118
6,911
Kubota Tractor M8540DTHNB Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M8540DTHNB Tractor
Number of Pages: 661 Pages
Engine 200000 Crankcase
Engine 201000 Oil Pan
Engine 202000 Cylinder Head
Engine 203500 Valve And Rocker Arm
Engine 205000 Head Cover
Engine 208000 Transmission Box Gear Case
Engine 211000 Piston And Crankshaft
Engine 212000 Camshaft And Idle Gear
Engine 213000 Balancer Note 010 And 040 Note Order By
Engine 215000 Flywheel
Engine 220001 Pump Case Pump Housing Note 225,227 And 240 Note Order
Engine 221000 Injection Pump
Engine 223001 Governor
Engine 224000 Fork Lever (Governor)
Engine 225000 Governor Adjusting Bolt
Engine 231001 Fuel Filter
Engine 240000 Nozzle Holder And Glow
Engine 260001 Thermostat Water Flange And Thermostat
Engine 261001 Water Pump
Engine 271001 Inlet Manifold
Engine 272000 Exhaust Manifold
Engine 272200 EGR Valve EGR Cooler EGR Valve
Engine 272300 EGR Cooler
Engine 272600 Turbocharge Turbo Charger
Engine 273001 Air Cleaner
Engine 273500 Air Cleaner Component Parts
Engine 275001 Muffler
Engine 280000 Oil Pipe (Turbo Charger)
Engine 280300 Oil Pipe (Mechanical Stopwatch) Oil Pipe (Mechanical
Engine 282000 Oil Cooler
Engine 295000 Engine Electrical Parts Engine Electrical Parts
Engine A01001 Hand Accelerator Lever
Engine A03001 Accelerator Pedal
Fuel System A11001 Fuel Tank
Fuel System A12001 Fuel Tank (Right Side) Fuel Tank Rh
A13001 Fuel Tank (Left Side) Fuel Tank Lh Note 010 And Fig.No.A14101 Ref.No.080
Fuel System A14101 Fuel Pipe 1 (Rear) Fuel Pipe 1 (Rear)
Fuel System A14201 Fuel Pipe 2 (Front) Fuel Pipe 2 (Front)
Fuel System A15101 Separator
Fuel System A16101 Separator Component Parts Old Separator Component Parts Old Chassis No.
Fuel System A16102 Separator Component Parts New Chassis No.
Cooling Water System A41001 Fan
Cooling Water System A42001 Water Pipe
Cooling Water System A43001 Radiator
Cooling Water System A45001 Reserve Tank Reserve
Electrical System A54001 Alternator
Electrical System A55001 Alternator Component Parts
Electrical System A56000 Starter
Electrical System A57000 Starter Component Parts
Electrical System A58001 Battery Old Battery Old Chassis No. 83891 S.No. 83891
Electrical System A58002 Battery New Battery New Chassis No. 83892 S.No. 83892
Electrical System B00100 Sensor (Engine) Sensor (Engine)
Electrical System B02000 Switch Sensor (Front) (
Electrical System B03001 Switch Sensor (Rear) EC Se Tur Switch Sensor
(Dashboard) Switch (Panel) Note 030 New Part And Fig.No.M15500 Ref.No.100 Optional
Electrical System B13001 Relay
Electrical System B14001 Dashboard Panel
Electrical System B32000 Head Light
Electrical System B32100 Outdoor Lighting Component Parts Head Light
Electrical System B33901 Front Combined Headlight Front Combination
Electrical System B36001 Rear Combination Headlight
Electrical System B36501 License Lamp
Electrical System B37001 Trailer Socket
Tur Electrical Wiring (Front) EC Se Tur Note 010 And Fig.No.A11001-110,B03001-160,170,B13001-
Tur Electrical Wiring (Rear) EC Se Tur Note 010 And Fig.No.A11001-110,B03001-160,170,
Clutch Gear Clutch Transmission C11000 Clutch Housing
Clutch Gear Clutch Transmission C11100 Shuttle Valve Shuttle Valve
Clutch Gear Clutch Transmission C11300 Shuttle Transmission Box Shuttle Gear
Clutch Gear Clutch Transmission C12500 Shift Cover
Clutch Gear Clutch Transmission C14001 Transmission Box EC Se Tur Transmission
Clutch Gear Clutch Transmission C14201 Ventilation Hose (Ventilation Hose) Breather
Clutch Gear Clutch Transmission C15002 Gear Housing Back Cover Se Tur Transmission
Clutch Gear Clutch Transmission C17000 Rear Axle Housing Rear Axle
Clutch Gear Clutch Transmission C22000 Damper Disc Damper Disc
Clutch Gear Clutch Transmission C24001 Clutch Pedal
Clutch Gear Clutch Transmission C26500 Valve Lever (
Clutch Gear Clutch Transmission D21500 Input Shaft
Clutch Gear Clutch Transmission D21600 Transmission Clutch Component Parts Shuttle
Clutch Gear Clutch Transmission D21700 Shuttle Shaft
Clutch Gear Clutch Transmission D22500 First Shaft
Clutch Gear Clutch Transmission D22700 Second Shaft
