
Solenoid Valve
Oil Tank
Oil Filter
Control Lever (Shovel)
Control Lever (Shovel) (Component Parts)
Control Lever (S P) (Component Parts)
Shovel Arm
Tilt Arm
Bucket
Bucket
Hydraulic Oil Line (Suction)
Hydraulic Oil Line (Return)
Hydraulic Oil Line (Oil Cooler)
Return Filter
Return Filter
High Pressure Oil Line
Hydraulic Oil Line (Lift)
Hydraulic Oil Line (Tilt)
Hydraulic Oil Line (S P)
Lift Cylinder
Lift Cylinder Left (Component Parts)
Lift Cylinder Right (Component Parts)
Tilt Cylinder
Tilt Cylinder (Component Parts)
Steering Cylinder
Steering Cylinder (Component Parts)
Auto Leveler
Front Frame
Frame Connection
Rear Frame
Rear Frame
Rear Fender
Mud Guad
Fender
Hood
Hood Lock
Operation Stand
Operation Stand
Sound Absorber
Sound Absorber
Weight
Canopy
Cabin (Body)
Cabin (Door Lh )
Cabin (Door Lock Lh )
Cabin (Door Rh )
Cabin (Door Lock Rh)
Cabin (Wiper Motor)
Cabin (Rear Door)
Cabin (Window)
Cabin (Inner Roof)
Cabin (Electrical Wiring)
Cabin (Heater)
Cabin (Heater Hose)
Cabin (Cushion)
Label
Label
Label
R420s
Crank Case
Oil Pan
Gear Case
Head Cover
Main Bearing Case
Main Bearing Case
Flywheel
Stop Solenoid
Governor
Speed Control Plate
Boost Compensator
Starter
Turbo Charger
Inlet Manifold
Exhaust Manifold
Gasket Kit
Gasket Kit
Control Arm
Lock Rod
Control Cable
Control Cable
Stand
Cover
Slide Frame
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Bucket
Out Ligger Cylinder
Swing Cylinder
Boom Cylinder
Arm Cylinder
Bucket Cylinder
Slide Lock Cylinder
Oil Piping Boom
Oil Piping Arm
Oil Piping Bucket
Oil Piping Swing
Control Valve
Label
Engine Bracket
Water Pipe
Air Cleaner
Muffler
Drain Piping
Fuel Piping
Battery
Relay
Switch And Meter
Lamp
Lamp
Lamp
Electrical Wiring
Mission Case
Front Axle Case
Front Axle
Front Differential
Rear Axle Case
Rear Axle
Rear Differential
Propeller Shaft
Wheel Tire
Steering Handle
Accelerator Pedal
Accelerator Cable
Brake Pedal
Brake Operation
Brake Piping
Brake
Pump Housing
Lst Pump (Adapter)
Lst Motor
Control Valve
Control Valve
Spool Section (S P)
Solenoid Valve
Oil Tank
Oil Filter
Shovel Arm
Tilt Arm
Bucket
Bucket
Return Filter
Return Filter
Lift Cylinder
Tilt Cylinder
Steering Cylinder
Auto Leveler
Front Frame
Frame Connection
Rear Frame
Rear Frame
Rear Fender
Mud Guad
Fender
Hood
Hood Lock
Operation Stand
Operation Stand
Sound Absorber
Sound Absorber
Weight
Canopy
Cabin (Body)
Cabin (Door Lh )
Cabin (Door Rh )
Cabin (Wiper Motor)
Cabin (Rear Door)
Cabin (Window)
Cabin (Inner Roof)
Cabin (Heater)
Cabin (Heater Hose)
Cabin (Cushion)
Label
Label
Label
