Kubota Tractor M7151P M7151KVT Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M7151P ; M7151KVT Tractor
Number of Pages: 709 Pages
Itens Usado S Frequentemente / Frequently Used Items
Itens Usado S Frequentemente (Componenetes Electricos) / Freque Ntly Used Items (Electrical Parts)
Bloco Motor(Superior) / Crankcase (Upper)
Bloco Motor(Inferior) / Crankcase (Lower)
Cárter Do Óleo [Com Compressor De Ar] / Oil Pan [With Air Compressor]
Cárter Do Óleo [Sem Compressor De Ar] / Oil Pan [W/O Air Compressor]
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exha Ust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Bomba De Abastecimento / Supply Pump
Injector E Vela Aquecimento / Injector And Glow Plug
Common Rail / Common Rail
Bomba Agua / Water Pump
Radiador Oleo / Oil Cooler
Separador De Óleo [Peças Componentes] / Oil Sepa Rator [Component Parts]
Tubo Do Separador De Óleo [Sem Aquecedor] / Oil Separator Pipe [W/O Heater]
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo C Harger)
Filtro Ar [Com Tdf Dianteira] / Air Cleaner [Wit H Front Pto]
Filtro Ar [Sem Tdf Dianteira] / Air Cleaner [W/O Front Pto]
Filtro Ar [Peças Componentes] / Air Cleaner [Com Ponent Parts]
Tubo De Entrada (Filtro De Ar) [Com Compressor D E Ar] / Inlet Pipe (Air Cleaner) [With Air Compress Er]
Tubo De Entrada (Filtro De Ar) [Sem Compressor D E Ar] / Inlet Pipe (Air Cleaner) [W/O Air Compresse R]
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubos De Água Egr / Egr Water Piping
Silenciador Do Filtro De Partículas Diesel / Die Sel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peça S Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Tubo Pressao / Pressure Pipe
Panela Escape / Muffler Pipe
Silenciador De Redução Catalítica Seletivo [Anti Go] / Selective Catalytic Reduction Muffler [Old] # # N.º De Série<=30255 S.No.;<=30255 [Note:Order By Fig.No.460002 Ref.No.040,050,070,080, 95 And 215 Ne W Parts.] / S.No.<=30255 [Note:Order By Fig.No.4600 02 Ref.No.040,050,070,080, 95 And 215 New Parts.]
Silenciador De Redução Catalítica Seletivo [Anti Go] / Selective Catalytic Reduction Muffler [Old] # # N.º De Série30256 To 30771 S.No.;30256 To 30771 / S.No.30256 To 30771 S.No.;30256 To 30771
Silenciador De Redução Catalítica Seletivo [Novo ] / Selective Catalytic Reduction Muffler [New]
Tubulação E Proteção Do Silênciador / Muffler Pi Pe And Cover
Bomba Do Fluido De Escape De Diesel / Diesel Exh Aust Fluid Pump
Depósito Do Fluido De Escape De Diesel [Peças Co Mponentes] / Diesel Exhaust Fluid Tank [Component Parts]
Depósito Do Fluido De Escape De Diesel Tubo / Di Esel Exhaust Fluid Hose
Depósito Do Fluido De Escape De Diesel Aquecedor Tubo / Diesel Exhaust Fluid Heater Hose
Depósito Do Fluido De Escape De Diesel Mangueira De Respiro / Diesel Exhaust Fluid Breather Hose
Válvula Egr (Sistema De Redução Catalítica Selet Iva) / Egr Valve (Selective Catalytic Reduction Sys Tem)
Sistema De Arrefecimento Egr (Sistema De Redução Catalítica Seletiva) / Egr Cooler (Selective Catal Ytic Reduction System)
Tubo Egr (Sistema De Redução Catalítica Seletiva ) / Egr Pipe (Selective Catalytic Reduction System)
Tubos De Água Egr (Sistema De Redução Catalítica Seletiva) / Egr Water Piping (Selective Catalytic Reduction System)
Componentes Electricos Motor (Sensor/Ecu) / Engi Ne Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape) / E Ngine Electrical Parts (Muffler)
Deposito Combustivel / Fue L Tank
Suporte Deposito Combustiv El [Com Equipamento Do Carregador] / Fuel Tank Brac Ket [With Loader Equipment]
Suporte Deposito Combustiv El [Sem Equipamento Do Carregador] / Fuel Tank Brac Ket [W/O Loader Equipment]
Tubo Do Combustível (Enchi Mento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Arrefece Dor Gasoleo) / Fuel Pipe (Fuel Cooler)
Arrefecedor Do Combustível [Antigo] / Fuel Cooler [Old]
Arrefecedor Do Combustível [Novo] / Fuel Cooler [New]
Separador / Separator
Separador [Peças Component Es] / Separator [Component Parts]
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Compo Nentes] / Fuel Pump [Component Parts]
Filtro Gasoleo / Fuel Filt Er
Filtro Gasoleo [Peças Comp Onentes] / Fuel Filter [Component Parts]
Suporte Ventilador [Antiga] / Fan Bracket [Old]
Suporte Ventilador [Nova] / Fan Bracket [New]
Polia De Acionamento Da Ventoinha / Fan Drive Pulley
Ventoinh A [Antiga] / Fan [Old]
Ventoinh A [Nova] / Fan [New]
Tubo De Água E Tubo Do Sistema De Arrefecimento / Water Pip E And Cooler Pipe
Unidade Do Sistema De Arrefecimento / Cooler Unit
Unidade Do Arrefecedor (Radiador) [Peças Componentes] / Coo Ler Unit (Radiator) [Component Parts]
Unidade Do Arrefecedor (Permutador Intermédio De Calor) [Pe Ças Componentes] / Cooler Unit (Inter Cooler) [Comp Onent Parts]
Unidade Do Arrefecedor (Arrefecedor Do Óleo) [Peças Compone Ntes] / Cooler Unit (Oil Cooler) [Component Parts]
Unidade Do Arrefecedor (Condensador) [Peças Componentes] / Cooler Unit (Condenser) [Component Parts]
Tubo Do Depósito De Reserva [Com Compressor De Ar] / Reserv E Tank Hose [With Air Compressor]
Tubo Do Depósito De Reserva [Sem Compressor De Ar] / Reserv E Tank Hose [W/O Air Compressor]
Alternador (200a) / Alter Nator (200a)
Alternador (150a) / Alter Nator (150a)
Alternador (200a) [Peças Componentes] / Alternator (200a) [Component Parts]
Alternador (150a) [Peças Componentes] / Alternator (150a) [Component Parts]
Motor Arranque / Starter
Suporte De Bateria / Batt Ery Bracket
Interruptor/Sensor (Bloco Motor Esquerda) / Switch/Sensor (Engine Lh)
Sensor Da Redução Catalít Ica Seletiva / Selective Catalytic Reduction Sensor
