Kubota Tractor M8540DTNQPC Spare Parts Catalog EN FR
Language: French, English
Model: Kubota M8540DTNQPC Tractor
Number of Pages: 322 Pages
Frequently Used Items / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Soupapes Et Culbuteurs / Valve And Rocker Arm
Couvre-Culasse / Head Cover
Piston Et Vilebrequin / Piston And Crankshaft
Arbre A Cames Et Arbre De Pignon Fou / Camshaf T And Idle Gear Shaft
Compensateur / Balancer
Volant Du Moteur / Flywheel
Carter De Pompe / Pump Housing
Levier A Fourche (Regulateur De Vitesses) / Fo Rk Lever (Governor)
Vis De Reglage De Vitesse / Governor Adjusting Bolt
Injecteurs Et Bougies Prechauffage / Nozzle Ho Lder And Glow Plug
Bride A Eau Et Thermostat / Water Flange And T Hermostat
Pompe A Eau / Water Pump
Soupape D'egr / Egr Valve
Filter A Air / Air Cleaner
Filtre A Air [Parties Composantes] / Air Clean Er [Component Parts]
Silencieux / Muffler
Tuyau D'huile (Turbo-Chargeur) / Oil Pipe (Tur Bo Charger)
Tuyau D'huile (Mecanique Commutateur) / Oil Pi Pe (Mechanical Timer)
Refroidisseur / Oil Cooler
Levier D'accelerateur / Hand Accelerator Lever
Reservoir Carb. / Fuel Tank
Reservoir A Carburant Droite / Fuel Tank Rh
Reservoir A Carburant Gauche / Fuel Tank Lh
Tuyau A Carburant 1 (Arriere) / Fuel Pipe 1 (Rear)
Tuyau A Carburant 2 (Avant) / Fuel Pipe 2 (Front)
Separateur / Separator
Separateur [Parties Composante S] / Separator [Component Parts]
Ventilateur / Fan
Ventilateur / Fan
Tuyau D'eau / Wat Er Pipe
Radiateur / Radia Tor
Vase Expansion / Reserve Tank
Alternateur / Alternat Or
Alternateur [Parties C Omposantes] / Alternator [Component Parts]
Demarreur / Starter
Demarreur [Parties Com Posantes] / Starter [Component Parts]
Batterie / Battery
Batterie / Battery
Batterie / Battery
Commutateur/Detector ( Avant) / Switch/Sensor (Front)
Commutateur (Tableau D E Bord) / Switch (Panel Board)
Communtateurs / Switch
Relais / Relay
Phare Avant / Head Lig Ht
Feux De Route [Parties Composantes] / Head Light [Component Parts]
Feux De Combinaison Av Ant / Front Combination Light
Lumiere De Travail/Lum Iere De Balise / Working Light/Beacon Light
Feux De Combinaison Ar Riere / Rear Combination Light
Lampe Plaque Immatricu Lation / License Lamp
Prise De Remorque / Tr Ailer Socket
Plafonnier / Room Ligh T
Radio-Orateur / Radio Speaker
Reservoir Lave-Glace / Washer Tank
Essuie-Glase Avant / F Ront Wiper
Faisceau Electrique (M Oteur) / Electrical Wiring (Engine)
Faisceau Electrique (P Rincipal) / Electrical Wiring (Main)
Cablage Electrique (Ca Bine) / Electrical Wiring (Cab)
Carter Embrayage / Clutch Housing
Soupape D'inverse Ur / Shuttle Valve
Covercle De Chang Ement / Shift Cover
Carter De Transmi Ssion / Transmission Case
Tuyau De Reniflar D (Carter De Transmission) / Breather Hose (Transmi Ssion Case)
Couvercle De Cart Er De Boite Arriere / Transmission Case Rear Cover
Carter Pont Arrie Re / Rear Axle Case
Couvercle De Cart Er Pont Arriere / Rear Axle Case Cover
Amoritisseur Disq Ue / Damper Disk
Pedale D'embrayag E / Clutch Pedal
Arbre D'entree / Input Shaft
Embrayage De Inve Rseur [Parties Composantes] / Shuttle Clutch [Compo Nent Parts]
Arbre Inverseur / Shuttle Shaft
Premier Arbre / F Irst Shaft
Deuxieme Arbre / Second Shaft
Troisieme Arbre / Third Shaft
Differentiel Arri Ere / Rear Differential
Arbre De Transmis Sion Pdf / Pto Propeller Shaft
Pdf Embrayage [Vi Eux] / Pto Clutch [Old]
Pdf Embrayage [No Uveau] / Pto Clutch [New]
Embrayage Pdf [Pa Rties Composantes] [Vieux] / Pto Clutch [Component Parts] [Old]
Embrayage Pdf [Pa Rties Composantes] [Nouveau] / Pto Clutch [Componen T Parts] [New]
Soupape D'embraya Ge Pdf / Pto Clutch Valve
Arbre Pdf / Pto S Haft
Embrayage Avant D 'Entrainement / Front Drive Clutch
