Kubota Tractor M7153P M7153KVT Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M7153P ; M7153KVT Tractor
Number of Pages: 600 Pages
Itens Usado S Frequentemente / Frequently Used Items
Itens Usado S Frequentemente (Componenetes Electricos) [Luzes F Rente [Com Led]] [Luzes Trabalho [Com Led]] / Frequ Ently Used Items (Electrical Parts) [Head Light [Wi Th Led]] [Work Light [With Led]]
Itens Usado S Frequentemente (Componenetes Electricos) [Luzes F Rente [Com Halogénio]] [Luzes Trabalho [Com Halogén Io]] / Frequently Used Items (Electrical Parts) [He Ad Light [With Harogen]] [Work Light [With Harogen] ]
Bloco Motor(Superior) / Crankcase (Upper)
Bloco Motor(Inferior) / Crankcase (Lower)
Cárter Do Óleo [Com Compressor De Ar] / Oil Pan [With Air Compressor]
Cárter Do Óleo [Sem Compressor De Ar] / Oil Pan [W/O Air Compressor]
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exha Ust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Bomba De Abastecimento / Supply Pump
Injector E Vela Aquecimento / Injector And Glow Plug
Common Rail / Common Rail
Bomba Agua / Water Pump
Radiador Oleo / Oil Cooler
Separador De Óleo [Peças Componentes] / Oil Sepa Rator [Component Parts]
Tubo Do Separador De Óleo / Oil Separator Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo C Harger)
Filtro Ar [Com Tdf Dianteira] / Air Cleaner [Wit H Front Pto]
Filtro Ar [Sem Tdf Dianteira] / Air Cleaner [W/O Front Pto]
Filtro Ar [Peças Componentes] / Air Cleaner [Com Ponent Parts]
Tubo De Entrada (Filtro De Ar) [Com Compressor D E Ar] / Inlet Pipe (Air Cleaner) [With Air Compress Er]
Tubo De Entrada (Filtro De Ar) [Sem Compressor D E Ar] / Inlet Pipe (Air Cleaner) [W/O Air Compresse R]
Flange Filtro Ar E Valvula Acelarador / Air Clea Ner Flange And Throttle Valve
Valvula Egr / Egr Valve
Tubos De Água Egr / Egr Water Piping
Silenciador Do Filtro De Partículas Diesel / Die Sel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peça S Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Flange Silenciosa / Muffler Flange
Suporte (Dpf) 1 / Muffler Bracket (Dpf) 1
Suporte (Dpf) 2 / Muffler Bracket (Dpf) 2
Tubo Pressao / Pressure Pipe
Panela Escape / Muffler Pipe
Silenciador Da Redução Catalítica Seletiva / Sel Ective Catalytic Reduction Muffler
Suporte De Silenciador De Redução Catalítica Sel Etiva / Selective Catalytic Reduction Muffler Brack Et
Resguardo Da Redução Catalítica Seletiva / Selec Tive Catalytic Reduction Cover
Tubulação E Proteção Do Silênciador / Muffler Pi Pe And Cover
Bomba Do Fluido De Escape De Diesel / Diesel Exh Aust Fluid Pump
Depósito Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Tank
Depósito Do Fluido De Escape De Diesel [Peças Co Mponentes] / Diesel Exhaust Fluid Tank [Component Parts]
Depósito Do Fluido De Escape De Diesel Tubo / Di Esel Exhaust Fluid Hose
Depósito Do Fluido De Escape De Diesel Aquecedor Tubo / Diesel Exhaust Fluid Heater Hose
Depósito Do Fluido De Escape De Diesel Mangueira De Respiro / Diesel Exhaust Fluid Breather Hose
Sistema De Arrefecimento Egr (Sistema De Redução Catalítica Seletiva) / Egr Cooler (Selective Catal Ytic Reduction System)
Tubos De Água Egr (Sistema De Redução Catalítica Seletiva) / Egr Water Piping (Selective Catalytic Reduction System)
Cobertura De Escape De Exaustão/Tampa De Recircu Lação De Gás De Escape / Exhaust Manifold Cover/Egr Cover
Componentes Electricos Motor (Sensor/Ecu) / Engi Ne Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape) / E Ngine Electrical Parts (Muffler)
Motor Elétrica Peças De Montagem / Engine Electr Ical Mounting Parts
Deposito Combustivel / Fue L Tank
Suporte Deposito Combustiv El [Com Equipamento Do Carregador] / Fuel Tank Brac Ket [With Loader Equipment]
Suporte Deposito Combustiv El [Sem Equipamento Do Carregador] / Fuel Tank Brac Ket [W/O Loader Equipment]
Tubo Do Combustível (Enchi Mento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Arrefece Dor Gasoleo) / Fuel Pipe (Fuel Cooler)
Arrefecedor Gasoleo / Fuel Cooler
Separador / Separator
Separador [Peças Component Es] / Separator [Component Parts]
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Compo Nentes] / Fuel Pump [Component Parts]
Filtro Gasoleo / Fuel Filt Er
Filtro Gasoleo [Peças Comp Onentes] / Fuel Filter [Component Parts]
Suporte Ventilador / Fan Bracket
Polia De Acionamento Da Ventoinha / Fan Drive Pulley
Ventoinh A / Fan
Tubo De Água E Tubo Do Sistema De Arrefecimento / Water Pip E And Cooler Pipe
Unidade Do Sistema De Arrefecimento / Cooler Unit
Refriger Ador Intermediário / Inter Cooler
Condesad Or / Condenser
Tubo Do Depósito De Reserva [Com Compressor De Ar] / Reserv E Tank Hose [With Air Compressor]
