Kubota Tractor M7132P KVT Parts Catalog
Model: Kubota M7132P KVT Tractor
Number of Pages: 884 Pages
Frequently Used Items Frequently Used Items
Frequently Used Items Frequently Used Items (Electrical Parts)
Engine Crankcase (Upper)
Engine Crankcase (Lower)
Engine Oil Pan
Engine Cylinder Head
Engine Inlet Valve And Exhaust Valve
Engine Rocker Arm Shaft
Engine Head Cover
Engine Front Cover
Engine Piston And Crankshaft
Engine Camshaft And Idle Gear Shaft
Engine Balancer
Engine Flywheel
Engine Fuel Filter
Engine Supply Pump
Engine Injector And Glow Plug
Engine Injection Pipe
Engine Common Rail
Engine Water Flange And Thermostat
Engine Water Pump
Engine Oil Cooler
Engine Oil Separator
Engine Oil Separator [Component Parts]
Engine Oil Separator Pipe
Engine Oil Pipe (Turbo Charger)
Engine Air Cleaner
Engine Air Cleaner [Component Parts]
Engine Inlet Pipe (Air Cleaner)
Engine Turbo Charger
Engine Inlet Manifold
Engine Air Cleaner Flange And Throttle Valve
Engine Egr Valve
Engine Egr Cooler
Engine Egr Water Piping
Engine Exhaust Manifold
Engine Diesel Particulate Filter Muffler
Engine Diesel Particulate Filter Muffler [Component Parts]
Engine Muffler Bracket (Dpf) 1
Engine Muffler Bracket (Dpf) 2
Engine Pressure Pipe
Engine Muffler Pipe
Engine Selective Catalytic Reduction Muffler
Engine Muffler Pipe And Cover
Engine Diesel Exhaust Fluid Pump
Engine Diesel Exhaust Fluid Tank
Engine Diesel Exhaust Fluid Tank [Component Parts]
Engine Diesel Exhaust Fluid Hose
Engine Diesel Exhaust Fluid Heater Hose
Engine Diesel Exhaust Fluid Breather Hose
Engine Egr Valve (Selective Catalytic Reduction System)
Engine Egr Cooler (Selective Catalytic Reduction System)
Engine Egr Pipe (Selective Catalytic Reduction System)
Engine Egr Water Piping (Selective Catalytic Reduction System)
Engine Exhaust Manifold CoverEgr Cover
Engine Engine Electrical Parts (SensorEcu)
Engine Engine Electrical Parts (Muffler)
Engine Injector Harness
Engine Accelerator Pedal
Fuel System Fuel Tank [Old] ## S.No.=50174 S.No.;=50174
Fuel System Fuel Tank [New] ## S.No.=50175 S.No.;=50175
Fuel System Fuel Tank Bracket
Fuel System Fuel Pipe (Fuel Filler)
Fuel System Fuel Pipe (Fuel Pump)
Fuel System Fuel Pipe (Fuel Cooler)
Fuel System Fuel Cooler
Fuel System Separator
Fuel System Separator [Component Parts]
Fuel System Fuel Pump
Fuel System Fuel Pump [Component Parts]
Fuel System Fuel Filter
Fuel System Fuel Filter [Component Parts]
Cooling Water System Fan Bracket
Cooling Water System Fan Drive Pulley
Cooling Water System Water Pipe And Cooler Pipe
Cooling Water System Cooler Unit
Cooling Water System Cooler Unit (Radiator) [Component Parts]
Cooling Water System Cooler Unit (Inter Cooler) [Component Parts]
Cooling Water System Cooler Unit (Oil Cooler) [Component Parts]
Cooling Water System Cooler Unit (Condenser) [Component Parts]
Cooling Water System Reserve Tank
Cooling Water System Reserve Tank Hose
Electrical System Alternator (200a)
Electrical System Alternator (150a)
Electrical System Alternator (200a) [Component Parts]
Electrical System Alternator (150a) [Component Parts]
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System Battery Bracket
Electrical System SwitchSensor (Engine Lh)
Electrical System SwitchSensor (Engine Rh)
Electrical System Selective Catalytic Reduction Sensor
Electrical System Front Suspension Sensor [With Front Suspension]
Electrical System Sensor (Pedal)
Electrical System Sensor (Transmission Housing Rh)
Electrical System Sensor (Transmission Housing Lh)
