Kubota Tractor M8200SDTN-CAB Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M8200SDTN-CAB Tractor
Number of Pages: 505 Pages
Bloque Motor[Tipo Cabina] / Crankcase [Cab Type]
Aceite Cacerola / Oil Pan
Culata[Tipo Cabina] / Cylinder Head [Cab Type]
Tapa De Balancines[Tipo Antiguo] / Head Cover [Old Type]
Tapa De Balancines[Tipo Nuevo] / Head Cover [New Type]
Volante / Flywheel
Compensador / Balancer
Regulador[Tipo Cabina] / Governor [Cab Type]
Carcasa De Bomba[Tipo Cabina] / Pump Housing [Cab Type]
Bifurcacion Palanca(Regulador) / Fork Lever (Governor)
Tornillo De Ajuste De Regulador[Tipo Antiguo] / Governor Adjusting Bolt [Old Type]
Tornillo De Ajuste De Regulador[Tipo Nuevo] / Governor Adjusting Bolt [New Type]
Brida De Agua Y Termostato[Tipo Cabina] / Water Flange And Thermostat [Cab Type]
Bomba De Agua[Tipo Cabina] / Water Pump [Cab Type]
Filtro De Aire[Tipo Cabina] / Air Cleaner [Cab Type]
Aire Limpiador[Componente Piezas] / Air Cleaner [Component Parts]
Silenciador / Muffler
Actuador / Actuator
Aceite Tubo(Turbo Cargador) / Oil Pipe (Turbo Charger)
Hidraulico Bomba Base / Hydraulic Pump Base
Radiador De Aceite[Tipo Cabina] / Oil Cooler [Cab Type]
Kit De Juntas Superior[Tipo Antiguo] / Upper Gasket Kit [Old Type]
Kit De Juntas Superior[Tipo Nuevo] / Upper Gasket Kit [New Type]
Actuador / Actuator
Palanca De Acelerador De Mano[Tipo Cabina] / Hand Accelerator Lever [Cab Type]
Deposito De Combustible[Tipo Cabina] / Fuel Tank [Cab Type]
Soporte De Deposito De Combustible[Tipo Cabina] / Fuel Tank Bracket [Cab Type]
Deposito De Combustible Dcha[Tipo Cabina] / Fuel Tank Rh [Cab Type]
Deposito De Combustible Izqd[Tipo Cabina] / Fuel Tank Lh [Cab Type]
Tubo De Combustible 1(Posterior)[Tipo Cabina] / Fuel Pipe 1 (Rear) [Cab Type]
Tubo De Combustible 2(Anterior)[Tipo Cabina] / Fuel Pipe 2 (Front) [Cab Type]
Decantador[Tipo Cabina] / Separator [Cab Type]
Separador[Componente Piezas] / Separator [Component Parts]
Ventilador[Tipo Cabina] / Fan [Cab Type]
Tubo De Agua[Tipo Cabina] / Water Pipe [Cab Type]
Radiador[Tipo Cabina] / Radiator [Cab Type]
Deposito De Reserva[Tipo Cabina] / Reserve Tank [Cab Type]
Alternador[Tipo Cabina] / Alternator [Cab Type]
Alternador[Componente Piezas][Tipo Cabina] / Alternator [Component Parts] [Cab Type]
Motor De Arranque / Starter
Conmutador/Sensor[Tipo Cabina] / Switch/Sensor [Cab Type]
Conmutador(Tablero De Instrumentos)[Tipo Cabina] / Switch (Panel Board) [Cab Type]
Conmutador[Tipo Cabina] / Switch [Cab Type]
Rele[Tipo Cabina] / Relay [Cab Type]
Tablero De Instrumentos[Tipo Cabina] / Panel Board [Cab Type]
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz / Head Light
Luz Intermitente[Tipo Cabina] / Flasher Light [Cab Type]
Faro De Labor[Tipo Cabina] / Work Light [Cab Type]
Luces Combinadas Traseras[Tipo Cabina] / Rear Combination Light [Cab Type]
Luz De Habitaculo[Tipo Cabina] / Room Light [Cab Type]
Deposito De Lavaparabrisas[Tipo Cabina] / Washer Tank [Cab Type]
Limpiaparabrisas[Tipo Cabina] / Wiper [Cab Type]
Cableado Electrico 1[Tipo Cabina] / Electrical Wiring 1 [Cab Type]
Cableado Electrico[Tipo Cabina] / Electrical Wiring [Cab Type]
Carcasa De Embrague[Tipo Nuevo] / Clutch Housing [New Type]
Caja De Engranajes De Inversor[Tipo Nuevo] / Shuttle Gear Case [New Type]
