Kubota Tractor M8540DTHC Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M8540DTHC Tractor
Number of Pages: 859 Pages
Artículos De Uso Frecuente / Frequently Used Items
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Compensador / Balancer
Volante / Flywheel
Bomba Carcasa / Pump Housing
Bomba Inyección / Injection Pump
Bifurcacion Palanca (Regulador) / Fork Lever (Governor)
Regulador Ajuste Tornillo / Governor Adjusting Bolt
Agua Bomba / Water Pump
Valvula De Egr / Egr Valve
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Pipa Del Aceite (Contador De Tiempo Mecanico) / Oil Pipe (Mechanical Timer)
Piezas Electricas Del Motor / Sensor (Engine)
Palanca Acelerador / Hand Accelerator Lever
Llenador Del Combustible / Fuel Supply
Combustible Tubo / Fuel Pipe
Separador / Separator
Separador [Componente Piezas] [Antiguo] / Separator [Component Parts] [Old]
Separador [Componente Piezas] [Nuevo] / Separator [Component Parts] [New]
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Sensor (Motor) / Sensor (Engine)
Conmutador/Sensor (Motor/Unidad Del Combustible) / Switch/Sensor (Front)
Conmutador/Sensor (Trasero) [Ec] [Se] [Tur] / Switch/Sensor (Rear) [Ec] [Se] [Tur]
Conmutador/Sensor (Trasero) [Tdf Proporcional] [Ita] / Switch/Sensor (Rear) [G-Pto] [Ita]
Conmutador (Luz/Panel) [Ds] [Ec] [Uk] [Ita] / Switch (Light/Panel) [Ds] [Ec] [Uk] [Ita]
Conmutador (Luz/Panel) [Excepto [Ds]] [Se] [Ita] [Tur] / Switch (Light/Panel) [Except [Ds]] [Se] [Ita] [Tur]
Rele / Relay
Tablero Panel / Panel Board
Culata Luz [Ec] [Se] [Ita] [Tur] / Head Light [Ec] [Se] [Ita] [Tur]
Faro Delantero [Componente Piezas] [Ec] [Se] [Ita] [Tur] / Head Light [Component Parts] [Ec] [Se] [Ita] [Tur]
Adelante Combinacion Luz / Front Combination Light
Trabajo Luz/Luz Del Faro [Ec] [Se] [Ita] [Tur] / Working Light/Beacon Light [Ec] [Se] [Ita] [Tur]
Trasero Combinacion Luz / Rear Combination Light
Licencia Lampara / License Lamp
Remolque Vaso [Antiguo] / Trailer Socket [Old]
Remolque Vaso [Nuevo] / Trailer Socket [New]
Altavoz De Radio [Ec] [Se] [Ita] [Tur] / Radio Speaker [Ec] [Se] [Ita] [Tur]
Limpiador Delantero / Front Wiper
Electrico Cableado (Motor) [Ec] [Se] [Uk] [Tur] / Electrical Wiring (Engine) [Ec] [Se] [Uk] [Tur]
Electrico Cableado (Motor) [Tdf Proporcional] [Ita] / Electrical Wiring (Engine) [G-Pto] [Ita]
Electrico Cableado (Principal) [Ec] [Antiguo] / Electrical Wiring (Main) [Ec] [Old]
Electrico Cableado (Principal) [Ec] [Nuevo] / Electrical Wiring (Main) [Ec] [New]
Electrico Cableado (Principal) [Se] [Tur] [Antiguo] / Electrical Wiring (Main) [Se] [Tur] [Old]
Electrico Cableado (Principal) [Se] [Tur] [Nuevo] / Electrical Wiring (Main) [Se] [Tur] [New]
Electrico Cableado (Principal) [Tdf Proporcional] [Ita] / Electrical Wiring (Main) [G-Pto] [Ita]
