Kubota Tractor M8200DTN-B M8200SDTN-B Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M8200DTN-B ; M8200SDTN-B Tractor
Number of Pages: 492 Pages
Bloque Motor[Tipo Arco] / Crankcase [Rops Type]
Aceite Cacerola / Oil Pan
Culata[Tipo Arco] / Cylinder Head [Rops Type]
Tapa De Balancines[Tipo Antiguo] / Head Cover [Old Type]
Tapa De Balancines[Tipo Nuevo] / Head Cover [New Type]
Volante / Flywheel
Compensador / Balancer
Regulador[Tipo Arco] / Governor [Rops Type]
Carcasa De Bomba[Tipo Arco] / Pump Housing [Rops Type]
Bifurcacion Palanca(Regulador) / Fork Lever (Governor)
Tornillo De Ajuste De Regulador[Tipo Antiguo] / Governor Adjusting Bolt [Old Type]
Torniuuo De Japste De Regpujdorlti.O Jntigpoz / Gohernor Jdapsting Bout Loud Tw.Ez Pp Nda De Seriete4e26:8 Sandarte4e26:8 / Sandate4e26:8 Sandarte4e26:8
Tornillo De Ajuste De Regulador[Tipo Nuevo] / Governor Adjusting Bolt [New Type]
Brida De Agua Y Termostato[Tipo Arco] / Water Flange And Thermostat [Rops Type]
Bomba De Agua[Tipo Arco] / Water Pump [Rops Type]
Filtro De Aire[Tipo Arco] / Air Cleaner [Rops Type]
Aire Limpiador[Componente Piezas] / Air Cleaner [Component Parts]
Silenciador / Muffler
Actuador / Actuator
Aceite Tubo(Turbo Cargador) / Oil Pipe (Turbo Charger)
Hidraulico Bomba Base / Hydraulic Pump Base
Radiador De Aceite[Tipo Arco] / Oil Cooler [Rops Type]
Kit De Juntas Superior[Tipo Antiguo] / Upper Gasket Kit [Old Type]
Kit De Juntas Superior[Tipo Nuevo] / Upper Gasket Kit [New Type]
Palanca De Acelerador De Mano[Tipo Arco] / Hand Accelerator Lever [Rops Type]
Cable De Parada De Motor[Tipo Arco] / Engine Stop Wire [Rops Type]
Deposito De Combustible[Tipo Arco] / Fuel Tank [Rops Type]
Deposito De Combustible Dcha[Tipo Arco] / Fuel Tank Rh [Rops Type]
Deposito De Combustible Izqd[Tipo Arco] / Fuel Tank Lh [Rops Type]
Tubo De Combustible 1(Posterior)[Tipo Arco] / Fuel Pipe 1 (Rear) [Rops Type]
Tubo De Combustible 2(Anterior)[Tipo Arco] / Fuel Pipe 2 (Front) [Rops Type]
Decantador[Tipo Arco] / Separator [Rops Type]
Separador[Componente Piezas] / Separator [Component Parts]
Ventilador[Tipo Arco] / Fan [Rops Type]
Tubo De Agua[Tipo Arco] / Water Pipe [Rops Type]
Radiador[Tipo Arco] / Radiator [Rops Type]
Deposito De Reserva[Tipo Arco] / Reserve Tank [Rops Type]
Alternador[Tipo Arco] / Alternator [Rops Type]
Alternador[Componente Piezas][Tipo Arco] / Alternator [Component Parts] [Rops Type]
Motor De Arranque / Starter
Bateria[Tipo Arco] / Battery [Rops Type]
Conmutador/Sensor[Tipo Arco] / Switch/Sensor [Rops Type]
Conmutador(Tablero De Instrumentos)/Rele[Tipo Arco][Tipo Antiguo] / Switch(Panel Board)/Relay [Rops Type] [Old Type]
Conmutador(Tablero De Instrumentos)/Rele[Tipo Arco][Tipo Nuevo] / Switch(Panel Board)/Relay [Rops Type] [New Type]
Tablero De Instrumentos[Tipo Arco] / Panel Board [Rops Type]
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz / Head Light
Luz Intermitente[Tipo Arco] / Flasher Light [Rops Type]
Piloto Trasero[Tipo Arco] / Tail Light [Rops Type]
Cableado Electrico 1[Tipo Arco][Tipo Antiguo] / Electrical Wiring 1 [Rops Type] [Old Type]
Cableado Electrico 1[Tipo Arco][Tipo Nuevo] / Electrical Wiring 1 [Rops Type] [New Type]
Carcasa De Embrague[Tipo Antiguo] / Clutch Housing [Old Type]
Carcasa De Embrague[Tipo Nuevo] / Clutch Housing [New Type]
