Kubota Tractor M8200DTN-B M8200SDTN-B Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M8200DTN-B ; M8200SDTN-B Tractor
Number of Pages: 302 Pages
Itens U So Frequente / Frequently Used Items
Bloco Motor / Crankcase [Rops Type]
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head [Rops T Ype]
Carreto / Gear Case
Tampa Cabeça / Head Cover [Old Type]
Tampa Cabeça / Head Cover [New Type]
Arvore Cames E Veio / Camshaft And I Dle Gear Shaft
Piston E Cambota / Piston And Cranks Haft
Volante Motor / Flywheel
Compensador / Balancer
Regulador / Governor [Rops Type]
Valvula Solenoide / Nozzle Holder An D Glow Plug
Suporte Bico [Peças Componentes] / N Ozzle Holder [Component Parts]
Caixa Da Bomba / Pump Housing [Rops Type]
Alavanca Do Garfo (Governador) / For K Lever (Governor)
Parafuso De Ajuste De Governador / G Overnor Adjusting Bolt [Old Type]
Parafuso De Ajuste De Governador / G Overnor Adjusting Bolt [New Type]
Filtro Gasoleo / Fuel Filter
Bomba Agua E Termostacto / Water Fla Nge And Thermostat [Rops Type]
Bomba Agua / Water Pump [Rops Type]
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner [Rops Type]
Filtro Ar [Peças Componentes] / Air Cleaner [Component Parts]
Escpae / Muffler
Actuador / Actuator
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Hydraulic Pump Base / Hydraulic Pump Base
Radiador Oleo / Oil Cooler [Rops Typ E]
Kit De Juntas Superior (Tipo Antigo) / Upper Gasket Kit [Old Type]
Kit De Juntas Superior (Novo Tipo) / Upper Gasket Kit [New Type]
Deposito Combustivel / Lower Gasket Kit
Acelarador Mao / Hand Accelerator Lever [Rops Type]
Engine Stop Wi Re [Rops Type] / Engine Stop Wire [Rops Type]
Deposito Combu Stivel / Fuel Tank [Rops Type]
Deposito Combu Stivel (Drt) / Fuel Tank Rh [Rops Type]
Deposito Combu Stivel (Esq) / Fuel Tank Lh [Rops Type]
Tubo Combustiv El / Fuel Pipe 2 (Front) [Rops Type]
Separador / Se Parator [Rops Type]
Separador[Peça S Componentes] / Separator [Component Parts]
Ventoinha / Fan [Rops Type]
Tubo Agua / Water Pipe [Rops Type]
Radiador / Radiator [Rops Type]
Deposito Reserva / Reserve Tank [Rops Type]
Alternador / Alternator [Rops Type]
Alternador [P Eças Componentes] / Alternator [Component Parts] [R Ops Type]
Motor Arranqu E / Starter
Motor Arranqu E [Componentes] / Starter [Component Parts]
Bateria / Bat Tery [Rops Type]
Interruptor/S Ensor / Switch/Sensor [Rops Type]
Interruptor ( Quadro Do Painel)/Relé / Switch(Panel Board)/Relay [Rops Type] [Old Type]
Interruptor ( Quadro Do Painel)/Relé / Switch(Panel Board)/Relay [Rops Type] [New Type]
Painel / Pane L Board [Rops Type]
Painel[Peças Componentes] / Panel Board [Component Parts]
Farol Diantei Ro / Head Light
Flasher Light [Rops Type] / Flasher Light [Rops Type]
Farol Traseir O / Tail Light [Rops Type]
Cablagem Elec Trica / Electrical Wiring 1 [Rops Type] [Old Type]
Cablagem Elec Trica / Electrical Wiring 1 [Rops Type] [New Type]
Carter Embraiagem / Clutch Housing [Old Type]
