Kubota Tractor M8540DTNQPC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M8540DTNQPC Tractor
Number of Pages: 525 Pages
Bloque Motor / Crankcase
Carter / Oil Pan
Cilindro Ppal / Cylinder Head
Valvulas Y Balancines / Valve And Rocker Arm
Culata Cubierta / Head Cover
Caja De Cambio / Gear Case
Piston Y Ciguenal / Piston And Crankshaft
Compensador / Balancer
Volante / Flywheel
Bomba Carcasa / Pump Housing
Bifurcacion Palanca(Regulador) / Fork Lever (Governor)
Regulador Ajuste Tornillo / Governor Adjusting Bolt
Filtro Combustible / Fuel Filter
Inyector Y Bujia Precalent / Nozzle Holder And Glow Plug
Termostatoy Tapa / Water Flange And Thermostat
Bomba Agua / Water Pump
Valvula De Egr / Egr Valve
Filtro De Aire / Air Cleaner
Entrada Tubo [Componente Piezas] / Air Cleaner [Component Parts]
Silenciador / Muffler
Pipa Del Aceite (Contador De Tiempo Mecanico) / Oil Pipe (Mechanical Timer)
Palanca Acelerador / Hand Accelerator Lever
Deposito De Combustible Dcha / Fuel Tank Rh
Deposito De Combustible Izqd / Fuel Tank Lh
Combustible Tubo 1 (Trasero) / Fuel Pipe 1 (Rear)
Combustible Tubo 2 (Fronte) / Fuel Pipe 2 (Front)
Separador / Separator
Ventilador / Fan
Manguitoagua / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Motor De Arranque [Componentes] / Starter [Component Parts]
Conmutador/Sensor (Adelante) / Switch/Sensor (Front)
Conmutador/Sensor (Trasero) / Switch/Sensor (Rear)
Conmutador / Switch
Rele / Relay
Faro Delantero / Head Light
Adelante Combinacion Luz / Front Combination Light
Trabajo Luz/Luz Del Faro / Working Light/Beacon Light
Trasero Combinacion Luz / Rear Combination Light
Luz Matricula / License Lamp
Limpiador Delantero / Front Wiper
Electrico Cableado (Motor) / Electrical Wiring (Engine)
Electrico Cableado (Principal) / Electrical Wiring (Main)
Electrico Cableado (Cabina) / Electrical Wiring (Cab)
Carcasa De Embrague / Clutch Housing
Manguera Del Respiradero (Transmision Caja) / Breather Hose (Transmission Case)
Cubierta De La Caja Del Eje Trasero / Rear Axle Case Cover
Pedal Embrague / Clutch Pedal
Valvula Palanca (Embrague) / Valve Lever (Clutch)
Entrada Eje / Input Shaft
Inversor Embrague [Componente Piezas] [Ds] / Shuttle Clutch [Component Parts]
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Eje Diferencial / Bevel Gear
Embrague Tdf [Antiguo] / Pto Clutch [Old]
Embrague Tdf [Nuevo] / Pto Clutch [New]
Pto Embrague [Componente Piezas] [Antiguo] / Pto Clutch [Component Parts] [Old]
Pto Embrague [Componente Piezas] [Nuevo] / Pto Clutch [Component Parts] [New]
Eje Tdf / Pto Shaft
Embrague Impulsor Delantero [Componente Piezas] / Front Drive Clutch [Component Parts]
Eje Propulsor Delantero(Posterior) / Front Propeller Shaft (Rear)
Horquilla De Cambio Principal / Main Gear Shift Fork
Gama Y Arrastramiento Engranaje Cambio Bifurcacion / Range And Creep Gear Shift Fork
Inversor Cable / Shuttle Cable
Freno Derecho / Brake Rh
Freno Izquierdo / Brake Lh
Varilla De Freno (Pedal De Freno) / Brake Rod (Brake Pedal)
Varilla De Freno (Leva De Freno) / Brake Rod (Brake Cam)
Válvula Del Freno De Estacionamiento / Parking Brake Valve
Freno Pedal / Brake Pedal
Soporte De Eje Delantero / Front Axle Bracket
Eje Propulsor / Front Propeller Shaft
Carcasa Diferencial Delantero / Front Differential Case
Diferencial Delantero / Differential Front
Caja De Engranaje Conico Dcha / Bevel Gear Case Rh
Caja De Engranaje Conico Izqd / Bevel Gear Case Lh
Diferencial Engranaje Eje Derecho / Differential Gear Shaft Rh
Maneta Direccion / Steering Handle
Orbitrol / Steering Controller
Direccion Controlador [Componente Piezas] / Steering Controller [Component Parts]
Cilindro De Direccion [Componentes] / Steering Cylinder [Component Parts]
Bomba Hidraulica [Componentes] / Hydraulic Pump [Component Parts]
Hidraulico Tubo (Entrega) / Hydraulic Pipe (Delivery)
Hidraulico Radiador De Aceite / Oil Cooler
Hidraulico Aceite Linea (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Pto)
Hidraulico Aceite Linea (Tdf Embrague Valvula) / Hydraulic Oil Line (Pto Clutch Valve)
Latiguillo De Direccion (Impulsion) / Steering Hose (Delivery)
Ascenzo Brazo / Lift Arm
Distribuidor [Antiguo] / Control Valve [Old]
Distribuidor [Nuevo] / Control Valve [New]
Palanca De Control De Esfuerzo Y Posicion / Draft And Position Control Lever