Suspensão Frontal Sensor [Com Suspensão Frontal] / Front Suspension Sensor [ With Front Suspension]
Sensor (Pedal) / Sensor ( Pedal)
Interruptor/Sensor [Eixo Dianteiro: Tipo Padrão] [Com Compressor De Ar] [Tip O De Suspensão (Ar)] [Antigo] / Switch/Sensor [Fron T Axle:Standard Type] [Suspension Type (Air)] [With Air Compressor] [Old]
Interruptor/Sensor [Eixo Dianteiro: Tipo Padrão] [Com Compressor De Ar] [Tip O De Suspensão (Ar)] [Novo] / Switch/Sensor [Front Axle:Standard Type] [Suspension Type (Air)] [With A Ir Compressor] [New]
Interruptor/Sensor [Eixo Dianteiro: Tipo Padrão] [Com Compressor De Ar] [Sus Pensão(Mola)] [Antigo] / Switch/Sensor [Front Axle: Standard Type] [Suspension Type (Spring)] [With Air Compressor] [Old]
Interruptor/Sensor [Eixo Dianteiro: Tipo Padrão] [Com Compressor De Ar] [Sus Pensão(Mola)] [Novo] / Switch/Sensor [Front Axle:St Andard Type] [Suspension Type (Spring)] [With Air C Ompressor] [New]
Interruptor/Sensor [Eixo Dianteiro: Tipo Padrão] [Sem Compressor De Ar] [Ant Igo] / Switch/Sensor [Front Axle:Standard Type] [W/ O Air Compressor] [Old]
Interruptor/Sensor [Eixo Dianteiro: Tipo Padrão] [Sem Compressor De Ar] [Nov O] / Switch/Sensor [Front Axle:Standard Type] [W/O Air Compressor] [New]
Interruptor/Sensor [Eixo Dianteiro: Tipo Pesado] [Sem Compressor De Ar] / Sw Itch/Sensor [Front Axle:Heavy Duty Type] [W/O Air C Ompressor]
Sensor (Caixa De Transmis São) [Componente De Translaxe] / Sensor (Transmissi On Housing Rh) [Transaxle Component]
Sensor (Caixa De Transmis São) [Componente De Translaxe] / Sensor (Transmissi On Housing Lh) [Transaxle Component]
Sensor Da Conicidade/Sens Or 3p / Draft Sensor/3p Sensor
Interruptor (Painel) / Sw Itch (Panel Board)
Interruptor (Direcção) [C Om Direção Automática] / Switch (Steering) [Auto St Eering Compatible]
Interruptor (Direcção) [S Em Direção Automática] / Switch (Steering) [Auto St Eering Incompatible]
Interruptor (Cobertura De Mudança) / Switch (Shift Cover)
Interruptor Externo / Ext Ernal Switch
Relé/Controlador [Sem Aqu Ecedor] / Relay/Controller [W/O Heater]
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico /Controlador (Vdc) / Electronic Control Unit/Contro Ller(Vdc)
Controlador (Ceu) / Contr Oller (Ceu)
Controlador (Ceu) [Peças Componentes] / Controller (Ceu) [Component Parts]
Painel / Panel
Peças Elétricas Da Trasei Ra Interior Da Cabine (Saída Elétrica/Painel De Con Trolo Do Ar Condicionado) / Cab Inner Rear Electric Al Parts (Electrical Outlet/Air Conditioner Control Panel)
Terminal Isobus / Isobus Terminal
Apoio De Braço (4 Válvula S De Controlo Remoto) / Armrest (4 Remote Control V Alves)
Apoio De Braço (5 Válvula S De Controlo Remoto) [Com Controle De Video Game] / Armrest (5 Remote Control Valves) [With Joystick]
Apoio De Braço (5 Válvula S De Controlo Remoto) [Sem Controle De Video Game] / Armrest (5 Remote Control Valves) [W/O Joystick]
Apoio De Braço (6 Válvula S De Controlo Remoto) [Com Controle De Video Game] [Com Tdf Dianteira] / Armrest (6 Remote Control Val Ves) [With Joystick] [With Front Pto]
Apoio De Braço (6 Válvula S De Controlo Remoto) [Sem Controle De Video Game] [Com Tdf Dianteira] / Armrest (6 Remote Control Val Ves) [W/O Joystick] [With Front Pto]
Apoio De Braço (6 Válvula S De Controlo Remoto) [Sem Controle De Video Game] [Sem Tdf Dianteira] / Armrest (6 Remote Control Val Ves) [W/O Joystick] [W/O Front Pto]
Terminal (12 Polegadas) / Terminal (12 Inch)
Terminal (7 Polegadas) / Terminal (7 Inch)
Luzes Frente / Head Light
Luzes Frente (Coluna) [Co M Farol De Repetição] / Head Light (Pillar) [With R Epeat Head Light]
Lâmpada Farol / Beacon La Mp
Luzes Frontais / Front Co Mbination Lamp
Luz De Trabalho (Dianteir O/Teto) [Antigo] / Work Light (Front/Roof) [Old]
Luz De Trabalho (Dianteir O/Teto) [Novo] / Work Light (Front/Roof) [New]
Luz De Trabalho (Dianteir O/Coluna) / Work Light (Front/Pillar)
Luz De Trabalho (Traseiro /Teto) / Work Light (Rear/Roof)
Luz De Trabalho (Traseiro /Coluna) / Work Light (Rear/Pillar)
Braco Traseiro / Rear Com Bination Lamp
Lâmpada Licenciada [Antig O] / License Lamp [Old]
Lâmpada Licenciada [Novo] / License Lamp [New]
Ficha Reboque / Trailer S Ocket
Luz Interior / Room Light
Alta Voz Radio / Radio Sp Eaker
Depósito De Lavagem / Was Her Tank
Escova / Wiper
Cablagem Elétrica (Motor) 1 (Filtro De Ar/Dpf) / Electrical Wiring (Engine) 1 (Air Cleaner/Dpf)
Cablagem Elétrica (Motor) 2 (Crs) / Electrical Wiring (Engine) 2 (Crs)
Cablagem Elétrica (Motor) 3 (Combustível/Scr) / Electrical Wiring (Engine) 3 (Fuel/Scr)
Cablagem Elétrica (Motor) 4 (Fusível/Bateria) / Electrical Wiring (Engine) 4 (Fuse/Battery)
Cablagem Elétrica (Motor) 5 (Compressor/Volante) [Com Compressor De Ar] / El Ectrical Wiring (Engine) 5 (Compressor/Flywheel) [W Ith Air Compresser]
Cablagem Elétrica (Motor) 5 (Compressor/Volante) [Sem Compressor De Ar] / El Ectrical Wiring (Engine) 5 (Compressor/Flywheel) [W /O Air Compresser]
Cablagem Elétrica (Capot) / Electrical Wiring (Bonnet(Hood))
Cablagem Elétrica (Altern Ador) [Com Alternador (200 A)] / Electrical Wiring (Alternator 200a)
Cablagem Elétrica (Altern Ador) [Com Alternador (150 A)] / Electrical Wiring (Alternator 150a)
Cablagem Eletrica (Motor Arranque) / Electrical Wiring (Starter)
Cablagem Electrica (Fonte De Alimentação)/Controlador (Ceu) / Electrical Wir Ing (Power Supply)/Controller (Ceu)
Cablagem Electrica (Eixo Tranversal/Frente) [Com Compressor De Ar] / Electri Cal Wiring (Transaxle/Front) [With Air Compresser]
Cablagem Electrica (Eixo Tranversal/Frente) [Sem Compressor De Ar] / Electri Cal Wiring (Transaxle/Front) [W/O Air Compresser]
