Kubota Tractor M7171P Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M7171P Tractor
Number of Pages: 687 Pages
Itens Usados Fr Equentemente [Com Compressor De Ar] / Frequently Us Ed Items [With Air Compresser]
Itens Usados Fr Equentemente [Sem Compressor De Ar] / Frequently Us Ed Items [W/O Air Compresser]
Itens Usados Fr Equentemente (Componenetes Electricos) / Frequently Used Items (Electrical Parts)
B Loco Motor(Superior) / Crankcase (Upper)
B Loco Motor(Inferior) / Crankcase (Lower)
C Árter Do Óleo [Com Compressor De Ar] / Oil Pan [Wit H Air Compressor]
C Árter Do Óleo [Sem Compressor De Ar] / Oil Pan [W/O Air Compressor]
C Abeça Motor / Cylinder Head
V Alvula Admissao E Escape / Inlet Valve And Exhaust Valve
B Raço / Rocker Arm Shaft
T Ampa Cabeça / Head Cover
C Obertura Frontal / Front Cover
P Iston E Cambota / Piston And Crankshaft
C Ompensador / Balancer
V Olante Motor / Flywheel
F Iltro Gasoleo / Fuel Filter
I Njector E Vela Aquecimento / Injector And Glow Plug
T Ubo Injector / Injection Pipe
C Ommon Rail / Common Rail
B Omba Agua / Water Pump
R Adiador Oleo / Oil Cooler
S Eparador De Óleo / Oil Separator
S Eparador De Óleo [Peças Componentes] / Oil Separato R [Component Parts]
T Ubo Do Separador De Óleo / Oil Separator Pipe
T Ubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charg Er)
F Iltro Ar [Com Tdf Dianteira] / Air Cleaner [With Fr Ont Pto]
F Iltro Ar [Sem Tdf Dianteira] / Air Cleaner [W/O Fro Nt Pto]
F Iltro Ar [Peças Componentes] / Air Cleaner [Compone Nt Parts]
T Ubo De Entrada (Filtro De Ar) [Com Compressor De Ar ] / Inlet Pipe (Air Cleaner) [With Air Compresser]
T Ubo De Entrada (Filtro De Ar) [Sem Compressor De Ar ] / Inlet Pipe (Air Cleaner) [W/O Air Compresser]
T Urbo Compressor / Turbo Charger
F Lange Filtro Ar E Valvula Acelarador / Air Cleaner Flange And Throttle Valve
V Alvula Egr / Egr Valve
R Efrigerador Egr / Egr Cooler
T Ubos De Água Egr / Egr Water Piping
C Olector Escape / Exhaust Manifold
S Ilenciador Do Filtro De Partículas Diesel / Diesel Particulate Filter Muffler
S Ilenciador Do Filtro De Partículas Diesel [Peças Co Mponentes] / Diesel Particulate Filter Muffler [Com Ponent Parts]
T Ubo Pressao / Pressure Pipe
P Anela Escape / Muffler Pipe
S Ilenciador De Redução Catalítica Seletivo [Antigo] / Selective Catalytic Reduction Muffler [Old]
S Ilenciador De Redução Catalítica Seletivo [Novo] / Selective Catalytic Reduction Muffler [New]
T Ubulação E Proteção Do Silênciador / Muffler Pipe A Nd Cover
D Epósito Do Fluido De Escape De Diesel / Diesel Exha Ust Fluid Tank
D Epósito Do Fluido De Escape De Diesel [Peças Compon Entes] / Diesel Exhaust Fluid Tank [Component Parts ]
D Epósito Do Fluido De Escape De Diesel Tubo / Diesel Exhaust Fluid Hose
D Epósito Do Fluido De Escape De Diesel Aquecedor Tub O / Diesel Exhaust Fluid Heater Hose
D Epósito Do Fluido De Escape De Diesel Mangueira De Respiro / Diesel Exhaust Fluid Breather Hose
V Álvula Egr (Sistema De Redução Catalítica Seletiva) / Egr Valve (Selective Catalytic Reduction System)
S Istema De Arrefecimento Egr (Sistema De Redução Cat Alítica Seletiva) / Egr Cooler (Selective Catalytic Reduction System)
T Ubo Egr (Sistema De Redução Catalítica Seletiva) / Egr Pipe (Selective Catalytic Reduction System)
T Ubos De Água Egr (Sistema De Redução Catalítica Sel Etiva) / Egr Water Piping (Selective Catalytic Redu Ction System)
C Omponentes Electricos Motor (Sensor/Ecu) / Engine E Lectrical Parts (Sensor/Ecu)
Deposito Combustivel / Fuel Ta Nk
Suporte Deposito Combustivel [ Com Equipamento Do Carregador] / Fuel Tank Bracket [With Loader Equipment]
Suporte Deposito Combustivel [ Sem Equipamento Do Carregador] / Fuel Tank Bracket [W/O Loader Equipment]
Tubo Do Combustível (Enchiment O Do Combustível) / Fuel Pipe (Fuel Filter)
Arrefecedor Do Combustível [An Tigo] / Fuel Cooler [Old]
Arrefecedor Do Combustível [No Vo] / Fuel Cooler [New]
Separador / Separator
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Component Es] / Fuel Pump [Component Parts]
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Componen Tes] / Fuel Filter [Component Parts]
Suporte Vent Ilador [Antigo] / Fan Bracket [Old]
Suporte Vent Ilador [Novo] / Fan Bracket [New]
Polia De Aci Onamento Da Ventoinha / Fan Drive Pulley
Ventoinha [A Ntigo] / Fan [Old]
Ventoinha [N Ovo] / Fan [New]
Tubo De Água E Tubo Do Sistema De Arrefecimento / Water Pipe An D Cooler Pipe
Unidade Do S Istema De Arrefecimento / Cooler Unit
Unidade Do A Rrefecedor (Radiador) [Peças Componentes] / Cooler Unit (Radiator) [Component Parts]
Unidade Do A Rrefecedor (Permutador Intermédio De Calor) [Peças Componentes] / Cooler Unit (Inter Cooler) [Componen T Parts]
Unidade Do A Rrefecedor (Arrefecedor Do Óleo) [Peças Componentes ] / Cooler Unit (Oil Cooler) [Component Parts]
Unidade Do A Rrefecedor (Condensador) [Peças Componentes] / Cool Er Unit (Condenser) [Component Parts]
Tubo Do Depó Sito De Reserva [Com Compressor De Ar] / Reserve Ta Nk Hose [With Air Compressor]
Tubo Do Depó Sito De Reserva [Sem Compressor De Ar] / Reserve Ta Nk Hose [W/O Air Compressor]
Alternador (200a) / Alternato R (200a)
Alternador (150a) / Alternato R (150a)
Alternador (200a) [Peças Comp Onentes] / Alternator (200a) [Component Parts]
Alternador (150a) [Peças Comp Onentes] / Alternator (150a) [Component Parts]
Motor Arranque / Starter
Suporte De Bateria / Battery Bracket
Interruptor/Sensor (Bloco Mot Or Esquerda) / Switch/Sensor (Engine Lh)
