118
7,392
Kubota Tractor MK5000DW MK5000DR Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota MK5000DW, MK5000DR Tractor
Number of Pages: 417 Pages
Engine 000100 Crankcase
Engine 000200 Oil Pan
Engine 000300 Cylinder Head
Engine 000400 Transmission Box Gear Case
Engine 000500 Head Cover
Engine 010000 Main Bearing Case
Engine 010100 Camshaft And Idle Gear
Engine 010200 Piston And Crankshaft
Engine 010301 Flywheel
Engine 010500 Fuel Camshaft
Engine 010600 Balancer
Engine 020000 Engine Stop Lever
Engine 020200 Injection Pump
Engine 020400 Governor
Engine 020500 Speed Control Plate (Old) Speed Control Plate Old Chassis No. 7fzz999 S.No. 7fzz999
Speed Control Plate (Old) Speed Control Plate Old Chassis No.7ga0001 To 7gpz999 S.No.7ga0001 To 7gpz999
Engine 020502 Speed Control Plate New Chassis No. 7gq0001 S.No. 7gq0001
Engine 020600 Nozzle Holder And Glow
Engine 050000 Thermostat Water Flange And Thermostat
Engine 050100 Water Pump
Engine 060000 Valve And Rocker Arm
Engine 060100 Inlet Manifold
Engine 060200 Exhaust Manifold
Engine 060400 Air Cleaner
Engine 060500 Inlet Pipe (Air Cleaner)
Engine 060600 Muffler
Engine 060700 Turbocharger Turbo Charger
Engine 060800 Turbocharger Oil Pipe (Turbo Charger)
Engine 090100 Upper Gasket Kit
Engine 090200 Lower Gasket Kit
Engine A01000 Accelerator Lever
Engine A02500 Accelerator Linkage
Fuel System A10000 Fuel Tank Support
Fuel System A10100 Fuel Tank
Fuel System A11000 Fuel Pipe Fuel Filter
Fuel System A13000 Fuel Filter Component
Cooling Water System A40100 Fan
Cooling Water System A41000 Water Pipe
Cooling Water System A42000 Radiator
Cooling Water System A43000 Reserve Tank Reserve
Electrical System A51500 Alternator
Electrical System A52000 Alternator Component Parts
Electrical System A52500 Starter
Electrical System A53000 Starter Component Parts
Electrical System A53500 Battery
Electrical System B00100 Switch Sensor (Motor) Switch Sensor
Electrical System B10200 Switch Relay Switch Relay
Electrical System B10300 Switch Sensor Switch Sensor
Electrical System B11500 Dashboard Panel Board
Electrical System B12000 Panel Board
Electrical System B30100 Outdoor Lighting EC Tur Head Light
System B30300 Outdoor Lighting Component Parts EC Tur Old Head Light Component Parts EC Tur
System B30301 Outdoor Lighting Component Parts EC Tur New Head Light Component Parts EC Tur
Electrical System B31000 Winker Lamp
Electrical System B31200 Rear Lamp
Electrical System B31301 Plate Light W License Lamp W
Electrical System B31302 Plate Light R License Lamp R
Electrical System B31601 Trailer Socket W Trailer Socket
Electrical System B31602 Trailer Socket R Trailer Socket
Electrical System B50300 Wire Harness (Front) Electrical Wiring (
Electrical System B50700 Wire Harness (Rear) Electrical Wiring
Clutch Gear Clutch Transmission C10100 Clutch
Clutch Gear Clutch Transmission C20100 Clutch Lever Clutch Lever
Clutch Gear Clutch Transmission C30100 Clutch Pedal
Clutch Gear Clutch Transmission C40101 Clutch Housing
Clutch Gear Clutch Transmission C41000 Center Box Mid Case
Clutch Gear Clutch Transmission C41200 PTO Clutch Valve PTO Clutch
Dr Clutch Gear Clutch Transmission C41400 PTO Clutch Valve Component Parts
Clutch Gear Clutch Transmission C42001 Transmission Case
Clutch Gear Clutch Transmission D10100 Main Shaft
Clutch Gear Clutch Transmission D10500 Counter Shaft
Clutch Gear Clutch Transmission D11500 Shuttle Shaft
Clutch Gear Clutch Transmission D11700 Gear Range Shaft Range Gear
Clutch Gear Clutch Transmission D12501 Spiral Bevel
Clutch Gear Clutch Transmission D12700 Rear Differential
Clutch Gear Clutch Transmission D13000 PTO Countershaft