Electrical System Draft Sensorp Sensor
Electrical System Switch (Panel Board)
Electrical System Switch (Steering) [Auto Steering Compatible]
Electrical System Switch (Steering) [Auto Steering Incompatible]
Electrical System Switch (Shift Cover)
Electrical System Switch (Console Lh)
Electrical System External Switch
Electrical System RelayController
Electrical System Electronic Control Unit (Engine)
Electrical System Electronic Control UnitController
Electrical System Ecu Mounting Part
Electrical System Controller (Ceu)
Electrical System Controller (Ceu) [Component Parts]
Electrical System Panel
Electrical System Cab Inner Rear Electrical Parts (Electrical OutletAir Conditioner C
Electrical System Isobus Terminal [With Isobus]
Electrical System Armrest
Electrical System Terminal (12 Inch)
Electrical System Terminal (7 Inch)
Electrical System Head Light
Electrical System Head Light (Pillar) [With Repeat Head Light]
Electrical System Beacon Lamp
Electrical System Front Combination Lamp
Electrical System Work Light (FrontRoof)
Electrical System Work Light (FrontPillar)
Electrical System Work Light (RearRoof)
Electrical System Work Light (RearPillar)
Electrical System Tail Light
Electrical System License Lamp
Electrical System Trailer Socket
Electrical System Room Light
Electrical System Radio Speaker
Electrical System Washer Tank
Electrical System Wiper
Electrical System Electrical Wiring (Engine) 1 (Air CleanerDpf)
Electrical System Electrical Wiring (Engine) 2 (Crs)
Electrical System Electrical Wiring (Engine) 3 (FuelScr)
Electrical System Electrical Wiring (Engine) 4 (FuseBattery)
Electrical System Electrical Wiring (Engine) 5 (CompressorFlywheel)
Electrical System Electrical Wiring (Bonnet(Hood))
Electrical System Electrical Wiring (Alternator 200a)
Electrical System Electrical Wiring (Alternator 150a)
Electrical System Electrical Wiring (Starter)
Electrical System Electrical Wiring (Power SupplyController (Ceu))
Electrical System Electrical Wiring (TransaxleFront)
Electrical System Electrical Wiring (TransAxle Rear)
Electrical System Electrical Wiring (Remote Control Valve)
Electrical System Electrical Wiring (Cab) 1 (SteeringPanel)
Electrical System Electrical Wiring (Cab) 2 (Ecu)
Electrical System Electrical Wiring (Cab) 3 (Shift CoverArmrest)
Electrical System Electrical Wiring (Cab) 4 (Air Conditioner)
Electrical System Electrical Wiring (Front Pillar)
Electrical System Electrical Wiring (Roof)
Electrical System Electrical Wiring (FlasherMudguard)
Electrical System Electrical Wiring (Front Suspension) [With Front Suspension]
Electrical System Electrical Wiring (Auto Steering) [Auto Steering Compatible]
Electrical System Electrical Wiring (Isobus) [With Isobus]
Clutch Transmission Damper Disk And Housing Connection
Clutch Transmission Transmission Case
Clutch Transmission Transmission Housing
Clutch Transmission Housing Plug
Clutch Transmission Rear Axle Housing
Clutch Transmission PTO Shaft Housing
Clutch Transmission Lift Arm
Clutch Transmission PTO Shaft Housing Inner (Clutch)
Clutch Transmission PTO Shaft Housing Inner (Gear)
Clutch Transmission PTO Shaft Housing Inner (PTO Shaft)
Clutch Transmission PTO Shaft Housing Inner (Shift Fork)
Clutch Transmission Hydraulic Unit
Clutch Transmission Hydraulic Pump Housing
Clutch Transmission Hydraulic Piping
Clutch Transmission Hydraulic Control UnitFilter
Clutch Transmission Solenoid ValvePressure Regulater
Clutch Transmission Clutch Pedal
Shift Lever Shuttle Shift Lever
