Kubota Tractor M7132P M7132KVT Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M7132P ; M7132KVT Tractor
Number of Pages: 682 Pages
Itens Usado S Frequentemente [Com Compressor De Ar] / Frequentl Y Used Items [With Air Compresser]
Itens Usado S Frequentemente (Componenetes Electricos) / Freque Ntly Used Items (Electrical Parts)
Bloco Motor(Superior) / Crankcase (Upper)
Bloco Motor(Inferior) / Crankcase (Lower)
Cárter Do Óleo [Com Compressor De Ar] / Oil Pan [With Air Compressor]
Cárter Do Óleo [Sem Compressor De Ar] / Oil Pan [W/O Air Compressor]
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exha Ust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Bomba De Abastecimento / Supply Pump
Injector E Vela Aquecimento / Injector And Glow Plug
Common Rail / Common Rail
Bomba Agua / Water Pump
Radiador Oleo / Oil Cooler
Separador De Óleo [Peças Componentes] / Oil Sepa Rator [Component Parts]
Tubo Do Separador De Óleo / Oil Separator Pipe
Filtro Ar [Sem Tdf Dianteira] / Air Cleaner [W/O Front Pto]
Filtro Ar [Com Tdf Dianteira] / Air Cleaner [Wit H Front Pto]
Filtro Ar [Peças Componentes] / Air Cleaner [Com Ponent Parts]
Tubo De Entrada (Filtro De Ar) [Com Compressor D E Ar] / Inlet Pipe (Air Cleaner) [With Air Compress Er]
Tubo De Entrada (Filtro De Ar) [Sem Compressor D E Ar] / Inlet Pipe (Air Cleaner) [W/O Air Compresse R]
Flange Filtro Ar E Valvula Acelarador / Air Clea Ner Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubos De Água Egr / Egr Water Piping
Silenciador Do Filtro De Partículas Diesel / Die Sel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peça S Componentes] / Diesel Particulate Filter Muffler [Component Parts]
Tubo Pressao / Pressure Pipe
Panela Escape / Muffler Pipe
Silenciador Da Redução Catalítica Seletiva / Sel Ective Catalytic Reduction Muffler
Resguardo Da Redução Catalítica Seletiva [Antiga ] / Selective Catalytic Reduction Cover [Old]
Resguardo Da Redução Catalítica Seletiva [Nova] / Selective Catalytic Reduction Cover [New]
Tubulação E Proteção Do Silênciador / Muffler Pi Pe And Cover
Bomba Do Fluido De Escape De Diesel / Diesel Exh Aust Fluid Pump
Depósito Do Fluido De Escape De Diesel / Diesel Exhaust Fluid Tank
Depósito Do Fluido De Escape De Diesel [Peças Co Mponentes] / Diesel Exhaust Fluid Tank [Component Parts]
Depósito Do Fluido De Escape De Diesel Tubo / Di Esel Exhaust Fluid Hose
Depósito Do Fluido De Escape De Diesel Aquecedor Tubo / Diesel Exhaust Fluid Heater Hose
Depósito Do Fluido De Escape De Diesel Mangueira De Respiro / Diesel Exhaust Fluid Breather Hose
Válvula Egr (Sistema De Redução Catalítica Selet Iva) / Egr Valve (Selective Catalytic Reduction Sys Tem)
Sistema De Arrefecimento Egr (Sistema De Redução Catalítica Seletiva) / Egr Cooler (Selective Catal Ytic Reduction System)
Tubo Egr (Sistema De Redução Catalítica Seletiva ) / Egr Pipe (Selective Catalytic Reduction System)
Tubos De Água Egr (Sistema De Redução Catalítica Seletiva) / Egr Water Piping (Selective Catalytic Reduction System)
Cobertura De Escape De Exaustão/Tampa De Recircu Lação De Gás De Escape / Exhaust Manifold Cover/Egr Cover
Componentes Electricos Motor (Sensor/Ecu) / Engi Ne Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape) / E Ngine Electrical Parts (Muffler)
Deposito Combustivel [Anti Ga] / Fuel Tank [Old]
Deposito Combustivel [Nova ] / Fuel Tank [New]
Suporte Deposito Combustiv El [Com Equipamento Do Carregador] / Fuel Tank Brac Ket [With Loader Equipment]
Suporte Deposito Combustiv El [Sem Equipamento Do Carregador] / Fuel Tank Brac Ket [W/O Loader Equipment]
Tubo Do Combustível (Enchi Mento Do Combustível) / Fuel Pipe (Fuel Filter)
Tubo Combustivel (Arrefece Dor Gasoleo) / Fuel Pipe (Fuel Cooler)
Arrefecedor Gasoleo / Fuel Cooler
Separador / Separator
Separador [Peças Component Es] / Separator [Component Parts]
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Compo Nentes] / Fuel Pump [Component Parts]
Filtro Gasoleo / Fuel Filt Er
Filtro Gasoleo [Peças Comp Onentes] / Fuel Filter [Component Parts]
Suporte Ventilador / Fan Bracket
Polia De Acionamento Da Ventoinha / Fan Drive Pulley
Ventoinh A / Fan
Tubo De Água E Tubo Do Sistema De Arrefecimento / Water Pip E And Cooler Pipe
Unidade Do Sistema De Arrefecimento / Cooler Unit
Unidade Do Arrefecedor (Radiador) [Peças Componentes] / Coo Ler Unit (Radiator) [Component Parts]
Unidade Do Arrefecedor (Permutador Intermédio De Calor) [Pe Ças Componentes] / Cooler Unit (Inter Cooler) [Comp Onent Parts]
Unidade Do Arrefecedor (Arrefecedor Do Óleo) [Peças Compone Ntes] / Cooler Unit (Oil Cooler) [Component Parts]
Unidade Do Arrefecedor (Condensador) [Peças Componentes] / Cooler Unit (Condenser) [Component Parts]
