Kubota Tractor M7132S Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M7132S Tractor
Number of Pages: 716 Pages
B Loco Motor(Superior) / Crankcase (Upper)
B Loco Motor(Inferior) / Crankcase (Lower)
C Árter Do Óleo [Sem Compressor De Ar] / Oil Pan [W/O Air Compressor]
C Árter Do Óleo [Com Compressor De Ar] / Oil Pan [Wit H Air Compressor]
C Abeça Motor / Cylinder Head
V Alvula Admissao E Escape / Inlet Valve And Exhaust Valve
B Raço / Rocker Arm Shaft
T Ampa Cabeça / Head Cover
C Obertura Frontal / Front Cover
P Iston E Cambota / Piston And Crankshaft
C Ompensador / Balancer
V Olante Motor / Flywheel
F Iltro Gasoleo / Fuel Filter
B Omba De Abastecimento / Supply Pump
I Njector E Vela Aquecimento / Injector And Glow Plug
T Ubo Injector / Injection Pipe
C Ommon Rail / Common Rail
B Omba Agua / Water Pump
R Adiador Oleo / Oil Cooler
S Eparador De Óleo / Oil Separator
S Eparador De Óleo [Peças Componentes] / Oil Separato R [Component Parts]
T Ubo Do Separador De Óleo / Oil Separator Pipe
T Ubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charg Er)
F Iltro Ar [Sem Tdf Dianteira] / Air Cleaner [W/O Fro Nt Pto]
F Iltro Ar [Com Tdf Dianteira] / Air Cleaner [With Fr Ont Pto]
F Iltro Ar [Peças Componentes] / Air Cleaner [Compone Nt Parts]
T Ubo De Entrada (Filtro De Ar) [Sem Compressor De Ar ] / Inlet Pipe (Air Cleaner) [W/O Air Compresser]
T Ubo De Entrada (Filtro De Ar) [Com Compressor De Ar ] / Inlet Pipe (Air Cleaner) [With Air Compresser]
T Urbo Compressor / Turbo Charger
F Lange Filtro Ar E Valvula Acelarador / Air Cleaner Flange And Throttle Valve
V Alvula Egr / Egr Valve
R Efrigerador Egr / Egr Cooler
T Ubos De Água Egr / Egr Water Piping
C Olector Escape / Exhaust Manifold
S Ilenciador Do Filtro De Partículas Diesel / Diesel Particulate Filter Muffler
S Ilenciador Do Filtro De Partículas Diesel [Peças Co Mponentes] / Diesel Particulate Filter Muffler [Com Ponent Parts]
T Ubo Pressao / Pressure Pipe
P Anela Escape / Muffler Pipe
S Ilenciador Da Redução Catalítica Seletiva / Selecti Ve Catalytic Reduction Muffler
R Esguardo Da Redução Catalítica Seletiva [Antiga] / Selective Catalytic Reduction Cover [Old]
R Esguardo Da Redução Catalítica Seletiva [Nova] / Se Lective Catalytic Reduction Cover [New]
T Ubulação E Proteção Do Silênciador / Muffler Pipe A Nd Cover
B Omba Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Pump
D Epósito Do Fluido De Escape De Diesel / Diesel Exha Ust Fluid Tank
D Epósito Do Fluido De Escape De Diesel [Peças Compon Entes] / Diesel Exhaust Fluid Tank [Component Parts ]
D Epósito Do Fluido De Escape De Diesel Tubo / Diesel Exhaust Fluid Hose
D Epósito Do Fluido De Escape De Diesel Aquecedor Tub O / Diesel Exhaust Fluid Heater Hose
D Epósito Do Fluido De Escape De Diesel Mangueira De Respiro / Diesel Exhaust Fluid Breather Hose
V Álvula Egr (Sistema De Redução Catalítica Seletiva) / Egr Valve (Selective Catalytic Reduction System)
S Istema De Arrefecimento Egr (Sistema De Redução Cat Alítica Seletiva) / Egr Cooler (Selective Catalytic Reduction System)
T Ubo Egr (Sistema De Redução Catalítica Seletiva) / Egr Pipe (Selective Catalytic Reduction System)
T Ubos De Água Egr (Sistema De Redução Catalítica Sel Etiva) / Egr Water Piping (Selective Catalytic Redu Ction System)
C Obertura De Escape De Exaustão/Tampa De Recirculaçã O De Gás De Escape / Exhaust Manifold Cover/Egr Cov Er
C Omponentes Electricos Motor (Sensor/Ecu) / Engine E Lectrical Parts (Sensor/Ecu)
C Omponentes Electricos Motor (Panela Escape) / Engin E Electrical Parts (Muffler)
C Ablagem Injector / Injector Harness
P Edal Acelarador / Accelerator Pedal
Deposito Combustivel [Antiga] / Fuel Tank [Old]
Deposito Combustivel [Nova] / Fuel Tank [New]
Suporte Deposito Combustivel [ Com Equipamento Do Carregador] / Fuel Tank Bracket [With Loader Equipment]
Suporte Deposito Combustivel [ Sem Equipamento Do Carregador] / Fuel Tank Bracket [W/O Loader Equipment]
Tubo Do Combustível (Enchiment O Do Combustível) / Fuel Pipe (Fuel Filter)
Arrefecedor Gasoleo / Fuel Coo Ler
Separador / Separator
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Component Es] / Fuel Pump [Component Parts]
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Componen Tes] / Fuel Filter [Component Parts]
Suporte Vent Ilador / Fan Bracket
Polia De Aci Onamento Da Ventoinha / Fan Drive Pulley
Ventoinha / Fan
Tubo De Água E Tubo Do Sistema De Arrefecimento / Water Pipe An D Cooler Pipe
Unidade Do S Istema De Arrefecimento / Cooler Unit
Unidade Do A Rrefecedor (Radiador) [Peças Componentes] / Cooler Unit (Radiator) [Component Parts]
Unidade Do A Rrefecedor (Permutador Intermédio De Calor) [Peças Componentes] / Cooler Unit (Inter Cooler) [Componen T Parts]
Unidade Do A Rrefecedor (Arrefecedor Do Óleo) [Peças Componentes ] / Cooler Unit (Oil Cooler) [Component Parts]
