Kubota Tractor M7131P Parts Catalog
Model: Kubota M7131P Tractor
Number of Pages: 873 Pages
Frequently Used Items Frequently Used Items
Frequently Used Items Frequently Used Items (Electrical Parts)
Engine Crankcase (Upper)
Engine Crankcase (Lower)
Engine Oil Pan [WO Air Compressor]
Engine Cylinder Head
Engine Inlet Valve And Exhaust Valve
Engine Rocker Arm Shaft
Engine Head Cover
Engine Front Cover
Engine Piston And Crankshaft
Engine Camshaft And Idle Gear Shaft
Engine Balancer
Engine Flywheel
Engine Fuel Filter
Engine Supply Pump
Engine Injector And Glow Plug
Engine Injection Pipe
Engine Common Rail
Engine Water Flange And Thermostat
Engine Water Pump
Engine Oil Cooler
Engine Oil Separator
Engine Oil Separator [Component Parts]
Engine Oil Separator Pipe
Engine Oil Pipe (Turbo Charger)
Engine Air Cleaner [WO Front PTO]
Engine Air Cleaner [Component Parts]
Engine Inlet Pipe (Air Cleaner) [WO Air Compresser]
Engine Turbo Charger
Engine Inlet Manifold
Engine Air Cleaner Flange And Throttle Valve
Engine Egr Valve
Engine Egr Cooler
Engine Egr Water Piping
Engine Exhaust Manifold
Engine Diesel Particulate Filter Muffler
Engine Diesel Particulate Filter Muffler [Component Parts]
Engine Muffler Bracket (Dpf) 1
Engine Muffler Bracket (Dpf) 2
Engine Pressure Pipe
Engine Muffler Pipe
Engine Selective Catalytic Reduction Muffler [Old] ## S.No.=10173 S.No.;=10173
Engine Selective Catalytic Reduction Muffler [Old] ## S.No.=10174 To 10242 S.No
Engine Selective Catalytic Reduction Muffler [New] ## S.No.=10243 S.No.;=10243
Engine Muffler Pipe And Cover
Engine Diesel Exhaust Fluid Pump
Engine Diesel Exhaust Fluid Tank
Engine Diesel Exhaust Fluid Tank [Component Parts]
Engine Diesel Exhaust Fluid Hose
Engine Diesel Exhaust Fluid Heater Hose
Engine Diesel Exhaust Fluid Breather Hose
Engine Egr Valve (Selective Catalytic Reduction System)
Engine Egr Cooler (Selective Catalytic Reduction System)
Engine Egr Pipe (Selective Catalytic Reduction System)
Engine Egr Water Piping (Selective Catalytic Reduction System)
Engine Engine Electrical Parts (SensorEcu)
Engine Engine Electrical Parts (Muffler)
Engine Injector Harness
Engine Accelerator Pedal
Fuel System Fuel Tank
Fuel System Fuel Tank Bracket [Old] ## S.No.=10157 S.No.;=10157
Fuel System Fuel Tank Bracket [New] ## S.No.=10158 S.No.;=10158
Fuel System Fuel Pipe (Fuel Filter)
Fuel System Fuel Pipe (Fuel Pump)
Fuel System Fuel Pipe (Fuel Cooler) [Old] ## S.No.=10178 S.No.;=10178
Fuel System Fuel Pipe (Fuel Cooler) [New] ## S.No.=10179 S.No.;=10179
Fuel System Fuel Cooler
Fuel System Separator
Fuel System Separator [Component Parts]
Fuel System Fuel Pump
Fuel System Fuel Pump [Component Parts]
Fuel System Fuel Filter
Fuel System Fuel Filter [Component Parts]
Cooling Water System Fan Bracket
Cooling Water System Fan Drive Pulley
Cooling Water System Water Pipe And Cooler Pipe
Cooling Water System Cooler Unit [Old] ## S.No.=10173 S.No.;=10173
Cooling Water System Cooler Unit [New] ## S.No.=10174 S.No.;=10174
Cooling Water System Cooler Unit (Radiator) [Component Parts] [Old] ## S.No.=10173 S.No
Cooling Water System Cooler Unit (Radiator) [Component Parts] [New] ## S.No.=10174 S.No