Tubo Do Depósito De Reserva [Com Compressor De Ar] / Reserv E Tank Hose [With Air Compressor]
Tubo Do Depósito De Reserva [Sem Compressor De Ar] / Reserv E Tank Hose [W/O Air Compressor]
Alternador (200a) / Alter Nator (200a)
Alternador (150a) / Alter Nator (150a)
Alternador (200a) [Peças Componentes] / Alternator (200a) [Component Parts]
Alternador (150a) [Peças Componentes] / Alternator (150a) [Component Parts]
Motor Arranque / Starter
Battery Bracket / Battery Bracket
Suporte De Bateria / Batt Ery Bracket
Interruptor/Sensor (Bloco Motor Esquerda) / Switch/Sensor (Engine Lh)
Interruptor/Sensor (Bloco Motor Direita) / Switch/Sensor (Engine Rh)
Sensor Da Redução Catalít Ica Seletiva / Selective Catalytic Reduction Sensor
Suspensão Frontal Sensor / Front Suspension Sensor
Sensor (Pedal) / Sensor ( Pedal)
Interruptor/Sensor [Com C Ompressor De Ar] / Switch/Sensor [With Air Compress Or]
Interruptor/Sensor [Sem C Ompressor De Ar] / Switch/Sensor [W/O Air Compresso R]
Sensor (Caixa De Transmis São) / Sensor (Transmission Housing Rh)
Sensor (Caixa De Transmis São) / Sensor (Transmission Housing Lh)
Sensor Da Conicidade/Sens Or 3p [Com Puxo (Escada)] / Draft Sensor/3p Sensor [With Hitch (Ladder)]
Sensor Da Conicidade/Sens Or 3p [Com Puxo (Dromone)] / Draft Sensor/3p Sensor [With Hitch (Dromone)]
Interruptor (Direcção) [C Om Direção Automática] / Switch (Steering) [Auto St Eering Compatible]
Interruptor (Direcção) [S Em Direção Automática] / Switch (Steering) [Auto St Eering Incompatible]
Interruptor (Cobertura De Mudança) / Switch (Shift Cover)
Interruptor (Consola Do L Ado Esquerdo) / Switch (Console Lh)
Interruptor Externo / Ext Ernal Switch
Relé/Controlador / Relay/ Controller
Unidade Control Electrico (Bloco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico /Controlador [Com Compressor De Ar] / Electronic Co Ntrol Unit/Controller [With Air Compressor]
Unidade Control Electrico /Controlador [Sem Compressor De Ar] / Electronic Co Ntrol Unit/Controller [W/O Air Compressor]
Controlador (Ceu) / Contr Oller (Ceu)
Controlador (Ceu) [Peças Componentes] / Controller (Ceu) [Component Parts]
Painel / Panel
Peças Elétricas Da Trasei Ra Interior Da Cabine (Saída Elétrica/Painel De Con Trolo Do Ar Condicionado) / Cab Inner Rear Electric Al Parts (Electrical Outlet/Air Conditioner Control Panel)
Terminal Isobus / Isobus Terminal
Apoio De Braço [Com Contr Ole De Video Game] [Com Tdf Dianteira] / Armrest [W Ith Joystick] [With Front Pto]
Apoio De Braço [Com Contr Ole De Video Game] [Sem Tdf Dianteira] / Armrest [W Ith Joystick] [W/O Front Pto]
Apoio De Braço [Sem Contr Ole De Video Game] [Sem Tdf Dianteira] / Armrest [W /O Joystick] [W/O Front Pto]
Terminal (12 Polegadas) / Terminal (12 Inch)
Terminal (7 Polegadas) / Terminal (7 Inch)
Luzes Frente / Head Light
Luzes Frente (Coluna) / H Ead Light (Pillar)
Lâmpada Farol / Beacon La Mp
Lámpada De Pisca Pisca [N Ova] / Lamp Of Side Marker [New]
Luzes Frontais / Front Co Mbination Lamp
Luz De Trabalho (Dianteir O/Teto) / Work Light (Front/Roof)
Luz De Trabalho (Dianteir O/Coluna) / Work Light (Front/Pillar)
Luz De Trabalho (Traseiro /Teto) / Work Light (Rear/Roof)
Luz De Trabalho (Traseiro /Coluna) / Work Light (Rear/Pillar)
Braco Traseiro / Rear Com Bination Lamp
Ficha Reboque [Travão De Trailer De 1 Linha] / Trailer Socket [1-Line Traler Brake]
Luz Interior / Room Light
Alta Voz Radio / Radio Sp Eaker
Depósito De Lavagem / Was Her Tank
Escova / Wiper
Cablagem Elétrica (Motor) 1 (Filtro De Ar/Dpf) / Electrical Wiring (Engine) 1 (Air Cleaner/Dpf)
Cablagem Elétrica (Motor) 2 (Crs) / Electrical Wiring (Engine) 2 (Crs)
Cablagem Elétrica (Motor) 3 (Combustível/Scr) [Com Compressor De Ar] / Elect Rical Wiring (Engine) 3 (Fuel/Scr) [With Air Compre Ssor]
Cablagem Elétrica (Motor) 3 (Combustível/Scr) [Sem Compressor De Ar] / Elect Rical Wiring (Engine) 3 (Fuel/Scr) [W/O Air Compres Sor]
Cablagem Elétrica (Motor) 4 (Fusível/Bateria) / Electrical Wiring (Engine) 4 (Fuse/Battery)
Cablagem Elétrica (Motor) 5 (Compressor/Volante) [Com Compressor De Ar] / El Ectrical Wiring (Engine) 5 (Compressor/Flywheel) [W Ith Air Compresser]
Cablagem Elétrica (Motor) 5 (Compressor/Volante) [Sem Compressor De Ar] / El Ectrical Wiring (Engine) 5 (Compressor/Flywheel) [W /O Air Compresser]
Cablagem Elétrica (Capot) / Electrical Wiring (Bonnet(Hood))
Cablagem Eletrica (Altern Ador 200a) / Electrical Wiring (Alternator 200a)
Cablagem Eletrica (Altern Ador 150a) / Electrical Wiring (Alternator 150a)
Cablagem Eletrica (Motor Arranque) / Electrical Wiring (Starter)
Cablagem Electrica (Fonte De Alimentação/Controlador (Ceu)) / Electrical Wir Ing (Power Supply/Controller (Ceu))
