Kubota Tractor M8540DTH Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M8540DTH Tractor
Number of Pages: 672 Pages
Engine 200000 Crankcase
Engine 201000 Oil Pan
Engine 202000 Cylinder Head
Engine 203500 Valve And Rocker Arm
Engine 205000 Head Cover
Engine 208000 Transmission Box Gear Case
Engine 211000 Piston And Crankshaft
Engine 212000 Camshaft And Idle Gear
Engine 213000 Balancer Note 010 And 040 Note Order By
Engine 215000 Flywheel
Engine 220000 Pump Case Pump Housing Note 225,227 And 240 Note Order
Engine 221000 Injection Pump
Engine 223000 Governor
Fork Lever (Governor) Note 010 And 070 Note
Engine 225000 Governor Adjusting Bolt
Engine 231000 Fuel Filter
Engine 240000 Nozzle Holder And Glow
Engine 260000 Thermostat Water Flange And Thermostat
Engine 261000 Water Pump
Engine 271000 Inlet Manifold
Engine 272000 Exhaust Manifold
Engine 272200 EGR Valve
Engine 272300 EGR Cooler
Engine 272600 Turbocharge Turbo Charger
Engine 273001 Air Cleaner
Engine 273500 Air Cleaner Component Parts
Muffler Note 170 And Fig.Nom18000 Ref.No.050 Note Order By
Engine 280000 Oil Pipe (Turbo Charger)
Engine 280300 Oil Pipe (Mechanical Stopwatch) Oil Pipe (Mechanical
Engine 282000 Oil Cooler
Engine 295000 Sensor (Engine) Sensor (Engine)
Engine A01001 Hand Accelerator Lever
Engine A03000 Accelerator Pedal
Fuel System A11001 Fuel Tank
Fuel System A13500 Fuel Supply Fuel Filler
Fuel System A14001 Fuel Pipe
Fuel System A15100 Separator
Fuel System A16101 Separator Component Parts Old Chassis No.
Fuel System A16102 Separator Component Parts New Chassis No.
Cooling Water System A41000 Fan
Cooling Water System A42000 Water Pipe
Cooling Water System A43000 Radiator
Cooling Water System A45000 Reserve Tank
Electrical System A54001 Alternator
Electrical System A55000 Alternator Component Parts
Electrical System A56000 Starter
Electrical System A57000 Starter Component Parts
Electrical System A58000 Battery
Electrical System B00100 Sensor (Engine) Sensor (Engine)
Electrical System B02001 Switch Sensor (Front) (
Electrical System B03001 Switch Sensor (Rear) Switch Sensor
Switch (Control Panel) Switch (Panel Board) Note 030 New Part And Fig.No.M15501
Electrical System B13001 Relay
Electrical System B14000 Dashboard Panel Board
Electrical System B32000 Head Light
Electrical System B32100 Headlight Component Parts Head Light Component
Electrical System B33900 Front Combination Headlight Front Combination
Electrical System B36001 Rear Combination Headlight
Electrical System B36501 License Lamp
Electrical System B37001 Trailer Socket
System B50501 Electrical Wiring (Engine) Note 010,180 And 190
Electric Cables (Body) Electrical Wiring (Main) Note 010 And Fig.No.B50501 Ref.No.180,190
Clutch Housing Old Chassis No. 86785 Note Order Fig.No.C11002 Ref.No.010 And Fig.No.D25802 Ref.No.010,020,030
Gear Clutch Transmission C11002 Clutch Housing New Clutch Housing New Chassis No. 86786
Clutch Gear Clutch Transmission C11100 Shuttle Valve Shuttle Valve
Clutch Gear Clutch Transmission C11300 Shuttle Transmission Box Shuttle Gear
Clutch Gear Clutch Transmission C12500 Shift Cover
Transmission Case Old Chassis No. 87335 Note Order Fig.No.C14002 Ref.No.010 And Fig.No.J30801 Ref.No.150,160
Gear Clutch Transmission C14002 Transmission Case New Transmission Case New Chassis No. 87336
Clutch Gear Clutch Transmission C15001 Gear Housing Rear Cover Transmission Case
Clutch Gear Clutch Transmission C17000 Rear Axle Case
Clutch Gear Clutch Transmission C22000 Damper Disc Damper Disc
Clutch Gear Clutch Transmission C24000 Clutch Pedal
Clutch Gear Clutch Transmission C26500 Valve Lever (Clutch) Valve Lever (Clutch Gear Clutch Transmission D21200 Input Shaft
Clutch Gear Clutch Transmission D21300 Clutch Pack (High Low) Component Parts Clutch
Clutch Gear Clutch Transmission D21700 Shuttle Shaft
Clutch Gear Clutch Transmission D22500 First Shaft
Clutch Gear Clutch Transmission D22700 Second Shaft
Clutch Gear Clutch Transmission D23501 Third Shaft
Clutch Gear Clutch Transmission D25600 Creep Shaft
Shaft Old Drive Shaft Old Chassis No. 86785 Note 010 New Part And Fig.No.U28000 Whole
Clutch Gear Clutch Transmission D25802 Drive Shaft New Drive Shaft New Chassis No. 86786 S.No.