Cooling Water System Cooler Unit (Inter Cooler) [Component Parts]
Cooling Water System Cooler Unit (Oil Cooler) [Component Parts]
Cooling Water System Cooler Unit (Condenser) [Component Parts]
Cooling Water System Reserve Tank [Old] ## S.No.=10178 S.No.;=10178
Cooling Water System Reserve Tank [New] ## S.No.=10179 S.No.;=10179
Cooling Water System Reserve Tank Hose [WO Air Compressor] [Old] ## S.No.=10181 S.No
Cooling Water System Reserve Tank Hose [WO Air Compressor] [New] ## S.No.=10182 S.No
Electrical System Alternator (200a)
Electrical System Alternator (200a) [Component Parts]
Electrical System Starter
Electrical System Starter [Component Parts]
Electrical System Battery
Electrical System Battery Bracket [Old] ## S.No.=10079 S.No.;=10079
Electrical System Battery Bracket [Old] ## S.No.10080 To 10173 S.No.;10080 To 10173
Electrical System Battery Bracket [New] ## S.No.=10174 S.No.;=10174
Electrical System SwitchSensor (Engine Lh)
Electrical System SwitchSensor (Engine Rh)
Electrical System Selective Catalytic Reduction Sensor [Old] ## S.No.=10101 S.No
Electrical System Selective Catalytic Reduction Sensor [Old] ## S.No.10102 To 10242 S.No
Electrical System Selective Catalytic Reduction Sensor [New] ## S.No.=10243 S.No
Electrical System Front Suspension Sensor [With Front Suspension]
Electrical System Sensor (Pedal)
Electrical System SwitchSensor [WO Air Compressor]
Electrical System Sensor (Transmission Housing Rh) [Transaxle Component]
Electrical System Sensor (Transmission Housing Lh) [Transaxle Component]
Electrical System Draft Sensorp Sensor [Old] ## S.No.=10065 S.No.;=10065
Electrical System Draft Sensorp Sensor [New] ## S.No.=10066 S.No.;=10066
Electrical System Switch (Panel Board)
Electrical System Switch (Steering)
Electrical System Switch (Shift Cover)
Electrical System External Switch
Electrical System RelayController
Electrical System Electronic Control Unit (Engine)
Electrical System Ecu
Electrical System Ecu Mounting Part
Electrical System Controller (Ceu)
Electrical System Controller (Ceu) [Component Parts]
Electrical System Panel
Electrical System Cab Inner Rear Electrical Parts (Electrical OutletAir Conditioner Contr
Electrical System Isobus Terminal
Electrical System Armrest (4 Remote Control Valves)
Electrical System Terminal
Electrical System Head Light
Electrical System Front Combination Lamp
Electrical System Work Light (FrontRoof) [Old] ## S.No.=10242 S.No.;=10242
Electrical System Work Light (FrontRoof) [New] ## S.No.=10243 S.No.;=10243
Electrical System Work Light (FrontPillar)
Electrical System Work Light (RearRoof)
Electrical System Work Light (RearPillar)
Electrical System Tail Light
Electrical System License Lamp [Old] ## S.No.=10242 S.No.;=10242
Electrical System License Lamp [New] ## S.No.=10243 S.No.;=10243
Electrical System Trailer Socket
Electrical System Room Light
Electrical System Radio Speaker
Electrical System Washer Tank
Electrical System Wiper
Electrical System Electrical Wiring (Engine) 1 (Air CleanerDpf) [Old] ## S.No.=10178 S
Electrical System Electrical Wiring (Engine) 1 (Air CleanerDpf) [New] ## S.No.=10179 S