Clutch Gear Clutch Transmission D23500 Third Shaft
Clutch Gear Clutch Transmission D25600 Creep Shaft
Clutch Gear Clutch Transmission D26001 Bevel Gear Shaft EC Se Tur Bevel Gear
Clutch Gear Clutch Transmission D26200 Rear Differential Differential
Clutch Gear Clutch Transmission D26500 PTO Propeller Shaft
Clutch Gear Clutch Transmission D26601 PTO Clutch EC Se Tur PTO Clutch
Transmission D26701 PTO Clutch Component Parts Old PTO Clutch Component Parts Old
Transmission D26702 PTO Clutch Component Parts New PTO Clutch Component Parts New
Clutch Gear Clutch Transmission D26800 PTO Clutch Valve PTO Clutch
Clutch Gear Clutch Transmission D27500 PTO Shaft
Clutch Gear Clutch Transmission D35000 Front Drive Clutch Front Drive
Clutch Gear Clutch Transmission D35200 Front Drive Clutch Component Parts Front Drive
Clutch Gear Clutch Transmission D35500 Propeller Shaft (Rear) Front Propeller
Speed Change Shift Fork D41001 Main Transmission
Speed Change Shift Fork D44501 Gear And Creep Range
Speed Change Shift Fork D47001 Differential Lock Transmission
Gear Speed Change Shift Fork F11001 Main Gear
Gear Speed Change Shift Fork F11600 Main Transmission
Speed Change Shift Fork F12501 Transmission Shuttle
Gear Speed Change Shift Fork F13301 Shuttle
Speed Change Shift Fork F13501 Gear Range
Speed Change Shift Fork F15000 PTO Transmission
Rear Axle Brake F18000 Rear Differential Lock Pedal Rear Differential
Rear Axle Brake F20000 Rear Axle
Rear Axle Brake F20601 Brake (Right Side) Brake Rh
Rear Axle Brake F20701 Brake (Left Side) Brake Lh
Rear Axle Brake F21101 Brake Rod (Brake Pedal)
Rear Axle Brake F22001 Parking Brake Lever
Rear Axle Brake F23501 Brake Pedal
Rear Axle Brake F31501 Brake Master Cylinder Brake Master Cylinder
Rear Axle Brake F32001 Brake Master Cylinder Component Parts Brake Master
Rear Axle Brake F33001 Brake Pipe Brake Pipe
Rear Axle Brake F33500 Brake Master Cylinder Pipe Brake Master
Front Axle Chassis G10500 Front Axle Frame Front Axle
Front Axle Chassis G11000 Front Axle Body Bracket Front Axle
Front Axle Chassis G14000 Propeller Shaft Front Propeller
Front Axle Chassis G15001 Front Differential Housing Front Differential
Front Axle Chassis G16000 Sloping Transmission (Front) Bevel Gear (
Front Axle Chassis G17000 Front Differential Differential
Front Axle Chassis G22100 Sloping Transmission Housing (Right Side) Bevel
Front Axle Chassis G22200 Sloping Transmission Housing (Left Side) Bevel
Front Axle Chassis G22300 Front Axle Housing (Right Side) Front Axle
Front Axle Chassis G22400 Front Axle Housing (Left Side) Front Axle
Front Axle Chassis G22800 Differential Transmission Shaft (Right Side) Differential
Front Axle Chassis G22900 Differential Transmission Shaft (Left Side) Differential
Front Axle Chassis G24100 Front Axle (Right Side) Front Axle
Front Axle Chassis G24200 Front Axle (Left Side) Front Axle
Steering H11001 Steering Handle
Steering H12300 Tilt Lever
Steering H13001 Steering Joint Steering Joint
Steering H14001 Steering Control Steering Controller
Steering H15001 Steering Control Component Parts Steering Controller
Steering H16000 Steering Cylinder Tie Rod Steering
H16501 Steering Cylinder Component Parts Old Steering Cylinder Component Parts Old
H16502 Steering Cylinder Component Parts New Steering Cylinder Component Parts New
Hydraulic System J13000 Hydraulic Pump
Hydraulic System J13500 Hydraulic Pump
Hydraulic System J22000 Hydraulic Oil Line (Feed) Pipe
Hydraulic System J26501 Oil Cooler
Hydraulic System J27501 Hydraulic Pipe (Direction PTO) Hydraulic Oil Line (
Hydraulic System J27601 Hydraulic Pipe (Shuttle PTO) Hydraulic Oil Line
Hydraulic System J27900 Hydraulic Pipe (Pto Clutch Valve) Hydraulic Oil Line
Hydraulic System J28001 Steering Hose (Feed) Steering Hose
Hydraulic System J30800 Hydraulic Cylinder Housing Hydraulic
Hydraulic System J31500 Hydraulic Piston Lifting Arm Hydraulic
Hydraulic System J31700 Safety Valve Relief Valve Safety Valve
Hydraulic System J32301 Lowering Adjustment Valve Lowering Lock
Hydraulic System J35501 Control Valve Old Control Valve Old Chassis No. 88979 S.No.