Interruptor/Sensor (Bloco Mot Or Direita) / Switch/Sensor (Engine Rh)
Sensor Da Redução Catalítica Seletiva / Selective Catalytic Reduction Sensor
Suspensão Frontal Sensor [Com Suspensão Frontal] / Front Suspension Sensor [With Front Suspension]
Sensor (Pedal) / Sensor (Peda L)
Interruptor/Sensor [Eixo Dian Teiro: Tipo Padrão] [Com Compressor De Ar] [Tipo De Suspensão (Ar)] [Antigo] / Switch/Sensor [Front Ax Le:Standard Type] [Suspension Type (Air)] [With Air Compressor] [Old]
Interruptor/Sensor [Eixo Dian Teiro: Tipo Padrão] [Com Compressor De Ar] [Tipo De Suspensão (Ar)] [Novo] / Switch/Sensor [Front Axle :Standard Type] [Suspension Type (Air)] [With Air C Ompressor] [New]
Interruptor/Sensor [Eixo Dian Teiro: Tipo Padrão] [Com Compressor De Ar] [Suspens Ão(Mola)] [Antigo] / Switch/Sensor [Front Axle:Stan Dard Type] [Suspension Type (Spring)] [With Air Com Pressor] [Old]
Interruptor/Sensor [Eixo Dian Teiro: Tipo Padrão] [Com Compressor De Ar] [Suspens Ão(Mola)] [Novo] / Switch/Sensor [Front Axle:Standa Rd Type] [Suspension Type (Spring)] [With Air Compr Essor] [New]
Interruptor/Sensor [Eixo Dian Teiro: Tipo Padrão] [Sem Compressor De Ar] [Antigo] / Switch/Sensor [Front Axle:Standard Type] [W/O Ai R Compressor] [Old]
Interruptor/Sensor [Eixo Dian Teiro: Tipo Padrão] [Sem Compressor De Ar] [Novo] / Switch/Sensor [Front Axle:Standard Type] [W/O Air Compressor] [New]
Interruptor/Sensor [Eixo Dian Teiro: Tipo Pesado] [Com Compressor De Ar] / Switch /Sensor [Front Axle:Heavy Duty Type] [With Air Comp Ressor]
Interruptor/Sensor [Eixo Dian Teiro: Tipo Pesado] [Sem Compressor De Ar] / Switch /Sensor [Front Axle:Heavy Duty Type] [W/O Air Compr Essor]
Sensor (Caixa De Transmissão) [Componente De Translaxe] / Sensor (Transmission H Ousing Rh) [Transaxle Component]
Sensor/Valvula (Hidráulica Bo Mba De Moradia / Tdf Shaft Habitação) / Sensor/Valv E (Hydraulic Pump Housing/Pto Shaft Housing)
Sensor Da Conicidade/Sensor 3 P / Draft Sensor/3p Sensor
Interruptor (Painel) / Switch (Panel Board)
Interruptor (Direcção) [Com D Ireção Automática] / Switch (Steering) [Auto Steeri Ng Compatible]
Interruptor (Direcção) [Sem D Ireção Automática] / Switch (Steering) [Auto Steeri Ng Incompatible]
Interruptor (Cobertura De Mud Ança) / Switch (Shift Cover)
Interruptor Externo / Externa L Switch
Relé/Controlador / Relay/Cont Roller
Unidade Control Electrico (Bl Oco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico/Con Trolador / Electronic Control Unit/Controller
Controlador (Ceu) / Controlle R (Ceu)
Controlador (Ceu) [Peças Comp Onentes] / Controller (Ceu) [Component Parts]
Painel / Panel
Peças Elétricas Da Traseira I Nterior Da Cabine (Saída Elétrica/Painel De Control O Do Ar Condicionado) / Cab Inner Rear Electrical P Arts (Electrical Outlet/Air Conditioner Control Pan El)
Terminal Isobus / Isobus Term Inal
Apoio De Braço (4 Válvulas De Controlo Remoto) [Com Controle De Video Game] / Ar Mrest (4 Remote Control Valves) [With Joystick]
Apoio De Braço (4 Válvulas De Controlo Remoto) [Sem Controle De Video Game] / Ar Mrest (4 Remote Control Valves) [W/O Joystick]
Apoio De Braço (5 Válvulas De Controlo Remoto) [Com Controle De Video Game] / Ar Mrest (5 Remote Control Valves) [With Joystick]
Apoio De Braço (6 Válvulas De Controlo Remoto) [Com Controle De Video Game] / Ar Mrest (6 Remote Control Valves) [With Joystick]
Apoio De Braço (6 Válvulas De Controlo Remoto) [Sem Controle De Video Game] / Ar Mrest (6 Remote Control Valves) [W/O Joystick]
Terminal (12 Polegadas) / Ter Minal (12 Inch)
Terminal (7 Polegadas) / Term Inal (7 Inch)
Luzes Frente / Head Light
Luzes Frente (Coluna) [Com Fa Rol De Repetição] / Head Light (Pillar) [With Repea T Head Light]
Lâmpada Farol / Beacon Lamp
Luzes Frontais / Front Combin Ation Lamp
Luz De Trabalho (Dianteiro/Te To) [Antigo] / Work Light (Front/Roof) [Old]
Luz De Trabalho (Dianteiro/Te To) [Novo] / Work Light (Front/Roof) [New]
Luz De Trabalho (Dianteiro/Co Luna) [Com 10 Luzes De Trabalho] / Work Light (Fron T/Pillar) [Cab Work Light:With 10 Work Light]
Luz De Trabalho (Traseiro/Tet O) / Work Light (Rear/Roof)
Luz De Trabalho (Traseiro/Col Una) [Com 10 Luzes De Trabalho] / Work Light (Rear/ Pillar) [Cab Work Light:With 10 Work Light]
Braco Traseiro / Rear Combina Tion Lamp
Lâmpada Licenciada [Antigo] / License Lamp [Old]
Lâmpada Licenciada [Novo] / L Icense Lamp [New]
Ficha Reboque / Trailer Socke T
Luz Interior / Room Light
Alta Voz Radio / Radio Speake R
Escova / Wiper
Cablagem Elétrica (Motor) 1 ( Filtro De Ar/Dpf) / Electrical Wiring (Engine) 1 (A Ir Cleaner/Dpf)
Cablagem Elétrica (Motor) 2 ( Crs) / Electrical Wiring (Engine) 2 (Crs)
Cablagem Elétrica (Motor) 3 ( Combustível/Scr) / Electrical Wiring (Engine) 3 (Fu El/Scr)
Cablagem Elétrica (Motor) 4 ( Fusível/Bateria) / Electrical Wiring (Engine) 4 (Fu Se/Battery)
Cablagem Elétrica (Motor) 5 ( Compressor/Volante) [Com Compressor De Ar] / Electr Ical Wiring (Engine) 5 (Compressor/Flywheel) [With Air Compresser]
Cablagem Elétrica (Motor) 5 ( Compressor/Volante) [Sem Compressor De Ar] / Electr Ical Wiring (Engine) 5 (Compressor/Flywheel) [W/O A Ir Compresser]
Cablagem Elétrica (Capot) / E Lectrical Wiring (Bonnet(Hood))
Cablagem Elétrica (Alternador ) [Com Alternador (200 A)] / Electrical Wiring (Alt Ernator 200a)
Cablagem Eletrica (Motor Arra Nque) / Electrical Wiring (Starter)
Cablagem Electrica (Fonte De Alimentação)/Controlador (Ceu) / Electrical Wiring (Power Supply)/Controller (Ceu)