Unidade Do A Rrefecedor (Condensador) [Peças Componentes] / Cool Er Unit (Condenser) [Component Parts]
Tubo Do Depó Sito De Reserva [Sem Compressor De Ar] / Reserve Ta Nk Hose [W/O Air Compressor]
Tubo Do Depó Sito De Reserva [Com Compressor De Ar] / Reserve Ta Nk Hose [With Air Compressor]
Alternador (200a) / Alternato R (200a)
Alternador (150a) / Alternato R (150a)
Alternador (200a) [Peças Comp Onentes] / Alternator (200a) [Component Parts]
Alternador (150a) [Peças Comp Onentes] / Alternator (150a) [Component Parts]
Motor Arranque / Starter
Suporte De Bateria / Battery Bracket
Interruptor/Sensor (Bloco Mot Or Esquerda) / Switch/Sensor (Engine Lh)
Interruptor/Sensor (Bloco Mot Or Direita) / Switch/Sensor (Engine Rh)
Sensor Da Redução Catalítica Seletiva / Selective Catalytic Reduction Sensor
Suspensão Frontal Sensor / Fr Ont Suspension Sensor
Sensor (Pedal) / Sensor (Peda L)
Interruptor/Sensor [Sem Compr Essor De Ar] / Switch/Sensor [W/O Air Compressor]
Interruptor/Sensor [Com Compr Essor De Ar] / Switch/Sensor [With Air Compressor]
Sensor/Valvula (Carter Embrai Agem/Habitação De Transmissão) / Sensor/Regulater ( Clutch Housing/Transmission Housing)
Sensor/Valvula (Hidráulica Bo Mba De Moradia / Tdf Shaft Habitação) [Tipo De Oc] / Sensor/Valve (Hydraulic Pump Housing/Pto Shaft Ho Using) [Oc Type]
Sensor/Valvula (Hidráulica Bo Mba De Moradia / Tdf Shaft Habitação) [Tipo De Ccls ] / Sensor/Valve (Hydraulic Pump Housing/Pto Shaft Housing) [Ccls Type]
Sensor Da Conicidade/Sensor 3 P [Com Puxo (Escada)] / Draft Sensor/3p Sensor [Wit H Hitch (Ladder)]
Interruptor (Ligação 3p Diant Eira) [Com 3p Dianteiro] / Switch (Front 3p Link) [ With Front 3p]
Interruptor (Painel) / Switch (Panel Board)
Interruptor (Direcção) [Sem D Ireção Automática] / Switch (Steering) [Auto Steeri Ng Incompatible]
Interruptor (Cobertura De Mud Ança) / Switch (Shift Cover)
Interruptor (Consola Do Lado Esquerdo) / Switch (Console Lh)
Relé/Controlador / Relay/Cont Roller
Unidade Control Electrico (Bl Oco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico/Con Trolador [Sem Compressor De Ar] / Electronic Contro L Unit/Controller [W/O Air Compressor]
Unidade Control Electrico/Con Trolador [Com Compressor De Ar] / Electronic Contro L Unit/Controller [With Air Compressor]
Controlador (Ceu) / Controlle R (Ceu)
Controlador (Ceu) [Peças Comp Onentes] / Controller (Ceu) [Component Parts]
Painel / Panel
Peças Elétricas Da Traseira I Nterior Da Cabine (Saída Elétrica/Painel De Control O Do Ar Condicionado) / Cab Inner Rear Electrical P Arts (Electrical Outlet/Air Conditioner Control Pan El)
Apoio De Braço [Sem Tdf Diant Eira] / Armrest [W/O Front Pto]
Apoio De Braço [Com Tdf Diant Eira] / Armrest [With Front Pto]
Luzes Frente / Head Light
Luzes Frente (Coluna) [Com Fa Rol De Repetição] / Head Light (Pillar) [With Repea T Head Light]
Lâmpada Farol / Beacon Lamp
Lámpada De Pisca Pisca [Com L Uz De Trabalho(Coluna)] [Nova] / Lamp Of Side Marke R [With Work Light(Pillar)] [New]
Lámpada De Pisca Pisca [Sem L Uz De Trabalho(Coluna)] [Nova] / Lamp Of Side Marke R [W/O Work Light(Pillar)] [New]
Luzes Frontais / Front Combin Ation Lamp
Luz De Trabalho (Dianteiro/Te To) / Work Light (Front/Roof)
Luz De Trabalho (Traseiro/Tet O) / Work Light (Rear/Roof)
Luz De Trabalho (Traseiro/Col Una) [Com Luz De Trabalho(Coluna)] / Work Light (Re Ar/Pillar) [With Work Light(Pillar)]
Braco Traseiro / Rear Combina Tion Lamp
Farol Matricula / License Lam P
Ficha Reboque [Travão De Trai Ler De 2 Linha/1+2 Linha] / Trailer Socket [2-Line/ 1+2-Line Traler Brake]
Ficha Reboque [Travão De Trai Ler De 1 Linha] / Trailer Socket [1-Line Traler Bra Ke]
Luz Interior / Room Light
Alta Voz Radio / Radio Speake R
Escova / Wiper
Cablagem Elétrica (Motor) 1 ( Filtro De Ar/Dpf) / Electrical Wiring (Engine) 1 (A Ir Cleaner/Dpf)
Cablagem Elétrica (Motor) 2 ( Crs) / Electrical Wiring (Engine) 2 (Crs)
Cablagem Elétrica (Motor) 3 ( Combustível/Scr) / Electrical Wiring (Engine) 3 (Fu El/Scr)
Cablagem Elétrica (Motor) 4 ( Fusível/Bateria) / Electrical Wiring (Engine) 4 (Fu Se/Battery)
Cablagem Elétrica (Motor) 5 ( Compressor/Volante) [Sem Compressor De Ar] / Electr Ical Wiring (Engine) 5 (Compressor/Flywheel) [W/O A Ir Compresser]
Cablagem Elétrica (Motor) 5 ( Compressor/Volante) [Com Compressor De Ar] / Electr Ical Wiring (Engine) 5 (Compressor/Flywheel) [With Air Compresser]
Cablagem Elétrica (Capot) / E Lectrical Wiring (Bonnet(Hood))
Cablagem Elétrica (Alternador ) [Com Alternador (200 A)] / Electrical Wiring (Alt Ernator 200a)
Cablagem Elétrica (Alternador ) [Com Alternador (150 A)] / Electrical Wiring (Alt Ernator 150a)
Cablagem Eletrica (Motor Arra Nque) / Electrical Wiring (Starter)
Cablagem Electrica (Fonte De Alimentação/Controlador (Ceu)) / Electrical Wiring (Power Supply/Controller (Ceu))
