Kubota Tractor M8200SDTN-CAB Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M8200SDTN-CAB Tractor
Number of Pages: 298 Pages
Itens Uso Freque Nte / Frequently Used Items
Bloco Motor / Crankcase [Cab Type]
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head [Cab Type]
Carreto / Gear Case
Tampa Cabeça / Head Cover [Old Type]
Tampa Cabeça / Head Cover [New Type]
Volante Motor / Flywheel
Compensador / Balancer
Regulador / Governor [Cab Type]
Valvula Solenoide / Nozzle Holder And Glow Pl Ug
Suporte Bico [Peças Componentes] / Nozzle Hol Der [Component Parts]
Caixa Da Bomba / Pump Housing [Cab Type]
Alavanca Do Garfo (Governador) / Fork Lever ( Governor)
Parafuso De Ajuste De Governador / Governor A Djusting Bolt [Old Type]
Parafuso De Ajuste De Governador / Governor A Djusting Bolt [New Type]
Filtro Gasoleo / Fuel Filter
Bomba Agua E Termostacto / Water Flange And T Hermostat [Cab Type]
Bomba Agua / Water Pump [Cab Type]
Válvula E Veio Do Balanceiro / Valve And Rock Er Arm
Filtro Ar / Air Cleaner [Cab Type]
Escpae / Muffler
Actuador / Actuator
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler [Cab Type]
Kit De Juntas Superior (Tipo Antigo) / Upper Gasket Kit [Old Type]
Kit De Juntas Superior (Novo Tipo) / Upper Ga Sket Kit [New Type]
Deposito Combustivel / Lower Gasket Kit
Acelarador Mao / Hand Accelerator Lever [Cab Type]
Deposito Combustivel / Fuel Tank [Cab Type]
Suporte Deposito Combus Tivel / Fuel Tank Bracket [Cab Type]
Deposito Combustivel (D Rt) / Fuel Tank Rh [Cab Type]
Deposito Combustivel (E Sq) / Fuel Tank Lh [Cab Type]
Tubo Combustivel / Fuel Pipe 1 (Rear) [Cab Type]
Separador / Separator [ Cab Type]
Separador[Peças Compone Ntes] / Separator [Component Parts]
Vento Inha / Fan [Cab Type]
Tubo Agua / Water Pipe [Cab Type]
Radia Dor / Radiator [Cab Type]
Depos Ito Reserva / Reserve Tank [Cab Type]
Alternador / Alternato R [Cab Type]
Alternador [Peças Comp Onentes] / Alternator [Component Parts] [Cab Type]
Motor Arranque / Start Er
Motor Arranque [Compon Entes] / Starter [Component Parts]
Bateria / Battery [Cab Type]
Interruptor/Sensor / S Witch/Sensor [Cab Type]
Interruptor / Switch ( Panel Board) [Cab Type]
Interruptor / Switch [ Cab Type]
Rele / Relay [Cab Type ]
Painel / Panel Board [ Cab Type]
Painel[Peças Component Es] / Panel Board [Component Parts]
Farol Dianteiro / Head Light
Luzes Trabalho / Work Light [Cab Type]
Braco Traseiro / Rear Combination Light [Cab Type]
Luz Interior / Room Li Ght [Cab Type]
Deposito Limpa Parabr Isas / Washer Tank [Cab Type]
Escova Limpa Vidros / Wiper [Cab Type]
Cablagem Electrica / E Lectrical Wiring 1 [Cab Type]
Cabalagem Eletrica(Cab Ine)[Ec] [G] / Electrical Wiring [Cab Type]
Carter Embraiag Em / Clutch Housing [New Type]
Carretos Invers Or / Shuttle Gear Case [New Type]
