Kubota Tractor M8540DTHNBC Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M8540DTHNBC Tractor
Number of Pages: 736 Pages
Engine 200000 Crankcase
Engine 201000 Oil Pan
Engine 202000 Cylinder Head
Engine 203500 Valve And Rocker Arm
Engine 205000 Head Cover
Engine 208000 Transmission Box Gear Case
Engine 211000 Piston And Crankshaft
Engine 212000 Camshaft And Idle Gear
Engine 213000 Balancer Note 010 And 040 Note Order
Engine 215000 Flywheel
Engine 220002 Pump Case Pump Housing Note 225,227 And 240 Note Order
Engine 221000 Injection Pump
Engine 223002 Governor
Engine 224000 Fork Lever (Governor)
Engine 225000 Governor Adjusting Bolt
Engine 231002 Fuel Filter
Engine 240000 Nozzle Holder And Glow
Engine 260002 Thermostat Water Flange And Thermostat
Engine 261002 Water Pump
Engine 271002 Inlet Manifold
Engine 272000 Exhaust Manifold
Engine 272200 EGR Valve EGR Cooler EGR Valve
Engine 272300 EGR Cooler
Engine 272600 Turbocharger Turbo Charger
Engine 273002 Air Cleaner
Engine 273500 Air Cleaner Component Parts
Sound Absorber Old Muffler Old Chassis No. 88979 Not 080,090 And 150 S.No.
Engine 275003 Sound Absorber New Muffler New Chassis No. 88980 S.No. 88980 S.No.
Engine 280000 Oil Pipe (Turbo Charger)
Engine 280300 Oil Pipe (Mechanical Stopwatch) Oil Pipe (Mechanical
Engine 282000 Oil Cooler
Engine 295000 Engine Electrical Parts Engine Electrical Parts
Engine A01002 Hand Accelerator Lever
Engine A03002 Accelerator Pedal
Fuel System A11002 Fuel Tank
Fuel System A12002 Fuel Tank (Right Side) Fuel Tank Rh
Fuel System A13002 Fuel Tank (Left Side) Fuel Tank Lh
Fuel System A14102 Fuel Pipe 1 (Rear) EC Se Tur Fuel Pipe 1 (Rear)
Fuel System A14202 Fuel Pipe 2 (Front) Fuel Pipe 2 (Front)
Fuel System A15102 Separator
Fuel System A16101 Separator Component Parts Old Separator Component Parts Old Chassis
Fuel System A16102 Separator Component Parts New Separator Component Parts New Chassis
Cooling Water System A41002 Fan
Cooling Water System A42002 Water Pipe
Cooling Water System A43002 Radiator
Cooling Water System A45002 Reserve Tank Reserve
Electrical System A54002 Alternator
Electrical System A55002 Alternator Component Parts
Electrical System A56000 Starter
Electrical System A57000 Starter Component Parts
Electrical System A58003 Battery Old Battery Old Chassis No. 83891 S.No. 83891
Electrical System A58004 Battery New Battery New Chassis No. 83892 S.No. 83892
Electrical System B00100 Sensor (Engine) Sensor (Engine)
Electrical System B02000 Key Sensor (Front) Switch Sensor
Electrical System B03003 Key Sensor (Rear) EC Se Tur Switch Sensor
Electrical System B10502 Key (Dashboard) Switch (
Electrical System B11000 Key Switch
Electrical System B13002 Relay
Electrical System B14002 Dashboard Panel
Electrical System B32000 Head Light
Electrical System B32100 Exterior Lighting Component Parts Head Light
Electrical System B33902 Front Combination Headlight Front Combination
Electrical System B35000 Working Light Flashlight Working Light Beacon
Electrical System B36002 Rear Combination Headlight