Cablagem Electrica (Eixo Tran Versal/Frente) [Com Compressor De Ar] / Electrical Wiring (Transaxle/Front) [With Air Compresser]
Cablagem Electrica (Eixo Tran Versal/Frente) [Sem Compressor De Ar] / Electrical Wiring (Transaxle/Front) [W/O Air Compresser]
Cablagem Electrica (Eixo Tran Versal/Traseira) / Electrical Wiring (Transaxle/Rea R)
Cablagem Electrica (Distribui Dor Auxiliar) / Electrical Wiring (Remote Control V Alve)
Cablagem Elétrica (Cabine) 1 (Direção/Painel) [Antigo] / Electrical Wiring (Cab) 1 (Steering/Panel) [Old]
Cablagem Elétrica (Cabine) 1 (Direção/Painel) [Novo] / Electrical Wiring (Cab) 1 (Steering/Panel) [New]
Cablagem Elétrica (Cabine) 2 (Ecu) [Antigo] / Electrical Wiring (Cab) 2 (Ecu) [O Ld]
Cablagem Elétrica (Cabine) 2 (Ecu) [Novo] / Electrical Wiring (Cab) 2 (Ecu) [New ]
Cablagem Elétrica (Cabine) 3 (Cobertura Das Mudanças/Apoio De Braço) / Electrica L Wiring (Cab) 3 (Shift Cover/Armrest)
Cablagem Elétrica (Cabine) 4 (Ar Condicionado) / Electrical Wiring (Cab) 4 (Air Conditioner)
Cablagem Elétrica (Pilar Dian Teiro) [Antigo] / Electrical Wiring (Front Pillar) [Old]
Cablagem Elétrica (Pilar Dian Teiro) [Novo] / Electrical Wiring (Front Pillar) [N Ew]
Cablagem Electrica (Teto) / E Lectrical Wiring (Roof)
Cablagem Electrica (Pisca/Pár A-Lama) / Electrical Wiring (Flasher/Mudguard)
Cablagem Electrica (Suspensão Dianteira) [Com Suspensão Dianteira] / Electrical Wiring (Front Suspension) [With Front Suspension]
Cablagem Electrica (Direção A Utomática) [Como Direção Automática] / Electrical W Iring (Auto Steering) [Auto Steering Compatible]
Cablagem Electrica (Isobus) [ Antigo] / Electrical Wiring (Isobus) [Old]
Cablagem Electrica (Isobus) [ Novo] / Electrical Wiring (Isobus) [New]
Disco Do Amortecedor E Ligação À Caixa [Antigo] / Damper Disk And Housing Connection [Old]
Disco Do Amortecedor E Ligação À Caixa [Novo] / Damper Disk And Housing C Onnection [New]
Eixo Tranversal [Sem A Rrasto] / Transaxle [W/O Creep]
Carter Embraiagem [Com Ponente De Translaxe] / Clutch Housing [Transaxle C Omponent]
Caixa De Transmissão [ Componente De Translaxe] / Transmission Housing [Tr Ansaxle Component]
Estrutura Do Veio Tdf [Componente De Translaxe] / Pto Shaft Housing [Tran Saxle Component]
Braco Hidraulico [Comp Onente De Translaxe] / Lift Arm [Transaxle Componen T]
Veio Secundario [Compo Nente De Translaxe] / Counter Shaft [Transaxle Comp Onent]
Veio Primario [Compone Nte De Translaxe] / Main Shaft [Transaxle Component ]
Veio De Transmissão Da Tdf [Componente De Translaxe] / Pto Drive Shaft [T Ransaxle Component]
Embraiagem Dianteira [ Componente De Translaxe] / Front Clutch [Transaxle Component]
Deslocação De Potência [Componente De Translaxe] / Power Shift [Transaxle Component]
Embraiagem Hidráulica (Entrada) [Componente De Translaxe] / Hydraulic Clu Tch (Input) [Transaxle Component]
Embraiagem Hidráulica (Saída) [Componente De Translaxe] / Hydraulic Clutc H (Output) [Transaxle Component]
Veio De Entrada De Pot Ência [Componente De Translaxe] / Power Input Shaft [Transaxle Component]
Embraiagem Principal [ Componente De Translaxe] / Main Clutch [Transaxle C Omponent]
Transladador 1 [Compon Ente De Translaxe] / Shifter 1 [Transaxle Component ]
Estrutura Interior Do Veio Tdf (Embreagem) / Pto Shaft Housing Inner (Clu Tch)
Estrutura Interior Do Veio Tdf (Engrenagem) / Pto Shaft Housing Inner (Ge Ar)
Estrutura Interior Do Veio Tdf (Veio Tdf) / Pto Shaft Housing Inner (Pto Shaft)
Estrutura Interior Do Veio Tdf (Forquilha De Embraiagem) / Pto Shaft Hous Ing Inner (Shift Fork)
Válvula De Pressão / P Ressure Valve
Caixa De Mudança De Ve Locidade [Componente De Translaxe] / Gear Shift Hou Sing [Transaxle Component]
Pedal Embraiagem / Clu Tch Pedal
Alvanca Inversor / Shuttle Shift L Ever
Alavanca Tdf / Pto Gear Shift Leve R
Eixo Traseiro [Componente D E Translaxe] / Rear Axle [Transaxle Component]
Diferencial Traseiro [Compo Nente De Translaxe] / Rear Differential [Transaxle Component]
Travão [Componente De Trans Laxe] / Brake [Transaxle Component]
Eixo [Componente De Transla Xe] / Brake Shaft [Transaxle Component]
Alavanca Travao Mao / Parki Ng Brake Lever
Pedal Travao / Brake Pedal
Cilindro Principal Do Travã O [Antigo] / Brake Master Cylinder [Old]
Cilindro Principal Do Travã O [Novo] / Brake Master Cylinder [New]
Tubo Do Travão 1 (Superior/ Parte Dianteira) / Brake Pipe 1 (Upper/Front)
Tubo Do Travão 2 (Inferior/ Parte Traseira) [Com Compressor De Ar] / Brake Pipe 2 (Lower/Rear) [With Air Compresser]
Tubo Do Travão 2 (Inferior/ Parte Traseira) [Sem Compressor De Ar] / Brake Pipe 2 (Lower/Rear) [W/O Air Compresser]
Estrutura Do Eixo Diante Iro [Com Suspensão Frontal] / Front Axle Frame [Wit H Front Suspension]
Estrutura Do Carregador Dianteiro [Com Equipamento Do Carregador] / Front L Oader Frame [With Loader Equipment]
Para-Choques Peso Diante Iro [Antigo] / Front Weight Bumper [Old]
Para-Choques Peso Diante Iro [Novo] / Front Weight Bumper [New]
Balanceiro Da Suspensão Dianteira [Com Suspensão Dianteira] [Com 3p Diantei Ro] [Eixo Dianteiro: Tipo Padrão] / Front Suspensio N Rocker Arm [With Front Suspension] [With Front 3p ] [Front Axle:Standard Type]
Balanceiro Da Suspensão Dianteira [Com Suspensão Dianteira] [Com 3p Diantei Ro] [Eixo Dianteiro: Tipo Pesado] / Front Suspensio N Rocker Arm [With Front Suspension] [With Front 3p ] [Front Axle:Heavy Duty Type]
