Kubota Tractor M7173P Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M7173P Tractor
Number of Pages: 611 Pages
Itens Usados Fr Equentemente / Frequently Used Items
Itens Usados Fr Equentemente (Componenetes Electricos) [Luzes Frent E [Com Led]] [Luzes Trabalho [Com Led]] / Frequentl Y Used Items (Electrical Parts) [Head Light [With L Ed]] [Work Light [With Led]]
Itens Usados Fr Equentemente (Componenetes Electricos) [Luzes Frent E [Com Halogénio]] [Luzes Trabalho [Com Halogénio]] / Frequently Used Items (Electrical Parts) [Head L Ight [With Harogen]] [Work Light [With Harogen]]
B Loco Motor (Superior) / Crankcase (Upper)
B Loco Motor (Inferior) / Crankcase (Lower)
C Árter Do Óleo [Com Compressor De Ar] / Oil Pan [Wit H Air Compressor]
C Árter Do Óleo [Sem Compressor De Ar] / Oil Pan [W/O Air Compressor]
C Abeça Motor / Cylinder Head
V Alvula Admissao E Escape / Inlet Valve And Exhaust Valve
B Raço / Rocker Arm Shaft
T Ampa Cabeça / Head Cover
C Obertura Frontal / Front Cover
P Iston E Cambota / Piston And Crankshaft
C Ompensador / Balancer
V Olante Motor / Flywheel
F Iltro Gasoleo / Fuel Filter
B Omba De Abastecimento / Supply Pump
I Njector E Vela Aquecimento / Injector And Glow Plug
T Ubo Injector / Injection Pipe
C Ommon Rail / Common Rail
B Omba Agua / Water Pump
R Adiador Oleo / Oil Cooler
S Eparador De Óleo / Oil Separator
T Ubo Do Separador De Óleo / Oil Separator Pipe
T Ubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charg Er)
F Iltro Ar [Com Tdf Dianteira] / Air Cleaner [With Fr Ont Pto]
F Iltro Ar [Sem Tdf Dianteira] / Air Cleaner [W/O Fro Nt Pto]
F Iltro Ar [Peças Componentes] / Air Cleaner [Compone Nt Parts]
T Ubo De Entrada (Filtro De Ar) [Com Compressor De Ar ] / Inlet Pipe (Air Cleaner) [With Air Compresser]
T Ubo De Entrada (Filtro De Ar) [Sem Compressor De Ar ] / Inlet Pipe (Air Cleaner) [W/O Air Compresser]
T Urbo Compressor / Turbo Charger
F Lange Filtro Ar E Valvula Acelarador / Air Cleaner Flange And Throttle Valve
V Alvula Egr / Egr Valve
R Efrigerador Egr / Egr Cooler
T Ubos De Água Egr / Egr Water Piping
C Olector Escape / Exhaust Manifold
S Ilenciador Do Filtro De Partículas Diesel / Diesel Particulate Filter Muffler
S Ilenciador Do Filtro De Partículas Diesel [Peças Co Mponentes] / Diesel Particulate Filter Muffler [Com Ponent Parts]
F Lange Silenciosa / Muffler Flange
S Uporte (Dpf) 1 / Muffler Bracket (Dpf) 1
S Uporte (Dpf) 2 / Muffler Bracket (Dpf) 2
T Ubo Pressao / Pressure Pipe
P Anela Escape / Muffler Pipe
S Ilenciador Da Redução Catalítica Seletiva / Selecti Ve Catalytic Reduction Muffler
S Uporte De Silenciador De Redução Catalítica Seletiv A / Selective Catalytic Reduction Muffler Bracket
R Esguardo Da Redução Catalítica Seletiva / Selective Catalytic Reduction Cover
T Ubulação E Proteção Do Silênciador / Muffler Pipe A Nd Cover
B Omba Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Pump
D Epósito Do Fluido De Escape De Diesel / Diesel Exha Ust Fluid Tank
D Epósito Do Fluido De Escape De Diesel [Peças Compon Entes] / Diesel Exhaust Fluid Tank [Component Parts ]
D Epósito Do Fluido De Escape De Diesel Tubo / Diesel Exhaust Fluid Hose
D Epósito Do Fluido De Escape De Diesel Aquecedor Tub O / Diesel Exhaust Fluid Heater Hose
D Epósito Do Fluido De Escape De Diesel Mangueira De Respiro / Diesel Exhaust Fluid Breather Hose
S Istema De Arrefecimento Egr (Sistema De Redução Cat Alítica Seletiva) / Egr Cooler (Selective Catalytic Reduction System)
T Ubos De Água Egr (Sistema De Redução Catalítica Sel Etiva) / Egr Water Piping (Selective Catalytic Redu Ction System)
C Obertura De Escape De Exaustão/Tampa De Recirculaçã O De Gás De Escape / Exhaust Manifold Cover/Egr Cov Er
C Omponentes Electricos Motor (Sensor/Ecu) / Engine E Lectrical Parts (Sensor/Ecu)
C Omponentes Electricos Motor (Panela Escape) / Engin E Electrical Parts (Muffler)
C Ablagem Injector / Injector Harness
M Otor Elétrica Peças De Montagem / Engine Electrical Mounting Parts
P Edal Acelarador / Accelerator Pedal
Deposito Combustivel / Fuel Ta Nk
Suporte Deposito Combustivel [ Com Equipamento Do Carregador] / Fuel Tank Bracket [With Loader Equipment]
Suporte Deposito Combustivel [ Sem Equipamento Do Carregador] / Fuel Tank Bracket [W/O Loader Equipment]
Tubo Do Combustível (Enchiment O Do Combustível) / Fuel Pipe (Fuel Filter)
Arrefecedor Gasoleo / Fuel Coo Ler
Separador / Separator
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Component Es] / Fuel Pump [Component Parts]
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Componen Tes] / Fuel Filter [Component Parts]
Suporte Vent Ilador / Fan Bracket
Polia De Aci Onamento Da Ventoinha / Fan Drive Pulley
Ventoinha / Fan
Tubo De Água E Tubo Do Sistema De Arrefecimento / Water Pipe An D Cooler Pipe
Unidade Do S Istema De Arrefecimento / Cooler Unit
Radiador / R Adiator
Refrigerador Intermediário / Inter Cooler
Radiador Ole O / Oil Cooler
Condesador / Condenser
Tubo Do Depó Sito De Reserva [Com Compressor De Ar] / Reserve Ta Nk Hose [With Air Compressor]