Tubo Do Depósito De Reserva [Sem Compressor De Ar] / Reserv E Tank Hose [W/O Air Compressor]
Alternador (200a) / Alter Nator (200a)
Alternador (150a) / Alter Nator (150a)
Alternador (200a) [Peças Componentes] / Alternator (200a) [Component Parts]
Alternador (150a) [Peças Componentes] / Alternator (150a) [Component Parts]
Motor Arranque / Starter
Suporte De Bateria / Batt Ery Bracket
Interruptor/Sensor (Bloco Motor Direita) / Switch/Sensor (Engine Rh)
Sensor Da Redução Catalít Ica Seletiva / Selective Catalytic Reduction Sensor
Componenetes Electricos Re Sguardo / Electrical Parts Cover
Suspensão Frontal Sensor / Front Suspension Sensor
Sensor (Pedal/Alavanca Tr Avao Mao) / Sensor (Pedal/Parking Brake Lever)
Interruptor/Sensor / Swit Ch/Sensor
Interruptor/Sensor [Com C Ompressor De Ar] / Switch/Sensor [With Air Compress Or]
Interruptor/Sensor [Sem C Ompressor De Ar] / Switch/Sensor [W/O Air Compresso R]
Sensor (Caixa De Transmis São) / Sensor (Transmission Housing Rh)
Sensor (Caixa De Transmis São) / Sensor (Transmission Housing Lh)
Sensor Da Conicidade/Sens Or 3p [Com Puxo (Escada)] / Draft Sensor/3p Sensor [With Hitch (Ladder)]
Sensor Da Conicidade/Sens Or 3p [Com Puxo (Dromone)] / Draft Sensor/3p Sensor [With Hitch (Dromone)]
Interruptor (Ligação 3p D Ianteira) [Com 3p Dianteiro] / Switch (Front 3p Lin K) [With Front 3p]
Interruptor (Painel) / Sw Itch (Panel Board)
Interruptor (Direcção) [C Om Direção Automática] / Switch (Steering) [Auto St Eering Compatible]
Interruptor (Direcção) [S Em Direção Automática] / Switch (Steering) [Auto St Eering Incompatible]
Interruptor (Cobertura De Mudança) [Com Direçao Rápida] / Switch (Shift Cove R) [With Fast Steering]
Interruptor (Cobertura De Mudança) [Sem Direçao Rápida] / Switch (Shift Cove R) [W/O Fast Steering]
Interruptor (Consola Do L Ado Esquerdo) [Com Aquecedor De Espelho Retrovisor] / Switch (Console Lh) [With Mirror Heater]
Interruptor Externo / Ext Ernal Switch
Relé/Controlador / Relay/ Controller
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico /Controlador [Com Compressor De Ar] / Electronic Co Ntrol Unit/Controller [With Air Compressor]
Unidade Control Electrico /Controlador [Sem Compressor De Ar] / Electronic Co Ntrol Unit/Controller [W/O Air Compressor]
Ecu Peças De Montagem / E Cu Mounting Part
Controlador (Ceu) / Contr Oller (Ceu)
Controlador (Ceu) [Peças Componentes] / Controller (Ceu) [Component Parts]
Painel / Panel
Peças Elétricas Da Trasei Ra Interior Da Cabine (Saída Elétrica/Painel De Con Trolo Do Ar Condicionado) [Com Ar Condicionado - Au Tomático] / Cab Inner Rear Electrical Parts (Electr Ical Outlet/Air Conditioner Control Panel) [With Au To Air Conditioner]
Peças Elétricas Da Trasei Ra Interior Da Cabine (Saída Elétrica/Painel De Con Trolo Do Ar Condicionado) [Com Ar Condicionado - Ma Nual] / Cab Inner Rear Electrical Parts (Electrical Outlet/Air Conditioner Control Panel) [With Manual Air Conditioner]
Terminal Isobus / Isobus Terminal
Apoio De Braço [Com Contr Ole De Video Game] / Armrest [With Joystick]
Apoio De Braço [Sem Contr Ole De Video Game] / Armrest [W/O Joystick]
Terminal (12 Polegadas) / Terminal (12 Inch)
Terminal (7 Polegadas) / Terminal (7 Inch)
Luzes Frente [Com Lampada De Led] / Head Light [With Led Light]
Luzes Frente [Com Lampada De Halogénio] / Head Light [With Halogen Light]
Luzes Frente De Repetição (Coluna) [Com Luzes Frente De Repetição] / Repeat Head Light (Pillar) [With Repeat Head Light]
Lâmpada Farol / Beacon La Mp
Lámpada De Pisca Pisca [S Em Luz De Trabalho(Coluna)] / Lamp Of Side Marker [ W/O Work Light(Pillar)]
Lámpada De Pisca Pisca [C Om Luz De Trabalho(Coluna)] / Lamp Of Side Marker [ With Work Light(Pillar)]
Luz De Trabalho (Dianteir O/Teto) [Com Lampada De Led] / Work Light (Front/Ro Of) [With Led Light]
Luz De Trabalho (Dianteir O/Teto) [Com Lampada De Halogénio] / Work Light (Fr Ont/Roof) [With Halogen Light]
Luz De Trabalho (Dianteir O/Coluna) [Com Luz De Trabalho(Coluna)] / Work Ligh T (Front/Pillar) [With Work Light(Pillar)]
Luz De Trabalho (Traseiro /Coluna) [Com Luz De Trabalho(Coluna)] / Work Light (Rear/Pillar) [With Work Light(Pillar)]
Braco Traseiro / Rear Com Bination Lamp
Ficha Reboque [Travão De Trailer De 1+2 Linha] / Trailer Socket [1+2-Line Tr Aler Brake]
Ficha Reboque [Travão De Trailer De 1 Linha] / Trailer Socket [1-Line Traler Brake]
Luz Interior / Room Light
Alta Voz Radio / Radio Sp Eaker
Depósito De Lavagem / Was Her Tank
Escova / Wiper
Cablagem Elétrica (Motor) (Filtro De Ar/Dpf) / Electrical Wiring (Engine) (A Ir Cleaner/Dpf)