Hydraulic System J35502 Control Valve New Control Valve New Chassis No. 88980 S.No.
Hydraulic System J38001 Draft And Position Control Lever Draft And Position
And Draft Shaft Old Position And Draft Shaft Old Chassis No. 83439 Note Order Fig.No.J38202 Ref.No.030 And
Hydraulic System J38202 Position And Draft Shaft New Chassis No.
Hydraulic System J39200 Feed Back Lever
Hydraulic System J44504 Remote Control Valve Se Tur Old Auxiliary Control Valve Se Tur Old
Hydraulic System J44505 Remote Control Valve Se Tur New Auxiliary Control Valve Se Tur New
J44701 Remote Control Valve (FD) Component Parts Old Auxiliary Control Valve (FD) Component Parts Old Auxiliary Control Valve (FD) Component Parts Old
J44703 Remote Control Valve (SCD) Component Parts New Auxiliary Control Valve (SCD) Component
Hydraulic System J44704 Remote Control Valve (S D) Component Parts Auxiliary Control
System J44900 Flow Priority Valve Component Parts Old Flow Priority Valve Component Parts
Hydraulic System J45401 Support Control Valve Lever (First) Auxiliary Control
Hydraulic System J45501 Support Control Valve Lever (Second) Auxiliary Control
Lift Support Cylinder Se Tur Old 3p-Lift Assist Cylinder Lh Se Tur Old Chassis No. 86771 Note
System J47104 3p-Left Taking Assist Cylinder Se Tur New 3p-Lift Assist Cylinder Lh Se Tur New
Taking Assist Cylinder Se Tur Old 3p-Lift Assist Cylinder Rh Se Tur Old Chassis No. 86771 Note
System J47204 3p-Right Taking Assist Cylinder Se Tur New 3p-Lift Assist Cylinder Rh Se Tur New
System J47301 3p-Taking Assist Cylinder Component Parts Old 3p-Lift Assist Cylinder Component Parts
System J47302 3p-Lift Assist Cylinder Component Parts
Hydraulic System J47501 Ventilation Hose (3 Point Cylinder) Breather
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K10500 Top Link Bracket
Bar Connection 3-Point Linkage Drawbar Hitch K11001 3 Point Tie (Upper Tie) Old Top Link Old Chassis
3-Point Linkage Drawbar Hitch K11002 3 Point Tie (Upper Tie) Old Top Link Chassis No.87599 To
Bar Connection 3-Point Linkage Drawbar Hitch K11003 3 Point Tie (Upper Tie) New Top Link New Chassis
Link 3-Point Linkage Drawbar Hitch K12503 Alt Bağ Se Tur Old Lower Link Se Tur Old
Connection 3-Point Linkage Drawbar Hitch K12504 Alt Bağ Se Tur New Lower Link Se Tur New
Drawbar Hitch K13306 Stabilizer Se Tur Old Stabilizer Se Tur Old Chassis No. 83555 Note Order
3-Point Linkage Drawbar Hitch K13307 Stabilizer Se Tur Old Stabilizer Se Tur Old Chassis No.83556
Linkage 3-Point Linkage Drawbar Hitch K13308 Stabilizer Se Tur New Stabilizer Se Tur New
Drawing Bar Linkage 3-Point Linkage Drawbar Hitch K14001 Right Drawing Shaft Old Lift Rod Rh Old Chassis
Drawing Bar Linkage 3-Point Linkage Drawbar Hitch K14002 Right Drawing Shaft New Lift Rod Rh New Chassis
Drawing Bar Linkage 3-Point Linkage Drawbar Hitch K14301 Left Draw Shaft Old Lift Rod Lh Old Chassis
Drawing Bar Connection 3-Point Linkage Drawbar Hitch K14302 Left Draw Shaft New Lift Rod Lh New Chassis
3-Point Linkage Drawbar Hitch L10500 Drawing Bar Bracket Se Tur Drawbar Bracket Se Tur Note Order
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L17002 PTO Protection Se Tur Pto
