Kubota Tractor MK5000DW MK5000DR Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota MK5000DW ; MK5000DR Tractor
Number of Pages: 242 Pages
Itens Uso Frequent E / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Arvore Cames E Veio / Camshaft And Idle Gear Sh Aft
Volante Motor / Flywheel
Veio / Fuel Camshaft
Compensador / Balancer
Solenoide Paragem / Engine Stop Lever
Placa De Controlo De Velocidade [Velho] / Speed Control Plate [Old]
Placa De Controlo De Velocidade [Novo] / Speed Control Plate [New]
Vela Pre Aquecimento / Nozzle Holder And Glow P Lug
Bomba Agua E Termostacto / Water Flange And The Rmostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Alavanca Acelarador / Accelerator Lever
Ligação Do Acelerador / Accelerator Linkage
Suporte Do Depósito De Co Mbustível / Fuel Tank Support
Deposito Combustivel / Fu El Tank
Tubo Gasoleo/ Filtro / Fu El Pipe/Fuel Filter
Filtro Gasoleo[Peças Comp Onentes] / Fuel Filter [Component Parts]
Ventoin Ha / Fan
Tubo Ag Ua / Water Pipe
Radiado R / Radiator
Deposit O Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Co Mponentes] / Starter [Component Parts]
Interruptor/Sensor (Bloc O Motor) / Switch/Sensor (Engine)
Interruptor / Rele / Swi Tch/Relay
Interruptor/Sensor / Swi Tch/Sensor
Painel / Panel Board
Painel [Peças Componente S] / Panel Board [Component Parts]
Farol Frente [Ec] [Tur] / Head Light [Ec] [Tur]
Luzes Frente [Peças Comp Onentes] [Ec] [Tur] [Velho] / Head Light [Component Parts] [Ec] [Tur] [Old]
Luzes Frente [Peças Comp Onentes] [Ec] [Tur] [Novo] / Head Light [Component Parts] [Ec] [Tur] [New]
Lampada / Winker Lamp
Farol Traseiro / Rear La Mp
Farol Matricula [W] / Li Cense Lamp [W]
Farol Matricula [R] / Li Cense Lamp [R]
Ficha Reboque [W] / Trai Ler Socket [W]
Ficha Reboque [R] / Trai Ler Socket [R]
Cablagem Electrica (Dian Teiro) / Electrical Wiring (Front)
Cablagem Electrica (Tras Eiros) / Electrical Wiring (Rear)
Embraiagem / Clut Ch
Alavanca Da Embra Iagem / Clutch Lever
Caixa Intermedia / Mid Case
Válvula Da Embrai Agem Tdf/Fixador Do Rolamento / Pto Clutch Valve
Valvula Embraiage M Tdf[Peças Componentes] / Pto Clutch Valve [Compon Ent Parts]
Veio Primario / M Ain Shaft
Veio Secundario / Counter Shaft
Veio Inversor / S Huttle Shaft
Veio Gamas Veloci Dades / Range Gear Shaft
Pinhao Espiral / Spiral Bevel Pinion
Diferencial Trase Iro / Rear Differential
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf[Pe Ças Componentes] / Pto Clutch [Component Parts]
Veio Principal Td F / Pto Drive Shaft
Veio Tdf / Pto Sh Aft
Forque Ta / Main Gear Shift Fork
Forqui Lha Inversor / Shuttle Shift Fork
Forque Ta Velocidades / Range Gear Shift Fork
Alavan Ca / Differential Lock Shift Fork
Alvanc A Inversor / Shuttle Shift Lever
Alavan Ca Velocidades / Range Gear Shift Lever
Mudanç As Redutoras E Haste De Mudança Do Comutador / Rang E Gear Shift And Shuttle Shift Rod
Alavan Ca Dupla Traccao / Front Wheel Drive Lever
Eixo Traseiro (Lado Es Querdo) / Rear Axle(Left)
Eixo Traseiro (Lado Di Reito) / Rear Axle(Right)
Travao(Esq) / Brake Lh
Travao(Drt) / Brake Rh
Tirante Travao 1 (Peda L Travao) / Brake Rod 1 (Brake Pedal)
Tirante Travao 2 (Frei O Cam) / Brake Rod 2 (Brake Cam)
Travao Mao 1 (Suporte) / Hand Brake 1 (Support)
Pedal Travao / Brake P Edal
Veio Eixo / Front D Rive Shaft
Veio Do Propulsor D Ianteiro (Traseiro) / Propeller Shaft (Rear)
Veio Do Propulsor ( Dianteiro) / Propeller Shaft (Front)
Caixa Do Diferencia L Dianteiro / Front Differential Case
Engrenagem Cónica ( Dianteira) / Bevel Gear (Front)
Diferencial (Diante Iro) / Differential (Front)
Carter Eixo / Front Axle Case
Veio Grupo Conico / Differential Gear Shaft