Clutch Gear Clutch Transmission D26000 Bevel Gear
Gear Clutch Transmission D26201 Rear Differential Old Rear Differential Old Chassis No. 87323
Gear Clutch Transmission D26202 Rear Differential New Rear Differential New Chassis No. 87324
Clutch Gear Clutch Transmission D26300 Rear Differential Lock Clutch Rear Differential
Clutch Gear Clutch Transmission D26500 PTO Propeller Shaft
Clutch Gear Clutch Transmission D26601 PTO Clutch Old PTO Clutch Old Chassis No. 87335 S.No.
Clutch Gear Clutch Transmission D26602 PTO Clutch New PTO Clutch New
Chassis No. 87336 S.No.
Transmission D26701 PTO Clutch Component Parts Old PTO Clutch Component Parts Old
Transmission D26702 PTO Clutch Component Parts New PTO Clutch Component Parts New
D26801 PTO Clutch Valve Old PTO Clutch Valve Old Chassis No. 87335 Note Order Fig.No.U33501
Gear Clutch Transmission D26802 PTO Clutch Valve New PTO Clutch Valve New Chassis No. 87336 S.
Clutch Gear Clutch Transmission D27501 PTO Shaft
Clutch Gear Clutch Transmission D35001 Front Drive Clutch Front Drive
Clutch Gear Clutch Transmission D35200 Front Drive Clutch Component Parts Front Drive
Speed Change Shift Fork D41000 Main Transmission
Speed Change Shift Fork D44500 Gear And Crawl Range
Speed Change Shift Fork F11001 Main Gear
Speed Change Shift Fork F11501 Main Transmission
Speed Change Shift Fork F12501 Transmission Shuttle
Gear Speed Change Shift Fork F13300 Shuttle
Speed Change Shift Fork F13601 Gear And Creep Range
Speed Change Shift Fork F15000 PTO Transmission
Rear Axle Brake F18000 Rear Differential Lock Pedal Rear Differential
Rear Axle Brake F20000 Rear Axle
Rear Axle Brake F20600 Brake (Right Side) Brake Rh
Rear Axle Brake F20700 Brake (Left Side) Brake Lh
Rear Axle Brake F21500 Parking Brake Cam Shaft Parking Brake Camshaft
Rear Axle Brake F22001 Parking Brake Lever
Rear Axle Brake F22500 Parking Brake Rod
Rear Axle Brake F23000 Parking Brake
Rear Axle Brake F23500 Brake Pedal
Rear Axle Brake F31000 Brake Oil Tank Brake Oil Tank
Rear Axle Brake F32000 Brake Master Cylinder Component Parts Brake Master Cylinder
Rear Axle Brake F33000 Brake Pipe
Front Axle Chassis G10501 Front Axle Frame
Front Axle Chassis G11000 Front Axle Housing Bracket Front Axle
Front Axle Chassis G14000 Propeller Shaft Front Propeller
Front Axle Chassis G15000 Front Differential Housing Front Differential
Front Axle Chassis G16000 Slant Transmission (Front) Bevel Gear (
Front Axle Chassis G17000 Front Differential Differential Front
Front Axle Chassis G22100 Slant Transmission Housing (Right Side) Bevel
Front Axle Chassis G22201 Slant Transmission Housing (Left Side) Bevel
Front Axle Chassis G22300 Front Axle Housing (Right Side) Front Axle