Cablagem Electrica (Eixo Tranversal/Traseira) / Electrical Wiring (Transaxle /Rear)
Cablagem Electrica (Distr Ibuidor Auxiliar) / Electrical Wiring (Remote Contr Ol Valve)
Cablagem Elétrica (Cabine ) 1 (Direção/Painel) [Antigo] / Electrical Wiring ( Cab) 1 (Steering/Panel) [Old]
Cablagem Elétrica (Cabine ) 1 (Direção/Painel) [Novo] / Electrical Wiring (Ca B) 1 (Steering/Panel) [New]
Cablagem Elétrica (Cabine ) 2 (Ecu) [Antigo] / Electrical Wiring (Cab) 2 (Ecu ) [Old]
Cablagem Elétrica (Cabine ) 2 (Ecu) [Novo] / Electrical Wiring (Cab) 2 (Ecu) [New]
Cablagem Elétrica (Cabine ) 3 (Cobertura Das Mudanças/Apoio De Braço) / Elect Rical Wiring (Cab) 3 (Shift Cover/Armrest)
Cablagem Elétrica (Cabine ) 4 (Ar Condicionado) / Electrical Wiring (Cab) 4 ( Air Conditioner)
Cablagem Elétrica (Pilar Dianteiro) [Antigo] / Electrical Wiring (Front Pill Ar) [Old]
Cablagem Elétrica (Pilar Dianteiro) [Novo] / Electrical Wiring (Front Pillar ) [New]
Cablagem Electrica (Teto) / Electrical Wiring (Roof)
Cablagem Electrica (Pisca /Pára-Lama) / Electrical Wiring (Flasher/Mudguard)
Cablagem Electrica (Suspe Nsão Dianteira) [Com Suspensão Dianteira] / Electri Cal Wiring (Front Suspension) [With Front Suspensio N]
Cablagem Electrica (Direç Ão Automática) [Como Direção Automática] / Electric Al Wiring (Auto Steering) [Auto Steering Compatible ]
Cablagem Electrica (Isobu S) [Antigo] / Electrical Wiring (Isobus) [Old]
Cablagem Electrica (Isobu S) [Novo] / Electrical Wiring (Isobus) [New]
Disco Do Amorteced Or E Ligação À Caixa [Antigo] / Damper Disk And Hou Sing Connection [Old]
Disco Do Amorteced Or E Ligação À Caixa [Novo] / Damper Disk And Housi Ng Connection [New]
Eixo Tranversal / Transaxle
Eixo Tranversal [C Omponente De Translaxe] / Transaxle [Transaxle Comp Onent]
Caixa De Transmiss Ão [Componente De Translaxe] / Transmission Housing [Transaxle Component]
Caixa De Plugue [C Omponente De Translaxe] / Housing Plug [Transaxle C Omponent]
Caixa De Interrupt Or [Componente De Translaxe] / Housing Switch [Tran Saxle Component]
Caixa Do Eixo Tras Eiro [Componente De Translaxe] / Rear Axle Housing [Transaxle Component]
Estrutura Do Veio Tdf [Componente De Translaxe] / Pto Shaft Housing [ Transaxle Component]
Braco Hidraulico [ Componente De Translaxe] / Lift Arm [Transaxle Comp Onent]
Estrutura Interior Do Veio Tdf (Embreagem) [Componente De Translaxe] / Pto Shaft Housing Inner (Clutch) [Transaxle Compo Nent]
Estrutura Interior Do Veio Tdf (Veio Tdf) [Componente De Translaxe] / Pto Shaft Housing Inner (Pto Shaft) [Transaxle Com Ponent]
Estrutura Interior Do Veio Tdf (Forquilha De Embraiagem) [Componente De Translaxe] / Pto Shaft Housing Inner (Shift Fork ) [Transaxle Component]
Unidade Hidráulica [Componente De Translaxe] / Hydraulic Unit [Transa Xle Component]
Hidráulica Bomba D E Moradia [Componente De Translaxe] / Hydraulic Pum P Housing [Transaxle Component]
Bomba Hidraulico [ Componente De Translaxe] / Hydraulic Pump [Transaxl E Component]
Condutas Hidráulic As [Componente De Translaxe] / Hydraulic Piping [Tr Ansaxle Component]
Unidade De Control O Hidráulico/Filtro [Componente De Translaxe] / Hyd Raulic Control Unit/Filter [Transaxle Component]
Válvula Solenóide/ Regulador De Pressão [Componente De Translaxe] / So Lenoid Valve/Pressure Regulater [Transaxle Componen T]
Alvanca Inversor / Shuttle Shi Ft Lever
Eixo Traseiro [Componen Te De Translaxe] / Rear Axle [Transaxle Component]
Diferencial Traseiro [C Omponente De Translaxe] / Rear Differential [Transa Xle Component]
Travão [Componente De T Ranslaxe] / Brake [Transaxle Component]
Eixo [Componente De Tra Nslaxe] / Brake Shaft [Transaxle Component]
Alavanca Travao Mao / P Arking Brake Lever
Pedal Travao / Brake Pe Dal
Cilindro Principal Do T Ravão [Antigo] / Brake Master Cylinder [Old]
Cilindro Principal Do T Ravão [Novo] / Brake Master Cylinder [New]
Tubo Do Travão 1 (Super Ior/Parte Dianteira) / Brake Pipe 1 (Upper/Front)
Tubo Do Travão 2 (Infer Ior/Parte Traseira) / Brake Pipe 2 (Lower/Rear)
Estrutura Do Eixo Di Anteiro [Com Suspensão Frontal] / Front Axle Frame [With Front Suspension]
Estrutura Do Eixo Di Anteiro [Sem Suspensão Frontal] / Front Axle Frame [W/O Front Suspension]
Estrutura Do Carrega Dor Dianteiro [Com Equipamento Do Carregador] / Fro Nt Loader Frame [With Loader Equipment]
Para-Choques Peso Di Anteiro [Antigo] / Front Weight Bumper [Old]
Para-Choques Peso Di Anteiro [Novo] / Front Weight Bumper [New]
Balanceiro Da Suspen São Dianteira [Com Suspensão Dianteira] [Com 3p Dia Nteiro] / Front Suspension Rocker Arm [With Front S Uspension] [With Front 3p]
Balanceiro Da Suspen São Dianteira [Com Suspensão Dianteira] [Sem 3p Dia Nteiro] / Front Suspension Rocker Arm [With Front S Uspension] [W/O Front 3p]
Eixo Dianteiro [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / Front Axle [With Front Suspension] [Front Axle:St Andard Type]
Eixo Dianteiro [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Pesado] / Front Axle [With Front Suspension] [Front Axle:He Avy Duty Type]
Eixo Dianteiro [Sem Suspensão Dianteira] [Eixo Dianteiro: Tipo Pesado] / Front Axle [W/O Front Suspension] [Front Axle:Hea Vy Duty Type]
Suporte Do Eixo Dian Teiro [Componente Do Eixo Dianteiro] [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / Front A Xle Bracket [Front Axle Component] [With Front Susp Ension] [Front Axle:Standard Type]
Suporte Do Eixo Dian Teiro [Componente Do Eixo Dianteiro] [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Pesado] / Front A Xle Bracket [Front Axle Component] [With Front Susp Ension] [Front Axle:Heavy Duty Type]