Tubo Do Depó Sito De Reserva [Sem Compressor De Ar] / Reserve Ta Nk Hose [W/O Air Compressor]
Alternador (200a) / Alternato R (200a)
Alternador (150a) / Alternato R (150a)
Alternador (200a) [Peças Comp Onentes] / Alternator (200a) [Component Parts]
Alternador (150a) [Peças Comp Onentes] / Alternator (150a) [Component Parts]
Suporte De Bateria / Battery Bracket
Interruptor/Sensor (Bloco Mot Or Esquerda) / Switch/Sensor (Engine Lh)
Interruptor/Sensor (Bloco Mot Or Direita) / Switch/Sensor (Engine Rh)
Sensor Da Redução Catalítica Seletiva / Selective Catalytic Reduction Sensor
Componenetes Electricos Resgua Rdo / Electrical Parts Cover
Suspensão Frontal Sensor / Fr Ont Suspension Sensor
Sensor (Pedal/Alavanca Travao Mao) / Sensor (Pedal/Parking Brake Lever)
Interruptor/Sensor / Switch/S Ensor
Interruptor/Sensor [Com Compr Essor De Ar] / Switch/Sensor [With Air Compressor]
Interruptor/Sensor [Sem Compr Essor De Ar] / Switch/Sensor [W/O Air Compressor]
Sensor/Regulador (Carter Embr Aiagem/Habitação De Transmissão) / Sensor/Regulater (Clutch Housing/Transmission Housing)
Sensor/Valvula (Hidráulica Bo Mba De Moradia / Tdf Shaft Habitação) / Sensor/Valv E (Hydraulic Pump Housing/Pto Shaft Housing)
Sensor Da Conicidade/Sensor 3 P [Com Puxo (Escada)] / Draft Sensor/3p Sensor [Wit H Hitch (Ladder)]
Sensor Da Conicidade/Sensor 3 P [Com Puxo (Dromone)] / Draft Sensor/3p Sensor [Wi Th Hitch (Dromone)]
Interruptor (Ligação 3p Diant Eira) [Com 3p Dianteiro] / Switch (Front 3p Link) [ With Front 3p]
Interruptor (Painel) / Switch (Panel Board)
Interruptor (Direcção) [Com D Ireção Automática] / Switch (Steering) [Auto Steeri Ng Compatible]
Interruptor (Direcção) [Sem D Ireção Automática] / Switch (Steering) [Auto Steeri Ng Incompatible]
Interruptor (Cobertura De Mud Ança) [Com Direçao Rápida] / Switch (Shift Cover) [ With Fast Steering]
Interruptor (Cobertura De Mud Ança) [Sem Direçao Rápida] / Switch (Shift Cover) [ W/O Fast Steering]
Interruptor (Consola Do Lado Esquerdo) [Com Aquecedor De Espelho Retrovisor] / S Witch (Console Lh) [With Mirror Heater]
Interruptor (Consola Do Lado Esquerdo) [Sem Aquecedor De Espelho Retrovisor] / S Witch (Console Lh) [W/O Mirror Heater]
Interruptor Externo / Externa L Switch
Relé/Controlador / Relay/Cont Roller
Unidade Control Electrico (Bl Oco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico/Con Trolador [Com Compressor De Ar] / Electronic Contro L Unit/Controller [With Air Compressor]
Controlador (Ceu) / Controlle R (Ceu)
Painel / Panel
Peças Elétricas Da Traseira I Nterior Da Cabine (Saída Elétrica/Painel De Control O Do Ar Condicionado) [Com Ar Condicionado - Automá Tico] / Cab Inner Rear Electrical Parts (Electrical Outlet/Air Conditioner Control Panel) [With Auto A Ir Conditioner]
Peças Elétricas Da Traseira I Nterior Da Cabine (Saída Elétrica/Painel De Control O Do Ar Condicionado) [Com Ar Condicionado - Manual ] / Cab Inner Rear Electrical Parts (Electrical Out Let/Air Conditioner Control Panel) [With Manual Air Conditioner]
Terminal Isobus / Isobus Term Inal
Apoio De Braço (6 Válvulas De Controlo Remoto) [Com Controle De Video Game] / Ar Mrest (6 Remote Control Valves) [With Joystick]
Apoio De Braço (5 Válvulas De Controlo Remoto) [Sem Controle De Video Game] / Ar Mrest (5 Remote Control Valves) [W/O Joystick]
Terminal (12 Polegadas) / Ter Minal (12 Inch)
Terminal (7 Polegadas) / Term Inal (7 Inch)
Luzes Frente [Com Lampada De Led] / Head Light [With Led Light]
Luzes Frente [Com Lampada De Halogénio] / Head Light [With Halogen Light]
Luzes Frente De Repetição (Co Luna) [Com Luzes Frente De Repetição] / Repeat Head Light (Pillar) [With Repeat Head Light]
Lâmpada Farol / Beacon Lamp
Lámpada De Pisca Pisca [Com L Uz De Trabalho(Coluna)] / Lamp Of Side Marker [With Work Light (Pillar)]
Luzes Frontais / Front Combin Ation Lamp
Luz De Trabalho (Dianteiro/Te To) [Com Lampada De Led] / Work Light (Front/Roof) [With Led Light]
Luz De Trabalho (Dianteiro/Co Luna) [Com Luz De Trabalho(Coluna)] / Work Light (F Ront/Pillar) [With Work Light (Pillar)]
Luz De Trabalho (Traseiro/Tet O) [Com Lampada De Led] / Work Light (Rear/Roof) [W Ith Led Light]
Luz De Trabalho (Traseiro/Tet O) [Com Lampada De Halogénio] / Work Light (Rear/Ro Of) [With Halogen Light]
Luz De Trabalho (Traseiro/Col Una) [Com Luz De Trabalho(Coluna)] / Work Light (Re Ar/Pillar) [With Work Light (Pillar)]
Braco Traseiro / Rear Combina Tion Lamp
Farol Matricula / License Lam P
Ficha Reboque [Travão De Trai Ler De 1+2 Linha] / Trailer Socket [1+2-Line Traler Brake]
Ficha Reboque [Travão De Trai Ler De 1 Linha] / Trailer Socket [1-Line Traler Bra Ke]
Luz Interior / Room Light
Holofote [Com Holofote] / Spo T Light [With Spot Light]
Alta Voz Radio / Radio Speake R
Escova / Wiper
Cablagem Elétrica (Motor) (Fi Ltro De Ar/Dpf) / Electrical Wiring (Engine) (Air C Leaner/Dpf)
Cablagem Elétrica (Motor) (Cr S) / Electrical Wiring (Engine) (Crs)
Cablagem Elétrica (Motor) (Co Mbustível/Scr) / Electrical Wiring (Engine) (Fuel/S Cr)