Cablagem Electrica (Eixo Tranversal/Frente) [Com Compressor De Ar] [Com Susp Ensão Dianteira] / Electrical Wiring (Transaxle/Fro Nt) [With Air Compresser] [With Front Suspension]
Cablagem Electrica (Eixo Tranversal/Frente) [Sem Compressor De Ar] [Com Susp Ensão Frontal] / Electrical Wiring (Transaxle/Front ) [W/O Air Compresser] [With Front Suspension]
Cablagem Electrica (Eixo Tranversal/Traseira) [Antiga] / Electrical Wiring ( Transaxle/Rear) [Old]
Cablagem Electrica (Eixo Tranversal/Traseira) [Nova] / Electrical Wiring (Tr Ansaxle/Rear) [New]
Cablagem Electrica (Distr Ibuidor Auxiliar) / Electrical Wiring (Remote Contr Ol Valve)
Cablagem Electrica(Etcv V Alvula/Secagem) [Com Compressor De Ar] / Electrical Wiring (Etcv Valve/Air Dryer) [With Air Compressor ]
Cablagem Elétrica (Cabine ) 1 (Direção/Painel) / Electrical Wiring (Cab) 1 (S Teering/Panel)
Cablagem Elétrica (Cabine ) 2 (Ecu) / Electrical Wiring (Cab) 2 (Ecu)
Cablagem Elétrica (Cabine ) 3 (Cobertura Das Mudanças/Apoio De Braço) / Elect Rical Wiring (Cab) 3 (Shift Cover/Armrest)
Cablagem Elétrica (Cabine ) 4 (Ar Condicionado) [Modelo 50km/H] / Electrical Wiring (Cab) 4 (Air Conditioner) [50 Km/H Model]
Cablagem Elétrica (Cabine ) 4 (Ar Condicionado) [Modelo 40km/H] / Electrical Wiring (Cab) 4 (Air Conditioner) [40 Km/H Model]
Cablagem Elétrica (Pilar Dianteiro) [Antigo] / Electrical Wiring (Front Pill Ar) [Old]
Cablagem Elétrica (Pilar Dianteiro) [Novo] / Electrical Wiring (Front Pillar ) [New]
Cablagem Electrica (Teto) / Electrical Wiring (Roof)
Cablagem Electrica (Pisca /Pára-Lama) / Electrical Wiring (Flasher/Mudguard)
Cablagem Electrica [Com 3 P Dianteiro] [Antiga] / Electrical Wiring [With Fro Nt 3p] [Old]
Cablagem Electrica [Com 3 P Dianteiro] [Nova] / Electrical Wiring [With Front 3p] [New]
Cablagem Electrica (Suspe Nsão Dianteira) / Electrical Wiring (Front Suspensi On)
Cablagem Electrica (Com D Ireção Automática) [Com Direção Automática] / Elect Rical Wiring (Auto Steering) [Auto Steering Compati Ble]
Cablagem Electrica (Isobu S) / Electrical Wiring (Isobus)
Disco Do Amorteced Or E Ligação À Caixa / Damper Disk And Housing Conn Ection
Caixa Da Transmiss Ão / Transmission Case
Caixa De Transmiss Ão / Transmission Housing
Caixa De Plugue / Housing Plug
Caixa Do Eixo Tras Eiro / Rear Axle Housing
Estrutura Do Veio Tdf / Pto Shaft Housing
Braco Hidraulico / Lift Arm
Estrutura Interior Do Veio Tdf (Embreagem) / Pto Shaft Housing Inner (Clutch)
Estrutura Interior Do Veio Tdf (Engrenagem) / Pto Shaft Housing Inner (Gear)
Estrutura Interior Do Veio Tdf (Veio Tdf) / Pto Shaft Housing Inner ( Pto Shaft)
Estrutura Interior Do Veio Tdf (Forquilha De Embraiagem) / Pto Shaft Housing Inner (Shift Fork)
Unidade Hidráulica / Hydraulic Unit
Hidráulica Bomba D E Moradia / Hydraulic Pump Housing
Condutas Hidráulic As / Hydraulic Piping
Unidade De Control O Hidráulico/Filtro / Hydraulic Control Unit/Filter
Válvula Solenóide/ Regulador De Pressão / Solenoid Valve/Pressure Regu Later
Alvanca Inversor / Shuttle Shi Ft Lever
Eixo Traseiro / Rear Ax Le
Diferencial Traseiro / Rear Differential
Travão / Brake
Eixo Traseiro / Brake S Haft
Alavanca Travao Mao / P Arking Brake Lever
Pedal Travao / Brake Pe Dal
Cilindro Travao Princip Al / Brake Master Cylinder
Tubo Do Travão 1 (Super Ior/Parte Dianteira) [Travão De Trailer De 1 Linha] / Brake Pipe 1 (Upper/Front) [1-Line Traler Brake]
Tubo Do Travão 1 (Super Ior/Parte Dianteira) [Travão De Trailer De 2 Linha] / Brake Pipe 1 (Upper/Front) [2-Line Traler Brake]
Tubo Do Travão 2 (Infer Ior/Parte Traseira) [Travão De Trailer De 1 Linha] [Com Compressor De Ar] / Brake Pipe 2 (Lower/Rear) [1-Line Traler Brake] [With Air Compressor]
Tubo Do Travão 2 (Infer Ior/Parte Traseira) [Travão De Trailer De 1 Linha] [Sem Compressor De Ar] / Brake Pipe 2 (Lower/Rear) [1-Line Traler Brake] [W/O Air Compressor]
Tubo Do Travão 2 (Infer Ior/Parte Traseira) [Travão De Trailer De 2 Linha] / Brake Pipe 2 (Lower/Rear) [2-Line Traler Brake]
Estrutura Do Eixo Di Anteiro [Com Suspensão Frontal] [Com 3p Dianteiro] / Front Axle Frame [With Front Suspension] [With Fr Ont 3p]
Balanceiro Da Suspen São Dianteira [Com 3p Dianteiro] [Antiga] / Front S Uspension Rocker Arm [With Front 3p] [Old]
Balanceiro Da Suspen São Dianteira [Com 3p Dianteiro] [Nova] / Front Sus Pension Rocker Arm [With Front 3p] [New]
Eixo Dianteiro / Fro Nt Axle
Eixo Dianteiro [Com Suspensão Frontal] / Front Axle [With Front Suspens Ion]
Suporte Eixo Frente [Eixo Dianteiro Peças Componentes] / Front Axle Bra Cket [Front Axle Component]
Suporte Do Eixo Dian Teiro [Com Suspensão Dianteira] [Eixo Dianteiro: Ti Po Pesado] / Front Axle Bracket [Front Axle Compone Nt] [With Front Suspension]
Carter Eixo Frente [ Eixo Dianteiro Peças Componentes] / Front Axle Hous Ing [Front Axle Component]