Cablagem Elétrica (Motor) (Crs) / Electrical Wiring (Engine) (Crs)
Cablagem Elétrica (Motor) (Combustível/Scr) / Electrical Wiring (Engine) (Fu El/Scr)
Cablagem Elétrica (Motor) (Fusível/Bateria) / Electrical Wiring (Engine) (Fu Se/Battery)
Cablagem Elétrica (Motor) (Compressor/Volante) [Com Compressor De Ar] / Elec Trical Wiring (Engine) (Compressor/Flywheel) [With Air Compressor]
Cablagem Elétrica (Motor) (Compressor/Volante) [Sem Compressor De Ar] / Elec Trical Wiring (Engine) (Compressor/Flywheel) [W/O A Ir Compressor]
Cablagem Elétrica (Capot) [Com Lampada De Led] / Electrical Wiring (Bonnet(H Ood)) [With Led Light]
Cablagem Elétrica (Capot) [Com Lampada De Halogénio] / Electrical Wiring (Bo Nnet(Hood)) [With Halogen Light]
Cablagem Elétrica (Altern Ador) [Com Alternador (200 A)] / Electrical Wiring (Alternator 200a)
Cablagem Elétrica (Altern Ador) [Com Alternador (150 A)] / Electrical Wiring (Alternator 150a)
Cablagem Eletrica (Motor Arranque) / Electrical Wiring (Starter)
Cablagem Electrica (Fonte De Alimentação/Controlador (Ceu)) / Electrical Wir Ing (Power Supply/Controller (Ceu))
Cablagem Electrica (Eixo Tranversal/Frente) [Com Compressor De Ar] / Electri Cal Wiring (Transaxle/Front) [With Air Compresser]
Cablagem Electrica (Eixo Tranversal/Frente) [Sem Compressor De Ar] / Electri Cal Wiring (Transaxle/Front) [W/O Air Compresser]
Cablagem Electrica (Eixo Tranversal/Traseira) / Electrical Wiring (Transaxle /Rear)
Cablagem Electrica (Distr Ibuidor Auxiliar) / Electrical Wiring (Remote Contr Ol Valve)
Cablagem Electrica(Etcv V Alvula/Secagem) [Com Compressor De Ar] / Electrical Wiring (Etcv Valve/Air Dryer) [With Air Compressor ]
Cablagem Elétrica (Cabine ) (Direção/Painel) / Electrical Wiring (Cab) (Steer Ing/Panel)
Cablagem Elétrica (Cabine ) (Ecu) / Electrical Wiring (Cab) (Ecu)
Cablagem Elétrica (Cabine ) (Cobertura Das Mudanças/Apoio De Braço) [Com Dire Çao Rápida] / Electrical Wiring (Cab) (Shift Cover/ Armrest) [With Fast Steering]
Cablagem Elétrica (Cabine ) (Cobertura Das Mudanças/Apoio De Braço) [Sem Dire Çao Rápida] / Electrical Wiring (Cab) (Shift Cover/ Armrest) [W/O Fast Steering]
Cablagem Elétrica (Cabine ) (Ar Condicionado) [Com Ar Condicionado - Automáti Co] [Modelo 50km/H] / Electrical Wiring (Cab) (Air Conditioner) [With Auto Air Conditioner] [50 Km/H M Odel]
Cablagem Elétrica (Cabine ) (Ar Condicionado) [Com Ar Condicionado - Manual] [Modelo 50km/H] / Electrical Wiring (Cab) (Air Cond Itioner) [With Manual Air Conditioner] [50 Km/H Mod El]
Cablagem Electrica (Supor Te Da Grelha Dianteira) [Sem Luz De Trabalho(Diante Iro/Coluna)] / Electrical Wiring (Front Pillar) [W/ O Work Light (Front/Pillar)]
Cablagem Electrica (Supor Te Da Grelha Dianteira) [Com Luz De Trabalho(Diante Iro/Coluna)] / Electrical Wiring (Front Pillar) [Wi Th Work Light (Front/Pillar)]
Cablagem Electrica (Teto) [Com Aquecedor De Espelho Retrovisor] / Electrical Wiring (Roof) [With Mirror Heater]
Cablagem Electrica (Teto) [Sem Aquecedor De Espelho Retrovisor] / Electrical Wiring (Roof) [W/O Mirror Heater]
Cablagem Electrica (Pisca /Pára-Lama) / Electrical Wiring (Flasher/Mudguard)
Cablagem Electrica [Com 3 P Dianteiro] / Electrical Wiring [With Front 3p]
Cablagem Electrica (Suspe Nsão Dianteira) / Electrical Wiring (Front Suspensi On)
Cablagem Electrica (Com D Ireção Automática) [Com Direção Automática] / Elect Rical Wiring (Auto Steering) [Auto Steering Compati Ble]
Cablagem Electrica (Isobu S) / Electrical Wiring (Isobus)
Caixa Da Transmiss Ão / Transmission Case
Caixa De Transmiss Ão / Transmission Housing
Caixa De Plugue / Housing Plug
Estrutura Do Veio Tdf / Pto Shaft Housing
Braco Hidraulico / Lift Arm
Estrutura Interior Do Veio Tdf (Embreagem) / Pto Shaft Housing Inner (Clutch)
Estrutura Interior Do Veio Tdf (Engrenagem) / Pto Shaft Housing Inner (Gear)
Estrutura Interior Do Veio Tdf (Veio Tdf) / Pto Shaft Housing Inner ( Pto Shaft)
Estrutura Interior Do Veio Tdf (Forquilha De Embraiagem) / Pto Shaft Housing Inner (Shift Fork)
Unidade Hidráulica / Hydraulic Unit
Hidráulica Bomba D E Moradia / Hydraulic Pump Housing
Condutas Hidráulic As / Hydraulic Piping
Unidade De Control O Hidráulico/Filtro / Hydraulic Control Unit/Filter
Válvula Solenóide/ Regulador De Pressão / Solenoid Valve/Pressure Regu Later
Alvanca Inversor / Shuttle Shi Ft Lever
Eixo Traseiro / Rear Ax Le
Diferencial Traseiro / Rear Differential
Travão / Brake
Eixo Traseiro / Brake S Haft
Alavanca Travao Mao / P Arking Brake Lever
Pedal Travao / Brake Pe Dal
Tubo Do Travão (Superio R/Parte Dianteira) [Travão De Trailer De 1 Linha] / Brake Pipe (Upper/Front) [1-Line Traler Brake]
