118
6,911
Kubota Tractor M7132SC Spare Parts Catalog EN TR
Language: English, Turkish
Region: Turkey
Model: Kubota M7132SC Tractor
Number of Pages: 1256 Pages
Engine 400100 Engine Block (Upper) Crankcase (Upper)
Engine 400200 Engine Block (Lower) Crankcase (Lower)
Engine 401001 Oil Pan Without Air Compressor W O Air Compressor
Engine 401002 Oil Pan With Air Compressor
Engine 402000 Cylinder Head
Engine 403000 Inlet And Exhaust Valve Vana Inlet
Engine 404000 Rocker Arm Shaft
Engine 405000 Head Cover
Engine 410000 Front Cover
Engine 411000 Piston And Crankshaft
Engine 412000 Camshaft And Idle Gear
Engine 413000 Balancer
Engine 415000 Flywheel
Engine 420000 Fuel Filter
Engine 421000 Feed Pump Supply Pump
Engine 425000 Injector And Glow Plug
Engine 426000 Injection Pipe
Engine 428000 Common Rail
Engine 430000 Thermostat Water Flange And Thermostat
Engine 431000 Water Pump
Engine 435000 Oil Cooler
Engine 436000 Oil Separator
Engine 436300 Oil Separator Component Parts Oil
Engine 436500 Oil Separator Pipe
Engine 437000 Oil Pipe (Turbo Charger)
Engine 440001 Air Cleaner Without Front PTO Air Cleaner W O Front
Engine 440002 Air Cleaner With Front PTO Air Cleaner With Front Pto
Engine 440500 Air Cleaner Component Parts
Engine 441501 Inlet Pipe (Air Cleaner) Without Air Compressor Inlet Pipe (Air Cleaner)
Engine 441502 Inlet Pipe (Air Cleaner) With Air Compressor Inlet Pipe (Air Cleaner)
Engine 442000 Turbocharger Turbo Charger
Engine 444000 Inlet Manifold
Engine 445000 Air Filter Flange And Throttle Valve And Throttle
Engine 446000 EGR Valve
Engine 447000 EGR Cooler
Engine 448000 EGR Water System Piping EGR Water Piping
Engine 450000 Exhaust Manifold
Engine 455000 Diesel Particulate Filter Absorber Diesel Particulate Filter
Engine 455500 Diesel Particulate Filter Absorber Component Parts Filter
Engine 457500 Pressure Pipe
Engine 459000 Sound Absorber Pipe Muffler Pipe
Engine 460000 Selective Catalytic Reduction Muffler Reduction
Selector Catalytic Reduction Cover Old Selective Catalytic Reduction Cover Old Chassis No.
Selector Catalytic Reduction Cover New Selective Catalytic Reduction Cover New Chassis No.
Engine 465300 Sound Absorber Pipe And Cover Muffler Pipe And Cover
Engine 470000 Diesel Exhaust Fluid Pump Diesel
Engine 471000 Diesel Exhaust Fluid Tank Diesel
Engine 471500 Diesel Exhaust Fluid Tank Component Parts Diesel
Engine 472000 Diesel Exhaust Fluid Hose
Engine 472500 Diesel Exhaust Fluid Heater Hose Diesel Exhaust Fluid Heater
Engine 472700 Diesel Exhaust Fluid Air Hole Hose Diesel Exhaust Fluid Breather
Engine 473000 EGR Valve (Selector Catalyst Reduction System) EGR Valve (Selective Catalytic
Engine 474000 EGR Cooler (Selector Catalyst Reduction System) EGR Cooler (Selective
Engine 475000 EGR Pipe (Selector Catalyst Reduction System) EGR Pipe (Selective Catalytic
Engine 476000 EGR Water System Piping (Selector Catalyst Reduction System) EGR Water Piping (
Engine 480000 Exhaust Manifold Cover EGR Cover Exhaust Manifold Cover EGR
Engine 495000 Engine Electrical Parts (Sensor ECu)
Engine 496000 Engine Electrical Parts (Sound Absorber) Engine Electrical Parts
Engine 497000 Injector Harness
Engine A03000 Accelerator Pedal
Fuel System A11001 Fuel Tank Old Fuel Tank Old Chassis No. 30519 S.No. 30519 S.
Fuel System A11002 Fuel Tank New Fuel Tank New Chassis No. 30520 S.No. 30520 S.