Balanceiro Da Suspensão Dianteira [Com Suspensão Dianteira] [Sem 3p Diantei Ro] [Eixo Dianteiro: Tipo Padrão] / Front Suspensio N Rocker Arm [With Front Suspension] [W/O Front 3p] [Front Axle:Standard Type]
Balanceiro Da Suspensão Dianteira [Com Suspensão Dianteira] [Sem 3p Diantei Ro] [Eixo Dianteiro: Tipo Pesado] / Front Suspensio N Rocker Arm [With Front Suspension] [W/O Front 3p] [Front Axle:Heavy Duty Type]
Proteção [Com Suspensão Frontal] / Front Guard [With Front Suspension]
Eixo Dianteiro [Com Susp Ensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / Fr Ont Axle [With Front Suspension] [Front Axle:Standa Rd Type]
Eixo Dianteiro [Com Susp Ensão Dianteira] [Eixo Dianteiro: Tipo Pesado] / Fr Ont Axle [With Front Suspension] [Front Axle:Heavy Duty Type]
Suporte Do Eixo Dianteir O [Componente Do Eixo Dianteiro] [Com Suspensão Dia Nteira] [Eixo Dianteiro: Tipo Padrão] / Front Axle Bracket [Front Axle Component] [With Front Suspensi On] [Front Axle:Standard Type]
Suporte Do Eixo Dianteir O [Componente Do Eixo Dianteiro] [Com Suspensão Dia Nteira] [Eixo Dianteiro: Tipo Pesado] / Front Axle Bracket [Front Axle Component] [With Front Suspensi On] [Front Axle:Heavy Duty Type]
Caixa Do Eixo Dianteiro [Componente Do Eixo Dianteiro] [Eixo Dianteiro: Tip O Padrão] / Front Axle Housing [Front Axle Componen T] [Front Axle:Standard Type]
Caixa Do Eixo Dianteiro [Componente Do Eixo Dianteiro] [Eixo Dianteiro: Tip O Pesado] / Front Axle Housing [Front Axle Componen T] [Front Axle:Heavy Duty Type]
Diferencial Dianteiro [C Omponente Do Eixo Dianteiro] [Eixo Dianteiro: Tipo Padrão] / Front Differential [Front Axle Component] [Front Axle:Standard Type]
Diferencial Dianteiro [C Omponente Do Eixo Dianteiro] [Eixo Dianteiro: Tipo Pesado] / Front Differential [Front Axle Component] [Front Axle:Heavy Duty Type]
Veio Do Carreto Diferenc Ial [Componente Do Eixo Dianteiro] [Eixo Dianteiro: Tipo Pesado] / Differential Gear Shaft [Front Axle Component] [Front Axle:Heavy Duty Type]
Sensor Do Ângulo De Vira Gem Da Roda [Componente Do Eixo Dianteiro] [Eixo Di Anteiro: Tipo Padrão] [Antigo] / Wheel Turning Angl E Sensor [Front Axle Component] [Front Axle:Standar D Type] [Old]
Sensor Do Ângulo De Vira Gem Da Roda [Componente Do Eixo Dianteiro] [Eixo Di Anteiro: Tipo Padrão] [Novo] / Wheel Turning Angle Sensor [Front Axle Component] [Front Axle:Standard Type] [New]
Sensor Do Ângulo De Vira Gem Da Roda [Componente Do Eixo Dianteiro] [Eixo Di Anteiro: Tipo Pesado] / Wheel Turning Angle Sensor [Front Axle Component] [Front Axle:Heavy Duty Type]
Ponteira Da Direção/Cili Ndro Da Direção [Componente Do Eixo Dianteiro] [Eix O Dianteiro: Tipo Padrão] / Tie Rod/Steering Cylind Er [Front Axle Component] [Front Axle:Standard Type ]
Veio Do Propulsor E Resg Uardo [Com Suspensão Dianteira] / Propeller Shaft A Nd Cover [With Front Suspension]
Direcção Assistida [Peças Componentes] / Steeri Ng Post [Component Parts]
Pedal Inclinacao / Tilt Pedal
Comando De Direção [Com Direção Automática] / S Teering Controller [Auto Steering Compatible]
Comando De Direção [Sem Direção Automática] / S Teering Controller [Auto Steering Incompatible]
Hidráulica Bomba De Moradia [ Componente De Translaxe] / Hydraulic Pump Housing [ Transaxle Component]
Bomba Hidraulico [Componente De Translaxe] / Hydraulic Pump [Transaxle Component ]
Linha De Óleo Hidráulico (Eix O Tranversal) [Componente De Translaxe] / Hydraulic Oil Line (Transaxle) [Transaxle Component]
Circuito Oleo Direcção (Radia Dor Oleo/Frente) / Hydraulic Oil Line (Oil Cooler/F Ront)
Circuito Oleo Direcção (Radia Dor Oleo/Traseira) / Hydraulic Oil Line (Oil Cooler /Rear)
Radiador Oleo [Com Tdf Diante Ira] / Oil Cooler [With Front Pto]
Circuito Oleo Direcção (Filtr O De Direcção) / Hydraulic Oil Line (Steering Filte R)
Filtro Oleo 2 [Peças Componen Tes] / Oil Filter 2 [Component Parts]
Circuito Oleo Direcção (Direc Ção Valvula) / Hydraulic Oil Line (Steering Valve)
Tubo Da Direção (Fornecimento ) [Eixo Dianteiro: Tipo Padrão] / Steering Hose (De Livery) [Front Axle:Standard Type]
Tubo Da Direção (Fornecimento ) [Eixo Dianteiro: Tipo Pesado] / Steering Hose (De Livery) [Front Axle:Heavy Duty Type]
Linha De Óleo Hidráulico (Tub O De Fornecimento Do Eixo Dianteiro/Traseiro) [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / Hydraulic Oil Line (Front Axle Delivery Pipe/Fron T) [With Front Suspension] [Front Axle:Standard Typ E]
Linha De Óleo Hidráulico (Tub O De Fornecimento Do Eixo Dianteiro/Traseiro) [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Pesado] / Hydraulic Oil Line (Front Axle Delivery Pipe/Fron T) [With Front Suspension] [Front Axle:Heavy Duty T Ype]
Linha De Óleo Hidráulico (Tub O De Fornecimento Do Eixo Dianteiro/Traseiro) [Sem Suspensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / Hydraulic Oil Line (Front Axle Delivery Pipe/Fron T) [W/O Front Suspension] [Front Axle:Standard Type ]
Linha De Óleo Hidráulico (Tub O De Fornecimento Do Eixo Dianteiro/Traseiro) / Hyd Raulic Oil Line (Front Axle Delivery Pipe/Rear)
Linha De Óleo Hidráulico (Fil Tro De Óleo) / Hydraulic Oil Line (Oil Filter)
Linha De Óleo Hidráulico (Fil Tro De Óleo A Válvula De Controlo Remoto/Abertura D E Drenagem Hidráulica) / Hydraulic Oil Line (Oil Fi Lter To Remote Control Valve/Hyd. Drain Port)
Linha De Óleo Hidráulico (Tub O Do Travão A Válvula De Controlo Remoto) [Com Susp Ensão Dianteira] / Hydraulic Oil Line (Brake Pipe T O Remote Control Valve) [With Front Suspension]
Bloco De Válvula 1 (Eixo Tran Versal) [Componente De Translaxe] / Valve Block 1 ( Transaxle) [Transaxle Component]