Clutch Gear Clutch Transmission D13200 PTO Clutch
Clutch Gear Clutch Transmission D13300 PTO Clutch Component Parts
Clutch Gear Clutch Transmission D13401 PTO Drive Shaft PTO Drive Shaft
Clutch Gear Clutch Transmission D13500 PTO Shaft
Speed Change Shift Fork D20100 Main Transmission
Speed Change Shift Fork D20500 Transmission Shuttle
Speed Change Shift Fork D21700 Gear Range
Speed Change Shift Fork D22500 Differential Lock
Gear Speed Change Shift Fork E10100 Main Gear
Speed Change Shift Fork E10500 Transmission Shuttle
Speed Change Shift Fork E11000 Gear Range
Fork Shift Lever Speed Change Shift Fork E11300 Gear Range Transmission And Shuttle
Speed Change Shift Fork E14000 Front Wheel
Rear Axle Brake E15100 Rear Axle (Left Side) Rear Axle(Left)
Rear Axle Brake E15200 Rear Axle (Right Side) Rear Axle(Right)
Rear Axle Brake E16100 Brake (Left Side) Brake Lh
Rear Axle Brake E16200 Brake (Right Side) Brake Rh
Rear Axle Brake E16500 Brake Rod 1 (Brake Pedal) Brake Rod 1 (Brake
Rear Axle Brake E17000 Brake Rod 2 (Brake Drawing) Brake Rod 2 (Brake
Rear Axle Brake E18000 Hand Brake 1 (Support) Hand Brake 1 (Support)
Rear Axle Brake E18500 Hand Brake 2 (Lever)
Rear Axle Brake E20100 Brake Pedal
Front Axle Chassis F10501 Front Axle Frame Front Axle
Front Axle Chassis F12200 Front Drive Shaft
Front Axle Chassis F12300 Propeller Shaft (Rear) Propeller Shaft
Front Axle Chassis F12401 Propeller Shaft
Front Axle Chassis F12500 Front Differential
Front Axle Chassis F12700 Tilt Transmission (Front) Bevel Gear (
Front Axle Chassis F13000 Differential Case (Front) Differential
Front Axle Chassis F14000 Front Axle Housing Front Axle
Front Axle Chassis F14500 Differential Shaft,Transmission Differential
Front Axle Chassis F15000 Front Axle
Steering G10101 Steering W Steering Handle W
Steering G10102 Steering Wheel R Steering Handle R
Steering G11000 Steering Control Steering Controller
Steering G11700 Steering Support
Steering G18001 Rubber Tie Rod Steering Cylinder
Steering G18501 Steering Cylinder Component Parts
Hydraulic System H12000 Hydraulic Pump
Dr Hydraulic System H12500 Hydraulic Pump
Hydraulic System H14500 Regulator Valve Regulator Valve
Hydraulic System H20500 Hydraulic Oil Line (Input) Hydraulic Oil
Hydraulic System H21000 Hydraulic Oil Line (Feed) Oil
Hydraulic System H21500 Hydraulic Oil Line (Steering) Oil
Hydraulic System H23000 PTO Hydraulic Pipe PTO Hydraulic
Hydraulic System H23500 Hydraulic Outlet
Hydraulic System H30102 Hydraulic Cylinder
Hydraulic System H32002 Lift Arm Tur Se Lift Arm Tur
Hydraulic System H33002 Reaction Lever Tur Se Feed Back Lever
Hydraulic System H40500 Control Valve
Hydraulic System H44002 Position Control Lever Tur Se Position Control
Hydraulic System H45000 Position And Traction Control Connection Tur Se Position And
Hydraulic System H45200 Traction Control Lever Tur Se Draft Control
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch J10100 Top Stranger Holder Tur Se
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch J10502 Top Link Bracket
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch J10503 Top Link Bracket
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch J11000 Bottom Link
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch J11300 Stabilizer
Dr 3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch J11502 Lifting Rod Se
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K10500 Towbar
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K11500 Front Connection
Dr 3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K12502 PTO Protection Tur Se
Dr Hood Bonnet L10101 Front Grille Old Chassis No. 50309 S.No. 50309 S.
