Kubota Tractor M8540DTHC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M8540DTHC Tractor
Number of Pages: 509 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Válvula E Veio Do Balanceiro / Valve And Ro Cker Arm
Tampa Cabeça / Head Cover
Carreto / Gear Case
Arvore Cames E Veio / Camshaft And Idle Gea R Shaft
Compensador / Balancer
Volante Motor / Flywheel
Caixa Da Bomba / Pump Housing
Alavanca Do Garfo (Governador) / Fork Lever (Governor)
Parafuso De Ajuste De Governador / Governor Adjusting Bolt
Filtro Gasoleo / Fuel Filter
Acessorios / Water Pump
Refrigerador Egr / Egr Cooler
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Component Parts]
Escpae / Muffler
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger )
Tubo Oleo (Temporizador Mecanico) / Oil Pip E (Mechanical Timer)
Radiador Oleo / Oil Cooler
Componentes Electricos Motor / Sensor (Engi Ne)
Fornecimento Combustivel / Fuel Supply
Tubo Combustivel / Fuel Pip E
Separador / Separator
Separador[Peças Componentes ] / Separator [Component Parts] [Old]
Separador[Peças Componentes ] / Separator [Component Parts] [New]
Ventilado R / Fan
Radiador / Water Pipe
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componente S] / Starter [Component Parts]
Interruptor/Sensor (Bloco Motor) / Sensor (Engine)
Interruptor/Sensor (Frente ) / Switch/Sensor (Front)
Interruptor/Sensor / Switc H/Sensor (Rear) [Ec] [Se] [Tur]
Interruptor/Sensor / Switc H/Sensor (Rear) [G-Pto] [Ita]
Interruptor / Switch (Pane L Board)
Interruptor / Switch (Ligh T/Panel) [Ds] [Ec] [Uk] [Ita]
Interruptor / Switch (Ligh T/Panel) [Except [Ds]] [Se] [Ita] [Tur]
Interruptor / Rele / Relay
Luzes Frente / Head Light [Ec] [Se] [Ita] [Tur]
Farol Frente[Peças Compone Ntes] / Head Light [Component Parts] [Ec] [Se] [Ita ] [Tur]
Luzes Frontais / Front Com Bination Light
Luzes Trabalho / Working L Ight/Beacon Light [Ec] [Se] [Ita] [Tur]
Braco Traseiro / Rear Comb Ination Light
Ficha Reboque / Trailer So Cket [Old]
Ficha Reboque / Trailer So Cket [New]
Luz Interior / Room Light
Alta Voz Radio / Radio Spe Aker [Ec] [Se] [Ita] [Tur]
Depósito De Lavagem / Wash Er Tank
Escova Limpa Vidro Frontal / Front Wiper
Cablagem Eletrcia (Frente) / Electrical Wiring (Engine) [Ec] [Se] [Uk] [Tur]
Cablagem Eletrcia (Frente) / Electrical Wiring (Engine) [G-Pto] [Ita]
Cablagem Electrica / Elect Rical Wiring (Main) [Ec] [Old]
Cablagem Electrica / Elect Rical Wiring (Main) [Ec] [New]
Cablagem Electrica / Elect Rical Wiring (Main) [Se] [Tur] [Old]
Cablagem Electrica / Elect Rical Wiring (Main) [Se] [Tur] [New]
Cablagem Electrica / Elect Rical Wiring (Main) [G-Pto] [Ita]
Cabalagem Eletrica(Cabine) [Ec] [G] / Electrical Wiring (Cab) [Ec] [Se] [Ita] [Tur]
Carter Embraiagem / Clutch Housing [Ds] [Ec] [Uk] [Ita] [Old]
Carter Embraiagem / Clutch Housing [Ds] [Ec] [Uk] [Ita] [New]
Carter Embraiagem / Clutch Housing [Except [Ds]] [Se] [Ita] [Tur] [Old ]
Carter Embraiagem / Clutch Housing [Except [Ds]] [Se] [Ita] [Tur] [New ]
