Kubota Tractor M8200DT-CAB Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M8200DT-CAB Tractor
Number of Pages: 341 Pages
Itens Uso Frequent E / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover [Old Type]
Tampa Cabeça / Head Cover [New Type]
Arvore Cames E Veio / Camshaft And Idle G Ear Shaft
Volante Motor / Flywheel
Compensador / Balancer
Valvula Solenoide / Nozzle Holder And Glo W Plug
Caixa Da Bomba / Pump Housing
Alavanca Do Garfo (Governador) / Fork Lev Er (Governor)
Parafuso De Ajuste De Governador / Govern Or Adjusting Bolt
Filtro Gasoleo / Fuel Filter
Bomba Agua E Termostacto / Water Flange A Nd Thermostat
Acessorios / Water Pump
Válvula E Veio Do Balanceiro / Valve And Rocker Arm
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Clean Er [Component Parts]
Escpae / Muffler
Actuador / Actuator
Tubo Oleo (Turbo) / Oil Pipe(Turbo Charge R)
Base Da Bomba Hidráulica / Hydraulic Pump Base
Radiador Oleo / Oil Cooler
Deposito Combustivel / Lower Gasket Kit
Engine Stop Wire / Engine Stop Wire
Deposito Combustivel (Drt ) / Fuel Tank Rh
Deposito Combustivel (Esq ) / Fuel Tank Lh
Tubo Combustivel / Fuel P Ipe
Separador / Separator
Separador[Peças Component Es] / Separator [Component Parts]
Ventila Dor / Fan
Radiado R / Water Pipe
Radiado R / Radiator
Deposit O Reserva / Reserve Tank
Alternador / Alternator
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque[Peças Com Ponentes] / Starter [Component Parts]
Interruptor / Sensor (Mo Tor) / Switch/Sensor
Interruptor / Switch(Pan El Board)
Comutador / Switch
Interruptor / Rele / Rel Ay
Painel / Panel Board
Painel[Peças Componentes ] / Panel Board [Component Parts]
Bomba Hidraulico / Light
Luzes De Aviso / Hazard Light
Luzes Trabalho / Work Li Ght
Braco Traseiro / Rear Co Mbination Light
Luz Interior / Room Ligh T
Depósito De Lavagem / Wa Sher Tank
Escova Limpa Vidros / Wi Per
Cabalagem Eletrica(Cabin E)[Ec] [G] / Electrical Wiring
Bearing Holder / Bearing Holder
Carter Transmissa O / Transmission Case Rear Cover
Carter Eixo / Rea R Axle Case
Compensador / Clu Tch
Forqueta Embraiag Em / Clutch Release Fork
Bloqueio Diferenc Ial / Clutch Pedal
Veio Primario / I Nput Shaft
Veio Secundario / Countershaft [Old Type]
Veio Secundario / Countershaft [New Type]
Veio Do Ralenti T Raseiro / Back Idle Shaft
Grupo Conico / Be Vel Gear
Diferencial Trase Iro / Differential Rear
Veio Tdf / Pto Pr Opeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf[Pe Ças Componentes] / Pto Clutch [Component Parts]
Valvula Embraiage M Tdf / Pto Clutch Valve
Valvula Embraiage M Tdf[Peças Componentes] / Pto Clutch Valve [Compo Nent Parts]
Veio Tdf / Pto Sh Aft
Forqueta / Main G Ear Shift Fork
Forquilha Inverso R / Shuttle Gear Shift Fork
Forqueta Velocida Des / Range Gear Shift Fork/Creep Shift Fork
Pedal Bloqueio Di Ferencial Traseiro / Rear Differential Lock Pedal
Eixo Traseiro / R Ear Axle
Travão / Brake
Brake Rod 1 / Brake Ro D 1
Brake Rod 2 / Brake Ro D 2
Alavanca Velocidades / Main Gear Shift Lever
Tirante / Main Gear Sh Ift Rod
Principal De Transmiss Ão Eixo Da Alavanca / Main Gear Shift Lever Shaft
Alvanca Inversor / Shu Ttle Shift Lever
Alavanca Velocidades / Range Gear Shift Lever/Creep Gear Shift Lever
Alavanca Embraiagem Td F / Pto Clutch Lever
Alavanca Tdf / Pto Gea R Shift Lever
Tirante Travao Mao / P Arking Brake Rod [Old Type]
Tirante Travao Mao / P Arking Brake Rod [New Type]
Pedal Travao / Brake P Edal
Suporte Eixo Diante Iro / Front Axle Bracket
Veio Frontal / Fron T Propeller Shaft
Caixa Diferencial D Ianteiro / Front Differential Case
Engrenagem Cónica ( Dianteira) / Bevel Gear (Front)
Diferencial Diantei Ro / Differential Front
Bloqueio Diferencia L Frente / Front Differential Lock Clutch
Carter Grupo Conico / Bevel Gear Case
Carter Eixo / Front Axle Case
Grupo Conico / Diff Erential Gear Shaft
Eixo Dianteiro / Fr Ont Axle
Direcção Assistida / Direção Punho / Steer Ing Handle
Junta / Steering Joint
Distribuidor Direcção[Peças Componentes] / Steering Controller [Component Parts]
Direcção / Steering Linkage
Cilindro Direcção[Peças Componentes] / Ste Ering Cylinder [Component Parts] [Old]