Electrical System B36502 License Lamp
B37002 Trailer Socket Note 010,020 And Fig.No.B36502 Ref.No.010
Electrical System B41000 Indoor Room Light
Electrical System B42500 Radio Speaker Radio Speaker
Electrical System B43000 Washer Tank Washer Tank
Electrical System B44100 Front Wiper
Electrical System B50503 Electrical Cables (Motor) EC Se Tur Electrical
Electrical System B51003 Electrical Cables (Main) EC Se Tur Electrical
Electrical System B52000 Electrical Cables (Cabin) Electrical
Clutch Gear Clutch Transmission C11000 Clutch Housing
Clutch Gear Clutch Transmission C11100 Shuttle Valve Shuttle Valve
Clutch Gear Clutch Transmission C11300 Shuttle Transmission Box Shuttle Gear
Clutch Gear Clutch Transmission C12500 Shift Cover
Clutch Gear Clutch Transmission C14003 Transmission Box EC Se Tur Transmission
Clutch Gear Clutch Transmission C14202 Ventilation Hose (Ventilation Hose) Breather
Clutch Gear Clutch Transmission C15002 Gear Housing Rear Cover Se Tur Transmission
Clutch Gear Clutch Transmission C17000 Rear Axle Housing Rear Axle
Clutch Gear Clutch Transmission C22000 Damper Disc Damper Disc
Clutch Gear Clutch Transmission C24002 Clutch Pedal
Clutch Gear Clutch Transmission C26500 Valve Lever (Clutch) Valve Lever (
Clutch Gear Clutch Transmission D21500 Input Shaft
Clutch Gear Clutch Transmission D21600 Transmission Clutch Component Parts Shuttle
Clutch Gear Clutch Transmission D21700 Shuttle Shaft
Clutch Gear Clutch Transmission D22500 First Shaft
Clutch Gear Clutch Transmission D22700 Second Shaft
Clutch Gear Clutch Transmission D23500 Third Shaft
Clutch Gear Clutch Transmission D25600 Creep Shaft
Clutch Gear Clutch Transmission D26001 Bevel Gear Shaft EC Se Tur Bevel Gear
Clutch Gear Clutch Transmission D26200 Rear Differential Differential
Ion D26500 PTO Propeller Shaft
Clutch Gear Clutch Transmission D26601 PTO Clutch EC Se Tur PTO Clutch
Clutch Transmission D26701 PTO Clutch Component Parts Old PTO Clutch Component Parts Old
Transmission D26702 PTO Clutch Component Parts New PTO Clutch Component Parts New
Clutch Gear Clutch Transmission D26800 PTO Clutch Valve PTO Clutch
Clutch Gear Clutch Transmission D27500 PTO Shaft
Clutch Gear Clutch Transmission D35000 Front Drive Clutch Front Drive
Clutch Gear Clutch Transmission D35200 Front Drive Clutch Component Parts Front Drive
Clutch Gear Clutch Transmission D35500 Propeller Shaft (Rear) Front Propeller
Speed Change Shift Fork D41002 Main Transmission
Speed Change Shift Fork D44502 Gear And Crawl Range
Speed Change Shift Fork D47002 Differential Lock
Gear Speed Change Shift Fork F11002 Main Gear
Speed Change Shift Fork F11500 Main Transmission
Speed Change Shift Fork F12502 Transmission Shuttle
Gear Speed Change Shift Fork F13302
Speed Change Shift Fork F13502 Gear Range
Speed Change Shift Fork F15000 PTO Transmission
Rear Axle Brake F20000 Rear Axle
Rear Axle Brake F20602 Brake (Right Side) Brake Rh
Rear Axle Brake F20702 Brake (Left Side) Brake Lh
Rear Axle Brake F21102 Brake Rod (Brake Pedal) Brake Rod (Brake