Cablagem Electrica (Eixo Tran Versal/Frente) [Sem Compressor De Ar] / Electrical Wiring (Transaxle/Front) [W/O Air Compresser]
Cablagem Electrica (Eixo Tran Versal/Frente) [Com Compressor De Ar] / Electrical Wiring (Transaxle/Front) [With Air Compresser]
Cablagem Electrica (Eixo Tran Versal/Traseira) [Antiga] / Electrical Wiring (Tran Saxle/Rear) [Old]
Cablagem Electrica (Eixo Tran Versal/Traseira) [Nova] / Electrical Wiring (Transa Xle/Rear) [New]
Cablagem Electrica (Distribui Dor Auxiliar) / Electrical Wiring (Remote Control V Alve)
Cablagem Electrica(Etcv Valvu La/Secagem) [Com Compressor De Ar] / Electrical Wir Ing (Etcv Valve/Air Dryer) [With Air Compressor]
Cablagem Elétrica (Cabine) 1 (Direção/Painel) / Electrical Wiring (Cab) 1 (Steer Ing/Panel)
Cablagem Elétrica (Cabine) 2 (Ecu) / Electrical Wiring (Cab) 2 (Ecu)
Cablagem Elétrica (Cabine) 3 (Cobertura Das Mudanças/Apoio De Braço) / Electrica L Wiring (Cab) 3 (Shift Cover/Armrest)
Cablagem Elétrica (Cabine) 4 (Ar Condicionado) [Modelo 50km/H] / Electrical Wiri Ng (Cab) 4 (Air Conditioner) [50 Km/H Model]
Cablagem Elétrica (Cabine) 4 (Ar Condicionado) [Modelo 40km/H] / Electrical Wiri Ng (Cab) 4 (Air Conditioner) [40 Km/H Model]
Cablagem Elétrica (Pilar Dian Teiro) [Novo] / Electrical Wiring (Front Pillar) [N Ew]
Cablagem Electrica (Teto) / E Lectrical Wiring (Roof)
Cablagem Electrica (Pisca/Pár A-Lama) / Electrical Wiring (Flasher/Mudguard)
Cablagem Electrica [Com 3p Di Anteiro] [Antiga] / Electrical Wiring [With Front 3 P] [Old]
Cablagem Electrica [Com 3p Di Anteiro] [Nova] / Electrical Wiring [With Front 3p] [New]
Cablagem Electrica (Suspensão Dianteira) / Electrical Wiring (Front Suspension)
Disco Do Amortecedor E Ligação À Caixa / Damper Disk And Housing Connecti On
Carter Embraiagem / Cl Utch Housing
Caixa De Transmissão / Transmission Housing
Caixa Do Eixo Traseiro / Rear Axle Housing
Estrutura Do Veio Tdf / Pto Shaft Housing
Veio Secundario / Coun Tershaft
Veio Primario / Main S Haft
Veio Principal Tdf / P To Drive Shaft
Embraiagem Dianteira / Front Clutch
Deslocação De Potência / Power Shift
Embraiagem Hidráulica (Entrada) / Hydraulic Clutch (Input)
Embraiagem Hidráulica (Saída) / Hydraulic Clutch (Output)
Veio De Entrada De Pot Ência / Power Input Shaft
Embraiagem Principal / Main Clutch
Transladador 1 / Shift Er 1
Estrutura Interior Do Veio Tdf (Embreagem) / Pto Shaft Housing Inner (Clu Tch)
Estrutura Interior Do Veio Tdf (Engrenagem) / Pto Shaft Housing Inner (Ge Ar)
Estrutura Interior Do Veio Tdf (Veio Tdf) / Pto Shaft Housing Inner (Pto Shaft)
Estrutura Interior Do Veio Tdf (Forquilha De Embraiagem) / Pto Shaft Hous Ing Inner (Shift Fork)
Válvula De Pressão / P Ressure Valve
Caixa De Mudança De Ve Locidade / Gear Shift Housing
Pedal Embraiagem / Clu Tch Pedal
Alvanca Inversor / Shuttle Shift L Ever
Alavanca Tdf / Pto Gear Shift Leve R
Diferencial Traseiro / Rear Differential
Travão / Brake
Eixo Traseiro / Brake Shaft
Pedal Travao / Brake Pedal
Tubo Do Travão 1 (Superior/ Parte Dianteira) [Travão De Trailer De 2 Linha/1+2 Linha] / Brake Pipe 1 (Upper/Front) [2-Line/1+2-Lin E Traler Brake]
Tubo Do Travão 2 (Inferior/ Parte Traseira) [Travão De Trailer De 1+2 Linha] / Brake Pipe 2 (Lower/Rear) [1+2-Line Traler Brake]
Tubo Do Travão 2 (Inferior/ Parte Traseira) [Travão De Trailer De 1 Linha/2 Li Nha] / Brake Pipe 2 (Lower/Rear) [1-Line/2-Line Tra Ler Brake]
Estrutura Do Eixo Diante Iro [Sem Suspensão Frontal] / Front Axle Frame [W/O Front Suspension]
Para-Choques Peso Diante Iro [Sem 3p Dianteiro] / Front Weight Bumper [W/O F Ront 3p]
Balanceiro Da Suspensão Dianteira [Com 3p Dianteiro] [Nova] / Front Suspens Ion Rocker Arm [With Front 3p] [New]
Balanceiro Da Suspensão Dianteira [Sem 3p Dianteiro] [Antiga] / Front Suspe Nsion Rocker Arm [W/O Front 3p] [Old]
Balanceiro Da Suspensão Dianteira [Sem 3p Dianteiro] [Nova] / Front Suspens Ion Rocker Arm [W/O Front 3p] [New]
Distribuidor Auxiliar [S Em 3p Dianteiro] / Front Guard [W/O Front 3p]
Eixo Dianteiro [Com Susp Ensão Frontal] / Front Axle [With Front Suspension]
Eixo Dianteiro [Sem Susp Ensão Frontal] / Front Axle [W/O Front Suspension]
Suporte Do Eixo Dianteir O [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo P Esado] / Front Axle Bracket [Front Axle Component] [With Front Suspension]
Suporte Do Eixo Dianteir O [Sem Suspensão Dianteira] [Eixo Dianteiro: Tipo P Esado] / Front Axle Bracket [Front Axle Component] [W/O Front Suspension]
Carter Eixo Frente [Eixo Dianteiro Peças Componentes] / Front Axle Housing [Front Axle Component]
Diferencial Dianteiro [E Ixo Dianteiro Peças Componentes] / Front Differenti Al [Front Axle Component]
Veio Carreto Diferencial [Eixo Dianteiro Peças Componentes] / Differential Gear Shaft [Front Axle Component]
Sensor De Ângulo De Vira Gem Roda [Eixo Dianteiro Peças Componentes] / Wheel Turning Angle Sensor [Front Axle Component]