Embrayage Avant D 'Entrainement [Parties Composantes] / Front Drive C Lutch [Component Parts]
Arbre De Transmis Sion (Arriere) / Front Propeller Shaft (Rear)
Fourchette De Vit Esse Principal / Main Gear Shift Fork
Fourchette De Cha Ngement De Gamme Et Rampante / Range And Creep Gear Shift Fork
Fourchette De Blo Cage Differentiel / Differential Lock Shift Fork
Levier De Changem Ent De Vitesses Principal / Main Gear Shift Lever
Tige De Changemen T De Vitesses Principal / Main Gear Shift Rod
Levier Inverseur De Marche / Shuttle Shift Lever
Cable De Inverseu R / Shuttle Cable
Levier De Changem Ent De Gamme / Range Gear Shift Lever
Levier De Chengem Ent De Vitesse Pdf / Pto Gear Shift Lever
Axe Arriere / Rear Axle
Frein Droite / Brake Rh
Frein Gauche / Brake Lh
Tige De Frein (Pedal De F Rein) / Brake Rod (Brake Pedal)
Tige De Frein (Came De Fr Ein) / Brake Rod (Brake Cam)
Levier De Frein Stationne Ment / Parking Brake Lever
Soupape De Frein De Stati Onnement / Parking Brake Valve
Pedale De Frien / Brake P Edal
Support Essieu Avant / Front Axle Frame
Arbre De Transmission / Front Propeller Shaft
Avant Carter De Differ Entiel / Front Differential Case
Engrenage Conique (Ava Nt) / Bevel Gear (Front)
Differentiel Avant / D Ifferential Front
Carter Engrenage Coniq Ue Droite / Bevel Gear Case Rh
Carter Engrenage Coniq Ue Gauche / Bevel Gear Case Lh
Carter Reducteur Droit E / Front Axle Case Rh
Carter Reducteur Gauch E / Front Axle Case Lh
Demi Arbre De Pont Ava Nt Droite / Differential Gear Shaft Rh
Demi Arbre De Pont Ava Nt Gauche / Differential Gear Shaft Lh
Reducteur Droite / Fro Nt Axle Rh
Reducteur Gauche / Fro Nt Axle Lh
Joint De Cardan De Direction / Steering J Oint
Controleur De Direction / Steering Contro Ller
Servo Direction [Parties Composantes] / S Teering Controller [Component Parts]
Barrd De Accouplement/Cylindre De Directi On / Tie Rod/Steering Cylinder
Verib De Direction [Parties Composantes] / Steering Cylinder [Component Parts]
Pompe Hydraulique / Hyd Raulic Pump
Pompe Hydraulique [Part Ies Composantes] / Hydraulic Pump [Component Parts]
Circuit De Huile Hydrau Lique (Refoulement) / Hydraulic Pipe (Delivery)
Refroidisseur / Oil Coo Ler
Circuit D'huile Hydraul Ique (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydraul Ique (Inverseu/Pdf) / Hydraulic Oil Line (Shuttle/P To)
Circuit D'huile Hydraul Ique (Soupape D'embrayage Pdf) / Hydraulic Oil Line (Pto Clutch Valve)
Tuyau De Direction (Ref Oulement) / Steering Hose (Delivery)
Carter De Cylindre Hydr Aulique / Hydraulic Cylinder Case
Bras De Relevage / Lift Arm
Clapet De Surcharge/Sou Pape De Securite / Safety Valve/Relief Valve
Distributeur Hydrauliqu E [Vieux] / Control Valve [Old]
Distributeur Hydrauliqu E [Nouveau] / Control Valve [New]
Levier De Command De Tr Action/Levier De Position / Draft And Position Cont Rol Lever
Position Et Arbre D'eff Ort / Position And Draft Shaft
Levier De Renvoi / Feed Back Lever
Valve Auxiliaire / Auxi Liary Control Valve
Valve Auxiliaire (Fd) [ Parties Composantes] / Auxiliary Control Valve (Fd) [Component Parts]
Levier De Controle De D Istributeur Auxiliaire (1eme) / Auxiliary Control V Alve Lever (1st)
Levier De Controle De D Istributeur Auxiliaire (2eme) / Auxiliary Control V Alve Lever (2nd)
3-Pts Soulevez Le Cylin Dre D'aide Gauche / 3p-Lift Assist Cylinder Lh
3-Pts Soulevez Le Cylin Dre D'aide Droite / 3p-Lift Assist Cylinder Rh
3-Pts Soulevez Le Cylin Dre D'aide [Parties Composantes] / 3p-Lift Assist C Ylinder [Component Parts]
Tuyau De Reniflard (3-P Ts Cylindre) / Breather Hose (3p Cylinder)
Support De Tirant Superieur / Top Lin K Bracket
Tirant Superieur / Top Link
Bras Inferieurs / Lower Link
