Kubota Tractor M7060DTHC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota M7060DTHC Tractor
Number of Pages: 336 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhau St Valve
Braço / Rocker Arm Shaft
Tampa Cabeça / Head Cover
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Compensador / Balancer
Volante Motor / Flywheel
Filtro Gasoleo / Fuel Filter
Injector E Vela Aquecimento / Injector And Glow P Lug
Common Rail / Common Rail
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Bomba Agua / Water Pump
Flange Filtro Ar / Air Cleaner Flange And Throttl E Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Tubo Agua Valvula Egr / Egr Water Piping
Filtro Ar [Peças Componentes] / Air Cleaner [Comp Onent Parts]
Tubo Aspiracao / Inlet Pipe
Panela Escape / Muffler Pipe
Silenciador Do Filtro De Partículas Diesel / Dies El Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peças Componentes] / Diesel Particulate Filter Muffler [ Component Parts]
Sensor Escape / Muffler Sensor
Tubo Pressao / Pressure Pipe
Separador Oleo / Oil Separator
Separador Oleo [Componentes] / Oil Separator [Com Ponent Parts]
Turbo Separador Oleo / Oil Separator Pipe
Tubo Oleo (Turbo) / Oil Pipe (Turbo Charger)
Radiador Oleo / Oil Cooler
Kit Junta (Superior) / Upper Gasket Kit
Kit Junta (Inferior) / Lower Gasket Kit
Componentes Electricos Motor / Engine Electrical Parts
Deposito Combustivel / Fuel Ta Nk
Fornecimento Combustivel [Velh O] / Fuel Filler [Old]
Fornecimento Combustivel [Novo ] / Fuel Supply [New]
Tubo Combustivel (Filtro/Bomba ) / Fuel Pipe (Filter/Supply Pump)
Arrefecedor Gasoleo / Fuel Coo Ler
Separador / Separator
Suporte V Entilador / Fan Bracket
Ventoinha / Fan
Tubo Agua / Water Pipe
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Interruptor/Sensor (Abaste Ca Unidade) / Switch/Sensor (Fuel Unit/Horn)
Interruptor/Sensor (Maquin A) / Switch/Sensor (Engine)
Interruptor/Sensor (Carter Embraiagem/Caixa Velocidades) / Switch/Sensor (Clu Tch Housing/Transmission Case)
Interruptor (Painel) / Swi Tch (Panel Board)
Comutador (Painel) / Switc H (Panel)
Rele / Relay
Unidade Control Electrico / Electronic Control Unit
Painel / Panel Board
Luzes Frente / Head Light
Farol Frente [Peças Compon Entes] / Head Light [Component Parts]
Luzes Frontais / Front Com Bination Light
Luzes Trabalho/Luz De Bali Za / Working Light/Beacon Light
Braco Traseiro / Rear Comb Ination Light
Ficha Reboque / Trailer So Cket
Luz Interior / Room Light
Alta Voz Radio / Radio Spe Aker
Deposito Limpa Parabrisas / Washer Tank
Escova Limpa Vidro Frontal / Front Wiper
Cablagem Electrica (Crs) / Electrical Wiring (Crs)
Cablagem Eletrcia (Frente) / Electrical Wiring (Engine)
Cablagem Electrica (Princi Pal) / Electrical Wiring (Main)
Cabalagem Eletrica (Cabine ) / Electrical Wiring (Cab)
Valvula Inversor / Shuttle Valve
Carretos Inversor / Shuttle Gear Case
Tampa / Shift Cov Er
Carter Transmissa O / Transmission Case Rear Cover
Carter Eixo Trase Iro (Drt) / Rear Axle Case Rh
Carter Eixo Trase Iro (Esq) / Rear Axle Case Lh
Disco Amortecedor / Damper Disk
Cabo Embraiagem / Clutch Cable
Valvula (Inversor ) / Valve Lever (Clutch)
Veio Primario / I Nput Shaft
Embraiagem Invers Or (Inversor) [Peças Componentes] / Clutch Pack (Sh Uttle) [Component Parts]
Veio Inversor / S Huttle Shaft
Primeiro Veio / F Irst Shaft