Direcção [Peças Componen Tes] / Steering [Component Parts] [New]
Bomba Hidraulico / Hydra Ulic Pump
Bomba Hidraulico[Peças C Omponentes] / Hydraulic Pump [Component Parts]
Linha Aspiração / Hydrau Lic Pipe (Suction)
Tubo Oleo / Hydraulic Pi Pe (Delivery)
Circuito Oleo Direcção / Hydraulic Oil Line (Steering/Pto)
Tubo Direccao / Steering Hose (Delivery)
Cilindro Hidraulico / Hy Draulic Cylinder
Braço De Elevação Hidráu Lico / Hydraulic Lift Arm
Resguardo Cilindro Hidrá Ulico / Hydraulic Cylinder Cover
Braco Hidraulico / Contr Ol Valve
Valvula Control / Contro L Valve [Component Parts]
Alavanca Control Esforço / Draft And Position Control Lever 1
Alavanca Control Esforço / Draft And Position Control Lever 2
Veio Posicao Esforço / P Osition And Draft Shaft
Excentrico Posicao / Pos Ition Cam
Puxar Came / Draft Cam
Distribuidor Auxiliar / Auxiliary Control Valve
Acessorios / Auxiliary C Ontrol Valve [Component Parts]
Valvula Auxiliar [Peças Componentes] / Auxiliary Control Valve (Fd)[Compone Nt Parts]
Alavanca Valvula Auxilia R 1 Pos / Auxiliary Contorol Valve Lever
Parte Superior / Top Lin K Bracket
Ligacao Superior / Top L Ink
Ligacao Inferior / Lower Link [Old Type]
Ligacao Inferior / Lower Link [New Type]
Estabilizador(Drt) / Lif T Rod Rh
Estabilizador(Esq) / Lif T Rod Lh
Bar Ra De Engate Oscilante / Swinging Drawbar
Pro Teccao Tdf / Pto Shaft Protector
Capot Dianteiro / Hood(Bonnet) Front
Capot Superior / Hood(Bonnet) Upper
Lado Do Capot / Hood(Bonnet) Side
Capot Lateral / Hood(Bonnet) Side Cover
Estrutura Cabine / Cab Frame
Kit Limpa Vidro Traseiros (Opcao) / Panel Frame
Porta(Drt) / Door Rh
Porta(Esq) / Door Lh
Trinco Porta(Drt) / Door Lock Rh
Lado Vidro / Side Window
Vidro Traseiro / Rear Window
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Acessorios / Seat
Piso / Floor Mat
Chapa Inspecção(Frente) / Inspection Plate
Cobertura Guarda Lamas(Drt) / Fender Cover Rh
Cobertura Gurada Lamas(Esq) / Fender Cover Lh
Resguardo Coluna / Pillar Cover
Guarda Lamas(Drt) / Fender Rh
Guarda Lamas(Esquerda) / Fender Lh
Dianteira Do Suporte Da Cabine / Cab Brack Et Front
Suporte Cabine Traseiro / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Air Condicionado / Air Cond Itioner
Tubo Aquecimento / Heater H Ose
Condesador / Condenser
Compressor / Compressor [Ol D Type]
Compressor / Compressor [Ne W Type]
Suporte Compressor / Compre Ssor Bracket
Etiqueta (Dianteira) / Label 1
Etiqueta / Label 2
Acessorios / Accessories And Service Parts
Kit Farios Trabalho (Opçao) / Working Light Kit [Option]
Lever Joint Stay Kit [Option] / Lever Joint Sta Y Kit [Option]
Trailer Socket Kit [Option] / Trailer Socket Ki T [Option]
Rear Wiper Kit [Option] [Old Type] / Rear Wiper Kit [Option] [Old Type]
Rear Wiper Kit [Option] [New Type] / Rear Wiper Kit [Option] [New Type]
Kit Do Pára-Choques Dianteiro / Front Weight Bu Mper Kit [Option]
Kit Cardan Universal / Universal Joint Support Kit [Option]
High Capacity Hyd.Kit [Option] / High Capacity Hyd.Kit [Option]
Bomba Hidraulico[Peças Componentes] / Hydraulic Pump [Component Parts] [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Control Valve Kit (Scd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Control Valve Kit (Fd) [Option]
Kit Valvula Control Auxiliar[Opcao] / Auxiliary Control Valve Kit (Scd/Fc) [Option]
Kit Distribuidor Serviços Externos[Peças Compon Entes][Opcao] / Auxiliary Control Valve (Scd) [Comp Onent Parts] [Option]
Kit Distribuidor Serviços Externos[Peças Compon Entes][Opcao] / Auxiliary Control Valve (Scd/Fc) [C Omponent Parts] [Option]
Kit Alavancas Serviços Externos 2º Posição [Op Cao] / Auxilary Control Valve Lever Kit (2nd) [Opti On]
Kit Alavancas Serviços Externos 3º Posição [Op Cao] / Auxilary Control Valve Lever Kit (3rd) [Opti On]
Assist Cylinder Kit [Option] / Assist Cylinder Kit [Option]
Cilindro Auxiliar (Componentes) / Assist Cylind Er [Component Parts] [Option]
Rearview Mirror Kit [Option] / Rearview Mirror Kit [Option]
Carreto / Gear Case
Escpae / Muffler
Actuador / Actuator
Ventila Dor / Fan
Comutador / Switch
Travão / Brake
Acessorios / Seat
Piso / Floor Mat
Etiqueta / Label 2