Cablagem Elétrica (Motor) (Fu Sível/Bateria) / Electrical Wiring (Engine) (Fuse/B Attery)
Cablagem Elétrica (Motor) (Co Mpressor/Volante) [Com Compressor De Ar] / Electric Al Wiring (Engine) (Compressor/Flywheel) [With Air Compressor]
Cablagem Elétrica (Motor) (Co Mpressor/Volante) [Sem Compressor De Ar] / Electric Al Wiring (Engine) (Compressor/Flywheel) [W/O Air C Ompressor]
Cablagem Elétrica (Capot) [Co M Lampada De Led] / Electrical Wiring (Bonnet(Hood) ) [With Led Light]
Cablagem Elétrica (Capot) [Co M Lampada De Halogénio] / Electrical Wiring (Bonnet (Hood)) [With Halogen Light]
Cablagem Elétrica (Alternador 200a) / Electrical Wiring (Alternator 200a)
Cablagem Elétrica (Alternador 150a) / Electrical Wiring (Alternator 150a)
Cablagem Eletrica (Motor Arra Nque) / Electrical Wiring (Starter)
Cablagem Electrica (Fonte De Alimentação/Controlador (Ceu)) / Electrical Wiring (Power Supply/Controller (Ceu))
Cablagem Electrica (Eixo Tran Versal/Frente) [Com Compressor De Ar] / Electrical Wiring (Transaxle/Front) [With Air Compresser]
Cablagem Electrica (Eixo Tran Versal/Frente) [Sem Compressor De Ar] / Electrical Wiring (Transaxle/Front) [W/O Air Compresser]
Cablagem Electrica (Eixo Tran Versal/Traseira) / Electrical Wiring (Transaxle/Rea R)
Cablagem Electrica(Etcv Valvu La/Secagem) [Com Compressor De Ar] / Electrical Wir Ing (Etcv Valve/Air Dryer) [With Air Compressor]
Cablagem Elétrica (Cabine) (D Ireção/Painel) / Electrical Wiring (Cab) (Steering/ Panel)
Cablagem Elétrica (Cabine) (E Cu) / Electrical Wiring (Cab) (Ecu)
Cablagem Elétrica (Cabine) (C Obertura Das Mudanças/Apoio De Braço) [Com Direçao Rápida] / Electrical Wiring (Cab) (Shift Cover/Armr Est) [With Fast Steering]
Cablagem Elétrica (Cabine) (C Obertura Das Mudanças/Apoio De Braço) [Sem Direçao Rápida] / Electrical Wiring (Cab) (Shift Cover/Armr Est) [W/O Fast Steering]
Cablagem Elétrica (Cabine) (A R Condicionado) [Com Ar Condicionado - Automático] [Modelo 50km/H] / Electrical Wiring (Cab) (Air Cond Itioner) [With Auto Air Conditioner] [50 Km/H Model ]
Cablagem Elétrica (Cabine) (A R Condicionado) [Com Ar Condicionado - Manual] [Mod Elo 50km/H] / Electrical Wiring (Cab) (Air Conditio Ner) [With Manual Air Conditioner] [50 Km/H Model]
Cablagem Electrica (Suporte D A Grelha Dianteira) [Sem Luz De Trabalho(Dianteiro/ Coluna)] / Electrical Wiring (Front Pillar) [W/O Wo Rk Light (Front/Pillar)]
Cablagem Electrica (Suporte D A Grelha Dianteira) [Com Luz De Trabalho(Dianteiro/ Coluna)] / Electrical Wiring (Front Pillar) [With W Ork Light (Front/Pillar)]
Cablagem Electrica (Teto) [Co M Aquecedor De Espelho Retrovisor] / Electrical Wir Ing (Roof) [With Mirror Heater]
Cablagem Electrica (Teto) [Se M Aquecedor De Espelho Retrovisor] / Electrical Wir Ing (Roof) [W/O Mirror Heater]
Cablagem Electrica (Pisca/Pár A-Lama) / Electrical Wiring (Flasher/Mudguard)
Cablagem Electrica [Com 3p Di Anteiro] / Electrical Wiring [With Front 3p]
Cablagem Electrica (Suspensão Dianteira) / Electrical Wiring (Front Suspension)
Cablagem Electrica (Com Direç Ão Automática) [Com Direção Automática] / Electrica L Wiring (Auto Steering) [Auto Steering Compatible]
Cablagem Electrica (Isobus) / Electrical Wiring (Isobus)
Disco Do Amortecedor E Ligação À Caixa / Damper Disk And Housing Connecti On
Carter Embraiagem / Cl Utch Housing
Caixa De Transmissão / Transmission Housing
Caixa Do Eixo Traseiro / Rear Axle Housing
Estrutura Do Veio Tdf / Pto Shaft Housing
Braco Hidraulico / Lif T Arm
Veio Secundario / Coun Tershaft
Veio Primario [Com Arr Asto] / Main Shaft [With Creep]
Veio Primario [Sem Arr Asto] / Main Shaft [W/O Creep]
Veio Principal Tdf / P To Drive Shaft
Dispositivo De Marcha [Com Lento] / Creep Gear [With Creep]
Embraiagem Dianteira / Front Clutch
Deslocação De Potência [Com Arrasto] / Power Shift [With Creep]
Deslocação De Potência [Sem Arrasto] / Power Shift [W/O Creep]
Embraiagem Hidráulica (Entrada) / Hydraulic Clutch (Input)
Embraiagem Hidráulica (Saída) / Hydraulic Clutch (Output)
Veio De Entrada De Pot Ência / Power Input Shaft
Embraiagem Principal [ Com Arrasto] / Main Clutch [With Creep]
Transladador [Com Arra Sto] / Shifter [With Creep]
Transladador [Sem Arra Sto] / Shifter [W/O Creep]
Transladador (Arrasto) [Com Arrasto] / Shifter (Creep) [With Creep]
Estrutura Interior Do Veio Tdf (Embreagem) / Pto Shaft Housing Inner (Clu Tch)
Estrutura Interior Do Veio Tdf (Engrenagem) / Pto Shaft Housing Inner (Ge Ar)
Estrutura Interior Do Veio Tdf (Veio Tdf) / Pto Shaft Housing Inner (Pto Shaft)
Estrutura Interior Do Veio Tdf (Forquilha De Embraiagem) / Pto Shaft Hous Ing Inner (Shift Fork)
Válvula De Pressão / P Ressure Valve
Caixa De Mudança De Ve Locidade / Gear Shift Housing
Pedal Embraiagem / Clu Tch Pedal
Alvanca Inversor / Shuttle Shift L Ever
Alavanca Tdf / Pto Gear Shift Leve R
Diferencial Traseiro / Rear Differential
Travão / Brake
Eixo Traseiro / Brake Shaft
Alavanca Travao Mao / Parki Ng Brake Lever
Pedal Travao / Brake Pedal