Fuel System A11501 Fuel Tank Bracket With Loading Equipment Fuel Tank Bracket
Fuel System A11502 Fuel Tank Bracket Without Loading Equipment Fuel Tank Bracket
Fuel System A14100 Fuel Pipe (Fuel Filter)
Fuel System A14200 Fuel Pipe (Fuel Pump) Fuel Pipe (Fuel
Fuel System A14400 Fuel Pipe (Fuel Cooler)
Fuel System A14500 Fuel Cooler
Fuel System A15100 Separator
Fuel System A16100 Separator Component Parts
Fuel System A16500 Fuel Pump Fuel Pump
Fuel System A16600 Fuel Pump Component Parts
Fuel System A17000 Fuel Filter
Fuel System A18000 Fuel Filter Component Parts
Cooling Water System A40500 Fan Bracket Fan Bracket
Cooling Water System A40700 Fan Drive Pulley
Cooling Water System A41000 Fan
Cooling Water System A42500 Water Pipe And Cooler Pipe Water Pipe
Cooling Water System A46000 Air Conditioner Cooler Unit
Cooling Water System A46200 Cooling Unit (Radiator) Component Parts Cooler
Water System Cooling Water System A46300 Cooling Unit (Intercooler) Component Parts Cooler
Water System Cooling Water System A46400 Cooling Unit (Oil Cooler) Component Parts Cooler
Water System Cooling Water System A46500 Cooling Unit (Condenser) Component Parts Cooler
Cooling Water System A47500 Reserve Tank
Water System Cooling Water System A47701 Reserve Tank Hose Air Compressor Without Reserve
Water System Cooling Water System A47702 Reserve Tank Hose With Air Compressor Reserve
Electrical System A54001 Alternator (200a) Alternator (200a)
Electrical System A54002 Alternator (150a) Alternator (150a)
Electrical System A55001 Alternator (200a) Component Parts Alternator (200a)
Electrical System A55002 Alternator (150a) Component Parts Alternator (150a)
Electrical System A56000 Starter
Electrical System A57000 Starter Component Parts
Electrical System A58000 Battery
Electrical System A59000 Battery Bracket Battery Bracket
Electrical System B00200 Switch Sensor (Engine Left Side) Switch Sensor
Electrical System B00300 Switch Sensor (Engine Right Side) Switch Sensor
Electrical System B00400 Selector Catalyst Reduction Sensor Selective Catalytic
Electrical System B00900 Front Suspension Sensor Front Suspension
Electrical System B01000 Sensor(Pedal) Sensor(Pedal)
Electrical System B01501 Switch Sensor Without Air Compressor Switch Sensor
Electrical System B01502 Switch Sensor With Air Compressor Switch Sensor
Electrical System B02000 Sensor Regulator (Clamp Housing Gearbox Housing) Sensor Regulator
Pump Housing PTO Shaft Housing) Oc Type Sensor Valve (Hydraulic Pump Housing PTO Shaft Housing) Oc Type
Pto Shaft Housing) Ccls Type Sensor Valve (Hydraulic Pump Housing PTO Shaft Housing) Ccls Type Note
Electrical System B03501 Flow Sensor 3p Sensor Connection (Stair) With Draft Sensor
Electrical System B03502 Flow Sensor 3p Sensor Connection (Dromone) With Draft Sensor
Electrical System B04000 Switch (Front 3p Connection) Front 3p With Switch (Front 3p
Electrical System B10400 Switch (Control Panel) Switch (Panel
Electrical System B11301 Switch (Steering) Incompatible Auto Steering Switch (Steering)
Electrical System B11702 Switch (Slide Cover) Switch (Shift
Electrical System B11800 Switch (Console, Left Side) Switch (Console
Electrical System B12802 External Switch
Electrical System B13200 Relay Controller Relay Controller
Electrical System B13300 ECu (Engine) Electronic Control Unit (
Electrical System B13401 ECu Control Without Air Compressor Electronic Control Unit
Electrical System B13402 ECu Control With Air Compressor Electronic Control Unit
Electrical System B13700 Control (CEU) Controller (CEU)
Electrical System B13800 Control (CEU) Component Parts Controller (CEU)
Electrical System B14000 Dashboard Panel
B17002 Cab Inner Rear Electrical Parts (Electrical Outlet Air Conditioning Control Panel) Cab Inner Rear
Electrical System B18105 Armrest Front Without PTO Armrest W O
Electrical System B18106 Armrest Front PTO With Armrest With
Electrical System B32000 Exterior Light Head Light
Electrical System B32300 Headlight (Band) Repeater Light With Headlight (Pillar)
Electrical System B33600 Beacon Lamp
B33801 Side Marker Lamp With Work Light(Band) New Lamp Of Side Marker With Work Light(Pillar)
Electrical System B33900 Front Combination Headlight Front Combination
Electrical System B35000 Work Light (Front Ceiling) Work Light (Front
Electrical System B35200 Work Light (Front Pillar) With Work Light (Pillar) Work Light (
Electrical System B35300 Work Light (Rear Ceiling) Work Light (Rear
Electrical System B35400 Work Light (Rear Pillar) With Work Light (Pillar) Work Light (
Electrical System B36000 Rear Combination Headlight
Electrical System B36500 License Lamp
Electrical System B37001 Trailer Socket 2-Line 1+2-Line Trailer Brake Trailer Socket
Electrical System B37002 Trailer Socket 1-Line Trailer Brake Trailer Socket
Electrical System B41000 Interior Lighting Room Light
Electrical System B42500 Radio Speaker Radio Speaker
Electrical System B43000 Washer Tank Washer Tank
Electrical System B44000 Wiper Wiper
Electrical System B60000 Electrical Cables (Motor) 1 (Air Cleaner Dpf) Electrical
Electrical System B60500 Electrical Cables (Motor) 2 (Crs) Electrical Wiring
Electrical System B61000 Electrical Cables (Motor) 3 (Petrol Scr) Electrical
Electrical System B61500 Electrical Cables (Engine) 4 (Fuse Battery) Electrical Wiring
System B62001 Electrical Cables (Engine) 5 (Compressor Flywheel) Without Air Compressor Electrical Wiring
System B62002 Electrical Cables (Engine) 5 (Compressor Flywheel) With Air Compressor Electrical Wiring
Electrical System B65000 Electrical Cables (Bone) Electrical Wiring
Electrical System B65501 Electrical Cables (Alternator 200a) Electrical Wiring
Electrical System B65502 Electrical Wiring (Alternator 150a) Electrical Wiring
Electrical System B66000 Electrical Wiring (Starter) Electrical Wiring
Electrical System B67000 Electrical Wiring (Power Supply) Control (CEU)) Electrical Wiring
Electrical System B70001 Electrical Wiring (Transaxial Front) Without Air Compressor Electrical
Electrical System B70002 Electrical Wiring (Transaxial Front) With Air Compressor Electrical Wiring
System B71000 Electrical Wiring (Transaxial Rear) Old Electrical Wiring (Transaxle Rear) Old
System B71001 Electrical Cables (Transaxle Rear) New Electrical Wiring (Transaxle Rear) New
Electrical System B75002 Electrical Cables (Remote Control Valve) Electrical Wiring
Electrical System B76000 Harness,Wire(Etcv Valve Dryer) With Air Compressor Electrical Wiring (
Electrical System B80000 Electrical Cables (Cabin) 1 (Steering Panel) Electrical
Electrical System B80500 Electrical Cables (Cabin) 2 (ECu) Electrical Wiring
Electrical System B81002 Electrical Cables (Cabin) 3 (Gear Cover Armrest) Electrical
Electrical System B81501 Electrical Cables (Cabin) 4 (Air Conditioning) 50km S Model Electrical Wiring (
Electrical System B81502 Electrical Cables (Cabin) 4 (Air Conditioning) 40km S Model Electrical Wiring (
Electrical System B85000 Electrical Cables (Front Pillar) Old Electrical Wiring (Front Pillar) Old Chassis
System B85001 Electrical Cables (Front Pillar) New Electrical Wiring (Front Pillar) New
Electrical System B85500 Electrical Cables (Roof) Electrical Wiring
Electrical System B86002 Electrical Cables (Flasher Fender) Electrical Wiring
Electrical System B86500 Wire Harness Front 3p With Old Electrical Wiring With Front 3p Old Chassis No.
