Kubota Tractor M8540DTH Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M8540DTH Tractor
Number of Pages: 629 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Compensador / Balancer
Volante / Flywheel
Bomba Carcasa / Pump Housing
Bifurcacion Palanca (Regulador) / Fork Lever (Governor)
Regulador Ajuste Tornillo / Governor Adjusting Bolt
Inyector Y Bujia Precalent / Nozzle Holder And Glow Plug
Agua Bomba / Water Pump
Valvula De Egr / Egr Valve
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Pipa Del Aceite (Contador De Tiempo Mecanico) / Oil Pipe (Mechanical Timer)
Sensor (Motor) / Sensor (Engine)
Palanca De Acelerador De Mano / Hand Accelerator Lever
Llenador Del Combustible / Fuel Filler
Separador / Separator
Separador [Componente Piezas] [Antiguo] / Separator [Component Parts] [Old]
Separador [Componente Piezas] [Nuevo] / Separator [Component Parts] [New]
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador/Sensor (Adelante) / Switch/Sensor (Front)
Conmutador/Sensor (Trasero) / Switch/Sensor (Rear)
Rele / Relay
Tablero Panel / Panel Board
Culata Luz / Head Light
Culata Luz [Componente Piezas] / Head Light [Component Parts]
Adelante Combinacion Luz / Front Combination Light
Luces Combinadas Traseras / Rear Combination Light
Licencia Lampara / License Lamp
Electrico Cableado (Motor) / Electrical Wiring (Engine)
Electrico Cableado (Cuerpo) / Electrical Wiring (Main)
Carcasa De Embrague [Antiguo] / Clutch Housing [Old]
Carcasa De Embrague [Nuevo] / Clutch Housing [New]
Caja De Engranajes De Inversor / Shuttle Gear Case
Transmision Caja [Antiguo] / Transmission Case [Old]
Transmision Caja [Nuevo] / Transmission Case [New]
Valvula Palanca (Embrague) / Valve Lever (Clutch)
Eje De Entrada / Input Shaft
Embrague De Hi-Lo (Inversor) [Componente Piezas] / Clutch Pack (Shuttle) [Component Parts]
Inversor Eje / Shuttle Shaft
Primer Eje / First Shaft
Segundo Eje / Second Shaft
Tercero Eje / Third Shaft
Eje Propulsor [Antiguo] / Drive Shaft [Old]
Eje Propulsor [Nuevo] / Drive Shaft [New]
Eje De Engranaje Diferencial / Bevel Gear
Diferencial Trasero [Antiguo] / Rear Differential [Old]
Diferencial Trasero [Nuevo] / Rear Differential [New]
Trasero Diferencial Cerradura Embrague / Rear Differential Lock Clutch
Eje Propulsor De Tdf / Pto Propeller Shaft
Embrague De Tdf [Antiguo] / Pto Clutch [Old]
Embrague De Tdf [Nuevo] / Pto Clutch [New]
Embrague De Tdf [Componente Piezas] [Antiguo] / Pto Clutch [Component Parts] [Old]
Embrague De Tdf [Componente Piezas] [Nuevo] / Pto Clutch [Component Parts] [New]
Valvula De Embrague De Tdf [Antiguo] / Pto Clutch Valve [Old]
Valvula De Embrague De Tdf [Nuevo] / Pto Clutch Valve [New]
Tdf Eje / Pto Shaft
Adelante Accionar Embrague [Componente Piezas] / Front Drive Clutch [Component Parts]
Horquilla De Cambio Principal / Main Gear Shift Fork
Gama Y Arrastramiento Engranaje Cambio Bifurcacion / Range And Creep Gear Shift Fork
Palanca De Cambio Principal / Main Gear Shift Lever
Varilla De Cambio Principal / Main Gear Shift Rod
Inversor Cambio Palanca / Shuttle Shift Lever
