Kubota Tractor M8200DT Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota M8200DT Tractor
Number of Pages: 479 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Tapa De Balancines [Tipo Antiguo] / Head Cover [Old Type]
Tapa De Balancines [Tipo Nuevo] / Head Cover [New Type]
Volante / Flywheel
Compensador / Balancer
Bomba Carcasa / Pump Housing
Bifurcacion Palanca(Regulador) / Fork Lever (Governor)
Regulador Ajuste Tornillo / Governor Adjusting Bolt
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Aire Limpiador[Componente Piezas] / Air Cleaner [Component Parts]
Silenciador / Muffler
Actuador / Actuator
Aceite Tubo(Turbo Cargador) / Oil Pipe (Turbo Charger)
Hidraulico Bomba Base / Hydraulic Pump Base
Mano Acelerador Palanca / Hand Accelerator Lever
Motor Parar Cable / Engine Stop Wire
Combustible Deposito Derecho / Fuel Tank Rh
Combustible Deposito Izquierdo / Fuel Tank Lh
Combustible Tubo / Fuel Pipe
Separador / Separator
Separador[Componente Piezas] / Separator [Component Parts]
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador(Panel Tablero)/ Rele / Switch(Panel Board)/Relay
Tablero Panel / Panel Board
Tablero De Instrumentos [Componentes] / Panel Board [Component Parts]
Culata Luz / Head Light
Peligro Luz/Cola Luz / Hazard Light/Tail Light
Rodamiento Soporte / Bearing Holder
Transmision Caja Trasero Cubierta / Transmission Case Rear Cover
Trasero Eje Caja / Rear Axle Case
Embrague / Clutch
Embrague Desbloquear Bifurcacion / Clutch Release Fork
Pedal De Embrague [Tipo Antiguo] / Clutch Pedal [Old Type]
Pedal De Embrague [Tipo Nuevo] / Clutch Pedal [New Type]
Entrada Eje / Input Shaft
Primero Eje / First Shaft
Eje Intermedio [Tipo Antiguo] / Countershaft [Old Type]
Eje Intermedio [Tipo Nuevo] / Countershaft [New Type]
Trasero Punto Muerto Eje / Back Idle Shaft
Gama Engranaje Eje/Marcha Muy Lenta Engranaje Eje / Range Gear Shaft/Creep Gear Shaft
Bisel Engranaje / Bevel Gear
Diferencial Trasero / Differential Rear
Pto Helice Eje / Pto Propeller Shaft
Tdf Embrague / Pto Clutch
Embrague De Tdf [Componentes] [Tipo Antiguo] / Pto Clutch [Component Parts] [Old Type]
Embrague De Tdf [Componentes] [Tipo Nuevo] / Pto Clutch [Component Parts] [New Type]
Pto Embrague Valvula / Pto Clutch Valve
Pto Embrague Valvula [Componente Piezas] / Pto Clutch Valve [Component Parts]
Pto Eje / Pto Shaft
Inversor Engranaje Cambio Bifurcacion / Shuttle Gear Shift Fork
Gama Engranaje Cambio Bfrccn/Mrch My Lnt Engrnj Cmb Bfrccn / Range Gear Shift Fork/Creep Gear Shift Fork
Trasero Diferencial Cerradura Pedal / Rear Differential Lock Pedal
Eje Trasero / Rear Axle
Freno / Brake
Freno Varilla / Brake Rod
Inversor Cambio Palanca / Shuttle Shift Lever
Gama Engranaje Cambio Palanca/Mrch My Lnt Engrnj Cmb Plnc / Range Gear Shift Lever/Creep Gear Shift Lever
Pto Embrague Palanca / Pto Clutch Lever
Pto Engranaje Cambio Palanca / Pto Gear Shift Lever
Palanca De Freno De Estacionamiento [Tipo Antiguo] / Parking Brake Lever [Old Type]
Palanca De Freno De Estacionamiento [Tipo Nuevo] / Parking Brake Lever [New Type]
Freno Pedal / Brake Pedal
Adelante Helice Eje / Front Propeller Shaft
Bisel Engranaje(Adelante) / Bevel Gear (Front)