Caixa Velocidad Es / Transmission Case
Carter Transmis Sao / Transmission Case Rear Cover [New Type]
Carter Eixo / R Ear Axle Case
Caixa Da Transm Issão Dianteira / Front Drive Case
Compensador / C Lutch
Forqueta Embrai Agem / Clutch Release Fork [New Type]
Pedal Embraiage M / Clutch Pedal [Cab Type]
Veio Primario / Input Shaft [New Type]
Primeiro Veio / First Shaft [New Type]
Secundario Veio / Second Shaft [New Type]
Terceiro Veio / Third Shaft [New Type]
Back Idle Shaft [New Type] / Back Idle Shaft [New Type]
Veio Creeper / Creep Shaft
Grupo Conico / Bevel Gear [Old Type]
Diferencial Tra Seiro / Differential Rear
Embraiagem Tdf / Pto Clutch [New Type]
Embraiagem Tdf[ Peças Componentes] / Pto Clutch [Component Parts] [ New Type]
Valvula Embraia Gem Tdf / Pto Clutch Valve
Valvula Embraia Gem Tdf[Peças Componentes] / Pto Clutch Valve [Com Ponent Parts]
Veio Tdf / Pto Shaft
Veio Primario ( Traseira) / Front Propeller Shaft (Rear)
Embraiagem Hidr Aulica (Bi Speed) / Hydraulic Clutch (Bi-Speed Turn )
Forqueta / Main Gear Shift Fork [New Type]
Forquilha Inver Sor / Shuttle Gear Shift Fork [Cab Type]
Forqueta Caixa / Creeper / Range Gear Shift Fork
Alavanca / Rear Differential Lock Shift Fork
Eixo Traseiro / Rear Axle
Travão / Brake
Brake Rod 1 [Cab Typ E] / Brake Rod 1 [Cab Type]
Brake Rod 2 [Cab Typ E] / Brake Rod 2 [Cab Type]
Alavanca Velocidades / Main Gear Shift Lever [Cab Type]
Alvanca Inversor / S Huttle Shift Lever [Cab Type]
Alavanca Velocidades / Range Gear Shift Lever [Cab Type]
Tirante Velocidades / Range Gear Shift Rod [Cab Type]
Alavanca Embraiagem Tdf / Pto Clutch Lever [Cab Type]
Alavanca Tdf / Pto G Ear Shift Lever
Alavanca Travao Mao / Parking Brake Lever [Cab Type] [New Type]
Pedal Travao / Brake Pedal
Pedal Bloqueio Difer Encial Traseiro / Rear Differential Lock Pedal [Cab Type]
Suporte Eixo Fren Te / Front Axle Frame [Cab Type]
Suporte Eixo Dian Teiro / Front Axle Bracket [Cab Type]
Carter Eixo / Fro Nt Axle Case
Veio Primario / F Ront Propeller Shaft [Cab Type]
Engrenagem Cónica (Dianteira) / Bevel Gear (Front)
Diferencial Diant Eiro / Differential Front
Carter Grupo Coni Co / Bevel Gear Case
Grupo Conico / Di Fferential Gear Shaft
Eixo Dianteiro / Front Axle
Punho Volante / Steering Handle [Cab Typ E]
Distribuidor Direcção(Nova) / Steering C Ontroller [Cab Type]
Distribuidor Direcção[Peças Componentes] / Steering Controller [Component Parts]
Direcção / Steering Linkage
Cilindro Direcção[Peças Componentes] / S Teering Cylinder [Component Parts]
Bomba Hidraulico / Hyd Raulic Pump
Bomba Hidraulico[Peças Componentes] / Hydraulic Pump [Component Parts]
Circuito Oleo Direcção / Hydraulic Oil Line (Steering/Pto) [Cab Type]
Tubo Direccao / Steeri Ng Hose (Delivery) [Cab Type]
Solenoid Valve / Solen Oid Valve