Suporte Do Eixo Dian Teiro [Componente Do Eixo Dianteiro] [Sem Suspensão Dianteira] [Eixo Dianteiro: Tipo Pesado] / Front A Xle Bracket [Front Axle Component] [W/O Front Suspe Nsion] [Front Axle:Heavy Duty Type]
Caixa Do Eixo Diante Iro [Componente Do Eixo Dianteiro] [Eixo Dianteiro: Tipo Pesado] / Front Axle Housing [Front Axle Comp Onent] [Front Axle:Heavy Duty Type]
Diferencial Dianteir O [Componente Do Eixo Dianteiro] [Eixo Dianteiro: T Ipo Padrão] / Front Differential [Front Axle Compon Ent] [Front Axle:Standard Type]
Diferencial Dianteir O [Componente Do Eixo Dianteiro] [Eixo Dianteiro: T Ipo Pesado] / Front Differential [Front Axle Compon Ent] [Front Axle:Heavy Duty Type]
Veio Do Carreto Dife Rencial [Componente Do Eixo Dianteiro] [Eixo Diante Iro: Tipo Padrão] / Differential Gear Shaft [Front Axle Component] [Front Axle:Standard Type]
Veio Do Carreto Dife Rencial [Componente Do Eixo Dianteiro] [Eixo Diante Iro: Tipo Pesado] / Differential Gear Shaft [Front Axle Component] [Front Axle:Heavy Duty Type]
Sensor Do Ângulo De Viragem Da Roda [Componente Do Eixo Dianteiro] [Eix O Dianteiro: Tipo Padrão] [Antigo] / Wheel Turning Angle Sensor [Front Axle Component] [Front Axle:Sta Ndard Type] [Old]
Sensor Do Ângulo De Viragem Da Roda [Componente Do Eixo Dianteiro] [Eix O Dianteiro: Tipo Padrão] [Novo] / Wheel Turning An Gle Sensor [Front Axle Component] [Front Axle:Stand Ard Type] [New]
Sensor Do Ângulo De Viragem Da Roda [Componente Do Eixo Dianteiro] [Eix O Dianteiro: Tipo Pesado] / Wheel Turning Angle Sen Sor [Front Axle Component] [Front Axle:Heavy Duty T Ype]
Ponteira Da Direção/ Cilindro Da Direção [Componente Do Eixo Dianteiro] [Eixo Dianteiro: Tipo Padrão] / Tie Rod/Steering Cy Linder [Front Axle Component] [Front Axle:Standard Type]
Ponteira Da Direção/ Cilindro Da Direção [Componente Do Eixo Dianteiro] [Eixo Dianteiro: Tipo Pesado] / Tie Rod/Steering Cy Linder [Front Axle Component] [Front Axle:Heavy Dut Y Type]
Veio Do Propulsor E Resguardo [Com Suspensão Dianteira] / Propeller Sha Ft And Cover [With Front Suspension]
Veio Do Propulsor E Resguardo [Sem Suspensão Dianteira] / Propeller Sha Ft And Cover [W/O Front Suspension]
Direcção Assistida [Peças Componentes] / St Eering Post [Component Parts]
Pedal Inclinacao / Tilt Pedal
Comando De Direção [Com Direção Automática] / Steering Controller [Auto Steering Compatible]
Comando De Direção [Sem Direção Automática] / Steering Controller [Auto Steering Incompatible]
Circuito Oleo Direcção (R Adiador Oleo/Frente) / Hydraulic Oil Line (Oil Cool Er/Front)
Circuito Oleo Direcção (R Adiador Oleo/Traseira) [Com Suspensão Dianteira] / Hydraulic Oil Line (Oil Cooler/Rear) [With Front Su Spension]
Circuito Oleo Direcção (R Adiador Oleo/Traseira) [Sem Suspensão Dianteira] / Hydraulic Oil Line (Oil Cooler/Rear) [W/O Front Sus Pension]
Radiador Oleo [Com Tdf Di Anteira] / Oil Cooler [With Front Pto]
Circuito Oleo Direcção (F Iltro De Direcção) / Hydraulic Oil Line (Steering F Ilter)
Filtro Oleo 2 [Peças Comp Onentes] / Oil Filter 2 [Component Parts]
Circuito Oleo Direcção (D Irecção Valvula) / Hydraulic Oil Line (Steering Val Ve)
Tubo Da Direção (Fornecim Ento) [Eixo Dianteiro: Tipo Padrão] / Steering Hose (Delivery) [Front Axle:Standard Type]
Tubo Da Direção (Fornecim Ento) [Eixo Dianteiro: Tipo Pesado] / Steering Hose (Delivery) [Front Axle:Heavy Duty Type]
Linha De Óleo Hidráulico (Tubo De Fornecimento Do Eixo Dianteiro/Traseiro) [ Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Padr Ão] / Hydraulic Oil Line (Front Axle Delivery Pipe/ Front) [With Front Suspension] [Front Axle:Standard Type]
Linha De Óleo Hidráulico (Tubo De Fornecimento Do Eixo Dianteiro/Traseiro) [ Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Pesa Do] / Hydraulic Oil Line (Front Axle Delivery Pipe/ Front) [With Front Suspension] [Front Axle:Heavy Du Ty Type]
Linha De Óleo Hidráulico (Tubo De Fornecimento Do Eixo Dianteiro/Traseiro) [ Sem Suspensão Dianteira] [Eixo Dianteiro: Tipo Pesa Do] / Hydraulic Oil Line (Front Axle Delivery Pipe/ Front) [W/O Front Suspension] [Front Axle:Heavy Dut Y Type]
Linha De Óleo Hidráulico (Tubo De Fornecimento Do Eixo Dianteiro/Traseiro) / Hydraulic Oil Line (Front Axle Delivery Pipe/Rear)
Linha De Óleo Hidráulico (Filtro De Óleo) / Hydraulic Oil Line (Oil Filter)
Linha De Óleo Hidráulico (Filtro De Óleo A Válvula De Controlo Remoto/Abertu Ra De Drenagem Hidráulica) [Com Equipamento Do Carr Egador] / Hydraulic Oil Line (Oil Filter To Remote Control Valve/Hyd. Drain Port) [With Loader Equipme Nt]
Linha De Óleo Hidráulico (Filtro De Óleo A Válvula De Controlo Remoto/Abertu Ra De Drenagem Hidráulica) [Sem Equipamento Do Carr Egador] / Hydraulic Oil Line (Oil Filter To Remote Control Valve/Hyd. Drain Port) [W/O Loader Equipmen T]
Linha De Óleo Hidráulico (Tubo Do Travão A Válvula De Controlo Remoto) [Com Suspensão Dianteira] / Hydraulic Oil Line (Brake Pi Pe To Remote Control Valve) [With Front Suspension]
Linha De Óleo Hidráulico (Tubo Do Travão A Válvula De Controlo Remoto) [Sem Suspensão Dianteira] / Hydraulic Oil Line (Brake Pi Pe To Remote Control Valve) [W/O Front Suspension]
Bloco De Válvula 1 (Eixo Tranversal) [Componente De Translaxe] / Valve Block 1 (Transaxle) [Transaxle Component]
Bloco De Válvula 2 (Válvu La Solenóide) [Componente De Translaxe] / Valve Blo Ck 2 (Solenoid Valve) [Transaxle Component]
Axial Bomba [Com Equipame Nto Do Carregador] / Axial Pump [With Loader Equipm Ent]
Axial Bomba [Sem Equipame Nto Do Carregador] / Axial Pump [W/O Loader Equipme Nt]