Carter Embraiagem / Clutch Housing [New Type]
Carret Os Inversor / Shuttle Gear Case [New Type]
Bearin G Holder [Old Type] / Bearing Holder [Old Type]
Carter Transmissao / Transmission Case Rear Cover [Old Ty Pe]
Carter Transmissao / Transmission Case Rear Cover [New Ty Pe]
Carter Eixo / Rear Axle Case
Caixa Da Transmissão Dianteira / Front Drive Case
Compen Sador / Clutch
Forque Ta Embraiagem / Clutch Release Fork [Old Type]
Forque Ta Embraiagem / Clutch Release Fork [New Type]
Pedal Embraiagem / Clutch Pedal [Rops Type]
Veio P Rimario / Input Shaft [Old Type]
Primei Ro Veio / First Shaft [Old Type]
Primei Ro Veio / First Shaft [New Type]
Secund Ario Veio / Second Shaft [New Type]
Tercei Ro Veio / Third Shaft [Old Type]
Tercei Ro Veio / Third Shaft [New Type]
Back I Dle Shaft [New Type] / Back Idle Shaft [New Type] # # N.º De Série>=51733 S.No.;>=51733 / S.No.>=51733 S.No.;>=51733
Veio C Reeper / Creep Shaft
Grupo Conico / Bevel Gear [Old Type]
Difere Ncial Traseiro / Differential Rear
Veio T Df / Pto Propeller Shaft
Embrai Agem Tdf / Pto Clutch [Old Type]
Embrai Agem Tdf / Pto Clutch [New Type]
Embrai Agem Tdf[Peças Componentes] / Pto Clutch [Component Parts] [Old Type]
Embrai Agem Tdf[Peças Componentes] / Pto Clutch [Component Parts] [New Type]
Valvul A Embraiagem Tdf / Pto Clutch Valve
Valvul A Embraiagem Tdf[Peças Componentes] / Pto Clutch Va Lve [Component Parts]
Veio P Rimario (Traseira) / Front Propeller Shaft (Rear)
Embrai Agem Hidraulica (Bi Speed) / Hydraulic Clutch (Bi-S Peed Turn)
Forque Ta / Main Gear Shift Fork [Old Type]
Forque Ta / Main Gear Shift Fork [New Type]
Forqui Lha Inversor / Shuttle Gear Shift Fork [Rops Type] [New Type]
Forque Ta Caixa / Creeper / Range Gear Shift Fork
Alavan Ca / Rear Differential Lock Shift Fork
Eixo T Raseiro / Rear Axle
Travão / Br Ake
Tirante Tra Vao / Brake Rod [Rops Type]
Alavanca Ve Locidades / Main Gear Shift Lever [Rops Type]
Alvanca Inv Ersor / Shuttle Shift Lever [Rops Type] [New Type]
Alavanca Ve Locidades / Range Gear Shift Lever [Rops Type]
Tirante Vel Ocidades / Range Gear Shift Rod [Rops Type]
Alavanca Em Braiagem Tdf / Pto Clutch Lever [Rops Type]
Alavanca Td F / Pto Gear Shift Lever
Alavanca Tr Avao Mao / Parking Brake Lever [Rops Type] [Old Typ E]
Alavanca Tr Avao Mao / Parking Brake Lever [Rops Type] [New Typ E]
Pedal Trava O / Brake Pedal
Pedal Bloqu Eio Diferencial Traseiro / Rear Differential Lock P Edal [Rops Type]
Suporte Eixo Frente / Front Axle Frame [Rops Type]
Suporte Eixo Dianteiro / Front Axle Bracket [Rops Type]
Carter E Ixo / Front Axle Case
Veio Pri Mario / Front Propeller Shaft [Rops Type]
Engrenag Em Cónica (Dianteira) / Bevel Gear (Front)
Diferenc Ial Dianteiro / Differential Front
Carter G Rupo Conico / Bevel Gear Case
Grupo Co Nico / Differential Gear Shaft
Eixo Dia Nteiro / Front Axle
Punho Volante / Steering Handle [Rops Type]
Distribuidor Direcção(Nova) / S Teering Controller [Rops Type]
Distribuidor Direcção[Peças Com Ponentes] / Steering Controller [Component Parts]