Diferencial Dianteir O [Eixo Dianteiro Peças Componentes] / Front Differ Ential [Front Axle Component]
Veio Carreto Diferen Cial [Eixo Dianteiro Peças Componentes] / Different Ial Gear Shaft [Front Axle Component]
Sensor De Ângulo De Viragem Roda [Eixo Dianteiro Peças Componentes] / W Heel Turning Angle Sensor [Front Axle Component]
Tirante/Cilindro Dir Ecção [Eixo Dianteiro Peças Componentes] / Tie Rod/ Steering Cylinder [Front Axle Component]
Veio Do Propulsor E Resguardo / Propeller Shaft And Cover
Veio Do Propulsor E Resguardo [Com Suspensão Dianteira] / Propeller Sha Ft And Cover [With Front Suspension]
Direcção Assistida [Peças Componentes] / St Eering Post [Component Parts]
Pedal Inclinacao / Tilt Pedal
Comando De Direção [Com Direção Automática] / Steering Controller [Auto Steering Compatible]
Comando De Direção [Sem Direção Automática] / Steering Controller [Auto Steering Incompatible]
Circuito Oleo Direcção (R Adiador Oleo/Frente) / Hydraulic Oil Line (Oil Cool Er/Front)
Circuito Oleo Direcção (R Adiador Oleo/Traseira) / Hydraulic Oil Line (Oil Co Oler/Rear)
Radiador Oleo [Com Tdf Di Anteira] / Oil Cooler [With Front Pto]
Circuito Oleo Direcção (D Irecção Valvula/Filtro) [Com Compressor De Ar] / Hy Draulic Oil Line (Steering Valve/Filter) [With Air Compresser]
Filtro Oleo 2 [Peças Comp Onentes] / Oil Filter 2 [Component Parts]
Circuito Oleo Direcção (D Irecção Valvula) / Hydraulic Oil Line (Steering Val Ve)
Tubo Direccao (Fornecimen To) / Steering Hose (Delivery)
Tubo Direccao (Delivery) [Com Suspensão Frontal] / Steering Hose (Delivery) [With Front Suspension]
Linha De Óleo Hidráulico (Tubo De Fornecimento Do Eixo Dianteiro/Traseiro) / Hydraulic Oil Line (Front Axle Delivery Pipe/Front )
Linha De Óleo Hidráulico (Tubo De Fornecimento Do Eixo Dianteiro/Traseiro) / Hydraulic Oil Line (Front Axle Delivery Pipe/Rear)
Linha De Óleo Hidráulico (Filtro De Óleo) [Travão De Trailer De 1 Linha] / H Ydraulic Oil Line (Oil Filter) [1-Line Trailer Brak E]
Linha De Óleo Hidráulico (Filtro De Óleo) [Travão De Trailer De 2 Linha/1+2 Linha] / Hydraulic Oil Line (Oil Filter) [2-Line/1+ 2-Line Trailer Brake]
Linha De Óleo Hidráulico (Filtro De Óleo A Válvula De Controlo Remoto/Abertu Ra De Drenagem Hidráulica) [Travão De Trailer De 1 Linha] [Com Equipamento Do Carregador] / Hydraulic Oil Line (Oil Filter To Remote Control Valve/Hyd. D Rain Port) [1-Line Trailer Brake] [With Loader Equi Pment]
Linha De Óleo Hidráulico (Filtro De Óleo A Válvula De Controlo Remoto/Abertu Ra De Drenagem Hidráulica) [Travão De Trailer De 1 Linha] [Sem Equipamento Do Carregador] / Hydraulic Oil Line (Oil Filter To Remote Control Valve/Hyd. D Rain Port) [1-Line Trailer Brake] [W/O Loader Frame ]
Linha De Óleo Hidráulico (Filtro De Óleo A Válvula De Controlo Remoto/Abertu Ra De Drenagem Hidráulica) [Modelo 50km/H:Travão De Trailer De 2 Linha] / Hydraulic Oil Line (Oil Filt Er To Remote Control Valve/Hyd. Drain Port) [50 Km/ H Model:2-Line Trailer Brake]
Linha De Óleo Hidráulico (Filtro De Óleo A Válvula De Controlo Remoto/Abertu Ra De Drenagem Hidráulica) [Modelo 40km/H:Travão De Trailer De 2 Linha] / Hydraulic Oil Line (Oil Filt Er To Remote Control Valve/Hyd. Drain Port) [40 Km/ H Model:2-Line Trailer Brake]
Linha De Óleo Hidráulico (Tubo Do Travão A Válvula De Controlo Remoto) / Hyd Raulic Oil Line (Brake Pipe To Remote Control Valve )
Linha De Óleo Hidráulico (Tubo Do Travão A Válvula De Controlo Remoto) [Com Suspensão Dianteira] / Hydraulic Oil Line (Brake Pi Pe To Remote Control Valve) [With Front Suspension]
Bloco De Válvula 1 (Eixo Tranversal) / Valve Block 1 (Transaxle)
Bloco De Válvula 2 (Válvu La Solenóide) / Valve Block 2 (Solenoid Valve)
Axial Bomba [Com Equipame Nto Do Carregador] / Axial Pump [With Loader Equipm Ent]
Axial Bomba [Sem Equipame Nto Do Carregador] / Axial Pump [W/O Loader Equipme Nt]
Tubulação De Bomba Axial [Com Suspensão Dianteira] [Com Equipamento Do Carre Gador] / Axial Pump Piping [With Front Suspension] [With Loader Equipment]
Tubulação De Bomba Axial [Com Suspensão Dianteira] [Sem Equipamento Do Carre Gador] / Axial Pump Piping [With Front Suspension] [W/O Loader Equipment]
Linha De Óleo Hidráulico (Bomba Axial A Válvula De Controlo Remoto) [Com Sus Pensão Dianteira] [Com Equipamento Do Carregador] / Hydraulic Oil Line (Axial Pump To Remote Control V Alve) [With Front Suspension] [With Loader Equipmen T]
Linha De Óleo Hidráulico (Bomba Axial A Válvula De Controlo Remoto) [Com Sus Pensão Dianteira] [Sem Equipamento Do Carregador] / Hydraulic Oil Line (Axial Pump To Remote Control V Alve) [With Front Suspension] [W/O Loader Equipment ]
Tubo Da Válvula Da Suspen São Dianteira (Parte Traseira) [Com Saída Hidráulic A Dianteira] / Front Suspension Valve Pipe (Rear) [ With Front Hyd. Outlet]