Electrical System B86501 Wire Harness Front 3p With New Electrical Wiring With Front 3p New Chassis No.
Electrical System B87000 Electrical Cables (Front Suspension) Electrical Wiring
Clutch Gear Clutch Transmission C50000 Damper Disk And Case Connection Damper Disk And
Clutch Gear Clutch Transmission C52500 Clutch Housing
Clutch Gear Clutch Transmission C53000 Gear Case Transmission Housing
Clutch Gear Clutch Transmission C54000 Rear Axle Housing
Clutch Gear Clutch Transmission C54500 PTO Shaft Housing PTO Shaft Housing
Clutch Gear Clutch Transmission C55000 Lift Arm
Clutch Gear Clutch Transmission C60100 Counter Shaft Countershaft
Clutch Gear Clutch Transmission C60201 Main Shaft
Clutch Gear Clutch Transmission C60300 PTO Drive Shaft PTO Drive Shaft
Clutch Gear Clutch Transmission C60400 Creep Gear
Clutch Gear Clutch Transmission C60600 Front Clutch Front Clutch
Clutch Gear Clutch Transmission C60801 Power Shift Power Shift
Clutch Gear Clutch Transmission C60900 Hydraulic Clutch (Input) Hydraulic Clutch
Clutch Gear Clutch Transmission C61000 Hydraulic Clutch (Output) Hydraulic Clutch
Clutch Gear Clutch Transmission C61100 Power Input Shaft Power Input Shaft
Clutch Gear Clutch Transmission C61201 Main Clutch Main Clutch
Clutch Gear Clutch Transmission C61301 Changer 1 Shifter 1
Clutch Gear Clutch Transmission C61500 Changer 2 (Creep) Shifter 2 (
Clutch Gear Clutch Transmission C62000 PTO Shaft Inner Housing (Clutch) PTO Shaft Housing
Clutch Gear Clutch Transmission C62300 PTO Shaft Inner Case (Transmission) PTO Shaft Housing
Clutch Gear Clutch Transmission C62500 PTO Shaft Inner Case (Pto Shaft) PTO Shaft Housing
Clutch Gear Clutch Transmission C62700 PTO Shaft Inner Case (Sliding Fork) PTO Shaft Housing
Clutch Gear Clutch Transmission C73100 Pressure Valve Pressure Valve
Clutch Gear Clutch Transmission C73200 Transmission Sliding Case Gear Shift
Clutch Gear Clutch Transmission C75000 Clutch Pedal
Gear Lever Shift Lever E51000 Shuttle Shift Lever
Gear Lever Shift Lever E52000 Creep Gear Shift Lever
Gear Lever Shift Lever E53002 PTO Gear Shift Lever
Rear Axle Brake F70000 Rear Axle
Rear Axle Brake F70500 Rear Differential
Rear Axle Brake F74000 Brake
Rear Axle Brake F75000 Brake Shaft
Rear Axle Brake F80000 Parking Brake Lever
Rear Axle Brake F81000 Brake Pedal
Rear Axle Brake F82000 Brake Master Cylinder Brake Master Cylinder
Brake Rear Axle Brake F83001 Brake Pipe 1 (Upper Front) 2-Line 1+2-Line Trailer Brake Brake Pipe 1 (Upper
Axle Brake Rear Axle Brake F83002 Brake Pipe 1 (Upper Front) 1-Line Trailer Brake Brake Pipe 1 (Upper
Axle Brake Rear Axle Brake F83501 Brake Pipe 2 (Lower Rear) 1+2-Line Trailer Brake Brake Pipe 2 (Lower
Brake Rear Axle Brake F83502 Brake Pipe 2 (Lower Rear) 1-Line 2-Line Trailer Brake Brake Pipe 2 (Lower
Frame Front Axle Chassis G10503 Front Axle Frame Front Suspension With Front 3p With Front Axle Frame
Front Axle Chassis G10504 Front Axle Frame With Front Suspension With Front 3p Without Front Axle Frame
Front Axle Chassis G51000 Front Loader Chassis With Loading Equipment Front Loader
Front Axle Chassis G51500 Front Weight Bumper Front Without Front 3p Front Weight
G52001 Front Suspension Rocker Arm Front With 3p Old Front Suspension Rocker Arm With Front
G52002 Front Suspension Rocker Arm Front With New Front Suspension Rocker Arm With Front
G52003 Front Suspension Clutch Arm Front Without 3p Old Front Suspension Rocker Arm W O Front
G52004 Front Suspension Clutch Arm Front Without 3p New Front Suspension Rocker Arm W O Front
Front Axle Chassis G52500 Front Guard Front Without 3p Front Guard W
Front Axle Chassis G53001 Front Axle With Front Suspension Front Axle With
Axle Chassis G53501 Front Axle Body Bracket Front Axle Component Front Suspension With Front Axle Bracket
Front Axle Chassis G54000 Front Axle Case Front Axle Component Front Axle Housing