Front Axle Chassis G22400 Front Axle Housing (Left Side) Front Axle
Front Axle Chassis G22800 Differential Transmission Shaft (Right Side) Differential
Front Axle Chassis G22900 Differential Transmission Shaft (Left Side) Differential
Front Axle Chassis G24100 Front Axle (Right Side) Front Axle Rh
Front Axle Chassis G24200 Front Axle (Left Side) Front Axle Lh
Steering H11001 Steering Handle Not 110 Ve 130 Note
Steering H12000 Slide Pedal Tilt Pedal
Steering H13000 Steering Joint
Steering H14000 Steering Control Steering Controller
H15001 Steering Control Component Parts Old Steering Controller Component Parts Old
H15002 Steering Control Component Parts New Steering Controller Component Parts New
Steering H16001 Rubber Rod Steering Cylinder Tie Rod Steering
Steering H16500 Steering Cylinder Component Parts
Hydraulic System J13000 Hydraulic Pump
Hydraulic System J13500 Hydraulic Pump
System J22001 Hydraulic Oil Line (Feed) Pipe (Delivery) Note 060 And 070
Hydraulic System J22300 Hydraulic Pipe (Trailer Brake)
Hydraulic System J23700 Trailer Brake Valve
Hydraulic System J26501 Oil Cooler
J27501 Hydraulic Pipe (Steering PTO) Hydraulic Oil Line (Steering PTO) Note 080 Ve
Hydraulic System J27600 Hydraulic Pipe (Shuttle PTO) Hydraulic Oil Line (
Hydraulic System J28000 Steering Hose (Delivered) Steering Hose
Hydraulic System J30801 Hydraulic Cylinder Housing Old Hydraulic
Hydraulic System J30802 Hydraulic Cylinder Housing New Hydraulic
Hydraulic System J31500 Hydraulic Piston Lifting Arm Hydraulic
Hydraulic System J31700 Safety Valve Relief Valve Safety Valve
Hydraulic System J32300 Lowering Adjustment Valve Lowering Lock Lever
Hydraulic System J35500 Control Valve
Hydraulic System J37800 Position Control Lever Position Control
Hydraulic System J38001 Draft And Position Control Lever Position
Cylinder Housing Old Position And Draft Shaft Old Chassis No. 83375 Note Order Fig.No.J38202 Ref.No.120
Hydraulic System J38202 Hydraulic Cylinder Housing New Position And Draft Shaft New Chassis No.
Hydraulic System J39200 Feed Back Lever
Hydraulic System J44501 Remote Control Valve EC Auxiliary Control
Hydraulic System J44502 Remote Control Valve Se Tur Auxiliary Control
J44701 Remote Control Valve (FD) Component Parts Old Auxiliary Control Valve (FD) Component
J44702 Remote Control Valve (FD) Component Parts New Auxiliary Control Valve (FD) Component
Hydraulic System J44703 Remote Control Valve (S D) Component Parts Auxiliary Control
Hydraulic System J45500 Assist Control Valve Lever Auxiliary Control
Hydraulic System J47101 3p-Left Lift Assist Cylinder Old 3p-Lift Assist Cylinder Lh Old Chassis No.