Tubo Da Válvula Da Suspen São Dianteira (Parte Traseira) [Sem Saída Hidráulic A Dianteira] / Front Suspension Valve Pipe (Rear) [ W/O Front Hyd. Outlet]
Valvula Da Suspensão Fron Tal / Front Suspension Valve
Valvula Da Suspensão Fron Tal [Peças Componentes] / Front Suspension Valve [C Omponent Parts]
Tubo Da Válvula Da Suspen São Dianteira (Frente) [Com Saída Hidráulica Diante Ira] / Front Suspension Valve Pipe (Front) [With Fr Ont Hyd. Outlet]
Tubo Da Válvula Da Suspen São Dianteira (Frente) [Sem Saída Hidráulica Diante Ira] / Front Suspension Valve Pipe (Front) [W/O Fro Nt Hyd. Outlet]
Suspensão Frontal Acumula Dor / Front Suspension Accumulator
Suspensão Frontal Cilindr O Tubo / Front Suspension Cylinder Hose
Válvula De Controlo Remot O (6 Válvulas) [Com Saída Hidráulica Dianteira] / R Emote Control Valve (6 Valves) [With Front Hyd. Out Let]
Válvula De Controlo Remot O (6 Válvulas) [Sem Saída Hidráulica Dianteira] / R Emote Control Valve (6 Valves) [W/O Front Hyd. Outl Et]
Válvula De Controlo Remot O (5 Válvulas) [Com Saída Hidráulica Dianteira] / R Emote Control Valve (5 Valves) [With Front Hyd. Out Let]
Válvula De Controlo Remot O (5 Válvulas) [Sem Saída Hidráulica Dianteira] / R Emote Control Valve (5 Valves) [W/O Front Hyd. Outl Et]
Válvula De Controlo Remot O (6 Válvulas) [Peças Componentes] / Auxiliary Cont Rol Valve (6 Valves) [Component Parts]
Válvula De Controlo Remot O (5 Válvulas) [Peças Componentes] / Auxiliary Cont Rol Valve (5 Valves) [Component Parts]
Válvula De Controle Direc Ional (6 Válvulas) [Peças Componentes] / Directiona L Control Valve (6 Valves) [Component Parts]
Válvula De Controle Direc Ional (5 Válvulas) [Peças Componentes] / Directiona L Control Valve (5 Valves) [Component Parts]
Válvula De Placa End [Peç As Componentes] / End Plate Valve [Component Parts]
Coletor De Óleo (Válvula De Controlo Remoto) [4p] [Antiga] / Oil Collector(R Emote Control Valve) [4p] [Old]
Coletor De Óleo (Válvula De Controlo Remoto) [4p] [Nova] / Oil Collector(Rem Ote Control Valve) [4p] [New]
Coletor De Óleo (Válvula De Controlo Remoto) [5p] [Antiga] / Oil Collector(R Emote Control Valve) [5p] [Old]
Coletor De Óleo (Válvula De Controlo Remoto) [5p] [Nova] / Oil Collector(Rem Ote Control Valve) [5p] [New]
Coletor De Óleo (Válvula De Controlo Remoto) [3p] [Antiga] / Oil Collector(R Emote Control Valve) [3p] [Old]
Coletor De Óleo (Válvula De Controlo Remoto) [3p] [Nova] / Oil Collector(Rem Ote Control Valve) [3p] [New]
Tubo Da Saída Hidráulica Dianteira (Parte Traseira) [Com Saída Hidráulica Di Anteira] / Front Hydraulic Outlet Pipe (Rear) [With Front Hyd. Outlet]
Tubo Da Saída Hidráulica Dianteira (Intermédia) [Com Saída Hidráulica Diante Ira] / Front Hydraulic Outlet Pipe (Middle) [With F Ront Hyd. Outlet]
Tubo Da Saída Hidráulica Dianteira (Parte Dianteira) [Com Saída Hidráulica D Ianteira] / Front Hydraulic Outlet Pipe (Front) [Wi Th Front Hyd. Outlet]
Tubo Da Saída Hidráulica (Tubo De Controlo Do Sensor De Carga) / Hydraulic O Utlet Pipe (Load-Sensing Control Hose)
Tubo Da Saída Hidráulica (Power Beyond/Tubo De Retorno) / Hydraulic Outlet P Ipe (Power Beyond/Return Hose)
Valvula Travao Reboque [T Ravão De Trailer De 1 Linha] / Trailer Brake Valve [1-Line Trailer Brake]
Valvula Travao Reboque 1 [Modelo 40km/H:Travão De Trailer De 2 Linha] / Trai Ler Brake Valve 1 [40 Km/H Model:2-Line Trailer Bra Ke]
Valvula Travao Reboque 2/ Tubo [Modelo 50km/H:Travão De Trailer De 2 Linha] / Trailer Brake Valve 2/Pipe [50 Km/H Model:2-Line T Railer Brake]
Valvula Travao Reboque 2/ Tubo [Modelo 40km/H:Travão De Trailer De 2 Linha] / Trailer Brake Valve 2/Pipe [40 Km/H Model:2-Line T Railer Brake]
Valvula Travao Reboque 2/ Tubo [Travão De Trailer De 1+2 Linha] / Trailer Bra Ke Valve 2/Pipe [1+2-Line Trailer Brake]
Tubo Da Válvula Do Travão De Reboque/Acoplamento [Travão De Trailer De 1 Lin Ha] / Trailer Brake Valve Pipe/Coupler [1-Line Trai Ler Brake]
Tubo Da Válvula Do Travão De Reboque/Acoplamento [Travão De Trailer De 1+2 L Inha] / Trailer Brake Valve Pipe/Coupler [1+2-Line Trailer Brake]
Valvula Travao Reboque 3/ Tubo [Travão De Trailer De 1+2 Linha] / Trailer Bra Ke Valve 3/Pipe [1+2-Line Trailer Brake]
Tubo De Óleo Do Carregado R (Parte Traseira) [Com Equipamento Do Carregador] / Front Loader Oil Pipe (Rear) [With Loader Equipme Nt]
Tubo De Óleo Do Carregado R (Parte Dianteira) [Com Equipamento Do Carregador] / Front Loader Oil Pipe (Front) [With Loader Equip Ment]
Compressor De Ar [Com Compres Sor De Ar] / Air Compressor [With Air Compressor]
Compressor De Ar [Peças Compo Nentes][Com Compressor De Ar] / Air Compressor [Com Ponent Parts] [With Air Compressor]