Rear Axle Brake F21200 Brake Rod (Brake Drawing) Brake Rod (Brake
Rear Axle Brake F22002 Parking Brake Lever
Rear Axle Brake F23502 Brake Pedal
Rear Axle Brake F31502 Brake Master Cylinder Brake Master
Rear Axle Brake F32002 Brake Master Cylinder Component Parts Brake Master
Rear Axle Brake F33002 Brake Pipe Brake Pipe
Front Axle Chassis G10500 Front Axle Frame Front Axle
Front Axle Chassis G11000 Front Axle Body Bracket Front Axle
Front Axle Chassis G14000 Propeller Shaft Front Propeller
Front Axle Chassis G15002 Front Differential Housing Front
Front Axle Chassis G16000 Sloping Transmission (Front) Bevel Gear (
Front Axle Chassis G17000 Front Differential Differential
Front Axle Chassis G22100 Sloping Transmission Housing (Right Side) Bevel
Front Axle Chassis G22200 Sloping Transmission Housing (Left Side) Bevel
Front Axle Chassis G22300 Front Axle Housing (Right Side) Front Axle
Front Axle Chassis G22400 Front Axle Housing (Left Side) Front Axle
Front Axle Chassis G22800 Differential Transmission Shaft (Right Side) Differential
Front Axle Chassis G22900 Differential Transmission Shaft (Left Side) Differential
Front Axle Chassis G24100 Front Axle (Right Side) Front Axle
Front Axle Chassis G24200 Front Axle (Left Side) Front Axle
Steering H11002 Steering Handle
Steering H12000 Slip Pedal Tilt Pedal
Steering H13002 Steering Additional Steering Joint
Steering H14002 Steering Control Old Steering Controller Old Chassis No. 83737 S.No.
Steering H14003 Steering Control New Steering Controller New Chassis No. 83738 S.
H15002 Steering Control Component Parts Old Steering Controller Component Parts Old
Steering Control Component Parts Old Steering Controller Component Parts Old Chassis No.83738
H15004 Steering Control Component Parts New Steering Controller Component Parts New
Steering H16000 Rubber Tie Rod Steering Cylinder
H16501 Steering Cylinder Component Parts Old
H16502 Steering Cylinder Component Parts New
Hydraulic System J13000 Hydraulic Pump
Hydraulic System J13500 Hydraulic Pump
Hydraulic System J22000 Hydraulic Oil Line (Feed) Pipe
Hydraulic System J26502 Oil Cooler
Hydraulic System J27502 Hydraulic Pipe (Direction PTO) Hydraulic Oil Line (
Hydraulic System J27602 Hydraulic Pipe (Pto Shuttle) Hydraulic Oil Line
Hydraulic System J27900 Hydraulic Pipe (Pto Clutch Valve) Hydraulic Oil
Hydraulic System J28002 Steering Hose (Feed) Steering Hose
Hydraulic System J30800 Hydraulic Cylinder Housing Hydraulic
Hydraulic System J31500 Hydraulic Piston Lifting Arm Hydraulic
Hydraulic System J31700 Safety Valve Relief Valve Safety Valve
Hydraulic System J32302 Lowering Adjustment Valve Lowering Lock
Hydraulic System J35501 Control Valfi Old Control Valve Old Chassis No. 88979 S.
Hydraulic System J35502 Control Valve New Control Valve New Chassis No. 88980 S.
Hydraulic System J38002 Draft And Position Control Lever Draft And Position
And Draft Shaft Old Position And Draft Shaft Old Chassis No. 83439 Note Order Fig.No.J38204 Ref.No.030 And
Hydraulic System J38204 Position And Draft Shaft New Position And Draft Shaft New Chassis No.
