Kubota Tractor MK5000DW Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota MK5000DW Tractor
Number of Pages: 369 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Volante / Flywheel
Compensador / Balancer
Motor Parar Palanca / Engine Stop Lever
Placa De Control De Velocidad [Viejo] / Speed Control Plate [Old]
Placa De Control De Velocidad [Nuevo] / Speed Control Plate [New]
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo / Inlet Pipe
Silenciador / Muffler
Acelerador Varillaje / Accelerator Linkage
Combustible Deposito Suporte / Fuel Tank Support
Combustible Tubo/Combustible Filtro / Fuel Pipe/Fuel Filter
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador/Rele / Switch/Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz [Ec] [Tur] / Head Light [Ec] [Tur]
Culata Luz [Componente Piezas] [Ec] [Tur] [Viejo] / Head Light [Component Parts] [Ec] [Tur] [Old]
Culata Luz [Componente Piezas] [Ec] [Tur] [Nuevo] / Head Light [Component Parts] [Ec] [Tur] [New]
Intermitente Lampara / Winker Lamp
Cola Luz / Rear Lamp
Licencia Lampara [W] / License Lamp [W]
Remolque Vaso [W] / Trailer Socket [W]
Electrico Cableado (Adelante) / Electrical Wiring (Front)
Electrico Cableado (Trasero) / Electrical Wiring (Rear)
Embrague / Clutch
Embrague Palanca / Clutch Lever
Intermedia Caja / Mid Case
Válvula De Embrague De La Tdf/Soporte De Cojinete / Pto Clutch Valve
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Principal Eje / Main Shaft
Arbol Contrarrotante / Counter Shaft
Inversor Eje / Shuttle Shaft
Espiral Bisel Pinon / Spiral Bevel Pinion
Pto Arbol Contrarrotante / Pto Countershaft
Tdf Embrague / Pto Clutch
Pto Embrague [Componente Piezas] / Pto Clutch [Component Parts]
Pto Accionar Eje / Pto Drive Shaft
Tdf Eje / Pto Shaft
Inversor Cambio Bifurcacion / Shuttle Shift Fork
Inversor Cambio Palanca / Shuttle Shift Lever
Gama Engranaje Y Inversor Varilla / Range Gear Shift And Shuttle Shift Rod
Trasero Eje Izquierdo / Rear Axle(Left)
Trasero Eje Derecho / Rear Axle(Right)
Freno Izquierdo / Brake Lh
Freno Derecho / Brake Rh
Freno Varilla 1 (Freno Pedal) / Brake Rod 1 (Brake Pedal)
Varilla De Freno 2 (Leva De Freno) / Brake Rod 2 (Brake Cam)
Freno De Mano 1 (Soporte) / Hand Brake 1 (Support)
Freno De Mano 2 (Palanca) / Hand Brake 2 (Lever)
Freno Pedal / Brake Pedal
Adelante Accionar Eje / Front Drive Shaft
Árbol De Transmisión Delantero (Trasero) / Propeller Shaft (Rear)
Eje De Transmisión (Delantero) / Propeller Shaft (Front)
Diferencial (Adelante) / Differential (Front)
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Eje / Front Axle
Maneta,Drccn [W] / Steering Handle [W]
Direccion Soporte / Steering Support
Regulador Valvula / Regulator Valve
Hidraulico Aceite Linea (Entrada) / Hydraulic Oil Line (Inlet)
Linea De Aceite Hidraulico(Impulsion) / Hydraulic Oil Line (Delivery)
Pto Hidraulico Aceite Linea / Pto Hydraulic Pipe
Bloque De Salida Hidraulica / Hydraulic Outlet Block
