Kubota Tractor M8200DT Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M8200DT Tractor
Number of Pages: 276 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover [Old Type]
Tampa Cabeça / Head Cover [New Type]
Volante Motor / Flywheel
Compensador / Balancer
Suporte Bico [Peças Componentes] / Nozzle Holder [ Component Parts]
Caixa Da Bomba / Pump Housing
Alavanca Do Garfo (Governador) / Fork Lever (Govern Or)
Parafuso De Ajuste De Governador / Governor Adjusti Ng Bolt
Filtro Gasoleo / Fuel Filter
Bomba Agua E Termostacto / Water Flange And Thermos Tat
Acessorios / Water Pump
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Compon Ent Parts]
Escpae / Muffler
Actuador / Actuator
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Hydraulic Pump Base / Hydraulic Pump Base
Radiador Oleo / Oil Cooler
Deposito Combustivel / Lower Gasket Kit
Engine Stop Wire / Engine Stop Wire
Deposito Combustivel (Drt) / Fuel Tank Rh
Deposito Combustivel (Esq) / Fuel Tank Lh
Tubo Combustivel / Fuel Pipe
Separador / Separator
Separador[Peças Componentes] / Separator [Component Parts]
Ventilador / Fan
Radiador / Water Pipe
Deposito Re Serva / Reserve Tank
Alternador / Alternator
Alternador [Peças Componente S] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Interruptor / Sensor (Motor) / Switch/Sensor
Painel / Panel Board
Painel[Peças Componentes] / Panel Board [Component Parts]
Farol Dianteiro / Head Light
Hazard Light/Tail Light / Ha Zard Light/Tail Light
Cabalagem Eletrica(Cabine)[E C] [G] / Electrical Wiring
Carter Embraiagem / C Lutch Housing
Bearing Holder / Bear Ing Holder
Caixa Velocidades / T Ransmission Case
Carter Transmissao / Transmission Case Rear Cover
Carter Eixo / Rear Ax Le Case
Compensador / Clutch
Forqueta Embraiagem / Clutch Release Fork
Pedal Embraiagem / Cl Utch Pedal [Old Type]
Veio Primario / Input Shaft
Primeiro Veio / First Shaft
Veio Secundario / Cou Ntershaft [Old Type]
Veio Secundario / Cou Ntershaft [New Type]
Back Idle Shaft / Bac K Idle Shaft
Veio Gamas Velocidade S Inversor / Range Gear Shaft/Creep Gear Shaft
Grupo Conico / Bevel Gear
Diferencial Traseiro / Differential Rear
Veio Tdf / Pto Propel Ler Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf[Peças Componentes] / Pto Clutch [Component Parts] [Old Ty Pe]
Embraiagem Tdf[Peças Componentes] / Pto Clutch [Component Parts] [New Ty Pe]
Valvula Embraiagem Td F / Pto Clutch Valve
Valvula Embraiagem Td F[Peças Componentes] / Pto Clutch Valve [Component Parts]
Forquilha Inversor / Shuttle Gear Shift Fork
Forqueta Caixa / Cree Per / Range Gear Shift Fork/Creep Gear Shift Fork
Pedal Bloqueio Difere Ncial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / Rear Axle
Travão / Brake
Tirante Travao / Brake Rod
Alavanca Velocidades / Mai N Gear Shift Lever
Alavanca Velocidades / Ran Ge Gear Shift Lever/Creep Gear Shift Lever
Alavanca Embraiagem Tdf / Pto Clutch Lever
Alavanca Tdf / Pto Gear Sh Ift Lever
Alavanca Dupla Traccao / F Ront Wheel Drive Lever
Alavanca Travao Mao / Park Ing Brake Lever [Old Type]
Alavanca Travao Mao / Park Ing Brake Lever [New Type]
Pedal Travao / Brake Pedal
Suporte Eixo Frente / F Ront Axle Frame
Suporte Eixo Dianteiro / Front Axle Bracket
Veio Frontal / Front Pr Opeller Shaft
Caixa Diferencial Diant Eiro / Front Differential Case
Engrenagem Cónica (Dian Teira) / Bevel Gear (Front)