Tirante/Cilindro Direcçã O [Eixo Dianteiro Peças Componentes] / Tie Rod/Stee Ring Cylinder [Front Axle Component]
Veio Do Propulsor E Resg Uardo [Com Suspensão Dianteira] / Propeller Shaft A Nd Cover [With Front Suspension]
Veio Do Propulsor E Resg Uardo [Sem Suspensão Dianteira] / Propeller Shaft A Nd Cover [W/O Front Suspension]
Direcção Assistida [Peças Componentes] / Steeri Ng Post [Component Parts]
Pedal Inclinacao / Tilt Pedal
Comando De Direção [Sem Direção Automática] / S Teering Controller [Auto Steering Incompatible]
Hidráulica Bomba De Moradia / Hydraulic Pump Housing
Linha De Óleo Hidráulico (Eix O Tranversal) / Hydraulic Oil Line (Transaxle)
Circuito Oleo Direcção (Radia Dor Oleo/Frente) / Hydraulic Oil Line (Oil Cooler/F Ront)
Radiador Oleo [Com Tdf Diante Ira] / Oil Cooler [With Front Pto]
Circuito Oleo Direcção (Direc Ção Valvula/Filtro) [Sem Compressor De Ar] / Hydrau Lic Oil Line (Steering Valve/Filter) [W/O Air Compr Esser]
Circuito Oleo Direcção (Direc Ção Valvula/Filtro) [Com Compressor De Ar] / Hydrau Lic Oil Line (Steering Valve/Filter) [With Air Comp Resser]
Filtro Oleo 2 [Peças Componen Tes] / Oil Filter 2 [Component Parts]
Tubo Direccao (Delivery) [Com Suspensão Frontal] / Steering Hose (Delivery) [Wit H Front Suspension]
Tubo Direccao (Delivery) [Sem Suspensão Frontal] / Steering Hose (Delivery) [W/O Front Suspension]
Linha De Óleo Hidráulico (Tub O De Fornecimento Do Eixo Dianteiro/Traseiro) / Hyd Raulic Oil Line (Front Axle Delivery Pipe/Front)
Linha De Óleo Hidráulico (Tub O De Fornecimento Do Eixo Dianteiro/Traseiro) / Hyd Raulic Oil Line (Front Axle Delivery Pipe/Rear)
Linha De Óleo Hidráulico (Fil Tro De Óleo) [Travão De Trailer De 2 Linha/1+2 Linh A] / Hydraulic Oil Line (Oil Filter) [2-Line/1+2-Li Ne Trailer Brake]
Linha De Óleo Hidráulico (Fil Tro De Óleo) [Travão De Trailer De 1 Linha] / Hydra Ulic Oil Line (Oil Filter) [1-Line Trailer Brake]
Linha De Óleo Hidráulico (Fil Tro De Óleo A Válvula De Controlo Remoto/Abertura D E Drenagem Hidráulica) [Modelo 50km/H:Travão De Tra Iler De 2 Linha/1+2 Linha] [Com Equipamento Do Carr Egador] [Com Power Beyond] / Hydraulic Oil Line (Oi L Filter To Remote Control Valve/Hyd. Drain Port) [ 50 Km/H Model:2-Line/1+2-Line Trailer Brake] [With Loader Equipment] [With Power Beyond]
Linha De Óleo Hidráulico (Fil Tro De Óleo A Válvula De Controlo Remoto/Abertura D E Drenagem Hidráulica) [Modelo 50km/H:Travão De Tra Iler De 2 Linha/1+2 Linha] [Com Equipamento Do Carr Egador] [Sem Power Beyond] / Hydraulic Oil Line (Oi L Filter To Remote Control Valve/Hyd. Drain Port) [ 50 Km/H Model:2-Line/1+2-Line Trailer Brake] [With Loader Equipment] [W/O Power Beyond]
Linha De Óleo Hidráulico (Fil Tro De Óleo A Válvula De Controlo Remoto/Abertura D E Drenagem Hidráulica) [Modelo 50km/H:Travão De Tra Iler De 2 Linha/1+2 Linha] [Sem Equipamento Do Carr Egador] [Sem Power Beyond] / Hydraulic Oil Line (Oi L Filter To Remote Control Valve/Hyd. Drain Port) [ 50 Km/H Model:2-Line/1+2-Line Trailer Brake] [W/O L Oader Equipment] [W/O Power Beyond]
Linha De Óleo Hidráulico (Fil Tro De Óleo A Válvula De Controlo Remoto/Abertura D E Drenagem Hidráulica) [Travão De Trailer De 1 Linh A] [Com Equipamento Do Carregador] [Com Power Beyon D] / Hydraulic Oil Line (Oil Filter To Remote Contr Ol Valve/Hyd. Drain Port) [1-Line Trailer Brake] [W Ith Loader Equipment] [With Power Beyond]
Linha De Óleo Hidráulico (Fil Tro De Óleo A Válvula De Controlo Remoto/Abertura D E Drenagem Hidráulica) [Travão De Trailer De 1 Linh A] [Com Equipamento Do Carregador] [Sem Power Beyon D] / Hydraulic Oil Line (Oil Filter To Remote Contr Ol Valve/Hyd. Drain Port) [1-Line Trailer Brake] [W Ith Loader Equipment] [W/O Power Beyond]
Linha De Óleo Hidráulico (Fil Tro De Óleo A Válvula De Controlo Remoto/Abertura D E Drenagem Hidráulica) [Travão De Trailer De 1 Linh A] [Sem Equipamento Do Carregador] [Sem Power Beyon D] / Hydraulic Oil Line (Oil Filter To Remote Contr Ol Valve/Hyd. Drain Port) [1-Line Trailer Brake] [W /O Loader Equipment] [W/O Power Beyond]
Linha De Óleo Hidráulico (Fil Tro De Óleo A Válvula De Controlo Remoto/Abertura D E Drenagem Hidráulica) [Modelo 40km/H:Travão De Tra Iler De 1+2 Linha] / Hydraulic Oil Line (Oil Filter To Remote Control Valve/Hyd. Drain Port) [40 Km/H Model:1+2-Line Trailer Brake]
Linha De Óleo Hidráulico (Tub O Do Travão A Válvula De Controlo Remoto) / Hydraul Ic Oil Line (Brake Pipe To Remote Control Valve)
Bloco De Válvula 1 (Eixo Tran Versal) / Valve Block 1 (Transaxle)
Bloco De Válvula 2 (Válvula S Olenóide) / Valve Block 2 (Solenoid Valve)
Axial Bomba [Tipo De Ccls] [C Om Equipamento Do Carregador] / Axial Pump [Ccls Ty Pe] [With Loaderequipment]
Tubulação De Bomba Axial [Tip O De Ccls] [Com Equipamento Do Carregador] [Com Pow Er Beyond] / Axial Pump Piping [Ccls Type] [With Lo Aderequipment] [With Power Beyond]