Tubo Do Compressor De Ar [Com Compressor De Ar] / Air Compressor Pipe [With Air Compressor]
Tubo De Refrigeração [Com Com Pressor De Ar] / Cooling Pipe [With Air Compressor]
Secagem [Com Compressor De Ar ] / Dryer [With Air Compressor]
Deposito De Ar [Com Compresso R De Ar] / Air Tank [With Air Compressor]
Tubo Do Deposito De Ar [Com C Ompressor De Ar] [Tipo De Suspensão Traseira (Mola) ] / Air Tank Pipe [With Air Compressor] [Rear Suspe Nsion Type (Spring)]
Tubo Do Deposito De Ar [Com C Ompressor De Ar] [Tipo De Suspensão Traseira (Ar)] / Air Tank Pipe [With Air Compressor] [Rear Suspens Ion Type (Air)]
Acoplador De Ar [Com Compress Or De Ar] / Air Coupler [With Air Compressor]
Elo 3p Dianteiro (Elo Estrutura/Superior) [Com Saída Hi Dráulica Dianteira] / Front 3p Link (Frame/Top Link ) [With Front Hyd. Outlet]
Elo 3p Dianteiro (Elo Estrutura/Superior) [Sem Saída Hi Dráulica Dianteira] / Front 3p Link (Frame/Top Link ) [W/O Front Hyd. Outlet]
Liga Ção 3p Dianteira (Elevador) / Front 3p Link (Lifter )
Liga Ção 3p Dianteira (Cilindro) / Front 3p Link (Cylind Er)
Tdf Dianteira [Com Tdf Dianteira] / Front Pto [With Fro Nt Pto]
Caix A Da Engrenagem Tdf 1 (Carreto) [Peças Componentes] [Com Tdf Dianteira] / Pto Gear Case 1 (Gear) [Comp Onent Parts] [With Front Pto]
Caix A Da Engrenagem Tdf 2 (Bomba) [Peças Componentes] [ Com Tdf Dianteira] / Pto Gear Case 2 (Pump) [Compon Ent Parts] [With Front Pto]
Caix A Da Engrenagem Tdf 3 (Embraiagem) [Peças Component Es] [Com Tdf Dianteira] / Pto Gear Case 3 (Clutch) [Component Parts] [With Front Pto]
Caix A Da Engrenagem Tdf 4 (Caixa) [Peças Componentes] [ Com Tdf Dianteira] / Pto Gear Case 4 (Case) [Compon Ent Parts] [With Front Pto]
Caix A Da Engrenagem Tdf 5 (Kit De Juntas E Vedantes) [P Eças Componentes] [Com Tdf Dianteira] / Pto Gear Ca Se 5 (Gasket And Seal Kit) [Component Parts] [With Front Pto]
Supo Rte Do Elo Superior/Suporte Do Acoplador / Top Link Bracket/Coupler Bracket
Supo Rte Do Elo Superior/Suporte Do Acoplador [Antiga] / Top Link Bracket/Coupler Bracket [Old]
Supo Rte Do Elo Superior/Suporte Do Acoplador [Nova] / T Op Link Bracket/Coupler Bracket [New]
Liga Ção 3 Pontos (Ligação Superior:Manual) / 3-Point Li Nkage (Top Link:Manual)
Liga Ção 3 Pontos (Ligação Superior:Hidráulica) / 3-Poin T Linkage (Top Link:Hydraulic)
Liga Ção 3 Pontos (Ligação Inferior) / 3-Point Linkage (Lower Link)
Esta Bilizador (Elevador) [Com Puxo (Escada)] / Stabiliz Er(Lifter) [With Hitch (Ladder)]
Esta Bilizador (Automatico) [Com Puxo (Escada)] / Stabil Izer(Automatic) [With Hitch (Ladder)]
Esta Bilizador (Elevador) [Com Puxo (Dromone)] / Stabili Zer(Lifter) [With Hitch (Dromone)]
Esta Bilizador (Automatico) [Com Puxo (Dromone)] / Stabi Lizer(Automatic) [With Hitch (Dromone)]
Esta Bilizador (Elevador) [Peças Componentes] / Stabiliz Er (Lifter) [Component Parts]
Esta Bilizador (Automatico) [Peças Componentes] / Stabil Izer(Automatic) [Component Parts]
3-Po Nt Acoplamento (Tirante) / 3-Point Linkage (Lift Ro D)
Ciln Dro Eleveção / Lift Cylinder
Puxo Barra / Drawbar Bracket
Barr A Reboque (Fixed Piton) / Drawbar(Fixed Piton)
Barr A Reboque(Engate K80) / Drawbar(Coupling K80)
Barr A Reboque(Padrão) / Drawbar(Standard)
Barr A Reboque (Cuna) / Drawbar(Cuna)
Cobe Rtura De Barras De Engate [Com Barra Reboque] / Dra Wbar Cover [With Drawbar]
Puxo (Escada) / Hitch (Ladder)
Puxo (Dromone) / Hitch (Dromone)
Puxo (Dromone) [Peças Componentes] / Hitch (Dromone) [C Omponent Parts]
Puxo (Dromone) Control Alavanca / Hitch (Dromone) Trail Er Lever
Ganc Ho Trailer (Manual) / Trailer Clevis (Manual)
Ganc Ho Trailer (Automatico) / Trailer Clevis (Automatic )
Ganc Ho Trailer (Cuna-D2) / Trailer Clevis (Cuna-D2)
Ganc Ho Trailer (Cuna-D3) / Trailer Clevis (Cuna-D3)
Ganc Ho Trailer (Cuna-C) / Trailer Clevis (Cuna-C)
Ganc Ho Trailer (K80) / Trailer Clevis (K80)
Ganc Ho Trailer (Piton) / Trailer Clevis (Piton)
Capot Inferior (Direito) / Hood (Bonnet) Si De Lower Rh
Capot Inferior (Esquerdo) [Com Compressor D E Ar] / Hood (Bonnet) Side Lower Lh [With Air Compr Essor]
Capot Inferior (Esquerdo) [Sem Compressor D E Ar] / Hood (Bonnet) Side Lower Lh [W/O Air Compre Ssor]
Placa Do Obturador (Silenciador/Isolador) / Shutter Plate (Sound Absorber/Insulator)
Guarda-Lamas Dianteiro(W:410) / Front Fende R (W:410)
Guarda-Lamas Dianteiro(W:540) / Front Fende R (W:540)
Degrau Direito [Com Suspensão Frontal] [Com Equipa Mento Do Carregador] / Step Rh [With Front Suspensi On] [With Loader Equipment]
Degrau Direito [Com Suspensão Frontal] [Sem Equipa Mento Do Carregador] / Step Rh [With Front Suspensi On] [W/O Loader Equipment]
Degrau Esquerdo / Step Lh
Vidro Frente / Front Glass
Porta Esq / Door Lh
Vidro Traseiro Da Escotilha / Hatch Back Glass(Rea R Window )