Shift Lever PTO Gear Shift Lever
Rear Axle Brake Rear Axle [Bar Type Axle]
Rear Axle Brake Rear Axle [Flange Type Axle]
Rear Axle Brake Rear Differential
Rear Axle Brake Brake
Rear Axle Brake Brake Shaft
Rear Axle Brake Rear Axle Hub (For 8 Hole Rim) [Bar Type Axle]
Rear Axle Brake Rear Axle Hub (For 10 Hole Rim) [Bar Type Axle]
Rear Axle Brake Parking Brake Lever
Rear Axle Brake Brake Pedal
Rear Axle Brake Brake Master Cylinder
Rear Axle Brake Brake Pipe 1 (UpperFront)
Rear Axle Brake Brake Pipe 2 (LowerRear)
Front Axle Chassis Front Axle Frame [With Front Suspension]
Front Axle Chassis Front Axle Frame [Front Rigid Type Axle]
Front Axle Chassis Front Loader Frame [With Loader Equipment]
Front Axle Chassis Front Suspension Rocker Arm [With Front Suspension]
Front Axle Chassis Front Suspension Cylinder [Component Parts]
Front Axle Chassis Front Axle [With Front Suspension]
Front Axle Chassis Front Axle [Front Rigid Type Axle]
Front Axle Chassis Front Axle Bracket [Front Axle Component] [With Front Suspension]
Front Axle Chassis Front Axle Bracket [Front Axle Component] [Front Rigid Type Axle]
Front Axle Chassis Front Axle Housing [Front Axle Component]
Front Axle Chassis Front Differential [Front Axle Component]
Front Axle Chassis Differential Gear Shaft [Front Axle Component]
Front Axle Chassis Wheel Turning Angle Sensor [Front Axle Component]
Front Axle Chassis Tie RodSteering Cylinder [Front Axle Component]
Front Axle Chassis Propeller Shaft And Cover [With Front Suspension]
Front Axle Chassis Propeller Shaft And Cover [Front Rigid Type Axle]
Steering Steering Wheel
Steering Steering Post [Component Parts]
Steering Tilt Pedal
Steering Steering Controller [Auto Steering Compatible]
Steering Steering Controller [Auto Steering Incompatible]
Hydraulic System Hydraulic Oil Line (Oil CoolerFront)
Hydraulic System Hydraulic Oil Line (Oil CoolerRear)
Hydraulic System Oil Cooler [With Front PTO]
Hydraulic System Hydraulic Oil Line (Steering ValveFilter)
Hydraulic System Oil Filter 2 [Component Parts]
Hydraulic System Hydraulic Oil Line (Steering Valve)
Hydraulic System Steering Hose (Delivery)
Hydraulic System Hydraulic Oil Line (Front Axle Delivery PipeFront) [With Front Suspe
Hydraulic System Hydraulic Oil Line (Front Axle Delivery PipeFront) [Front Rigid Type
Hydraulic System Hydraulic Oil Line (Front Axle Delivery PipeRear)
Hydraulic System Hydraulic Oil Line (Oil Filter)
Hydraulic System Hydraulic Oil Line (Oil Filter To Remote Control ValveHyd
Hydraulic System Hydraulic Oil Line (Brake Pipe To Remote Control Valve)
Hydraulic System Valve Block 1 (Transaxle)
Hydraulic System Valve Block 2 (Solenoid Valve)
Hydraulic System Axial Pump
Hydraulic System Axial Pump Piping
Hydraulic System Hydraulic Oil Line (Axial Pump To Remote Control Valve)
Hydraulic System Front Suspension Valve Pipe (Rear) [With Front Suspension]
Hydraulic System Front Suspension Valve [With Front Suspension]
Hydraulic System Front Suspension Valve [Component Parts][With Front Suspension]
Hydraulic System Front Suspension Valve Pipe (Front) [With Front Suspension]
Hydraulic System Front Suspension Accumulator [With Front Suspension]
Hydraulic System Front Suspension Cylinder Hose [With Front Suspension]
Hydraulic System Remote Control Valve (4 Valves)
Hydraulic System Remote Control Valve (5 Valves)
Hydraulic System Remote Control Valve (6 Valves)
Hydraulic System Auxiliary Control Valve (4 Valves) [Component Parts]