Electrico Cableado (Cabina) [Ec] [Se] [Ita] [Tur] / Electrical Wiring (Cab) [Ec] [Se] [Ita] [Tur]
Embrague Carcasa [Ds] [Ec] [Uk] [Ita] [Antiguo] / Clutch Housing [Ds] [Ec] [Uk] [Ita] [Old]
Embrague Carcasa [Ds] [Ec] [Uk] [Ita] [Nuevo] / Clutch Housing [Ds] [Ec] [Uk] [Ita] [New]
Embrague Carcasa [Excepto [Ds]] [Se] [Ita] [Tur] [Antiguo] / Clutch Housing [Except [Ds]] [Se] [Ita] [Tur] [Old]
Embrague Carcasa [Excepto [Ds]] [Se] [Ita] [Tur] [Nuevo] / Clutch Housing [Except [Ds]] [Se] [Ita] [Tur] [New]
Inversor Valvula / Shuttle Valve
Engranajes De Inversor Caja [Ds] [Ec] [Uk] [Ita] / Shuttle Gear Case [Ds] [Ec] [Uk] [Ita]
Engranajes De Inversor Caja [Excepto [Ds]] [Se] [Ita] [Tur] / Shuttle Gear Case [Except [Ds]] [Se] [Ita] [Tur]
Valvula De Doble Velocidad [Ds] [Ec] [Uk] [Ita] / Dual Speed Valve [Ds] [Ec] [Uk] [Ita]
Transmision Caja [Ec] [Uk] [Se] [Tur] / Transmission Case [Ec] [Uk] [Se] [Tur]
Transmision Caja [Tdf Proporcional] [Ita] / Transmission Case [G-Pto] [Ita]
Cubierta Trasera De Caja De Transmision [Ec] [Se] [Ita] [Tur] / Transmission Case Rear Cover [Ec] [Se] [Ita] [Tur]
Trasero Eje Caja / Rear Axle Case
Cable De Embrague / Clutch Cable
Valvula Palanca (Embrague) / Valve Lever (Clutch)
Entrada Eje [Ds] [Ec] [Uk] [Ita] / Input Shaft [Ds] [Ec] [Uk] [Ita]
Entrada Eje [Excepto [Ds]] [Se] [Ita] [Tur] / Input Shaft [Except [Ds]] [Se] [Ita] [Tur]
Paquete Del Embrague (Inversor) [Componente Piezas] [Ds] [Ec] [Uk] [Ita] / Clutch Pack (Hi-Lo) [Component Parts] [Ds] [Ec] [Uk] [Ita]
Paquete Del Embrague (Inversor) [Componente Piezas] [Excepto [Ds]] [Se] [Ita] [Tur] / Clutch Pack (Shuttle) [Component Parts] [Except [Ds]] [Se] [Ita] [Tur]
Eje De Inversor [Ds] [Ec] [Uk] [Ita] / Shuttle Shaft [Ds] [Ec] [Uk] [Ita]
Eje De Inversor [Excepto [Ds]] [Se] [Ita] [Tur] / Shuttle Shaft [Except [Ds]] [Se] [Ita] [Tur]
Paquete Del Embrague (Inversor) [Componente Piezas] [Ds] [Ec] [Uk] [Ita] [Antiguo] / Clutch Pack (Shuttle) [Component Parts] [Ds] [Ec] [Uk] [Ita] [Old]
Paquete Del Embrague (Inversor) [Componente Piezas] [Ds] [Ec] [Uk] [Ita] [Nuevo] / Clutch Pack (Shuttle) [Component Parts] [Ds] [Ec] [Uk] [Ita] [New]
Primer Eje [Ds] [Ec] [Uk] [Ita] / First Shaft [Ds] [Ec] [Uk] [Ita]
Primer Eje [Excepto [Ds]] [Se] [Ita] [Tur] / First Shaft [Except [Ds]] [Se] [Ita] [Tur]
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Eje Propulsor [Antiguo] / Drive Shaft [Old]
Eje Propulsor [Nuevo] / Drive Shaft [New]
Eje De Engranaje Diferencial [Ec] [Uk] [Se] [Tur] / Bevel Gear [Ec] [Uk] [Se] [Tur]
Eje De Engranaje Diferencial [Tdf Proporcional] [Ita] / Bevel Gear [G-Pto] [Ita]
Diferencial Trasero [Antiguo] / Differential Rear [Old]
Diferencial Trasero [Nuevo] / Differential Rear [New]