Front Axle Chassis G54500 Front Differential Front Axle Component Front Differential
Axle Frame Front Axle Chassis G55000 Differential Transmission Shaft Front Axle Component Differential Gear
Frame Front Axle Chassis G55500 Wheel Angle Sensor Front Axle Component Wheel Turning
Frame Front Axle Chassis G56000 Connection Rod Steering Cylinder Front Axle Component Tie Rod Steering
Frame Front Axle Chassis G57001 Propeller Shaft And Cover Front Suspension With Propeller Shaft
Steering H11000 Steering Wheel
Steering H11200 Steering Assembly Component Parts Steering Post Component
Steering H12000 Slip Pedal Tilt Pedal
Steering H14001 Steering Control Incompatible Auto Steering Controller
Hydraulic System J12800 Hydraulic Pump Housing Hydraulic Pump
Hydraulic System J13000 Hydraulic Pump
Hydraulic System J13800 Hydraulic Pump Gear Filter Hydraulic Pump
Hydraulic System J14200 Hydraulic Oil Line (Transex) Hydraulic Oil
Hydraulic System J62000 Hydraulic Oil Line (Oil Cooler Front) Hydraulic Oil Line
Hydraulic System J62500 Hydraulic Oil Line (Oil Cooler Rear) Hydraulic Oil
Hydraulic System J63000 Oil Cooler Front PTO With Oil Cooler With
System J64001 Hydraulic Oil Line (Steering Valve Filter) Without Air Compressor Hydraulic
Hydraulic System J64002 Hydraulic Oil Line (Steering Valve Filter) With Air Compressor Hydraulic Oil
Hydraulic System J64500 Oil Filter 2 Component Parts Oil Filter 2
Hydraulic System J64700 Hydraulic Oil Line (Steering Valve) Hydraulic Oil
Hydraulic System J65001 Steering Hose (Deliver) Front Suspension With Steering Hose (
Hydraulic System J66000 Hydraulic Oil Line (Front Axle Feed Pipe Front) Hydraulic Oil Line
Hydraulic System J66500 Hydraulic Oil Line (Front Axle Feed Pipe Rear) Hydraulic Oil Line
Hydraulic System J68001 Hydraulic Oil Line (Oil Filter) 2-Line 1+2-Line Trailer Brake Hydraulic Oil
Hydraulic System J68002 Hydraulic Oil Line (Oil Filter) 1-Line Trailer Brake Hydraulic Oil
Port) 50km S Model 2-Line 1+2-Line Trailer Brake Loading Equipment With Power Beyond Hydraulic
Port) 50km S Model 2-Line 1+2-Line Trailer Brake Loading Without Power Beyond With Equipment
Port) 50km H Model 2-Line 1+2-Line Trailer Brake Without Loading Equipment Without Power Beyond
Valve Hydraulic To Discharge Port) 1-Line Trailer Brake Without Loading Equipment With Power Beyond With Hydraulic
Valve Hydraulic To Discharge Port) 1-Line Trailer Brake Without Loading Equipment Without Power Beyond Hydraulic
Hydraulic System J69002 Hydraulic Oil Line (Brake Pipe To Remote Control Valve) Hydraulic
Hydraulic System J69300 Valve Block 1 (Transaxs) Valve Block 1 (
Hydraulic System J69500 Valve Block 2 (Solenoid Valve) Valve Block 2 (
Ccls Type With Loading Equipment Axial Pump Ccls Type With Loader Equipment Not Ccls.....Load Sensing
Ccls Type Without Loading Equipment Axial Pump Ccls Type W O Loader Equipment Not Ccls.....Load Sensing
System J70102 Axial Pump Pipe Ccls Type With Loading Equipment With Power Beyond Axial Pump Piping
System J70103 Axial Pump Pipe Ccls Type With Loading Equipment Without Power Beyond Axial Pump
Without Power Beyond With Equipment Ccls Type W O Loader Equipment With Power Beyond
Oil Filter Oc Type With Loading Equipment Hydraulic Pump And Oil Filter Oc Type With Loader Equipment
Filter Oc Type Without Loading Equipment Hydraulic Pump And Oil Filter Oc Type W O Loader Equipment
Without Power Beyond Equipment Hydraulic Oil Line (Axial Pump To Remote Control Valve) Ccls Type
Hydraulic Oil Line (Axial Pump To Remote Control Valve) Ccls Type Without Loading Equipment
With Power Beyond Hydraulic Oil Line (Axial Pump To Remote Control Valve) Ccls Type
Control Valve) Oc Type With Front Suspension Valve Pipe (Remote Control Valve) Oc Type
Front Suspension Valve Pipe (Remote) Without Oc Type Loading Equipment Control Valve) Oc
Pipe (Rear) Oc Type Front Hyd. Without Outlet Front Suspension Valve Pipe (Rear) Oc Type W O Front Hyd.