Electrical System Electrical Wiring (Engine) 2 (Crs)
Electrical System Electrical Wiring (Engine) 3 (FuelScr)
Electrical System Electrical Wiring (Engine) 4 (FuseBattery)
Electrical System Electrical Wiring (Engine) 5 (CompressorFlywheel) [WO Air Compresser]
Electrical System Electrical Wiring (Bonnet(Hood))
Electrical System Electrical Wiring (Alternator 200a)
Electrical System Electrical Wiring (Starter)
Electrical System Electrical Wiring (Power Supply)Controller (Ceu)
Electrical System Electrical Wiring (TransaxleFront) [With Front Suspension] [WO Air Com
Electrical System Electrical Wiring (TransaxleFront) [WO Front Suspension] [WO Air Comp
Electrical System Electrical Wiring (TransAxle Rear)
Electrical System Electrical Wiring (Remote Control Valve)
Electrical System Electrical Wiring (Cab) 1 (SteeringPanel) [Old] ## S.No.=10090 S.No
Electrical System Electrical Wiring (Cab) 1 (SteeringPanel) [New] ## S.No.=10091 S.No
Electrical System Electrical Wiring (Cab) 2 (Ecu) [Old] ## S.No.=10090 S.No.;=10090
Electrical System Electrical Wiring (Cab) 2 (Ecu) [New] ## S.No.=10091 S.No.;=10091
Electrical System Electrical Wiring (Cab) 3 (Shift CoverArmrest)
Electrical System Electrical Wiring (Cab) 4 (Air Conditioner)
Electrical System Electrical Wiring (Front Pillar) [Old] ## S.No.=10072 S.No.;=10072
Electrical System Electrical Wiring (Front Pillar) [New] ## S.No.=10073 S.No.;=10073
Electrical System Electrical Wiring (Roof)
Electrical System Electrical Wiring (FlasherMudguard)
Electrical System Electrical Wiring (Front Suspension) [With Front Suspension]
Electrical System Electrical Wiring (Auto Steering) [Auto Steering Compatible]
Electrical System Electrical Wiring (Isobus)
Clutch Transmission Damper Disk And Housing Connection [Old] ## S.No.=10045 S.No
Clutch Transmission Damper Disk And Housing Connection [New] ## S.No.=10046 S.No
Clutch Transmission Transaxle
Clutch Transmission Housing Plug [Transaxle Component]
Clutch Transmission Transmission Housing [Transaxle Component]
Clutch Transmission Rear Axle Housing [Transaxle Component]
Clutch Transmission PTO Shaft Housing [Transaxle Component]
Clutch Transmission Lift Arm [Transaxle Component]
Clutch Transmission Counter Shaft [Transaxle Component]
Clutch Transmission Main Shaft [Transaxle Component] [WO Creep]
Clutch Transmission PTO Drive Shaft [Transaxle Component]
Clutch Transmission Front Clutch [Transaxle Component]
Clutch Transmission Power Shift [Transaxle Component] [WO Creep]
Clutch Transmission Hydraulic Clutch (Input) [Transaxle Component]
Clutch Transmission Hydraulic Clutch (Output) [Transaxle Component]
Clutch Transmission Power Input Shaft [Transaxle Component]
Clutch Transmission Main Clutch [Transaxle Component] [WO Creep]
Clutch Transmission Shifter [Transaxle Component] [WO Creep]
Clutch Transmission PTO Shaft Housing Inner (Clutch) [Transaxle Component]
Clutch Transmission PTO Shaft Housing Inner (Gear) [Transaxle Component]
Clutch Transmission PTO Shaft Housing Inner (PTO Shaft) [Transaxle Component]
Clutch Transmission PTO Shaft Housing Inner (Shift Fork) [Transaxle Component]