Trasero Diferencial Cerradura Embrague / Rear Differential Lock Clutch
Pto Helice Eje / Pto Propeller Shaft
Pto Embrague [Ec] [Uk] [Se] [Tur] [Antiguo] / Pto Clutch [Ec] [Uk] [Se] [Tur] [Old]
Pto Embrague [Ec] [Uk] [Se] [Tur] [Nuevo] / Pto Clutch [Ec] [Uk] [Se] [Tur] [New]
Pto Embrague [Tdf Proporcional] [Ita] [Antiguo] / Pto Clutch [G-Pto] [Ita] [Old]
Pto Embrague [Tdf Proporcional] [Ita] [Nuevo] / Pto Clutch [G-Pto] [Ita] [New]
Pto Embrague [Componente Piezas] [Antiguo] / Pto Clutch [Component Parts] [Old]
Pto Embrague [Componente Piezas] [Nuevo] / Pto Clutch [Component Parts] [New]
Pto Embrague Valvula [Antiguo] / Pto Clutch Valve [Old]
Pto Embrague Valvula [Nuevo] / Pto Clutch Valve [New]
Pto Eje [Ec] [Se] [Ita] [Tur] / Pto Shaft [Ec] [Se] [Ita] [Tur]
Embrague Impulsor Delantero [Componente Piezas] / Front Drive Clutch [Component Parts]
Principal Engranaje Cambio Bifurcacion [Ds] [Ec] [Uk] [Ita] / Main Gear Shift Fork [Ds] [Ec] [Uk] [Ita]
Principal Engranaje Cambio Bifurcacion [Excepto [Ds]] [Se] [Ita] [Tur] / Main Gear Shift Fork [Except [Ds]] [Se] [Ita] [Tur]
Gama Y Arrastramiento Engranaje Cambio Bifurcacion / Range And Creep Gear Shift Fork
Horquilla De Cambio De Tdf Proporcional [Tdf Proporcional] [Ita] / Ground Pto Shift Fork [G-Pto] [Ita]
Principal Engranaje Cambio Palanca [Ds] [Ec] [Uk] [Ita] / Main Gear Shift Lever [Ds] [Ec] [Uk] [Ita]
Principal Engranaje Cambio Palanca [Excepto [Ds]] [Se] [Ita] [Tur] / Main Gear Shift Lever [Except [Ds]] [Se] [Ita] [Tur]
Principal Engranaje Cambio Palanca Eje [Antiguo] / Main Gear Shift Lever Shaft [Old]
Principal Engranaje Cambio Palanca Eje [Nuevo] / Main Gear Shift Lever Shaft [New]
Inversor Cable / Shuttle Cable
Palanca De La Cambio De Engran. De La Gama Y Arrastramiento / Range And Creep Gear Shift Lever
Palanca De Cambio De Tdf [Ec] [Se] [Tur] / Pto Gear Shift Lever [Ec] [Se] [Tur]
Masa Pto Cambio Palanca [Tdf Proporcional] [Ita] / Ground Pto Shift Lever [G-Pto] [Ita]
Eje Trasero / Rear Axle
Freno Derecho [Ec] [Uk] [Se] [Tur] / Brake Rh [Ec] [Uk] [Se] [Tur]
Freno Derecho [Ita] / Brake Rh [Ita]
Freno Izquierdo / Brake Lh
Arbol De Levas Del Freno De Estacionamiento / Parking Brake Camshaft
Estacionamiento Freno Varilla / Parking Brake Rod
Estacionamiento Freno / Parking Brake
Freno Pedal / Brake Pedal
Freno Aceite Deposito / Brake Oil Tank
Freno Tubo / Brake Pipe
Adelante Helice Eje / Front Propeller Shaft
Bisel Engranaje Caja Derecho / Bevel Gear Case Rh
Bisel Engranaje Caja Izquierdo / Bevel Gear Case Lh
Diferencial Engranaje Eje Derecho / Differential Gear Shaft Rh
Direccion Junta / Steering Joint
Direccion Controlador / Steering Controller
Direccion Controlador [Componente Piezas] [Antiguo] / Steering Controller [Component Parts] [Old]