Hydraulic C System J47102 3p-Left Lift Support Cylinder New 3p-Lift Assist Cylinder Lh New Chassis
Hydraulic System J47200 3p-Right Lift Support Cylinder 3p-Lift Assist
J47301 3p-Lift Support Cylinder Component Parts Old 3p-Lift Assist Cylinder Component Parts
J47302 3p-Lift Support Cylinder Component Parts New 3p-Lift Assist Cylinder Component Parts
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K10500 Upper Link Bracket
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K11000
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K12500 Old Baj Lower
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K13300 Stabilizer
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14000 Right Draw Shaft
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14300 Left Draw Shaft
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L10501 Drawing Bar Bracket EC
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L10502 Drawing Bar Bracket Se Tur
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L17001 PTO Protective EC Pto
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L17002 PTO Protection Se Tur Pto
Hood Bonnet M11000 Front Grille
Hood Bonnet M12000 Hood (Bonnet) Upper
Bone Hood (Sound Absorbing Damper Material) Old Hood (Bonnet) Upper (Sound Absorber Insulator) Old
Bone Hood (Bonnet) Upper (Sound Absorber Insulator) New
Hood Bonnet M12300 Hood (Bonnet) Damper
Hood Bonnet M12400 Bone Lock Bonnet Lock
Hood Bonnet M12700 Bone Side Cover Hood (Bonnet) Side Cover
Hood Bonnet M14001 Bone Support Bonnet Support
M15501 Hood (Bone) Rear Hood (Bonnet) Rear Not Order Fig.No.B10501 Ref.No.030 Note
Hood Bonnet M17500 Hood (Bonnet) Rear (Sound Absorber) Hood (Bonnet) Rear (Sound
Rearview Mirror Note 050 And Fig.No275000 Ref.No.170 Note
Hood Bonnet M22001 Fender Note 010 And 015 Note Order By
Hood Bonnet M22201 Slide Cover Shift Lever Guide
Hood Bonnet M22300 Floor Sheet
Hood Bonnet M22400 Floor Sheet (Sound Absorber)
Hood Bonnet M23301 Step
Hood Bonnet M23401 Auxiliary Step Auxiliary Step
Hood Bonnet M23501 Seat EC Seat EC
Hood Bonnet M23502 Seat Se Tur Seat Se Tur
Hood Bonnet M27001 Tool Box
ROPS M31101 ROPS (Middle) ROPS (Upper)
ROPS M31201 ROPS (Rear) ROPS (Lower)
Labels S12001 Label (Front)
Labels S13000 Label (Panel) Label (Panel)
Labels S14001 Label (Back) Label (Rear)
Accessories Service Parts Accessories And Service Parts T11000 Accessories Service Parts Accessories
Option U11000 Alternator Kit Option Alternator Kit Option
Option U11300 Alternator Component Parts Option Alternator Component
Option U13001 Work Light Kit Option Working Light Kit Option
Option U28000 Drive Shaft Kit Option Old Drive Shaft Kit Option Old Chassis No. 83872 S.No.
Clutch Replacement Kit (Clutch Holder) Option Old PTO Clutch Replacement Kit (Cluch Holder) Option
Replacement Kit (Breather Hose) Option Old PTO Clutch Replacement Kit (Breather Hose)
Option U35000 PTO (540 1000) Conversion Kit (Gearbox) Option PTO (540 1000) Conversion
Option U35100 PTO (540 1000) Conversion Kit (Gear) Option PTO (540 1000) Conversion
Option U35200 PTO (540 1000) Conversion Kit (Gear) Option PTO (540 1000) Conversion
Option U70001 Support Control Valve Kit (SCD) Option Auxiliary Control Valve Kit
Kit (FD) Option Old Auxiliary Control Valve Kit (FD) Option Old Chassis No. 83059 Components For
Kit (FD) Option New Auxiliary Control Valve Kit (FD) Option New Chassis No. 83060 Components For
Option U70004 Support Control Valve Kit (FC) Option Auxiliary Control Valve Kit
Option U70006 Support Control Valve Kit (SCD FC) Option Auxiliary Control Valve
Option U70501 Support Control Valve (SCD) Component Parts Option Auxiliary Control Valve (
Control Valve (FC) Component Parts Option Old Auxiliary Control Valve (FC) Component Parts
Control Valve (FC) Component Parts Option New Auxiliary Control Valve (FC) Component Parts
Option U70504 Support Control Valve (SCD FC) Component Parts Option Auxiliary Control Valve (
Option U71000 Support Control Valve Lever Kit (Third) Option Auxiliary Control Valve
Pto Shaft Protector Kit Se Tur Option Old PTO Shaft Protector Kit Se Tur Option Old Chassis
Option U90501 Step Support Kit Option Old Step Support Kit Option Old Chassis No. 80882 S.No.
Region: Turkey
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