Clutch Transmission Pressure Valve [Transaxle Component]
Clutch Transmission Gear Shift Housing [Transaxle Component]
Clutch Transmission Clutch Pedal
Shift Lever Shuttle Shift Lever [Old] ## S.No.=10242 S.No.;=10242
Shift Lever Shuttle Shift Lever [New] ## S.No.=10243 S.No.;=10243
Shift Lever PTO Gear Shift Lever
Rear Axle Brake Rear Axle [Transaxle Component]
Rear Axle Brake Rear Differential [Transaxle Component]
Rear Axle Brake Brake [Transaxle Component]
Rear Axle Brake Brake Shaft [Transaxle Component]
Rear Axle Brake Rear Axle Hub
Rear Axle Brake Parking Brake Lever
Rear Axle Brake Brake Pedal
Rear Axle Brake Brake Master Cylinder
Rear Axle Brake Brake Pipe 1 (UpperFront) [With Front Suspension]
Rear Axle Brake Brake Pipe 1 (UpperFront) [WO Front Suspension]
Rear Axle Brake Brake Pipe 2 (LowerRear)
Front Axle Chassis Front Axle Frame [With Front Suspension] [WO Front PTO]
Front Axle Chassis Front Axle Frame [WO Front Suspension] [WO Front PTO]
Front Axle Chassis Front Loader Frame
Front Axle Chassis Front Weight Bumper [WO Front PTO] [Old] ## S.No.=10139 S.No
Front Axle Chassis Front Weight Bumper [WO Front PTO] [New] ## S.No.=10140 S.No
Front Axle Chassis Front Suspension Rocker Arm [With Front Suspension] [WO Front 3p] [Old
Front Axle Chassis Front Suspension Rocker Arm [With Front Suspension] [WO Front 3p] [New
Front Axle Chassis Front Guard [With Front Suspension] [WO Front 3p]
Front Axle Chassis Front Axle [With Front Suspension]
Front Axle Chassis Front Axle [WO Front Suspension]
Front Axle Chassis Front Axle Bracket [Front Axle Component] [With Front Suspension]
Front Axle Chassis Front Axle Bracket [Front Axle Component] [WO Front Suspension]
Front Axle Chassis Front Axle Housing [Front Axle Component]
Front Axle Chassis Front Differential [Front Axle Component]
Front Axle Chassis Differential Gear Shaft [Front Axle Component]
Front Axle Chassis Wheel Turning Angle Sensor [Front Axle Component]
Front Axle Chassis Tie RodSteering Cylinder [Front Axle Component]
Front Axle Chassis Propeller Shaft And Cover [With Front Suspension]
Front Axle Chassis Propeller Shaft And Cover [WO Front Suspension]
Steering Steering Wheel
Steering Steering Post [Component Parts]
Steering Tilt Pedal
Steering Steering Controller
Hydraulic System Hydraulic Pump Housing [Transaxle Component]
Hydraulic System Hydraulic Pump [Transaxle Component]
Hydraulic System Hydraulic Pump Gear Filter [Transaxle Component]
Hydraulic System Hydraulic Oil Line (Transaxle) [Transaxle Component]
Hydraulic System Hydraulic Oil Line (Oil CoolerFront)
Hydraulic System Hydraulic Oil Line (Oil CoolerRear)
Hydraulic System Hydraulic Oil Line (Steering Filter)
Hydraulic System Oil Filter 2 [Component Parts]
Hydraulic System Hydraulic Oil Line (Steering Valve)
Hydraulic System Steering Hose (Delivery) [With Front Suspension]
Hydraulic System Steering Hose (Delivery) [WO Front Suspension]
Hydraulic System Hydraulic Oil Line (Front Axle Delivery PipeFront) [With Front Suspensio
Hydraulic System Hydraulic Oil Line (Front Axle Delivery PipeFront) [WO Front Suspension
Hydraulic System Hydraulic Oil Line (Front Axle Delivery PipeRear)