Cubierta Trasera De Caja De Transmision[Tipo Nuevo] / Transmission Case Rear Cover [New Type]
Trasero Eje Caja / Rear Axle Case
Adelante Accionar Caja / Front Drive Case
Embrague / Clutch
Horquilla De Desacoplamiento[Tipo Nuevo] / Clutch Release Fork [New Type]
Pedal De Embrague[Tipo Cabina] / Clutch Pedal [Cab Type]
Eje De Entrada[Tipo Nuevo] / Input Shaft [New Type]
Primer Eje[Tipo Nuevo] / First Shaft [New Type]
Segundo Eje[Tipo Nuevo] / Second Shaft [New Type]
Tercer Eje[Tipo Nuevo] / Third Shaft [New Type]
Eje Del Engranaje Loco Posterior [Tipo Nuevo] / Back Idle Shaft [New Type]
Engranaje Conico[Tipo Antiguo] / Bevel Gear [Old Type]
Bisel Engranaje / Bevel Gear
Diferencial Trasero / Differential Rear
Pto Helice Eje / Pto Propeller Shaft
Embrague De Tdf[Tipo Nuevo] / Pto Clutch [New Type]
Embrague De Tdf[Componente Piezas][Tipo Nuevo] / Pto Clutch [Component Parts] [New Type]
Pto Embrague Valvula / Pto Clutch Valve
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Pto Eje / Pto Shaft
Adelante Helice Eje(Trasero) / Front Propeller Shaft (Rear)
Hidraulico Embrague(Bi-Velocidad Girar) / Hydraulic Clutch (Bi-Speed Turn)
Horquilla De Cambio Principal[Tipo Nuevo] / Main Gear Shift Fork [New Type]
Horquilla De Cambio De Inversor[Tipo Cabina] / Shuttle Gear Shift Fork [Cab Type]
Trasero Diferencial Cerradura Cambio Bifurcacion / Rear Differential Lock Shift Fork
Eje Trasero / Rear Axle
Freno / Brake
Varilla De Freno 1[Tipo Cabina] / Brake Rod 1 [Cab Type]
Varilla De Freno 2[Tipo Cabina] / Brake Rod 2 [Cab Type]
Palanca De Cambio Principal[Tipo Cabina] / Main Gear Shift Lever [Cab Type]
Palanca De Cambio De Inversor[Tipo Cabina] / Shuttle Shift Lever [Cab Type]
Palanca De Cambio De Gama[Tipo Cabina] / Range Gear Shift Lever [Cab Type]
Varilla De Cambio De Gama[Tipo Cabina] / Range Gear Shift Rod [Cab Type]
Palanca De Embrague De Tdf[Tipo Cabina] / Pto Clutch Lever [Cab Type]
Palanca De Freno De Estacionamiento[Tipo Cabina][Tipo Antiguo] / Parking Brake Lever [Cab Type] [Old Type]
Palanca De Freno De Estacionamiento[Tipo Cabina][Tipo Nuevo] / Parking Brake Lever [Cab Type] [New Type]
Freno Pedal / Brake Pedal
Pedal De Bloqueo De Diferencial Trasero[Tipo Cabina] / Rear Differential Lock Pedal [Cab Type]
Bastidor De Eje Delantero[Tipo Cabina] / Front Axle Frame [Cab Type]
Soporte De Eje Delantero[Tipo Cabina] / Front Axle Bracket [Cab Type]
Eje Propulsor Delantero[Tipo Cabina] / Front Propeller Shaft [Cab Type]
Bisel Engranaje(Adelante) / Bevel Gear (Front)
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Eje / Front Axle
Mango De Direccion[Tipo Cabina] / Steering Handle [Cab Type]
Distribuidor De Direccion[Tipo Cabina] / Steering Controller [Cab Type]
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts]
Direccion Varillaje / Steering Linkage
Hidraulico Tubo(Aspiracion) / Hydraulic Pipe (Suction)
Tubo Hidraulico(Impulsion)[Tipo Cabina] / Hydraulic Pipe (Delivery) [Cab Type]
Linea De Aceite Hidraulico(Direccion/Tdf)[Tipo Cabina] / Hydraulic Oil Line (Steering/Pto) [Cab Type]
Latiguillo De Direccion(Impulsion)[Tipo Cabina] / Steering Hose (Delivery) [Cab Type]
Solenoide Valvula / Solenoid Valve
Cilindro Hidraulico[Tipo Cabina] / Hydraulic Cylinder [Cab Type]
Hidraulico Ascenso Brazo / Hydraulic Lift Arm
