Kubota Tractor M7131SC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M7131SC Tractor
Number of Pages: 685 Pages
Itens Usados F Requentemente [Com Compressor De Ar] / Frequently U Sed Items [With Air Compresser]
Itens Usados F Requentemente [Sem Compressor De Ar] / Frequently U Sed Items [W/O Air Compresser]
Itens Usados F Requentemente (Componenetes Electricos) / Frequentl Y Used Items (Electrical Parts)
Bloco Motor(Superior) / Crankcase (Upper)
Bloco Motor(Inferior) / Crankcase (Lower)
Cárter Do Óleo [Com Compressor De Ar] / Oil Pan [Wi Th Air Compressor]
Cárter Do Óleo [Sem Compressor De Ar] / Oil Pan [W/ O Air Compressor]
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaust Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Bomba De Abastecimento / Supply Pump
Injector E Vela Aquecimento / Injector And Glow Plu G
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Thermos Tat
Bomba Agua / Water Pump
Radiador Oleo / Oil Cooler
Separador De Óleo [Peças Componentes] / Oil Separat Or [Component Parts]
Tubo Do Separador De Óleo / Oil Separator Pipe
Filtro Ar [Com Tdf Dianteira] / Air Cleaner [With F Ront Pto]
Filtro Ar [Sem Tdf Dianteira] / Air Cleaner [W/O Fr Ont Pto]
Filtro Ar [Peças Componentes] / Air Cleaner [Compon Ent Parts]
Tubo De Entrada (Filtro De Ar) [Com Compressor De A R] / Inlet Pipe (Air Cleaner) [With Air Compresser]
Tubo De Entrada (Filtro De Ar) [Sem Compressor De A R] / Inlet Pipe (Air Cleaner) [W/O Air Compresser]
Flange Filtro Ar E Valvula Acelarador / Air Cleaner Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubos De Água Egr / Egr Water Piping
Silenciador Do Filtro De Partículas Diesel / Diesel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peças C Omponentes] / Diesel Particulate Filter Muffler [Co Mponent Parts]
Tubo Pressao / Pressure Pipe
Panela Escape / Muffler Pipe
Silenciador De Redução Catalítica Seletivo [Antigo] / Selective Catalytic Reduction Muffler [Old]
Silenciador De Redução Catalítica Seletivo [Novo] / Selective Catalytic Reduction Muffler [New]
Tubulação E Proteção Do Silênciador / Muffler Pipe And Cover
Bomba Do Fluido De Escape De Diesel / Diesel Exhaus T Fluid Pump
Depósito Do Fluido De Escape De Diesel / Diesel Exh Aust Fluid Tank
Depósito Do Fluido De Escape De Diesel [Peças Compo Nentes] / Diesel Exhaust Fluid Tank [Component Part S]
Depósito Do Fluido De Escape De Diesel Tubo / Diese L Exhaust Fluid Hose
Depósito Do Fluido De Escape De Diesel Aquecedor Tu Bo / Diesel Exhaust Fluid Heater Hose
Depósito Do Fluido De Escape De Diesel Mangueira De Respiro / Diesel Exhaust Fluid Breather Hose
Válvula Egr (Sistema De Redução Catalítica Seletiva ) / Egr Valve (Selective Catalytic Reduction System )
Sistema De Arrefecimento Egr (Sistema De Redução Ca Talítica Seletiva) / Egr Cooler (Selective Catalyti C Reduction System)
Tubo Egr (Sistema De Redução Catalítica Seletiva) / Egr Pipe (Selective Catalytic Reduction System)
Tubos De Água Egr (Sistema De Redução Catalítica Se Letiva) / Egr Water Piping (Selective Catalytic Red Uction System)
Componentes Electricos Motor (Sensor/Ecu) / Engine Electrical Parts (Sensor/Ecu)
Componentes Electricos Motor (Panela Escape) / Engi Ne Electrical Parts (Muffler)
Suporte Deposito Combustivel [Com Equipamento Do Carregador] / Fuel Tank Bracket [With Loader Equipment]
Suporte Deposito Combustivel [Sem Equipamento Do Carregador] / Fuel Tank Bracket [W/O Loader Equipment]
Tubo Do Combustível (Enchimen To Do Combustível) / Fuel Pipe (Fuel Filter)
Arrefecedor Do Combustível [A Ntigo] / Fuel Cooler [Old]
Arrefecedor Do Combustível [N Ovo] / Fuel Cooler [New]
Separador / Separator
Bomba Gasoleo / Fuel Pump
Bomba Gasoleo [Peças Componen Tes] / Fuel Pump [Component Parts]
Filtro Gasoleo [Peças Compone Ntes] / Fuel Filter [Component Parts]
Suporte Ven Tilador [Antigo] / Fan Bracket [Old]
Suporte Ven Tilador [Novo] / Fan Bracket [New]
Polia De Ac Ionamento Da Ventoinha / Fan Drive Pulley
Ventoinha [ Antigo] / Fan [Old]
Ventoinha [ Novo] / Fan [New]
Tubo De Águ A E Tubo Do Sistema De Arrefecimento / Water Pipe A Nd Cooler Pipe
Unidade Do Sistema De Arrefecimento / Cooler Unit
Unidade Do Arrefecedor (Permutador Intermédio De Calor) [Peças Componentes] / Cooler Unit (Inter Cooler) [Compone Nt Parts]
Unidade Do Arrefecedor (Arrefecedor Do Óleo) [Peças Componente S] / Cooler Unit (Oil Cooler) [Component Parts]
Unidade Do Arrefecedor (Condensador) [Peças Componentes] / Coo Ler Unit (Condenser) [Component Parts]
Deposito Re Serva / Reserve Tank
Tubo Do Dep Ósito De Reserva [Com Compressor De Ar] / Reserve T Ank Hose [With Air Compressor]
Tubo Do Dep Ósito De Reserva [Sem Compressor De Ar] / Reserve T Ank Hose [W/O Air Compressor]
Alternador (200a) / Alternat Or (200a)
Alternador (150a) / Alternat Or (150a)
Alternador (200a) [Peças Com Ponentes] / Alternator (200a) [Component Parts]
Alternador (150a) [Peças Com Ponentes] / Alternator (150a) [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Compon Entes] / Starter [Component Parts]
Suporte De Bateria / Battery Bracket
Interruptor/Sensor (Bloco Mo Tor Esquerda) / Switch/Sensor (Engine Lh)
Interruptor/Sensor (Bloco Mo Tor Direita) / Switch/Sensor (Engine Rh)
Sensor Da Redução Catalítica Seletiva / Selective Catalytic Reduction Sensor