Hydraulic System Hydraulic Oil Line (Oil Filter)
Hydraulic System Hydraulic Oil Line (Oil Filter To Remote Control ValveHyd. Drain Port)
Hydraulic System Hydraulic Oil Line (Brake Pipe To Remote Control Valve) [With Front Suspe
Hydraulic System Hydraulic Oil Line (Brake Pipe To Remote Control Valve) [WO Front Suspen
Hydraulic System Valve Block 1 (Transaxle) [Transaxle Component]
Hydraulic System Valve Block 2 (Solenoid Valve) [Transaxle Component]
Hydraulic System Axial Pump
Hydraulic System Axial Pump Piping [With Front Suspension]
Hydraulic System Axial Pump Piping [WO Front Suspension]
Hydraulic System Hydraulic Oil Line (Axial Pump To Remote Control Valve) [With Front Suspe
Hydraulic System Hydraulic Oil Line (Axial Pump To Remote Control Valve) [WO Front Suspen
Hydraulic System Front Suspension Valve Pipe (Rear) [With Front Suspension]
Hydraulic System Front Suspension Valve [With Front Suspension] [Old] ## S.No.=10242 S
Hydraulic System Front Suspension Valve [With Front Suspension] [New] ## S.No.=10243 S
Hydraulic System Front Suspension Valve [Component Parts][With Front Suspension]
Hydraulic System Front Suspension Valve Pipe (Front) [With Front Suspension] [WO Front Hy
Hydraulic System Front Suspension Accumulator [With Front Suspension] [Old] ## S.No
Hydraulic System Front Suspension Accumulator [With Front Suspension] [New] ## S.No
Hydraulic System Front Suspension Cylinder Hose [With Front Suspension]
Hydraulic System Remote Control Valve (4 Valves)
Hydraulic System Auxiliary Control Valve (4 Valves) [Component Parts]
Hydraulic System Directional Control Valve (4 Valves) [Component Parts]
Hydraulic System End Plate Valve [Component Parts]
Hydraulic System Oil Collector(Remote Control Valve) [4p] [Old] ## S.No.=10232 S.No
Hydraulic System Oil Collector(Remote Control Valve) [4p] [New] ## S.No.=10233 S.No
Hydraulic System Hydraulic Outlet Pipe (Load-Sensing Control Hose) [With Power Beyond]
Hydraulic System Hydraulic Outlet Pipe (Power BeyondReturn Hose) [With Power Beyond]
Hydraulic System Trailer Brake Valve
Hydraulic System Trailer Brake Valve Pipe
Hydraulic System Front Loader Oil Pipe (Rear)
Hydraulic System Front Loader Oil Pipe (Front)
3-Point Linkage Drawbar Hitch Top Link BracketCoupler Bracket [Old] ## S.No.=10222 S.No
3-Point Linkage Drawbar Hitch Top Link BracketCoupler Bracket [New] ## S.No.=10223 S.No
3-Point Linkage Drawbar Hitch 3-Point Linkage (Top LinkManual)
3-Point Linkage Drawbar Hitch 3-Point Linkage (Lower Link)
3-Point Linkage Drawbar Hitch Stabilizer
3-Point Linkage Drawbar Hitch Stabilizer [Component Parts]
3-Point Linkage Drawbar Hitch 3-Point Linkage (Lift Rod)
3-Point Linkage Drawbar Hitch Lift Cylinder
3-Point Linkage Drawbar Hitch Drawbar Bracket [Old] ## S.No.=10204 S.No.;=10204
3-Point Linkage Drawbar Hitch Drawbar Bracket [New] ## S.No.=10205 S.No.;=10205
3-Point Linkage Drawbar Hitch Hitch (Ladder)
3-Point Linkage Drawbar Hitch Trailer Clevis (Piton)
3-Point Linkage Drawbar Hitch Trailer Clevis (K80)
3-Point Linkage Drawbar Hitch Trailer Clevis (Manual)
3-Point Linkage Drawbar Hitch Trailer Clevis (Automatic)