Direccion Controlador [Componente Piezas] [Nuevo] / Steering Controller [Component Parts] [New]
Hidraulico Tubo (Entrega) [Ec] [Uk] [Se] [Tur] [Antiguo] / Hydraulic Pipe (Delivery) [Ec] [Uk] [Se] [Tur] [Old]
Hidraulico Tubo (Entrega) [Ec] [Uk] [Se] [Tur] [Nuevo] / Hydraulic Pipe (Delivery) [Ec] [Uk] [Se] [Tur] [New]
Hidraulico Tubo (Entrega) [Ita] / Hydraulic Pipe (Delivery) [Ita]
Hidraulico Tubo (Remolque Freno) [Ec] [Uk] [Se] [Tur] / Hydraulic Pipe (Trailer Brake) [Ec] [Uk] [Se] [Tur]
Remolque Freno Valvula [Ec] / Trailer Brake Valve [Ec]
Remolque Freno Valvula [Se] [Uk] [Tur] / Trailer Brake Valve [Se] [Uk] [Tur]
Hidraulico Aceite Linea (Valvula De Doble Velocidad) [Ds] [Ec] [Uk] [Ita] / Hydraulic Oil Line (Dual Speed Valve) [Ds] [Ec] [Uk] [Ita]
Hidraulico Aceite Linea (Direccion/Pto) [Ec] [Uk] / Hydraulic Oil Line (Steering/Pto) [Ec] [Uk]
Hidraulico Aceite Linea (Direccion/Pto) [Se] [Tur] / Hydraulic Oil Line (Steering/Pto) [Se] [Tur]
Hidraulico Aceite Linea (Inversor/Controlador) / Hydraulic Oil Line (Shuttle/Controller)
Cilindro Hidraulico [Antiguo] / Hydraulic Cylinder Case [Old]
Cilindro Hidraulico [Nuevo] / Hydraulic Cylinder Case [New]
Brazo De Elevacion / Hydraulic Lift Arm
Coloque La Palanca De Mando / Position Control Lever
Esfuerzo Y Posicion Control Palanca / Draft And Position Control Lever
Esfuerzo Y Posicion Control Varilla / Draft And Position Control Rod
Posicion Y Esfuerzo Eje [Antiguo] / Position And Draft Shaft [Old]
Posicion Y Esfuerzo Eje [Nuevo] / Position And Draft Shaft [New]
Distribuidor De Servicios Externos [Ec] [Uk] [Ita] / Auxiliary Control Valve [Ec] [Uk] [Ita]
Distribuidor De Servicios Externos [Se] [Tur] / Auxiliary Control Valve [Se] [Tur]
Auxiliar Control Valvula (Fd) [Componente Piezas] [Antiguo] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Auxiliar Control Valvula (Fd) [Componente Piezas] [Nuevo] / Auxiliary Control Valve (Fd) [Component Parts] [New]
Auxiliar Control Valvula (S/D) [Componente Piezas] / Auxiliary Control Valve (S/D) [Component Parts]
Auxiliar Control Valvula Palanca / Auxiliary Control Valve Lever
Cilindro De Ayuda De Elevacion Izquierdo [Se] [Tur] / 3p-Lift Assist Cylinder Lh [Se] [Tur]
Cilindro De Ayuda De Elevacion Izquierdo [Ec] [Uk] [Ita] / 3p-Lift Assist Cylinder Lh [Ec] [Uk] [Ita]
Cilindro De Ayuda De Elevacion Derecho [Se] [Tur] / 3p-Lift Assist Cylinder Rh [Se] [Tur]
Cilindro De Ayuda De Elevacion Derecho [Ec] [Uk] [Ita] / 3p-Lift Assist Cylinder Rh [Ec] [Uk] [Ita]
Cilindro De Ayuda De Elevacion [Componente Piezas] [Antiguo] / 3p-Lift Assist Cylinder [Component Parts] [Old]
Cilindro De Ayuda De Elevacion [Componente Piezas] [Nuevo] / 3p-Lift Assist Cylinder [Component Parts] [New]
Bajar Vinculo [Ec] [Uk] [Ita] / Lower Link [Ec] [Uk] [Ita]