Suspensão Frontal Sensor [Co M Suspensão Frontal] / Front Suspension Sensor [Wit H Front Suspension]
Sensor (Pedal) / Sensor (Ped Al)
Interruptor/Sensor [Eixo Dia Nteiro: Tipo Padrão] [Com Compressor De Ar] [Suspen São(Mola)] [Antigo] / Switch/Sensor [Front Axle:Sta Ndard Type] [Suspension Type (Spring)] [With Air Co Mpressor] [Old]
Interruptor/Sensor [Eixo Dia Nteiro: Tipo Padrão] [Com Compressor De Ar] [Suspen São(Mola)] [Novo] / Switch/Sensor [Front Axle:Stand Ard Type] [Suspension Type (Spring)] [With Air Comp Ressor] [New]
Interruptor/Sensor [Eixo Dia Nteiro: Tipo Padrão] [Sem Compressor De Ar] [Antigo ] / Switch/Sensor [Front Axle:Standard Type] [W/O A Ir Compressor] [Old]
Interruptor/Sensor [Eixo Dia Nteiro: Tipo Padrão] [Sem Compressor De Ar] [Novo] / Switch/Sensor [Front Axle:Standard Type] [W/O Air Compressor] [New]
Interruptor/Sensor [Eixo Dia Nteiro: Tipo Pesado] [Sem Compressor De Ar] / Switc H/Sensor [Front Axle:Heavy Duty Type] [W/O Air Comp Ressor]
Sensor (Caixa De Transmissão ) [Componente De Translaxe] / Sensor (Transmission Housing Rh) [Transaxle Component]
Sensor/Valvula (Hidráulica B Omba De Moradia / Tdf Shaft Habitação) / Sensor/Val Ve (Hydraulic Pump Housing/Pto Shaft Housing)
Sensor Da Conicidade/Sensor 3p / Draft Sensor/3p Sensor
Interruptor (Painel) / Switc H (Panel Board)
Interruptor (Direcção) [Sem Direção Automática] / Switch (Steering) [Auto Steer Ing Incompatible]
Interruptor (Cobertura De Mu Dança) / Switch (Shift Cover)
Interruptor Externo / Extern Al Switch
Relé/Controlador / Relay/Con Troller
Unidade Control Electrico (B Loco Motor) / Electronic Control Unit (Engine)
Unidade Control Electrico/Co Ntrolador / Electronic Control Unit/Controller
Controlador (Ceu) / Controll Er (Ceu)
Controlador (Ceu) [Peças Com Ponentes] / Controller (Ceu) [Component Parts]
Painel / Panel
Peças Elétricas Da Traseira Interior Da Cabine (Saída Elétrica/Painel De Contro Lo Do Ar Condicionado) / Cab Inner Rear Electrical Parts (Electrical Outlet/Air Conditioner Control Pa Nel)
Apoio De Braço [Com Tdf Dian Teira] / Armrest [With Front Pto]
Apoio De Braço [Sem Tdf Dian Teira] / Armrest [W/O Front Pto]
Luzes Frente / Head Light
Luzes Frente (Coluna) [Com F Arol De Repetição] / Head Light (Pillar) [With Repe At Head Light]
Lâmpada Farol / Beacon Lamp
Luzes Frontais / Front Combi Nation Lamp
Luz De Trabalho (Dianteiro/T Eto) [Antigo] / Work Light (Front/Roof) [Old]
Luz De Trabalho (Dianteiro/T Eto) [Novo] / Work Light (Front/Roof) [New]
Luz De Trabalho (Dianteiro/C Oluna) [Com 10 Luzes De Trabalho] / Work Light (Fro Nt/Pillar) [Cab Work Light:With 10 Work Light]
Luz De Trabalho (Traseiro/Te To) / Work Light (Rear/Roof)
Luz De Trabalho (Traseiro/Co Luna) [Com 10 Luzes De Trabalho] / Work Light (Rear /Pillar) [Cab Work Light:With 10 Work Light]
Lâmpada Licenciada [Antigo] / License Lamp [Old]
Lâmpada Licenciada [Novo] / License Lamp [New]
Ficha Reboque / Trailer Sock Et
Luz Interior / Room Light
Alta Voz Radio / Radio Speak Er
Escova / Wiper
Cablagem Elétrica (Motor) 1 (Filtro De Ar/Dpf) / Electrical Wiring (Engine) 1 ( Air Cleaner/Dpf)
Cablagem Elétrica (Motor) 2 (Crs) / Electrical Wiring (Engine) 2 (Crs)
Cablagem Elétrica (Motor) 3 (Combustível/Scr) / Electrical Wiring (Engine) 3 (F Uel/Scr)
Cablagem Elétrica (Motor) 4 (Fusível/Bateria) / Electrical Wiring (Engine) 4 (F Use/Battery)
Cablagem Elétrica (Motor) 5 (Compressor/Volante) [Com Compressor De Ar] / Elect Rical Wiring (Engine) 5 (Compressor/Flywheel) [With Air Compresser]
Cablagem Elétrica (Motor) 5 (Compressor/Volante) [Sem Compressor De Ar] / Elect Rical Wiring (Engine) 5 (Compressor/Flywheel) [W/O Air Compresser]
Cablagem Elétrica (Capot) / Electrical Wiring (Bonnet(Hood))
Cablagem Elétrica (Alternado R) [Com Alternador (150 A)] / Electrical Wiring (Al Ternator 150a)
Cablagem Eletrica (Motor Arr Anque) / Electrical Wiring (Starter)
Cablagem Electrica (Fonte De Alimentação)/Controlador (Ceu) / Electrical Wiring (Power Supply)/Controller (Ceu)
Cablagem Electrica (Eixo Tra Nversal/Frente) [Com Compressor De Ar] / Electrical Wiring (Transaxle/Front) [With Air Compresser]
Cablagem Electrica (Eixo Tra Nversal/Frente) [Sem Compressor De Ar] / Electrical Wiring (Transaxle/Front) [W/O Air Compresser]
Cablagem Electrica (Eixo Tra Nversal/Traseira) / Electrical Wiring (Transaxle/Re Ar)
Cablagem Electrica (Distribu Idor Auxiliar) / Electrical Wiring (Remote Control Valve)
Cablagem Elétrica (Cabine) 1 (Direção/Painel) [Antigo] / Electrical Wiring (Cab ) 1 (Steering/Panel) [Old]
Cablagem Elétrica (Cabine) 1 (Direção/Painel) [Novo] / Electrical Wiring (Cab) 1 (Steering/Panel) [New]
Cablagem Elétrica (Cabine) 2 (Ecu) [Antigo] / Electrical Wiring (Cab) 2 (Ecu) [ Old]
Cablagem Elétrica (Cabine) 2 (Ecu) [Novo] / Electrical Wiring (Cab) 2 (Ecu) [Ne W]
Cablagem Elétrica (Cabine) 3 (Cobertura Das Mudanças/Apoio De Braço) / Electric Al Wiring (Cab) 3 (Shift Cover/Armrest)
Cablagem Elétrica (Cabine) 4 (Ar Condicionado) / Electrical Wiring (Cab) 4 (Air Conditioner)
Cablagem Elétrica (Pilar Dia Nteiro) [Antigo] / Electrical Wiring (Front Pillar) [Old]
Cablagem Elétrica (Pilar Dia Nteiro) [Novo] / Electrical Wiring (Front Pillar) [ New]
Cablagem Electrica (Teto) / Electrical Wiring (Roof)
Cablagem Electrica (Pisca/Pá Ra-Lama) / Electrical Wiring (Flasher/Mudguard)