Caja De Engranajes De Inversor[Tipo Nuevo] / Shuttle Gear Case [New Type]
Portacojinete[Tipo Antiguo] / Bearing Holder [Old Type]
Cubierta Trasera De Caja De Transmision[Tipo Antiguo] / Transmission Case Rear Cover [Old Type]
Cubierta Trasera De Caja De Transmision[Tipo Nuevo] / Transmission Case Rear Cover [New Type]
Trasero Eje Caja / Rear Axle Case
Adelante Accionar Caja / Front Drive Case
Embrague / Clutch
Horquilla De Desacoplamiento[Tipo Antiguo] / Clutch Release Fork [Old Type]
Horquilla De Desacoplamiento[Tipo Nuevo] / Clutch Release Fork [New Type]
Pedal De Embrague[Tipo Arco] / Clutch Pedal [Rops Type]
Eje De Entrada[Tipo Antiguo] / Input Shaft [Old Type]
Eje De Entrada[Tipo Nuevo] / Input Shaft [New Type]
Primer Eje[Tipo Antiguo] / First Shaft [Old Type]
Primer Eje[Tipo Nuevo] / First Shaft [New Type]
Segundo Eje[Tipo Antiguo] / Second Shaft [Old Type]
Segundo Eje[Tipo Nuevo] / Second Shaft [New Type]
Tercer Eje[Tipo Antiguo] / Third Shaft [Old Type]
Tercer Eje[Tipo Nuevo] / Third Shaft [New Type]
Eje Del Engranaje Loco Posterior [Tipo Nuevo] / Back Idle Shaft [New Type]
Engranaje Conico[Tipo Antiguo] / Bevel Gear [Old Type]
Bisel Engranaje / Bevel Gear
Diferencial Trasero / Differential Rear
Pto Helice Eje / Pto Propeller Shaft
Embrague De Tdf[Tipo Antiguo] / Pto Clutch [Old Type]
Embrague De Tdf[Tipo Nuevo] / Pto Clutch [New Type]
Embrague De Tdf[Componente Piezas][Tipo Antiguo] / Pto Clutch [Component Parts] [Old Type]
Embrague De Tdf[Componente Piezas][Tipo Nuevo] / Pto Clutch [Component Parts] [New Type]
Pto Embrague Valvula / Pto Clutch Valve
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Pto Eje / Pto Shaft
Adelante Helice Eje(Trasero) / Front Propeller Shaft (Rear)
Hidraulico Embrague(Bi-Velocidad Girar) / Hydraulic Clutch (Bi-Speed Turn)
Horquilla De Cambio Principal[Tipo Antiguo] / Main Gear Shift Fork [Old Type]
Horquilla De Cambio Principal[Tipo Nuevo] / Main Gear Shift Fork [New Type]
Horquilla De Cambio De Inversor[Tipo Arco][Tipo Nuevo] / Shuttle Gear Shift Fork [Rops Type] [New Type]
Trasero Diferencial Cerradura Cambio Bifurcacion / Rear Differential Lock Shift Fork
Eje Trasero / Rear Axle
Freno / Brake
Varilla De Freno[Tipo Arco] / Brake Rod [Rops Type]
Palanca De Cambio Principal[Tipo Arco] / Main Gear Shift Lever [Rops Type]
Palanca De Cambio De Inversor[Tipo Arco][Tipo Nuevo] / Shuttle Shift Lever [Rops Type] [New Type]
Palanca De Cambio De Gama[Tipo Arco] / Range Gear Shift Lever [Rops Type]
Varilla De Cambio De Gama[Tipo Arco] / Range Gear Shift Rod [Rops Type]
Palanca De Embrague De Tdf[Tipo Arco] / Pto Clutch Lever [Rops Type]
Palanca De Freno De Estacionamiento[Tipo Arco][Tipo Antiguo] / Parking Brake Lever [Rops Type] [Old Type]
Palanca De Freno De Estacionamiento[Tipo Arco][Tipo Nuevo] / Parking Brake Lever [Rops Type] [New Type]
Freno Pedal / Brake Pedal
Pedal De Bloqueo De Diferencial Trasero[Tipo Arco] / Rear Differential Lock Pedal [Rops Type]
Bastidor De Eje Delantero[Tipo Arco] / Front Axle Frame [Rops Type]
Soporte De Eje Delantero[Tipo Arco] / Front Axle Bracket [Rops Type]
Eje Propulsor Delantero[Tipo Arco] / Front Propeller Shaft [Rops Type]
Bisel Engranaje(Adelante) / Bevel Gear (Front)
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Eje / Front Axle