Bajar Vinculo [Se] [Tur] / Lower Link [Se] [Tur]
Estabilizador / Stabilizer
Ascenso Varilla Derecho / Lift Rod Rh
Barra De Remolque Soporte [Ec] [Uk] / Drawbar Bracket [Ec] [Uk]
Barra De Remolque Soporte [Se] [Tur] / Drawbar Bracket [Se] [Tur]
Barra De Remolque Soporte [Ita] / Drawbar Bracket [Ita]
Protector De Eje De Tdf [Ec] [Antiguo] / Pto Shaft Protector [Ec] [Old]
Protector De Eje De Tdf [Ec] [Nuevo] / Pto Shaft Protector [Ec] [New]
Protector De Eje De Tdf [Se] [Tur] [Antiguo] / Pto Shaft Protector [Se] [Tur] [Old]
Protector De Eje De Tdf [Se] [Tur] [Nuevo] / Pto Shaft Protector [Se] [Tur] [New]
Protector De Eje De Tdf [Ita] / Pto Shaft Protector [Ita]
Capo (Capo) Superior / Hood (Bonnet) Upper
Capo (Capo) Lado Cubierta / Hood (Bonnet) Side Cover
Capo Soporte [Antiguo] / Bonnet Support [Old]
Capo Soporte [Nuevo] / Bonnet Support [New]
Cabina Bastidor [Ec] [Uk] [Se] [Tur] [Antiguo] / Cab Frame [Ec] [Uk] [Se] [Tur] [Old]
Cabina Bastidor [Ec] [Uk] [Se] [Tur] [Nuevo] / Cab Frame [Ec] [Uk] [Se] [Tur] [New]
Cabina Bastidor [Tdf Proporcional] [Ita] [Antiguo] / Cab Frame [G-Pto] [Ita] [Old]
Cabina Bastidor [Tdf Proporcional] [Ita] [Nuevo] / Cab Frame [G-Pto] [Ita] [New]
Capo (Capo) Trasero / Hood (Bonnet) Rear
Adelante Vidrio / Front Glass
Puerta Derecho / Door Rh
Puerta Izqd / Door Lh
Cerradura De Puerta Izqd / Door Lock Lh
Lado Ventana / Side Window
Trasero Ventana / Rear Window
Interno Techo / Inner Roof
Externo Techo / Outer Roof
Asiento [Excepto [Ds]] [Se] [Ita] [Tur] / Seat [Except [Ds]] [Se] [Ita] [Tur]
Piso Estera [Antiguo] / Floor Mat [Old]
Piso Estera [Nuevo] / Floor Mat [New]
Inspeccion Placa [Ec] [Uk] / Inspection Plate [Ec] [Uk]
Inspeccion Placa [Se] [Tur] / Inspection Plate [Se] [Tur]
Inspeccion Placa [Excepto [Ds]] [Ita] / Inspection Plate [Except [Ds]] [Ita]
Inspeccion Placa [Ds] [Ita] / Inspection Plate [Ds] [Ita]
Material Insonoro [Ec] [Uk] [Se] [Tur] / Soundproof Material [Ec] [Uk] [Se] [Tur]
Material Insonoro [Tdf Proporcional] [Ita] / Soundproof Material [G-Pto] [Ita]
Guardabarros Cubierta Derecho [Ds] [Ec] [Uk] [Ita] / Fender Cover Rh [Ds] [Ec] [Uk] [Ita]
Guardabarros Cubierta Derecho [Excepto [Ds]] [Se] [Ita] [Tur] / Fender Cover Rh [Except [Ds]] [Se] [Ita] [Tur]
Guardabarros Cubierta / Fender Cover Lh
Guardabarros / Fender
Herramienta Caja [Antiguo] / Tool Box [Old]
Herramienta Caja [Nuevo] / Tool Box [New]
Aire Acondicionador Conducto / Air Conditioner Duct
Modo Caso / Mode Case
Condensador / Condenser
Aire Acondicionador Manguito/Condensador Manguito [Antiguo] / Air Conditioner Hose/Condenser Hose [Old]
Aire Acondicionador Manguito/Condensador Manguito [Nuevo] / Air Conditioner Hose/Condenser Hose [New]
Compresor / Compressor
Compressor Soporte / Compressor Bracket