Cablagem Electrica (Suspensã O Dianteira) [Com Suspensão Dianteira] / Electrical Wiring (Front Suspension) [With Front Suspension]
Disco Do Amortecedor E Ligação À Caixa [Antigo] / Damper Disk And Housin G Connection [Old]
Disco Do Amortecedor E Ligação À Caixa [Novo] / Damper Disk And Housing Connection [New]
Eixo Tranversal [Com Lento] / Transaxle [With Creep]
Carter Embraiagem [Co Mponente De Translaxe] / Clutch Housing [Transaxle Component]
Caixa De Transmissão [Componente De Translaxe] / Transmission Housing [T Ransaxle Component]
Caixa Do Eixo Traseir O [Componente De Translaxe] / Rear Axle Housing [Tr Ansaxle Component]
Estrutura Do Veio Tdf [Componente De Translaxe] / Pto Shaft Housing [Tra Nsaxle Component]
Braco Hidraulico [Com Ponente De Translaxe] / Lift Arm [Transaxle Compone Nt]
Veio Secundario [Comp Onente De Translaxe] / Counter Shaft [Transaxle Com Ponent]
Veio Primario [Compon Ente De Translaxe] / Main Shaft [Transaxle Componen T]
Veio De Transmissão D A Tdf [Componente De Translaxe] / Pto Drive Shaft [ Transaxle Component]
Dispositivo De Marcha [Com Lento] [Componente De Translaxe] / Creep Gear [With Creep] [Transaxle Component]
Embraiagem Dianteira [Componente De Translaxe] / Front Clutch [Transaxle Component]
Deslocação De Potênci A [Componente De Translaxe] / Power Shift [Transaxl E Component]
Embraiagem Hidráulica (Entrada) [Componente De Translaxe] / Hydraulic Cl Utch (Input) [Transaxle Component]
Tmbeaialtm 0idep8yica Nsa)Da[ ]C/Mw/Otort Dt Reaosyaft# É 0.Dea8yic Cy8r C0 N/8rw8r[ ]Reaosafyt C/Mw/Otor#
Veio De Entrada De Po Tência [Componente De Translaxe] / Power Input Shaf T [Transaxle Component]
Embraiagem Principal [Componente De Translaxe] / Main Clutch [Transaxle Component]
Transladador 1 [Compo Nente De Translaxe] / Shifter 1 [Transaxle Componen T]
Transladador 2 (Lento ) [Componente De Translaxe] / Shifter 2 (Creep) [Tr Ansaxle Component]
Estrutura Interior Do Veio Tdf (Embreagem) / Pto Shaft Housing Inner (Cl Utch)
Estrutura Interior Do Veio Tdf (Engrenagem) / Pto Shaft Housing Inner (G Ear)
Estrutura Interior Do Veio Tdf (Veio Tdf) / Pto Shaft Housing Inner (Pto Shaft)
Estrutura Interior Do Veio Tdf (Forquilha De Embraiagem) / Pto Shaft Hou Sing Inner (Shift Fork)
Válvula De Pressão / Pressure Valve
Caixa De Mudança De V Elocidade [Componente De Translaxe] / Gear Shift Ho Using [Transaxle Component]
Pedal Embraiagem / Cl Utch Pedal
Alavanca Das Mudanças Lentas / Cr Eep Gear Shift Lever
Alavanca Tdf / Pto Gear Shift Lev Er
Eixo Traseiro [Componente De Translaxe] / Rear Axle [Transaxle Component]
Diferencial Traseiro [Comp Onente De Translaxe] / Rear Differential [Transaxle Component]
Travão [Componente De Tran Slaxe] / Brake [Transaxle Component]
Alavanca Travao Mao / Park Ing Brake Lever
Pedal Travao / Brake Pedal
Cilindro Principal Do Trav Ão [Antigo] / Brake Master Cylinder [Old]
Cilindro Principal Do Trav Ão [Novo] / Brake Master Cylinder [New]
Tubo Do Travão 1 (Superior /Parte Dianteira) / Brake Pipe 1 (Upper/Front)
Tubo Do Travão 2 (Inferior /Parte Traseira) [Com Compressor De Ar] / Brake Pip E 2 (Lower/Rear) [With Air Compresser]
Tubo Do Travão 2 (Inferior /Parte Traseira) [Sem Compressor De Ar] / Brake Pip E 2 (Lower/Rear) [W/O Air Compresser]
Estrutura Do Eixo Diant Eiro [Com Suspensão Frontal] / Front Axle Frame [Wi Th Front Suspension]
Estrutura Do Eixo Diant Eiro [Sem Suspensão Frontal] / Front Axle Frame [W/ O Front Suspension]
Estrutura Do Carregador Dianteiro [Com Equipamento Do Carregador] / Front Loader Frame [With Loader Equipment]
Para-Choques Peso Diant Eiro [Antigo] / Front Weight Bumper [Old]
Para-Choques Peso Diant Eiro [Novo] / Front Weight Bumper [New]
Balanceiro Da Suspensão Dianteira [Com Suspensão Dianteira] [Com 3p Diante Iro] [Eixo Dianteiro: Tipo Padrão] / Front Suspensi On Rocker Arm [With Front Suspension] [With Front 3 P] [Front Axle:Standard Type]
Balanceiro Da Suspensão Dianteira [Com Suspensão Dianteira] [Com 3p Diante Iro] [Eixo Dianteiro: Tipo Pesado] / Front Suspensi On Rocker Arm [With Front Suspension] [With Front 3 P] [Front Axle:Heavy Duty Type]
Balanceiro Da Suspensão Dianteira [Com Suspensão Dianteira] [Sem 3p Diante Iro] [Eixo Dianteiro: Tipo Padrão] / Front Suspensi On Rocker Arm [With Front Suspension] [W/O Front 3p ] [Front Axle:Standard Type]
Balanceiro Da Suspensão Dianteira [Com Suspensão Dianteira] [Sem 3p Diante Iro] [Eixo Dianteiro: Tipo Pesado] / Front Suspensi On Rocker Arm [With Front Suspension] [W/O Front 3p ] [Front Axle:Heavy Duty Type]
Proteção [Com Suspensão Frontal] / Front Guard [With Front Suspension]
Eixo Dianteiro [Com Sus Pensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / F Ront Axle [With Front Suspension] [Front Axle:Stand Ard Type]
Eixo Dianteiro [Com Sus Pensão Dianteira] [Eixo Dianteiro: Tipo Pesado] / F Ront Axle [With Front Suspension] [Front Axle:Heavy Duty Type]
Eixo Dianteiro [Sem Sus Pensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / F Ront Axle [W/O Front Suspension] [Front Axle:Standa Rd Type]
Eixo Dianteiro [Sem Sus Pensão Dianteira] [Eixo Dianteiro: Tipo Pesado] / F Ront Axle [W/O Front Suspension] [Front Axle:Heavy Duty Type]