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case [Ds] [Ec] [Uk] [Ita]
Carretos Inversor / Shuttle Gear Case [Except [Ds]] [Se] [Ita] [Tur]
Tampa / Shift Cover
Valva Dual Speed / Dual Speed Valve [Ds] [Ec] [Uk] [Ita]
Caixa Velocidades / Transmission Case [Ec] [Uk] [Se] [Tur]
Caixa Velocidades / Transmission Case [G-Pto] [Ita]
Carter Transmissao / Transmission Case Rear Cover [Ec] [Se] [Ita] [Tur ]
Carter Eixo / Rear Axle Case
Disco Amortecedor / Damper Disk
Bloqueio Diferencia L / Clutch Pedal
Cabo Embraiagem / C Lutch Cable
Valvula (Inversor) / Valve Lever (Clutch)
Veio Primario / Inp Ut Shaft [Ds] [Ec] [Uk] [Ita]
Veio Primario / Inp Ut Shaft [Except [Ds]] [Se] [Ita] [Tur]
Kit Embraiagem Hi-L O [Peças Componentes] / Clutch Pack (Hi-Lo) [Compon Ent Parts] [Ds] [Ec] [Uk] [Ita]
Kit Embraiagem Hi-L O [Peças Componentes] / Clutch Pack (Shuttle) [Comp Onent Parts] [Except [Ds]] [Se] [Ita] [Tur]
Veio Inversor / Shu Ttle Shaft [Ds] [Ec] [Uk] [Ita]
Veio Inversor / Shu Ttle Shaft [Except [Ds]] [Se] [Ita] [Tur]
Embraiagem Inversor [Peças Componentes] / Clutch Pack (Shuttle) [Compo Nent Parts] [Ds] [Ec] [Uk] [Ita] [Old]
Embraiagem Inversor [Peças Componentes] / Clutch Pack (Shuttle) [Compo Nent Parts] [Ds] [Ec] [Uk] [Ita] [New]
Primeiro Veio / Fir St Shaft [Ds] [Ec] [Uk] [Ita]
Primeiro Veio / Fir St Shaft [Except [Ds]] [Se] [Ita] [Tur]
Secundario Veio / S Econd Shaft
Terceiro Veio / Thi Rd Shaft
Veio Creeper / Cree P Shaft
Veio / Drive Shaft [Old]
Veio / Drive Shaft [New]
Grupo Conico / Beve L Gear [Ec] [Uk] [Se] [Tur]
Grupo Conico / Beve L Gear [G-Pto] [Ita]
Diferencial Traseir O / Differential Rear [Old]
Diferencial Traseir O / Differential Rear [New]
Embraiagem Bloqueio Diferencial Traseiro / Rear Differential Lock Clut Ch
Veio Tdf / Pto Prop Eller Shaft
Embraiagem Tdf / Pt O Clutch [Ec] [Uk] [Se] [Tur] [Old]
Embraiagem Tdf / Pt O Clutch [Ec] [Uk] [Se] [Tur] [New]
Embraiagem Tdf / Pt O Clutch [G-Pto] [Ita] [Old]
Embraiagem Tdf / Pt O Clutch [G-Pto] [Ita] [New]
Embraiagem Tdf [Peç As Componentes] / Pto Clutch [Component Parts] [Old ]
Embraiagem Tdf [Peç As Componentes] / Pto Clutch [Component Parts] [New ]
Valvula Embraiagem Tdf / Pto Clutch Valve [Old]
Valvula Embraiagem Tdf / Pto Clutch Valve [New]
Veio Tdf / Pto Shaf T [Ec] [Se] [Ita] [Tur]
Embraiagem Andament O / Front Drive Clutch
Veio Embraiagem[Peç As Componentes] / Front Drive Clutch [Component Par Ts]
Forqueta / Main Gear Shift Fork [Ds] [Ec] [Uk] [Ita]
Forqueta / Main Gear Shift Fork [Except [Ds]] [Se] [Ita] [T Ur]
Forquilh A Tdf / Ground Pto Shift Fork [G-Pto] [Ita]
Alavanca Velocidades / Main Gear Shift Lever [Ds] [Ec] [Uk] [Ita]
Alavanca Velocidades / Main Gear Shift Lever [Except [Ds]] [Se] [Ita] [Tur]
Tirante / Main Gear Shift Rod
Principa L De Transmissão Eixo Da Alavanca / Main Gear Shift Lever Shaft [Old]
Principa L De Transmissão Eixo Da Alavanca / Main Gear Shift Lever Shaft [New]