Adelante Diferencial Cerradura Embrague / Front Differential Lock Clutch
Diferencial Eje Del Engranaje / Differential Gear Shaft
Adelante Eje / Front Axle
Direccion Controlador[Componente Piezas] / Steering Controller [Component Parts]
Direccion Varillaje / Steering Linkage
Direccion Cilindro [Componente Piezas] / Steering Cylinder [Component Parts] [Old]
Direccion Cilindro [Componente Piezas] / Steering [Component Parts] [New]
Hidraulico Tubo(Aspiracion) / Hydraulic Pipe (Suction)
Hidraulico Tubo(Entrega) / Hydraulic Pipe (Delivery)
Hidraulico Aceite Linea(Direccion/Pto) / Hydraulic Oil Line (Steering/Pto)
Hidraulico Ascenso Brazo / Hydraulic Lift Arm
Hidraulico Cilindro Cubierta / Hydraulic Cylinder Cover
Control Valvula[Componente Piezas] / Control Valve [Component Parts]
Esfuerzo Y Posicion Control Palanca / Draft And Position Control Lever
Posicion Y Esfuerzo Eje / Position And Draft Shaft
Posicion Leva / Position Cam
Esfuerzo Leva / Draft Cam
Auxiliar Control Valvula / Auxiliary Control Valve
Auxiliar Control Valvula[Componente Piezas] / Auxiliary Control Valve [Component Parts]
Auxiliar Control Valvula Palanca / Auxiliary Control Valve Lever
Bajar Vinculo / Lower Link
Estabilizador [Tipo Antiguo] / Stabilizer [Old Type]
Estabilizador [Tipo Nuevo] / Stabilizer [New Type]
Ascenso Varilla Derecho / Lift Rod Rh
Oscilacion Barra De Remolque / Swinging Drawbar
Pto Eje Protector / Pto Shaft Protector
Capo(Capo)Adelante / Hood(Bonnet) Front
Capo(Capo)Superior / Hood(Bonnet) Upper
Capo(Capo)Lado / Hood(Bonnet) Side
Capo(Capo)Lado Cubierta / Hood(Bonnet) Side Cover
Capo(Capo)Trasero / Hood(Bonnet) Rear
Guardabarros / Fender
Piso Asiento / Floor Seat
Peldano / Step
Hoja / Seat
Herramienta Caja / Tool Box
Arco De Seguridad [Tipo Nuevo] / Rops [New Type]
Etiqueta / Label
Funcionamiento Luz Kit[Opcion] / Working Light Kit [Option]
Remolque Mazo De Cables Kit[Opcion] / Trailer Harness Kit [Option]
Freno [Opcion] / Brake [Option]
Adelante Peso Parachoques Kit[Opcion] / Front Weight Bumper Kit [Option]
Alto Capacidad Hidraulico Kit[Opcion] / High Capacity Hyd.Kit [Option]
Kit De Distribuidor De Servicios Externos (Scd) [Opcion] / Auxiliary Control Valve Kit (Scd) [Option]
Auxiliar Control Valvula (Fd) [Opcion] / Auxiliary Control Valve Kit (Fd) [Option]
Kit De Distribuidor De Servicios Externos (Fc) [Opcion] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Distribuidor De Servicios Externos (Scd) [Componentes] [Opcion] / Auxiliary Control Valve (Scd) [Component Parts] [Option]
Distribuidor De Servicios Externos (Fc) [Componentes] [Opcion] / Auxiliary Control Valve (Fc) [Component Parts] [Option]
Kit De Palanca De Distribuidor De Servicios Externos (Tercero) [Opcion] / Auxilairy Control Valve Lever Kit (3rd) [Option]
Kit De Valvulas De Freno De Remolque (Varilla De Freno) [Opcion] / Traler Brake Valve Kit(Brake Rod) [Option]
Kit De Valvulas De Freno De Remolque (Valvula Principal) [Opcion] / Traler Brake Valve Kit(Main Valve) [Option]
Kit De Valvulas De Freno De Remolque (Latiguillo Hidraulico) [Opcion] / Traler Brake Valve Kit(Hyd.Hose) [Option]
Apoyo Del Paso [Opcion] / Step Support Kit [Option]
