Kubota Tractor M8560DTH Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M8560DTH Tractor
Number of Pages: 345 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaus T Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Carreto / Gear Case
Compensador / Balancer
Volante Motor / Flywheel
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Thermo Stat
Bomba Agua / Water Pump
Flange Filtro Ar / Air Cleaner Flange And Throttle Valve
Valvula Egr/Egr Refrigerador / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar [Velho] / Air Cleaner [Old]
Filtro Ar [Novo] / Air Cleaner [New]
Filtro Ar[Peças Componentes] / Air Cleaner [Compon Ent Parts]
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Clean Er)
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Diese L Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peças Componentes] / Diesel Particulate Filter Muffler [C Omponent Parts]
Sensor Escape / Muffler Sensor
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor / Engine Electrical P Arts
Diagmaster / Diagmaster
Deposito Combustivel / Fuel Tan K
Fornecimento Combustivel / Fuel Filler
Tubo Combustivel / Fuel Pipe (F Uel Filter)
Tubo Combustivel / Fuel Pipe (F Uel Pump)
Tubo Combustivel / Fuel Pipe (F Uel Cooler)
Arrefecedor Gasoleo / Fuel Cool Er
Separador / Separator
Separador[Peças Componentes] / Separator [Component Parts]
Ventoinha / Fan
Tubo Agua / Wate R Pipe
Radiador / Radia Tor
Alternador / Alternator
Motor Arranque / Starter
Motor Arranque [Peças Compo Nentes] / Starter [Component Parts]
Interruptor/Sensor (Frente) / Switch/Sensor (Front)
Interruptor/Sensor (Parte T Raseira) / Switch/Sensor (Rear)
Interruptor/Sensor (Carter Embraiagem) / Switch/Sensor (Clutch Housing)
Interruptor (Painel) / Swit Ch (Panel Board)
Rele / Relay
Unidade Control Electrico ( Dtsc) / Electronic Control Unit
Quadro Do Painel / Panel Bo Ard
Luzes Frente / Head Light
Farol Frente [Peças Compone Ntes] / Head Light [Component Parts]
Luzes Frontais / Front Comb Ination Light
Farol Matricula / License L Amp
Ficha Reboque / Trailer Soc Ket
Cablagem Electrica (Crs) / Electrical Wiring (Crs)
Cablagem Electrica (Frente) [Velho] / Electrical Wiring (Front) [Old]
Cablagem Electrica (Frente) [Novo] / Electrical Wiring (Front) [New]
Cablagem Electrica (Traseir O) [Velho] / Electrical Wiring (Rear) [Old]
Cablagem Electrica (Traseir O) [Novo] / Electrical Wiring (Rear) [New]
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cove R
Caixa Da Transmiss Ão [Velho] / Transmission Case [Old]
Caixa Da Transmiss Ão [Novo] / Transmission Case [New]
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo [Velho ] / Rear Axle Case [Old]
Carter Eixo [Novo] / Rear Axle Case [New]
Disco Amortecedor / Damper Disk
Valvula (Inversor) / Valve Lever (Clutch)
Veio Primario / In Put Shaft
Kit Embraiagem Hi- Lo [Peças Componentes] / Clutch Pack (Shuttle) [Com Ponent Parts]
Veio Inversor / Sh Uttle Shaft
Primeiro Veio / Fi Rst Shaft
Terceiro Veio / Th Ird Shaft
Veio Creeper / Cre Ep Shaft
Veio / Drive Shaft
Grupo Conico / Bev El Gear
Diferencial Trasei Ro [Velho] / Rear Differential [Old]
Diferencial Trasei Ro [Novo] / Rear Differential [New]
Embraiagem Bloquei O Diferencial Traseiro / Rear Differential Lock Clu Tch
Embraiagem Tdf / P To Clutch
Embraiagem Tdf [Pe Ças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiagem Tdf / Pto Clutch Valve