Suporte Do Eixo Diantei Ro [Componente Do Eixo Dianteiro] [Com Suspensão Di Anteira] [Eixo Dianteiro: Tipo Padrão] / Front Axle Bracket [Front Axle Component] [With Front Suspens Ion] [Front Axle:Standard Type]
Suporte Do Eixo Diantei Ro [Componente Do Eixo Dianteiro] [Com Suspensão Di Anteira] [Eixo Dianteiro: Tipo Pesado] / Front Axle Bracket [Front Axle Component] [With Front Suspens Ion] [Front Axle:Heavy Duty Type]
Suporte Do Eixo Diantei Ro [Sem Suspensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / Front Axle Bracket [W/O Front Suspension] [Front Axle:Standard Type]
Suporte Do Eixo Diantei Ro [Componente Do Eixo Dianteiro] [Sem Suspensão Di Anteira] [Eixo Dianteiro: Tipo Pesado] / Front Axle Bracket [Front Axle Component] [W/O Front Suspensi On] [Front Axle:Heavy Duty Type]
Caixa Do Eixo Dianteiro [Componente Do Eixo Dianteiro] [Eixo Dianteiro: Ti Po Padrão] / Front Axle Housing [Front Axle Compone Nt] [Front Axle:Standard Type]
Caixa Do Eixo Dianteiro [Componente Do Eixo Dianteiro] [Eixo Dianteiro: Ti Po Pesado] / Front Axle Housing [Front Axle Compone Nt] [Front Axle:Heavy Duty Type]
Diferencial Dianteiro [ Componente Do Eixo Dianteiro] [Eixo Dianteiro: Tipo Padrão] / Front Differential [Front Axle Component ] [Front Axle:Standard Type]
Diferencial Dianteiro [ Componente Do Eixo Dianteiro] [Eixo Dianteiro: Tipo Pesado] / Front Differential [Front Axle Component ] [Front Axle:Heavy Duty Type]
Veio Do Carreto Diferen Cial [Componente Do Eixo Dianteiro] [Eixo Dianteiro : Tipo Padrão] / Differential Gear Shaft [Front Axl E Component] [Front Axle:Standard Type]
Veio Do Carreto Diferen Cial [Componente Do Eixo Dianteiro] [Eixo Dianteiro : Tipo Pesado] / Differential Gear Shaft [Front Axl E Component] [Front Axle:Heavy Duty Type]
Sensor Do Ângulo De Vir Agem Da Roda [Componente Do Eixo Dianteiro] [Eixo D Ianteiro: Tipo Padrão] [Antigo] / Wheel Turning Ang Le Sensor [Front Axle Component] [Front Axle:Standa Rd Type] [Old]
Sensor Do Ângulo De Vir Agem Da Roda [Componente Do Eixo Dianteiro] [Eixo D Ianteiro: Tipo Padrão] [Novo] / Wheel Turning Angle Sensor [Front Axle Component] [Front Axle:Standard Type] [New]
Sensor Do Ângulo De Vir Agem Da Roda [Componente Do Eixo Dianteiro] [Eixo D Ianteiro: Tipo Pesado] / Wheel Turning Angle Sensor [Front Axle Component] [Front Axle:Heavy Duty Type ]
Ponteira Da Direção/Cil Indro Da Direção [Componente Do Eixo Dianteiro] [Ei Xo Dianteiro: Tipo Padrão] / Tie Rod/Steering Cylin Der [Front Axle Component] [Front Axle:Standard Typ E]
Ponteira Da Direção/Cil Indro Da Direção [Componente Do Eixo Dianteiro] [Ei Xo Dianteiro: Tipo Pesado] / Tie Rod/Steering Cylin Der [Front Axle Component] [Front Axle:Heavy Duty T Ype]
Veio Do Propulsor E Res Guardo [Com Suspensão Dianteira] / Propeller Shaft And Cover [With Front Suspension]
Veio Do Propulsor E Res Guardo [Sem Suspensão Dianteira] / Propeller Shaft And Cover [W/O Front Suspension]
Direcção Assistida [Peças Componentes] / Steer Ing Post [Component Parts]
Pedal Inclinacao / Tilt Pedal
Comando De Direção [Sem Direção Automática] / Steering Controller [Auto Steering Incompatible]
Hidráulica Bomba De Moradia [Componente De Translaxe] / Hydraulic Pump Housing [Transaxle Component]
Bomba Hidraulico [Componente De Translaxe] / Hydraulic Pump [Transaxle Componen T]
Embraiagem/Filtro Da Bomba H Idráulica [Componente De Translaxe] / Hydraulic Pum P Gear / Filter [Transaxle Component]
Linha De Óleo Hidráulico (Ei Xo Tranversal) [Componente De Translaxe] / Hydrauli C Oil Line (Transaxle) [Transaxle Component]
Circuito Oleo Direcção (Radi Ador Oleo/Frente) / Hydraulic Oil Line (Oil Cooler/ Front)
Circuito Oleo Direcção (Radi Ador Oleo/Traseira) / Hydraulic Oil Line (Oil Coole R/Rear)
Radiador Oleo [Com Tdf Diant Eira] / Oil Cooler [With Front Pto]
Circuito Oleo Direcção (Filt Ro De Direcção) / Hydraulic Oil Line (Steering Filt Er)
Filtro Oleo 2 [Peças Compone Ntes] / Oil Filter 2 [Component Parts]
Circuito Oleo Direcção (Dire Cção Valvula) / Hydraulic Oil Line (Steering Valve)
Tubo Da Direção (Forneciment O) [Eixo Dianteiro: Tipo Padrão] / Steering Hose (D Elivery) [Front Axle:Standard Type]
Tubo Da Direção (Forneciment O) [Eixo Dianteiro: Tipo Pesado] / Steering Hose (D Elivery) [Front Axle:Heavy Duty Type]
Linha De Óleo Hidráulico (Tu Bo De Fornecimento Do Eixo Dianteiro/Traseiro) [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / Hydraulic Oil Line (Front Axle Delivery Pipe/Fro Nt) [With Front Suspension] [Front Axle:Standard Ty Pe]
Linha De Óleo Hidráulico (Tu Bo De Fornecimento Do Eixo Dianteiro/Traseiro) [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Pesado] / Hydraulic Oil Line (Front Axle Delivery Pipe/Fro Nt) [With Front Suspension] [Front Axle:Heavy Duty Type]
Linha De Óleo Hidráulico (Tu Bo De Fornecimento Do Eixo Dianteiro/Traseiro) [Sem Suspensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / Hydraulic Oil Line (Front Axle Delivery Pipe/Fro Nt) [W/O Front Suspension] [Front Axle:Standard Typ E]
Linha De Óleo Hidráulico (Tu Bo De Fornecimento Do Eixo Dianteiro/Traseiro) [Sem Suspensão Dianteira] [Eixo Dianteiro: Tipo Pesado] / Hydraulic Oil Line (Front Axle Delivery Pipe/Fro Nt) [W/O Front Suspension] [Front Axle:Heavy Duty T Ype]
Linha De Óleo Hidráulico (Tu Bo De Fornecimento Do Eixo Dianteiro/Traseiro) / Hy Draulic Oil Line (Front Axle Delivery Pipe/Rear)