Front Suspension Valve Pipe (Rear) Oc Type With Front Hyd. Outlet
Front Suspension Valve Pipe (Rear) Ccls Type With Front Hyd. Outlet Note
Ccls Type Front Hyd. Without Outlet Front Suspension Valve Pipe (Rear) Ccls Type W O Front Hyd. Outlet
Hydraulic System J72000 Front Suspension Valve Front Suspension
Hydraulic System J72200 Front Suspension Valve Component Parts Front Suspension
Hydraulic System J72501 Front Suspension Valve Pipe (Front) With Front Hyd.Outlet Front Suspension Valve
Hydraulic System J72502 Front Suspension Valve Pipe (Front) Without Front Hyd.Outlet None Front Suspension
Hydraulic System J73000 Front Suspension Accumulator Front Suspension
Hydraulic System J73500 Front Suspension Cylinder Hose Front Suspension
Control Valve (4 Valves) Oc Type Remote Control Valve (4 Valves) Oc Type With Front 3p Not Oc....
Remote Control Valve (4 Valves) Oc Type With Front Hyd. Outlet
Valve (4 Valves) Oc Type Front 3p Without Remote Control Valve (4 Valves) Oc Type W O Front 3p Not
Remote Control Valve (3 Valves) Oc Type Remote Control Valve (3 Valves) Oc Type Not Oc....Open Center
Control Valve (3 Valves) Ccls Type Remote Control Valve (3 Valves) Ccls Type Not Ccls.....Load Sensing Closed
Valve) Ccls Type Front 3p Without Remote Control Valve (4 Valves) Ccls Type W O Front 3p Not Ccls.....Load
Ccls Type Front Hyd.Without Remote Control Valve (4 Valves) Ccls Type W O Front Hyd. Outlet Note
Ccls Type With Front Hyd. Outlet Remote Control Valve (4 Valves) Ccls Type With Front Hyd. Outlet Note
Valve (4 Valves) Oc Type Component Parts Auxiliary Control Valve (4 Valves) Type De Oc Component Parts
Valve (3 Valves) Oc Type Component Parts Auxiliary Control Valve (3 Valves) Type De Oc Component Parts
(4 Valves) Oc Type Component Parts Directional Control Valve 1 (4 Valves) Type De Oc Component Parts
(3 Valves) Oc Type Component Parts Directional Control Valve 1 (3 Valves) Type De Oc Component Parts
Valve 2 Oc Type Component Parts Directional Control Valve 2 Type De Oc Component Parts Not Oc....
Valve 3 Oc Type Component Parts Directional Control Valve 3 Type De Oc Component Parts Not Oc....
Hydraulic System J74300 Central Valve Component Parts Center Valve
Plate Valve Oc Type Component Parts End Plate Valve Type De Oc Component Parts Not Oc....Open
J74501 Oil Collector (Remote Control Valve) 4p Old Oil Collector (Remote Control Valve) 4p
J74502 Oil Collector (Remote Control Valve) 4p New Oil Collector(Remote Control Valve) 4p
J74503 Oil Collector(Remote Control Valve) 3p Old Oil Collector(Remote Control Valve) 3p
J74504 Oil Collector(Remote Control Valve) 3p New Oil Collector(Remote Control Valve) 3p
J74505 Oil Collector(Remote Control Valve) 2p Old Oil Collector(Remote Control Valve) 2p
J74506 Oil Collector(Remote Control Valve) 2p New Oil Collector(Remote Control Valve) 2p
Hydraulic System J75001 Spare Control Valve Lever (3 Valve) Auxiliary Control
Hydraulic System J75002 Backup Control Valve Lever (4 Valve) Auxiliary Control
Hydraulic System J75501 Backup Control Valve Wire (3 Valve) Auxiliary Control
Hydraulic System J75502 Backup Control Valve Wire (4 Valve) Auxiliary Control
Hydraulic System J76000 Front Hydraulic Outlet Pipe (Rear) With Front Hydraulic Outlet
Hydraulic System J76300 Front Hydraulic Outlet Pipe (Middle) Front Hydraulic With Front Hydraulic Outlet Outlet
Hydraulic System J76500 Front Hydraulic Outlet Pipe (Front) Front Hydraulic Outlet With Front Hydraulic Outlet
System J77002 Hydraulic Outlet Pipe (Load Sensing Control Hose) Hydraulic Outlet With Power Beyond
System J77302 Hydraulic Outlet Pipe (Power Beyond Return Hose) Hydraulic Outlet With Power Beyond
System J78001 Trailer Brake Valve 1 Pipe 50km H Model 2-Line 1+2-Line Trailer Brake Trailer Brake
Hydraulic System J78002 Trailer Brake Valve 1-Line Trailer Brake Trailer Brake
Hydraulic System J78101 Trailer Brake Valve 2 Pipe 50km H Model 1+2-Line Trailer Brake Trailer Brake
Hydraulic System J78102 Trailer Brake Valve Pipe 2-Line Trailer Brake Trailer Brake
Hydraulic System J78301 Trailer Brake Valve Pipe Clamp 1+2-Line Trailer Brake Trailer Brake
Hydraulic System J78302 Trailer Brake Valve Pipe Clamp 2-Line Trailer Brake Trailer Brake
Hydraulic System J78303 Trailer Brake Valve Pipe Clamp 1-Line Trailer Brake Trailer Brake
Hydraulic System J78401 Trailer Brake Valve 3 Pipe 50km H Model 1+2-Line Trailer Brake Trailer Brake
Hydraulic System J78402 Trailer Brake Valve 2 Pipe 2-Line Trailer Brake Trailer Brake
Hydraulic System J79002 Front Loader Oil Pipe (Rear) Ccls Type Loading Equipment With Front Loader Oil