Veio Tdf / Pto Sha Ft
Embraiagem Andamen To / Front Drive Clutch
Veio Embraiagem[Pe Ças Componentes] / Front Drive Clutch [Component Pa Rts]
Gama E G Arfo Caixa Creep / Range And Creep Gear Shift Fork
Alavanca Velocidades / Main Gear Shift Lever
Cabo Inv Ersor / Shuttle Cable
Gama E T Irante Caixa Creep / Range And Creep Gear Shift Lev Er
Pedal Bloqueio Diferenc Ial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Ax Le Shaft
Travao(Drt) / Brake Rh
Travao(Esq) / Brake Lh
Tirante Travao Mao / Pa Rking Brake Rod
Veio Bloqueio / Parking Brake Camshaft
Tirante Travao Mao [Nov A] / Parking Brake Rod [New]
Travao Parque [Nova] / Parking Brake [New]
Pedal Travao / Brake Pe Dal
Deposito Oleo Travoes / Brake Oil Tank
Tubo Travao / Brake Pip E
Suporte Eixo Frente [Velho] / Front Axle Frame [Old]
Suporte Eixo Frente [Novo] / Front Axle Frame [New]
Suporte Eixo Dianteiro / Fron T Axle Bracket
Caixa Diferencial Dianteiro / Front Differential Case
Grupo Conico Frente(Frente) / Bevel Gear (Front)
Caixas Engrenagens Conica (Dr T) / Bevel Gear Case Rh
Caixas Engrenagens Conica (Es Q) / Bevel Gear Case Lh
Carter Eixo Frente(Drt) / Fro Nt Axle Case Rh
Carter Eixo Frente(Esq) / Fro Nt Axle Case Lh
Carreto Diferencial(Drt) / Di Fferential Gear Shaft Rh
Carreto Diferencial(Esq) / Di Fferential Gear Shaft Lh
Veio Transmissao(Drt) / Front Axle Rh
Veio Transmissao(Esq) / Front Axle Lh
Pedal Inclinacao / Tilt Pedal
Junta [Velho] / Steering Joint [Old]
Junta [Novo] / Steering Joint [New]
Distribuidor Direcção [Peças Componentes] [Ve Lho] / Steering Controller [Component Parts] [Old]
Distribuidor Direcção [Peças Componentes] [No Vo] / Steering Controller [Component Parts] [New] # # N.º De Série>=53603 S.No.;>=53603 / S.No.>=53603 S.No.;>=53603
Rotula/Cilindro Direcção / Tie Rod/Steering C Ylinder
Cilindro Direcção [Peças Componentes] / Steer Ing Cylinder [Component Parts]
Bomba Hidraulico / Hydrauli C Pump
Bomba Hidraulico [Peças Com Ponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo [Velho] / Hydraul Ic Oil Line (Delivery) [Old]
Tubo Oleo [Novo] / Hydrauli C Oil Line (Delivery) [New]
Tubo Hidraulico [Velho] / H Ydraulic Pipe (Trailer Brake) [Old]
Tubo Hidraulico [Novo] / Hy Draulic Pipe (Trailer Brake) [Old]
Tubo Hidraulico [Novo] / Hy Draulic Pipe (Trailer Brake) [New]
Valvula De Freio De Reboque [Velho] / Trailer Brake Valve [Old]
Valvula De Freio De Reboque [Velho]] / Trailer Brake Valve [Old]
Valvula De Freio De Reboque [Novo] / Trailer Brake Valve [New]
Circuito Oleo Direcção (Dir Ecção/Tdf) / Hydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Controller)
Tubo Direccao / Steering Ho Se (Delivery)
Caixa Cilindro Hidraulico / Hydraulic Cylinder Case
Piston Hidraulico / Braços / Hydraulic Lift Arm
Valvula Segurança / Safety Valve/Relief Valve
Trinco / Lowering Lock Leve R
Valvula Control / Control V Alve
Alavanca Control Posicao [N Ovo] / Position Control Lever [New]
Alavanca Control Esforço / Draft And Position Control Lever
Veio Posicao Esforço / Posi Tion And Draft Shaft
Alavanca / Feed Back Lever
Distribuidor Auxiliar [Velh O] / Auxiliary Control Valve [Old]
Distribuidor Auxiliar [Novo ] / Auxiliary Control Valve [New]
Valvula Auxiliar [Peças Com Ponentes] [Velho] / Auxiliary Control Valve (Fd) [C Omponent Parts] [Old]
Valvula Auxiliar [Peças Com Ponentes] [Novo] / Auxiliary Control Valve (Scd) [C Omponent Parts] [New]