Hydraulic System Auxiliary Control Valve (5 Valves) [Component Parts]
Hydraulic System Auxiliary Control Valve (6 Valves) [Component Parts]
Hydraulic System Directional Control Valve (4 Valves) [Component Parts]
Hydraulic System Directional Control Valve (5 Valves) [Component Parts]
Hydraulic System Directional Control Valve (6 Valves) [Component Parts]
Hydraulic System Center Valve [Component Parts]
Hydraulic System End Plate Valve [Component Parts]
Hydraulic System Oil Collector (Remote Control Valve) [4p]
Hydraulic System Oil Collector (Remote Control Valve) [3p]
Hydraulic System Front Hydraulic Outlet Pipe (Rear) [With Front Hyd. Outlet]
Hydraulic System Front Hydraulic Outlet Pipe (Middle) [With Front Hyd. Outlet]
Hydraulic System Front Hydraulic Outlet Pipe (Front) [With Front Hyd. Outlet]
Hydraulic System Hydraulic Outlet Pipe (Load-Sensing Control Hose) [With Power Beyond]
Hydraulic System Hydraulic Outlet Pipe (Power BeyondReturn Hose) [With Power Beyond]
Hydraulic System Trailer Brake Valve
Hydraulic System Trailer Brake Valve PipeCoupler
Hydraulic System Front Loader Oil Pipe (Rear) [With Loader Equipment]
Hydraulic System Front Loader Oil Pipe (Front) [With Loader Equipment]
Air Compressor Air Compressor
Air Compressor Air Compressor [Component Parts]
Air Compressor Air Compressor Pipe
Air Compressor Air Tank
Air Compressor Air Coupler
Air Compressor Air Valve [Component Parts]
3-Point Linkage Drawbar Hitch Front 3p Link (FrameTop Link) [With Front 3p]
3-Point Linkage Drawbar Hitch Front 3p Link (Lifter) [With Front 3p]
3-Point Linkage Drawbar Hitch Front 3p Link (Cylinder) [With Front 3p]
3-Point Linkage Drawbar Hitch Front PTO [With Front PTO]
3-Point Linkage Drawbar Hitch PTO Gear Case (Gear) [Component Parts] [With Front PTO]
3-Point Linkage Drawbar Hitch PTO Gear Case (Pump) [Component Parts] [With Front PTO]
3-Point Linkage Drawbar Hitch PTO Gear Case (Clutch) [Component Parts] [With Front PTO
3-Point Linkage Drawbar Hitch PTO Gear Case (Case) [Component Parts] [With Front PTO]
3-Point Linkage Drawbar Hitch PTO Gear Case (Gasket And Seal Kit) [Component Parts] [W
3-Point Linkage Drawbar Hitch Top Link BracketCoupler Bracket
3-Point Linkage Drawbar Hitch 3-Point Linkage (Top LinkManual)
3-Point Linkage Drawbar Hitch 3-Point Linkage (Top LinkHydraulic)
3-Point Linkage Drawbar Hitch 3-Point Linkage (Lower Link)
3-Point Linkage Drawbar Hitch Stabilizer (Lifter)
3-Point Linkage Drawbar Hitch Stabilizer (Automatic)
3-Point Linkage Drawbar Hitch Stabilizer (Lifter) [Component Parts]
3-Point Linkage Drawbar Hitch Stabilizer (Automatic) [Component Parts]
3-Point Linkage Drawbar Hitch 3-Point Linkage (Lift Rod)
3-Point Linkage Drawbar Hitch Lift Cylinder
3-Point Linkage Drawbar Hitch Drawbar Bracket
3-Point Linkage Drawbar Hitch Drawbar (Standard)
3-Point Linkage Drawbar Hitch Drawbar (Coupling K80)
3-Point Linkage Drawbar Hitch Drawbar (Fixed Piton)
3-Point Linkage Drawbar Hitch Hitch (Ladder)
Hood Bonnet Hood (Bonnet) Upper
Hood Bonnet Hood (Bonnet) Damper
Hood Bonnet Hood (Bonnet) Lock
Hood Bonnet Hood (Bonnet) Frame (Upper)
Hood Bonnet Hood (Bonnet) Frame (Lower)
Hood Bonnet Hood (Bonnet) Side Lower Rh
Hood Bonnet Hood (Bonnet) Side Lower Lh
Hood Bonnet Shutter Plate
Hood Bonnet Shutter Plate (Sound AbsorberInsulator)
Hood Bonnet Front Fender (W410)
Hood Bonnet Front Fender (W540)
Cab Cab Frame
Cab Step Rh [With Front Suspension]
Cab Step Rh [Front Rigid Type Axle]
Cab Step Lh
Cab Front Cover
Cab Front Glass
Cab Door Rh
Cab Door Lh