Etiquetta (Posterior) [Ec] [Se] [Tur] / Label (Rear) [Ec] [Se] [Tur]
Etiquetta (Posterior) [Ita] / Label (Rear) [Ita]
Kit De Alternador 1 (Alternador) [Opcion] / Alternator Kit 1 (Alternator) [Option]
Alternador Kit 2 (Cable Mazo De Cables) [Opcion] / Alternator Kit 2 (Wire Harness) [Option]
Alternador [Componente Piezas] [Opcion] / Alternator [Component Parts] [Option]
Trasero Limpiaparabrisas Kit [Opcion] / Rear Wiper Kit [Option]
Eje Propulsor Kit [Opcion] [Antiguo] / Drive Shaft Kit [Option] [Old]
Principal Engranaje Cambio Palanca [Opcion] / Main Gear Shift Lever Kit [Option]
Kit De Sustitucion Del Embrague Pto (Embrague/Soporte) [Opcion] [Antiguo] / Pto Clutch Replacement Kit (Clutch/Holder) [Option] [Old]
Kit De Sustitucion Del Embrague Pto (Tubo Respiradero) [Opcion] [Antiguo] / Pto Clutch Replacement Kit (Breather Hose) [Option] [Old]
Tdf (540/1000) Conversion Kit (Engranaje Caja) [Opcion] / Pto (540/1000) Conversion Kit (Gear Case) [Option]
Tdf (540/1000) Conversion Kit (Engranaje) [Opcion] / Pto (540/1000) Conversion Kit (Gear) [Option]
Tdf (540/1000) Conversion Kit (Engranaje) [Ec] [Se] [Ita] [Tur] [Opcion] / Pto (540/1000) Conversion Kit (Gear) [Ec] [Se] [Ita] [Tur] [Option]
Kit De Distribuidor De Servicios Externos (Scd) [Opcion] / Auxiliary Control Valve Kit (Scd) [Option]
Kit De Distribuidor De Servicios Externos (Fd) [Opcion] / Auxiliary Control Valve Kit (Fd) [Option]
Kit De Distribuidor De Servicios Externos (Fc) [Opcion] / Auxiliary Control Valve Kit (Fc) [Option]
Kit De Distribuidor De Servicios Externos (Scd/Fc) [Opcion] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Auxiliar Control Valvula (Scd) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Scd) [Component Parts] [Option]
Auxiliar Control Valvula (Fd) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Fd) [Component Parts] [Option]
Auxiliar Control Valvula (Fc) [Componente Piezas] [Opcion] [Antiguo] / Auxiliary Control Valve (Fc) [Component Parts] [Option] [Old]
Auxiliar Control Valvula (Fc) [Componente Piezas] [Opcion] [Nuevo] / Auxiliary Control Valve (Fc) [Component Parts] [Option] [New]
Auxiliar Control Valvula (Scd/Fc) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Option]
Auxiliar Control Valvula Palanca (Tercero) [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Remolque Freno Valvula Kit 1 (Valvula/Tubo) [Ita] [Opcion] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Ita] [Option]
Remolque Freno Valvula Kit 2 (Tubo) [Ita] [Opcion] / Trailer Brake Valve Kit 2 (Pipe) [Ita] [Option]
Remolque Freno Valvula Kit 3 (Tubo) [Ita] [Opcion] / Trailer Brake Valve Kit 3 (Pipe) [Ita] [Option]
Protector De Eje De Tdf [Se] [Tur] [Opcion] / Pto Shaft Protector Kit [Se] [Tur] [Option]
Volante / Flywheel
Ventilador / Fan
Rele / Relay