Cilindro Travao Principal / Brake Master Cylinder
Tubo Do Travão (Superior/Pa Rte Dianteira) [Travão De Trailer De 1+2 Linha] / B Rake Pipe (Upper/Front) [1+2-Line Traler Brake]
Tubo Do Travão (Superior/Pa Rte Dianteira) [Travão De Trailer De 1 Linha] / Bra Ke Pipe (Upper/Front) [1-Line Traler Brake]
Tubo Do Travão (Inferior/Pa Rte Traseira) [Travão De Trailer De 1+2 Linha] / B Rake Pipe (Lower/Rear) [1+2-Line Traler Brake]
Tubo Do Travão (Inferior/Pa Rte Traseira) [Travão De Trailer De 1 Linha] / Brak E Pipe (Lower/Rear) [1-Line Traler Brake]
Quadro Eixo Frente [Com Tdf Dianteira] / Front Axle Frame [With Front Pto]
Quadro Eixo Frente [Sem Tdf Dianteira] / Front Axle Frame [W/O Front Pto]
Estrutura Do Carregador Dianteiro [Com Equipamento Do Carregador] / Front L Oader Frame [With Loader Equipment]
Balanceiro Da Suspensão Dianteira [Com 3p Dianteiro] / Front Suspension Roc Ker Arm [With Front 3p]
Cilindro Da Suspensão Fr Ontal [Peças Componentes] / Front Suspension Cylind Er [Component Parts]
Suporte Eixo Frente [Eix O Dianteiro Peças Componentes] / Front Axle Bracket [Front Axle Component]
Carter Eixo Frente [Eixo Dianteiro Peças Componentes] / Front Axle Housing [Front Axle Component]
Diferencial Dianteiro [E Ixo Dianteiro Peças Componentes] / Front Differenti Al [Front Axle Component]
Veio Carreto Diferencial [Eixo Dianteiro Peças Componentes] / Differential Gear Shaft [Front Axle Component]
Sensor De Ângulo De Vira Gem Roda [Eixo Dianteiro Peças Componentes] / Wheel Turning Angle Sensor [Front Axle Component]
Tirante/Cilindro Direcçã O [Eixo Dianteiro Peças Componentes] / Tie Rod/Stee Ring Cylinder [Front Axle Component]
Veio Do Propulsor E Resg Uardo / Propeller Shaft And Cover
Direcção Assistida [Peças Componentes] / Steeri Ng Post [Component Parts]
Pedal Inclinacao / Tilt Pedal
Comando De Direção [Com Direção Automática] / S Teering Controller [Auto Steering Compatible]
Comando De Direção [Sem Direção Automática] / S Teering Controller [Auto Steering Incompatible]
Hidráulica Bomba De Moradia / Hydraulic Pump Housing
Embraiagem/Filtro Da Bomba Hi Dráulica / Hydraulic Pump Gear/Filter
Linha De Óleo Hidráulico (Eix O Tranversal) / Hydraulic Oil Line (Transaxle)
Circuito Oleo Direcção (Radia Dor Oleo/Frente) / Hydraulic Oil Line (Oil Cooler/F Ront)
Circuito Oleo Direcção (Radia Dor Oleo/Traseira) / Hydraulic Oil Line (Oil Cooler /Rear)
Radiador Oleo [Com Tdf Diante Ira] / Oil Cooler [With Front Pto]
Circuito Oleo Direcção (Direc Ção Valvula/Filtro) [Com Compressor De Ar] / Hydrau Lic Oil Line (Steering Valve/Filter) [With Air Comp Resser]
Circuito Oleo Direcção (Direc Ção Valvula/Filtro) [Sem Compressor De Ar] / Hydrau Lic Oil Line (Steering Valve/Filter) [W/O Air Compr Esser]
Filtro Oleo [Peças Componente S] / Oil Filter [Component Parts]
Circuito Oleo Direcção (Direc Ção Valvula) / Hydraulic Oil Line (Steering Valve)
Tubo Direccao (Fornecimento) / Steering Hose (Delivery)
Linha De Óleo Hidráulico (Tub O De Fornecimento Do Eixo Dianteiro/Traseiro) / Hyd Raulic Oil Line (Front Axle Delivery Pipe/Front)
Linha De Óleo Hidráulico (Tub O De Fornecimento Do Eixo Dianteiro/Traseiro) / Hyd Raulic Oil Line (Front Axle Delivery Pipe/Rear)
Linha De Óleo Hidráulico (Fil Tro De Óleo) [Com Equipamento Do Carregador] / Hydr Aulic Oil Line (Oil Filter) [With Loader Equipment]
Linha De Óleo Hidráulico (Fil Tro De Óleo) [Sem Equipamento Do Carregador] / Hydr Aulic Oil Line (Oil Filter) [W/O Loader Equipment]
Linha De Óleo Hidráulico (Fil Tro De Óleo A Válvula De Controlo Remoto/Abertura D E Drenagem Hidráulica) [Modelo 50km/H:Travão De Tra Iler De 1+2 Linha] [Com Equipamento Do Carregador] / Hydraulic Oil Line (Oil Filter To Remote Control Valve/Hyd. Drain Port) [50 Km/H Model:1+2-Line Trai Ler Brake] [With Loader Equipment]
Linha De Óleo Hidráulico (Fil Tro De Óleo A Válvula De Controlo Remoto/Abertura D E Drenagem Hidráulica) [Modelo 50km/H:Travão De Tra Iler De 1 Linha] [Com Equipamento Do Carregador] / Hydraulic Oil Line (Oil Filter To Remote Control Va Lve/Hyd. Drain Port) [50 Km/H Model:1-Line Trailer Brake] [With Loader Equipment]
Linha De Óleo Hidráulico (Fil Tro De Óleo A Válvula De Controlo Remoto/Abertura D E Drenagem Hidráulica) [Modelo 50km/H:Travão De Tra Iler De 1+2 Linha] [Sem Equipamento Do Carregador] / Hydraulic Oil Line (Oil Filter To Remote Control Valve/Hyd. Drain Port) [50 Km/H Model:1+2-Line Trai Ler Brake] [W/O Loader Equipment]
Linha De Óleo Hidráulico (Fil Tro De Óleo A Válvula De Controlo Remoto/Abertura D E Drenagem Hidráulica) [Modelo 50km/H:Travão De Tra Iler De 1 Linha] [Sem Equipamento Do Carregador] / Hydraulic Oil Line (Oil Filter To Remote Control Va Lve/Hyd. Drain Port) [50 Km/H Model:1-Line Trailer Brake] [W/O Loader Equipment]
Linha De Óleo Hidráulico (Tub O Do Travão A Válvula De Controlo Remoto) [Com Powe R Beyond] / Hydraulic Oil Line (Brake Pipe To Remo Te Control Valve) [With Power Beyond]