Bloco De Válvula 2 (Válvula S Olenóide) [Componente De Translaxe] / Valve Block 2 (Solenoid Valve) [Transaxle Component]
Axial Bomba [Com Equipamento Do Carregador] / Axial Pump [With Loader Equipment]
Axial Bomba [Sem Equipamento Do Carregador] / Axial Pump [W/O Loader Equipment]
Tubulação De Bomba Axial [Com Suspensão Dianteira] [Com Equipamento Do Carregado R] [Com Power Beyond] / Axial Pump Piping [With Fro Nt Suspension] [With Loader Equipment] [With Power Beyond]
Tubulação De Bomba Axial [Com Suspensão Dianteira] [Com Equipamento Do Carregado R] [Sem Power Beyond] / Axial Pump Piping [With Fro Nt Suspension] [With Loader Equipment] [W/O Power B Eyond]
Tubulação De Bomba Axial [Com Suspensão Dianteira] [Sem Equipamento Do Carregado R] [Com Power Beyond] / Axial Pump Piping [With Fro Nt Suspension] [W/O Loader Equipment] [With Power B Eyond]
Tubulação De Bomba Axial [Com Suspensão Dianteira] [Sem Equipamento Do Carregado R] [Sem Power Beyond] / Axial Pump Piping [With Fro Nt Suspension] [W/O Loader Equipment] [W/O Power Be Yond]
Linha De Óleo Hidráulico (Bom Ba Axial A Válvula De Controlo Remoto) [Com Suspens Ão Dianteira] [Com Equipamento Do Carregador] [Com Power Beyond] / Hydraulic Oil Line (Axial Pump To R Emote Control Valve) [With Front Suspension][With L Oader Equipment][With Power Beyond]
Linha De Óleo Hidráulico (Bom Ba Axial A Válvula De Controlo Remoto) [Com Suspens Ão Dianteira] [Com Equipamento Do Carregador] [Sem Power Beyond] / Hydraulic Oil Line (Axial Pump To R Emote Control Valve) [With Front Suspension][With L Oader Equipment][W/O Power Beyond]
Linha De Óleo Hidráulico (Bom Ba Axial A Válvula De Controlo Remoto) [Com Suspens Ão Dianteira] [Sem Equipamento Do Carregador] [Com Power Beyond] / Hydraulic Oil Line (Axial Pump To R Emote Control Valve) [With Front Suspension][With L Oader Equipment][With Power Beyond]
Linha De Óleo Hidráulico (Bom Ba Axial A Válvula De Controlo Remoto) [Com Suspens Ão Dianteira] [Sem Equipamento Do Carregador] [Sem Power Beyond] / Hydraulic Oil Line (Axial Pump To R Emote Control Valve) [With Front Suspension][W/O Lo Ader Equipment][W/O Power Beyond]
Tubo Da Válvula Da Suspensão Dianteira (Parte Traseira) [Com Suspensão Dianteira ] [Com Saída Hidráulica Dianteira] / Front Suspensi On Valve Pipe (Rear) [With Front Suspension] [With Front Hyd. Outlet]
Tubo Da Válvula Da Suspensão Dianteira (Parte Traseira) [Com Suspensão Dianteira ] [Sem Saída Hidráulica Dianteira] / Front Suspensi On Valve Pipe (Rear) [With Front Suspension] [W/O F Ront Hyd. Outlet]
Válvula Da Suspensão Dianteir A [Com Suspensão Dianteira] / Front Suspension Valv E [With Front Suspension]
Valvula Da Suspensão Frontal [Peças Componentes][Com Suspensão Dianteira] / Fron T Suspension Valve [Component Parts][With Front Sus Pension]
Suspensão Frontal Valvula Tub O (Frente) [Com Suspensão Dianteira] [Eixo Dianteir O: Tipo Padrão] [Com Saída Hidráulica Dianteira] / Front Suspension Valve Pipe (Front) [With Front Sus Pension] [Front Axle:Standard Type] [With Front Hyd . Outlet]
Suspensão Frontal Valvula Tub O (Frente) [Com Suspensão Dianteira] [Eixo Dianteir O: Tipo Padrão] [Sem Saída Hidráulica Dianteira] / Front Suspension Valve Pipe (Front) [With Front Sus Pension] [Front Axle:Standard Type] [W/O Front Hyd. Outlet]
Suspensão Frontal Valvula Tub O (Frente) [Com Suspensão Dianteira] [Eixo Dianteir O: Tipo Pesado] [Com Saída Hidráulica Dianteira] / Front Suspension Valve Pipe (Front) [With Front Sus Pension] [Front Axle:Heavy Duty Type] [With Front H Yd. Outlet]
Suspensão Frontal Acumulador [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Pad Rão] / Front Suspension Accumulator [With Front Sus Pension] [Front Axle:Standard Type]
Suspensão Frontal Acumulador [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Pes Ado] / Front Suspension Accumulator [With Front Sus Pension] [Front Axle:Heavy Duty Type]
Suspensão Frontal Cilindro Tu Bo [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / Front Suspension Cylinder Hose [With Fron T Suspension] [Front Axle:Standard Type]
Suspensão Frontal Cilindro Tu Bo [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Pesado] / Front Suspension Cylinder Hose [With Fron T Suspension] [Front Axle:Heavy Duty Type]
Válvula De Controlo Remoto (5 Válvulas) [Com Saída Hidráulica Dianteira] / Remot E Control Valve (5 Valves) [With Front Hyd. Outlet]
Válvula De Controlo Remoto (5 Válvulas) [Sem Saída Hidráulica Dianteira] / Remot E Control Valve (5 Valves) [W/O Front Hyd. Outlet]
Válvula De Controlo Remoto (5 Válvulas) [Sem 3p Dianteiro] / Remote Control Valv E (5 Valves) [W/O Front 3p]
Válvula De Controlo Remoto (6 Válvulas) [Com Saída Hidráulica Dianteira] / Remot E Control Valve (6 Valves) [With Front Hyd. Outlet]
Válvula De Controlo Remoto (5 Válvulas) [Peças Componentes] / Auxiliary Control Valve (5 Valves) [Component Parts]
Válvula De Controlo Remoto (6 Válvulas) [Peças Componentes] / Auxiliary Control Valve (6 Valves) [Component Parts]
Válvula De Controle Direciona L (5 Válvulas) [Peças Componentes] / Directional Co Ntrol Valve (5 Valves) [Component Parts]
Válvula De Controle Direciona L (6 Válvulas) [Peças Componentes] / Directional Co Ntrol Valve (6 Valves) [Component Parts]
Válvula Central [Peças Compon Entes] / Center Valve [Component Parts]
Válvula De Placa End [Peças C Omponentes] / End Plate Valve [Component Parts]