Hydraulic System J79003 Front Loader Oil Pipe (Rear) Oc Type Loading Equipment With Front Loader Oil
Hydraulic System J79502 Front Loader Oil Pipe (Front) Ccls Type Loading Front Loader Oil With Equipment
Hydraulic System J79503 Front Loader Oil Pipe (Front) Oc Type Loading Equipment With Front Loader Oil
Air Compressor Air Compressor J81800 Air Compressor Air Compressor With Air Compressor
Air Compressor J82000 Air Compressor Component Parts Air Compressor With Air Compressor
Compressor Air Compressor J82200 Air Compressor Pipe Air Compressor With Air Compressor
Compressor Air Compressor J82300 Air Compressor Pipe Air Compressor With Air Compressor
Air Compressor Air Compressor J82700 Dryer Air Compressor With Dryer With Air
Air Compressor Air Compressor J83100 Air Tank Air Compressor With Air Tank With
Compressor J83301 Air Tank Pipe Air Compressor With Cabin Suspension(Spring) Type Air Tank
Air Compressor Air Compressor J83700 Air Clamp Air Compressor With Air Coupler
Point Linkage Drawbar Hitch K01001 Front 3p Connection (Frame Upper Connection) Front 3p With Front Hyd.Outlet With
Linkage Drawbar Hitch K01002 Front 3p Connection (Frame Upper Connection) Front 3p Without Front Hyd.Outlet
Connection Drawing Bar Connection 3-Point Linkage Drawbar Hitch K01500 Front 3p Connection (Lift) Front 3p With Front
Connection Drawing Bar Connection 3-Point Linkage Drawbar Hitch K01700 Front 3p Connection (Cylinder) Front 3p With Front
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K03000 Front PTO Front PTO With Front
3-Point Linkage Drawbar Hitch K03300 PTO Gearbox 1 (Transmission) Component Parts With Front Pto
3-Point Linkage Drawbar Hitch K03400 PTO Gearbox 2 (Pump) Component Parts With Front Pto
3-Point Linkage Drawbar Hitch K03500 PTO Gearbox 3 (Clutch) Component Parts With Front Pto
3-Point Linkage Drawbar Hitch K03700 PTO Gearbox 4 (Body) Component Parts With Front Pto
Point Linkage Drawbar Hitch K03900 PTO Gearbox 5 (Seal Kit) Component Parts Front PTO With Pto
Point Linkage Drawbar Hitch K10800 Top Link Bracket Clamp Bracket Old Top Link Bracket Coupler
Point Linkage Drawbar Hitch K10801 Top Link Bracket Clamp Bracket New Top Link Bracket Coupler
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K11001 3-Point Mount (Top Mount Manual) 3-
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K12500 3-Point Mount (Link,Lower) 3-Point
Drawing Bar Connection 3-Point Linkage Drawbar Hitch K13301 With Stabilizer(Lift) Connection (Ladder)
Draw Bar Connection 3-Point Linkage Drawbar Hitch K13302 With Stabilizer(Automatic) Connection (Ladder)
Draw Bar Connection 3-Point Linkage Drawbar Hitch K13303 With Stabilizer(Lift) Connection (Dromone)
Draw Bar Connection 3-Point Linkage Drawbar Hitch K13304 With Stabilizer(Automatic) Connection (Dromone)
Link Draw Bar Connection 3-Point Linkage Drawbar Hitch K13401 Stabilizer (Lift) Component Parts
Drawing Bar Connection 3-Point Linkage Drawbar Hitch K13402 Stabilizer (Automatic) Component Parts
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K13500 3 Point Link Lifting Rod)
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch K14500 Lifting Cylinder
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L10500 Drawing Bar Bracket
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L12001 Towbar (Standard)
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L12002 Towbar (Clamp K80)
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L12003 Towbar (Fixed Piton)
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L12004 Towbar (Cuna)
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L12300 With Towbar
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L15101 Connection (Ladder)
3 Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L15102 Connection (Dromone)
Connection Drawing Bar Connection 3-Point Linkage Drawbar Hitch L15400 Connection (Dromone) Component Parts
Connection Drawing Bar Connection 3-Point Linkage Drawbar Hitch L15500 Connection (Dromone) Trailer Lifter
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L15801 Trailer Hook (Manual)
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L15802 Trailer Hook (Automatic)
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L15803 Trailer Hook (K80)
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L15804 Trailer Hook (Piton)
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L15805 Trailer Hook (Cuna-C)
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L15806 Trailer Hook (Cuna-D2)