Linha De Óleo Hidráulico (Tub O Do Travão A Válvula De Controlo Remoto) [Sem Powe R Beyond] / Hydraulic Oil Line (Brake Pipe To Remo Te Control Valve) [W/O Power Beyond]
Bloco De Válvula (Eixo Tranve Rsal) / Valve Block (Transaxle)
Bloco De Válvula (Válvula Sol Enóide) / Valve Block (Solenoid Valve)
Axial Bomba [Com Equipamento Do Carregador] / Axial Pump [With Loader Equipment]
Axial Bomba [Sem Equipamento Do Carregador] / Axial Pump [W/O Loader Equipment]
Tubulação De Bomba Axial [Com Equipamento Do Carregador] [Com Power Beyond] / Ax Ial Pump Pingpe [With Loader Equipment] [With Power Beyond]
Tubulação De Bomba Axial [Com Equipamento Do Carregador] [Sem Power Beyond] / Ax Ial Pump Piping [With Loader Equipment] [W/O Power Beyond]
Tubulação De Bomba Axial [Sem Equipamento Do Carregador] [Com Power Beyond] / Ax Ial Pump Piping [W/O Loader Equipment] [With Power Beyond]
Tubulação De Bomba Axial [Sem Equipamento Do Carregador] [Sem Power Beyond] / Ax Ial Pump Piping [W/O Loader Equipment] [W/O Power B Eyond]
Linha De Óleo Hidráulico (Bom Ba Axial A Válvula De Controlo Remoto) [Com Equipam Ento Do Carregador] [Com Power Beyond] / Hydraulic Oil Line (Axial Pump To Remote Control Valve) [With Loader Equipment] [With Power Beyond]
Linha De Óleo Hidráulico (Bom Ba Axial A Válvula De Controlo Remoto) [Com Equipam Ento Do Carregador] [Sem Power Beyond] / Hydraulic Oil Line (Axial Pump To Remote Control Valve) [With Loader Equipment] [W/O Power Beyond]
Linha De Óleo Hidráulico (Bom Ba Axial A Válvula De Controlo Remoto) [Sem Equipam Ento Do Carregador] [Com Power Beyond] / Hydraulic Oil Line (Axial Pump To Remote Control Valve) [W/O Loader Equipment] [With Power Beyond]
Linha De Óleo Hidráulico (Bom Ba Axial A Válvula De Controlo Remoto) [Sem Equipam Ento Do Carregador] [Sem Power Beyond] / Hydraulic Oil Line (Axial Pump To Remote Control Valve) [W/O Loader Equipment] [W/O Power Beyond]
Tubo Da Válvula Da Suspensão Dianteira (Parte Traseira) [Com Saída Hidráulica Di Anteira] / Front Suspension Valve Pipe (Rear) [With Front Hyd. Outlet]
Tubo Da Válvula Da Suspensão Dianteira (Parte Traseira) [Sem Saída Hidráulica Di Anteira] / Front Suspension Valve Pipe (Rear) [W/O Front Hyd. Outlet]
Valvula Da Suspensão Frontal / Front Suspension Valve
Tubo Da Válvula Da Suspensão Dianteira (Frente) [Com Saída Hidráulica Dianteira] / Front Suspension Valve Pipe (Front) [With Front Hyd. Outlet]
Tubo Da Válvula Da Suspensão Dianteira (Frente) [Sem Saída Hidráulica Dianteira] / Front Suspension Valve Pipe (Front) [W/O Front H Yd. Outlet]
Suspensão Frontal Acumulador / Front Suspension Accumulator
Suspensão Frontal Cilindro Tu Bo / Front Suspension Cylinder Hose
Válvula De Controlo Remoto (6 Válvulas) [Com 3p Dianteiro] [Com Saída Hidráulica Dianteira] / Remote Control Valve (6 Valves) [With Front 3p] [With Front Hyd. Outlet]
Válvula De Controlo Remoto (6 Válvulas) [Com 3p Dianteiro] [Sem Saída Hidráulica Dianteira] / Remote Control Valve (6 Valves) [With Front 3p] [W/O Front Hyd. Outlet]
Válvula De Controlo Remoto (5 Válvulas) [Com 3p Dianteiro] [Com Saída Hidráulica Dianteira] / Remote Control Valve (5 Valves) [With Front 3p] [With Front Hyd. Outlet]
Válvula De Controlo Remoto (5 Válvulas) [Com 3p Dianteiro] [Sem Saída Hidráulica Dianteira] / Remote Control Valve (5 Valves) [With Front 3p] [W/O Front Hyd. Outlet]
Válvula De Controlo Remoto (6 Válvulas) [Peças Componentes] / Auxiliary Control Valve (6 Valves) [Component Parts]
Válvula De Controlo Remoto (5 Válvulas) [Peças Componentes] / Auxiliary Control Valve (5 Valves) [Component Parts]
Válvula De Controle Direciona L (6 Válvulas) [Peças Componentes] / Directional Co Ntrol Valve (6 Valves) [Component Parts]
Válvula De Controle Direciona L (5 Válvulas) [Peças Componentes] / Directional Co Ntrol Valve (5 Valves) [Component Parts]
Válvula De Placa End [Peças C Omponentes] / End Plate Valve [Component Parts]
Coletor De Óleo (Válvula De C Ontrolo Remoto) [4p] / Oil Collector (Remote Contro L Valve) [4p]
Coletor De Óleo (Válvula De C Ontrolo Remoto) [3p] / Oil Collector (Remote Contro L Valve) [3p]
Tubo Da Saída Hidráulica Dian Teira (Parte Traseira) [Com Saída Hidráulica Diante Ira] / Front Hydraulic Outlet Pipe (Rear) [With Fro Nt Hyd. Outlet]
Tubo Da Saída Hidráulica Dian Teira (Intermédia) [Com Saída Hidráulica Dianteira] / Front Hydraulic Outlet Pipe (Middle) [With Front Hyd. Outlet]
Tubo Da Saída Hidráulica (Tub O De Controlo Do Sensor De Carga) [Com Power Beyond ] / Hydraulic Outlet Pipe (Load-Sensing Control Hos E) [With Power Beyond]
Tubo Da Saída Hidráulica (Pow Er Beyond/Tubo De Retorno) [Com Power Beyond] / Hyd Raulic Outlet Pipe (Power Beyond/Return Hose) [With Power Beyond]
Valvula Travao Reboque [Model O 50km/H:Travão De Trailer De 1+2 Linha] / Trailer Brake Valve [50 Km/H Model:1+2-Line Trailer Brake]
Valvula Travao Reboque [Travã O De Trailer De 1 Linha] / Trailer Brake Valve [1-L Ine Trailer Brake]
Valvula Travao Reboque/Tubo 1 [Modelo 50km/H:Travão De Trailer De 1+2 Linha] / T Railer Brake Valve/Pipe 1 [50 Km/H Model:1+2-Line T Railer Brake]