Linha De Óleo Hidráulico (Fi Ltro De Óleo) / Hydraulic Oil Line (Oil Filter)
Linha De Óleo Hidráulico (Fi Ltro De Óleo A Válvula De Controlo Remoto/Abertura De Drenagem Hidráulica) [Com Equipamento Do Carrega Dor] / Hydraulic Oil Line (Oil Filter To Remote Con Trol Valve/Hyd. Drain Port) [With Loader Equipment]
Linha De Óleo Hidráulico (Fi Ltro De Óleo A Válvula De Controlo Remoto/Abertura De Drenagem Hidráulica) [Sem Equipamento Do Carrega Dor] / Hydraulic Oil Line (Oil Filter To Remote Con Trol Valve/Hyd. Drain Port) [W/O Loader Equipment]
Linha De Óleo Hidráulico (Tu Bo Do Travão A Válvula De Controlo Remoto) [Com Sus Pensão Dianteira] / Hydraulic Oil Line (Brake Pipe To Remote Control Valve) [With Front Suspension]
Linha De Óleo Hidráulico (Tu Bo Do Travão A Válvula De Controlo Remoto) [Sem Sus Pensão Dianteira] / Hydraulic Oil Line (Brake Pipe To Remote Control Valve) [W/O Front Suspension]
Bloco De Válvula 1 (Eixo Tra Nversal) [Componente De Translaxe] / Valve Block 1 (Transaxle) [Transaxle Component]
Bloco De Válvula 2 (Válvula Solenóide) [Componente De Translaxe] / Valve Block 2 (Solenoid Valve) [Transaxle Component]
Bomba Hidráulica E Filtro Do Óleo [Com Suspensão Dianteira] [Com Equipamento Do Carregador] / Hydraulic Pump And Oil Filter [With Front Suspension] [With Loader Equipment]
Bomba Hidráulica E Filtro Do Óleo [Com Suspensão Dianteira] [Sem Equipamento Do Carregador] / Hydraulic Pump And Oil Filter [With Front Suspension] [W/O Loader Equipment]
Bomba Hidráulica E Filtro Do Óleo [Sem Suspensão Dianteira] [Sem Equipamento Do Carregador] / Hydraulic Pump And Oil Filter [W/O F Ront Suspension] [W/O Loader Equipment]
Tubo Da Válvula Da Suspensão Dianteira (Válvula De Controlo Remoto) [Com Suspen São Dianteira] / Front Suspension Valve Pipe (Remot E Control Valve) [With Front Suspension]
Tubo Da Válvula Da Suspensão Dianteira (Parte Traseira) [Com Suspensão Dianteir A] [Com Saída Hidráulica Dianteira] / Front Suspens Ion Valve Pipe (Rear) [With Front Suspension] [With Front Hyd. Outlet]
Tubo Da Válvula Da Suspensão Dianteira (Parte Traseira) [Com Suspensão Dianteir A] [Sem Saída Hidráulica Dianteira] / Front Suspens Ion Valve Pipe (Rear) [With Front Suspension] [W/O Front Hyd. Outlet]
Válvula Da Suspensão Diantei Ra [Com Suspensão Dianteira] / Front Suspension Val Ve [With Front Suspension]
Valvula Da Suspensão Frontal [Peças Componentes][Com Suspensão Dianteira] / Fro Nt Suspension Valve [Component Parts][With Front Su Spension]
Suspensão Frontal Valvula Tu Bo (Frente) [Com Suspensão Dianteira] [Eixo Diantei Ro: Tipo Padrão] [Sem Saída Hidráulica Dianteira] / Front Suspension Valve Pipe (Front) [With Front Su Spension] [Front Axle:Standard Type] [W/O Front Hyd . Outlet]
Suspensão Frontal Valvula Tu Bo (Frente) [Com Suspensão Dianteira] [Eixo Diantei Ro: Tipo Pesado] [Com Saída Hidráulica Dianteira] / Front Suspension Valve Pipe (Front) [With Front Su Spension] [Front Axle:Heavy Duty Type] [With Front Hyd. Outlet]
Suspensão Frontal Valvula Tu Bo (Frente) [Com Suspensão Dianteira] [Eixo Diantei Ro: Tipo Pesado] [Sem Saída Hidráulica Dianteira] / Front Suspension Valve Pipe (Front) [With Front Su Spension] [Front Axle:Heavy Duty Type] [W/O Front H Yd. Outlet]
Suspensão Frontal Acumulador [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Pa Drão] / Front Suspension Accumulator [With Front Su Spension] [Front Axle:Standard Type]
Suspensão Frontal Acumulador [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Pe Sado] / Front Suspension Accumulator [With Front Su Spension] [Front Axle:Heavy Duty Type]
Suspensão Frontal Cilindro T Ubo [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Padrão] / Front Suspension Cylinder Hose [With Fro Nt Suspension] [Front Axle:Standard Type]
Suspensão Frontal Cilindro T Ubo [Com Suspensão Dianteira] [Eixo Dianteiro: Tipo Pesado] / Front Suspension Cylinder Hose [With Fro Nt Suspension] [Front Axle:Heavy Duty Type]
Válvula De Controlo Remoto ( 3 Válvulas) / Remote Control Valve (3 Valves)
Válvula De Controlo Remoto ( 4 Válvulas) [Sem 3p Dianteiro] / Remote Control Val Ve (4 Valves) [W/O Front 3p]
Válvula De Controlo Remoto ( 4 Válvulas) [Com Saída Hidráulica Dianteira] / Remo Te Control Valve (4 Valves) [With Front Hyd. Outlet ]
Válvula De Controlo Remoto ( 4 Válvulas) [Com 3p Dianteiro] [Sem Saída Hidráulic A Dianteira] / Remote Control Valve (4 Valves) [Wit H Front 3p] [W/O Front Hyd. Outlet]
Válvula De Controlo Remoto ( 3 Válvulas) [Peças Componentes] / Auxiliary Control Valve (3 Valves) [Component Parts]
Válvula De Controlo Remoto ( 4 Válvulas) [Peças Componentes] / Auxiliary Control Valve (4 Valves) [Component Parts]
Válvula De Controle Direcion Al 1 (3 Válvulas) [Peças Componentes] / Directional Control Valve 1 (3 Valves) [Component Parts]
Válvula De Controle Direcion Al 1 (4 Válvulas) [Peças Componentes] / Directional Control Valve 1 (4 Valves) [Component Parts]
Válvula De Controle Direcion Al 2 [Peças Componentes] / Directional Control Valv E 2 [Component Parts]
Válvula De Controle Direcion Al 3 [Peças Componentes] / Directional Control Valv E 3 [Component Parts]
Válvula Central [Peças Compo Nentes] / Center Valve [Component Parts]
Válvula De Placa End [Peças Componentes] / End Plate Valve [Component Parts]