Point Connection Drawing Bar 3-Point Linkage Drawbar Hitch L15807 Trailer Hook (Cuna-D3)
Kaput Bone Hood Bonnet M12000 Hood (Bonnet) Upper
Hood Bone M12300 Hood (Bonnet) Damper
Hood Bone M12400 Bone Lock Hood (Bonnet) Lock
Hood Bone M15100 Bone Side Cover Right Side Hood (Bonnet) Side Lower
Bone Hood Bonnet M15201 Bonnet (Bone) Left Side Without Lower Air Compressor Hood (Bonnet)
Bone Hood Bonnet M15202 Bonnet (Bone) Left Side With Lower Air Compressor Hood (Bonnet) Side
Bonnet Bone Hood Bonnet M17000 Shutter Plate
Bonnet Bone Hood Bonnet M17200 Grille Plate (Robust Absorber Insulation) Shutter Plate (Sound
Bonnet Bone Hood Bonnet M19001 Front Fender (W 410) Front Fender(W 410)
Bonnet Bone Hood Bonnet M19002 Front Fender (W 540) Front Fender(W 540)
Cab N11003 Cab Frame Cab Frame
Cab N11301 Step Right With Loading Equipment Step Rh With Loader Equipment
Cab N11302 Step Right Without Loading Equipment Step Rh W O Loader Equipment
Cab N11400 Step Left Step Lh
Cab N11800 Front Cover
Cab N12000 Front Glass Front Glass
Cab N12500 Door (Right Side) Door Rh
Cab N13000 Door (Left Side) Door Lh
Cab N13500 Door Lock (Right Side) Door Lock Rh
Cab N14000 Door Lock (Left Side) Door Lock Lh
Cab N15000 Rear Window Hatch Back Glass(Rear Window )
Cab N15600 Sunroof
Cab N15800 Rearview Mirror
Cab N16000 Inner Ceiling Inner Roof
Cab N16500 Outer Ceiling Outer Roof
Cab N16800 Seat Bracket Seat Bracket
Cab N17002 Seat
Cab N17102 Seat 1 (Seat Cushion) Component Parts Seat1 (Seat Cushion) Component
Cab N17202 Seat 2 (Armrest Backrest) Component Parts Seat2 (Armrest Backrest)
Cab N17300 Seat Suspension Component Parts Seat Suspension Component
Cab N17400 Passenger Seat Passenger Seat
Cab N17500 Floor Mat
Cab N17600 Soundproof Material 1 (Panel) Soundproof Material 1 (Panel)
Cab N17700 Soundproof Material 2 (Floor) Soundproof Material 2 (Floor)
Cab N17900 Soundproof Material 3 (Console) Soundproof Material 3 (Console)
Cab N18200 Soundproof Material 4 (Ceiling) Soundproof Material 4 (Roof)
Cab N18503 Sliding Cover (Console Right) Shift Cover (Console Rh)
Cab N18700 Radio Cover And Air Conditioner Control Panel Cover Radio Cover And Air Conditioner
Cab N18800 Console, Left Side Console Lh
Cab N18900 Pillar Cover
Cab N19500 Fender Cover
Cab N22500 Fender (Right Side) Fender Rh
Cab N23000 Fender (Left Side) Fender Lh
Cab N23200 Upper Fender Over Fender
Cab N24001 Cab Bracket With Front Loading Equipment Cab Bracket Front With Loader
Cab N24002 Cab Bracket Without Front Loading Equipment Cab Bracket Front W O Loader
Cab N24500 Cab Bracket Rear
Cab N24601 Rear Damper Suspension Type (Spring) Rear Damper Suspension Type
Cab N25000 Tool Box
Air Conditioner P11500 Air Conditioner
Air Conditioner P13900 Air Conditioner Tube (Fresh) Air Conditioner Duct (Fresh
Air Conditioner P14000 Air Conditioner Tube (Rear) Air Conditioner Duct (Rear)
Air Conditioner P14100 Mode Box Mode Case
Air Conditioner P14300 Air Outlets Indicator Dashboard Air Outlets
Air Conditioner P14700 Inner Air Recirculation
Air Conditioner P15000 Heater Hose
Air Conditioning Air Conditioner P15700 Air Conditioning Hose Condenser Hose Air Conditioner
Air Conditioning Air Conditioner P15901 Compressor Drive Belt Without Air Compressor
Air Conditioning Air Conditioner P15902 Compressor Drive Belt With Air Compressor With Compressor
Air Conditioning Air Conditioner P16000 Compressor (Air Conditioning) Compressor (Air Conditioner)
Front Rear Tire R11001 Front Wheel(380 85r28) Michelin Front Wheel (380
Front Rear Tire R11002 Front Wheel(380 85r28) Trelleborg Front Wheel (380
Front Rear Tire R11003 Front Wheel(380 85r28) Firestone Front Wheel (380
Front Rear Tire R11004 Front Wheel(380 85r28) Mitas Front Wheel (380
Front Rear Tire R11005 Front Wheel(420 70r28) Michelin Front Wheel (420
Front Rear Tire R11006 Front Wheel(420 70r28) Trelleborg Front Wheel (420
Front Rear Tire R11007 Front Wheel(420 70r28) Firestone Front Wheel (420
Front Rear Tire R11008 Front Wheel(420 70r28) Mitas Front Wheel (420
Front Rear Tire R11009 Front Wheel(420 85r28) Michelin Front Wheel (420
Front Rear Tire R11010 Front Wheel(420 85r28) Trelleborg Front Wheel (420
Front Rear Tire R11011 Front Wheel(420 85r28) Firestone Front Wheel (420
Front Rear Tire R11012 Front Wheel(420 85r28) Mitas Front Wheel (420
Front Rear Tire R11013 Front Wheel(480 70r28) Michelin Front Wheel (480
Front Rear Tire R11014 Front Wheel(480 70r28) Trelleborg Front Wheel (480
Front Rear Tire R11015 Front Wheel(480 70r28) Firestone Front Wheel (480
Front Rear Tire R11016 Front Wheel(480 70r28) Mitas Front Wheel (480