Terceiro Veio / T Hird Shaft
Veio / Drive Shaf T
Veio Creeper / Cr Eep Shaft
Grupo Conico / Be Vel Gear
Diferencial Trase Iro / Rear Differential
Veio Tdf / Pto Pr Opeller Shaft
Embraiagem Tdf / Pto Clutch
Embraiagem Tdf [P Eças Componentes] / Pto Clutch [Component Parts]
Veio Tdf / Pto Sh Aft
Embraiagem Andame Nto / Front Drive Clutch
Veio Embraiagem [ Peças Componentes] / Front Drive Clutch [Component Parts]
Forquet A / Main Gear Shift Fork
Forquet A Caixa / Creeper / Range Gear Shift Fork/Creep Gea R Shift Fork
Alavanc A / Rear Differential Lock Shift Fork
Alavanc A Velocidades / Main Gear Shift Lever
Tirante / Main Gear Shift Rod
Cabo In Versor / Shuttle Cable
Gama E Tirante Caixa Creep / Range And Creep Gear Shift Le Ver
Alavanc A Tdf / Pto Gear Shift Lever
Eixo Traseiro / Rear A Xle
Travao (Drt) / Brake R H
Travao (Esq) / Brake L H
Tirante Travao Mao / P Arking Brake Rod
Veio Bloqueio / Parkin G Brake Camshaft
Pedal Travao / Brake P Edal
Cilindro Travao Princi Pal / Brake Master Cylinder
Cilindro Travao Princi Pal [Peças Componentes] / Brake Master Cylinder [Co Mponent Parts]
Tubo Travao / Brake Pi Pe
Suporte Eixo Dianteiro / Fro Nt Axle Bracket
Veio Primario / Propeller Sh Aft
Grupo Conico Frente (Frente) / Bevel Gear (Front)
Diferencial Dianteiro / Fron T Differential
Caixas Engrenagens Conica (D Rt) / Bevel Gear Case Rh
Caixas Engrenagens Conica (E Sq) / Bevel Gear Case Lh
Carter Eixo Frente (Drt) / F Ront Axle Case Rh
Carter Eixo Frente (Esq) / F Ront Axle Case Lh
Carreto Diferencial (Drt) / Differential Gear Shaft Rh
Carreto Diferencial (Esq) / Differential Gear Shaft Lh
Veio Transmissao (Drt) / Fro Nt Axle Rh
Veio Transmissao (Esq) / Fro Nt Axle Lh
Pedal Inclinacao / Tilt Pedal
Junta / Steering Joint
Distribuidor Direcção / Steering Controller
Distribuidor Direcção [Peças Componentes] / Steering Controller [Component Parts]
Rotula/Cilindro Direcção / Tie Rod/Steering Cylinder
Cilindro Direcção [Peças Componentes] / Stee Ring Cylinder [Component Parts]
Bomba Hidraulico / Hydraul Ic Pump
Bomba Hidraulico [Peças Co Mponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo (Entrega) / Hydr Aulic Oil Line (Delivery)
Circuito Oleo Direcção (Di Reccao/Tdf) / Hydraulic Oil Line (Steering/Pto)
Tubo Oleo (Inversor/Contro Lador) / Hydraulic Oil Line (Shuttle/Controller)
Tubo Direccao (Entrega) / Steering Hose (Delivery)
Tubo Valvula Solenoide / S Olenoid Valve Pipe
Caixa Cilindro Hidraulico / Hydraulic Cylinder Case
Hidraulico Braços / Hydrau Lic Lift Arm
Valvula Segurança / Safety Valve/Relief Valve
Trinco / Lowering Lock Lev Er
Alavanca Control Posicao / Position Control Lever
Alavanca Control Esforço / Draft And Position Control Lever
Suporte Alavanca / Draft A Nd Position Control Rod
Veio Posicao Esforço / Pos Ition And Draft Shaft
Alimente Alavanca Atras / Feed Back Lever
Distribuidor Auxiliar / Au Xiliary Control Vakve
Valvula Auxiliar (S/D) [Pe Ças Componentes] / Auxiliary Control Valve (Single/ Double) [Component Parts]
Valvula Auxiliar (Scd) [Pe Ças Componentes] / Auxiliary Control Valve (Scd) [C Omponent Parts]
Alavanca Valvula Auxiliar (Primeiro) / Auxiliary Control Valve Lever (1st)
Alavanca Valvula Auxiliar (Segundo) / Auxiliary Control Valve Lever (2nd)
Cilindro Auxiliar De Eleva Cao (Esq) / 3p-Lift Assist Cylinder Lh