Hydraulic System J39200 Feed Back Lever
Hydraulic System J44508 Remote Control Valve Se Tur Old Auxiliary Control Valve Se Tur Old
Hydraulic System J44509 Remote Control Valve Se Tur New Auxiliary Control Valve Se Tur New
J44705 Remote Control Valve (FD) Component Parts Old Auxiliary Control Valve (FD) Component
J44706 Remote Control Valve (SCD) Component Parts New Auxiliary Control Valve (SCD) Component
System J44900 Current Priority Valve Component Parts Old
I Flow Priority Valve Component Parts
Hydraulic System J45402 Support Control Valve Lever (First) Auxiliary Control
Hydraulic System J45502 Support Control Valve Lever (Second) Auxiliary Control
Left Lift Support Cylinder Se Tur Old 3p-Lift Assist Cylinder Lh Se Tur Old Chassis No. 86771 Note
System J47108 3p-Left Lift Assist Cylinder Se Tur New 3p-Lift Assist Cylinder Lh Se Tur New
Right Lift Assist Cylinder Se Tur Old 3p-Lift Assist Cylinder Rh Se Tur Old Chassis No. 86771 Note
System J47208 3p-Right Lift Support Cylinder Se Tur New 3p-Lift Assist Cylinder Rh Se Tur New
System J47301 3p-Lift Support Cylinder Component Parts Old 3p-Lift Assist Cylinder Component
System J47302 3p-Lift Support Cylinder Component Parts New 3p-Lift Assist Cylinder Component
Hydraulic System J47502 Ventilation Hose (3 Point Cylinder) Breather
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K10500 Upper Link Bracket
Bar Connection 3-Point Linkage Drawbar Hitch K11001 3 Point Tie (Upper Tie) Old Top Link Old
3-Point Linkage Drawbar Hitch K11002 3 Point Tie (Upper Tie) Old Top Link Old Chassis No.87599
Bar Connection 3-Point Linkage Drawbar Hitch K11003 3 Point Tie (Upper Tie) New Top Link New
Bar Connection 3-Point Linkage Drawbar Hitch K12503 Alt Bağ Se Tur Old Lower Link Se Tur Old
Bar Connection 3-Point Linkage Drawbar Hitch K12504 Lower Link Se Tur New Lower Link Se Tur New
Drawbar Hitch K13306 Stabilizer Se Tur Old Stabilizer Se Tur Old Chassis No. 83555 Note Order
3-Point Linkage Drawbar Hitch K13307 Stabilizer Se Tur Old Stabilizer Se Tur Old Chassis No.
Link 3-Point Linkage Drawbar Hitch K13308 Stabilizer Se Tur New Stabilizer Se Tur New
Drawing Bar Link 3-Point Linkage Drawbar Hitch K14001 Right Drawing Shaft Old Lift Rod Rh Old Chassis
Drawing Bar Link 3-Point Linkage Drawbar Hitch K14002 Right Drawing Shaft New Lift Rod Rh New Chassis
Drawing Bar Link 3-Point Linkage Drawbar Hitch K14301 Left Drawing Shaft Old Lift Rod Lh Old Chassis
Drawing Bar Link 3-Point Linkage Drawbar Hitch K14302 Left Pulling Shaft New Lift Rod Lh New Chassis
3-Point Linkage Drawbar Hitch L10500 Drawing Bar Bracket Se Tur Drawbar Bracket Se Tur Note
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L17002 PTO Protection Se Tur Pto
Hood Bone M11002 Front Grille
Kaput Bone Hood Bonnet M12002 Hood (Bonnet) Upper
Hood Bone M12302 Hood (Bonnet) Damper
Kaput Bone Hood Bonnet M12400 Bone Lock Bonnet Lock
Hood Bone M12702 Bone Side Cover Hood (Bonnet) Side Cover
Bonnet Bone Hood Bonnet M14002 Bone Support Bonnet Support
Cab N11001 Cab Frame EC Se Tur Cab Frame EC Se Tur
Cab N11700 Cover (Bonnet) Rear Hood (Bonnet) Rear
Cab N12000 Windshield Front Glass
Cab N12500 Door (Right Side) Door Rh
Cab N13000 Door (Left Side) Door Lh
Cab N13500 Door Lock (Right Side) Door Lock Rh
Cab N14000 Door Lock (Left Side) Door Lock Lh
Cab N14600 Side Window (Right Side) Side Window Rh
Cab N14700 Side Window (Left Side) Side Window Lh
Cab N15001 Rear Window Old Rear Window (Upper) Old Chassis No. 84550 S.No. 84550
Cab N15002 Rear Window New Rear Window (Upper) New Chassis No. 84551 S.No. 84551
Cab N15801 Rearview Mirror Old Rearview Mirror Old Chassis No. 83795 S.No. 83795 S.