Posicion Y Esfuerzo Eje / Position And Draft Shaft
Palanca Alimentacion Trasera / Feed Back Lever
Distribuidor De Servicios Externos / Auxiliary Control Valve
Auxiliar Control Valvula (Fd) [Componente Piezas] / Auxiliary Control Valve (Fd) [Component Parts]
Auxiliar Control Valvula Palanca (1r) / Auxiliary Control Valve Lever (1st)
Auxiliar Control Valvula Palanca (2do) / Auxiliary Control Valve Lever (2nd)
Manguera Del Respiradero (Cilindro De Ayuda De Elevacion) / Breather Hose (3p Cylinder)
Parte Superior / Top Link
Bajar Vinculo / Lower Link
Estabilizador / Stabilizer
Ascenso Varilla Dcha / Lift Rod Rh
Ayudar Cilindro Soporte / Drawbar Bracket
Pto Protector / Pto Shaft Protector
Parrilla Frontal / Front Grille
Capo Lado / Hood (Bonnet) Upper
Carter / Bonnet Lock
Capo Lado Cubierta / Hood (Bonnet) Side Cover
Capo Soporte / Bonnet Support
Cabina Bastidor / Cab Frame
Adelante Vidrio / Front Glass
Puerta Derecha / Door Rh
Puerta Izqd / Door Lh
Cerradura De Puerta Izqd / Door Lock Lh
Lado Ventana Derecho / Side Window Rh
Lado Ventana Izquierdo / Side Window Lh
Trasero Ventana (Superior) / Rear Window (Upper)
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Piso Estera / Floor Mat
Material Insonoro / Soundproof Material
Inspeccion Placa / Inspection Plate
Guardabarros Cubierta Derecho / Fender Cover Rh
Cubierta De Guardabarros Izqd / Fender Cover Lh
Ventilador / Fender
Herramienta Caja / Tool Box
Aire Acondicionador Conducto / Air Conditioner Duct
Manguitocalentador / Heater Hose
Condensador / Condenser
Compresor / Compressor
Soporte De Compresor / Compressor Bracket
Vaciar Manguito / Drain Hose
Estructura Del Lado Derecho (Power Crawler) / Frame Rh (Power Crawler)
Estructura Del Lado Izquierdo (Power Crawler) / Frame Lh (Power Crawler)
Soporte Para Sacudidas Del Lado Derecho (Power Crawler) / Shaking Bracket Rh (Power Crawler)
Soporte Para Sacudidas Del Lado Izquierdo (Power Crawler) / Shaking Bracket Lh (Power Crawler)
Rueda Loca Del Lado Derecho (Power Crawler) / Idler Rh (Power Crawler)
Rueda Loca Del Lado Izquierdo (Power Crawler) / Idler Lh (Power Crawler)
Rodillo Guía Del Lado Derecho (Power Crawler) / Truck Roller Rh (Power Crawler)
Rodillo Guía Del Lado Izquierdo (Power Crawler) / Truck Roller Lh (Power Crawler)
Rueda Dentada Y Oruga (Power Crawler) / Sppocket And Crawler (Power Crawler)
Etiqueta 1 (Adelante) / Label 1 (Front)
Etiqueta 2 (Cabina Bastidor) / Label 2 (Cab Frame)
Etiqueta 3 (Posterior) / Label 3 (Rear)
Kit De Alternador (Alternador) [Opcion] / Alternator Kit (Alternator) [Option]
Alternador Kit 2(Cable Mazo De Cables)[Opcion] / Alternator Kit 2 (Wire Harness) [Option]
Alternador [Componente Piezas] [Opcion] / Alternator [Component Parts] [Option]
Adelante Control Remoto De Salida Hidraulica(Soporte/Tubo) [Opcion] / Front Remote Hydraulic Outlet (Holder/Pipe) [Option]
Adelante Control Remoto De Salida Hidraulica(1r Valvula) [Opcion] / Front Remote Hydraulic Outlet (1st Valve) [Option]
Adelante Control Remoto De Salida Hidraulica(2do Valvula) [Opcion] / Front Remote Hydraulic Outlet (2nd Valve) [Option]
Distribuidor De Servicios Externos (Fc) [Comp. Piezas] [Opcion] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Distribuidor De Servicios Externos (Scd) [Comp. Piezas] [Opcion] [Antiguo] / Auxiliary Control Valve (Scd) [Component Parts] [Option] [Old]
Distribuidor De Servicios Externos (Scd) [Comp. Piezas] [Opcion] [Nuevo] / Auxiliary Control Valve (Scd) [Component Parts] [Option] [New]
Adelante Control Remoto De Salida Hidraulica(Cubierta De La Valvula) [Opcion] / Front Remote Hydraulic Outlet (Valve Cover) [Option]
Adelante Control Remoto De Salida Hidraulica(Control Palanca) [Opcion] / Front Remote Hydraulic Outlet (Control Lever) [Option]
Adelante Control Remoto De Salida Hidraulica(1r Valvula Palanca De Control) [Opcion] / Front Remote Hyd. Outlet (1st Valve Control Lever) [Option]
Adelante Control Remoto De Salida Hidraulica(2do Valvula Palanca De Control) [Opcion] / Front Remote Hyd. Outlet (2nd Valve Control Lever) [Option]
Adelante Control Remoto De Salida Hidraulica (Cubierta) [Opcion] / Front Remote Hydraulic Outlet (Cover) [Option]
Carter / Oil Pan
Volante / Flywheel
Ventilador / Fan
Conmutador / Switch
Rele / Relay
Eje Tdf / Pto Shaft
Ventilador / Fender