Alavanca Valvula Auxiliar 1 Pos / Auxiliary Control Valve Lever (2nd)
Cilindro Auxiliar De Elevac Ao Esq [Se] / 3p-Lift Assist Cylinder Lh [Se]
Cilindro Auxiliar De Elevac Ao Drt [Se] / 3p-Lift Assist Cylinder Rh [Se]
Cilindro Auxiliar De Elevac Ao [Peças Componentes] [Velho] / 3p-Lift Assist Cyl Inder [Component Parts] [Old]
Parte Superior / Top Link Bracket
Ligaca O Superior / Top Link
Ligaca O Inferior [Se] [Velho] / Lower Link [Se] [Old]
Ligaca O Inferior [Novo] / Lower Link [New]
Estabi Lizador [Velho] / Stabilizer [Old]
Estabi Lizador [Novo] / Stabilizer [Neu]
Estabi Lizador(Drt) / Lift Rod Rh
Estabi Lizador(Esq) / Lift Rod Lh
Barra [Se] [Velho] / Drawbar Bracket [Se] [Old]
Barra [Se] [Novo] / Drawbar Bracket [Se] [New]
Protec Cao Tdf [Se] / Pto Shaft Protector [Se]
Grelha Frontal / Front Grille
Capot Superior / Isolador / Hood (Bonnet) Upp Er (Sound Absorber/Insulator)
Trico Capot / Bonnet Lock
Capot Traseiro / Hood (Bonnet) Rear (Sound Ab Sorber)
Guarda Lamas / Fender
Tampa / Shift Cover
Piso [Velho] / Floor Sheet [Old]
Piso [Novo] / Floor Sheet [New]
Piso (Isolante) / Floor Sheet (Soundproof Mat Erial)
Degrau / Step
Degrau Auxiliar / Auxiliary Step
Banco [Se] / Seat [Se]
Caixa Ferramenta / Tool Box
Es Trutura De Protecção (Frente) / Rops (Upper)
Es Trutura De Protecção (Traseira) / Rops (Lower) [Old ]
Es Trutura De Protecção (Traseira) / Rops (Lower) [New ]
Etiqueta (Dianteiro) / Label (Front)
Etiqueta (Traseiros) / Label (Rear)
Acessorios / Accessories
Panela Escape [Opçao] [Velho] / Upper Muffler Kit [Option] [Old]
Panela Escape [Opçao] [Novo] / Upper Muffler Kit [ Option] [New]
Kit Ecu [Opção] / Ecu Kit [Option]
Alternador 1 [Opçao] / Alternator Kit 1 (Alternato R) [Option]
Alternador 2 [Opçao] / Alternator Kit 2 (Wire Harn Ess) [Option]
Alternador [Opçao] [Peças Componentes] / Alternato R [Component Parts] [Option]
Kit Farios Trabalho [Opçao] / Working Light Kit [O Ption]
Kit Fusivel [Opção] / Fuse Kit [Option]
Kit Conversao Tdf (540/1000) (Engrenagem Box) [Opç Ão] / Pto(540/1000) Conversion Kit (Gear Case) [Opt Ion]
Kit Conversao Tdf (540/1000) (Engrenagem) [Opção] / Pto(540/1000) Conversion Kit (Gear) [Option]
Kit Modificação Tdf (540/1000) (Engrenagem) [Opção ] / Pto (540/1000) Conversion Kit (Gear) [Option]
Kit De Atualização Para Embraiagem 4x4 [Opção] / 4 Wd Clutch Upgrade Kit [Option]
Embraiagem 4x4 [Peças Componentes] [Opção] / 4wd C Lutch [Component Parts] [Option]
Apoio [Opção] [Nova] / Front Bumper Kit [Option] [ New]
Apoio [Opção] / Front Bumper Kit [Option]
Kit Valvula Control Auxiliar (Scd) [Opcao] / Auxil Iary Control Valve Kit (Scd) [Option]
Kit Valvula Control Auxiliar (Fd) [Opcao] / Auxili Ary Control Valve Kit (Fd) [Option]
Kit Valvula Control Auxiliar (Fc) [Opcao] / Auxili Ary Control Valve Kit (Fc) [Option]
Kit Valvula Control Auxiliar (Scd/Fc) [Opcao] / Au Xiliary Control Valve Kit (Scd/Fc) [Option]
Kit Distribuidor Serviços Externos (Scd) [Peças Co Mponentes][Opcao] / Auxiliary Control Valve (Scd) [ Component Parts] [Option]
Kit Distribuidor Serviços Externos (Fd) [Peças Com Ponentes][Opcao] / Auxiliary Control Valve (Fd) [Co Mponent Parts] [Option]
Kit Distribuidor Serviços Externos (Fc) [Peças Com Ponentes][Opcao] / Auxiliary Control Valve (Fc) [Co Mponent Parts] [Option]
Kit Alavanca Serviços Externos [Opcao] / Auxiliary Control Valve Lever Kit (3rd) [Option]