Cabin Cab N15802 Rearview Mirror New Rearview Mirror New Chassis No. 83796 S.No. 83796 S.
Cab N16000 Inner Ceiling Inner Roof
Cab N16500 Outer Ceiling Outer Roof
Cab N17500 Floor Mat
Cab N18000 Inspection Plate
N21000 Fender Cover (Right Side) Fender Cover Rh Note 030,125 And 130 Note
Cab N21500 Fender Cover (Left Side) Fender Cover Lh
Cab N22400 Fender
Cab N24000 Cab Bracket Front
Cab N24500 Cab Bracket Rear
Cabin Cab N25000 Tool Box
Air Conditioner P11500 Air Conditioner
Air Conditioner P14000 Air Conditioner Tube Air Conditioner Duct
Air Conditioner P15000 Heater Hose
Air Conditioner P15500 Condenser
Air Conditioner P15700 Air Conditioner Hose Condenser Hose
Air Conditioner P16000 Compressor
Air Conditioner P16500 Compressor Bracket Compressor Bracket
Air Conditioner P17500 Drain Hose
Labels S12002 Label (Front)
Labels S13002 Label (Panel) Label (Panel)
Labels S14003 Label (Back) EC Se Tur Label (Rear) EC Se Tur
Accessories Service Part Accessories T11002 Accessories Service Part Accessories And
Option U11002 Alternator Kit 1 (Alternator) Option Alternator Kit 1 (
Option U11100 Alternator Kit 2 (Wire Harness) Option Alternator Kit 2 (Wire
Option U11300 Alternator Kit Component Parts Option Alternator Component
Option U68002 Front Support Control Valve Kit (Holder Tube) Option Front Remote Hydraulic
Option U68300 Front Support Control Valve Kit (First Valve) Option Front Remote Hydraulic
Option U68400 Front Support
Single Control Valve Kit (Second Valve) Option Front Remote Hydraulic
Option U68500 Front Support Control Valve Kit (FC) Component Parts Option Auxiliary Control
Control Valve Kit (SCD) Component Parts Option Old Auxiliary Control Valve (SCD) Component Parts
Control Valve Kit (SCD) Component Parts Option New Auxiliary Control Valve (SCD) Component Parts
Option U68700 Front Support Control Valve Kit (Valve Cover) Option Front Remote Hydraulic
Option U68802 Front Support Control Valve Kit (Control Lever) Option Front Remote Hydraulic
Option U69002 Front Support Control Valve Kit (First Valve Control Lever) Option Front Remote Hydraulic
Option U69202 Front Support Control Valve Kit (Second Valve Control Lever) Option Front Remote Hydraulic
Option U69502 Front Support Control Valve Kit (Housing Bracket) Option Front Remote Hydraulic
Trailer Brake Valve Kit 1 (Valve Pipe) Option Old Trailer Brake Valve Kit 1 (Valve Pipe) Option Old
Trailer Brake Valve Kit 1 (Valve Pipe) Option New Trailer Brake Valve Kit 1 (Valve Pipe) Option New
Option U75102 Trailer Brake Valve Kit 2 (Pipe) Option Trailer Brake Valve Kit
U87502 Draw Bar Bracket Kit Se Tur Option Old Drawbar Bracket Kit Se Tur Option Old Chassis
U88800 PTO Shaft Protector Kit Se Tur Option Old PTO Shaft Protector Kit Se Tur Option Old
Region: Turkey
Cab N22400 Fender
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