Coletor De Óleo (Válvula De Controlo Remoto) [2p] / Oil Collector(Remote Contro L Valve) [2p]
Coletor De Óleo (Válvula De Controlo Remoto) [3p] / Oil Collector(Remote Contro L Valve) [3p]
Coletor De Óleo (Válvula De Controlo Remoto) [4p (5 Válvulas)] / Oil Collector( Remote Control Valve) [4p(5 Valves)]
Alavanca Da Válvula De Contr Olo Auxiliar (3 Válvulas) / Auxiliary Control Valve Lever (3 Valves)
Alavanca Da Válvula De Contr Olo Auxiliar (4 Válvulas) / Auxiliary Control Valve Lever (4 Valves)
Cabo Da Válvula De Controlo Auxiliar (3 Válvulas) / Auxiliary Control Valve Wir E (3 Valves)
Cabo Da Válvula De Controlo Auxiliar (4 Válvulas) / Auxiliary Control Valve Wir E (4 Valves)
Tubo Da Saída Hidráulica Dia Nteira (Parte Traseira) [Com Saída Hidráulica Diant Eira] / Front Hydraulic Outlet Pipe (Rear) [With Fr Ont Hyd. Outlet]
Tubo Da Saída Hidráulica Dia Nteira (Intermédia) [Com Saída Hidráulica Dianteira ] / Front Hydraulic Outlet Pipe (Middle) [With Fron T Hyd. Outlet]
Valvula Travao Reboque / Tra Iler Brake Valve
Tubo Da Válvula Do Travão De Reboque / Trailer Brake Valve Pipe
Tubo De Óleo Do Carregador ( Parte Traseira) [Com Equipamento Do Carregador] / F Ront Loader Oil Pipe (Rear) [With Loader Equipment]
Tubo De Óleo Do Carregador ( Parte Dianteira) [Com Equipamento Do Carregador] / Front Loader Oil Pipe (Front) [With Loader Equipmen T]
Compressor De Ar [Com Compressor De Ar] / Air Compressor [With Air Compressor]
Tubo Do Compressor De Ar [Com Co Mpressor De Ar] / Air Compressor Pipe [With Air Com Pressor]
Deposito De Ar [Tipo De Suspensã O (Ar)] [Com Compressor De Ar] / Air Tank [Suspensi On Type (Air)] [With Air Compressor]
Deposito De Ar [Tipo De Suspensã O (Mola)] [Com Compressor De Ar] / Air Tank [Suspen Sion Type (Spring)] [With Air Compressor]
Valvula De Ar [Com Compressor De Ar] / Air Valve [With Air Compressor]
Valvula De Ar [Peças Componentes ] [Com Compressor De Ar] / Air Valve [Component Par Ts] [With Air Compressor]
Valvula De Ar (Reboque) [Com Com Pressor De Ar] / Air Valve (Trailer) [With Air Comp Ressor]
Valvula De Ar (Reboque) [Peças C Omponentes] [Com Compressor De Ar] / Air Valve (Tra Iler) [Component Parts] [With Air Compressor]
Elo 3p Dianteiro (Elo Estrutura/Superior) [Com Saída Hidrá Ulica Dianteira] / Front 3p Link (Frame/Top Link) [ With Front Hyd. Outlet]
Elo 3p Dianteiro (Elo Estrutura/Superior) [Sem Saída Hidrá Ulica Dianteira] / Front 3p Link (Frame/Top Link) [ W/O Front Hyd. Outlet]
Elo 3p Dianteiro (Içador) [Com 3p Dianteiro] [Antigo] / Fr Ont 3p Link (Lifter) [With Front 3p] [Old]
Elo 3p Dianteiro (Içador) [Com 3p Dianteiro] [Novo] / Fron T 3p Link (Lifter) [With Front 3p] [New]
Ligação 3p Dianteira (Cilindro) [Com 3p Dianteiro] [Antigo ] / Front 3p Link (Cylinder) [With Front 3p] [Old]
Ligação 3p Dianteira (Cilindro) [Com 3p Dianteiro] [Novo] / Front 3p Link (Cylinder) [With Front 3p] [New]
Tdf Dia Nteira [Com Tdf Dianteira] / Front Pto [With Front Pto]
Caixa D A Engrenagem Tdf 1 (Carreto) [Peças Componentes] [C Om Tdf Dianteira] / Pto Gear Case 1 (Gear) [Compone Nt Parts] [With Front Pto]
Caixa D A Engrenagem Tdf 3 (Embraiagem) [Peças Componentes] [Com Tdf Dianteira] / Pto Gear Case 3 (Clutch) [Co Mponent Parts] [With Front Pto]
Caixa D A Engrenagem Tdf 4 (Caixa) [Peças Componentes] [Com Tdf Dianteira] / Pto Gear Case 4 (Case) [Component Parts] [With Front Pto]
Caixa D A Engrenagem Tdf 5 (Kit De Juntas E Vedantes) [Peça S Componentes] [Com Tdf Dianteira] / Pto Gear Case 5 (Gasket And Seal Kit) [Component Parts] [With Fro Nt Pto]
Suporte Do Elo Superior/Suporte Do Acoplador / Top Link Br Acket/Coupler Bracket
Ligação 3 Pontos (Ligação Superior:Manual) / 3-Point Linka Ge (Top Link:Manual)
Ligação 3 Pontos (Ligação Inferior) / 3-Point Linkage (Lo Wer Link)
Estabil Izador (Elevador) / Stabilizer(Lifter)
3-Pont Acoplamento (Tirante) / 3-Point Linkage (Lift Rod)
Puxo Ba Rra / Drawbar Bracket
Barra R Eboque(Padrão) / Drawbar(Standard)
Barra R Eboque(Fix Piton) / Drawbar(Fix Piton)
Puxo (E Scada) / Hitch (Ladder)
Puxo (D Romone) / Hitch (Dromone)
Puxo (D Romone) [Peças Componentes] / Hitch (Dromone) [Comp Onent Parts]
Puxo (D Romone) Control Alavanca / Hitch (Dromone) Trailer Lever
Gancho Trailer (Automatico) / Trailer Clevis (Automatic)
Gancho Trailer (Manual) / Trailer Clevis (Manual)
Capot Inferior (Direito) / Hood (Bonnet) Side Lower Rh
Capot Inferior (Esquerdo) [Com Compressor De A R] / Hood (Bonnet) Side Lower Lh [With Air Compress Or]
Capot Inferior (Esquerdo) [Sem Compressor De A R] / Hood (Bonnet) Side Lower Lh [W/O Air Compresso R]
Placa Do Obturador (Silenciador/Isolador) / Sh Utter Plate (Sound Absorber/Insulator)
Guarda-Lamas Dianteiro (W:410) [Eixo Dianteiro :Tipo Padrão] [Antigo] / Front Fender (W:410) [Fron T Axle:Standard Type] [Old]
Guarda-Lamas Dianteiro (W:410) [Eixo Dianteiro :Tipo Padrão] [Novo] / Front Fender (W:410) [Front Axle:Standard Type] [New]
Guarda-Lamas Dianteiro (W:540) [Eixo Dianteiro :Tipo Padrão] [Antigo] / Front Fender (W:540) [Fron T Axle:Standard Type] [Old]
Guarda-Lamas Dianteiro (W:540) [Eixo Dianteiro :Tipo Padrão] [Novo] / Front Fender (W:540) [Front Axle:Standard Type] [New]
Guarda-Lamas Dianteiro (W:410) [Eixo Dianteiro :Tipo Enhancement] / Front Fender (W:410) [Front Ax Le:Heavy Duty Type]