Diferencial Dianteiro / Differential Front
Bloqueio Diferencial Fr Ente / Front Differential Lock Clutch
Carter Grupo Conico / B Evel Gear Case
Carter Eixo / Front Axl E Case
Direcção Assistida / Direção Punho / Steering Handle
Distribuidor Direcção[Peças Componentes] / Ste Ering Controller [Component Parts]
Direcção / Steering Linkage
Cilindro Direcção[Peças Componentes] / Steerin G Cylinder [Component Parts] [Old]
Cilindro Direcção[Peças Componentes] / Steerin G [Component Parts] [New]
Bomba Hidraulico[Peças Compo Nentes] / Hydraulic Pump [Component Parts]
Linha Aspiração / Hydraulic Pipe (Suction)
Tubo Oleo / Hydraulic Pipe ( Delivery)
Circuito Oleo Direcção / Hyd Raulic Oil Line (Steering/Pto)
Tubo Direccao / Steering Hos E (Delivery)
Cilindro Hidraulico / Hydrau Lic Cylinder
Braço De Elevação Hidráulico / Hydraulic Lift Arm
Resguardo Cilindro Hidráulic O / Hydraulic Cylinder Cover
Braco Hidraulico / Control V Alve
Valvula Control / Control Va Lve [Component Parts]
Acessorios / Draft And Posit Ion Control Lever
Veio Posicao Esforço / Posit Ion And Draft Shaft
Excentrico Posicao / Positio N Cam
Puxar Came / Draft Cam
Distribuidor Auxiliar / Auxi Liary Control Valve
Acessorios / Auxiliary Contr Ol Valve [Component Parts]
Alavanca Valvula Auxiliar 1 Pos / Auxiliary Control Valve Lever
Parte Superior / Top Link Br Acket
Ligacao Superior / Top Link
Ligacao Inferior / Lower Lin K
Estabilizador / Stabilizer [ Old Type]
Estabilizador / Stabilizer [ New Type]
Estabilizador(Drt) / Lift Ro D Rh
Estabilizador(Esq) / Lift Ro D Lh
Barra D E Engate Oscilante / Swinging Drawbar
Protecc Ao Tdf / Pto Shaft Protector
Hood(Bonnet) Front / Hood(Bonnet) Front
Capot Superior / Hood(Bonnet) Upper
Lado Do Capot / Hood(Bonnet) Side
Capot Lateral / Hood(Bonnet) Side Cover
Capot Traseiro / Hood(Bonnet) Rear
Guarda Lamas / Fender
Acessorios E Peças Serviço / Floor Seat
Degrau / Step
Acessorios / Seat
Caixa Ferramenta / Tool Box
Arco / Rops [Old Type]
Arco / Rops [New Type]
Etiqueta Frente / Label
Acessorios / Accessories And Service Part S
Kit Farios Trabalho (Opçao) / Working Light Kit [Op Tion]
Trailer Harness Kit [Option] / Trailer Harness Kit [Option]
Brake [Option] / Brake [Option]
Front Weight Bumper Kit [Option] / Front Weight Bum Per Kit [Option]
High Capacity Hyd.Kit [Option] / High Capacity Hyd. Kit [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit (Scd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit (Fd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit (Scd/Fc) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Con Trol Valve Kit (Fc) [Option]
Kit Distribuidor Serviços Externos[Peças Componente S][Opcao] / Auxiliary Control Valve (Scd) [Componen T Parts] [Option]
Kit Distribuidor Serviços Externos[Peças Componente S][Opcao] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Kit Alavanca Serviços Externos[Opcao] / Auxilairy C Ontrol Valve Lever Kit (3rd) [Option]
Kit De Válvula Do Travão Do Reboque [Opção] / Trale R Brake Valve Kit(Brake Rod) [Option]
Kit De Válvula Do Travão Do Reboque [Opção] / Trale R Brake Valve Kit(Main Valve) [Option]
Kit De Válvula Do Travão Do Reboque [Opção] / Trale R Brake Valve Kit(Hyd.Hose) [Option]
Step Support Kit [Option] / Step Support Kit [Optio N]
Carreto / Gear Case
Escpae / Muffler
Actuador / Actuator
Ventilador / Fan
Travão / Brake
Degrau / Step
Acessorios / Seat