Tubulação De Bomba Axial [Com Suspensão Dianteira] [Com Equipamento Do Carre Gador] [Com Power Beyond] / Axial Pump Piping [With Front Suspension] [With Loader Equipment] [With Po Wer Beyond]
Tubulação De Bomba Axial [Com Suspensão Dianteira] [Com Equipamento Do Carre Gador] [Sem Power Beyond] / Axial Pump Piping [With Front Suspension] [With Loader Equipment] [W/O Pow Er Beyond]
Tubulação De Bomba Axial [Com Suspensão Dianteira] [Sem Equipamento Do Carre Gador] [Com Power Beyond] / Axial Pump Piping [With Front Suspension] [W/O Loader Equipment] [With Pow Er Beyond]
Tubulação De Bomba Axial [Com Suspensão Dianteira] [Sem Equipamento Do Carre Gador] [Sem Power Beyond] / Axial Pump Piping [With Front Suspension] [W/O Loader Equipment] [W/O Powe R Beyond]
Tubulação De Bomba Axial [Sem Suspensão Dianteira] / Axial Pump Piping [W/O Front Suspension]
Linha De Óleo Hidráulico (Bomba Axial A Válvula De Controlo Remoto) [Com Sus Pensão Dianteira] [Com Equipamento Do Carregador] [ Com Power Beyond] / Hydraulic Oil Line (Axial Pump To Remote Control Valve) [With Front Suspension][Wi Th Loader Equipment][With Power Beyond]
Linha De Óleo Hidráulico (Bomba Axial A Válvula De Controlo Remoto) [Com Sus Pensão Dianteira] [Com Equipamento Do Carregador] [ Sem Power Beyond] / Hydraulic Oil Line (Axial Pump To Remote Control Valve) [With Front Suspension][Wi Th Loader Equipment][W/O Power Beyond]
Linha De Óleo Hidráulico (Bomba Axial A Válvula De Controlo Remoto) [Com Sus Pensão Dianteira] [Sem Equipamento Do Carregador] [ Com Power Beyond] / Hydraulic Oil Line (Axial Pump To Remote Control Valve) [With Front Suspension][Wi Th Loader Equipment][With Power Beyond]
Linha De Óleo Hidráulico (Bomba Axial A Válvula De Controlo Remoto) [Com Sus Pensão Dianteira] [Sem Equipamento Do Carregador] [ Sem Power Beyond] / Hydraulic Oil Line (Axial Pump To Remote Control Valve) [With Front Suspension][W/ O Loader Equipment][W/O Power Beyond]
Linha De Óleo Hidráulico (Bomba Axial A Válvula De Controlo Remoto) [Sem Sus Pensão Dianteira] / Hydraulic Oil Line (Axial Pump To Remote Control Valve) [W/O Front Suspension]
Tubo Da Válvula Da Suspen São Dianteira (Parte Traseira) [Com Suspensão Diant Eira] [Com Saída Hidráulica Dianteira] / Front Susp Ension Valve Pipe (Rear) [With Front Suspension] [W Ith Front Hyd. Outlet]
Válvula Da Suspensão Dian Teira [Com Suspensão Dianteira] / Front Suspension Valve [With Front Suspension]
Valvula Da Suspensão Fron Tal [Peças Componentes][Com Suspensão Dianteira] / Front Suspension Valve [Component Parts][With Front Suspension]
Suspensão Frontal Valvula Tubo (Frente) [Com Suspensão Dianteira] [Eixo Dian Teiro: Tipo Padrão] [Com Saída Hidráulica Dianteira ] / Front Suspension Valve Pipe (Front) [With Front Suspension] [Front Axle:Standard Type] [With Front Hyd. Outlet]
Suspensão Frontal Valvula Tubo (Frente) [Com Suspensão Dianteira] [Eixo Dian Teiro: Tipo Padrão] [Sem Saída Hidráulica Dianteira ] / Front Suspension Valve Pipe (Front) [With Front Suspension] [Front Axle:Standard Type] [W/O Front Hyd. Outlet]
Suspensão Frontal Valvula Tubo (Frente) [Com Suspensão Dianteira] [Eixo Dian Teiro: Tipo Pesado] [Com Saída Hidráulica Dianteira ] / Front Suspension Valve Pipe (Front) [With Front Suspension] [Front Axle:Heavy Duty Type] [With Fro Nt Hyd. Outlet]
Suspensão Frontal Valvula Tubo (Frente) [Com Suspensão Dianteira] [Eixo Dian Teiro: Tipo Pesado] [Sem Saída Hidráulica Dianteira ] / Front Suspension Valve Pipe (Front) [With Front Suspension] [Front Axle:Heavy Duty Type] [W/O Fron T Hyd. Outlet]
Suspensão Frontal Acumula Dor [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / Front Suspension Accumulator [With Front Suspension] [Front Axle:Standard Type]
Suspensão Frontal Cilindr O Tubo [Com Suspensão Dianteira] [Eixo Dianteiro: T Ipo Padrão] / Front Suspension Cylinder Hose [With Front Suspension] [Front Axle:Standard Type]
Suspensão Frontal Cilindr O Tubo [Com Suspensão Dianteira] [Eixo Dianteiro: T Ipo Pesado] / Front Suspension Cylinder Hose [With Front Suspension] [Front Axle:Heavy Duty Type]
Válvula De Controlo Remot O (4 Válvulas) / Remote Control Valve (4 Valves)
Válvula De Controlo Remot O (5 Válvulas) [Com Saída Hidráulica Dianteira] / R Emote Control Valve (5 Valves) [With Front Hyd. Out Let]
Válvula De Controlo Remot O (5 Válvulas) [Sem Saída Hidráulica Dianteira] / R Emote Control Valve (5 Valves) [W/O Front Hyd. Outl Et]
Válvula De Controlo Remot O (6 Válvulas) [Com Saída Hidráulica Dianteira] / R Emote Control Valve (6 Valves) [With Front Hyd. Out Let]
Válvula De Controlo Remot O (6 Válvulas) [Sem Saída Hidráulica Dianteira] / R Emote Control Valve (6 Valves) [W/O Front Hyd. Outl Et]
Válvula De Controlo Remot O (4 Válvulas) [Peças Componentes] / Auxiliary Cont Rol Valve (4 Valves) [Component Parts]
Válvula De Controlo Remot O (5 Válvulas) [Peças Componentes] / Auxiliary Cont Rol Valve (5 Valves) [Component Parts]
Válvula De Controlo Remot O (6 Válvulas) [Peças Componentes] / Auxiliary Cont Rol Valve (6 Valves) [Component Parts]
Válvula De Controle Direc Ional (4 Válvulas) [Peças Componentes] / Directiona L Control Valve (4 Valves) [Component Parts]
Válvula De Controle Direc Ional (5 Válvulas) [Peças Componentes] / Directiona L Control Valve (5 Valves) [Component Parts]
Válvula De Controle Direc Ional (6 Válvulas) [Peças Componentes] / Directiona L Control Valve (6 Valves) [Component Parts]
Válvula Central [Peças Co Mponentes] / Center Valve [Component Parts]
Válvula De Placa End [Peç As Componentes] / End Plate Valve [Component Parts]
Coletor De Óleo (Válvula De Controlo Remoto) [3p] / Oil Collector(Remote Con Trol Valve) [3p]