Stabilisateur / Stabilizer
Barre De Relevage Droite / Lift Rod R H
Barre De Relevage Gauche / Lift Rod L H
Support De La Barre D'attelage / Draw Bar Bracket
Protecteur D'axe De Pdf / Pto Shaft P Rotector
Capot Lateral / Hood (Bonnet) Upper
Carter D'huile / Bonnet Lock
Support De Capot / Bonnet Support
Armature De Cabine / Cab Frame
Verre Avant / Front Glass
Porte Droite / Door Rh
Porte Gauche / Door Lh
Serrure Porte Droite / Door Lock Rh
Fenetre Laterale Droite / Side Window Rh
Fenetre Laterale Gauche / Side Window Lh
Vitre Arriere (Superieur) / Rear Window (Upper)
Retroviseur / Rearview Mirror
Toit Interne / Inner Roof
Toit Externe / Outer Roof
Tapis / Floor Mat
Tapis / Floor Mat
Materiel Insonorise / Soundproof Material
Couvercle De Viste / Inspection Plate
Couvercle De Aile Droite / Fender Cover Rh
Ventilateur / Fender
Boite Dutils / Tool Box
Air Conditionneur / Air Co Nditioner
Conduit De Climatiseur / A Ir Conditioner Duct
Tuyau De Chauffage / Heate R Hose
Condensateur / Condenser
Compresseur / Compressor
Compresseur Support / Comp Ressor Bracket
Tuyau De Drainage / Drain Hose
Chassis Droite (Chenille De Puissance) / Frame Rh (Power Crawler)
Chassis Gauche (Chenille De Puissance) / Frame Lh (Power Crawler)
Secousse De La Parenthes E Droite (Chenille De Puissance) / Shaking Bracket Rh (Power Crawler)
Secousse De La Parenthes E Gauche (Chenille De Puissance) / Shaking Bracket Lh (Power Crawler)
Oisif Droite (Chenille D E Puissance) / Idler Rh (Power Crawler)
Oisif Gauche (Chenille D E Puissance) / Idler Lh (Power Crawler)
Rouleau De Camion Droite (Chenille De Puissance) / Truck Roller Rh (Power C Rawler)
Rouleau De Camion Gauche (Chenille De Puissance) / Truck Roller Lh (Power C Rawler)
Pignon Et Chenille (Chen Ille De Puissance) / Sppocket And Crawler (Power Cr Awler)
Etiquette 1 (Avant) / Label 1 (Front)
Etiquette 2 (Armature De Cabine) / Label 2 (Cab Frame)
Etiquette 3 (Arriere) / Label 3 (Rear)
Accessories Et Piece De Service / Ac Cessories And Service Parts
Alternateur (Alternateur) [Option] / Alternato R Kit (Alternator) [Option]
Alternateur 2 (Harness) [Option] / Alternator Kit 2 (Wire Harness) [Option]
Alternateur [Parties Composantes] [Option] / A Lternator [Component Parts] [Option]
Sortie Hyd. A Distance Avant (Support/Tuyau) [ Option] / Front Remote Hydraulic Outlet (Holder/Pip E) [Option]
Sortie Hydraulique A Distance Avant (1eme Soup Ape) [Option] / Front Remote Hydraulic Outlet (1st Valve) [Option]
Sortie Hydraulique A Distance Avant (2eme Soup Ape) [Option] / Front Remote Hydraulic Outlet (2nd Valve) [Option]
Valve Auxiliaire (Fc) [Parties Composantes] [O Ption] / Auxiliary Control Valve (Fc) [Component Pa Rts] [Option]
Valve Auxiliaire (Scd) [Parties Composantes] [ Option] [Vieux] / Auxiliary Control Valve (Scd) [Co Mponent Parts] [Option] [Old]
Valve Auxiliaire (Scd) [Parties Composantes] [ Option] [Nouveau] / Auxiliary Control Valve (Scd) [ Component Parts] [Option] [New]
Sortie Hyd. A Distance Avant (Couvercle De Sou Pape) [Option] / Front Remote Hydraulic Outlet (Val Ve Cover) [Option]
Sortie Hyd. A Distance Avant (Levier De Comman De) [Option] / Front Remote Hydraulic Outlet (Contr Ol Lever) [Option]
Sortie Hyd. A Distance Avant (Levier De 1eme) [Option] / Front Remote Hyd. Outlet (1st Valve Cont Rol Lever) [Option]
Sortie Hyd. A Distance Avant (Levier De 2eme) [Option] / Front Remote Hyd. Outlet (2nd Valve Cont Rol Lever) [Option]
Sortie Hyd. A Distance Avant (Couvercle) [Opti On] / Front Remote Hydraulic Outlet (Cover) [Option ]
Ventilateur / Fan
Ventilateur / Fan
Demarreur / Starter
Batterie / Battery
Batterie / Battery
Batterie / Battery
Relais / Relay
Tapis / Floor Mat
Tapis / Floor Mat
