Kubota Tractor M8540DTHNBC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M8540DTHNBC Tractor
Number of Pages: 426 Pages
Itens Uso Frequent E / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Tampa Cabeça / Head Cover
Carreto / Gear Case
Arvore Cames E Veio / Camshaft And Idle G Ear Shaft
Compensador / Balancer
Volante Motor / Flywheel
Caixa Da Bomba / Pump Housing
Alavanca Do Garfo (Governador) / Fork Lev Er (Governor)
Parafuso De Ajuste De Governador / Govern Or Adjusting Bolt
Filtro Gasoleo / Fuel Filter
Valvula Solenoide / Nozzle Holder And Glo W Plug
Bomba Agua E Termostacto / Water Flange A Nd Thermostat
Bomba Agua / Water Pump
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Clean Er [Component Parts]
Escpae / Muffler [Old]
Escpae / Muffler [New]
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charg Er)
Tubo Oleo (Temporizador Mecanico) / Oil P Ipe (Mechanical Timer)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor / Engine Ele Ctrical Parts
Deposito Combustivel / Fu El Tank
Deposito Combustivel (Drt ) / Fuel Tank Rh
Deposito Combustivel (Esq ) / Fuel Tank Lh
Tubo Combustivel / Fuel P Ipe 1 (Rear) [Ec] [Se] [Tur]
Tubo Combustivel / Fuel P Ipe 2 (Front)
Separador / Separator
Separador[Peças Component Es] / Separator [Component Parts] [Old]
Separador[Peças Component Es] / Separator [Component Parts] [New]
Ventoin Ha / Fan
Tubo Ag Ua / Water Pipe
Radiado R / Radiator
Deposit O Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componen Tes] / Starter [Component Parts]
Bateria / Battery [New]
Interruptor/Sensor (Bloc O Motor) / Sensor (Engine)
Interruptor/Sensor / Swi Tch/Sensor (Front)
Interruptor/Sensor / Swi Tch/Sensor (Rear) [Ec] [Se] [Tur]
Interruptor / Switch (Pa Nel)
Rele / Relay
Painel / Panel
Farol Dianteiro / Head L Ight
Farol Frente[Peças Compo Nentes] / Head Light [Component Parts]
Luzes Frontais / Front C Ombination Light
Luzes Trabalho / Working Light/Beacon Light
Braco Traseiro / Rear Co Mbination Lamp
Farol Matricula / Licens E Lamp
Luz Interior / Room Ligh T
Alta Voz Radio / Radio S Peaker
Deposito Limpa Parabris As / Washer Tank
Escova Limpa Vidro Front Al / Front Wiper
Electrical Wiring (Engin E) [Ec] [Se] [Tur] / Electrical Wiring (Engine) [Ec ] [Se] [Tur]
Cablagem Electrica / Ele Ctrical Wiring (Main) [Ec] [Se] [Tur]
Cabalagem Eletrica(Cabin E)[Ec] [G] / Electrical Wiring (Cab)
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cov Er
Caixa Velocidades / Transmission Case [Ec] [Se] [Tur]
Mangueira De Resp Iro (Caixa Velocidades) / Breather Hose (Transmissi On Case)
Carter Transmissa O / Transmission Case Rear Cover [Se] [Tur]
Carter Eixo / Rea R Axle Case
Disco Amortecedor / Damper Disk
Valvula (Inversor ) / Valve Lever (Clutch)
Veio Primario / I Nput Shaft
Embraiagem Invers Or [Peças Componentes] / Shuttle Clutch [Component Parts]
Veio Inversor / S Huttle Shaft
Primeiro Veio / F Irst Shaft
Terceiro Veio / T Hird Shaft
Veio Creeper / Cr Eep Shaft
Grupo Conico / Be Vel Gear [Ec] [Se] [Tur]
Diferencial Carte R / Differential Rear
Veio Tdf / Pto Pr Opeller Shaft
Embraiagem Tdf / Pto Clutch [Ec] [Se] [Tur]
Embraiagem Tdf[Pe Ças Componentes] / Pto Clutch [Component Parts] [Ol D]
Embraiagem Tdf[Pe Ças Componentes] / Pto Clutch [Component Parts] [Ne W]
Valvula Embraiage M Tdf / Pto Clutch Valve
Veio Tdf / Pto Sh Aft
Embraiagem Andame Nto / Front Drive Clutch
Veio Embraiagem[P Eças Componentes] / Front Drive Clutch [Component Parts]
Veio Primario (Tr Aseira) / Front Propeller Shaft (Rear)
Forque Ta / Main Gear Shift Fork
Gama E Garfo Caixa Creep / Range And Creep Gear Shift For K
Alavan Ca / Rear Differential Lock Shift Fork
Alavan Ca Velocidades / Main Gear Shift Lever
Tirant E / Main Gear Shift Rod