Coletor De Óleo (Válvula De C Ontrolo Remoto) [4p (6 Válvulas)] / Oil Collector(R Emote Control Valve) [4p(6 Valves)]
Coletor De Óleo (Válvula De C Ontrolo Remoto) [5p] / Oil Collector(Remote Control Valve) [5p]
Tubo Da Saída Hidráulica Dian Teira (Parte Traseira) [Com Saída Hidráulica Diante Ira] / Front Hydraulic Outlet Pipe (Rear) [With Fro Nt Hyd. Outlet]
Tubo Da Saída Hidráulica Dian Teira (Intermédia) [Com Saída Hidráulica Dianteira] / Front Hydraulic Outlet Pipe (Middle) [With Front Hyd. Outlet]
Tubo Da Saída Hidráulica Dian Teira (Parte Dianteira) [Com Saída Hidráulica Diant Eira] / Front Hydraulic Outlet Pipe (Front) [With F Ront Hyd. Outlet]
Tubo Da Saída Hidráulica (Tub O De Controlo Do Sensor De Carga) [Com Power Beyond ] / Hydraulic Outlet Pipe (Load-Sensing Control Hos E) [With Power Beyond]
Tubo Da Saída Hidráulica (Pow Er Beyond/Tubo De Retorno) [Com Power Beyond] / Hyd Raulic Outlet Pipe (Power Beyond/Return Hose) [With Power Beyond]
Valvula Travao Reboque / Trai Ler Brake Valve
Tubo Da Válvula Do Travão De Reboque / Trailer Brake Valve Pipe
Tubo De Óleo Do Carregador (P Arte Traseira) [Com Equipamento Do Carregador] / Fr Ont Loader Oil Pipe (Rear) [With Loader Equipment]
Tubo De Óleo Do Carregador (P Arte Dianteira) [Com Equipamento Do Carregador] / F Ront Loader Oil Pipe (Front) [With Loader Equipment ]
Compressor De Ar [Com Compressor De Ar] / Air Compressor [With Air Compressor]
Compressor De Ar [Peças Component Es][Com Compressor De Ar] / Air Compressor [Compone Nt Parts] [With Air Compressor]
Tubo Do Compressor De Ar [Com Com Pressor De Ar] / Air Compressor Pipe [With Air Comp Ressor]
Deposito De Ar [Tipo De Suspensão (Ar)] [Com Compressor De Ar] / Air Tank [Suspensio N Type (Air)] [With Air Compressor]
Deposito De Ar [Tipo De Suspensão (Mola)] [Com Compressor De Ar] / Air Tank [Suspens Ion Type (Spring)] [With Air Compressor]
Valvula De Ar [Com Compressor De Ar] / Air Valve [With Air Compressor]
Valvula De Ar [Peças Componentes] [Com Compressor De Ar] / Air Valve [Component Part S] [With Air Compressor]
Valvula De Ar (Reboque) [Com Comp Ressor De Ar] / Air Valve (Trailer) [With Air Compr Essor]
Valvula De Ar (Reboque) [Peças Co Mponentes] [Com Compressor De Ar] / Air Valve (Trai Ler) [Component Parts] [With Air Compressor]
Elo 3p D Ianteiro (Elo Estrutura/Superior) [Com Saída Hidráu Lica Dianteira] / Front 3p Link (Frame/Top Link) [W Ith Front Hyd. Outlet]
Elo 3p D Ianteiro (Elo Estrutura/Superior) [Sem Saída Hidráu Lica Dianteira] / Front 3p Link (Frame/Top Link) [W /O Front Hyd. Outlet]
Elo 3p D Ianteiro (Içador) [Com 3p Dianteiro] [Antigo] / Fro Nt 3p Link (Lifter) [With Front 3p] [Old]
Elo 3p D Ianteiro (Içador) [Com 3p Dianteiro] [Novo] / Front 3p Link (Lifter) [With Front 3p] [New]
Ligação 3p Dianteira (Cilindro) [Com 3p Dianteiro] [Antigo] / Front 3p Link (Cylinder) [With Front 3p] [Old]
Ligação 3p Dianteira (Cilindro) [Com 3p Dianteiro] [Novo] / Front 3p Link (Cylinder) [With Front 3p] [New]
Tdf Dian Teira [Com Tdf Dianteira] / Front Pto [With Front P To]
Caixa Da Engrenagem Tdf 1 (Carreto) [Peças Componentes] [Co M Tdf Dianteira] / Pto Gear Case 1 (Gear) [Componen T Parts] [With Front Pto]
Caixa Da Engrenagem Tdf 3 (Embraiagem) [Peças Componentes] [Com Tdf Dianteira] / Pto Gear Case 3 (Clutch) [Com Ponent Parts] [With Front Pto]
Caixa Da Engrenagem Tdf 4 (Caixa) [Peças Componentes] [Com Tdf Dianteira] / Pto Gear Case 4 (Case) [Component Parts] [With Front Pto]
Caixa Da Engrenagem Tdf 5 (Kit De Juntas E Vedantes) [Peças Componentes] [Com Tdf Dianteira] / Pto Gear Case 5 (Gasket And Seal Kit) [Component Parts] [With Fron T Pto]
Suporte Do Elo Superior/Suporte Do Acoplador / Top Link Bra Cket/Coupler Bracket
Ligação 3 Pontos (Ligação Superior:Manual) / 3-Point Linkag E (Top Link:Manual)
Ligação 3 Pontos (Ligação Superior:Hidráulica) / 3-Point Li Nkage (Top Link:Hydraulic)
Ligação 3 Pontos (Ligação Inferior) / 3-Point Linkage (Low Er Link)
Estabili Zador (Elevador) / Stabilizer(Lifter)
Estabili Zador (Elevador) [Peças Componentes] / Stabilizer ( Lifter) [Component Parts]
3-Pont A Coplamento (Tirante) / 3-Point Linkage (Lift Rod)
Puxo Bar Ra / Drawbar Bracket
Barra Re Boque(Padrão) / Drawbar(Standard)
Barra Re Boque(Fix Piton) / Drawbar(Fix Piton)
Puxo (Es Cada) / Hitch (Ladder)
Puxo (Dr Omone) / Hitch (Dromone)
Puxo (Dr Omone) [Peças Componentes] / Hitch (Dromone) [Compo Nent Parts]
Puxo (Dr Omone) Control Alavanca / Hitch (Dromone) Trailer L Ever
Gancho T Railer (Automatico) / Trailer Clevis (Automatic)
Gancho T Railer (Manual) / Trailer Clevis (Manual)
Capot Inferior (Direito) / Hood (Bonnet) Side L Ower Rh
Capot Inferior (Esquerdo) [Com Compressor De Ar ] / Hood (Bonnet) Side Lower Lh [With Air Compresso R]
Capot Inferior (Esquerdo) [Sem Compressor De Ar ] / Hood (Bonnet) Side Lower Lh [W/O Air Compressor ]
Placa Do Obturador (Silenciador/Isolador) / Shu Tter Plate (Sound Absorber/Insulator)
Guarda-Lamas Dianteiro (W:540) [Eixo Dianteiro: Tipo Padrão] [Antigo] / Front Fender (W:540) [Front Axle:Standard Type] [Old]
Guarda-Lamas Dianteiro (W:540) [Eixo Dianteiro: Tipo Padrão] [Novo] / Front Fender (W:540) [Front A Xle:Standard Type] [New]
Guarda-Lamas Dianteiro (W:540) [Eixo Dianteiro: Tipo Enhancement] / Front Fender (W:540) [Front Axl E:Heavy Duty Type]
Est Rutura Cabine / Cab Frame
Deg Rau Direito [Com Equipamento Do Carregador] / Step Rh [With Loader Equipment]
Deg Rau Direito [Sem Equipamento Do Carregador] [Com Su Spensão Dianteira] / Step Rh [W/O Loader Equipment] [With Front Suspension]