Coletor De Óleo (Válvula De Controlo Remoto) [4p (5 Válvulas)] / Oil Collect Or(Remote Control Valve) [4p(5 Valves)]
Coletor De Óleo (Válvula De Controlo Remoto) [4p (6 Válvulas)] / Oil Collect Or(Remote Control Valve) [4p(6 Valves)]
Coletor De Óleo (Válvula De Controlo Remoto) [5p] / Oil Collector(Remote Con Trol Valve) [5p]
Tubo Da Saída Hidráulica Dianteira (Parte Traseira) [Com Saída Hidráulica Di Anteira] / Front Hydraulic Outlet Pipe (Rear) [With Front Hyd. Outlet]
Tubo Da Saída Hidráulica Dianteira (Intermédia) [Com Saída Hidráulica Diante Ira] / Front Hydraulic Outlet Pipe (Middle) [With F Ront Hyd. Outlet]
Tubo Da Saída Hidráulica Dianteira (Parte Dianteira) [Com Saída Hidráulica D Ianteira] / Front Hydraulic Outlet Pipe (Front) [Wi Th Front Hyd. Outlet]
Tubo Da Saída Hidráulica (Tubo De Controlo Do Sensor De Carga) [Com Power Be Yond] / Hydraulic Outlet Pipe (Load-Sensing Control Hose) [With Power Beyond]
Tubo Da Saída Hidráulica (Power Beyond/Tubo De Retorno) [Com Power Beyond] / Hydraulic Outlet Pipe (Power Beyond/Return Hose) [ With Power Beyond]
Valvula Travao Reboque / Trailer Brake Valve
Tubo Da Válvula Do Travão De Reboque / Trailer Brake Valve Pipe
Tubo De Óleo Do Carregado R (Parte Traseira) [Com Equipamento Do Carregador] / Front Loader Oil Pipe (Rear) [With Loader Equipme Nt]
Tubo De Óleo Do Carregado R (Parte Dianteira) [Com Equipamento Do Carregador] / Front Loader Oil Pipe (Front) [With Loader Equip Ment]
Compressor De Ar [Com Compres Sor De Ar] / Air Compressor [With Air Compressor]
Compressor De Ar [Peças Compo Nentes][Com Compressor De Ar] / Air Compressor [Com Ponent Parts] [With Air Compressor]
Tubo Do Compressor De Ar [Com Compressor De Ar] / Air Compressor Pipe [With Air Compressor]
Deposito De Ar [Tipo De Suspe Nsão (Ar)] [Com Compressor De Ar] / Air Tank [Suspe Nsion Type (Air)] [With Air Compressor]
Deposito De Ar [Tipo De Suspe Nsão (Mola)] [Com Compressor De Ar] / Air Tank [Sus Pension Type (Spring)] [With Air Compressor]
Valvula De Ar [Com Compressor De Ar] / Air Valve [With Air Compressor]
Valvula De Ar [Peças Componen Tes] [Com Compressor De Ar] / Air Valve [Component Parts] [With Air Compressor]
Valvula De Ar (Reboque) [Com Compressor De Ar] / Air Valve (Trailer) [With Air C Ompressor]
Valvula De Ar (Reboque) [Peça S Componentes] [Com Compressor De Ar] / Air Valve ( Trailer) [Component Parts] [With Air Compressor]
Elo 3p Dianteiro (Elo Estrutura/Superior) [Com Saída Hi Dráulica Dianteira] / Front 3p Link (Frame/Top Link ) [With Front Hyd. Outlet]
Elo 3p Dianteiro (Elo Estrutura/Superior) [Sem Saída Hi Dráulica Dianteira] / Front 3p Link (Frame/Top Link ) [W/O Front Hyd. Outlet]
Elo 3p Dianteiro (Içador) [Com 3p Dianteiro] [Antigo] / Front 3p Link (Lifter) [With Front 3p] [Old]
Elo 3p Dianteiro (Içador) [Com 3p Dianteiro] [Novo] / F Ront 3p Link (Lifter) [With Front 3p] [New]
Liga Ção 3p Dianteira (Cilindro) [Com 3p Dianteiro] [Ant Igo] / Front 3p Link (Cylinder) [With Front 3p] [Ol D]
Liga Ção 3p Dianteira (Cilindro) [Com 3p Dianteiro] [Nov O] / Front 3p Link (Cylinder) [With Front 3p] [New]
Tdf Dianteira [Com Tdf Dianteira] / Front Pto [With Fro Nt Pto]
Caix A Da Engrenagem Tdf 1 (Carreto) [Peças Componentes] [Com Tdf Dianteira] / Pto Gear Case 1 (Gear) [Comp Onent Parts] [With Front Pto]
Caix A Da Engrenagem Tdf 2 (Bomba) [Peças Componentes] [ Com Tdf Dianteira] / Pto Gear Case 2 (Pump) [Compon Ent Parts] [With Front Pto]
Caix A Da Engrenagem Tdf 3 (Embraiagem) [Peças Component Es] [Com Tdf Dianteira] / Pto Gear Case 3 (Clutch) [Component Parts] [With Front Pto]
Caix A Da Engrenagem Tdf 4 (Caixa) [Peças Componentes] [ Com Tdf Dianteira] / Pto Gear Case 4 (Case) [Compon Ent Parts] [With Front Pto]
Caix A Da Engrenagem Tdf 5 (Kit De Juntas E Vedantes) [P Eças Componentes] [Com Tdf Dianteira] / Pto Gear Ca Se 5 (Gasket And Seal Kit) [Component Parts] [With Front Pto]
Supo Rte Do Elo Superior/Suporte Do Acoplador / Top Link Bracket/Coupler Bracket
Liga Ção 3 Pontos (Ligação Superior:Manual) / 3-Point Li Nkage (Top Link:Manual)
Liga Ção 3 Pontos (Ligação Superior:Hidráulica) / 3-Poin T Linkage (Top Link:Hydraulic)
Liga Ção 3 Pontos (Ligação Inferior) / 3-Point Linkage (Lower Link)
Esta Bilizador (Elevador) / Stabilizer(Lifter)
Esta Bilizador (Elevador) [Peças Componentes] / Stabiliz Er (Lifter) [Component Parts]
3-Po Nt Acoplamento (Tirante) / 3-Point Linkage (Lift Ro D)
Ciln Dro Eleveção / Lift Cylinder
Puxo Barra / Drawbar Bracket
Barr A Reboque(Padrão) / Drawbar(Standard)
Barr A Reboque(Fix Piton) / Drawbar(Fix Piton)
Puxo (Dromone) / Hitch (Dromone)
Puxo (Dromone) [Peças Componentes] / Hitch (Dromone) [C Omponent Parts]
Puxo (Dromone) Control Alavanca / Hitch (Dromone) Trail Er Lever
Ganc Ho Trailer (Automatico) / Trailer Clevis (Automatic )
Ganc Ho Trailer (Manual) / Trailer Clevis (Manual)
Capot Inferior (Direito) / Hood (Bonnet) Si De Lower Rh
Capot Inferior (Esquerdo) [Com Compressor D E Ar] / Hood (Bonnet) Side Lower Lh [With Air Compr Essor]
Capot Inferior (Esquerdo) [Sem Compressor D E Ar] / Hood (Bonnet) Side Lower Lh [W/O Air Compre Ssor]
Placa Do Obturador (Silenciador/Isolador) / Shutter Plate (Sound Absorber/Insulator)
Guarda-Lamas Dianteiro (W:540) [Eixo Diante Iro:Tipo Padrão] [Antigo] / Front Fender (W:540) [F Ront Axle:Standard Type] [Old]
Guarda-Lamas Dianteiro (W:540) [Eixo Diante Iro:Tipo Padrão] [Novo] / Front Fender (W:540) [Fro Nt Axle:Standard Type] [New]
Guarda-Lamas Dianteiro (W:540) [Eixo Diante Iro:Tipo Enhancement] / Front Fender (W:540) [Front Axle:Heavy Duty Type]
Estrutura Cabine / Cab Frame