Tubo Da Válvula Do Travão De Reboque/Acoplamento [Travão De Trailer De 1+2 Linha ] / Trailer Brake Valve Pipe/Coupler [1+2-Line Trai Ler Brake]
Tubo Da Válvula Do Travão De Reboque/Acoplamento [Travão De Trailer De 1 Linha] / Trailer Brake Valve Pipe/Coupler [1-Line Trailer Brake]
Tubo De Óleo Do Carregador (P Arte Traseira) [Com Equipamento Do Carregador] / Fr Ont Loader Oil Pipe (Rear) [With Loader Equipment]
Tubo De Óleo Do Carregador (P Arte Dianteira) [Com Equipamento Do Carregador] / F Ront Loader Oil Pipe (Front) [With Loader Equipment ]
Compressor De Ar [Com Compressor De Ar] / Air Compressor [With Air Compressor]
Compressor De Ar [Peças Component Es][Com Compressor De Ar] / Air Compressor [Compone Nt Parts] [With Air Compressor]
Tubo Do Compressor De Ar [Com Com Pressor De Ar] / Air Compressor Pipe [With Air Comp Ressor]
Tubo De Refrigeração [Com Compres Sor De Ar] / Cooling Pipe [With Air Compressor]
Deposito De Ar [Com Compressor De Ar] / Air Tank [With Air Compressor]
Tubo Do Deposito De Ar [Com Compr Essor De Ar] [Tipo De Suspensão Traseira (Mola)] / Air Tank Pipe [With Air Compressor] [Rear Suspensio N Type (Spring)]
Tubo Do Deposito De Ar [Com Compr Essor De Ar] [Tipo De Suspensão Traseira (Ar)] / Ai R Tank Pipe [With Air Compressor] [Rear Suspension Type (Air)]
Acoplador De Ar [Com Compressor D E Ar] [Travão De Trailer De 1 Linha] / Air Coupler [With Air Compressor] [1-Line Traler Brake]
Elo 3p D Ianteiro (Elo Estrutura/Superior) [Com 3p Dianteiro ] [Com Saída Hidráulica Dianteira] / Front 3p Link (Frame/Top Link) [With Front 3p] [With Front Hyd. O Utlet]
Elo 3p D Ianteiro (Elo Estrutura/Superior) [Com 3p Dianteiro ] [Sem Saída Hidráulica Dianteira] / Front 3p Link (Frame/Top Link) [With Front 3p] [W/O Front Hyd. Ou Tlet]
Elo 3p D Ianteiro (Içador) [Com 3p Dianteiro] / Front 3p Lin K (Lifter) [With Front 3p]
Ligação 3p Dianteira (Cilindro) [Com 3p Dianteiro] / Front 3p Link (Cylinder) [With Front 3p]
Tdf Dian Teira [Com Tdf Dianteira] / Front Pto [With Front P To]
Caixa Da Engrenagem Tdf (Carreto) [Peças Componentes] [Com Tdf Dianteira] / Pto Gear Case (Gear) [Component Pa Rts] [With Front Pto]
Caixa Da Engrenagem Tdf (Bomba) [Peças Componentes] [Com Td F Dianteira] / Pto Gear Case (Pump) [Component Part S] [With Front Pto]
Caixa Da Engrenagem Tdf (Embraiagem) [Peças Componentes] [C Om Tdf Dianteira] / Pto Gear Case (Clutch) [Compone Nt Parts] [With Front Pto]
Caixa Da Engrenagem Tdf (Caixa) [Peças Componentes] [Com Td F Dianteira] / Pto Gear Case (Case) [Component Part S] [With Front Pto]
Caixa Da Engrenagem Tdf (Kit De Juntas E Vedantes) [Peças C Omponentes] [Com Tdf Dianteira] / Pto Gear Case (Ga Sket And Seal Kit) [Component Parts] [With Front Pt O]
Suporte Do Elo Superior/Suporte Do Acoplador / Top Link Bra Cket/Coupler Bracket
Ligação 3 Pontos (Ligação Superior:Manual) / 3-Point Linkag E (Top Link:Manual)
Ligação 3 Pontos (Ligação Superior:Hidráulica) / 3-Point Li Nkage (Top Link:Hydraulic)
Estabili Zador (Automatico) [Com Puxo (Escada)] / Stabilizer (Automatic) [With Hitch (Ladder)]
Estabili Zador (Elevador) [Com Puxo (Dromone)] / Stabilizer (Lifter) [With Hitch (Dromone)]
Estabili Zador (Automatico) [Com Puxo (Dromone)] / Stabilize R (Automatic) [With Hitch (Dromone)]
Estabili Zador (Elevador) [Peças Componentes] / Stabilizer ( Lifter) [Component Parts]
Estabili Zador (Automatico) [Peças Componentes] / Stabilizer (Automatic) [Component Parts]
Ligação 3 Pontos (Tirante De Elevação) / 3-Point Linkage (L Ift Rod)
Puxo Bar Ra [Com Puxo (Escada)] / Drawbar Bracket [With Hitc H (Ladder)]
Barra Re Boque(Padrão) [Com Puxo (Escada)] / Drawbar (Standa Rd) [With Hitch (Ladder)]
Barra Re Boque (Fixed Piton) [Com Puxo (Escada)] / Drawbar ( Fixed Piton) [With Hitch (Ladder)]
Barra Re Boque (Cuna) [Com Puxo (Escada)] / Drawbar (Cuna) [ With Hitch (Ladder)]
Barra Re Boque(Engate K80) [Com Puxo (Escada)] / Drawbar (Co Upling K80) [With Hitch (Ladder)]
Cobertur A De Barras De Engate [Com Barra Reboque] / Drawbar Cover [With Drawbar]
Puxo (Es Cada) [Com Puxo (Escada)] / Hitch (Ladder) [With Hi Tch (Ladder)]
Puxo (Dr Omone) [Com Puxo (Dromone)] / Hitch (Dromone) [With Hitch (Dromone)]
Puxo (Dr Omone) [Peças Componentes] [Com Puxo (Dromone)] / H Itch (Dromone) [Component Parts] [With Hitch (Dromo Ne)]
Puxo (Dr Omone) Control Alavanca [Com Puxo (Dromone)] / Hitc H (Dromone) Trailer Lever [With Hitch (Dromone)]
Gancho T Railer (Automatico) [Com Puxo (Escada)] / Trailer C Levis (Automatic) [With Hitch (Ladder)]
Gancho T Railer (Piton) [Com Puxo (Escada)] / Trailer Clevis (Piton) [With Hitch (Ladder)]
Gancho T Railer (Cuna-D3) [Com Puxo (Escada)] / Trailer Clev Is (Cuna-D3) [With Hitch (Ladder)]
Gancho T Railer (K80) [Com Puxo (Escada)] / Trailer Clevis ( K80) [With Hitch (Ladder)]
Gancho T Railer (Cuna-D2) [Com Puxo (Escada)] / Trailer Clev Is (Cuna-D2) [With Hitch (Ladder)]
Gancho T Railer (Automatico) [Com Puxo (Escada)] [Peças Comp Onentes] / Trailer Clevis (Automatic) [Component Pa Rts] [With Hitch (Ladder)]