Dr Hood Bonnet L10102 Front Grille New Front Grille New Chassis No. 50310 S.No. 50310 S.
Hood Bonnet L10200 Hood (Bone) Front Pillar Hood (Bonnet) Front Support
Hood Bonnet L10500 Hood (Bonnet)
Hood Bonnet L10800 Hood (Bonnet) Damper
Hood Bonnet L13500 Hood (Bone) Rear
Hood Bonnet L20501 Rear View Mirror EC Tur Se Rearview Mirror EC Tur
Hood Bonnet L21000 Fender
Hood Bonnet L21301 Fender Support W Fender Support W
Hood Bonnet L21302 Fender Support R Fender Support R
Hood Bonnet L21700 Floor Sheet Cover
Hood Bonnet L22001 Seat W Seat W
Hood Bonnet L22002 Seat R Seat R
Hood Bonnet L22500 Step
Hood Bonnet L24001 Tool Box W Tool Box W
Hood Bonnet L24002 Tool Box R Tool Box R
ROPS L30101 ROPS W ROPS W
ROPS L30102 ROPS R ROPS R
Front Rear Tire P10101 Front Wheel(8-16) Front Wheel (8-16)
Front Rear Tire P10102 Front Wheel(9.5-16) Front Wheel (9.5-
Front Rear Tire P11001 Rear Wheels (12.4-28-4pr) Rear Wheel (12.4-
Front Rear Tire P11002 Rear Wheels (13.6-28) Rear Wheel (13.6-
Labels R10501 Label 1 (Front) Label 1 (Front)
Labels R11001 Label 2 (Rear) Label 2 (Rear)
Accessories And Service Parts S10500 Accessories And Service Parts
Option V18000 Working Light Kit Option
Option V42000 Bumper Kit Option Front Bumper Kit Option
Option V46001 Steering Handle Kit W Option Steering Handle Kit
Option V46002 Steering Handle Kit R Option Steering Handle Kit
Option V60001 Remote Control Valve Option Auxiliary Control Valve
Option V60002 Remote Control Valve (Floating) Option Auxiliary Control Valve
Option V60003 Remote Control Valve (Single) Option Auxiliary Control Valve (
Dr Option V62101 Auxiliary Control Valve Coupler (1.) Option Auxiliary Control Valve
Dr Option V62102 Auxiliary Control Valve Coupler (2.) Option Auxiliary Control Valve
Dr Option V62103 Auxiliary Control Valve Coupler (3.) Option Auxiliary Control Valve
Dr Option V62501 Auxiliary Control Valve Coupler (1.) W Option Auxiliary Control Valve
Dr Option V62502 Auxiliary Control Valve Coupler (1.) R Option Auxiliary Control Valve
Dr Option V62503 Auxiliary Control Valve Coupler (2.) W Option Auxiliary Control Valve
Dr Option V62504 Auxiliary Control Valve Coupler (2.) R Option Auxiliary Control Valve
Dr Option V62505 Auxiliary Control Valve Coupler (3.) W Option Auxiliary Control Valve
Dr Option V62506 Auxiliary Control Valve Coupler (3.) R Option Auxiliary Control Valve
Dr Option V73100 Swinging Drawbar Hook Drawbar Option Swinging Drawbar