Cilindro Auxiliar De Eleva Cao (Drt) / 3p-Lift Assist Cylinder Rh
Cilindro Auxiliar De Eleva Cao [Peças Componentes] / 3p-Lift Assist Cylinder [ Component Parts]
Parte Superior / Top Link Bracket
Ligac Ao Superior / Top Link
Ligac Ao Inferior / Lower Link
Estab Ilizador / Stabilizer
Estab Ilizador (Drt) / Lift Rod Rh
Barra / Drawbar Bracket
Prote Ccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior (Absorvente Sao/Isolador) / H Ood (Bonnet) Upper (Sound Absorber/Insulator)
Trico Capot / Bonnet Lock
Estrutura Cabine / Cab Frame
Degrau / Step
Para Brisas / Front Glass
Porta (Drt) / Door Rh
Trinco Porta (Drt) / Door Lock Rh
Trinco Porta (Esq) / Door Lock Lh
Lado Vidro / Side Window
Vidro Traseiro / Rear Window
Tecto Interior / Inner Roof
Tejadilho Exterior / Outer Roof
Piso / Floor Mat
Chapa Inspecção / Inspection Plate
Cobertura Guarda Lamas (Drt) / Fender Cover Rh
Cobertura Gurada Lamas (Esq) / Fender Cover Lh
Guarda Lamas / Fender
Suporte Cabine (Frente) / Cab Bracket Front
Suporte Cabine Parte Traseira / Cab Bracket Rear
Caixa Ferramenta / Tool Box
Ar Condicionado / Air Conditio Ner
Tubo Ar Condicionado / Air Con Ditioner Duct
Modo Caixa / Mode Case
Entradas Ar Painel Instrumento S / Dashboard Air Outlets
Circulaçao Ar Interior / Inner Air Recirculation
Condesador / Condenser
Tubo Ar Condicionado/Tubo Cond Ensador / Air Conditioner Hose / Condenser Hose
Compressor / Compressor
Etiqueta (Parte Traseira) / Label (Rear)
Acessorios / Accessories
Panela Escape [Opçao] / Upper Muffler Kit [Option ]
Kit Ecu [Opçao] / Ecu Kit [Option]
Kit Alternador (Alternador) [Opçao] / Alternator Kit (Alternator) [Option]
Kit Alternador (Cablagem Electrica) [Opçao] / Alt Ernator Kit (Wire Harness) [Option]
Alternador [Peças Componentes] [Opçao] / Alternat Or [Component Parts] [Option]
Kit Farios Trabalho [Opçao] / Working Light Kit [ Option]
Desempanador (Alternador) [Opçao] / Rear Defogger Kit (Alternator) [Option]
Desempanador (Vidro) [Opçao] / Rear Defogger Kit (Glass) [Option]
Desempanador (Cablagem Electrica) [Opçao] / Rear Defogger Kit (Wire Harness) [Option]
Kit Limpa Vidro Traseiros [Opçao] / Rear Wiper Ki T [Option]
Kit Fusivel [Opção] / Fuse Kit [Option]
Kit Suspensão [Opçao] / Implement Monitor Stay Ki T [Option]
Kit Conversao Tdf 540/1000 [Opçao] / Pto(540/1000 ) Conversion Kit [Option]
Kit De Atualização Para Embraiagem 4x4 [Opção] / 4wd Clutch Upgrade Kit [Option]
Embraiagem 4x4 [Peças Componentes] [Opção] / 4wd Clutch [Component Parts] [Option]
Apoio [Opçao] / Front Bumper Kit [Option]
Kit Valvula Control Auxiliar (Scd) [Opçao] / Auxi Liary Control Valve Kit (Scd) [Option]
Kit Valvula Control Auxiliar (Fd) [Opçao] / Auxil Iary Control Valve Kit (Fd) [Option]
Kit Valvula Control Auxiliar (Fc) [Opçao] / Auxil Iary Control Valve Kit (Fc) [Option]
Valvula Auxiliar (Fd) [Peças Componentes] [Opção] / Auxiliary Control Valve (Fd) [Component Parts] [ Option]
Valvula Auxiliar (Fc) [Peças Componentes] [Opção] / Auxiliary Control Valve (Fc) [Component Parts] [ Option]
Kit Alavanca Serviços Externos (Terço) [Opçao] / Auxiliary Control Valve Lever Kit (3rd) [Option]
Kit Valvula Travao Reboque 1 (Valvula/Tubo) [Opça O] / Trailer Brake Valve Kit 1 (Valve/Pipe) [Option ]
Kit Valvula Travao Reboque 2 (Tubo) [Opçao] / Tra Iler Brake Valve Kit 2 (Pipe) [Option]