Tubulação De Bomba Axial [Tip O De Ccls] [Com Equipamento Do Carregador] [Sem Pow Er Beyond] / Axial Pump Piping [Ccls Type] [With Lo Aderequipment] [W/O Power Beyond]
Tubulação De Bomba Axial [Tip O De Ccls] [Sem Equipamento Do Carregador] [Com Pow Er Beyond] / Axial Pump Piping [Ccls Type] [W/O Loa Derequipment]] [With Power Beyond]
Tubulação De Bomba Axial [Tip O De Ccls] [Sem Equipamento Do Carregador] [Sem Pow Er Beyond] / Axial Pump Piping [Ccls Type] [W/O Loa Derequipment]] [W/O Power Beyond]
Bomba Hidráulica E Filtro Do Óleo [Tipo De Oc] [Com Equipamento Do Carregador] / Hydraulic Pump And Oil Filter [Oc Type] [With Load Er Equipment]
Bomba Hidráulica E Filtro Do Óleo [Tipo De Oc] [Sem Equipamento Do Carregador] / Hydraulic Pump And Oil Filter [Oc Type] [W/O Loade R Equipment]
Linha De Óleo Hidráulico (Bom Ba Axial A Válvula De Controlo Remoto) [Tipo De Ccl S] [Com Equipamento Do Carregador] [Sem Power Beyon D] / Hydraulic Oil Line (Axial Pump To Remote Contr Ol Valve) [Ccls Type] [With Loaderequipment] [W/O P Ower Beyond]
Linha De Óleo Hidráulico (Bom Ba Axial A Válvula De Controlo Remoto) [Tipo De Ccl S] [Com Equipamento Do Carregador] [Com Power Beyon D] / Hydraulic Oil Line (Axial Pump To Remote Contr Ol Valve) [Ccls Type] [With Loaderequipment] [With Power Beyond]
Tubo Da Válvula Da Suspensão Dianteira (Válvula De Controlo Remoto) [Tipo De Oc] [Com Equipamento Do Carregador] / Front Suspension Valve Pipe (Remote Control Valve) [Oc Type] [With Loader Equipment]
Tubo Da Válvula Da Suspensão Dianteira (Válvula De Controlo Remoto) [Tipo De Oc] [Sem Equipamento Do Carregador] / Front Suspension Valve Pipe (Remote Control Valve) [Oc Type] [W/O L Oader Equipment]
Tubo Da Válvula Da Suspensão Dianteira (Parte Traseira) [Tipo De Oc] [Sem Saída Hidráulica Dianteira] / Front Suspension Valve Pipe (Rear) [Oc Type] [W/O Front Hyd. Outlet]
Tubo Da Válvula Da Suspensão Dianteira (Parte Traseira) [Tipo De Oc] [Com Saída Hidráulica Dianteira] / Front Suspension Valve Pipe (Rear) [Oc Type] [With Front Hyd. Outlet]
Tubo Da Válvula Da Suspensão Dianteira (Parte Traseira) [Tipo De Ccls] [Sem Saíd A Hidráulica Dianteira] / Front Suspension Valve Pi Pe (Rear) [Ccls Type] [W/O Front Hyd. Outlet]
Valvula Da Suspensão Frontal / Front Suspension Valve
Valvula Da Suspensão Frontal [Peças Componentes] / Front Suspension Valve [Compo Nent Parts]
Tubo Da Válvula Da Suspensão Dianteira (Frente) [Sem Saída Hidráulica Dianteira] / Front Suspension Valve Pipe (Front) [W/O Front H Yd. Outlet]
Suspensão Frontal Acumulador / Front Suspension Accumulator
Suspensão Frontal Cilindro Tu Bo / Front Suspension Cylinder Hose
Válvula De Controlo Remoto (4 Válvulas) [Tipo De Oc] [Com 3p Dianteiro] / Remote Control Valve (4 Valves) [Oc Type] [With Front 3p]
Válvula De Controlo Remoto (4 Válvulas) [Tipo De Oc] [Com Saída Hidráulica Diant Eira] / Remote Control Valve (4 Valves) [Oc Type] [ With Front Hyd. Outlet]
Válvula De Controlo Remoto (4 Válvulas) [Tipo De Oc] [Sem 3p Dianteiro] / Remote Control Valve (4 Valves) [Oc Type] [W/O Front 3p]
Válvula De Controlo Remoto (4 Válvulas) [Tipo De Ccls] [Sem 3p Dianteiro] / Rem Ote Control Valve (4 Valves) [Ccls Type] [W/O Front 3p]
Válvula De Controlo Remoto (4 Válvulas) [Tipo De Ccls] [Sem Saída Hidráulica Dia Nteira] / Remote Control Valve (4 Valves) [Ccls Typ E] [W/O Front Hyd. Outlet]
Válvula De Controlo Remoto (4 Válvulas) [Tipo De Oc] [Peças Componentes] / Auxil Iary Control Valve (4 Valves) [Type De Oc] [Compone Nt Parts]
Válvula De Controle Direciona L 1 (4 Válvulas) [Tipo De Oc] [Peças Componentes] / Directional Control Valve 1 (4 Valves) [Type De Oc ] [Component Parts]
Válvula De Controle Direciona L 2 [Tipo De Oc] [Peças Componentes] / Directional Control Valve 2 [Type De Oc] [Component Parts]
Válvula De Controle Direciona L 3 [Tipo De Oc] [Peças Componentes] / Directional Control Valve 3 [Type De Oc] [Component Parts]
Válvula Central [Peças Compon Entes] / Center Valve [Component Parts]
Válvula De Placa End [Tipo De Oc] [Peças Componentes] / End Plate Valve [Type De Oc] [Component Parts]
Coletor De Óleo (Válvula De C Ontrolo Remoto) [4p] [Nova] / Oil Collector(Remote Control Valve) [4p] [New]
Coletor De Óleo (Válvula De C Ontrolo Remoto) [3p] [Antiga] / Oil Collector(Remot E Control Valve) [3p] [Old]
Coletor De Óleo (Válvula De C Ontrolo Remoto) [3p] [Nova] / Oil Collector(Remote Control Valve) [3p] [New]
Coletor De Óleo (Válvula De C Ontrolo Remoto) [2p] [Nova] / Oil Collector(Remote Control Valve) [2p] [New]
Alavanca Da Válvula De Contro Lo Auxiliar (4 Válvulas) / Auxiliary Control Valve Lever (4 Valves)
Cabo Da Válvula De Controlo A Uxiliar (4 Válvulas) / Auxiliary Control Valve Wire (4 Valves)