Eixo Dianteiro / Fr Ont Axle
Punho Volante [W] / Steering Handle [W]
Punho Volante [R] / Steering Handle [R]
Distribuidor Direcção / Steering Controlle R
Suporte Da Direção / Steering Support
Rotula/Cilindro Direcção / Tie Rod/Steerin G Cylinder
Cilindro Direcção [Peças Componentes] / St Eering Cylinder [Component Parts]
Bomba Hidraulico / Hydra Ulic Pump
Valvula Reguladora / Reg Ulator Valve
Linha De Óleo Hidráulico (Entrada) / Hydraulic Oil Line (Inlet)
Tubo Oleo(Entrega) / Hyd Raulic Oil Line (Delivery)
Circuito Oleo (Direcção) / Hydraulic Oil Line (Steering)
Tubo Oleo (Tdf) / Pto Hy Draulic Pipe
Bloco Saidas Hidraulico / Hydraulic Outlet Block
Cilindro Hidraulico / Hy Draulic Cylinder
Braco Hidraulico [Tur] [ Se] / Lift Arm [Tur] [Se]
Alavanca [Tur] [Se] / Fe Ed Back Lever [Tur] [Se]
Valvula Control / Contro L Valve
Alavanca Control Posicao [Tur] [Se] / Position Control Lever [Tur] [Se]
Controlposicao E Profund Idade [Tur] [Se] / Position And Draft Control Link [Tur] [Se]
Control Posiçáo [Tur] [S E] / Draft Control Lever [Tur] [Se]
Sup Orte Terceiro Ponto [Tur] [Se] / Top Link Holder [T Ur] [Se]
Elo Superior [Tur] / Top Link [Tur]
Elo Superior [Se] / Top Link [Se]
Lig Acao Inferior / Lower Link
Est Abilizador / Stabilizer
Tir Ante De Elevação [Se] [Tur] / Lift Rod [Se] [Tur]
Bar Ra Reboque / Drawbar
Pux O / Front Hitch
Pro Teccao Tdf [Tur] [Se] / Pto Protector [Tur] [Se]
Grelha Frontal [Velho] / Front Grille [Old ]
Grelha Frontal [Novo] / Front Grille [New]
Suporte Dianteiro Capot / Hood (Bonnet) Fr Ont Support
Amortecedor Capot / Hood(Bonnet) Damper
Espelho Rectrovisor [Ec] [Tur] [Se] / Rear View Mirror [Ec] [Tur] [Se]
Guarda Lamas / Fender
Suporte Do Guarda-Lamas [W] / Fender Suppo Rt [W]
Suporte Do Guarda-Lamas [R] / Fender Suppo Rt [R]
Cobertura Piso / Floor Sheet Cover
Banco [W] / Seat [W]
Banco [R] / Seat [R]
Degrau / Step
Caixa Ferramenta [W] / Tool Box [W]
Caixa Ferramenta [R] / Tool Box [R]
Arco [W] / Rops [W]
Arco [R] / Rops [R]
Roda Frente (8-16) / Front Wheel (8-16)
Roda Frente (9.5-16) / Front Whe El (9.5-16)
Roda Traseira (13.6-28) / Rear W Heel (13.6-28)
Etiqueta 1 (Dianteiro) / Label 1 (Front)
Etiqueta 2 (Traseiro) / Label 2 (Rear)
Ace Ssorios E Peças Serviço / Accessories And Service P Arts
Kit Luzes Trabalho [Opcion] / Working Light Kit [Option]
Bumper Peso Kit [Opcion] / Front Bumper Kit [Op Tion]
Direção Punho Kit [W] [Opcion] / Steering Handl E Kit [W] [Option]
Direção Punho Kit [R] [Opcion] / Steering Handl E Kit [R] [Option]
Distribuidor Auxiliar [Opcion] / Auxiliary Cont Rol Valve [Option]
Distribuidor Auxiliar (Flutuante) [Opcion] / Au Xiliary Control Valve (Floating) [Option]
Distribuidor Auxiliar (Única) [Opcion] / Auxili Ary Control Valve (Single) [Option]
Válvula De Controle Alavanca Kit (Primeira) [Op Cion] / Auxiliary Control Valve Lever (1st) [Option ]
Válvula De Controle Alavanca Kit (Segunda) [Opc Ion] / Auxiliary Control Valve Lever (2nd) [Option]
Válvula De Controle Alavanca Kit (Terceiro) [Op Cion] / Auxiliary Control Valve Lever (3rd) [Option ]
Válvula De Controle Coupler (Primeiro) [R] [Opc Ion] / Auxiliary Control Valve Coupler (1st) [R] [O Ption]
Válvula De Controle Coupler (Segunda) [W] [Opci On] / Auxiliary Control Valve Coupler (2nd) [W] [Op Tion]
Válvula De Controle Coupler (Segunda) [R] [Opci On] / Auxiliary Control Valve Coupler (2nd) [R] [Op Tion]
Válvula De Controle Coupler (Terceiro) [W] [Opc Ion] / Auxiliary Control Valve Coupler (3rd) [W] [O Ption]
Válvula De Controle Coupler (Terceiro) [R] [Opc Ion] / Auxiliary Control Valve Coupler (3rd) [R] [O Ption]
Balanço Drawbar / Grancho Drawbar [Opcion] / Sw Inging Drawbar/Clevis Drawbar [Option]