Hood Bonnet Hood (Bonnet) Upper
Hood Bonnet Hood (Bonnet) Damper
Hood Bonnet Hood (Bonnet) Lock
Hood Bonnet Hood (Bonnet) Side Lower Rh
Hood Bonnet Hood (Bonnet) Side Lower Lh [WO Air Compressor]
Hood Bonnet Shutter Plate [Old] ## S.No.=10242 S.No.;=10242
Hood Bonnet Shutter Plate [New] ## S.No.=10243 S.No.;=10243
Hood Bonnet Shutter Plate (Sound AbsorberInsulator)
Hood Bonnet Front Fender (W540)
Cab Cab Frame
Cab Step Rh [With Front Suspension]
Cab Step Rh [WO Front Suspension]
Cab Step Lh
Cab Front Cover
Cab Front Glass
Cab Door Rh
Cab Door Lh
Cab Door Lock Rh
Cab Door Lock Lh
Cab Hatch Back Glass
Cab Sun Roof
Cab Rearview Mirror
Cab Inner Roof
Cab Outer Roof [Old] ## S.No.=10242 S.No.;=10242
Cab Outer Roof [New] ## S.No.=10243 S.No.;=10243
Cab Seat Bracket
Cab Seat
Cab Seat 1 (Seat Cushion) [Component Parts]
Cab Seat 2 (ArmrestBackrest) [Component Parts]
Cab Seat Suspension [Component Parts]
Cab Passenger Seat
Cab Floor Mat
Cab Soundproof Material 1 (Panel)
Cab Soundproof Material 2 (Floor)
Cab Soundproof Material 3 (Console)
Cab Soundproof Material 4 (Roof) [Old] ## S.No.=10242 S.No.;=10242
Cab Soundproof Material 4 (Roof) [New] ## S.No.=10243 S.No.;=10243
Cab Shift Cover (Console Rh)
Cab Radio Cover And Air Conditioner Control Panel Cover
Cab Console Lh
Cab Pillar Cover
Cab Fender Cover
Cab Fender Rh
Cab Fender Lh
Cab Over Fender
Cab Cab Bracket Front
Cab Cab Bracket Rear [Suspension Type]
Cab Rear Damper [Suspension Type (Spring)]
Cab Tool Box
Cab SMV Emblem [Old] ## S.No.=10043 S.No.;=10043
Air Conditioner Air Conditioner
Air Conditioner Air Conditioner Duct (Fresh Air)
Air Conditioner Air Conditioner Duct (Rear)
Air Conditioner Mode Case
Air Conditioner Dashboard Air Outlets
Air Conditioner Inner Air Recirculation
Air Conditioner Heater Hose
Air Conditioner Air Conditioner HoseCondenser Hose
Air Conditioner Compressor Drive Pulley [WO Air Compressor]
Air Conditioner Compressor (Air Conditioner)
Front Rear Tire Front Wheel (54065r28) [Michelin]
Front Rear Tire Rear Wheel (65065r38) [Michelin]
Labels Label (Hood (Bonnet))
Labels Label (Front)
Labels Label (PanelShift Cover)
Labels Label (Rear)
Labels Label (EcuController)
Labels Label (Cab Interior)
Accessories And Service Parts Accessories And Service Parts
Option Pipe Kit (CondensateurReserve Tank) [Option] ## S.No.=10181 S.No.;=10181
Option Beacon Lamp Kit [Option]
Option Extension Light Kit [Option]
Option Head Light Kit (Repeat Head Light) [Option]
Option Sensor Kit (Radar) [Option]
Option Anntena Kit (Auto Steer Rtk Modem) (Controller) [Option]
Option Anntena Kit (Auto Steer Rtk Modem) (Anntena) [Option]
Option Anntena Kit (Auto Steer DgpsWithout Rtk) [Option]
Option PTO Kit (21 Splines) [Option]
Option Auxiliary Control Valve Kit (Elec.5th) [Option]
Option Coupler Kit (Front Hyd. OutletElec.) (Pipe) [Option]
Option Coupler Kit (Front Hyd. OutletElec.) (CouplerPipe) [Option]
Option Top Link Kit (Hydraulic) [Option]
Option Drawbar Kit (Coupling K80) [Option]
Option Drawbar Kit (Fix Piton) [Option]
Option Front Fender Kit (W410) [Option]
Option Rear Over Fender Kit [Option]
Option Mirror Kit (Heat) [Option]