Degrau Direito [Com Equipamento Do Carregador] / S Tep Rh [With Loader Equipment]
Degrau Direito [Sem Equipamento Do Carregador] [Co M Suspensão Dianteira] / Step Rh [W/O Loader Equipm Ent] [With Front Suspension]
Degrau Direito [Sem Equipamento Do Carregador] [Se M Suspensão Dianteira] / Step Rh [W/O Loader Equipm Ent] [W/O Front Suspension]
Degrau Esquerdo / Step Lh
Vidro Frente / Front Glass
Porta Drt / Door Rh
Porta Esq / Door Lh
Vidro Traseiro [Sem Desembaçador] / Hatch Back Gla Ss(Rear Window ) [W/O Defogger]
Tejadilho / Sun Roof
Tecto Interior / Inner Roof
Tecto Abrir [Antiga] / Outer Roof [Old]
Tecto Abrir [Nova] / Outer Roof [New]
Suporte Do Assento / Seat Bracket
Banco / Seat
Banco 1 (Almofada) [Peças Componentes] / Seat1 (Se At Cushion) [Component Parts]
Banco 2 (Apoio Braço/Costas Banco) [Peças Componen Tes] / Seat2 (Armrest/Backrest) [Component Parts]
Suspensão Do Assento [Peças Componentes] / Seat Su Spension [Component Parts]
Banco De Passageiro / Passenger Seat
Tapete Do Piso / Floor Mat
Material À Prova De Som 1 (Painel) / Soundproof Ma Terial 1 (Panel)
Material À Prova De Som 2 (Chão) / Soundproof Mate Rial 2 (Floor)
Material À Prova De Som 3 (Consola) / Soundproof M Aterial 3 (Console)
Material À Prova De Som 4 (Tejadilho) [Nova] / Sou Ndproof Material 4 (Roof) [New]
Cobertura De Mudança (Consola Direita) / Shift Cov Er (Console Rh)
Tampa Do Rádio E Tampa Do Painel De Controlo Do Ar Condicionado / Radio Cover And Air Conditioner Con Trol Panel Cover
Consola (Esq)[Com Banco De Passageiro] / Console ( Lh)[With Passenger Seat]
Resguardo Coluna / Pillar Cover
Cobertura Do Guarda-Lamas / Fender Cover
Guarda Lamas (Direito) / Fender Rh
Guarda Lamas (Esquerda) / Fender Lh
Guarda Lamas / Over Fender
Suporte Cabine Frente [Com Equipamento Do Carregad Or] / Cab Bracket Front [With Loader Equipment]
Suporte Cabine Frente [Sem Equipamento Do Carregad Or] / Cab Bracket Front [W/O Loader Equipment]
Suporte Cabine Traseira / Cab Bracket Rear
Amortecedor Traseiro [Tipo De Suspensão (Ar)] [Com Compressor De Ar] / Rear Damper [Suspension Type ( Air)] [With Air Compressor]
Traseira Amortecedor [Tipo De Suspensão (Mola)] / Rear Damper [Suspension Type (Spring)]
Caixa De Ferramentas [Com Equipamento Do Carregado R] / Tool Box [With Loader Equipment]
Caixa De Ferramentas [Sem Equipamento Do Carregado R] / Tool Box [W/O Loader Equipment]
Ar Condicionado / Air Conditi Oner
Conduta Do Ar Condicionado (A R Frio) / Air Conditioner Duct (Fresh Air)
Conduta Do Ar Condicionado (T Raseira) / Air Conditioner Duct (Rear)
Modo Caixa / Mode Case
Entradas Ar Painel Instrument Os / Dashboard Air Outlets
Circulaçao Ar Interior / Inne R Air Recirculation
Tubo Aquecimento / Heater Hos E
Tubo Ar Condicionado/Tubo Con Densador / Air Conditioner Hose/Condenser Hose
Polia De Acionamento Do Compr Essor [Com Compressor De Ar] / Compressor Drive Pul Ley [With Air Compressor]
Polia De Acionamento Do Compr Essor [Sem Compressor De Ar] / Compressor Drive Pul Ley [W/O Air Compressor]
Compressor (Ar Condicionado) / Compressor (Air Conditioner)
Roda Dianteira (380/85r28:8 Burac O Jante) [Michelin] / Front Wheel (380/85r28:8 Hole S Rim) [Michelin]
Roda Dianteira (380/85r28:8 Burac O Jante) [Trelleborg] / Front Wheel (380/85r28:8 Ho Les Rim) [Trelleborg]
Roda Dianteira (380/85r28:8 Burac O Jante) [Firestone] / Front Wheel (380/85r28:8 Hol Es Rim) [Firestone]
Roda Dianteira (380/85r28:8 Burac O Jante) [Mitas] / Front Wheel (380/85r28:8 Holes R Im) [Mitas]
Roda Dianteira (420/70r28:8 Burac O Jante) [Michelin] / Front Wheel (420/70r28:8 Hole S Rim) [Michelin]
Roda Dianteira (420/70r28:8 Burac O Jante) [Trelleborg] / Front Wheel (420/70r28:8 Ho Les Rim) [Trelleborg]
Roda Dianteira (420/70r28:8 Burac O Jante) [Firestone] / Front Wheel (420/70r28:8 Hol Es Rim) [Firestone]
Roda Dianteira (420/70r28:8 Burac O Jante) [Mitas] / Front Wheel (420/70r28:8 Holes R Im) [Mitas]
Roda Dianteira (420/85r28:8 Burac O Jante) [Michelin] / Front Wheel (420/85r28:8 Hole S Rim) [Michelin]
Roda Dianteira (420/85r28:8 Burac O Jante) [Firestone] / Front Wheel (420/85r28:8 Hol Es Rim) [Firestone]
Roda Dianteira (420/85r28:8 Burac O Jante) [Mitas] / Front Wheel (420/85r28:8 Holes R Im) [Mitas]
Roda Dianteira (480/70r28:8 Burac O Jante) [Michelin] / Front Wheel (480/70r28:8 Hole S Rim) [Michelin]
Roda Dianteira (480/70r28:8 Burac O Jante) [Trelleborg] / Front Wheel (480/70r28:8 Ho Les Rim) [Trelleborg]
Roda Dianteira (480/70r28:8 Burac O Jante) [Mitas] / Front Wheel (480/70r28:8 Holes R Im) [Mitas]
Roda Dianteira (540/65r28:8 Burac O Jante) [Michelin] / Front Wheel (540/65r28:8 Hole S Rim) [Michelin]
Roda Dianteira (540/65r28:8 Burac O Jante) [Trelleborg] / Front Wheel (540/65r28:8 Ho Les Rim) [Trelleborg]
Roda Dianteira (540/65r28:8 Burac O Jante) [Firestone] / Front Wheel (540/65r28:8 Hol Es Rim) [Firestone]
Roda Dianteira (540/65r28:8 Burac O Jante) [Mitas] / Front Wheel (540/65r28:8 Holes R Im) [Mitas]
Roda Dianteira (380/85r28:10 Bura Co Jante) [Michelin] / Front Wheel (380/85r28:10 Ho Les Rim) [Michelin]
Roda Dianteira (380/85r28:10 Bura Co Jante) [Trelleborg] / Front Wheel (380/85r28:10 Holes Rim) [Trelleborg]
Roda Dianteira (380/85r28:10 Bura Co Jante) [Firestone] / Front Wheel (380/85r28:10 H Oles Rim) [Firestone]
Roda Dianteira (420/70r28:10 Bura Co Jante) [Michelin] / Front Wheel (420/70r28:10 Ho Les Rim) [Michelin]
Roda Dianteira (420/70r28:10 Bura Co Jante) [Trelleborg] / Front Wheel (420/70r28:10 Holes Rim) [Trelleborg]
Roda Dianteira (420/70r28:10 Bura Co Jante) [Firestone] / Front Wheel (420/70r28:10 H Oles Rim) [Firestone]