Cubierta De Cilindro Hidraulico[Tipo Cabina] / Hydraulic Cylinder Cover [Cab Type]
Palanca De Control De Esfuerzo Y Posicion[Tipo Cabina] / Draft And Position Control Lever [Cab Type]
Esfuerzo Y Posicion Control Palanca Soporte / Draft And Position Control Lever Bracket
Posicion Control Eje / Position Control Shaft
Esfuerzo Control Eje / Draft Control Shaft
Palanca De Reaccion[Tipo Cabina] / Feed Back Lever [Cab Type]
Distribuidor De Servicios Externos[Tipo Cabina] / Auxiliary Control Valve [Cab Type]
Auxiliar Control Valvula[Componente Piezas] / Auxiliary Control Valve [Component Parts]
Tercer Punto[Tipo Cabina] / Top Link [Cab Type]
Bajar Vinculo / Lower Link
Ascenso Varilla Derecho / Lift Rod Rh
Oscilacion Barra De Remolque / Swinging Drawbar
Pto Eje Protector / Pto Shaft Protector
Capo Anterior[Tipo Cabina] / Hood(Bonnet) Front [Cab Type]
Capo Superior[Tipo Cabina] / Hood(Bonnet) Upper [Cab Type]
Capo Lateral[Tipo Cabina] / Hood(Bonnet) Side [Cab Type]
Tapa Lateral De Capo[Tipo Cabina] / Hood(Bonnet) Side Cover [Cab Type]
Soporte De Capo[Tipo Cabina] / Bonnet Support [Cab Type]
Capo Posterior[Tipo Cabina] / Hood(Bonnet) Rear [Cab Type]
Bastidor De Cabina[Tipo Cabina] / Cab Frame [Cab Type]
Panel Frame[Tipo Cabina] / Panel Frame [Cab Type]
Luna Delantera[Tipo Cabina] / Front Glass [Cab Type]
Puerta Dcha[Tipo Cabina] / Door Rh [Cab Type]
Puerta Izqd[Tipo Cabina] / Door Lh [Cab Type]
Cerradura De Puerta Dcha[Tipo Cabina] / Door Lock Rh [Cab Type]
Cerradura De Puerta Izqd[Tipo Cabina] / Door Lock Lh [Cab Type]
Ventanilla Lateral[Tipo Cabina] / Side Window [Cab Type]
Ventanilla Trasera[Tipo Cabina] / Rear Window [Cab Type]
Espejo Retrovisor[Tipo Cabina] / Rearview Mirror [Cab Type]
Techo Interior[Tipo Cabina] / Inner Roof [Cab Type]
Techo Exterior[Tipo Cabina] / Outer Roof [Cab Type]
Asiento[Tipo Cabina] / Seat [Cab Type]
Alfombrilla De Piso[Tipo Cabina] / Floor Mat [Cab Type]
Guardabarros[Tipo Cabina] / Fender [Cab Type]
Soporte Anterior De Cabina[Tipo Cabina] / Cab Bracket Front [Cab Type]
Soporte Posterior De Cabina[Tipo Cabina] / Cab Bracket Rear [Cab Type]
Caja De Herramientas[Tipo Cabina] / Tool Box [Cab Type]
Aire Acondicionado[Tipo Cabina] / Air Conditioner [Cab Type]
Manguito De Calefaccion[Tipo Cabina] / Heater Hose [Cab Type]
Condensador[Tipo Cabina] / Condenser [Cab Type]
Compresor[Tipo Cabina] / Compressor [Cab Type]
Soporte De Compresor[Tipo Cabina] / Compressor Bracket [Cab Type]
Disco De Rueda Delantera[Excepto[Fr]] / Front Wheel Disk [Except[Fr]]
Disco De Rueda Trasera[Excepto[Fr]] / Rear Wheel Disk [Except[Fr]]
Etiqueta 1[Tipo Cabina] / Label 1 [Cab Type]
Etiqueta 2[Tipo Cabina] / Label 2 [Cab Type]
Kit De Enchufe De Remolque[Opcion][Tipo Cabina][Excepto[Fr]] / Trailer Socket Kit [Option][Cab Type] [Except[Fr]]
Kit De Radiocasete[Opcion][Tipo Cabina] / Radio Cassette Kit [Option] [Cab Type]
Kit De Limpiaparabrisas Trasero[Opcion][Tipo Cabina] / Rear Wiper Kit [Option] [Cab Type]
Kit De Distribuidor De Servicios Externos[Opcion][Tipo Cabina] / Auxiliary Control Valve Kit [Option] [Cab Type]
Auxiliar Control Valvula[Componente Piezas][Opcion] / Auxiliary Control Valve [Component Parts] [Option]
Kit De Espejo Retrovisor[Opcion][Tipo Cabina] / Rearview Mirror Kit [Option] [Cab Type]
Techo Exterior[Opcion][Tipo Cabina] / Outer Roof [Option] [Cab Type]