Hood Bone M11001 Front Grille
Hood Bone M12001 Hood (Bonnet) Upper
M12101 Bonnet Hood (Bonnet) Upper (Sound Absorber Insulator)
M12102 Bone Hood (Sound Absorber Damper Material) New Hood (Bonnet) Upper (Sound Absorber Insulator)
Hood Bone M12301 Hood (Bonnet) Damper
Kaput Bone Hood Bonnet M12400 Bone Lock Bonnet Lock
Kaput Bone Hood Bonnet M12701 Bone Yal Cover Hood (Bonnet) Side Cover
Kaput Bone Hood Bonnet M14001 Bone Support Bonnet Support
Hood Bone M14300 Shield Shield
Hood (Bone) Rear Hood (Bonnet) Rear Note 020 And Fig.No.B10501 Ref.No.030
Hood Bone M17500 Hood (Bonnet) Rear (Sound Absorbing Damper Material) Hood (Bonnet)
Kaput Bone Hood Bonnet M18000 Rearview Mirror
Hood Bone M22000 Fender
Kaput Bone Hood Bonnet M22300 Floor Sheet
Hood Bone M23100 Step
Hood Bone M23200 Step Upper Cover
Hood Bone M23300 Step Mat Sound Absorber Step Mat Sound Absorber
Hood Bonnet Hood Bonnet M23400 Auxiliary Step Auxiliary Step
Kaput Bone Hood Bonnet M23501 Seat EC Se Tur Seat EC Se Tur
Kaput Bone Hood Bonnet M27000 Tool Box
ROPS (Rolldown Protective Structures) ROPS M31100 ROPS 1 (Middle) ROPS 1 (Mid)
ROPS (Rolldown Protective Structures) ROPS M31200 ROPS 2 (Rear) ROPS 2 (Rear)
Labels S12001 Label (Front)
Labels S13001 Label (Panel)
Labels S14001 Label (Back) EC Se Tur Label (Rear) EC Se Tur
Accessory Service Part Accessories T11001 Accessory Service Part Accessories And
Option U11001 Alternator Kit 1 (Alternator) Option Alternator Kit 1 (Alternator)
Option U11300 Alternator Kit Component Parts Option Alternator Component
Option U68001 Front Support Control Valve Kit (Hander Tube) Option Front Remote Hydraulic
Option U68300 Front Support Control Valve Kit (First Valve) Option Front Remote Hydraulic
Option U68400 Front Support Control Valve Kit (Second Valve) Option Front Remote Hydraulic
Option U68500 Front Support Control Valve Kit (FC) Component Parts Option Auxiliary Control
Control Valve Kit (SCD) Component Parts Option Old Auxiliary Control Valve (SCD) Component Parts
Control Valve Kit (SCD) Component Parts Option New Auxiliary Control Valve (SCD) Component Parts
Option U68700 Front Support Control Valve Kit (Valve Cover) Option Front Remote Hydraulic
Option U68801 Front Support Control Valve Kit (Control Lever) Option Front Remote Hydraulic
U69001 Front Support Control Valve Kit (First Valve Control Lever) Option Front Remote Hydraulic
Option U69201 Front Support Control Valve Kit (Second Valve Control Lever) Option Front Remote Hydraulic
Option U69501 Front Support Control Valve Kit (Housing Bracket) Option Front Remote Hydraulic
Option U71000 Support Control Valve Lever (3.) Option Auxiliary Control Valve Lever
Option U75001 Trailer Brake Valve Kit 1 (Valve Pipe) Option Trailer Brake Valve Kit
Option U75101 Trailer Brake Valve Kit 2 (Pipe) Option Trailer Brake Valve Kit
Option U75200 Trailer Brake Valve Kit 3 (Cover) Option Trailer Brake Valve Kit 3
U87502 Drawbar Bracket Kit Se Tur Option Old Drawbar Bracket Kit Se Tur Option Old Chassis
U88800 PTO Shaft Protector Kit Se Tur Option Old PTO Shaft Protector Kit Se Tur Option Old
Option U90500 Step Support Kit Option Old Step Support Kit Option Old Chassis No. 80752 S.