Tejadilho / Sun Roof
Tecto Interior / Inner Roof
Tecto Abrir / Outer Roof
Suporte Do Assento / Seat Bracket
Banco / Seat
Banco 2 (Apoio Braço/Costas Banco) [Peças Componen Tes] / Seat2 (Armrest/Backrest) [Component Parts]
Suspensão Do Assento [Peças Componentes] / Seat Su Spension [Component Parts]
Banco De Passageiro / Passenger Seat
Tapete Do Piso / Floor Mat
Material À Prova De Som 1 (Painel) / Soundproof Ma Terial 1 (Panel)
Material À Prova De Som 2 (Chão) / Soundproof Mate Rial 2 (Floor)
Material À Prova De Som 3 (Consola) / Soundproof M Aterial 3 (Console)
Material À Prova De Som 4 (Tejadilho) / Soundproof Material 4 (Roof)
Cobertura De Mudança (Consola Direita) / Shift Cov Er (Console Rh)
Tampa Do Rádio E Tampa Do Painel De Controlo Do Ar Condicionado / Radio Cover And Air Conditioner Con Trol Panel Cover
Consola Do Lado Esquerdo / Console Lh
Resguardo Coluna / Pillar Cover
Cobertura Do Guarda-Lamas / Fender Cover
Guarda Lamas (Direito) / Fender Rh
Guarda Lamas (Esquerda) / Fender Lh
Guarda Lamas / Over Fender
Suporte Cabine Frente [Com Equipamento Do Carregad Or] / Cab Bracket Front [With Loader Equipment]
Suporte Cabine Frente [Sem Equipamento Do Carregad Or] / Cab Bracket Front [W/O Loader Equipment]
Suporte Cabine Traseira / Cab Bracket Rear
Suporte Cabine Traseira [Tipo De Suspensão Traseir A (Ar/Mola)] / Cab Bracket Rear [Rear Suspension Ty Pe (Air/Spring)]
Traseira Amortecedor [Tipo De Suspensão Traseira ( Mola)] / Rear Damper [Rear Suspension Type (Spring) ]
Traseira Amortecedor [Tipo De Suspensão Traseira ( Ar)] [Com Compressor De Ar] / Rear Damper [Rear Sus Pension Type (Air)] [With Air Compressor]
Caixa Ferramenta / Tool Box
Ar Condicionado / Air Conditi Oner
Conduta Do Ar Condicionado (A R Frio) / Air Conditioner Duct (Fresh Air)
Conduta Do Ar Condicionado (T Raseira) / Air Conditioner Duct (Rear)
Entradas Ar Painel Instrument Os / Dashboard Air Outlets
Circulaçao Ar Interior / Inne R Air Recirculation
Tubo Aquecimento / Heater Hos E
Tubo Ar Condicionado/Tubo Con Densador / Air Conditioner Hose/Condenser Hose
Polia De Acionamento Do Compr Essor [Com Compressor De Ar] / Compressor Drive Pul Ley [With Air Compressor]
Compressor (Ar Condicionado) / Compressor (Air Conditioner)
Roda Dianteira (380/85r28) [Miche Lin] / Front Wheel (380/85r28) [Michelin]
Roda Dianteira (380/85r28) [Trell Eborg] / Front Wheel (380/85r28) [Trelleborg]
Roda Dianteira (380/85r28) [Fires Tone] / Front Wheel (380/85r28) [Firestone]
Roda Dianteira (380/85r28) [Mitas ] / Front Wheel (380/85r28) [Mitas]
Roda Dianteira (420/70r28) [Miche Lin] / Front Wheel (420/70r28) [Michelin]
Roda Dianteira (420/70r28) [Trell Eborg] / Front Wheel (420/70r28) [Trelleborg]
Roda Dianteira (420/70r28) [Fires Tone] / Front Wheel (420/70r28) [Firestone]
Roda Dianteira (420/70r28) [Mitas ] / Front Wheel (420/70r28) [Mitas]
Roda Dianteira (420/85r28) [Miche Lin] / Front Wheel (420/85r28) [Michelin]
Roda Dianteira (420/85r28) [Trell Eborg] / Front Wheel (420/85r28) [Trelleborg]
Roda Dianteira (420/85r28) [Fires Tone] / Front Wheel (420/85r28) [Firestone]
Roda Dianteira (420/85r28) [Mitas ] / Front Wheel (420/85r28) [Mitas]
Roda Dianteira (480/70r28) [Miche Lin] / Front Wheel (480/70r28) [Michelin]
Roda Dianteira (480/70r28) [Trell Eborg] / Front Wheel (480/70r28) [Trelleborg]
Roda Dianteira (480/70r28) [Fires Tone] / Front Wheel (480/70r28) [Firestone]
Roda Dianteira (480/70r28) [Mitas ] / Front Wheel (480/70r28) [Mitas]
Roda Dianteira (540/65r28) [Trell Eborg] / Front Wheel (540/65r28) [Trelleborg]
Roda Dianteira (540/65r28) [Fires Tone] / Front Wheel (540/65r28) [Firestone]
Roda Dianteira (540/65r28) [Mitas ] / Front Wheel (540/65r28) [Mitas]
Roda Traseira (460/85r38) [Michel In] / Rear Wheel (460/85r38) [Michelin]
Roda Traseira (460/85r38) [Trelle Borg] / Rear Wheel (460/85r38) [Trelleborg]
Roda Traseira (460/85r38) [Firest One] / Rear Wheel (460/85r38) [Firestone]
Roda Traseira (460/85r38) [Mitas] / Rear Wheel (460/85r38) [Mitas]
Roda Traseira (520/70r38) [Michel In] / Rear Wheel (520/70r38) [Michelin]
Roda Traseira (520/70r38) [Firest One] / Rear Wheel (520/70r38) [Firestone]
Roda Traseira (520/70r38) [Mitas] / Rear Wheel (520/70r38) [Mitas]
Roda Traseira (520/85r38) [Michel In] / Rear Wheel (520/85r38) [Michelin]
Roda Traseira (520/85r38) [Trelle Borg] / Rear Wheel (520/85r38) [Trelleborg]
Roda Traseira (520/85r38) [Mitas] / Rear Wheel (520/85r38) [Mitas]
Roda Traseira (580/70r38) [Michel In] / Rear Wheel (580/70r38) [Michelin]
Roda Traseira (580/70r38) [Trelle Borg] / Rear Wheel (580/70r38) [Trelleborg]
Roda Traseira (580/70r38) [Mitas] / Rear Wheel (580/70r38) [Mitas]
Roda Traseira (650/65r38) [Michel In] / Rear Wheel (650/65r38) [Michelin]