Deg Rau Esquerdo / Step Lh
Cob Ertura Frontal / Front Cover
Vid Ro Frente / Front Glass
Por Ta Drt / Door Rh
Por Ta Esq / Door Lh
Tri Nco Porta Drt / Door Lock Rh
Tri Nco Porta Esq / Door Lock Lh
Vid Ro Traseiro Da Escotilha / Hatch Back Glass
Tej Adilho / Sun Roof
Esp Elho Rectrovisor / Rearview Mirror
Tec To Interior / Inner Roof
Cob Ertura Exterior Do Tejadilho [Antiga] / Outer Roof [Old]
Cob Ertura Exterior Do Tejadilho [Nova] / Outer Roof [N Ew]
Sup Orte Do Assento / Seat Bracket
Ban Co / Seat
Ban Co 1 (Almofada) [Peças Componentes] / Seat1 (Seat C Ushion) [Component Parts]
Ban Co 2 (Apoio Braço/Costas Banco) [Peças Componentes] / Seat2 (Armrest/Backrest) [Component Parts]
Sus Pensão Do Assento [Peças Componentes] / Seat Suspen Sion [Component Parts]
Ban Co De Passageiro / Passenger Seat
Mat Erial À Prova De Som 1 (Painel) / Soundproof Materi Al 1 (Panel)
Mat Erial À Prova De Som 2 (Chão) / Soundproof Material 2 (Floor)
Mat Erial À Prova De Som 3 (Consola) / Soundproof Mater Ial 3 (Console)
Mat Erial À Prova De Som 4 (Tejadilho) [Antiga] / Sound Proof Material 4 (Roof) [Old]
Mat Erial À Prova De Som 4 (Tejadilho) [Nova] / Soundpr Oof Material 4 (Roof) [New]
Cob Ertura De Mudança (Consola Direita) / Shift Cover ( Console Rh)
Tam Pa Do Rádio E Tampa Do Painel De Controlo Do Ar Con Dicionado / Radio Cover And Air Conditioner Control Panel Cover
Con Sola Do Lado Esquerdo / Console Lh
Res Guardo Coluna / Pillar Cover
Cob Ertura Do Guarda-Lamas / Fender Cover
Gua Rda Lamas (Direito) / Fender Rh
Gua Rda Lamas (Esquerda) / Fender Lh
Gua Rda Lamas / Over Fender
Sup Orte Cabine Frente [Com Equipamento Do Carregador] / Cab Bracket Front [With Loader Equipment]
Sup Orte Cabine Frente [Sem Equipamento Do Carregador] / Cab Bracket Front [W/O Loader Equipment]
Sup Orte Cabine Traseira / Cab Bracket Rear
Amo Rtecedor Traseiro [Tipo De Suspensão (Ar)] [Com Com Pressor De Ar] / Rear Damper [Suspension Type (Air) ] [With Air Compressor]
Tra Seira Amortecedor [Tipo De Suspensão (Mola)] / Rear Damper [Suspension Type (Spring)]
Cai Xa De Ferramentas [Com Equipamento Do Carregador] / Tool Box [With Loader Equipment]
Cai Xa De Ferramentas [Sem Equipamento Do Carregador] / Tool Box [W/O Loader Equipment]
Ar Condicionado / Air Conditioner
Conduta Do Ar Condicionado (Ar Fr Io) / Air Conditioner Duct (Fresh Air)
Conduta Do Ar Condicionado (Trase Ira) / Air Conditioner Duct (Rear)
Modo Caixa / Mode Case
Entradas Ar Painel Instrumentos / Dashboard Air Outlets
Circulaçao Ar Interior / Inner Ai R Recirculation
Tubo Ar Condicionado/Tubo Condens Ador / Air Conditioner Hose/Condenser Hose
Polia De Acionamento Do Compresso R [Com Compressor De Ar] / Compressor Drive Pulley [With Air Compressor]
Polia De Acionamento Do Compresso R [Sem Compressor De Ar] / Compressor Drive Pulley [W/O Air Compressor]
Compressor (Ar Condicionado) / Co Mpressor (Air Conditioner)
Roda Dianteira (380/85r28:8 Buraco Ja Nte) [Michelin] / Front Wheel (380/85r28:8 Holes Ri M) [Michelin]
Roda Dianteira (380/85r28:8 Buraco Ja Nte) [Trelleborg] / Front Wheel (380/85r28:8 Holes Rim) [Trelleborg]
Roda Dianteira (380/85r28:8 Buraco Ja Nte) [Firestone] / Front Wheel (380/85r28:8 Holes R Im) [Firestone]
Roda Dianteira (380/85r28:8 Buraco Ja Nte) [Mitas] / Front Wheel (380/85r28:8 Holes Rim) [Mitas]
Roda Dianteira (420/70r28:8 Buraco Ja Nte) [Michelin] / Front Wheel (420/70r28:8 Holes Ri M) [Michelin]
Roda Dianteira (420/70r28:8 Buraco Ja Nte) [Trelleborg] / Front Wheel (420/70r28:8 Holes Rim) [Trelleborg]
Roda Dianteira (420/70r28:8 Buraco Ja Nte) [Firestone] / Front Wheel (420/70r28:8 Holes R Im) [Firestone]
Roda Dianteira (420/70r28:8 Buraco Ja Nte) [Mitas] / Front Wheel (420/70r28:8 Holes Rim) [Mitas]
Roda Dianteira (420/85r28:8 Buraco Ja Nte) [Michelin] / Front Wheel (420/85r28:8 Holes Ri M) [Michelin]
Roda Dianteira (420/85r28:8 Buraco Ja Nte) [Trelleborg] / Front Wheel (420/85r28:8 Holes Rim) [Trelleborg]
Roda Dianteira (420/85r28:8 Buraco Ja Nte) [Firestone] / Front Wheel (420/85r28:8 Holes R Im) [Firestone]
Roda Dianteira (420/85r28:8 Buraco Ja Nte) [Mitas] / Front Wheel (420/85r28:8 Holes Rim) [Mitas]
Roda Dianteira (480/70r28:8 Buraco Ja Nte) [Michelin] / Front Wheel (480/70r28:8 Holes Ri M) [Michelin]
Roda Dianteira (480/70r28:8 Buraco Ja Nte) [Trelleborg] / Front Wheel (480/70r28:8 Holes Rim) [Trelleborg]
Roda Dianteira (480/70r28:8 Buraco Ja Nte) [Mitas] / Front Wheel (480/70r28:8 Holes Rim) [Mitas]
Roda Dianteira (540/65r28:8 Buraco Ja Nte) [Michelin] / Front Wheel (540/65r28:8 Holes Ri M) [Michelin]
Roda Dianteira (540/65r28:8 Buraco Ja Nte) [Trelleborg] / Front Wheel (540/65r28:8 Holes Rim) [Trelleborg]
Roda Dianteira (540/65r28:8 Buraco Ja Nte) [Firestone] / Front Wheel (540/65r28:8 Holes R Im) [Firestone]
Roda Dianteira (540/65r28:8 Buraco Ja Nte) [Mitas] / Front Wheel (540/65r28:8 Holes Rim) [Mitas]
Roda Dianteira (380/85r28:10 Buraco J Ante) [Michelin] / Front Wheel (380/85r28:10 Holes Rim) [Michelin]
Roda Dianteira (380/85r28:10 Buraco J Ante) [Trelleborg] / Front Wheel (380/85r28:10 Hole S Rim) [Trelleborg]
Roda Dianteira (380/85r28:10 Buraco J Ante) [Firestone] / Front Wheel (380/85r28:10 Holes Rim) [Firestone]
Roda Dianteira (380/85r28:10 Buraco J Ante) [Mitas] / Front Wheel (380/85r28:10 Holes Rim ) [Mitas]
Roda Dianteira (420/70r28:10 Buraco J Ante) [Michelin] / Front Wheel (420/70r28:10 Holes Rim) [Michelin]