Gancho T Railer (Manual) [Com Puxo (Escada)] [Peças Componen Tes] / Trailer Clevis (Manual) [Component Parts] [W Ith Hitch (Ladder)]
Estrutura Capot / Hood (Bonnet) Frame
Estrutura Capot [Com Lampada De Halogénio] / Ho Od (Bonnet) Frame [With Halogen Light]
Estrutura Capot (Inferior) / Hood (Bonnet) Fram E (Lower)
Capot Inferior (Direito) / Hood (Bonnet) Side L Ower Rh
Capot Inferior (Esquerdo) [Com Compressor De Ar ] / Hood (Bonnet) Side Lower Lh [With Air Compresso R]
Capot Inferior (Esquerdo) [Sem Compressor De Ar ] / Hood (Bonnet) Side Lower Lh [W/O Air Compressor ]
Placa Do Obturador (Silenciador/Isolador) / Shu Tter Plate (Sound Absorber/Insulator)
Guarda-Lamas Dianteiro (W:540) / Front Fender ( W:540)
Guarda-Lamas Dianteiro (W:600) / Front Fender ( W:600)
Placa Sinalizadora [Com Guarda-Lamas Dianteiro (W:600)] / Signal Plate [With Front Fender (W:600)]
Est Rutura Cabine [Tipo De Suspensão Traseira (Ar/Mola) ] / Cab Frame [Rear Suspension Type (Air/Spring)]
Deg Rau Direito [Sem Equipamento Do Carregador] / Step Rh [W/O Loader Equipment]
Deg Rau Esquerdo / Step Lh
Cob Ertura Frontal / Front Cover
Por Ta Drt / Door Rh
Por Ta Esq / Door Lh
Tri Nco Porta Drt / Door Lock Rh
Vid Ro Traseiro Da Escotilha (Vidro Traseiro) [Sem Dese Mbaçador] / Hatch Back Glass (Rear Window) [W/O Def Ogger]
Vid Ro Traseiro Da Escotilha (Vidro Traseiro) [Com Dese Mbaçador] / Hatch Back Glass (Rear Window) [With De Fogger]
Tej Adilho / Sun Roof
Esp Elho Rectrovisor [Com Aquecedor De Espelho Retrovis Or] / Rearview Mirror [With Mirror Heater]
Esp Elho Rectrovisor [Sem Aquecedor De Espelho Retrovis Or] / Rearview Mirror [W/O Mirror Heater]
Tec To Interior [Com Holofote] / Inner Roof [With Spot Light]
Tec To Interior [Sem Holofote] / Inner Roof [W/O Spot L Ight]
Cob Ertura Exterior Do Tejadilho / Outer Roof
Sup Orte Do Assento / Seat Bracket
Ban Co / Seat
Ass Ento Do Banco / Seat Cushion
Apo Io-De-Braço Do Banco/Encosto Do Banco / Seat Armres T/Seat Backrest
Sus Pensao Banco / Seat Suspension
Ban Co De Passageiro / Passenger Seat
Tap Ete Do Piso / Floor Mat
Mat Erial À Prova De Som (Painel) / Soundproof Material (Panel)
Mat Erial À Prova De Som (Chão) / Soundproof Material ( Floor)
Mat Erial À Prova De Som (Consola) / Soundproof Materia L (Console)
Mat Erial À Prova De Som (Tejadilho) / Soundproof Mater Ial (Roof)
Cob Ertura De Mudança (Consola Direita) [Com Arrasto] / Shift Cover (Console Rh) [With Creep]
Cob Ertura De Mudança (Consola Direita) [Sem Arrasto] / Shift Cover (Console Rh) [W/O Creep]
Tam Pa Do Rádio E Tampa Do Painel De Controlo Do Ar Con Dicionado [Com Ar Condicionado - Automático] / Radi O Cover And Air Conditioner Control Panel Cover [Wi Th Auto Air Conditioner]
Con Sola Do Lado Esquerdo / Console Lh
Res Guardo Coluna / Pillar Cover
Cob Ertura Do Guarda-Lamas / Fender Cover
Gua Rda Lamas (Direito) [Antigo] / Fender Rh [Old]
Gua Rda Lamas (Direito) [Novo] / Fender Rh [New]
Gua Rda Lamas (Esquerda) [Antigo] / Fender Lh [Old]
Gua Rda Lamas (Esquerda) [Novo] / Fender Lh [New]
Gua Rda Lamas / Over Fender
Sup Orte Cabine Frente [Com Equipamento Do Carregador] / Cab Bracket Front [With Loader Equipment]
Sup Orte Cabine Frente [Sem Equipamento Do Carregador] / Cab Bracket Front [W/O Loader Equipment]
Sup Orte Cabine Traseira [Tipo De Suspensão Traseira (A R/Mola)] / Cab Bracket Rear [Rear Suspension Type ( Air/Spring)]
Tra Seira Amortecedor [Tipo De Suspensão Traseira (Mola )] / Rear Damper [Rear Suspension Type (Spring)]
Tra Seira Amortecedor [Tipo De Suspensão Traseira (Ar)] [Com Compressor De Ar] / Rear Damper [Rear Suspens Ion Type (Air)] [With Air Compressor]
Cai Xa Ferramenta / Tool Box
Ar Condicionado [Com Ar Condicion Ado - Automático] / Air Conditioner [With Auto Air Conditioner]
Ar Condicionado [Com Ar Condicion Ado - Manual] / Air Conditioner [With Manual Air Co Nditioner]
Conduta Do Ar Condicionado (Ar Fr Io) / Air Conditioner Duct (Fresh Air)
Conduta Do Ar Condicionado (Trase Ira) / Air Conditioner Duct (Rear)
Modo Caixa / Mode Case
Entradas Ar Painel Instrumentos / Dashboard Air Outlets
Circulaçao Ar Interior [Com Ar Co Ndicionado - Automático] / Inner Air Recirculation [With Auto Air Conditioner]
Circulaçao Ar Interior [Com Ar Co Ndicionado - Manual] / Inner Air Recirculation [Wit H Manual Air Conditioner]
Tubo Ar Condicionado/Tubo Condens Ador / Air Conditioner Hose/Condenser Hose
Polia De Acionamento Do Compresso R [Com Compressor De Ar] / Compressor Drive Pulley [With Air Compressor]
Polia De Acionamento Do Compresso R [Sem Compressor De Ar] / Compressor Drive Pulley [W/O Air Compressor]
Compressor (Ar Condicionado) / Co Mpressor (Air Conditioner)
Roda Dianteira (480/70r28) [Michelin] / Front Wheel (480/70r28) [Michelin]
Roda Dianteira (540/65r28) [Michelin] / Front Wheel (540/65r28) [Michelin]
Roda Dianteira (540/65r28) [Trellebor G] / Front Wheel (540/65r28) [Trelleborg]
Roda Dianteira (600/60r28) [Michelin] / Front Wheel (600/60r28) [Michelin]