Tubo Da Saída Hidráulica Dian Teira (Parte Traseira) [Com Saída Hidráulica Diante Ira] / Front Hydraulic Outlet Pipe (Rear) [With Fro Nt Hyd. Outlet]
Tubo Da Saída Hidráulica Dian Teira (Intermédia) [Com Saída Hidráulica Dianteira] / Front Hydraulic Outlet Pipe (Middle) [With Front Hyd. Outlet]
Tubo Da Saída Hidráulica Dian Teira (Parte Dianteira) [Com Saída Hidráulica Diant Eira] / Front Hydraulic Outlet Pipe (Front) [With F Ront Hyd. Outlet]
Tubo Da Saída Hidráulica (Pow Er Beyond/Tubo De Retorno) [Com Power Beyond] / Hyd Raulic Outlet Pipe (Power Beyond/Return Hose) [With Power Beyond]
Valvula Travao Reboque 1/Tubo [Modelo 50km/H:Travão De Trailer De 2 Linha/1+2 Li Nha] / Trailer Brake Valve 1/Pipe [50 Km/H Model:2- Line/1+2-Line Trailer Brake]
Valvula Travao Reboque [Travã O De Trailer De 1 Linha] / Trailer Brake Valve [1-L Ine Trailer Brake]
Valvula Travao Reboque 1/Tubo [Modelo 40km/H:Travão De Trailer De 1+2 Linha] / T Railer Brake Valve 1/Pipe [40 Km/H Model:1+2-Line T Railer Brake]
Valvula Travao Reboque 2/Tubo [Modelo 50km/H:Travão De Trailer De 1+2 Linha] / T Railer Brake Valve 2/Pipe [50 Km/H Model:1+2-Line T Railer Brake]
Valvula Travao Reboque 2/Tubo [Modelo 40km/H:Travão De Trailer De 1+2 Linha] / T Railer Brake Valve 2/Pipe [40 Km/H Model:1+2-Line T Railer Brake]
Tubo Da Válvula Do Travão De Reboque/Acoplamento [Travão De Trailer De 1+2 Linha ] / Trailer Brake Valve Pipe/Coupler [1+2-Line Trai Ler Brake]
Tubo Da Válvula Do Travão De Reboque/Acoplamento [Travão De Trailer De 1 Linha] / Trailer Brake Valve Pipe/Coupler [1-Line Trailer Brake]
Valvula Travao Reboque 3/Tubo [Modelo 50km/H:Travão De Trailer De 1+2 Linha] / T Railer Brake Valve 3/Pipe [50 Km/H Model:1+2-Line T Railer Brake]
Valvula Travao Reboque/Tubo [ Modelo 40km/H:Travão De Trailer De 1+2 Linha] / Tra Iler Brake Valve/Pipe [40 Km/H Model:1+2-Line Trail Er Brake]
Tubo De Óleo Do Carregador (P Arte Traseira) [Tipo De Ccls] [Com Equipamento Do C Arregador] / Front Loader Oil Pipe (Rear) [Ccls Typ E] [With Loader Equipment]
Tubo De Óleo Do Carregador (P Arte Traseira) [Tipo De Oc] [Com Equipamento Do Car Regador] / Front Loader Oil Pipe (Rear) [Oc Type] [ With Loader Equipment]
Tubo De Óleo Do Carregador (P Arte Frente) [Tipo De Ccls] [Com Equipamento Do Car Regador] / Front Loader Oil Pipe (Front) [Ccls Type ] [With Loader Equipment]
Tubo De Óleo Do Carregador (P Arte Frente) [Tipo De Oc] [Com Equipamento Do Carre Gador] / Front Loader Oil Pipe (Front) [Oc Type] [W Ith Loader Equipment]
Compressor De Ar [Com Compressor De Ar] / Air Compressor [With Air Compressor]
Compressor De Ar [Peças Component Es][Com Compressor De Ar] / Air Compressor [Compone Nt Parts] [With Air Compressor]
Secagem [Com Compressor De Ar] / Dryer [With Air Compressor]
Deposito De Ar [Com Compressor De Ar] / Air Tank [With Air Compressor]
Tubo Do Deposito De Ar [Com Compr Essor De Ar] [Tipo De Suspensão(Mola)] / Air Tank P Ipe [With Air Compressor] [Suspension Type (Spring) ]
Tubo Do Deposito De Ar [Com Compr Essor De Ar] [Tipo De Suspensão (Ar)] / Air Tank Pi Pe [With Air Compressor] [Suspension Type (Air)]
Elo 3p D Ianteiro (Elo Estrutura/Superior) [Com 3p Dianteiro ] [Com Saída Hidráulica Dianteira] / Front 3p Link (Frame/Top Link) [With Front 3p] [With Front Hyd. O Utlet]
Elo 3p D Ianteiro (Elo Estrutura/Superior) [Com 3p Dianteiro ] [Sem Saída Hidráulica Dianteira] / Front 3p Link (Frame/Top Link) [With Front 3p] [W/O Front Hyd. Ou Tlet]
Elo 3p D Ianteiro (Içador) [Com 3p Dianteiro] / Front 3p Lin K (Lifter) [With Front 3p]
Ligação 3p Dianteira (Cilindro) [Com 3p Dianteiro] / Front 3p Link (Cylinder) [With Front 3p]
Tdf Dian Teira [Com Tdf Dianteira] / Front Pto [With Front P To]
Caixa Da Engrenagem Tdf 1 (Carreto) [Peças Componentes] [Co M Tdf Dianteira] / Pto Gear Case 1 (Gear) [Componen T Parts] [With Front Pto]
Caixa Da Engrenagem Tdf 2 (Bomba) [Peças Componentes] [Com Tdf Dianteira] / Pto Gear Case 2 (Pump) [Component Parts] [With Front Pto]
Caixa Da Engrenagem Tdf 3 (Embraiagem) [Peças Componentes] [Com Tdf Dianteira] / Pto Gear Case 3 (Clutch) [Com Ponent Parts] [With Front Pto]
Caixa Da Engrenagem Tdf 4 (Caixa) [Peças Componentes] [Com Tdf Dianteira] / Pto Gear Case 4 (Case) [Component Parts] [With Front Pto]
Caixa Da Engrenagem Tdf 5 (Kit De Juntas E Vedantes) [Peças Componentes] [Com Tdf Dianteira] / Pto Gear Case 5 (Gasket And Seal Kit) [Component Parts] [With Fron T Pto]
Suporte Do Elo Superior/Suporte Do Acoplador [Antiga] / Top Link Bracket/Coupler Bracket [Old]
Suporte Do Elo Superior/Suporte Do Acoplador [Nova] / Top L Ink Bracket/Coupler Bracket [New]
Ligação 3 Pontos (Ligação Superior:Manual) / 3-Point Linkag E (Top Link:Manual)
Ligação 3 Pontos (Ligação Superior:Hidráulica) / 3-Point Li Nkage (Top Link:Hydraulic)
Estabili Zador (Elevador) [Com Puxo (Escada)] / Stabilizer(L Ifter) [With Hitch (Ladder)]