Tubo Do Travão (Inferio R/Parte Traseira) [Travão De Trailer De 1+2 Linha] / Brake Pipe (Lower/Rear) [1+2-Line Traler Brake]
Tubo Do Travão (Inferio R/Parte Traseira) [Travão De Trailer De 1 Linha] / Brake Pipe (Lower/Rear) [1-Line Traler Brake]
Quadro Eixo Frente [ Com Tdf Dianteira] / Front Axle Frame [With Front P To]
Quadro Eixo Frente [ Sem Tdf Dianteira] / Front Axle Frame [W/O Front Pt O]
Estrutura Do Carrega Dor Dianteiro [Com Equipamento Do Carregador] / Fro Nt Loader Frame [With Loader Equipment]
Para-Choques Peso Di Anteiro [Sem 3p Dianteiro] / Front Weight Bumper [W /O Front 3p]
Balanceiro Da Suspen São Dianteira [Com 3p Dianteiro] / Front Suspension Rocker Arm [With Front 3p]
Balanceiro Da Suspen São Dianteira [Sem 3p Dianteiro] / Front Suspension Rocker Arm [W/O Front 3p]
Cilindro Da Suspensã O Frontal [Peças Componentes] / Front Suspension Cy Linder [Component Parts]
Distribuidor Auxilia R [Sem 3p Dianteiro] / Front Guard [W/O Front 3p]
Eixo Dianteiro / Fro Nt Axle
Suporte Eixo Frente [Eixo Dianteiro Peças Componentes] / Front Axle Bra Cket [Front Axle Component]
Carter Eixo Frente [ Eixo Dianteiro Peças Componentes] / Front Axle Hous Ing [Front Axle Component]
Diferencial Dianteir O [Eixo Dianteiro Peças Componentes] / Front Differ Ential [Front Axle Component]
Veio Carreto Diferen Cial [Eixo Dianteiro Peças Componentes] / Different Ial Gear Shaft [Front Axle Component]
Sensor De Ângulo De Viragem Roda [Eixo Dianteiro Peças Componentes] / W Heel Turning Angle Sensor [Front Axle Component]
Tirante/Cilindro Dir Ecção [Eixo Dianteiro Peças Componentes] / Tie Rod/ Steering Cylinder [Front Axle Component]
Veio Do Propulsor E Resguardo / Propeller Shaft And Cover
Direcção Assistida [Peças Componentes] / St Eering Post [Component Parts]
Pedal Inclinacao / Tilt Pedal
Comando De Direção [Com Direção Automática] / Steering Controller [Auto Steering Compatible]
Comando De Direção [Sem Direção Automática] / Steering Controller [Auto Steering Incompatible]
Circuito Oleo Direcção (R Adiador Oleo/Frente) / Hydraulic Oil Line (Oil Cool Er/Front)
Circuito Oleo Direcção (R Adiador Oleo/Traseira) / Hydraulic Oil Line (Oil Co Oler/Rear)
Radiador Oleo [Com Tdf Di Anteira] / Oil Cooler [With Front Pto]
Circuito Oleo Direcção (D Irecção Valvula/Filtro) [Com Compressor De Ar] / Hy Draulic Oil Line (Steering Valve/Filter) [With Air Compresser]
Circuito Oleo Direcção (D Irecção Valvula/Filtro) [Sem Compressor De Ar] / Hy Draulic Oil Line (Steering Valve/Filter) [W/O Air C Ompresser]
Filtro Oleo [Peças Compon Entes] / Oil Filter [Component Parts]
Circuito Oleo Direcção (D Irecção Valvula) / Hydraulic Oil Line (Steering Val Ve)
Tubo Direccao (Fornecimen To) / Steering Hose (Delivery)
Linha De Óleo Hidráulico (Tubo De Fornecimento Do Eixo Dianteiro/Traseiro) / Hydraulic Oil Line (Front Axle Delivery Pipe/Front )
Linha De Óleo Hidráulico (Tubo De Fornecimento Do Eixo Dianteiro/Traseiro) / Hydraulic Oil Line (Front Axle Delivery Pipe/Rear)
Linha De Óleo Hidráulico (Filtro De Óleo) [Com Equipamento Do Carregador] / Hydraulic Oil Line (Oil Filter) [With Loader Equipm Ent]
Linha De Óleo Hidráulico (Filtro De Óleo A Válvula De Controlo Remoto/Abertu Ra De Drenagem Hidráulica) [Travão De Trailer De 1+ 2 Linha] [Com Equipamento Do Carregador] / Hydrauli C Oil Line (Oil Filter To Remote Control Valve/Hyd. Drain Port) [1+2-Line Trailer Brake] [With Loader Equipment]
Linha De Óleo Hidráulico (Filtro De Óleo A Válvula De Controlo Remoto/Abertu Ra De Drenagem Hidráulica) [Travão De Trailer De 1 Linha] [Com Equipamento Do Carregador] / Hydraulic Oil Line (Oil Filter To Remote Control Valve/Hyd. D Rain Port) [1-Line Trailer Brake] [With Loader Equi Pment]
Linha De Óleo Hidráulico (Filtro De Óleo A Válvula De Controlo Remoto/Abertu Ra De Drenagem Hidráulica) [Travão De Trailer De 1 Linha] [Sem Equipamento Do Carregador] / Hydraulic Oil Line (Oil Filter To Remote Control Valve/Hyd. D Rain Port) [1-Line Trailer Brake] [W/O Loader Equip Ment]
Linha De Óleo Hidráulico (Tubo Do Travão A Válvula De Controlo Remoto) [Com Power Beyond] / Hydraulic Oil Line (Brake Pipe To Remote Control Valve)[With Power Beyond]
Linha De Óleo Hidráulico (Tubo Do Travão A Válvula De Controlo Remoto) [Sem Power Beyond] / Hydraulic Oil Line (Brake Pipe To Remote Control Valve)[W/O Power Beyond]
Bloco De Válvula (Eixo Tr Anversal) / Valve Block (Transaxle)
Bloco De Válvula (Válvula Solenóide) / Valve Block (Solenoid Valve)
Axial Bomba [Com Equipame Nto Do Carregador] / Axial Pump [With Loader Equipm Ent]
Axial Bomba [Sem Equipame Nto Do Carregador] / Axial Pump [W/O Loader Equipme Nt]