Front Rear Tire R11017 Front Wheel(540 65r28) Michelin Front Wheel (540
Front Rear Tire R11018 Front Wheel(540 65r28) Trelleborg Front Wheel (540
Front Rear Tire R11019 Front Wheel(540 65r28) Firestone Front Wheel (540
Front Rear Tire R11020 Front Wheel(540 65r28) Mitas Front Wheel (540
Front Rear Tire R12001 Rear Wheel (460 85r38) Michelin Rear Wheel (460
Front Rear Tire R12002 Rear Wheel (460 85r38) Trelleborg Rear Wheel (460
Front Rear Tire R12003 Rear Wheel (460 85r38) Firestone Rear Wheel (460
Front Rear Tire R12004 Rear Wheel (460 85r38) Mitas Rear Wheel (460
Front Rear Tire R12005 Rear Wheel (520 70r38) Michelin Rear Wheel (520
Front Rear Tire R12006 Rear Wheel (520 70r38) Trelleborg Rear Wheel (520
Front Rear Tire R12007 Rear Wheel (520 70r38) Firestone Rear Wheel (520
Front Rear Tire R12008 Rear Wheel (520 70r38) Mitas Rear Wheel (520
Front Rear Tire R12009 Rear Wheel (520 85r38) Michelin Rear Wheel (520
Front Rear Tire R12010 Rear Wheel (520 85r38) Trelleborg Rear Wheel (520
Front Rear Tire R12011 Rear Wheel (520 85r38) Firestone Rear Wheel (520
Front Rear Tire R12012 Rear Wheel (520 85r38) Mitas Rear Wheel (520
Front Rear Tire R12013 Rear Wheel (580 70r38) Michelin Rear Wheel (580
Front Rear Tire R12014 Rear Wheel (580 70r38) Trelleborg Rear Wheel (580
Front Rear Tire R12015 Rear Wheel (580 70r38) Firestone Rear Wheel (580
Front Rear Tire R12016 Rear Wheel (580 70r38) Mitas Rear Wheel (580
Front Rear Tire R12017 Rear Wheel (650 65r38) Michelin Rear Wheel (650
Front Rear Tire R12018 Rear Wheel (650 65r38) Trelleborg Rear Wheel (650
Front Rear Tire R12019 Rear Wheel (650 65r38) Firestone Rear Wheel (650
Front Rear Tire R12020 Rear Wheel (650 65r38) Mitas Rear Wheel (650
Labels S11002 Label (Bone)) Label (Hood (Bonnet))
Labels S12001 Label (Front) With Loader
Labels S12002 Label (Front) Loader Equipment No Label (Front) W O Loader
Labels S13003 Label (Dashboard Sliding Cover) Label (Panel Shift
Labels S14000 Label (Back) Label (Rear)
Labels S15000 Label (Electronic Control Unit Control) Label (ECu
Labels S16000 Label (Operator Interior) Label (Cab Interior)
Accessories Accessories T11000 Accessories Accessories
Option U11000 Alternator Kit (200a) Option Alternator Kit (200a) Option
Option U11300 Alternator Kit Component Parts (200a) Option Alternator Component
Option U14900 Head Light Kit (Dual Head Light) Option Head Light Kit (Repeat Head
Option U16800 Interior Light Kit Option Room Light Kit Option Kit Installation Time 0.5 Hours 1 Person Kit
(6 Splines) (Gear Case) Option Kit Assembly Time 5 Hours 1 Person. Note For Components Drawing Number K03300
U29300 Front PTO Kit (6 Splines) (Gearbox Packing) Component Parts Option Front PTO Kit (6 Splines)
Pto Kit (6 Splines) (Oil Cooler) Option Front PTO Kit (6 Splines) (Oil Cooler) Option Kit Installation Time
Option U38200 Sensor Kit (Radar) Option Sensor Kit (Radar) Option
Option U38800 PTO Kit (21 Gears) Option EC PTO Kit (21 Splines) Option
Rear View Mirror Kit(With Heater) Option Rearview Mirror Kit (With Heater) Option Kit Installation Time 2
Option U70000 Support Control Valve Kit (Mech.4th) (Valve) Option Auxiliary Control Valve Kit
Option U71000 Support Control Valve Kit (Mech.4th) (Lever) Option Auxiliary Control Valve
U74302 Coupler Kit (Front Hyd. Outlet Mech.) (Pipe) With Front Suspension Option Coupler Kit (Front Hyd. Outlet Mech.) (Coupler Pipe) With Front Suspension Option Coupler Kit (Front Hyd. Outlet
Option U84002 Top Link (Hydraulic) Option Top Link Kit (Hydraulic) Option
Option U86100 Front 3p Connection Kit (Frame Top Connection) Option Front 3p Link Kit (Frame
Option U86200 Front 3p Connection Kit (Crane) Option Front 3p Link Kit (Lifter)
Option U86300 Front 3p Connection Kit (Cylinder) Option Front 3p Link Kit (Cylinder)
Option U86500 Front 3p Connection Kit (Mech.4th) (Lever) Option Front 3p Link Kit (Mech.
Option U86602 Front 3p Link Kit (Mech.4th) (Valve) Option Front 3p Link Kit (Mech.4th)
3p Link External Switch Kit Option External Switch For Front 3-Point Hitch Option Kit Mounting
Option U88501 Tow Kit (Standard) Option Drawbar Kit (Standard) Option
Option U88502 Tow Kit (Cuna) Option Drawbar Kit (Cuna) Option
Option U88503 Tow Kit (Coupling K80) Option Drawbar Kit (Coupling K80)
Option U88504 Towbar Kit (Fix Piton) Option Old Drawbar Kit (Fix Piton) Option Old Chassis No. 30593
Option U88505 Towbar Kit (Fix Piton) Option New Drawbar Kit (Fix Piton) Option New Chassis No. 30594
Option U94402 Rear Window Defogger Kit Rear Defogger Kit
Option U94700 Sunshade Shield Kit Option Sunshade Shield Kit Option