Guarda-Lamas Dianteiro (W:540) [Eixo Dianteiro :Tipo Enhancement] / Front Fender (W:540) [Front Ax Le:Heavy Duty Type]
Es Trutura Cabine / Cab Frame
De Grau Direito [Com Equipamento Do Carregador] / Step Rh [With Loader Equipment]
De Grau Direito [Sem Equipamento Do Carregador] [Com S Uspensão Dianteira] / Step Rh [W/O Loader Equipment ] [With Front Suspension]
De Grau Direito [Sem Equipamento Do Carregador] [Sem S Uspensão Dianteira] / Step Rh [W/O Loader Equipment ] [W/O Front Suspension]
De Grau Esquerdo / Step Lh
Co Bertura Frontal / Front Cover
Vi Dro Frente / Front Glass
Po Rta Drt / Door Rh
Po Rta Esq / Door Lh
Tr Inco Porta Drt / Door Lock Rh
Tr Inco Porta Esq / Door Lock Lh
Vi Dro Traseiro Da Escotilha / Hatch Back Glass
Te Jadilho / Sun Roof
Es Pelho Rectrovisor / Rearview Mirror
Te Cto Interior / Inner Roof
Co Bertura Exterior Do Tejadilho [Antiga] / Outer Roof [Old]
Co Bertura Exterior Do Tejadilho [Nova] / Outer Roof [ New]
Su Porte Do Assento / Seat Bracket
Ba Nco / Seat
Ba Nco 1 (Almofada) [Peças Componentes] / Seat1 (Seat Cushion) [Component Parts]
Ba Nco 2 (Apoio Braço/Costas Banco) [Peças Componentes ] / Seat2 (Armrest/Backrest) [Component Parts]
Su Spensão Do Assento [Peças Componentes] / Seat Suspe Nsion [Component Parts]
Ta Pete Do Piso / Floor Mat
Ma Terial À Prova De Som 1 (Painel) / Soundproof Mater Ial 1 (Panel)
Ma Terial À Prova De Som 2 (Chão) / Soundproof Materia L 2 (Floor)
Ma Terial À Prova De Som 3 (Consola) / Soundproof Mate Rial 3 (Console)
Ma Terial À Prova De Som 4 (Tejadilho) [Antiga] / Soun Dproof Material 4 (Roof) [Old]
Ma Terial À Prova De Som 4 (Tejadilho) [Nova] / Soundp Roof Material 4 (Roof) [New]
Co Bertura De Mudança (Consola Direita) / Shift Cover (Console Rh)
Ta Mpa Do Rádio E Tampa Do Painel De Controlo Do Ar Co Ndicionado / Radio Cover And Air Conditioner Contro L Panel Cover
Co Nsola Do Lado Esquerdo / Console Lh
Re Sguardo Coluna / Pillar Cover
Co Bertura Do Guarda-Lamas / Fender Cover
Gu Arda Lamas (Direito) / Fender Rh
Gu Arda Lamas (Esquerda) / Fender Lh
Gu Arda Lamas / Over Fender
Su Porte Cabine Frente [Com Equipamento Do Carregador] / Cab Bracket Front [With Loader Equipment]
Su Porte Cabine Frente [Sem Equipamento Do Carregador] / Cab Bracket Front [W/O Loader Equipment]
Ca Bine Suporte (Traseira)[Suspensão] / Cab Bracket Re Ar [Suspension Type]
Ca Bine Suporte (Traseira)[Borracgha] / Cab Bracket Re Ar [Rubber Type]
Am Ortecedor Traseiro [Tipo De Suspensão (Ar)] [Com Co Mpressor De Ar] / Rear Damper [Suspension Type (Air )] [With Air Compressor]
Tr Aseira Amortecedor [Tipo De Suspensão (Mola)] / Rea R Damper [Suspension Type (Spring)]
Ca Ixa De Ferramentas [Com Equipamento Do Carregador] / Tool Box [With Loader Equipment]
Ca Ixa De Ferramentas [Sem Equipamento Do Carregador] / Tool Box [W/O Loader Equipment]
Ar Condicionado / Air Conditione R
Conduta Do Ar Condicionado (Ar F Rio) / Air Conditioner Duct (Fresh Air)
Conduta Do Ar Condicionado (Tras Eira) / Air Conditioner Duct (Rear)
Modo Caixa / Mode Case
Entradas Ar Painel Instrumentos / Dashboard Air Outlets
Circulaçao Ar Interior / Inner A Ir Recirculation
Tubo Ar Condicionado/Tubo Conden Sador / Air Conditioner Hose/Condenser Hose
Polia De Acionamento Do Compress Or [Com Compressor De Ar] / Compressor Drive Pulley [With Air Compressor]
Polia De Acionamento Do Compress Or [Sem Compressor De Ar] / Compressor Drive Pulley [W/O Air Compressor]
Compressor (Ar Condicionado) / C Ompressor (Air Conditioner)
Roda Dianteira (380/85r28:8 Buraco J Ante) [Michelin] / Front Wheel (380/85r28:8 Holes R Im) [Michelin]
Roda Dianteira (380/85r28:8 Buraco J Ante) [Trelleborg] / Front Wheel (380/85r28:8 Holes Rim) [Trelleborg]
Roda Dianteira (380/85r28:8 Buraco J Ante) [Firestone] / Front Wheel (380/85r28:8 Holes Rim) [Firestone]
Roda Dianteira (420/70r28:8 Buraco J Ante) [Trelleborg] / Front Wheel (420/70r28:8 Holes Rim) [Trelleborg]
Roda Dianteira (420/70r28:8 Buraco J Ante) [Firestone] / Front Wheel (420/70r28:8 Holes Rim) [Firestone]
Roda Dianteira (420/70r28:8 Buraco J Ante) [Mitas] / Front Wheel (420/70r28:8 Holes Rim) [Mitas]
Roda Dianteira (420/85r28:8 Buraco J Ante) [Michelin] / Front Wheel (420/85r28:8 Holes R Im) [Michelin]
Roda Dianteira (420/85r28:8 Buraco J Ante) [Trelleborg] / Front Wheel (420/85r28:8 Holes Rim) [Trelleborg]
Roda Dianteira (420/85r28:8 Buraco J Ante) [Firestone] / Front Wheel (420/85r28:8 Holes Rim) [Firestone]
Roda Dianteira (420/85r28:8 Buraco J Ante) [Mitas] / Front Wheel (420/85r28:8 Holes Rim) [Mitas]
Roda Dianteira (480/70r28:8 Buraco J Ante) [Michelin] / Front Wheel (480/70r28:8 Holes R Im) [Michelin]
Roda Dianteira (480/70r28:8 Buraco J Ante) [Trelleborg] / Front Wheel (480/70r28:8 Holes Rim) [Trelleborg]
Roda Dianteira (480/70r28:8 Buraco J Ante) [Firestone] / Front Wheel (480/70r28:8 Holes Rim) [Firestone]
Roda Dianteira (480/70r28:8 Buraco J Ante) [Mitas] / Front Wheel (480/70r28:8 Holes Rim) [Mitas]
Roda Dianteira (540/65r28:8 Buraco J Ante) [Michelin] / Front Wheel (540/65r28:8 Holes R Im) [Michelin]
Roda Dianteira (540/65r28:8 Buraco J Ante) [Trelleborg] / Front Wheel (540/65r28:8 Holes Rim) [Trelleborg]
Roda Dianteira (540/65r28:8 Buraco J Ante) [Firestone] / Front Wheel (540/65r28:8 Holes Rim) [Firestone]