Tubulação De Bomba Axial [Com Equipamento Do Carregador] [Com Power Beyond] / Axial Pump Pingpe[With Loader Equipment] [With Po Wer Beyond]
Tubulação De Bomba Axial [Com Equipamento Do Carregador] [Sem Power Beyond] / Axial Pump Piping[With Loader Equipment] [W/O Pow Er Beyond]
Tubulação De Bomba Axial [Sem Equipamento Do Carregador] / Axial Pump Piping [W/O Loader Equipment]
Linha De Óleo Hidráulico (Bomba Axial A Válvula De Controlo Remoto) [Com Equ Ipamento Do Carregador] [Com Power Beyond] / Hydrau Lic Oil Line (Axial Pump To Remote Control Valve) [ With Loader Equipment] [With Power Beyond]
Linha De Óleo Hidráulico (Bomba Axial A Válvula De Controlo Remoto) [Com Equ Ipamento Do Carregador] [Sem Power Beyond] / Hydrau Lic Oil Line (Axial Pump To Remote Control Valve) [ With Loader Equipment] [W/O Power Beyond]
Linha De Óleo Hidráulico (Bomba Axial A Válvula De Controlo Remoto) [Sem Equ Ipamento Do Carregador] / Hydraulic Oil Line (Axial Pump To Remote Control Valve) [W/O Loader Equipmen T]
Tubo Da Válvula Da Suspen São Dianteira (Parte Traseira) [Com Saída Hidráulic A Dianteira] / Front Suspension Valve Pipe (Rear) [ With Front Hyd. Outlet]
Tubo Da Válvula Da Suspen São Dianteira (Parte Traseira) [Sem Saída Hidráulic A Dianteira] / Front Suspension Valve Pipe (Rear) [ W/O Front Hyd. Outlet]
Valvula Da Suspensão Fron Tal / Front Suspension Valve
Valvula Da Suspensão Fron Tal [Peças Componentes] / Front Suspension Valve [C Omponent Parts]
Tubo Da Válvula Da Suspen São Dianteira (Frente) [Com Saída Hidráulica Diante Ira] / Front Suspension Valve Pipe (Front) [With Fr Ont Hyd. Outlet]
Tubo Da Válvula Da Suspen São Dianteira (Frente) [Sem Saída Hidráulica Diante Ira] / Front Suspension Valve Pipe (Front) [W/O Fro Nt Hyd. Outlet]
Suspensão Frontal Acumula Dor / Front Suspension Accumulator
Suspensão Frontal Cilindr O Tubo / Front Suspension Cylinder Hose
Válvula De Controlo Remot O (6 Válvulas) / Remote Control Valve (6 Valves)
Válvula De Controlo Remot O (5 Válvulas) [Com Saída Hidráulica Dianteira] / R Emote Control Valve (5 Valves) [With Front Hyd. Out Let]
Válvula De Controlo Remot O (5 Válvulas) [Sem Saída Hidráulica Dianteira] / R Emote Control Valve (5 Valves) [W/O Front Hyd. Outl Et]
Válvula De Controlo Remot O (4 Válvulas) / Remote Control Valve (4 Valves)
Válvula De Controlo Remot O (6 Válvulas) [Peças Componentes] / Auxiliary Cont Rol Valve (6 Valves) [Component Parts]
Válvula De Controlo Remot O (5 Válvulas) [Peças Componentes] / Auxiliary Cont Rol Valve (5 Valves) [Component Parts]
Válvula De Controlo Remot O (4 Válvulas) [Peças Componentes] / Auxiliary Cont Rol Valve (4 Valves) [Component Parts]
Válvula De Controle Direc Ional (6 Válvulas) [Peças Componentes] / Directiona L Control Valve (6 Valves) [Component Parts]
Válvula De Controle Direc Ional (5 Válvulas) [Peças Componentes] / Directiona L Control Valve (5 Valves) [Component Parts]
Válvula De Controle Direc Ional (4 Válvulas) [Peças Componentes] / Directiona L Control Valve (4 Valves) [Component Parts]
Válvula Central [Peças Co Mponentes] / Center Valve [Component Parts]
Válvula De Placa End [Peç As Componentes] / End Plate Valve [Component Parts]
Coletor De Óleo (Válvula De Controlo Remoto) [4p] / Oil Collector(Remote Con Trol Valve) [4p]
Tubo Da Saída Hidráulica Dianteira (Parte Traseira) [Com Saída Hidráulica Di Anteira] / Front Hydraulic Outlet Pipe (Rear) [With Front Hyd. Outlet]
Tubo Da Saída Hidráulica Dianteira (Parte Dianteira) [Com Saída Hidráulica D Ianteira] / Front Hydraulic Outlet Pipe (Front) [Wi Th Front Hyd. Outlet]
Tubo Da Saída Hidráulica (Tubo De Controlo Do Sensor De Carga) [Com Power Be Yond] / Hydraulic Outlet Pipe (Load-Sensing Control Hose) [With Power Beyond]
Tubo Da Saída Hidráulica (Power Beyond/Tubo De Retorno) [Com Power Beyond] / Hydraulic Outlet Pipe (Power Beyond/Return Hose) [ With Power Beyond]
Valvula Travao Reboque [T Ravão De Trailer De 1+2 Linha] / Trailer Brake Valv E [1+2-Line Trailer Brake]
Valvula Travao Reboque [T Ravão De Trailer De 1 Linha] / Trailer Brake Valve [1-Line Trailer Brake]
Valvula Travao Reboque/Tu Bo 1 [Travão De Trailer De 1+2 Linha] / Trailer Bra Ke Valve/Pipe 1 [1+2-Line Trailer Brake]
Tubo Da Válvula Do Travão De Reboque/Acoplamento [Travão De Trailer De 1+2 L Inha] / Trailer Brake Valve Pipe/Coupler [1+2-Line Trailer Brake]
Tubo Da Válvula Do Travão De Reboque/Acoplamento [Travão De Trailer De 1 Lin Ha] / Trailer Brake Valve Pipe/Coupler [1-Line Trai Ler Brake]
Valvula Travao Reboque/Tu Bo 2 [Travão De Trailer De 1+2 Linha] / Trailer Bra Ke Valve/Pipe 2 [1+2-Line Trailer Brake]