Roda Dianteira (420/70r28:10 Bura Co Jante) [Mitas] / Front Wheel (420/70r28:10 Holes Rim) [Mitas]
Roda Dianteira (420/85r28:10 Bura Co Jante) [Michelin] / Front Wheel (420/85r28:10 Ho Les Rim) [Michelin]
Roda Dianteira (420/85r28:10 Bura Co Jante) [Trelleborg] / Front Wheel (420/85r28:10 Holes Rim) [Trelleborg]
Roda Dianteira (420/85r28:10 Bura Co Jante) [Firestone] / Front Wheel (420/85r28:10 H Oles Rim) [Firestone]
Roda Dianteira (420/85r28:10 Bura Co Jante) [Mitas] / Front Wheel (420/85r28:10 Holes Rim) [Mitas]
Roda Dianteira (480/70r28:10 Bura Co Jante) [Michelin] / Front Wheel (480/70r28:10 Ho Les Rim) [Michelin]
Roda Dianteira (480/70r28:10 Bura Co Jante) [Trelleborg] / Front Wheel (480/70r28:10 Holes Rim) [Trelleborg]
Roda Dianteira (480/70r28:10 Bura Co Jante) [Firestone] / Front Wheel (480/70r28:10 H Oles Rim) [Firestone]
Roda Dianteira (480/70r28:10 Bura Co Jante) [Mitas] / Front Wheel (480/70r28:10 Holes Rim) [Mitas]
Roda Dianteira (540/65r28:10 Bura Co Jante) [Michelin] / Front Wheel (540/65r28:10 Ho Les Rim) [Michelin]
Roda Dianteira (540/65r28:10 Bura Co Jante) [Trelleborg] / Front Wheel (540/65r28:10 Holes Rim) [Trelleborg]
Roda Dianteira (540/65r28:10 Bura Co Jante) [Firestone] / Front Wheel (540/65r28:10 H Oles Rim) [Firestone]
Roda Dianteira (540/65r28:10 Bura Co Jante) [Mitas] / Front Wheel (540/65r28:10 Holes Rim) [Mitas]
Roda Traseira (460/85r38) [Michel In] / Rear Wheel (460/85r38) [Michelin]
Roda Traseira (460/85r38) [Trelle Borg] / Rear Wheel (460/85r38) [Trelleborg]
Roda Traseira (460/85r38) [Firest One] / Rear Wheel (460/85r38) [Firestone]
Roda Traseira (460/85r38) [Mitas] / Rear Wheel (460/85r38) [Mitas]
Roda Traseira (520/70r38) [Michel In] / Rear Wheel (520/70r38) [Michelin]
Roda Traseira (520/70r38) [Trelle Borg] / Rear Wheel (520/70r38) [Trelleborg]
Roda Traseira (520/70r38) [Firest One] / Rear Wheel (520/70r38) [Firestone]
Roda Traseira (520/85r38) [Michel In] / Rear Wheel (520/85r38) [Michelin]
Roda Traseira (520/85r38) [Trelle Borg] / Rear Wheel (520/85r38) [Trelleborg]
Roda Traseira (520/85r38) [Firest One] / Rear Wheel (520/85r38) [Firestone]
Roda Traseira (520/85r38) [Mitas] / Rear Wheel (520/85r38) [Mitas]
Roda Traseira (580/70r38) [Michel In] / Rear Wheel (580/70r38) [Michelin]
Roda Traseira (580/70r38) [Trelle Borg] / Rear Wheel (580/70r38) [Trelleborg]
Roda Traseira (580/70r38) [Firest One] / Rear Wheel (580/70r38) [Firestone]
Roda Traseira (580/70r38) [Mitas] / Rear Wheel (580/70r38) [Mitas]
Roda Traseira (650/65r38) [Michel In] / Rear Wheel (650/65r38) [Michelin]
Roda Traseira (650/65r38) [Trelle Borg] / Rear Wheel (650/65r38) [Trelleborg]
Roda Traseira (650/65r38) [Firest One] / Rear Wheel (650/65r38) [Firestone]
Roda Traseira (650/65r38) [Mitas] / Rear Wheel (650/65r38) [Mitas]
Decalcomania(Painel/Cobertura De Mudança) / Label (Panel/Shift Cover)
Etiqueta (Unidade Control Electrico/Controla Dor) / Label (Ecu/Controller)
Decalcomania (Cabine Interior) / Label (Cab Interior)
Acessorios / Accessories
Kit Alternador (200a) [Opção] / Alternator Kit ( 200a) [Option]
Alternador [Peças Componentes] (200a) [Opção] / Alternator [Component Parts] (200a) [Option]
Luzes Frente (Farol De Repetição) [Opçao] / Head Light Kit (Repeat Head Light) [Option]
Kit Da Tdf Dianteira (6 Estrias) (Caixa Da Engre Nagem) [Opção] / Front Pto Kit (6 Splines) (Gear Ca Se) [Option]
Kit Da Tdf Dianteira (6 Estrias) (Arrefecedor Do Óleo) [Opção] / Front Pto Kit (6 Splines) (Oil Coo Ler) [Option]
Kit Do Terminal (12 Polegadas) [Sem Direção Auto Mática] [Opção] / Terminal Kit (12 Inch) [Auto Stee Ring Incompatible] [Option]
Kit Do Sensor (Radar) [Opção] / Sensor Kit (Rada R) [Option]
Kit Sensor [Eixo Dianteiro: Tipo Padrão] [Opção] / Sensor Kit [Front Axle:Standard Type] [Option] # # N.º De Série<=30346 S.No.;<=30346 / S.No.<=30346 S.No.;<=30346
Kit Da Câmara [Opção] / Camera Kit [Option]
Kit De Antena (Modem Rtk De Direção Automática) (Antena) [Opçao] / Anntena Kit (Auto Steer Rtk Mode M) (Anntena) [Option]
Kit De Antena (Direção Automática Dgps/Sem Rtk) [Opçao] / Anntena Kit (Auto Steer Dgps/Without Rtk) [Option]
Kit De 21 Estrias De Tdf [Opção] / Pto Kit (21 S Plines) [Option]
Kit De Acoplador (Saída Hidráulica Dianteira/Elé Trica 6ª) (Tubo) [Opção] / Coupler Kit (Front Hyd. Outlet/Elec.6th) (Pipe) [Option]
Kit De Acoplador (Saída Hidráulica Dianteira/Elé Trica 6ª) (Acoplador/Tubo) [Opção] / Coupler Kit (F Ront Hyd. Outlet/Elec.6th) (Coupler/Pipe) [Option]
Kit De Acoplador Powr Beyond (Acoplador) [Opção] / Power Beyond Coupler Kit (Coupler) [Option]
Kit De Acoplador Powr Beyond (Tubo/Acoplador) [O Pção] / Power Beyond Coupler Kit (Pipe/Coupler) [Op Tion]
Kit Do Reboque (Pistão) [Opção] / Trailer Kit (P Iton) [Option]
Kit Do Reboque (K80) [Opção] / Trailer Kit (K80) [Option]
Kit Da Ligação 3-P Dianteira (Elétrica 5ª) (Válv Ula) [Opção] / Front 3p Link Kit (Elec.5th) (Valve) [Option]
Kit Da Ligação 3-P Dianteira (Elétrica 6ª) (Válv Ula) [Opção] / Front 3p Link Kit (Elec.6th) (Valve) [Option]
Kit De Suporte Da Escora [Opção] / Drawbar Brack Et Kit [Option]
Kit De Escora (Acoplamento K80) [Opção] / Drawba R Kit (Coupling K80) [Option]
Kit Do Guarda-Lamas Dianteiro (W:410) [Eixo Dian Teiro:Tipo Padrão] [Antigo] / Front Fender Kit (W:4 10) [Front Axle:Standard Type] [Old]
Kit Do Guarda-Lamas Dianteiro (W:410) [Eixo Dian Teiro:Tipo Padrão] [Novo] / Front Fender Kit (W:410 ) [Front Axle:Standard Type] [New]
Kit Do Guarda-Lamas Dianteiro (W:410) [Eixo Dian Teiro: Tipo Pesado] [Opção] / Front Fender Kit (W:4 10) [Front Axle:Heavy Duty Type] [Option]
Kit De Espelho (Calor) [Opção] / Mirror Kit (Hea T) [Option]