Estabili Zador (Elevador) [Com Puxo (Dromone)] / Stabilizer( Lifter) [With Hitch (Dromone)]
Estabili Zador (Elevador) [Peças Componentes] / Stabilizer ( Lifter) [Component Parts]
3-Pont A Coplamento (Tirante) / 3-Point Linkage (Lift Rod)
Puxo Bar Ra / Drawbar Bracket
Barra Re Boque(Engate K80) / Drawbar(Coupling K80)
Barra Re Boque (Fixed Piton) / Drawbar (Fixed Piton)
Barra Re Boque (Cuna) / Drawbar (Cuna)
Cobertur A De Barras De Engate [Com Barra Reboque] / Drawbar Cover [With Drawbar]
Puxo (Es Cada) / Hitch (Ladder)
Puxo (Dr Omone) / Hitch (Dromone)
Puxo (Dr Omone) [Peças Componentes] / Hitch (Dromone) [Compo Nent Parts]
Puxo (Dr Omone) Control Alavanca / Hitch (Dromone) Trailer L Ever
Gancho T Railer (Manual) / Trailer Clevis (Manual)
Gancho T Railer (Automatico) / Trailer Clevis (Automatic)
Gancho T Railer (K80) / Trailer Clevis (K80)
Gancho T Railer (Piton) / Trailer Clevis (Piton)
Gancho T Railer (Cuna-C) / Trailer Clevis (Cuna-C)
Gancho T Railer (Cuna-D2) / Trailer Clevis (Cuna-D2)
Gancho T Railer (Cuna-D3) / Trailer Clevis (Cuna-D3)
Capot Inferior (Direito) / Hood (Bonnet) Side L Ower Rh
Capot Inferior (Esquerdo) [Com Compressor De Ar ] / Hood (Bonnet) Side Lower Lh [With Air Compresso R]
Guarda-Lamas Dianteiro(W:410) / Front Fender(W: 410)
Guarda-Lamas Dianteiro(W:540) / Front Fender(W: 540)
Est Rutura Cabine / Cab Frame
Deg Rau Direito [Com Equipamento Do Carregador] / Step Rh [With Loader Equipment]
Deg Rau Direito [Sem Equipamento Do Carregador] [Com Su Spensão Dianteira] / Step Rh [W/O Loader Equipment] [With Front Suspension]
Deg Rau Direito [Sem Equipamento Do Carregador] [Sem Su Spensão Dianteira] / Step Rh [W/O Loader Equipment] [W/O Front Suspension]
Deg Rau Esquerdo / Step Lh
Cob Ertura Frontal / Front Cover
Vid Ro Frente / Front Glass
Por Ta Drt / Door Rh
Por Ta Esq / Door Lh
Tri Nco Porta Drt / Door Lock Rh
Tri Nco Porta Esq / Door Lock Lh
Tej Adilho / Sun Roof
Esp Elho Rectrovisor / Rearview Mirror
Tec To Interior / Inner Roof
Tec To Abrir / Outer Roof
Sup Orte Do Assento / Seat Bracket
Ban Co / Seat
Ban Co 1 (Almofada) [Peças Componentes] / Seat1 (Seat C Ushion) [Component Parts]
Ban Co 2 (Apoio Braço/Costas Banco) [Peças Componentes] / Seat2 (Armrest/Backrest) [Component Parts]
Sus Pensão Do Assento [Peças Componentes] / Seat Suspen Sion [Component Parts]
Ban Co De Passageiro / Passenger Seat
Tap Ete Do Piso / Floor Mat
Mat Erial À Prova De Som 1 (Painel) / Soundproof Materi Al 1 (Panel)
Mat Erial À Prova De Som 2 (Chão) / Soundproof Material 2 (Floor)
Mat Erial À Prova De Som 3 (Consola) / Soundproof Mater Ial 3 (Console)
Mat Erial À Prova De Som 4 (Tejadilho) / Soundproof Mat Erial 4 (Roof)
Cob Ertura De Mudança (Consola Direita) / Shift Cover ( Console Rh)
Tam Pa Do Rádio E Tampa Do Painel De Controlo Do Ar Con Dicionado / Radio Cover And Air Conditioner Control Panel Cover
Con Sola Do Lado Esquerdo / Console Lh
Res Guardo Coluna / Pillar Cover
Cob Ertura Do Guarda-Lamas / Fender Cover
Gua Rda Lamas (Direito) / Fender Rh
Gua Rda Lamas (Esquerda) / Fender Lh
Gua Rda Lamas / Over Fender
Sup Orte Cabine Frente [Com Equipamento Do Carregador] / Cab Bracket Front [With Loader Equipment]
Sup Orte Cabine Frente [Sem Equipamento Do Carregador] / Cab Bracket Front [W/O Loader Equipment]
Sup Orte Cabine Traseira / Cab Bracket Rear
Tra Seira Amortecedor [Tipo De Suspensão (Mola)] / Rear Damper [Suspension Type (Spring)]
Amo Rtecedor Traseiro [Tipo De Suspensão (Ar)] [Com Com Pressor De Ar] / Rear Damper [Suspension Type (Air) ] [With Air Compressor]
Cai Xa Ferramenta / Tool Box
Ar Condicionado / Air Conditioner
Conduta Do Ar Condicionado (Ar Fr Io) / Air Conditioner Duct (Fresh Air)
Conduta Do Ar Condicionado (Trase Ira) / Air Conditioner Duct (Rear)
Modo Caixa / Mode Case
Entradas Ar Painel Instrumentos / Dashboard Air Outlets
Circulaçao Ar Interior / Inner Ai R Recirculation
Tubo Ar Condicionado/Tubo Condens Ador / Air Conditioner Hose/Condenser Hose
Polia De Acionamento Do Compresso R [Sem Compressor De Ar] / Compressor Drive Pulley [W/O Air Compressor]
Polia De Acionamento Do Compresso R [Com Compressor De Ar] / Compressor Drive Pulley [With Air Compressor]
Compressor (Ar Condicionado) / Co Mpressor (Air Conditioner)
Roda Dianteira (380/85r28) [Michelin] / Front Wheel (380/85r28) [Michelin]
Roda Dianteira (380/85r28) [Firestone ] / Front Wheel (380/85r28) [Firestone]
Roda Dianteira (380/85r28) [Mitas] / Front Wheel (380/85r28) [Mitas]
Roda Dianteira (420/70r28) [Michelin] / Front Wheel (420/70r28) [Michelin]
Roda Dianteira (420/70r28) [Trellebor G] / Front Wheel (420/70r28) [Trelleborg]
Roda Dianteira (420/70r28) [Firestone ] / Front Wheel (420/70r28) [Firestone]
Roda Dianteira (420/70r28) [Mitas] / Front Wheel (420/70r28) [Mitas]
Roda Dianteira (420/85r28) [Michelin] / Front Wheel (420/85r28) [Michelin]