Cab Door Lock Rh
Cab Door Lock Lh
Cab Hatch Back Glass
Cab Sun Roof
Cab Rearview Mirror
Cab Inner Roof
Cab Outer Roof
Cab Seat Bracket
Cab Seat
Cab Seat[Component Parts]
Cab Passenger Seat
Cab Floor Mat
Cab Soundproof Material 1 (Panel)
Cab Soundproof Material 2 (Floor)
Cab Soundproof Material 3 (Console)
Cab Soundproof Material 4 (Roof)
Cab Shift Cover (Console Rh)
Cab Radio Cover And Air Conditioner Control Panel Cover
Cab Console Lh
Cab Pillar Cover
Cab Fender Cover
Cab Fender Rh
Cab Fender Lh
Cab Over Fender
Cab Cab Bracket Front
Cab Cab Bracket Rear [Suspension Type]
Cab Cab Bracket Rear [Rubber Type]
Cab Rear Damper [Suspension Type (Air)]
Cab Rear Damper [Suspension Type (Spring)]
Cab Tool Box [Old] ## S.No.=50174 S.No.;=50174
Cab Tool Box [New] ## S.No.=50175 S.No.;=50175
Air Conditioner Air Conditioner
Air Conditioner Air Conditioner Duct (Fresh Air)
Air Conditioner Air Conditioner Duct (Rear)
Air Conditioner Mode Case
Air Conditioner Dashboard Air Outlets
Air Conditioner Inner Air Recirculation
Air Conditioner Heater Hose
Air Conditioner Air Conditioner HoseCondenser Hose
Air Conditioner Compressor Drive Pulley
Air Conditioner Compressor (Air Conditioner)
Front Rear Tire Front Wheel (54065r28) [Michelin]
Front Rear Tire Front Wheel (54065r28) [Mitas]
Front Rear Tire Rear Wheel (65065r38) [Michelin]
Front Rear Tire Rear Wheel (65065r38) [Mitas]
Labels Label (Hood (Bonnet))
Labels Label (Front)
Labels Label (PanelShift Cover)
Labels Label (Rear)
Labels Label (EcuController)
Labels Label (Cab Interior)
Accessories Accessories
Option Beacon Lamp Kit [Option]
Option Working Light Kit [Option]
Option Extension Light Kit [Option]
Option Room Light Kit [Option]
Option Sensor Kit (Radar) [Option]
Option Camera Kit [Option]
Option Anntena Kit (Auto Steer Rtk Modem) (Anntena) [Option]
Option Anntena Kit (Auto Steer Rtk Modem) (Controller) [Option]
Option Anntena Kit (Auto Steer DgpsWithout Rtk) [Option]
Option PTO Kit (21 Splines) [Option]
Option PTO Kit (20 Splines) [Option]
Option Trailer Kit (Piton) [Option]
Option Trailer Kit (K80) [Option]
Option Trailer Kit (ClevisManual) [Option]
Option Trailer Kit (ClevisAuto) [Option]
Option Trailer Kit (ClevisCuna-C) [Option]
Option Trailer Kit (ClevisCuna-D2) [Option]
Option Trailer Kit (ClevisCuna-D3) [Option]
Option Trailer Clevis (Manual) [Component Parts] [Option]
Option Trailer Clevis (Automatic) [Component Parts] [Option]
Option Rearview Mirror Kit (With Heater) [Option]
Option Rear Axle Hub (For 8 Hole Rim) [Bar Type Axle] [Option]
Option Bar Axle Kit (Plug-On) [Flange Type Axle] [Option]
Option Auxiliary Control Valve Kit (Elec.5th) [Old] [Option]
Option Auxiliary Control Valve Kit (Elec.5th) [New] [Option]
Option Power Beyond Coupler Kit (Coupler) [Option]
Option Power Beyond Coupler Kit (PipeCoupler) [Option]
Option Top Link Kit (Hydraulic) [Option]
Option Front 3p Link Kit (FrameTop Link) [Option]
Option Front 3p Link Kit (Lifter) [Option]
Option Front 3p Link Kit (Cylinder) [Option]
Option Front 3p Link Kit (Mech.6th) (Valve) [Option]
Option Front 3p Link Kit (Mech.5th) (Valve) [Option]
Option External Switch For Front 3-Point Hitch [Option]
Option Drawbar Bracket Kit [Option]
Option Drawbar Kit (Standard) [Option]
Option Drawbar Kit (Cuna) [Option]
Option Drawbar Kit (Coupling K80) [Option]
Option Drawbar Kit (Fix Piton) [Option] [Old] ## S.No.=50090 S.No.;=50090
Option Drawbar Kit (Fix Piton) [Option] [New] ## S.No.=50091 S.No.;=50091
Option Rear Over Fender Kit [Option]