Roda Dianteira (540/65r28:8 Buraco J Ante) [Mitas] / Front Wheel (540/65r28:8 Holes Rim) [Mitas]
Roda Dianteira (380/85r28:10 Buraco Jante) [Michelin] / Front Wheel (380/85r28:10 Holes Rim) [Michelin]
Roda Dianteira (380/85r28:10 Buraco Jante) [Trelleborg] / Front Wheel (380/85r28:10 Hol Es Rim) [Trelleborg]
Roda Dianteira (380/85r28:10 Buraco Jante) [Mitas] / Front Wheel (380/85r28:10 Holes Ri M) [Mitas]
Roda Dianteira (420/70r28:10 Buraco Jante) [Michelin] / Front Wheel (420/70r28:10 Holes Rim) [Michelin]
Roda Dianteira (420/70r28:10 Buraco Jante) [Trelleborg] / Front Wheel (420/70r28:10 Hol Es Rim) [Trelleborg]
Roda Dianteira (420/70r28:10 Buraco Jante) [Firestone] / Front Wheel (420/70r28:10 Hole S Rim) [Firestone]
Roda Dianteira (420/70r28:10 Buraco Jante) [Mitas] / Front Wheel (420/70r28:10 Holes Ri M) [Mitas]
Roda Dianteira (420/85r28:10 Buraco Jante) [Michelin] / Front Wheel (420/85r28:10 Holes Rim) [Michelin]
Roda Dianteira (420/85r28:10 Buraco Jante) [Trelleborg] / Front Wheel (420/85r28:10 Hol Es Rim) [Trelleborg]
Roda Dianteira (420/85r28:10 Buraco Jante) [Firestone] / Front Wheel (420/85r28:10 Hole S Rim) [Firestone]
Roda Dianteira (420/85r28:10 Buraco Jante) [Mitas] / Front Wheel (420/85r28:10 Holes Ri M) [Mitas]
Roda Dianteira (480/70r28:10 Buraco Jante) [Michelin] / Front Wheel (480/70r28:10 Holes Rim) [Michelin]
Roda Dianteira (480/70r28:10 Buraco Jante) [Trelleborg] / Front Wheel (480/70r28:10 Hol Es Rim) [Trelleborg]
Roda Dianteira (480/70r28:10 Buraco Jante) [Firestone] / Front Wheel (480/70r28:10 Hole S Rim) [Firestone]
Roda Dianteira (480/70r28:10 Buraco Jante) [Mitas] / Front Wheel (480/70r28:10 Holes Ri M) [Mitas]
Roda Dianteira (540/65r28:10 Buraco Jante) [Michelin] / Front Wheel (540/65r28:10 Holes Rim) [Michelin]
Roda Dianteira (540/65r28:10 Buraco Jante) [Trelleborg] / Front Wheel (540/65r28:10 Hol Es Rim) [Trelleborg]
Roda Dianteira (540/65r28:10 Buraco Jante) [Firestone] / Front Wheel (540/65r28:10 Hole S Rim) [Firestone]
Roda Dianteira (540/65r28:10 Buraco Jante) [Mitas] / Front Wheel (540/65r28:10 Holes Ri M) [Mitas]
Roda Traseira (460/85r38) [Michelin] / Rear Wheel (460/85r38) [Michelin]
Roda Traseira (460/85r38) [Trellebor G] / Rear Wheel (460/85r38) [Trelleborg]
Roda Traseira (460/85r38) [Firestone ] / Rear Wheel (460/85r38) [Firestone]
Roda Traseira (460/85r38) [Mitas] / Rear Wheel (460/85r38) [Mitas]
Roda Traseira (520/70r38) [Michelin] / Rear Wheel (520/70r38) [Michelin]
Roda Traseira (520/70r38) [Trellebor G] / Rear Wheel (520/70r38) [Trelleborg]
Roda Traseira (520/70r38) [Firestone ] / Rear Wheel (520/70r38) [Firestone]
Roda Traseira (520/70r38) [Mitas] / Rear Wheel (520/70r38) [Mitas]
Roda Traseira (520/85r38) [Michelin] / Rear Wheel (520/85r38) [Michelin]
Roda Traseira (520/85r38) [Firestone ] / Rear Wheel (520/85r38) [Firestone]
Roda Traseira (520/85r38) [Mitas] / Rear Wheel (520/85r38) [Mitas]
Roda Traseira (580/70r38) [Michelin] / Rear Wheel (580/70r38) [Michelin]
Roda Traseira (580/70r38) [Trellebor G] / Rear Wheel (580/70r38) [Trelleborg]
Roda Traseira (580/70r38) [Firestone ] / Rear Wheel (580/70r38) [Firestone]
Roda Traseira (580/70r38) [Mitas] / Rear Wheel (580/70r38) [Mitas]
Roda Traseira (650/65r38) [Trellebor G] / Rear Wheel (650/65r38) [Trelleborg]
Roda Traseira (650/65r38) [Firestone ] / Rear Wheel (650/65r38) [Firestone]
Roda Traseira (650/65r38) [Mitas] / Rear Wheel (650/65r38) [Mitas]
Decalcomania(Painel/Cobertura De Mudança) / Lab El (Panel/Shift Cover)
Etiqueta (Unidade Control Electrico/Controlador ) / Label (Ecu/Controller)
Decalcomania (Cabine Interior) / Label (Cab Int Erior)
Acessorios / Accessories
Kit Alternador (200a) [Opção] / Alternator Kit (200 A) [Option]
Alternador [Peças Componentes] (200a) [Opção] / Alt Ernator [Component Parts] (200a) [Option]
Kit Farios Trabalho (Trseira) [Opçao] / Working Lig Ht (Rear) Kit [Option]
Luzes Frente (Farol De Repetição) [Opçao] / Head Li Ght Kit (Repeat Head Light) [Option]
Kit Da Tdf Dianteira (6 Estrias) (Caixa Da Engrenag Em) [Opção] / Front Pto Kit (6 Splines) (Gear Case) [Option]
Kit Da Tdf Dianteira (6 Estrias) (Caixa Da Engrenag Em/Junta) [Peças Componentes] [Opção] / Front Pto K It (6 Splines) (Gear Case/Gasket) [Component Parts] [Option]
Kit Da Tdf Dianteira (6 Estrias) (Arrefecedor Do Ól Eo) [Opção] / Front Pto Kit (6 Splines) (Oil Cooler ) [Option]
Kit Do Sensor (Radar) [Opção] / Sensor Kit (Radar) [Option]
Kit De 21 Estrias De Tdf [Opção] [Eu / Pto Kit (21 Splines) [Option] [Eu]
Auxiliar Do Válvula De Controlo Kit (Mecânica 4ª) ( Válvula) [Opção] / Auxiliary Control Valve Kit (Mec H.4th) (Valve) [Option]
Auxiliar Do Válvula De Controlo Kit (Mecânica 4ª) ( Alavanca) [Opção] / Auxiliary Control Valve Kit (Me Ch.4th) (Lever) [Option]
Kit Do Reboque (K80) [Opção] / Trailer Kit (K80) [O Ption]
Ligacao Superior (Hidráulica) [Opção] / Top Link Ki T (Hydraulic) [Option]
Kit De Ligação 3-P Dianteira (Mecânica 4ª) (Válvula ) [Opção] / Front 3p Link Kit (Mech.4th) (Valve) [O Ption]
Kit De Ligação 3-P Dianteira (Mecânica 4ª) (Alavanc A) [Opção] / Front 3p Link Kit (Mech.4th) (Lever) [ Option]
Kit De Suporte Da Escora [Opção] / Drawbar Bracket Kit [Option]
Kit De Escora (Acoplamento K80) [Opção] / Drawbar K It (Coupling K80) [Option]
Kit De Espelho (Calor) [Opção] / Mirror Kit (Heat) [Option]