Direcção / Steering Linkage
Cilindro Direcção[Peças Compone Ntes] / Steering Cylinder [Component Parts]
Bomba Hidraul Ico / Hydraulic Pump
Bomba Hidraul Ico[Peças Componentes] / Hydraulic Pump [Component Parts]
Linha Aspiraç Ão / Hydraulic Pipe (Suction)
Tubo Oleo / H Ydraulic Pipe (Delivery) [Rops Type]
Circuito Oleo Direcção / Hydraulic Oil Line (Steering/Pto) [Rops Type]
Tubo Direccao / Steering Hose (Delivery) [Rops Type]
Solenoid Valv E / Solenoid Valve
Cilindro Hidr Aulico / Hydraulic Cylinder [Rops Type]
Braço De Elev Ação Hidráulico / Hydraulic Lift Arm
Resguardo Cil Indro Hidráulico / Hydraulic Cylinder Cover [Rops T Ype]
Braco Hidraul Ico / Control Valve
Alavanca Cont Rol Esforço / Draft And Position Control Lever [Rop S Type]
Puxar E Posic Ionar Suporte De Alavanca De Controlo / Draft And P Osition Control Lever Bracket
Position Cont Rol Shaft / Position Control Shaft
Draft Control Shaft / Draft Control Shaft
Alavanca / Fe Ed Back Lever [Rops Type]
Distribuidor Auxiliar / Auxiliary Control Valve [Rops Type]
Acessorios / Auxiliary Control Valve [Component Parts]
Parte Superio R / Top Link Bracket
Ligacao Super Ior / Top Link [Rops Type]
Ligacao Infer Ior / Lower Link
Estabilizador (Drt) / Lift Rod Rh
Estabilizador (Esq) / Lift Rod Lh
Barra De Engate Oscilante / Swinging Drawba R
Proteccao Tdf / Pto Shaft Protector
Hood(Bonnet) Front [Rops Type] / Hood(Bonnet) Front [Rops Type]
Capot Superior / Hood(Bonnet) U Pper [Rops Type]
Lado Do Capot / Hood(Bonnet) Si De [Rops Type]
Capot Lateral / Hood(Bonnet) Si De Cover [Rops Type]
Capot Traseiro / Hood(Bonnet) R Ear [Rops Type]
Espelho Rectrovisor / Rearview Mirror [Rops Type]
Guarda Lamas / Fender [Rops Typ E]
Piso / Floor Seat [Rops Type]
Degrau / Step [Rops Type]
Rops 1 (Mid) [Rops Type] [Old T Ype] / Rops 1 (Mid) [Rops Type] [Old Type]
Rops 1 (Mid) [Rops Type] [New T Ype] [Excepte Type Cabine] / Rops 1 (Mid) [Rops Typ E] [New Type] [Excepte Type Cabine]
Rops 2 (Rear) [Rops Type] [Old Type] / Rops 2 (Rear) [Rops Type] [Old Type]
Rops 2 (Rear) [Rops Type] [New Type] [Excepte Type Cabine] / Rops 2 (Rear) [Rops T Ype] [New Type] [Excepte Type Cabine]
Banco / Seat [Rops Type]
Caixa Ferramenta / Tool Box [Ro Ps Type]
Front Wheel Disk [Except[Fr]] / Front Wheel Di Sk [Except[Fr]]
Rear Wheel Disk [Except[Fr]] / Rear Wheel Disk [Except[Fr]]
Etiqueta Traseira / Labe L [Rops Type]
Acessorios / Accessories A Nd Service Parts
Kit Luzes Trabalho (Opçao) / Working Light Kit [Option] [Rops Type]
Trailer Socket Kit [Option] [Rops Ty Pe] / Trailer Socket Kit [Option] [Rops Type]
Front Weight Bumper Kit [Option] [Ro Ps Type] / Front Weight Bumper Kit [Option] [Rops T Ype]
Auxiliary Control Valve Kit [Option] [Rops Type] / Auxiliary Control Valve Kit [Option] [Rops Type]
Distribuidor Auxiliar[Peças Componen Tes] / Auxiliary Control Valve [Component Parts] [O Ption]
Carreto / Gear Case
Escpae / Muffler
Actuador / Actuator
Travão / Br Ake