Alvanc A Inversor / Shuttle Shift Lever
Cabo I Nversor / Shuttle Cable
Alavan Ca Velocidades / Range Gear Shift Lever
Alavan Ca Tdf / Pto Gear Shift Lever
Eixo Traseiro / Rear A Xle
Travao(Drt) / Brake Rh
Travao(Esq) / Brake Lh
Tirante Travao / Brake Rod (Brake Pedal)
Tirante Travao 2 / Bra Ke Rod (Brake Cam)
Pedal Travao / Brake P Edal
Cilindro Travao Princi Pal / Brake Master Cylinder
Cilindro Travao Princi Pal[Peças Componentes] / Brake Master Cylinder [Com Ponent Parts]
Tubo Travao / Brake Pi Pe
Suporte Eixo Diante Iro / Front Axle Bracket
Veio Frontal / Fron T Propeller Shaft
Caixa Diferencial D Ianteiro / Front Differential Case
Engrenagem Cónica ( Dianteira) / Bevel Gear (Front)
Diferencial Diantei Ro / Differential Front
Caixas Engrenagens Conica(Drt) / Bevel Gear Case Rh
Caixas Engrenagens Conica(Esq) / Bevel Gear Case Lh
Carter Eixo Frente( Drt) / Front Axle Case Rh
Carter Eixo Frente( Esq) / Front Axle Case Lh
Carreto Diferencial (Drt) / Differential Gear Shaft Rh
Carreto Diferencial (Esq) / Differential Gear Shaft Lh
Eixo Frente (Drt) / Front Axle Rh
Eixo Dianteiro / Fr Ont Axle Lh
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção(Nova) / Steering Con Troller [Old]
Distribuidor Direcção(Nova) / Steering Con Troller [New]
Distribuidor Direcção[Peças Componentes] / Steering Controller [Component Parts] [Old]
Distribuidor Direcção[Peças Componentes] / Steering Controller [Component Parts] [New]
Direcção Assistida / Tie Rod/Steering Cyli Nder
Cilindro Direccao [Peças Componentes(Antig A) / Steering Cylinder [Component Parts] [Old]
Cilindro Direccao [Peças Componentes(Nova) / Steering Cylinder [Component Parts] [New]
Bomba Hidraulico / Hydra Ulic Pump
Bomba Hidraulico[Peças C Omponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo / Hydraulic Pi Pe (Delivery)
Radiador Oleo / Oil Cool Er
Circuito Oleo Direcção / Hydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Pto)
Tubo Oleo (Valvula Embra Iagem Tdf) / Hydraulic Oil Line (Pto Clutch Valve)
Tubo Direccao / Steering Hose (Delivery)
Caixa Hidraulico / Hydra Ulic Cylinder Case
Braço De Elevação Hidráu Lico / Hydraulic Lift Arm
Valvula Segurança / Safe Ty Valve/Relief Valve
Trinco / Lowering Lock L Ever
Valvula Control / Contro L Valve [Old]
Valvula Control / Contro L Valve [New]
Alavanca Control Esforço / Draft And Position Control Lever
Veio Posicao Esforço / P Osition And Draft Shaft [Old]
Veio Posicao Esforço / P Osition And Draft Shaft [New]
Alavanca / Feed Back Lev Er
Distribuidor Auxiliar / Auxiliary Control Valve [Se] [Tur] [Old]
Distribuidor Auxiliar / Auxiliary Control Valve [Se] [Tur] [New]
Valvula Auxiliar [Peças Componentes] / Auxiliary Control Valve (Fd) [Compon Ent Parts] [Old]
Valvula Auxiliar [Peças Componentes] / Auxiliary Control Valve (Scd) [Compo Nent Parts] [New]
Flow Priority Valve [Com Ponent Parts] [Old] / Flow Priority Valve [Componen T Parts] [Old]
Alavanca Valvula Auxilia R / Auxiliary Control Valve Lever (1st)
Alavanca Valvula Auxilia R 1 Pos / Auxiliary Control Valve Lever (2nd)
Cilindro Auxiliar De Ele Vação Esq (Cab) (Antigo) / 3p-Lift Assist Cylinder Lh [Se] [Tur] [Old]
Clindro Auxiliar De Elev Ação Esq (Cab) (Novo) / 3p-Lift Assist Cylinder Lh [Se] [Tur] [New]
Cilindro Auxiliar De Ele Vação Drt (Cab) Antigo / 3p-Lift Assist Cylinder Rh [Se] [Tur] [Old]
Cilindro Auxiliar De Ele Vação Drt (Cab) Novo / 3p-Lift Assist Cylinder Rh [ Se] [Tur] [New]
Cilindro Auxiliar De Ele Vacao[Peças Componentes] / 3p-Lift Assist Cylinder [Component Parts] [Old]
Cilindro Auxiliar De Ele Vacao[Peças Componentes] / 3p-Lift Assist Cylinder [Component Parts] [New]
Mangueira De Respiro (3p Cilindro) / Breather Hose (3p Cylinder)