Tubo De Óleo Do Carregado R (Parte Traseira) [Com Equipamento Do Carregador] / Front Loader Oil Pipe (Rear) [With Loader Equipme Nt]
Tubo De Óleo Do Carregado R (Parte Dianteira) [Com Equipamento Do Carregador] / Front Loader Oil Pipe (Front) [With Loader Equip Ment]
Compressor De Ar [Com Compres Sor De Ar] / Air Compressor [With Air Compressor]
Compressor De Ar [Peças Compo Nentes][Com Compressor De Ar] / Air Compressor [Com Ponent Parts] [With Air Compressor]
Tubo Do Compressor De Ar [Com Compressor De Ar] / Air Compressor Pipe [With Air Compressor]
Tubo De Refrigeração [Com Com Pressor De Ar] / Cooling Pipe [With Air Compressor]
Secagem [Com Compressor De Ar ] / Dryer [With Air Compressor]
Deposito De Ar [Com Compresso R De Ar] / Air Tank [With Air Compressor]
Tubo Do Deposito De Ar [Com C Ompressor De Ar] [Tipo De Suspensão Traseira (Mola) ] / Air Tank Pipe [With Air Compressor] [Rear Suspe Nsion Type (Spring)]
Tubo Do Deposito De Ar [Com C Ompressor De Ar] [Tipo De Suspensão Traseira (Ar)] / Air Tank Pipe [With Air Compressor] [Rear Suspens Ion Type (Air)]
Acoplador De Ar [Com Compress Or De Ar] [Travão De Trailer De 1 Linha] / Air Coup Ler [With Air Compressor] [1-Line Traler Brake]
Elo 3p Dianteiro (Elo Estrutura/Superior) [Com 3p Diant Eiro] [Com Saída Hidráulica Dianteira] / Front 3p L Ink (Frame/Top Link) [With Front 3p] [With Front Hy D. Outlet]
Elo 3p Dianteiro (Elo Estrutura/Superior) [Com 3p Diant Eiro] [Sem Saída Hidráulica Dianteira] / Front 3p L Ink (Frame/Top Link) [With Front 3p] [W/O Front Hyd . Outlet]
Elo 3p Dianteiro (Içador) [Com 3p Dianteiro] / Front 3p Link (Lifter) [With Front 3p]
Liga Ção 3p Dianteira (Cilindro) [Com 3p Dianteiro] / Fr Ont 3p Link (Cylinder) [With Front 3p]
Tdf Dianteira [Com Tdf Dianteira] / Front Pto [With Fro Nt Pto]
Caix A Da Engrenagem Tdf (Carreto) [Peças Componentes] [ Com Tdf Dianteira] / Pto Gear Case (Gear) [Componen T Parts] [With Front Pto]
Caix A Da Engrenagem Tdf (Bomba) [Peças Componentes] [Co M Tdf Dianteira] / Pto Gear Case (Pump) [Component Parts] [With Front Pto]
Caix A Da Engrenagem Tdf (Embraiagem) [Peças Componentes ] [Com Tdf Dianteira] / Pto Gear Case (Clutch) [Com Ponent Parts] [With Front Pto]
Caix A Da Engrenagem Tdf (Caixa) [Peças Componentes] [Co M Tdf Dianteira] / Pto Gear Case (Case) [Component Parts] [With Front Pto]
Caix A Da Engrenagem Tdf (Kit De Juntas E Vedantes) [Peç As Componentes] [Com Tdf Dianteira] / Pto Gear Case (Gasket And Seal Kit) [Component Parts] [With Fron T Pto]
Supo Rte Do Elo Superior/Suporte Do Acoplador / Top Link Bracket/Coupler Bracket
Liga Ção 3 Pontos (Ligação Superior:Manual) / 3-Point Li Nkage (Top Link:Manual)
Liga Ção 3 Pontos (Ligação Superior:Hidráulica) / 3-Poin T Linkage (Top Link:Hydraulic)
Liga Ção 3 Pontos (Ligação Inferior) / 3-Point Linkage (Lower Link)
Esta Bilizador (Elevador) [Com Puxo (Escada)] / Stabiliz Er(Lifter) [With Hitch (Ladder)]
Esta Bilizador (Automatico) [Com Puxo (Dromone)] / Stabi Lizer(Automatic) [With Hitch (Dromone)]
Esta Bilizador (Automatico) [Peças Componentes] / Stabil Izer(Automatic) [Component Parts]
Liga Ção 3 Pontos (Tirante De Elevação) / 3-Point Linkag E (Lift Rod)
Ciln Dro Eleveção / Lift Cylinder
Puxo Barra [Com Puxo (Escada)] / Drawbar Bracket [With Hitch (Ladder)]
Barr A Reboque(Padrão) [Com Puxo (Escada)] / Drawbar(Sta Ndard) [With Hitch (Ladder)]
Barr A Reboque (Fixed Piton) [Com Puxo (Escada)] / Drawb Ar(Fixed Piton) [With Hitch (Ladder)]
Barr A Reboque(Engate K80) [Com Puxo (Escada)] / Drawbar (Coupling K80) [With Hitch (Ladder)]
Cobe Rtura De Barras De Engate [Com Barra Reboque] / Dra Wbar Cover [With Drawbar]
Puxo (Escada) [Com Puxo (Escada)] / Hitch (Ladder) [Wit H Hitch (Ladder)]
Puxo (Dromone) [Com Puxo (Dromone)] / Hitch (Dromone) [ With Hitch (Dromone)]
Puxo (Dromone) [Peças Componentes] [Com Puxo (Dromone)] / Hitch (Dromone) [Component Parts] [With Hitch (D Romone)]
Puxo (Dromone) Control Alavanca [Com Puxo (Dromone)] / Hitch (Dromone) Trailer Lever [With Hitch (Dromone) ]
Ganc Ho Trailer (Automatico) [Com Puxo (Escada)] / Trail Er Clevis (Automatic) [With Hitch (Ladder)]
Ganc Ho Trailer (Manual) [Com Puxo (Escada)] / Trailer C Levis (Manual) [With Hitch (Ladder)]
Ganc Ho Trailer (Piton) [Com Puxo (Escada)] / Trailer Cl Evis (Piton) [With Hitch (Ladder)]
Ganc Ho Trailer (Automatico) [Com Puxo (Escada)] [Peças Componentes] / Trailer Clevis (Automatic) [Componen T Parts] [With Hitch (Ladder)]
Ganc Ho Trailer (Manual) [Com Puxo (Escada)] [Peças Comp Onentes] / Trailer Clevis (Manual) [Component Parts ] [With Hitch (Ladder)]
Estrutura Capot / Hood (Bonnet) Frame
Estrutura Capot (Inferior) / Hood (Bonnet) Frame (Lower)