Roda Traseira (580/70r38) [Michelin] / Rear Wheel (580/70r38) [Michelin]
Roda Traseira (650/65r38) [Michelin] / Rear Wheel (650/65r38) [Michelin]
Roda Traseira (650/65r38) [Trelleborg ] / Rear Wheel (650/65r38) [Trelleborg]
Roda Traseira (700/60r38) [Michelin] / Rear Wheel (700/60r38) [Michelin]
Decalcomania(Painel/Cobertura De Mudança) [Com A Rrasto] / Label (Panel/Shift Cover) [With Creep]
Etiqueta (Traseira) [Com Puxo (Dromone)] / Label S (Rear) [With Hitch (Dromone)]
Etiqueta (Unidade Control Electrico/Controlador) / Label (Ecu/Controller)
Decalcomania (Cabine Interior) / Label (Cab Inte Rior)
P Eça De Acessorio E Serviço Peças / Accessories And Service Parts
K It Alternador (200a) [Opção] / Alternator Kit (200a ) [Option]
A Lternador [Peças Componentes] (200a) [Opção] / Alte Rnator [Component Parts] (200a) [Option]
L Âmpada Farol [Opçao] / Beacon Lamp Kit [Option]
K It Luzes Trabalho [Com Lampada De Led] [Opçao] / Wo Rking Light Kit [With Led Light] [Option]
K It Luzes Trabalho [Com Lampada De Halogénio] [Opçao ] / Working Light Kit [With Halogen Light] [Option]
L Uzes Frente (Farol De Repetição) [Opçao] / Head Lig Ht Kit (Repeat Head Light) [Option]
K It De Luz Interior [Opção] / Room Light Kit [Option ]
K It Da Tdf Dianteira (6 Estrias) (Caixa Da Engrenage M) [Opção] / Front Pto Kit (6 Splines) (Gear Case) [Option]
K It Da Tdf Dianteira (6 Estrias) (Engrenagem) [Opção ] / Front Pto Kit (6 Splines) (Gear) [Option]
K It Da Tdf Dianteira (6 Estrias) (Bomba) [Opção] / F Ront Pto Kit (6 Splines) (Pump) [Option]
K It Da Tdf Dianteira (6 Estrias) (Embraiagem) [Opção ] / Front Pto Kit (6 Splines) (Clutch) [Option]
K It Da Tdf Dianteira (6 Estrias) (Caixa) [Opção] / F Ront Pto Kit (6 Splines) (Case) [Option]
K It Da Tdf Dianteira (6 Estrias) (Engrenagem Box/Jun Ta) [Opção] / Front Pto Kit (6 Splines) (Gear Case/ Gasket) [Option]
K It Da Tdf Dianteira (6 Estrias) (Arrefecedor Do Óle O) [Opção] / Front Pto Kit (6 Splines) (Oil Cooler) [Option]
K It Do Terminal (12 Polegadas) [Opção] / Terminal Ki T (12 Inch) [Option]
K It Do Sensor (Radar) [Opção] / Sensor Kit (Radar) [ Option]
K It Da Câmara [Opção] / Camera Kit [Option]
K It De Antena (Modem Rtk De Direção Automática) (Ant Ena) [Opçao] / Anntena Kit (Auto Steer Rtk Modem) ( Anntena) [Option]
K It De Antena (Modem Rtk De Direção Automática) (Con Trolador) [Opçao] / Anntena Kit (Auto Steer Rtk Mod Em) (Controller) [Option]
K It De Antena (Direção Automática Dgps/Sem Rtk) [Opç Ao] / Anntena Kit (Auto Steer Dgps/Without Rtk) [Op Tion]
K It De 21 Estrias De Tdf [Opção] [Ec] / Pto Kit (21 Splines) [Option] [Ec]
K It Do Reboque (Automático) [Opção] / Trailer Kit (A Uto) [Option]
K It Do Reboque (Manual) [Opção] / Trailer Kit (Manua L) [Option]
K It Do Reboque (K80) [Opção] / Trailer Kit (K80) [Op Tion]
K It Do Reboque (Pistão) [Opção] / Trailer Kit (Piton ) [Option]
K It Do Reboque (Cuna-D3) [Opção] / Trailer Kit (Cuna -D3) [Option]
K It Do Reboque (Cuna-D2) [Opção] / Trailer Kit (Cuna -D2) [Option]
K It Do Reboque (Cuna-C) [Opção] / Trailer Kit (Cuna- C) [Option]
G Ancho Trailer (Automatico) [Peças Componentes] [Opç Ão] / Trailer Clevis (Automatic) [Component Parts] [Option]
G Ancho Trailer (Manual) [Peças Componentes] [Opção] / Trailer Clevis (Manual) [Component Parts] [Option ]
E Spelho Retrovisor Com Kit De Aquecedor [Opção] / Re Arview Mirror Kit (With Heater) [Option]
A Uxiliar Do Válvula De Controlo Kit (Elétrica 5ª) [O Pção] / Auxiliary Control Valve Kit (Elec.5th) [Opt Ion]
K It De Acoplador Powr Beyond (Acoplador) [Opção] / P Ower Beyond Coupler Kit (Coupler) [Option]
K It De Acoplador Powr Beyond (Tubo/Acoplador) [Opção ] / Power Beyond Coupler Kit (Pipe/Coupler) [Option ]
L Igacao Superior (Hidráulica) [Opção] / Top Link Kit (Hydraulic) [Option]
K It De Ligação 3-P Dianteira (Elo Estrutura/Superior ) [Opção] / Front 3p Link Kit (Frame/Top Link) [Opt Ion]
K It De Ligação 3-P Dianteira (Elevação) [Opção] / Fr Ont 3p Link Kit (Lifter) [Option]
K It De Ligação 3-P Dianteira (Cilndro) [Opção] / Fro Nt 3p Link Kit (Cylinder) [Option]
K It De Ligação 3-P Dianteira (Mecânica 6ª) (Válvula) [Opção] / Front 3p Link Kit (Elec.6th) (Valve) [Op Tion]
K It De Ligação 3-P Dianteira (Mecânica 5ª) (Válvula) [Opção] / Front 3p Link Kit (Elec.5th) (Valve) [Op Tion]
K It Da Interruptor Externo Da Ligação 3-P Dianteira[ Opçao] / External Switch For Front 3-Point Hitch [O Ption]
K It De Escora (Padrão) [Opção] / Drawbar Kit (Standa Rd) [Option]
K It De Escora (Acoplamento K80) [Opção] / Drawbar Ki T (Coupling K80) [Option]
K It De Escora (Cuna) [Opção] / Drawbar Kit (Cuna) [O Ption]
K It Do Guarda-Lamas Dianteiro (W:410) [Opção] / Fron T Fender Kit (W:410) [Option]
K It Do Guarda-Lamas Dianteiro (W:540) [Opção] / Fron T Fender Kit (W:540) [Option]
K It Do Guarda-Lamas Traseiro [Opção] / Rear Over Fen Der Kit [Option]
K It Desnebulizador Traseiro [Opção] / Rear Defogger Kit [Option]
K It Protetor De Para-Sol [Opção] / Sunshade Shield K It [Option]