Roda Dianteira (420/70r28:10 Buraco J Ante) [Trelleborg] / Front Wheel (420/70r28:10 Hole S Rim) [Trelleborg]
Roda Dianteira (420/70r28:10 Buraco J Ante) [Firestone] / Front Wheel (420/70r28:10 Holes Rim) [Firestone]
Roda Dianteira (420/70r28:10 Buraco J Ante) [Mitas] / Front Wheel (420/70r28:10 Holes Rim ) [Mitas]
Roda Dianteira (420/85r28:10 Buraco J Ante) [Michelin] / Front Wheel (420/85r28:10 Holes Rim) [Michelin]
Roda Dianteira (420/85r28:10 Buraco J Ante) [Trelleborg] / Front Wheel (420/85r28:10 Hole S Rim) [Trelleborg]
Roda Dianteira (420/85r28:10 Buraco J Ante) [Firestone] / Front Wheel (420/85r28:10 Holes Rim) [Firestone]
Roda Dianteira (420/85r28:10 Buraco J Ante) [Mitas] / Front Wheel (420/85r28:10 Holes Rim ) [Mitas]
Roda Dianteira (480/70r28:10 Buraco J Ante) [Trelleborg] / Front Wheel (480/70r28:10 Hole S Rim) [Trelleborg]
Roda Dianteira (480/70r28:10 Buraco J Ante) [Firestone] / Front Wheel (480/70r28:10 Holes Rim) [Firestone]
Roda Dianteira (480/70r28:10 Buraco J Ante) [Mitas] / Front Wheel (480/70r28:10 Holes Rim ) [Mitas]
Roda Dianteira (540/65r28:10 Buraco J Ante) [Michelin] / Front Wheel (540/65r28:10 Holes Rim) [Michelin]
Roda Dianteira (540/65r28:10 Buraco J Ante) [Trelleborg] / Front Wheel (540/65r28:10 Hole S Rim) [Trelleborg]
Roda Dianteira (540/65r28:10 Buraco J Ante) [Firestone] / Front Wheel (540/65r28:10 Holes Rim) [Firestone]
Roda Dianteira (540/65r28:10 Buraco J Ante) [Mitas] / Front Wheel (540/65r28:10 Holes Rim ) [Mitas]
Roda Traseira (460/85r38) [Michelin] / Rear Wheel (460/85r38) [Michelin]
Roda Traseira (460/85r38) [Trelleborg ] / Rear Wheel (460/85r38) [Trelleborg]
Roda Traseira (460/85r38) [Firestone] / Rear Wheel (460/85r38) [Firestone]
Roda Traseira (460/85r38) [Mitas] / R Ear Wheel (460/85r38) [Mitas]
Roda Traseira (520/70r38) [Michelin] / Rear Wheel (520/70r38) [Michelin]
Roda Traseira (520/70r38) [Firestone] / Rear Wheel (520/70r38) [Firestone]
Roda Traseira (520/70r38) [Mitas] / R Ear Wheel (520/70r38) [Mitas]
Roda Traseira (520/85r38) [Michelin] / Rear Wheel (520/85r38) [Michelin]
Roda Traseira (520/85r38) [Trelleborg ] / Rear Wheel (520/85r38) [Trelleborg]
Roda Traseira (520/85r38) [Firestone] / Rear Wheel (520/85r38) [Firestone]
Roda Traseira (580/70r38) [Michelin] / Rear Wheel (580/70r38) [Michelin]
Roda Traseira (580/70r38) [Trelleborg ] / Rear Wheel (580/70r38) [Trelleborg]
Roda Traseira (580/70r38) [Firestone] / Rear Wheel (580/70r38) [Firestone]
Roda Traseira (580/70r38) [Mitas] / R Ear Wheel (580/70r38) [Mitas]
Roda Traseira (650/65r38) [Michelin] / Rear Wheel (650/65r38) [Michelin]
Roda Traseira (650/65r38) [Trelleborg ] / Rear Wheel (650/65r38) [Trelleborg]
Roda Traseira (650/65r38) [Firestone] / Rear Wheel (650/65r38) [Firestone]
Roda Traseira (650/65r38) [Mitas] / R Ear Wheel (650/65r38) [Mitas]
Decalcomania(Painel/Cobertura De Mudança) / Labe L (Panel/Shift Cover)
Etiqueta (Unidade Control Electrico/Controlador) / Label (Ecu/Controller)
Decalcomania (Cabine Interior) / Label (Cab Inte Rior)
Acessorios / Accessories
L Uzes Frente (Farol De Repetição) [Opçao] / Head Lig Ht Kit (Repeat Head Light) [Option]
K It Da Tdf Dianteira (6 Estrias) (Caixa Da Engrenage M) [Opção] / Front Pto Kit (6 Splines) (Gear Case) [Option]
K It Da Tdf Dianteira (6 Estrias) (Arrefecedor Do Óle O) [Opção] / Front Pto Kit (6 Splines) (Oil Cooler) [Option]
K It Do Terminal (12 Polegadas) [Sem Direção Automáti Ca] [Opção] / Terminal Kit (12 Inch) [Auto Steering Incompatible] [Option]
K It Do Sensor (Radar) [Opção] / Sensor Kit (Radar) [ Option]
K It Da Câmara [Opção] / Camera Kit [Option]
K It De Antena (Modem Rtk De Direção Automática) (Ant Ena) [Opçao] / Anntena Kit (Auto Steer Rtk Modem) ( Anntena) [Option]
K It De Antena (Modem Rtk De Direção Automática) (Con Trolador) [Opçao] / Anntena Kit (Auto Steer Rtk Mod Em) (Controller) [Option]
K It De Antena (Direção Automática Dgps/Sem Rtk) [Opç Ao] / Anntena Kit (Auto Steer Dgps/Without Rtk) [Op Tion]
K It De 21 Estrias De Tdf [Opção] / Pto Kit (21 Splin Es) [Option]
A Uxiliar Do Válvula De Controlo Kit (Elétrica 5ª) [O Pção] / Auxiliary Control Valve Kit (Elec.5th) [Opt Ion]
K It De Acoplador (Saída Hidráulica Dianteira/Elétric A 6ª) (Tubo) [Opção] / Coupler Kit (Front Hyd. Outl Et/Elec.6th) (Pipe) [Option]
K It De Acoplador (Saída Hidráulica Dianteira/Elétric A 6ª) (Acoplador/Tubo) [Opção] / Coupler Kit (Front Hyd. Outlet/Elec.6th) (Coupler/Pipe) [Option]
K It De Acoplador Powr Beyond (Acoplador) [Opção] / P Ower Beyond Coupler Kit (Coupler) [Option]
K It De Acoplador Powr Beyond (Tubo/Acoplador) [Opção ] / Power Beyond Coupler Kit (Pipe/Coupler) [Option ]
K It Do Reboque (Pistão) [Opção] / Trailer Kit (Piton ) [Option]
K It Do Reboque (K80) [Opção] / Trailer Kit (K80) [Op Tion]
K It Da Ligação 3-P Dianteira (Elétrica 6ª) (Válvula) [Opção] / Front 3p Link Kit (Elec.6th) (Valve) [Op Tion]
K It De Ligação 3-P Dianteira (Mecânica 4ª) (Válvula) [Opção] / Front 3p Link Kit (Mech.4th) (Valve) [Op Tion]
K It De Suporte Da Escora [Opção] / Drawbar Bracket K It [Option]
K It De Escora (Acoplamento K80) [Opção] / Drawbar Ki T (Coupling K80) [Option]
K It Do Guarda-Lamas Dianteiro (W:410) [Eixo Dianteir O:Tipo Padrão] [Antigo] / Front Fender Kit (W:410) [Front Axle:Standard Type] [Old]
K It Do Guarda-Lamas Dianteiro (W:410) [Eixo Dianteir O:Tipo Padrão] [Novo] / Front Fender Kit (W:410) [F Ront Axle:Standard Type] [New]
K It De Espelho (Calor) [Opção] / Mirror Kit (Heat) [ Option]
Painel / Panel
Escova / Wiper
Ban Co / Seat