Cable De Inversor / Shuttle Cable
Palanca De La Cambio De Engran. De La Gama Y Arrastramiento / Range And Creep Gear Shift Lever
Freno Derecho / Brake Rh
Freno Izquierdo / Brake Lh
Arbol De Levas Del Freno De Estacionamiento / Parking Brake Camshaft
Varilla De Freno De Estacionamiento / Parking Brake Rod
Estacionamiento Freno / Parking Brake
Freno Pedal / Brake Pedal
Deposito De Aceite De Freno / Brake Oil Tank
Tubo De Freno / Brake Pipe
Soporte De Eje Delantero / Front Axle Bracket
Eje Propulsor / Front Propeller Shaft
Engranaje Conico (Adelante) / Bevel Gear (Front)
Caja De Engranaje Conico Dcha / Bevel Gear Case Rh
Caja De Engranaje Conico Izqd / Bevel Gear Case Lh
Diferencial Engranaje Eje Derecho / Differential Gear Shaft Rh
Direccion Controlador / Steering Controller
Direccion Controlador [Componente Piezas] [Antiguo] / Steering Controller [Component Parts] [Old]
Direccion Controlador [Componente Piezas] [Nuevo] / Steering Controller [Component Parts] [New]
Hidraulico Bomba / Hydraulic Pump
Tubo Hidraulico (Impulsion) / Hydraulic Pipe (Delivery)
Hidraulico Tubo (Remolque Freno) / Hydraulic Pipe (Trailer Brake)
Remolque Freno Valvula / Trailer Brake Valve
Linea De Aceite Hidraulico (Direccion/Tdf) / Hydraulic Oil Line (Steering/Pto)
Hidraulico Aceite Linea (Inversor/Pto) / Hydraulic Oil Line (Shuttle/Pto)
Latiguillo De Direccion (Impulsion) / Steering Hose (Delivery)
Cilindro Hidraulico [Antiguo] / Hydraulic Cylinder Case [Old]
Cilindro Hidraulico [Nuevo] / Hydraulic Cylinder Case [New]
Piston Hidraulico/Brazo De Elevacion / Hydraulic Lift Arm
Coloque La Palanca De Mando / Position Control Lever
Palanca De Control De Esfuerzo Y Posicion / Draft And Position Control Lever
Posicion Y Esfuerzo Eje [Antiguo] / Position And Draft Shaft [Old]
Posicion Y Esfuerzo Eje [Nuevo] / Position And Draft Shaft [New]
Distribuidor De Servicios Externos [Ec] / Auxiliary Control Valve [Ec]
Distribuidor De Servicios Externos [Se] [Tur] / Auxiliary Control Valve [Se] [Tur]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Antiguo] / Auxiliary Control Valve (Fd) [Component Parts] [Old]
Distribuidor De Servicios Externos (Fd) [Componente Piezas] [Nuevo] / Auxiliary Control Valve (Fd) [Component Parts] [New]
Distribuidor De Servicios Externos (S/D) [Componente Piezas] / Auxiliary Control Valve (S/D) [Component Parts]
Palanca De Distribuidor De Servicios Externos / Auxiliary Control Valve Lever
Cilindro De Ayuda De Elevacion Izquierdo [Antiguo] / 3p-Lift Assist Cylinder Lh [Old]
Cilindro De Ayuda De Elevacion Izquierdo [Nuevo] / 3p-Lift Assist Cylinder Lh [New]
Cilindro De Ayuda De Elevacion [Componente Piezas] [Antiguo] / 3p-Lift Assist Cylinder [Component Parts] [Old]
Cilindro De Ayuda De Elevacion [Componente Piezas] [Nuevo] / 3p-Lift Assist Cylinder [Component Parts] [New]
Soporte De Tercer Punto / Top Link Bracket
3-Punto Varillaje / Lower Link
Estabilizador / Stabilizer
Varilla De Elevacion Izqd / Lift Rod Lh
Ayudar Cilindro Soporte [Ec] / Drawbar Bracket [Ec]
Ayudar Cilindro Soporte [Se] [Tur] / Drawbar Bracket [Se] [Tur]