Capot Inferior (Direito) / Hood (Bonnet) Si De Lower Rh
Capot Inferior (Esquerdo) [Com Compressor D E Ar] / Hood (Bonnet) Side Lower Lh [With Air Compr Essor]
Capot Inferior (Esquerdo) [Sem Compressor D E Ar] / Hood (Bonnet) Side Lower Lh [W/O Air Compre Ssor]
Placa Do Obturador (Silenciador/Isolador) / Shutter Plate (Sound Absorber/Insulator)
Guarda-Lamas Dianteiro(W:540) / Front Fende R(W:540)
Guarda-Lamas Dianteiro(W:600) / Front Fende R(W:600)
Placa Sinalizadora [Com Guarda-Lamas Diante Iro (W:600)] / Signal Plate [With Front Fender (W:6 00)]
Estrutura Cabine / Cab Frame
Degrau Direito [Com Equipamento Do Carregador] / S Tep Rh [With Loader Equipment]
Degrau Direito [Sem Equipamento Do Carregador] / S Tep Rh [W/O Loader Equipment]
Degrau Esquerdo / Step Lh
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Vidro Traseiro Da Escotilha (Vidro Traseiro) [Sem Desembaçador] / Hatch Back Glass (Rear Window) [W/O Defogger]
Vidro Traseiro Da Escotilha (Vidro Traseiro) [Com Desembaçador] / Hatch Back Glass (Rear Window) [Wit H Defogger]
Tejadilho / Sun Roof
Espelho Rectrovisor [Com Aquecedor De Espelho Retr Ovisor] / Rearview Mirror [With Mirror Heater]
Espelho Rectrovisor [Sem Aquecedor De Espelho Retr Ovisor] / Rearview Mirror [W/O Mirror Heater]
Tecto Interior [Com Holofote] / Inner Roof [With S Potlight]
Tecto Interior [Sem Holofote] / Inner Roof [W/O Sp Otlight]
Cobertura Exterior Do Tejadilho / Outer Roof
Suporte Do Assento / Seat Bracket
Banco / Seat
Assento Do Banco / Cushion,Seat
Apoio-De-Braço Do Banco/Encosto Do Banco / Seat Ar Mrest/Seat Backrest
Suspensao Banco / Seat Suspension
Banco De Passageiro / Passenger Seat
Tapete Do Piso / Floor Mat
Material À Prova De Som (Chão) / Soundproof Materi Al (Floor)
Material À Prova De Som (Consola) / Soundproof Mat Erial (Console)
Cobertura De Mudança (Consola Direita) / Shift Cov Er (Console Rh)
Tampa Do Rádio E Tampa Do Painel De Controlo Do Ar Condicionado [Com Ar Condicionado - Automático] / Radio Cover And Air Conditioner Control Panel Cover [With Auto Air Conditioner]
Tampa Do Rádio E Tampa Do Painel De Controlo Do Ar Condicionado [Com Ar Condicionado - Manual] / Radi O Cover And Air Conditioner Control Panel Cover [W Ith Manual Air Conditioner]
Resguardo Coluna / Pillar Cover
Cobertura Do Guarda-Lamas / Fender Cover
Guarda Lamas (Direito) [Antiga] / Fender Rh [Old]
Guarda Lamas (Direito) [Nova] / Fender Rh [New]
Guarda Lamas (Esquerda) [Antiga] / Fender Lh [Old]
Guarda Lamas (Esquerda) [Nova] / Fender Lh [New] # # N.º De Série>=30012 S.No.;>=30012 / S.No.>=30012 S.No.;>=30012
Guarda Lamas / Over Fender
Suporte Cabine Frente [Com Equipamento Do Carregad Or] / Cab Bracket Front [With Loader Equipment]
Suporte Cabine Frente [Sem Equipamento Do Carregad Or] / Cab Bracket Front [W/O Loader Equipment]
Suporte Cabine Traseira / Cab Bracket Rear
Traseira Amortecedor [Tipo De Suspensão Traseira ( Ar)] [Com Compressor De Ar] / Rear Damper [Rear Sus Pension Type (Air)] [With Air Compressor]
Caixa Ferramenta / Tool Box
Ar Condicionado [Com Ar Condi Cionado - Automático] / Air Conditioner [With Auto Air Conditioner]
Ar Condicionado [Com Ar Condi Cionado - Manual] / Air Conditioner [With Manual Ai R Conditioner]
Conduta Do Ar Condicionado (A R Frio) / Air Conditioner Duct (Fresh Air)
Conduta Do Ar Condicionado (T Raseira) / Air Conditioner Duct (Rear)
Modo Caixa / Mode Case
Entradas Ar Painel Instrument Os / Dashboard Air Outlets
Circulaçao Ar Interior [Com A R Condicionado - Automático] / Inner Air Recirculat Ion [With Auto Air Conditioner]
Circulaçao Ar Interior [Com A R Condicionado - Manual] / Inner Air Recirculation [With Manual Air Conditioner]
Tubo Aquecimento / Heater Hos E
Tubo Ar Condicionado/Tubo Con Densador / Air Conditioner Hose/Condenser Hose
Polia De Acionamento Do Compr Essor [Com Compressor De Ar] / Compressor Drive Pul Ley [With Air Compressor]
Polia De Acionamento Do Compr Essor [Sem Compressor De Ar] / Compressor Drive Pul Ley [W/O Air Compressor]
Compressor (Ar Condicionado) / Compressor (Air Conditioner)
Roda Dianteira (480/70r28) [Miche Lin] / Front Wheel (480/70r28) [Michelin]
Roda Dianteira (480/70r28) [Trell Eborg] / Front Wheel (480/70r28) [Trelleborg]
Roda Dianteira (540/65r28) [Miche Lin] / Front Wheel (540/65r28) [Michelin]
Roda Dianteira (540/65r28) [Fires Tone] / Front Wheel (540/65r28) [Firestone]
Roda Dianteira (600/60r28) [Miche Lin] / Front Wheel (600/60r28) [Michelin]
Roda Traseira (580/70r38) [Michel In] / Rear Wheel (580/70r38) [Michelin]
Roda Traseira (580/70r38) [Trelle Borg] / Rear Wheel (580/70r38) [Trelleborg]