Roda Dianteira (420/85r28) [Trellebor G] / Front Wheel (420/85r28) [Trelleborg]
Roda Dianteira (420/85r28) [Firestone ] / Front Wheel (420/85r28) [Firestone]
Roda Dianteira (420/85r28) [Mitas] / Front Wheel (420/85r28) [Mitas]
Roda Dianteira (480/70r28) [Michelin] / Front Wheel (480/70r28) [Michelin]
Roda Dianteira (480/70r28) [Trellebor G] / Front Wheel (480/70r28) [Trelleborg]
Roda Dianteira (480/70r28) [Firestone ] / Front Wheel (480/70r28) [Firestone]
Roda Dianteira (480/70r28) [Mitas] / Front Wheel (480/70r28) [Mitas]
Roda Dianteira (540/65r28) [Michelin] / Front Wheel (540/65r28) [Michelin]
Roda Dianteira (540/65r28) [Trellebor G] / Front Wheel (540/65r28) [Trelleborg]
Roda Dianteira (540/65r28) [Firestone ] / Front Wheel (540/65r28) [Firestone]
Roda Dianteira (540/65r28) [Mitas] / Front Wheel (540/65r28) [Mitas]
Roda Traseira (460/85r38) [Michelin] / Rear Wheel (460/85r38) [Michelin]
Roda Traseira (460/85r38) [Trelleborg ] / Rear Wheel (460/85r38) [Trelleborg]
Roda Traseira (460/85r38) [Firestone] / Rear Wheel (460/85r38) [Firestone]
Roda Traseira (460/85r38) [Mitas] / R Ear Wheel (460/85r38) [Mitas]
Roda Traseira (520/70r38) [Michelin] / Rear Wheel (520/70r38) [Michelin]
Roda Traseira (520/70r38) [Trelleborg ] / Rear Wheel (520/70r38) [Trelleborg]
Roda Traseira (520/70r38) [Firestone] / Rear Wheel (520/70r38) [Firestone]
Roda Traseira (520/70r38) [Mitas] / R Ear Wheel (520/70r38) [Mitas]
Roda Traseira (520/85r38) [Trelleborg ] / Rear Wheel (520/85r38) [Trelleborg]
Roda Traseira (520/85r38) [Firestone] / Rear Wheel (520/85r38) [Firestone]
Roda Traseira (520/85r38) [Mitas] / R Ear Wheel (520/85r38) [Mitas]
Roda Traseira (580/70r38) [Michelin] / Rear Wheel (580/70r38) [Michelin]
Roda Traseira (580/70r38) [Trelleborg ] / Rear Wheel (580/70r38) [Trelleborg]
Roda Traseira (580/70r38) [Firestone] / Rear Wheel (580/70r38) [Firestone]
Roda Traseira (580/70r38) [Mitas] / R Ear Wheel (580/70r38) [Mitas]
Roda Traseira (650/65r38) [Michelin] / Rear Wheel (650/65r38) [Michelin]
Roda Traseira (650/65r38) [Trelleborg ] / Rear Wheel (650/65r38) [Trelleborg]
Roda Traseira (650/65r38) [Firestone] / Rear Wheel (650/65r38) [Firestone]
Roda Traseira (650/65r38) [Mitas] / R Ear Wheel (650/65r38) [Mitas]
Etiqueta (Frente) [Com Equipamento Do Carregador ] / Label (Front) [With Loader Equipment]
Etiqueta (Frente) [Sem Equipamento Do Carregador ] / Label (Front) [W/O Loader Equipment]
Etiqueta (Unidade Control Electrico/Controlador) / Label (Ecu/Controller)
Decalcomania (Cabine Interior) / Label (Cab Inte Rior)
Acessorios / Accessories
K It Alternador (200a) [Opção] / Alternator Kit (200a ) [Option]
A Lternador [Peças Componentes] (200a) [Opção] / Alte Rnator [Component Parts] (200a) [Option]
L Uzes Frente (Farol De Repetição) [Opçao] / Head Lig Ht Kit (Repeat Head Light) [Option]
K It De Luz Interior [Opção] / Room Light Kit [Option ]
K It Da Tdf Dianteira (6 Estrias) (Caixa Da Engrenage M) [Opção] / Front Pto Kit (6 Splines) (Gear Case) [Option]
K It Da Tdf Dianteira (6 Estrias) (Caixa Da Engrenage M/Junta) [Peças Componentes] [Opção] / Front Pto Ki T (6 Splines) (Gear Case/Gasket) [Component Parts] [Option]
K It Da Tdf Dianteira (6 Estrias) (Arrefecedor Do Óle O) [Opção] / Front Pto Kit (6 Splines) (Oil Cooler) [Option]
K It Do Sensor (Radar) [Opção] / Sensor Kit (Radar) [ Option]
K It De 21 Estrias De Tdf [Opção] [Ec] / Pto Kit (21 Splines) [Option] [Ec]
E Spelho Retrovisor Com Kit De Aquecedor [Opção] / Re Arview Mirror Kit (With Heater) [Option]
K It De Acoplador (Saída Hidráulica Dianteira/Mecânic A) (Tubo) [Com Suspensão Frontal] [Opção] / Coupler Kit (Front Hyd. Outlet/Mech) (Pipe) [With Front Su Spension] [Option]
K It De Acoplador (Saída Hidráulica Dianteira/Mecânic A) (Tubo) [Sem Suspensão Frontal] [Opção] / Coupler Kit (Front Hyd. Outlet/Mech) (Pipe) [W/O Front Sus Pension] [Option]
K It De Acoplador (Saída Hidráulica Dianteira/Mecânic A)(Acoplador/Tubo) [Com Suspensão Dianteira] [Opção ] / Coupler Kit (Front Hyd. Outlet/Mech.) (Coupler/ Pipe) [With Front Suspension] [Option]
K It De Acoplador (Saída Hidráulica Dianteira/Mecânic A) (Acoplador/Tubo) [Sem Suspensão Frontal] [Opção] / Coupler Kit (Front Hyd. Outlet/Mech) (Coupler/Pi Pe) [W/O Front Suspension] [Option]
L Igacao Superior (Hidráulica) [Opção] / Top Link Kit (Hydraulic) [Option]
K It De Escora (Padrão) [Opção] / Drawbar Kit (Standa Rd) [Option]
K It De Escora (Cuna) [Opção] / Drawbar Kit (Cuna) [O Ption]
K It De Escora (Acoplamento K80) [Opção] / Drawbar Ki T (Coupling K80) [Option]
K It De Escora (Pistão Fixo) [Opção] [Antiga] / Drawb Ar Kit (Fix Piton) [Option] [Old]
K It De Escora (Pistão Fixo) [Opção] [Nova] / Drawbar Kit (Fix Piton) [Option] [New]
K It Desnebulizador Traseiro / Rear Defogger Kit
K It Protetor De Para-Sol [Opção] / Sunshade Shield K It [Option]