Roda Traseira (650/65r38) [Trelle Borg] / Rear Wheel (650/65r38) [Trelleborg]
Roda Traseira (650/65r38) [Firest One] / Rear Wheel (650/65r38) [Firestone]
Roda Traseira (650/65r38) [Mitas] / Rear Wheel (650/65r38) [Mitas]
Label (Front) / Label (Front)
Etiqueta (Frente) [Com Equipamento Do Carreg Ador] / Label (Front) [With Loader Equipment]
Etiqueta (Frente) [Sem Equipamento Do Carreg Ador] / Label (Front) [W/O Loader Equipment]
Decalcomania(Painel/Cobertura De Mudança) / Label (Panel/Shift Cover)
Etiqueta (Traseira) [Travão De Trailer De 1 Linha] / Label (Rear) [1-Line Traler Brake]
Etiqueta (Traseira) [Travão De Trailer De 2 Linha] / Label (Rear) [2-Line Traler Brake]
Etiqueta (Traseira) [Travão De Trailer De 1+ 2 Linha] / Label (Rear) [1+2-Line Traler Brake]
Etiqueta (Unidade Control Electrico/Controla Dor) / Label (Ecu/Controller)
Decalcomania (Cabine Interior) / Label (Cab Interior)
Acessorios / Accessories
Kit Alternador (200a) [Opção] / Alternator Kit ( 200a) [Option]
Alternador [Peças Componentes] (200a) [Opção] / Alternator [Component Parts] (200a) [Option]
Luzes Frente (Farol De Repetição) [Opçao] / Head Light Kit (Repeat Head Light) [Option]
Kit De Luz Interior [Opção] / Room Light Kit [Op Tion]
Kit Da Tdf Dianteira (6 Estrias) [Opção] / Front Pto Kit (6 Splines) [Option]
Kit Da Tdf Dianteira (6 Estrias) (Caixa Da Engre Nagem/Junta) [Peças Componentes] [Opção] / Front Pt O Kit (6 Splines) (Gear Case/Gasket) [Component Par Ts] [Option]
Kit Da Tdf Dianteira (6 Estrias) (Arrefecedor Do Óleo) [Opção] / Front Pto Kit (6 Splines) (Oil Coo Ler) [Option]
Kit Do Terminal (12 Polegadas) [Opção] / Termina L Kit (12 Inch) [Option]
Kit Do Sensor (Radar) [Opção] / Sensor Kit (Rada R) [Option]
Kit Da Câmara [Opção] / Camera Kit [Option]
Kit De Antena (Modem Rtk De Direção Automática) (Antena) [Opçao] / Anntena Kit (Auto Steer Rtk Mode M) (Anntena) [Option]
Kit De Antena (Modem Rtk De Direção Automática) (Controlador) [Opçao] / Anntena Kit (Auto Steer Rtk Modem) (Controller) [Option]
Kit De Antena (Direção Automática Rtk Bluetooth) [Opçao] / Anntena Kit (Auto Steer Rtk Bluetooth) [ Option]
Kit De Antena (Direção Automática Dgps/Sem Rtk) [Opçao] / Anntena Kit (Auto Steer Dgps/Without Rtk) [Option]
Kit De 21 Estrias De Tdf [Opção] [Ec] / Pto Kit (21 Splines) [Option] [Ec]
Espelho Retrovisor Com Kit De Aquecedor [Opção] / Rearview Mirror Kit (With Heater) [Option]
Kit De Eixo Da Barra De Ligação [Opção] / Bar Ax Le Kit (Plug-On) [Option]
Auxiliar Do Válvula De Controlo Kit (Elétrica 5ª ) [Opção] / Auxiliary Control Valve Kit (Elec.5th) [Option]
Kit De Acoplador Powr Beyond (Acoplador) [Opção] / Power Beyond Coupler Kit (Coupler) [Option]
Kit De Acoplador Powr Beyond (Tubo/Acoplador) [O Pção] / Power Beyond Coupler Kit (Pipe/Coupler) [Op Tion]
Kit De Acoplador (Saída Hidráulica Dianteira/Elé Trica 5ª) (Tubo) [Com Suspensão Frontal] [Opção] / Coupler Kit (Front Hyd. Outlet/Elec.5th) (Pipe) [Wi Th Front Suspension] [Option]
Kit De Acoplador (Saída Hidráulica Dianteira/Elé Trica 6ª) (Tubo) [Com Suspensão Frontal] [Opção] / Coupler Kit (Front Hyd. Outlet/Elec.6th) (Pipe) [Wi Th Front Suspension] [Option]
Kit De Acoplador (Saída Hidráulica Dianteira/Elé Trica 5ª) (Acoplador/Tubo) [Com Suspensão Frontal] [Opção] / Coupler Kit (Front Hyd. Outlet/Elec.5th) (Coupler/Pipe) [With Front Suspension] [Option]
Kit De Acoplador (Saída Hidráulica Dianteira/Elé Trica 6ª) (Acoplador/Tubo) [Com Suspensão Frontal] [Opção] / Coupler Kit (Front Hyd. Outlet/Elec.6th) (Coupler/Pipe) [With Front Suspension] [Option]
Ligacao Superior (Hidráulica) [Opção] / Top Link Kit (Hydraulic) [Option]
Kit De Ligação 3-P Dianteira (Elo Estrutura/Supe Rior) [Opção] / Front 3p Link Kit (Frame/Top Link) [Option]
Kit De Ligação 3-P Dianteira (Elevação) [Opção] / Front 3p Link Kit (Lifter) [Option]
Kit De Ligação 3-P Dianteira (Cilndro) [Opção] / Front 3p Link Kit (Cylinder) [Option]
Kit Da Ligação 3-P Dianteira (Elétrica 5ª) (Válv Ula) [Opção] / Front 3p Link Kit (Elec.5th) (Valve) [Option]
Kit Da Ligação 3-P Dianteira (Elétrica 6ª) (Válv Ula) [Opção] / Front 3p Link Kit (Elec.6th) (Valve) [Option]
Kit De Escora (Padrão) [Opção] / Drawbar Kit (St Andard) [Option]
Kit De Escora (Cuna) [Opção] / Drawbar Kit (Cuna ) [Option]
Kit De Escora (Acoplamento K80) [Opção] / Drawba R Kit (Coupling K80) [Option]
Kit De Escora (Pistão Fixo) [Opção] [Antiga] / D Rawbar Kit (Fix Piton) [Option] [Old]
Kit De Escora (Pistão Fixo) [Opção] [Nova] / Dra Wbar Kit (Fix Piton) [Option] [New]
Kit Desnebulizador Traseiro / Rear Defogger Kit
Kit Protetor De Para-Sol [Opção] / Sunshade Shie Ld Kit [Option]
Ventoinh A / Fan
Painel / Panel
Escova / Wiper
Travão / Brake
Porta Esq / Door Lh
Banco / Seat