Cilindro Hidraulico / Hydraulic Cylinder [Cab Type]
Braço De Elevação Hidr Áulico / Hydraulic Lift Arm
Resguardo Cilindro Hid Ráulico / Hydraulic Cylinder Cover [Cab Type]
Braco Hidraulico / Con Trol Valve
Alavanca Control Esfor Ço / Draft And Position Control Lever [Cab Type]
Puxar E Posicionar Sup Orte De Alavanca De Controlo / Draft And Position C Ontrol Lever Bracket
Position Control Shaft / Position Control Shaft
Draft Control Shaft / Draft Control Shaft
Alavanca / Feed Back L Ever [Cab Type]
Distribuidor Auxiliar / Auxiliary Control Valve [Cab Type]
Acessorios / Auxiliary Control Valve [Component Parts]
Parte Superior / Top L Ink Bracket
Ligacao Superior / Top Link [Cab Type]
Ligacao Inferior / Low Er Link
Estabilizador(Drt) / L Ift Rod Rh
Estabilizador(Esq) / L Ift Rod Lh
B Arra De Engate Oscilante / Swinging Drawbar
P Roteccao Tdf / Pto Shaft Protector
Hood(Bonnet) Front [Cab Type] / Hood(Bon Net) Front [Cab Type]
Capot Superior / Hood(Bonnet) Upper [Cab Type]
Lado Do Capot / Hood(Bonnet) Side [Cab T Ype]
Capot Lateral / Hood(Bonnet) Side Cover [Cab Type]
Suporte Capot / Bonnet Support [Cab Type ]
Capot Traseiro / Hood(Bonnet) Rear [Cab Type]
Estrutura Cabine / Cab Frame [Cab Type]
Kit Limpa Vidro Traseiros (Opcao) / Pane L Frame [Cab Type]
Vidro Frente E Traseiro / Front Glass [C Ab Type]
Porta(Drt) / Door Rh [Cab Type]
Porta(Esq) / Door Lh [Cab Type]
Trinco Porta(Drt) / Door Lock Rh [Cab Ty Pe]
Trinco Porta(Esq) / Door Lock Lh [Cab Ty Pe]
Lado Vidro / Side Window [Cab Type]
Vidro Traseiro / Rear Window [Cab Type]
Espelho Rectrovisor / Rearview Mirror [C Ab Type]
Tecto Interior / Inner Roof [Cab Type]
Tejadilho Exterior / Outer Roof [Cab Typ E]
Banco / Seat [Cab Type]
Piso / Floor Mat [Cab Type]
Guarda Lamas / Fender [Cab Type]
Suporte Cabine(Dianteiro) / Cab Bracket Front [Cab Type]
Suporte Cabine(Traseiro) / Cab Bracket R Ear [Cab Type]
Caixa Ferramenta / Tool Box [Cab Type]
Air Condicionado / Air Co Nditioner [Cab Type]
Tubo Aquecimento / Heater Hose [Cab Type]
Condesador / Condenser [C Ab Type]
Compressor / Compressor [ Cab Type]
Suporte Compressor / Comp Ressor Bracket [Cab Type]
Fron T Wheel Disk [Except[Fr]] / Front Wheel Disk [Excep T[Fr]]
Rear Wheel Disk [Except[Fr]] / Rear Wheel Disk [Except[ Fr]]
Etiqueta (Dianteira) / Label 1 [C Ab Type]
Etiqueta / Label 2 [Cab Type]
Acessorios / Accessories And Servic E Parts
Trailer Socket Kit [Option][Cab Type] [Except [Fr]] / Trailer Socket Kit [Option][Cab Type] [Exce Pt[Fr]]
Kit Radio Cassete / Radio Cassette Kit [Optio N] [Cab Type]
Rear Wiper Kit [Option] [Cab Type] / Rear Wip Er Kit [Option] [Cab Type]
Auxiliary Control Valve Kit [Option] [Cab Typ E] / Auxiliary Control Valve Kit [Option] [Cab Type ]
Rearview Mirror Kit [Option] [Cab Type] / Rea Rview Mirror Kit [Option] [Cab Type]