Cabo Inv Ersor / Shuttle Cable
Gama E T Irante Caixa Creep / Range And Creep Gear Shift Lev Er
Alavanca Tdf / Pto Gear Shift Lever [Ec] [Se] [Tur]
Alavanca / Ground Pto Shift Lever [G-Pto] [Ita]
Pedal Bloqueio Diferenci Al Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Axl E
Travao(Drt) / Brake Rh [ Ec] [Uk] [Se] [Tur]
Travao(Drt) / Brake Rh [ Ita]
Travão Esquerda / Brake Lh
Veio Bloqueio / Parking Brake Camshaft
Alavanca Travao Mao / Pa Rking Brake Lever
Tirante Travao Mao / Par King Brake Rod
Travão De Estacionamento / Parking Brake
Pedal Travao / Brake Ped Al
Deposito Oleo Travoes / Brake Oil Tank
Cilindro Travao Principa L[Peças Componentes] / Brake Master Cylinder [Compo Nent Parts]
Tubo Travao / Brake Pipe
Suporte Eixo Dianteir O / Front Axle Bracket
Veio Frontal / Front Propeller Shaft
Caixa Diferencial Dia Nteiro / Front Differential Case
Engrenagem Cónica (Di Anteira) / Bevel Gear (Front)
Diferencial Dianteiro / Differential Front
Caixas Engrenagens Co Nica(Drt) / Bevel Gear Case Rh
Caixas Engrenagens Co Nica(Esq) / Bevel Gear Case Lh
Carter Eixo Frente(Dr T) / Front Axle Case Rh
Carter Eixo Frente(Es Q) / Front Axle Case Lh
Carreto Diferencial(D Rt) / Differential Gear Shaft Rh
Eixo Frente (Drt) / F Ront Axle Rh
Eixo Dianteiro / Fron T Axle Lh
Direcção Assistida / Direção Punho / Steerin G Handle
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção[Peças Componentes] / S Teering Controller [Component Parts] [Old]
Distribuidor Direcção[Peças Componentes] / S Teering Controller [Component Parts] [New]
Direcção Assistida / Tie Rod/Steering Cylind Er
Cilindro Direcção[Peças Componentes] / Steer Ing Cylinder [Component Parts]
Bomba Hidraulico / Hydraul Ic Pump
Bomba Hidraulico[Peças Com Ponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo / Hydraulic Pipe (Delivery) [Ec] [Uk] [Se] [Tur] [Old]
Tubo Oleo / Hydraulic Pipe (Delivery) [Ec] [Uk] [Se] [Tur] [New]
Tubo Oleo / Hydraulic Pipe (Delivery) [Ita]
Tubo Hidraulico (Travao Re Boque) / Hydraulic Pipe (Trailer Brake) [Ec] [Uk] [ Se] [Tur]
Valvula Travao Reboque / T Railer Brake Valve [Ec]
Valvula Travao Reboque / T Railer Brake Valve [Se] [Uk] [Tur]
Tubo Oleo (Dual Speed) / H Ydraulic Oil Line (Dual Speed Valve) [Ds] [Ec] [Uk] [Ita]
Circuito Oleo Direcção / H Ydraulic Oil Line (Steering/Pto) [Ec] [Uk]
Tubo Oleo (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Controller)
Tubo Direccao / Steering H Ose (Delivery)
Caixa Hidraulico / Hydraul Ic Cylinder Case [Old]
Caixa Hidraulico / Hydraul Ic Cylinder Case [New]
Braço De Elevação Hidráuli Co / Hydraulic Lift Arm
Valvula Segurança / Safety Valve/Relief Valve
Trinco / Lowering Lock Lev Er
Braco Hidraulico / Control Valve
Alavanca Control Posicao / Position Control Lever
Acessorios / Draft And Pos Ition Control Lever
Suporte Alavanca / Draft A Nd Position Control Rod
Veio Posicao Esforço / Pos Ition And Draft Shaft [Old]
Veio Posicao Esforço / Pos Ition And Draft Shaft [New]