Protector De Eje De Tdf [Ec] / Pto Shaft Protector [Ec]
Protector De Eje De Tdf [Se] [Tur] / Pto Shaft Protector [Se] [Tur]
Capo Superior / Hood (Bonnet) Upper
Capo Superior (Amortiguador Sano/Aislador) [Antiguo] / Hood (Bonnet) Upper (Sound Absorber/Insulator) [Old]
Capo Superior (Amortiguador Sano/Aislador) [Nuevo] / Hood (Bonnet) Upper (Sound Absorber/Insulator) [New]
Tapa Lateral De Capo / Hood (Bonnet) Side Cover
Soporte De Capo / Bonnet Support
Capo Posterior / Hood (Bonnet) Rear
Capo Trasero (Amortiguador Sano) / Hood (Bonnet) Rear (Sound Absorber)
Guardabarros / Fender
Cambie De Puesto La Cubierta / Shift Lever Guide
Hoja De Piso / Floor Sheet
Hoja De Piso (Amortiguador Sano) / Floor Sheet (Sound Absorber)
Peldano / Step
Auxiliar Peldano / Auxiliary Step
Asiento [Ec] / Seat [Ec]
Asiento [Se] [Tur] / Seat [Se] [Tur]
Caja De Herramientas / Tool Box
Rops (Superior) / Rops (Upper)
Rops (Bajar) / Rops (Lower)
Etiquetta (Panel) / Label (Panel)
Etiquetta (Trasero) / Label (Rear)
Kit De Alternador [Opcion] / Alternator Kit [Option]
Alternador [Componente Piezas] [Opcion] / Alternator [Component Parts] [Option]
Ele Helice [Opcion] [Antiguo] / Drive Shaft Kit [Option] [Old]
Kit De Sustitucion Del Embrague Pto (Embrague/Soporte) [Opcion] [Antiguo] / Pto Clutch Replacement Kit (Cluch/Holder) [Option] [Old]
Kit De Sustitucion Del Embrague Pto (Tubo Respiradero) [Opcion] [Antiguo] / Pto Clutch Replacement Kit (Breather Hose) [Option] [Old]
Tdf (540/1000) Conversion Kit (Engranaje Caja) [Opcion] / Pto (540/1000) Conversion Kit (Gear Case) [Option]
Tdf (540/1000) Conversion Kit (Engranaje) [Opcion] / Pto (540/1000) Conversion Kit (Gear) [Option]
Kit De Distribuidor De Servicios Externos (Scd) [Opcion] / Auxiliary Control Valve Kit (Scd) [Option]
Kit De Distribuidor De Servicios Externos (Fd) [Opcion] [Antiguo] / Auxiliary Control Valve Kit (Fd) [Option] [Old]
Kit De Distribuidor De Servicios Externos (Fd) [Opcion] [Nuevo] / Auxiliary Control Valve Kit (Fd) [Option] [New]
Kit De Distribuidor De Servicios Externos (Fc) [Opcion] / Auxiliary Control Valve Kit (Fc) [Option]
Kit De Distribuidor De Servicios Externos (Scd/Fc) [Opcion] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Distribuidor De Servicios Externos (Scd) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Scd) [Component Parts] [Option]
Distribuidor De Servicios Externos (Fc) [Componente Piezas] [Opcion] [Antiguo] / Auxiliary Control Valve (Fc) [Component Parts] [Option] [Old]
Distribuidor De Servicios Externos (Fc) [Componente Piezas] [Opcion] [Nuevo] / Auxiliary Control Valve (Fc) [Component Parts] [Option] [New]
Distribuidor De Servicios Externos (Scd/Fc) [Componente Piezas] [Opcion] / Auxiliary Control Valve (Scd/Fc) [Component Parts] [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercero) [Opcion] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Protector De Eje De Tdf [Se] [Tur] [Opcion] [Antiguo] / Pto Shaft Protector Kit [Se] [Tur] [Option] [Old]
Apoyo Del Paso [Opcion] [Antiguo] / Step Support Kit [Opion] [Old]