Ascenso Brazo [Ec] [Uk] / Lift Arm [Ec] [Uk]
Alimentacion Trasero Palanca [Ec] [Uk] / Feed Back Lever [Ec] [Uk]
Posicion Control Palanca [Ec] [Uk] / Position Control Lever [Ec] [Uk]
Parte Superior [Ec] [Uk] / Top Link [Ec] [Uk]
Bajar Vinculo / Lower Link
Estabilizador / Stabilizer
Ascenso Varilla [Ec] [Uk] / Lift Rod [Ec] [Uk]
Barra De Remolque / Drawbar
Adelante Enganche / Front Hitch
Pto Protector [Ec] [Uk]
Parrilla Frontal [Viejo] / Front Grille [Old]
Parrilla Frontal [Nuevo] / Front Grille [New]
Soporte Delantero De Capo / Hood (Bonnet) Front Support
Amortiguador De La Capo / Hood(Bonnet) Damper
Espejo Retrovisor [Ec] [Tur] [Se] / Rearview Mirror [Ec] [Tur] [Se]
Guardabarros / Fender
Guardabarros Soporte [W] / Fender Support [W]
Cubierta De Asiento De Piso / Floor Sheet Cover
Asiento [W] / Seat [W]
Peldano / Step
Herramienta Caja [W] / Tool Box [W]
Arco De Seguridad [W] / Rops [W]
Rueda Delantera (8-16) / Front Wheel (8-16)
Rueda Delantera (9.5-16) / Front Wheel (9.5-16)
Rueda Trasera (12.4-28-4pr) / Rear Wheel (12.4-28-4pr)
Rueda Trasera (13.6-28) / Rear Wheel (13.6-28)
Etiqueta 1 (Adelante) / Label 1 (Front)
Etiqueta 2 (Trasero) / Label 2 (Rear)
Parachoques Delantero [Opcion] / Front Bumper Kit [Option]
Kit De Dirección Mango [W] [Opcion] / Steering Handle Kit [W] [Option]
Palanca De Posicion (Con El Esfuerzo) [Ec] [Uk] [Opcion] / Position Control Lever Kit (With Draft) [Ec] [Uk] [Option]
Articulacion De Posicion (Con El Esfuerzo) [Ec][Uk] [Opcion] / Position Control Link (With Draft) [Ec][Uk] [Option]
Palanca De Esfuerzo (Con El Esfuerzo) [Ec][Uk] [Opcion] / Draft Control Lever (With Draft) [Ec][Uk] [Option]
Soporte De Tercer Punto (Con El Esfuerzo) [Ec][Uk][Opcion] / Top Link Holder (With Draft) [Ec][Uk] [Option]
Alejado Control Valvula [Opcion] / Auxiliary Control Valve [Option]
Distribuidor De Servicios Externos (Flotante) [Opcion] / Auxiliary Control Valve (Floating) [Option]
Distribuidor De Servicios Externos (Simple) [Opcion] / Auxiliary Control Valve (Single) [Option]
Palanca De Distribuidor De Servicios Externos (1r) [Opcion] / Auxiliary Control Valve Lever (1st) [Option]
Palanca De Distribuidor De Servicios Externos (Segundo) [Opcion] / Auxiliary Control Valve Lever (2nd) [Option]
Palanca De Distribuidor De Servicios Externos (Tercero) [Opcion] / Auxiliary Control Valve Lever (3rd) [Option]
Acoplador De Distribuider De Servicios Externos (Primero) [W] [Opcion] / Auxiliary Control Valve Coupler (1st) [W] [Option]
Acoplador De Distribuider De Servicios Externos (Segundo) [W] [Opcion] / Auxiliary Control Valve Coupler (2nd) [W] [Option]
Acoplador De Distribuider De Servicios Externos (Tercero) [W] [Opcion] / Auxiliary Control Valve Coupler (3rd) [W] [Option]
Oscilacion Barra De Remolque/Horquilla Barra De Remolque [Opcion] / Swinging Drawbar/Clevis Drawbar [Option]
Volante / Flywheel
Ventilador / Fan
Embrague / Clutch
Tdf Eje / Pto Shaft
Peldano / Step