Alavanca / Feed Back Lever
Distribuidor Auxiliar / Au Xiliary Control Valve [Ec] [Uk] [Ita]
Distribuidor Auxiliar / Au Xiliary Control Valve [Se] [Tur]
Valvula Auxiliar [Peças Co Mponentes] / Auxiliary Control Valve (Fd) [Componen T Parts] [Old]
Valvula Auxiliar [Peças Co Mponentes] / Auxiliary Control Valve (Fd) [Componen T Parts] [New]
Valvula Auxiliar [Peças Co Mponentes] / Auxiliary Control Valve (S/D) [Compone Nt Parts]
Alavanca Valvula Auxiliar 1 Pos / Auxiliary Control Valve Lever
Cilindro Auxiliar De Eleva Cao(Esq) / 3p-Lift Assist Cylinder Lh [Ec] [Uk] [It A]
Cilindro Auxiliar De Eleva Cao(Drt) / 3p-Lift Assist Cylinder Rh [Se] [Tur]
Cilindro Auxiliar De Eleva Cao(Drt) / 3p-Lift Assist Cylinder Rh [Ec] [Uk] [It A]
Cilindro Auxiliar De Eleva Cao[Peças Componentes] / 3p-Lift Assist Cylinder [C Omponent Parts] [Old]
Cilindro Auxiliar De Eleva Cao[Peças Componentes] / 3p-Lift Assist Cylinder [C Omponent Parts] [New]
Parte Superior / Top Link Bracket
3-Pon T Acoplamento (Ligacao Superior) / Top Link
Ligac Ao Inferior / Lower Link [Ec] [Uk] [Ita]
Ligac Ao Inferior / Lower Link [Se] [Tur]
Estab Ilizador / Stabilizer
Estab Ilizador(Drt) / Lift Rod Rh
Estab Ilizador(Esq) / Lift Rod Lh
Barra / Drawbar Bracket [Ec] [Uk]
Barra / Drawbar Bracket [Se] [Tur]
Barra / Drawbar Bracket [Ita]
Prote Ccao Tdf / Pto Shaft Protector [Ec] [Old]
Prote Ccao Tdf / Pto Shaft Protector [Ec] [New]
Prote Ccao Tdf / Pto Shaft Protector [Se] [Tur] [Old]
Prote Ccao Tdf / Pto Shaft Protector [Se] [Tur] [New]
Prote Ccao Tdf / Pto Shaft Protector [Ita]
Grelha Frontal / Front Grille
Trico Capot / Bonnet Lock
Suporte Capot / Bonnet Support [Old]
Suporte Capot / Bonnet Support [New]
Estrutura Cabine / Cab Frame [Ec] [Uk] [Se] [Tur] [ Old]
Estrutura Cabine / Cab Frame [Ec] [Uk] [Se] [Tur] [ New]
Estrutura Cabine / Cab Frame [G-Pto] [Ita] [Old]
Estrutura Cabine / Cab Frame [G-Pto] [Ita] [New]
Porta(Drt) / Door Rh
Porta(Esq) / Door Lh
Trinco Porta(Drt) / Door Lock Rh
Trinco Porta(Esq) / Door Lock Lh
Lado Vidro / Side Window
Vidro Traseiro / Rear Window
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Banco / Seat [Except [Ds]] [Se] [Ita] [Tur]
Piso / Floor Mat [Old]
Piso / Floor Mat [New]
Chapa Inspecção(Frente) / Inspection Plate [Ec] [Uk ]
Chapa Inspecção(Frente) / Inspection Plate [Se] [Tu R]
Chapa Inspecção(Frente) / Inspection Plate [Except [Ds]] [Ita]
Chapa Inspecção(Frente) / Inspection Plate [Ds] [It A]
Isolante / Soundproof Material [Ec] [Uk] [Se] [Tur]
Isolante / Soundproof Material [G-Pto] [Ita]
Cobertura Guarda Lamas(Drt) / Fender Cover Rh [Ds] [Ec] [Uk] [Ita]
Cobertura Guarda Lamas(Drt) / Fender Cover Rh [Exce Pt [Ds]] [Se] [Ita] [Tur]
Cobertura Gurada Lamas(Esq) / Fender Cover Lh
Guarda Lamas / Fender
Dianteira Do Suporte Da Cabine / Cab Bracket Front
Suporte Cabine Traseiro / Cab Bracket Rear
Caixa Ferramenta / Tool Box [Old]
Caixa Ferramenta / Tool Box [New]
Air Condicionado / Air Condit Ioner