Roda Traseira (650/65r38) [Michel In] / Rear Wheel (650/65r38) [Michelin]
Roda Traseira (650/65r38) [Firest One] / Rear Wheel (650/65r38) [Firestone]
Roda Traseira (700/60r38) [Michel In] / Rear Wheel (700/60r38) [Michelin]
Decalcomania(Painel/Cobertura De Mudança) / Label (Panel/Shift Cover)
Etiqueta (Traseira) [Com Puxo (Escada)] / La Bel (Rear) [With Hitch (Ladder)]
Etiqueta (Traseira) [Com Puxo (Dromone)] / L Abel (Rear) [With Hitch (Dromone)]
Etiqueta (Unidade Control Electrico/Controla Dor) / Label (Ecu/Controller)
Decalcomania (Cabine Interior) / Label (Cab Interior)
Peça De Acessorio E Serviço Peças / Accessories And Service Parts
Kit Alternador (200a) [Opção] / Alternator Kit ( 200a) [Option]
Alternador [Peças Componentes] (200a) [Opção] / Alternator [Component Parts] (200a) [Option]
Lâmpada Farol [Opçao] / Beacon Lamp Kit [Option]
Kit Luzes Trabalho [Com Lampada De Led] [Opçao] / Working Light Kit [With Led Light] [Option]
Kit Luzes Trabalho [Com Lampada De Halogénio] [O Pçao] / Working Light Kit [With Halogen Light] [Opt Ion]
Luzes Frente (Farol De Repetição) [Opçao] / Head Light Kit (Repeat Head Light) [Option]
Kit De Luz Interior [Opção] / Room Light Kit [Op Tion]
Kit Da Tdf Dianteira (6 Estrias) (Caixa Da Engre Nagem) [Opção] / Front Pto Kit (6 Splines) (Gear Ca Se) [Option]
Kit Da Tdf Dianteira (6 Estrias) (Engrenagem) [O Pção] / Front Pto Kit (6 Splines) (Gear) [Option]
Kit Da Tdf Dianteira (6 Estrias) (Bomba) [Opção] / Front Pto Kit (6 Splines) (Pump) [Option]
Kit Da Tdf Dianteira (6 Estrias) (Embraiagem) [O Pção] / Front Pto Kit (6 Splines) (Clutch) [Option]
Kit Da Tdf Dianteira (6 Estrias) (Caixa) [Opção] / Front Pto Kit (6 Splines) (Case) [Option]
Kit Da Tdf Dianteira (6 Estrias) (Engrenagem Box /Junta) [Opção] / Front Pto Kit (6 Splines) (Gear C Ase/Gasket) [Option]
Kit Da Tdf Dianteira (6 Estrias) (Arrefecedor Do Óleo) [Opção] / Front Pto Kit (6 Splines) (Oil Coo Ler) [Option]
Kit Do Terminal (12 Polegadas) [Opção] / Termina L Kit (12 Inch) [Option]
Kit Do Sensor (Radar) [Opção] / Sensor Kit (Rada R) [Option]
Kit Da Câmara [Opção] / Camera Kit [Option]
Kit De Antena (Modem Rtk De Direção Automática) (Antena) [Opçao] / Anntena Kit (Auto Steer Rtk Mode M) (Anntena) [Option]
Kit De Antena (Direção Automática Dgps/Sem Rtk) [Opçao] / Anntena Kit (Auto Steer Dgps/Without Rtk) [Option]
Kit De 21 Estrias De Tdf [Opção] [Ec] / Pto Kit (21 Splines) [Option] [Ec]
Kit Do Reboque (Automático) [Opção] / Trailer Ki T (Auto) [Option]
Kit Do Reboque (Manual) [Opção] / Trailer Kit (M Anual) [Option]
Kit Do Reboque (K80) [Opção] / Trailer Kit (K80) [Option]
Kit Do Reboque (Pistão) [Opção] / Trailer Kit (P Iton) [Option]
Kit Do Reboque (Cuna-D3) [Opção] / Trailer Kit ( Cuna-D3) [Option]
Kit Do Reboque (Cuna-D2) [Opção] / Trailer Kit ( Cuna-D2) [Option]
Kit Do Reboque (Cuna-C) [Opção] / Trailer Kit (C Una-C) [Option]
Gancho Trailer (Automatico) [Peças Componentes] [Opção] / Trailer Clevis (Automatic) [Component Par Ts] [Option]
Espelho Retrovisor Com Kit De Aquecedor [Opção] / Rearview Mirror Kit (With Heater) [Option]
Auxiliar Do Válvula De Controlo Kit (Elétrica 5ª ) [Opção] / Auxiliary Control Valve Kit (Elec.5th) [Option]
Kit De Acoplador Powr Beyond (Acoplador) [Opção] / Power Beyond Coupler Kit (Coupler) [Option]
Kit De Acoplador Powr Beyond (Tubo/Acoplador) [O Pção] / Power Beyond Coupler Kit (Pipe/Coupler) [Op Tion]
Ligacao Superior (Hidráulica) [Opção] / Top Link Kit (Hydraulic) [Option]
Kit De Ligação 3-P Dianteira (Elo Estrutura/Supe Rior) [Opção] / Front 3p Link Kit (Frame/Top Link) [Option]
Kit De Ligação 3-P Dianteira (Elevação) [Opção] / Front 3p Link Kit (Lifter) [Option]
Kit De Ligação 3-P Dianteira (Cilndro) [Opção] / Front 3p Link Kit (Cylinder) [Option]
Kit De Ligação 3-P Dianteira (Mecânica 5ª) (Válv Ula) [Opção] / Front 3p Link Kit (Mech.5th) (Valve) [Option]
Kit Da Interruptor Externo Da Ligação 3-P Diante Ira[Opçao] / External Switch For Front 3-Point Hitc H [Option]
Kit De Escora (Padrão) [Opção] / Drawbar Kit (St Andard) [Option]
Kit De Escora (Acoplamento K80) [Opção] / Drawba R Kit (Coupling K80) [Option]
Kit De Escora (Pistão Fixo) [Opção] / Drawbar Ki T (Fix Piton) [Option]
Kit De Escora (Cuna) [Opção] / Drawbar Kit (Cuna ) [Option]
Kit Do Guarda-Lamas Dianteiro (W:540) [Opção] / Front Fender Kit (W:540) [Option]
Kit Do Guarda-Lamas Traseiro [Opção] / Rear Over Fender Kit [Option]
Kit Desnebulizador Traseiro / Rear Defogger Kit
Kit Protetor De Para-Sol [Opção] / Sunshade Shie Ld Kit [Option]
Ventoinh A / Fan
Painel / Panel
Escova / Wiper
Travão / Brake
Porta Drt / Door Rh
Porta Esq / Door Lh
Banco / Seat