Mango De Direccion[Tipo Arco] / Steering Handle [Rops Type]
Distribuidor De Direccion[Tipo Arco] / Steering Controller [Rops Type]
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts]
Direccion Varillaje / Steering Linkage
Hidraulico Tubo(Aspiracion) / Hydraulic Pipe (Suction)
Tubo Hidraulico(Impulsion)[Tipo Arco] / Hydraulic Pipe (Delivery) [Rops Type]
Linea De Aceite Hidraulico(Direccion/Tdf)[Tipo Arco] / Hydraulic Oil Line (Steering/Pto) [Rops Type]
Latiguillo De Direccion(Impulsion)[Tipo Arco] / Steering Hose (Delivery) [Rops Type]
Solenoide Valvula / Solenoid Valve
Cilindro Hidraulico[Tipo Arco] / Hydraulic Cylinder [Rops Type]
Hidraulico Ascenso Brazo / Hydraulic Lift Arm
Cubierta De Cilindro Hidraulico[Tipo Arco] / Hydraulic Cylinder Cover [Rops Type]
Palanca De Control De Esfuerzo Y Posicion[Tipo Arco] / Draft And Position Control Lever [Rops Type]
Esfuerzo Y Posicion Control Palanca Soporte / Draft And Position Control Lever Bracket
Posicion Control Eje / Position Control Shaft
Esfuerzo Control Eje / Draft Control Shaft
Palanca De Reaccion[Tipo Arco] / Feed Back Lever [Rops Type]
Distribuidor De Servicios Externos[Tipo Arco] / Auxiliary Control Valve [Rops Type]
Auxiliar Control Valvula[Componente Piezas] / Auxiliary Control Valve [Component Parts]
Tercer Punto[Tipo Arco] / Top Link [Rops Type]
Bajar Vinculo / Lower Link
Ascenso Varilla Derecho / Lift Rod Rh
Oscilacion Barra De Remolque / Swinging Drawbar
Pto Eje Protector / Pto Shaft Protector
Capo Anterior[Tipo Arco] / Hood(Bonnet) Front [Rops Type]
Capo Superior[Tipo Arco] / Hood(Bonnet) Upper [Rops Type]
Capo Lateral[Tipo Arco] / Hood(Bonnet) Side [Rops Type]
Tapa Lateral De Capo[Tipo Arco] / Hood(Bonnet) Side Cover [Rops Type]
Capo Posterior[Tipo Arco] / Hood(Bonnet) Rear [Rops Type]
Espejo Retrovisor[Tipo Arco] / Rearview Mirror [Rops Type]
Guardabarros[Tipo Arco] / Fender [Rops Type]
Asiento De Piso[Tipo Arco] / Floor Seat [Rops Type]
Peldano[Tipo Arco] / Step [Rops Type]
Arco De Seguridad 1(Intermedio)[Tipo Arco][Tipo Antiguo] / Rops 1 (Mid) [Rops Type] [Old Type]
Arco Seguridad 1 (Intermedio) [Tipo Arco][Tipo Nuevo][Except Tipo Cab.] / Rops 1 (Mid) [Rops Type] [New Type] [Excepte Type Cabine]
Arco De Seguridad 2(Posterior)[Tipo Arco][Tipo Antiguo] / Rops 2 (Rear) [Rops Type] [Old Type]
Arco Seguridad 2 (Posteropr) [Tipo Arco][Tipo Nuevo][Except Tipo Cab.] / Rops 2 (Rear) [Rops Type] [New Type] [Excepte Type Cabine]
Asiento[Tipo Arco] / Seat [Rops Type]
Caja De Herramientas[Tipo Arco] / Tool Box [Rops Type]
Disco De Rueda Delantera[Excepto[Fr]] / Front Wheel Disk [Except[Fr]]
Disco De Rueda Trasera[Excepto[Fr]] / Rear Wheel Disk [Except[Fr]]
Etiqueta[Tipo Arco] / Label [Rops Type]
Kit De Faro De Labor[Opcion][Tipo Arco] / Working Light Kit [Option] [Rops Type]
Kit De Enchufe De Remolque [Opcion] [Tipo Arco] / Trailer Socket Kit [Option] [Rops Type]
Kit De Lastre De Parachoques Delantero[Opcion][Tipo Arco] / Front Weight Bumper Kit [Option] [Rops Type]
Kit De Distribuidor De Servicios Externos[Opcion][Tipo Arco] / Auxiliary Control Valve Kit [Option] [Rops Type]
Auxiliar Control Valvula[Componente Piezas][Opcion] / Auxiliary Control Valve [Component Parts] [Option]
Apoyo Del Paso [Opcion] / Step Support Kit [Option]