Tubo Ar Condicionado / Air Co Nditioner Duct
Modo Caixa / Mode Case
Entradas Ar Painel Instrument Os / Dashboard Air Outlets
Circulaçao Ar Interior / Inne R Air Recirculation
Tubo Aquecimento / Heater Hos E
Condesador / Condenser
Tubo Ar Condicionado/Tubo Con Densador / Air Conditioner Hose/Condenser Hose [Old ]
Tubo Ar Condicionado/Tubo Con Densador / Air Conditioner Hose/Condenser Hose [New ]
Suporte Compressor / Compress Or Bracket
Etiqueta (Dianteira) / Label (Front)
Etiqueta 2 / Label (Rear) [Ec] [Se] [ Tur]
Acessorios / Accessories And Service Pa Rts
Kit Alternador [Opçao] / Alternator Kit 1 (Altern Ator) [Option]
Kit Alternador [Opçao] / Alternator Kit 2 (Wire H Arness) [Option]
Alternador [Peças Componentes] [Opcao] / Alternat Or [Component Parts] [Option]
Kit Limpa Vidro Traseiros (Opcao) / Rear Wiper Ki T [Option]
Veio De Acionamento Kit[Opção] / Drive Shaft Kit [Option] [Old]
Principal De Transmissão Da Alavanca [Opção] / Ma In Gear Shift Lever Kit [Option]
Embraiagem Tdf Peças De Substituição Kit(Embraiag Em/Suporte)[Opção] / Pto Clutch Replacement Kit (Cl Utch/Holder) [Option] [Old]
Embraiagem Tdf Peças De Substituição Kit(Respiro Tubo)[Opção] / Pto Clutch Replacement Kit (Breather Hose) [Option] [Old]
Kit Conversao Tdf 540/1000 (Engrenagem Box)(Opção ) / Pto (540/1000) Conversion Kit (Gear Case) [Opti On]
Kit Conversao Tdf 540/1000 (Engrenagem) (Opção) / Pto (540/1000) Conversion Kit (Gear) [Option]
Kit Modificação Tdf (540/1000)(Engrenagem)(Ec)(Se )(Ita) (Opção) / Pto (540/1000) Conversion Kit (Gea R) [Ec] [Se] [Ita] [Tur] [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary C Ontrol Valve Kit (Scd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary C Ontrol Valve Kit (Fd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary C Ontrol Valve Kit (Fc) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary C Ontrol Valve Kit (Scd/Fc) [Option]
Kit Distribuidor Serviços Externos[Peças Componen Tes][Opcao] / Auxiliary Control Valve (Scd) [Compon Ent Parts] [Option]
Kit Distribuidor Serviços Externos[Peças Componen Tes][Opcao] / Auxiliary Control Valve (Fd) [Compone Nt Parts] [Option]
Kit Distribuidor Serviços Externos[Peças Componen Tes][Opcao] / Auxiliary Control Valve (Fc) [Compone Nt Parts] [Option] [Old]
Kit Distribuidor Serviços Externos[Peças Componen Tes][Opcao] / Auxiliary Control Valve (Fc) [Compone Nt Parts] [Option] [New]
Kit Distribuidor Serviços Externos[Peças Componen Tes][Opcao] / Auxiliary Control Valve (Scd/Fc) [Com Ponent Parts] [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit Valvula Travao Reboque 1[Peças Componentes] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Ita] [Opti On]
Kit Valvula Travao Reboque 2[Peças Componentes] / Trailer Brake Valve Kit 2 (Pipe) [Ita] [Option]
Kit Valvula Travao Reboque 3[Peças Componentes] / Trailer Brake Valve Kit 3 (Pipe) [Ita] [Option]
Veio Tdf Kit[Opção] / Pto Shaft Protector Kit [Se ] [Tur] [Option]