Par Te Superior / Top Link Bracket
3-P Ont Acoplamento (Ligacao Superior) / Top Link [Old]
3-P Ont Acoplamento (Ligacao Superior) / Top Link [New]
Lig Acao Inferior / Lower Link [Se] [Tur] [Old]
Lig Acao Inferior / Lower Link [Se] [Tur] [New]
Est Abilizador / Stabilizer [Se] [Tur] [Old]
Est Abilizador / Stabilizer [Se] [Tur] [New]
Est Abilizador(Drt) / Lift Rod Rh [Old]
Est Abilizador(Esq) / Lift Rod Lh [Old]
Est Abilizador(Esq) / Lift Rod Lh [New]
Bar Ra / Drawbar Bracket [Se] [Tur]
Pro Teccao Tdf / Pto Shaft Protector [Se] [Tur]
Grelha Frontal / Front Grille
Trico Capot / Bonnet Lock
Estrutura Cabine / Cab Frame [Ec] [Se] [Tur]
Vidro Frente E Traseiro / Front Glass
Porta(Drt) / Door Rh
Porta(Esq) / Door Lh
Trinco Porta(Drt) / Door Lock Rh
Trinco Porta(Esq) / Door Lock Lh
Lado Vidro (Drt) / Side Window Rh
Lado Vidro (Esq) / Side Window Lh
Vidro Traseiro / Rear Window (Upper) [Old]
Vidro Traseiro / Rear Window (Upper) [New]
Espelho Rectrovisor / Rearview Mirror [Old]
Espelho Rectrovisor / Rearview Mirror [New]
Tecto Interior / Inner Roof
Tejadilho Exterior / Outer Roof
Piso / Floor Mat
Cobertura Guarda Lamas(Drt) / Fender Cover Rh
Cobertura Gurada Lamas(Esq) / Fender Cover Lh
Guarda Lamas / Fender
Suporte Cabine(Dianteiro) / Cab Bracket Front
Caixa Ferramenta / Tool Box
Air Condicionado / Air Cond Itioner
Tubo Ar Condicionado / Air Conditioner Duct
Tubo Aquecimento / Heater H Ose
Condesador / Condenser
Tubo Ar Condicionado/Tubo C Ondensador / Air Conditioner Hose/Condenser Hose
Compressor / Compressor
Suporte Compressor / Compre Ssor Bracket
Mangueira De Drenagem / Dra In Hose
Etiqueta 1 / Label (Front)
Etiqueta 2 / Label (Panel)
Etiqueta 3 / Label (Rear) [Ec] [Se] [Tur]
Acessorios / Accessories And Service Parts
Kit Alternador [Opçao] / Alternator Kit 1 (Alte Rnator) [Option]
Alternador [Peças Componentes] [Opcao] / Altern Ator [Component Parts] [Option]
Saída Hidráulica Remota Dianteira (Fixador/Tubo ) [Opção] / Front Remote Hydraulic Outlet (Holder/P Ipe) [Option]
Saída Hidráulica Remota Dianteira (1ª Válvula) [Opção] / Front Remote Hydraulic Outlet (1st Valve) [Option]
Saída Hidráulica Remota Dianteira (2ª Válvula) [Opção] / Front Remote Hydraulic Outlet (2nd Valve) [Option]
Kit Distribuidor Serviços Externos[Peças Compon Entes][Opcao] / Auxiliary Control Valve (Fc) [Compo Nent Parts] [Option]
Válvula De Controlo Auxiliar (Scd) [Peças Compo Nentes] [Opção] / Auxiliary Control Valve (Scd) [Co Mponent Parts] [Option] [Old]
Válvula De Controlo Auxiliar (Scd) [Peças Compo Nentes] [Opção] / Auxiliary Control Valve (Scd) [Co Mponent Parts] [Option] [New]
Saída Hidráulica Remota Dianteira (Tampa Da Vál Vula) [Opção] / Front Remote Hydraulic Outlet (Valv E Cover) [Option]
Saída Hidráulica Remota Dianteira (Alavanca De Controlo) [Opção] / Front Remote Hydraulic Outlet ( Control Lever) [Option]
Saída Hid. Remota Dianteira (1ª Válvula Alavanc A De Controlo) [Opção] / Front Remote Hydraulic Out Let (1st Valve Control Lever) [Option]
Saída Hidráulica Remota Dianteira (2ª Válvula A Lavanca De Controlo) [Opção] / Front Remote Hydraul Ic Outlet (2nd Valve Control Lever) [Option]
Saída Hidráulica Remota Dianteira (Suporte De P Rotecção) [Opção] / Front Remote Hydraulic Outlet ( Guard Bracket) [Option]
Kit Valvula Travao Reboque 1[Peças Componentes] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Option] [New]
Kit Valvula Travao Reboque 2[Peças Componentes] / Trailer Brake Valve Kit 2 (Pipe) [Option]
Drawbar Bracket Kit [Se] [Tur] [Option] [Old] / Drawbar Bracket Kit [Se] [Tur] [Option] [Old]
Veio Tdf Kit[Opção] / Pto Shaft Protector Kit [ Se] [Tur] [Option] [Old]
Carreto / Gear Case
Ventoin Ha / Fan
Rele / Relay
Painel / Panel
Piso / Floor Mat
